[U-Boot] [RFC PATCH 08/21] dm: core: Add a post_bind method for parents
Allow parent drivers to be called when a new child is bound to them. This allows a bus to set up information it needs for that child.
drivers/core/device.c | 12 ++++++++++++ include/dm/device.h | 2 ++ test/dm/bus.c | 35 +++++++++++++++++++++++++++++++++++ 3 files changed, 49 insertions(+)
diff --git a/drivers/core/device.c b/drivers/core/device.c index 8791688..aa54575 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -111,12 +111,24 @@ int device_bind(struct udevice *parent, struct driver *drv, const char *name, if (ret) goto fail_bind; } + if (parent && parent->driver->child_post_bind) { + ret = parent->driver->child_post_bind(dev); + if (ret) + goto fail_child_post_bind; + } + if (parent) dm_dbg("Bound device %s to %s\n", dev->name, parent->name); *devp = dev;
+fail_child_post_bind: + if (drv->unbind && drv->unbind(dev)) { + dm_warn("unbind() method failed on dev '%s' on error path\n", + dev->name); + } + fail_bind: if (uclass_unbind_device(dev)) { dm_warn("Failed to unbind dev '%s' on error path\n", diff --git a/include/dm/device.h b/include/dm/device.h index 096d84b..50f1b4f 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -132,6 +132,7 @@ struct udevice_id { * @remove: Called to remove a device, i.e. de-activate it * @unbind: Called to unbind a device from its driver * @ofdata_to_platdata: Called before probe to decode device tree data + * @child_post_bind: Called after a new child has been bound * @child_pre_probe: Called before a child device is probed. The device has * memory allocated but it has not yet been probed. * @child_post_remove: Called after a child device is removed. The device @@ -168,6 +169,7 @@ struct driver { int (*remove)(struct udevice *dev); int (*unbind)(struct udevice *dev); int (*ofdata_to_platdata)(struct udevice *dev); + int (*child_post_bind)(struct udevice *dev); int (*child_pre_probe)(struct udevice *dev); int (*child_post_remove)(struct udevice *dev); int priv_auto_alloc_size; diff --git a/test/dm/bus.c b/test/dm/bus.c index 26b8293..e18a6f7 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -17,6 +17,7 @@ DECLARE_GLOBAL_DATA_PTR;
struct dm_test_parent_platdata { int count; + int bind_flag; };
enum { @@ -31,6 +32,16 @@ static int testbus_drv_probe(struct udevice *dev) return dm_scan_fdt_node(dev, gd->fdt_blob, dev->of_offset, false); }
+static int testbus_child_post_bind(struct udevice *dev) +{ + struct dm_test_parent_platdata *plat; + + plat = dev_get_parent_platdata(dev); + plat->bind_flag = 1; + + return 0; +} + static int testbus_child_pre_probe(struct udevice *dev) { struct dm_test_parent_data *parent_data = dev_get_parentdata(dev); @@ -64,6 +75,7 @@ U_BOOT_DRIVER(testbus_drv) = { .of_match = testbus_ids, .id = UCLASS_TEST_BUS, .probe = testbus_drv_probe, + .child_post_bind = testbus_child_post_bind, .priv_auto_alloc_size = sizeof(struct dm_test_priv), .platdata_auto_alloc_size = sizeof(struct dm_test_pdata), .per_child_auto_alloc_size = sizeof(struct dm_test_parent_data), @@ -380,3 +392,26 @@ static int dm_test_bus_parent_platdata_uclass(struct dm_test_state *dms) } DM_TEST(dm_test_bus_parent_platdata_uclass, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test that the child post_bind method is called */ +static int dm_test_bus_child_post_bind(struct dm_test_state *dms) +{ + struct dm_test_parent_platdata *plat; + struct udevice *bus, *dev; + int child_count; + + ut_assertok(uclass_get_device(UCLASS_TEST_BUS, 0, &bus)); + for (device_find_first_child(bus, &dev), child_count = 0; + dev; + device_find_next_child(&dev)) { + /* Check that platform data is allocated */ + plat = dev_get_parent_platdata(dev); + ut_assert(plat != NULL); + ut_asserteq(1, plat->bind_flag); + child_count++; + } + ut_asserteq(3, child_count); + + return 0; +} +DM_TEST(dm_test_bus_child_post_bind, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
