[U-Boot] [PATCH 1/2] cpuat91: unbreak ethernet
* the following problems are met : config was set to use the new driver as a default but - RMII was not enabled for the new driver - the new driver didn't compile with RMII enabled - the new driver initialize a PHY at address O when the PHY of this board is at 1 thus we get "AT91 EMAC RMII: No PHY present"
* to fix these problems, this patch : - enable RMII for the new driver - fix the wrong define used in the at91_emac.c - allow the config file to set a default phy address (and use 0 as a default as in the actual at91_emac.c driver)
Signed-off-by: Eric Bénard eric@eukrea.com --- drivers/net/at91_emac.c | 24 ++++++++++++++---------- include/configs/cpuat91.h | 9 +++------ 2 files changed, 17 insertions(+), 16 deletions(-)
diff --git a/drivers/net/at91_emac.c b/drivers/net/at91_emac.c index 2399569..1ebcf05 100644 --- a/drivers/net/at91_emac.c +++ b/drivers/net/at91_emac.c @@ -53,6 +53,10 @@ Please decrease the CONFIG_SYS_RX_ETH_BUFFER value #endif
+#ifndef CONFIG_DRIVER_AT91EMAC_PHYADDR +#define CONFIG_DRIVER_AT91EMAC_PHYADDR 0 +#endif + /* MDIO clock must not exceed 2.5 MHz, so enable MCK divider */ #if (AT91C_MASTER_CLOCK > 80000000) #define HCLK_DIV AT91_EMAC_CFG_MCLK_64 @@ -198,12 +202,12 @@ static int at91emac_phy_reset(struct eth_device *netdev) emac = (at91_emac_t *) netdev->iobase;
adv = ADVERTISE_CSMA | ADVERTISE_ALL; - at91emac_write(emac, 0, MII_ADVERTISE, adv); + at91emac_write(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_ADVERTISE, adv); VERBOSEP("%s: Starting autonegotiation...\n", netdev->name); - at91emac_write(emac, 0, MII_BMCR, (BMCR_ANENABLE | BMCR_ANRESTART)); + at91emac_write(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_BMCR, (BMCR_ANENABLE | BMCR_ANRESTART));
for (i = 0; i < 100000 / 100; i++) { - at91emac_read(emac, 0, MII_BMSR, &status); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_BMSR, &status); if (status & BMSR_ANEGCOMPLETE) break; udelay(100); @@ -229,13 +233,13 @@ static int at91emac_phy_init(struct eth_device *netdev) emac = (at91_emac_t *) netdev->iobase;
/* Check if the PHY is up to snuff... */ - at91emac_read(emac, 0, MII_PHYSID1, &phy_id); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_PHYSID1, &phy_id); if (phy_id == 0xffff) { printf("%s: No PHY present\n", netdev->name); return 1; }
if (!(status & BMSR_LSTATUS)) { /* Try to re-negotiate if we don't have link already. */ @@ -243,7 +247,7 @@ static int at91emac_phy_init(struct eth_device *netdev) return 2;
for (i = 0; i < 100000 / 100; i++) { - at91emac_read(emac, 0, MII_BMSR, &status); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_BMSR, &status); if (status & BMSR_LSTATUS) break; udelay(100); @@ -253,8 +257,8 @@ static int at91emac_phy_init(struct eth_device *netdev) VERBOSEP("%s: link down\n", netdev->name); return 3; } else { - at91emac_read(emac, 0, MII_ADVERTISE, &adv); - at91emac_read(emac, 0, MII_LPA, &lpa); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_ADVERTISE, &adv); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_LPA, &lpa); media = mii_nway_result(lpa & adv); speed = (media & (ADVERTISE_100FULL | ADVERTISE_100HALF) ? 1 : 0); @@ -271,7 +275,7 @@ int at91emac_UpdateLinkSpeed(at91_emac_t *emac) { unsigned short stat1;
