[U-Boot] [PATCH 0/2] dm: i2c: make request sequence number optional and disable it for UniPhier
Masahiro Yamada (2): dm: i2c: make request sequence number optional ARM: UniPhier: disable DM_I2C_REQ_ALIAS to drop I2C aliases
arch/arm/dts/uniphier-ph1-ld4-ref.dts | 4 ---- arch/arm/dts/uniphier-ph1-pro4-ref.dts | 6 ------ arch/arm/dts/uniphier-ph1-sld8-ref.dts | 4 ---- common/cmd_i2c.c | 2 +- configs/ph1_ld4_defconfig | 1 + configs/ph1_pro4_defconfig | 1 + configs/ph1_sld8_defconfig | 1 + drivers/i2c/Kconfig | 10 ++++++++++ drivers/i2c/i2c-uclass-compat.c | 2 +- drivers/i2c/i2c-uclass.c | 4 +++- include/i2c.h | 17 +++++++++++++++++ 11 files changed, 35 insertions(+), 17 deletions(-)
For I2C (and some other uclasses), all the devices are required to have their own request sequence numbers to use them. Otherwise, uclass_get_device_by_seq() fails to get them. To specify those numbers, we have to add aliases to device trees. As a result, the "aliases" nodes grow bigger and bigger as we support more and more drivers in driver model. (See arch/arm/dts/uniphier-ph1-pro4-ref.dts for example.)
It is true that the sequence number is useful for identifying a device with the same number independently of the binding order, but it is painful to add an alias to every device.
This commit intends to make this feature optional. If CONFIG_DM_I2C_SEQ_ALIAS is not defined, uclass_get_device() is called instead of uclass_get_device_by_seq(). So we do not have to add aliases of I2C devices.
In most cases, this should work well enough because device trees are scanned from top to bottom and we usually describe device nodes in the order we expect for binding.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
common/cmd_i2c.c | 2 +- drivers/i2c/Kconfig | 10 ++++++++++ drivers/i2c/i2c-uclass-compat.c | 2 +- drivers/i2c/i2c-uclass.c | 4 +++- include/i2c.h | 17 +++++++++++++++++ 5 files changed, 32 insertions(+), 3 deletions(-)
diff --git a/common/cmd_i2c.c b/common/cmd_i2c.c index fe8f77a..5fc927a 100644 --- a/common/cmd_i2c.c +++ b/common/cmd_i2c.c @@ -138,7 +138,7 @@ static int cmd_i2c_set_bus_num(unsigned int busnum) struct udevice *bus; int ret;
- ret = uclass_get_device_by_seq(UCLASS_I2C, busnum, &bus); + ret = i2c_get_bus(busnum, &bus); if (ret) { debug("%s: No bus %d\n", __func__, busnum); return ret; diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 2cc776c..5c778ec 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -13,6 +13,16 @@ config DM_I2C enabled together (it is not possible to use driver model for one and not the other).
+config DM_I2C_SEQ_ALIAS + bool "Use aliases for numbering I2C buses" + depends on DM_I2C + default y + help + If this option is enabled, each I2C bus is numbered base on its + alias in the device tree to identify a device with the same number + all the time. Otherwise, I2C buses are numbered as they are scanned + at binding. + config SYS_I2C_UNIPHIER bool "UniPhier I2C driver" depends on ARCH_UNIPHIER && DM_I2C diff --git a/drivers/i2c/i2c-uclass-compat.c b/drivers/i2c/i2c-uclass-compat.c index 223f238..35736e8 100644 --- a/drivers/i2c/i2c-uclass-compat.c +++ b/drivers/i2c/i2c-uclass-compat.c @@ -35,7 +35,7 @@ int i2c_probe(uint8_t chip_addr) struct udevice *bus, *dev; int ret;
- ret = uclass_get_device_by_seq(UCLASS_I2C, cur_busnum, &bus); + ret = i2c_get_bus(UCLASS_I2C, cur_busnum, &bus); if (ret) { debug("Cannot find I2C bus %d: err=%d\n", cur_busnum, ret); return ret; diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index a6991bf..0992737 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -289,7 +289,7 @@ int i2c_get_chip_for_busnum(int busnum, int chip_addr, uint offset_len, struct udevice *bus; int ret;
- ret = uclass_get_device_by_seq(UCLASS_I2C, busnum, &bus); + ret = i2c_get_bus(busnum, &bus); if (ret) { debug("Cannot find I2C bus %d\n", busnum); return ret; @@ -457,7 +457,9 @@ static int i2c_child_post_bind(struct udevice *dev) UCLASS_DRIVER(i2c) = { .id = UCLASS_I2C, .name = "i2c", +#ifdef CONFIG_DM_I2C_SEQ_ALIAS .flags = DM_UC_FLAG_SEQ_ALIAS, +#endif .post_bind = i2c_post_bind, .post_probe = i2c_post_probe, .per_device_auto_alloc_size = sizeof(struct dm_i2c_bus), diff --git a/include/i2c.h b/include/i2c.h index 31b0389..6941df6 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -410,6 +410,23 @@ int i2c_get_chip(struct udevice *bus, uint chip_addr, uint offset_len, struct udevice **devp);
