[PATCH u-boot-marvell] ARM: dts: armada-385-turris-omnia: rename node in -u-boot.dtsi file
The SPI NOR flash node name in main device tree for Turris Omnia is called `spi-nor@0`.
Rename node spi-flash@0 in Turris Omnia's -u-boot.dtsi file to spi-nor@0 so that U-Boot does not try to probe the same SPI NOR device multiple times.
Signed-off-by: Marek Behún marek.behun@nic.cz Cc: Stefan Roese sr@denx.de --- arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi index 1b46797583..af0655daaa 100644 --- a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi +++ b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi @@ -41,10 +41,7 @@ &spi0 { u-boot,dm-pre-reloc;
- spi-flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <40000000>; + spi-nor@0 { u-boot,dm-pre-reloc; }; };
Thanks, Stefan
- spi-flash@0 {
reg = <0>;
- spi-nor@0 { u-boot,dm-pre-reloc; }; };
Viele Grüße, Stefan
Reviewed-by: Pali Rohár pali@kernel.org
- spi-flash@0 {
reg = <0>;
2.26.2
- spi-flash@0 {
reg = <0>;
Applied to u-boot-marvell/master
Thanks, Stefan
Marek Behún
Pali Rohár
Stefan Roese