- at91emac_read(emac, 0, MII_BMSR, &stat1); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_BMSR, &stat1);
if (!(stat1 & BMSR_LSTATUS)) /* link status up? */ return 1; @@ -372,7 +376,7 @@ static int at91emac_init(struct eth_device *netdev, bd_t *bd) value = AT91_EMAC_CFG_CAF | AT91_EMAC_CFG_NBC | HCLK_DIV; #ifdef CONFIG_RMII - value |= AT91C_EMAC_RMII; + value |= AT91_EMAC_CFG_RMII; #endif writel(value, &emac->cfg);
diff --git a/include/configs/cpuat91.h b/include/configs/cpuat91.h index b4fda76..049298c 100644 --- a/include/configs/cpuat91.h +++ b/include/configs/cpuat91.h @@ -131,15 +131,12 @@ (CONFIG_SYS_MEMTEST_START + PHYS_SDRAM_SIZE - 512 * 1024)
#define CONFIG_NET_MULTI 1 -#ifdef CONFIG_NET_MULTI #define CONFIG_DRIVER_AT91EMAC 1 #define CONFIG_SYS_RX_ETH_BUFFER 8 -#else -#define CONFIG_DRIVER_ETHER 1 -#endif +#define CONFIG_RMII 1 +#define CONFIG_MII 1 +#define CONFIG_DRIVER_AT91EMAC_PHYADDR 1 #define CONFIG_NET_RETRY_COUNT 20 -#define CONFIG_AT91C_USE_RMII 1 -#define CONFIG_PHY_ADDRESS (1 << 5) #define CONFIG_KS8721_PHY 1
#define CONFIG_SYS_FLASH_CFI 1
convert the board to the new soc architecture update default config i2c upgrade taken from eb_cpux9k2.h & board/BuS/eb_cpux9k2/cpux9k2.c
Signed-off-by: Eric Bénard eric@eukrea.com --- Makefile | 2 +- board/eukrea/cpuat91/cpuat91.c | 53 ++++++++++++++++----------------------- include/configs/cpuat91.h | 45 +++++++++++++++++++++++---------- 3 files changed, 54 insertions(+), 46 deletions(-)
diff --git a/Makefile b/Makefile index c26e491..ffc749d 100644 --- a/Makefile +++ b/Makefile @@ -2693,7 +2693,7 @@ CPUAT91_RAM_config \ CPUAT91_config : unconfig @mkdir -p $(obj)include @echo "#define CONFIG_$(@:_config=) 1" >$(obj)include/config.h - @$(MKCONFIG) -a cpuat91 arm arm920t cpuat91 eukrea at91rm9200 + @$(MKCONFIG) -a cpuat91 arm arm920t cpuat91 eukrea at91
csb637_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t csb637 NULL at91rm9200 diff --git a/board/eukrea/cpuat91/cpuat91.c b/board/eukrea/cpuat91/cpuat91.c index 0017962..cd4d42c 100644 --- a/board/eukrea/cpuat91/cpuat91.c +++ b/board/eukrea/cpuat91/cpuat91.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2006 Eukrea Electromatique <www.eukrea.com> + * (C) Copyright 2006-2010 Eukrea Electromatique <www.eukrea.com> * Eric Benard eric@eukrea.com * based on at91rm9200dk.c which is : * (C) Copyright 2002 @@ -27,13 +27,11 @@
#include <common.h> #include <netdev.h> -#include <asm/arch/AT91RM9200.h> -#include <asm/io.h>
-#if defined(CONFIG_DRIVER_ETHER) -#include <at91rm9200_net.h> -#include <ks8721.h> -#endif +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/at91_pio.h> +#include <asm/arch/at91_pmc.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -61,31 +59,7 @@ int dram_init(void) return 0; }