/** + * i2c_get_bus() - get an I2C bus + * + * This returns the bus for the given bus number. + * + * @busnum: Bus number. If CONFIG_DM_I2C_SEQ_ALIAS is enabled, this is a + * sequence number. Otherwise, it is a simple index. + * @devp: Stores pointer to a new bus if found + */ +#ifdef CONFIG_DM_I2C_SEQ_ALIAS +#define i2c_get_bus(busnum, devp) \ + uclass_get_device_by_seq(UCLASS_I2C, busnum, devp) +#else +#define i2c_get_bus(busnum, devp) \ + uclass_get_device(UCLASS_I2C, busnum, devp) +#endif + +/** * i2c_get_chip() - get a device to use to access a chip on a bus number * * This returns the device for the given chip address on a particular bus
Hi Masahiro,
On 20 February 2015 at 04:38, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
That tends to me the standard. If you look at the .dts files in the kernel they have aliases. I didn't see any Uniphier dts files in there though.
As of recently the sequence numbers should be assigned sensibly (0, 1, 2...) even without aliases. What do you see when you type 'dm uclass' on your board?
depends on DM_I2C
default y
help
at binding.
- i2c_get_bus() - get an I2C bus
- This returns the bus for the given bus number.
- @busnum: Bus number. If CONFIG_DM_I2C_SEQ_ALIAS is enabled, this is a
- @devp: Stores pointer to a new bus if found
I would prefer a solution that sits inside driver model itself. Once I have a response to the above question we can see if this is possible.
- i2c_get_chip() - get a device to use to access a chip on a bus number
- This returns the device for the given chip address on a particular bus
-- 1.9.1
Hi Simon,
On Mon, 23 Feb 2015 11:01:02 -0700 Simon Glass sjg@chromium.org wrote:
Hi Masahiro,
This is a problem for of my company. We are still using the locally hacked kernel that has not been mainlined yet.
(BTW, before me, U-Boot was also locally hacked in an ugly way...)
It would not be a problem to have some aliases, but I was just wondering if we must have an alias for every device.
If this is the standardized way, that's OK.
The following was displayed. No sequence number was displayed for I2C.
=> dm uclass uclass 0: root - * root_driver @ 9fb52028
Cannot find uclass for id 1: please add the UCLASS_DRIVER() declaration for this UCLASS_... id Cannot find uclass for id 2: please add the UCLASS_DRIVER() declaration for this UCLASS_... id Cannot find uclass for id 3: please add the UCLASS_DRIVER() declaration for this UCLASS_... id Cannot find uclass for id 4: please add the UCLASS_DRIVER() declaration for this UCLASS_... id Cannot find uclass for id 5: please add the UCLASS_DRIVER() declaration for this UCLASS_... id Cannot find uclass for id 6: please add the UCLASS_DRIVER() declaration for this UCLASS_... id uclass 7: simple_bus - * soc @ 9fb520a0 - systembus@00000000 @ 9fb520f8
Cannot find uclass for id 8: please add the UCLASS_DRIVER() declaration for this UCLASS_... id uclass 9: serial - * serial@54006800 @ 9fb52170, 0 - serial@54006900 @ 9fb521d8, 1
Cannot find uclass for id 10: please add the UCLASS_DRIVER() declaration for this UCLASS_... id Cannot find uclass for id 11: please add the UCLASS_DRIVER() declaration for this UCLASS_... id Cannot find uclass for id 12: please add the UCLASS_DRIVER() declaration for this UCLASS_... id Cannot find uclass for id 13: please add the UCLASS_DRIVER() declaration for this UCLASS_... id Cannot find uclass for id 14: please add the UCLASS_DRIVER() declaration for this UCLASS_... id uclass 15: i2c - i2c@58400000 @ 9fb52260
uclass 16: i2c_generic uclass 17: i2c_eeprom - eeprom @ 9fb522d8
Cannot find uclass for id 18: please add the UCLASS_DRIVER() declaration for this UCLASS_... id
depends on DM_I2C
default y
help
at binding.
