[PATCH] riscv: k210: Reduce DMA block size
Although the max DMA size supported by the hardware register is 22 bits (or 4M), the Linux driver for this device only supports transfers of up to 2M. On a device with 8M total memory, I don't think it will make too much of a difference.
Reported-by: Damien Le Moal Damien.LeMoal@wdc.com Signed-off-by: Sean Anderson seanga2@gmail.com ---
arch/riscv/dts/k210.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/riscv/dts/k210.dtsi b/arch/riscv/dts/k210.dtsi index 84cff51c36..2e1e2683c1 100644 --- a/arch/riscv/dts/k210.dtsi +++ b/arch/riscv/dts/k210.dtsi @@ -199,8 +199,8 @@ dma-channels = <6>; snps,dma-masters = <2>; snps,data-width = <5>; - snps,block-size = <0x400000 0x400000 0x400000 - 0x400000 0x400000 0x400000>; + snps,block-size = <0x200000 0x200000 0x200000 + 0x200000 0x200000 0x200000>; snps,axi-max-burst-len = <256>; status = "disabled"; };
Reviewed-by: Rick Chen rick@andestech.com
Rick Chen
Sean Anderson