-#if defined(CONFIG_DRIVER_ETHER) -#if defined(CONFIG_CMD_NET) - -/* - * Name: - * at91rm9200_GetPhyInterface - * Description: - * Initialise the interface functions to the PHY - * Arguments: - * None - * Return value: - * None - */ -void at91rm9200_GetPhyInterface(AT91PS_PhyOps p_phyops) -{ - p_phyops->Init = ks8721_initphy; - p_phyops->IsPhyConnected = ks8721_isphyconnected; - p_phyops->GetLinkSpeed = ks8721_getlinkspeed; - p_phyops->AutoNegotiate = ks8721_autonegotiate; -} - -#endif /* CONFIG_CMD_NET */ -#endif /* CONFIG_DRIVER_ETHER */ #ifdef CONFIG_DRIVER_AT91EMAC - int board_eth_init(bd_t *bis) { int rc = 0; @@ -93,3 +67,20 @@ int board_eth_init(bd_t *bis) return rc; } #endif + +#ifdef CONFIG_SOFT_I2C +void i2c_init_board(void) +{ + u32 pin; + at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; + + writel(1 << AT91_ID_PIOA, &pmc->pcer); + pin = AT91_PMX_AA_TWD | AT91_PMX_AA_TWCK; + writel(pin, &pio->pioa.idr); + writel(pin, &pio->pioa.pudr); + writel(pin, &pio->pioa.per); + writel(pin, &pio->pioa.oer); + writel(pin, &pio->pioa.sodr); +} +#endif diff --git a/include/configs/cpuat91.h b/include/configs/cpuat91.h index 049298c..b012782 100644 --- a/include/configs/cpuat91.h +++ b/include/configs/cpuat91.h @@ -1,5 +1,5 @@ /* - * CPUAT91 by (C) Copyright 2006 Eric Benard + * CPUAT91 by (C) Copyright 2006-2010 Eric Benard * eric@eukrea.com * * Configuration settings for the CPUAT91 board. @@ -23,15 +23,12 @@ * MA 02111-1307 USA */
-#ifndef __CONFIG_H -#define __CONFIG_H - -#define CONFIG_AT91_LEGACY +#ifndef _CONFIG_CPUAT91_H +#define _CONFIG_CPUAT91_H
#ifdef CONFIG_CPUAT91_RAM #define CONFIG_SKIP_LOWLEVEL_INIT 1 #define CONFIG_SKIP_RELOCATE_UBOOT 1 -#define CONFIG_CPUAT91 1 #else #define CONFIG_BOOTDELAY 1 #endif @@ -43,6 +40,7 @@
#define CONFIG_ARM920T 1 #define CONFIG_AT91RM9200 1 +#define CONFIG_CPUAT91 1
#undef CONFIG_USE_IRQ #define USE_920T_MMU 1 @@ -89,16 +87,36 @@ #undef CONFIG_USART0 #undef CONFIG_USART1
-#define CONFIG_HARD_I2C 1 +#undef CONFIG_HARD_I2C +#define CONFIG_SOFT_I2C 1 +#define AT91_PIN_SDA (1<<25) +#define AT91_PIN_SCL (1<<26) + +#define CONFIG_SYS_I2C_INIT_BOARD 1 +#define CONFIG_SYS_I2C_SPEED 50000 +#define CONFIG_SYS_I2C_SLAVE 0 + +#define I2C_INIT i2c_init_board(); +#define I2C_ACTIVE writel(AT91_PMX_AA_TWD, &pio->pioa.mddr); +#define I2C_TRISTATE writel(AT91_PMX_AA_TWD, &pio->pioa.mder); +#define I2C_READ ((readl(&pio->pioa.pdsr) & AT91_PMX_AA_TWD) != 0) +#define I2C_SDA(bit) \ + if (bit) \ + writel(AT91_PMX_AA_TWD, &pio->pioa.sodr); \ + else \ + writel(AT91_PMX_AA_TWD, &pio->pioa.codr); +#define I2C_SCL(bit) \ + if (bit) \ + writel(AT91_PMX_AA_TWCK, &pio->pioa.sodr); \ + else \ + writel(AT91_PMX_AA_TWCK, &pio->pioa.codr); + +#define I2C_DELAY udelay(2500000/CONFIG_SYS_I2C_SPEED)
-#if defined(CONFIG_HARD_I2C) -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0 #define CONFIG_SYS_I2C_EEPROM_ADDR 0x54 #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 -#endif
#define CONFIG_BOOTP_BOOTFILESIZE 1 #define CONFIG_BOOTP_BOOTPATH 1 @@ -117,10 +135,8 @@ #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_NFS