I understand your thought. I take this series back and I marked it as RFC.
Best Regards Masahiro Yamada
Hi Masahiro, On Feb 23, 2015 8:16 PM, "Masahiro Yamada" yamada.m@jp.panasonic.com wrote:
Hi Simon,
Hi Masahiro,
OK, this command displays ->req_seq. Can you check ->seq after you probe the device?
- root_driver @ 9fb52028
- soc @ 9fb520a0
uclass 9: serial
- serial@54006800 @ 9fb52170, 0
uclass 15: i2c
- eeprom @ 9fb522d8
busnum)
depends on DM_I2C
default y
help
its
number
are scanned
at binding.
ret);
return ret;
*dev)
this is a
devp)
Sorry I can't test right now. But I wonder if we could/should build your logic into a new function ? I need to think about it too.
In our use cases, it would not be so troublesome to use the bus number given by the binding order.
arch/arm/dts/uniphier-ph1-ld4-ref.dts | 4 ---- arch/arm/dts/uniphier-ph1-pro4-ref.dts | 6 ------ arch/arm/dts/uniphier-ph1-sld8-ref.dts | 4 ---- configs/ph1_ld4_defconfig | 1 + configs/ph1_pro4_defconfig | 1 + configs/ph1_sld8_defconfig | 1 + 6 files changed, 3 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/uniphier-ph1-ld4-ref.dts b/arch/arm/dts/uniphier-ph1-ld4-ref.dts index d479be1..9c24bbf 100644 --- a/arch/arm/dts/uniphier-ph1-ld4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-ld4-ref.dts @@ -30,10 +30,6 @@ serial1 = &uart1; serial2 = &uart2; serial3 = &uart3; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; }; };
diff --git a/arch/arm/dts/uniphier-ph1-pro4-ref.dts b/arch/arm/dts/uniphier-ph1-pro4-ref.dts index 685b5a6..c76a837 100644 --- a/arch/arm/dts/uniphier-ph1-pro4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-pro4-ref.dts @@ -30,12 +30,6 @@ serial1 = &uart1; serial2 = &uart2; serial3 = &uart3; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c5 = &i2c5; - i2c6 = &i2c6; }; };
diff --git a/arch/arm/dts/uniphier-ph1-sld8-ref.dts b/arch/arm/dts/uniphier-ph1-sld8-ref.dts index 0cb9c47..3399ed2 100644 --- a/arch/arm/dts/uniphier-ph1-sld8-ref.dts +++ b/arch/arm/dts/uniphier-ph1-sld8-ref.dts @@ -30,10 +30,6 @@ serial1 = &uart1; serial2 = &uart2; serial3 = &uart3; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; }; };
diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig index 52bbe9b..4d06a2b 100644 --- a/configs/ph1_ld4_defconfig +++ b/configs/ph1_ld4_defconfig @@ -36,6 +36,7 @@ CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_DM_SERIAL=y CONFIG_UNIPHIER_SERIAL=y CONFIG_DM_I2C=y +# CONFIG_DM_I2C_SEQ_ALIAS is not set CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index 1517f3c..e2a7d36 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -36,6 +36,7 @@ CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_DM_SERIAL=y CONFIG_UNIPHIER_SERIAL=y CONFIG_DM_I2C=y +# CONFIG_DM_I2C_SEQ_ALIAS is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig index e3ce5cc..394ce71 100644 --- a/configs/ph1_sld8_defconfig +++ b/configs/ph1_sld8_defconfig @@ -36,6 +36,7 @@ CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_DM_SERIAL=y CONFIG_UNIPHIER_SERIAL=y CONFIG_DM_I2C=y +# CONFIG_DM_I2C_SEQ_ALIAS is not set CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y
Masahiro Yamada