-#if defined(CONFIG_HARD_I2C) #define CONFIG_CMD_EEPROM 1 #define CONFIG_CMD_I2C 1 -#endif
#define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM 0x20000000 @@ -148,6 +164,7 @@ #define PHYS_FLASH_1 0x10000000 #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 #define CONFIG_SYS_MAX_FLASH_SECT 128 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT
#if defined(CONFIG_CMD_USB) #define CONFIG_USB_OHCI_NEW 1 @@ -230,4 +247,4 @@ "flashboot=run ramargs;bootm 10040000\0" \ "netboot=run ramargs;tftpboot 21000000 cpuat91/uImage;" \ "bootm 21000000\0" -#endif /* __CONFIG_H */ +#endif /* _CONFIG_CPUAT91_H */
Hi Eric,
On 6/10/2010 2:50 PM, Eric Bénard wrote:
- the following problems are met :
- to fix these problems, this patch :
Signed-off-by: Eric Bénarderic@eukrea.com
- /* MDIO clock must not exceed 2.5 MHz, so enable MCK divider */ #if (AT91C_MASTER_CLOCK> 80000000) #define HCLK_DIV AT91_EMAC_CFG_MCLK_64
- at91emac_write(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_ADVERTISE, adv); VERBOSEP("%s: Starting autonegotiation...\n", netdev->name);
- at91emac_write(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_BMCR, (BMCR_ANENABLE | BMCR_ANRESTART));
This line's too long. Please check the other ones too. Try to keep less than 78 characters.
for (i = 0; i< 100000 / 100; i++) {
at91emac_read(emac, 0, MII_BMSR,&status);
if (status& BMSR_ANEGCOMPLETE) break; udelay(100);at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_BMSR,&status);
- at91emac_read(emac, 0, MII_PHYSID1,&phy_id);
- at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_PHYSID1,&phy_id); if (phy_id == 0xffff) { printf("%s: No PHY present\n", netdev->name); return 1; }
- at91emac_read(emac, 0, MII_BMSR,&status);
if (!(status& BMSR_LSTATUS)) { /* Try to re-negotiate if we don't have link already. */
at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_BMSR,&status); if (status& BMSR_LSTATUS) break; udelay(100);
at91emac_read(emac, 0, MII_ADVERTISE,&adv);
at91emac_read(emac, 0, MII_LPA,&lpa);
at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_ADVERTISE,&adv);
media = mii_nway_result(lpa& adv); speed = (media& (ADVERTISE_100FULL | ADVERTISE_100HALF) ? 1 : 0);at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_LPA,&lpa);
- at91emac_read(emac, 0, MII_BMSR,&stat1);
at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_BMSR,&stat1);
if (!(stat1& BMSR_LSTATUS)) /* link status up? */ return 1;
- value |= AT91_EMAC_CFG_RMII; #endif writel(value,&emac->cfg);
#define CONFIG_NET_MULTI 1 -#ifdef CONFIG_NET_MULTI #define CONFIG_DRIVER_AT91EMAC 1 #define CONFIG_SYS_RX_ETH_BUFFER 8 -#else -#define CONFIG_DRIVER_ETHER 1 -#endif +#define CONFIG_RMII 1 +#define CONFIG_MII 1 +#define CONFIG_DRIVER_AT91EMAC_PHYADDR 1 #define CONFIG_NET_RETRY_COUNT 20 -#define CONFIG_AT91C_USE_RMII 1 -#define CONFIG_PHY_ADDRESS (1<< 5) #define CONFIG_KS8721_PHY 1
regards, Ben
Signed-off-by: Eric Bénard eric@eukrea.com --- v2 : fix line lengths
drivers/net/at91_emac.c | 32 ++++++++++++++++++++++---------- include/configs/cpuat91.h | 9 +++------ 2 files changed, 25 insertions(+), 16 deletions(-)
diff --git a/drivers/net/at91_emac.c b/drivers/net/at91_emac.c index 2399569..cf0a7c0 100644 --- a/drivers/net/at91_emac.c +++ b/drivers/net/at91_emac.c @@ -53,6 +53,10 @@ Please decrease the CONFIG_SYS_RX_ETH_BUFFER value #endif
+#ifndef CONFIG_DRIVER_AT91EMAC_PHYADDR +#define CONFIG_DRIVER_AT91EMAC_PHYADDR 0 +#endif + /* MDIO clock must not exceed 2.5 MHz, so enable MCK divider */ #if (AT91C_MASTER_CLOCK > 80000000) #define HCLK_DIV AT91_EMAC_CFG_MCLK_64 @@ -198,12 +202,15 @@ static int at91emac_phy_reset(struct eth_device *netdev) emac = (at91_emac_t *) netdev->iobase;
adv = ADVERTISE_CSMA | ADVERTISE_ALL; - at91emac_write(emac, 0, MII_ADVERTISE, adv); + at91emac_write(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, + MII_ADVERTISE, adv); VERBOSEP("%s: Starting autonegotiation...\n", netdev->name); - at91emac_write(emac, 0, MII_BMCR, (BMCR_ANENABLE | BMCR_ANRESTART)); + at91emac_write(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, MII_BMCR, + (BMCR_ANENABLE | BMCR_ANRESTART));
for (i = 0; i < 100000 / 100; i++) { - at91emac_read(emac, 0, MII_BMSR, &status); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, + MII_BMSR, &status); if (status & BMSR_ANEGCOMPLETE) break; udelay(100); @@ -229,13 +236,15 @@ static int at91emac_phy_init(struct eth_device *netdev) emac = (at91_emac_t *) netdev->iobase;
/* Check if the PHY is up to snuff... */ - at91emac_read(emac, 0, MII_PHYSID1, &phy_id); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, + MII_PHYSID1, &phy_id); if (phy_id == 0xffff) { printf("%s: No PHY present\n", netdev->name); return 1; }
if (!(status & BMSR_LSTATUS)) { /* Try to re-negotiate if we don't have link already. */ @@ -243,7 +252,8 @@ static int at91emac_phy_init(struct eth_device *netdev) return 2;
for (i = 0; i < 100000 / 100; i++) { - at91emac_read(emac, 0, MII_BMSR, &status); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, + MII_BMSR, &status); if (status & BMSR_LSTATUS) break; udelay(100); @@ -253,8 +263,10 @@ static int at91emac_phy_init(struct eth_device *netdev) VERBOSEP("%s: link down\n", netdev->name); return 3; } else { - at91emac_read(emac, 0, MII_ADVERTISE, &adv); - at91emac_read(emac, 0, MII_LPA, &lpa); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, + MII_ADVERTISE, &adv); + at91emac_read(emac, CONFIG_DRIVER_AT91EMAC_PHYADDR, + MII_LPA, &lpa); media = mii_nway_result(lpa & adv); speed = (media & (ADVERTISE_100FULL | ADVERTISE_100HALF) ? 1 : 0); @@ -271,7 +283,7 @@ int at91emac_UpdateLinkSpeed(at91_emac_t *emac) { unsigned short stat1;
if (!(stat1 & BMSR_LSTATUS)) /* link status up? */ return 1; @@ -372,7 +384,7 @@ static int at91emac_init(struct eth_device *netdev, bd_t *bd) value = AT91_EMAC_CFG_CAF | AT91_EMAC_CFG_NBC | HCLK_DIV; #ifdef CONFIG_RMII - value |= AT91C_EMAC_RMII; + value |= AT91_EMAC_CFG_RMII; #endif writel(value, &emac->cfg);
Hi Eric,
Applied to net/next repo.
regards, Ben
Ben Warren
Eric Bénard
