[PATCH v2 00/32] spl: Preparation for Universal Payload
This series tidies up SPL a little and adds some core ofnode functions needed to support Universal Payload. It also includes a few minor fix-ups for sandbox.
For SPL the changes include CONFIG naming, removing various #ifdefs and tidying up the FIT code.
One notable piece of the ofnode improvements is support for flattening a livetree. This should be useful in future as we move FDT fixups to use the ofnode API.
Changes in v2: - Rename based on Tom's feedback - Improve readability by moving the size part to the header file - Explicitly copy two maintainers as it seems only Mario was auto-cc'd - Change the approach to use the header file - Use the same condition for both pieces to avoid possible problems - No changes as it still seems unclear what should be done
Michal Simek (1): dm: core: support reading a single indexed u64 value
Simon Glass (31): spl: Use CONFIG_SPL... instead of CONFIG_..._SPL_... spl: Rename SYS_SPL_ARGS_ADDR to SPL_PAYLOAD_ARGS_ADDR spl: Avoid #ifdef with CONFIG_SPL_SYS_MALLOC spl: mx6: powerpc: Drop the condition on timer_init() spl: Drop #ifdefs for BOARD_INIT and watchdog spl: Avoid #ifdef with CONFIG_SPL_PAYLOAD_ARGS_ADDR spl: Drop the switch() statement for OS selection spl: Avoid an #ifdef when printing gd->malloc_ptr spl: Remove #ifdefs with BOOTSTAGE spl: Rename spl_load_fit_image() to load_simple_fit() spl: Move the full FIT code to spl_fit.c spl: Use the correct FIT_..._PROP constants spl: Move bloblist writing until the image is known dm: core: Reverse the argument order in ofnode_copy_props() dm: core: Ensure we run flattree tests on ofnode dm: core: Tidy up comments in the ofnode tests dm: core: Add a function to create an empty tree dm: core: Add a way to copy a node dm: core: Add a way to delete a node dm: core: Add a way to convert a devicetree to a dtb dm: core: Support writing a boolean dm: core: Support writing a 64-bit value dm: core: Add tests for oftree_path() sandbox: Move reading the RAM buffer into a better place sandbox: Init the EC properly even if no state file is available sandbox: Only read the state if we have a state file sandbox: Move the bloblist down a little in memory bloblist: Support initing from multiple places fdt: Allow the devicetree to come from a bloblist command: Include a required header in command.h pci: serial: Support reading PCI-register size with base
Kconfig | 2 +- README | 2 +- arch/arm/cpu/armv7/ls102xa/fdt.c | 2 +- .../armv8/fsl-layerscape/doc/README.falcon | 2 +- arch/sandbox/cpu/start.c | 27 +- arch/sandbox/cpu/state.c | 2 + arch/sandbox/dts/test.dts | 7 +- boot/vbe_request.c | 2 +- boot/vbe_simple_os.c | 2 +- common/Kconfig | 2 +- common/bloblist.c | 15 +- common/board_f.c | 4 +- common/spl/Kconfig | 16 +- common/spl/Kconfig.nxp | 2 +- common/spl/spl.c | 222 ++++----------- common/spl/spl_ext.c | 4 +- common/spl/spl_fat.c | 4 +- common/spl/spl_fit.c | 127 +++++++-- common/spl/spl_mmc.c | 2 +- common/spl/spl_nand.c | 10 +- common/spl/spl_nor.c | 8 +- common/spl/spl_spi.c | 2 +- common/spl/spl_ubi.c | 2 +- common/spl/spl_xip.c | 2 +- configs/am335x_baltos_defconfig | 4 +- configs/am335x_boneblack_vboot_defconfig | 4 +- configs/am335x_evm_defconfig | 4 +- configs/am335x_evm_spiboot_defconfig | 4 +- configs/am335x_guardian_defconfig | 4 +- configs/am335x_hs_evm_defconfig | 4 +- configs/am335x_hs_evm_uart_defconfig | 4 +- configs/am335x_igep003x_defconfig | 4 +- configs/am335x_pdu001_defconfig | 4 +- configs/am335x_shc_defconfig | 4 +- configs/am335x_shc_ict_defconfig | 4 +- configs/am335x_shc_netboot_defconfig | 4 +- configs/am335x_shc_sdboot_defconfig | 4 +- configs/am335x_sl50_defconfig | 4 +- configs/am3517_evm_defconfig | 6 +- configs/am43xx_evm_defconfig | 4 +- configs/am43xx_evm_rtconly_defconfig | 4 +- configs/am43xx_evm_usbhost_boot_defconfig | 4 +- configs/am43xx_hs_evm_defconfig | 4 +- configs/am57xx_evm_defconfig | 4 +- configs/am57xx_hs_evm_defconfig | 4 +- configs/am57xx_hs_evm_usb_defconfig | 4 +- configs/am62ax_evm_r5_defconfig | 6 +- configs/am62x_evm_r5_defconfig | 8 +- configs/am64x_evm_a53_defconfig | 4 +- configs/am64x_evm_r5_defconfig | 8 +- configs/am65x_evm_a53_defconfig | 4 +- configs/am65x_evm_r5_defconfig | 8 +- configs/am65x_evm_r5_usbdfu_defconfig | 8 +- configs/am65x_evm_r5_usbmsc_defconfig | 8 +- configs/am65x_hs_evm_a53_defconfig | 4 +- configs/am65x_hs_evm_r5_defconfig | 8 +- configs/apalis-tk1_defconfig | 8 +- configs/apalis_imx6_defconfig | 2 +- configs/apalis_t30_defconfig | 8 +- configs/axm_defconfig | 8 +- configs/beaver_defconfig | 8 +- configs/bitmain_antminer_s9_defconfig | 4 +- configs/brppt1_mmc_defconfig | 4 +- configs/brppt2_defconfig | 2 +- configs/brsmarc1_defconfig | 4 +- configs/brxre1_defconfig | 4 +- configs/cardhu_defconfig | 8 +- configs/cei-tk1-som_defconfig | 8 +- configs/cgtqmx8_defconfig | 8 +- configs/chiliboard_defconfig | 4 +- configs/cl-som-imx7_defconfig | 2 +- configs/cm_fx6_defconfig | 2 +- configs/cm_t43_defconfig | 4 +- configs/colibri_imx6_defconfig | 2 +- configs/colibri_t20_defconfig | 8 +- configs/colibri_t30_defconfig | 8 +- configs/da850evm_defconfig | 8 +- configs/da850evm_nand_defconfig | 8 +- configs/dalmore_defconfig | 8 +- configs/deneb_defconfig | 8 +- configs/devkit8000_defconfig | 8 +- configs/dh_imx6_defconfig | 2 +- configs/display5_defconfig | 4 +- configs/display5_factory_defconfig | 4 +- configs/dra7xx_evm_defconfig | 4 +- configs/dra7xx_hs_evm_defconfig | 4 +- configs/dra7xx_hs_evm_usb_defconfig | 4 +- configs/draco_defconfig | 6 +- configs/endeavoru_defconfig | 8 +- configs/etamin_defconfig | 6 +- .../gardena-smart-gateway-at91sam_defconfig | 4 +- configs/ge_b1x5v2_defconfig | 2 +- configs/giedi_defconfig | 8 +- configs/grouper_common_defconfig | 8 +- configs/gwventana_emmc_defconfig | 4 +- configs/gwventana_nand_defconfig | 4 +- configs/harmony_defconfig | 8 +- configs/igep00x0_defconfig | 6 +- configs/imx28_xea_defconfig | 2 +- configs/imx6dl_icore_nand_defconfig | 2 +- configs/imx6dl_mamoj_defconfig | 4 +- configs/imx6q_bosch_acc_defconfig | 2 +- configs/imx6q_icore_nand_defconfig | 2 +- configs/imx6q_logic_defconfig | 4 +- configs/imx6qdl_icore_mipi_defconfig | 4 +- configs/imx6qdl_icore_mmc_defconfig | 4 +- configs/imx6qdl_icore_nand_defconfig | 2 +- configs/imx6qdl_icore_rqs_defconfig | 4 +- configs/imx6ul_geam_mmc_defconfig | 2 +- configs/imx6ul_geam_nand_defconfig | 2 +- configs/imx6ul_isiot_emmc_defconfig | 2 +- configs/imx6ul_isiot_nand_defconfig | 2 +- configs/imx6ulz_smm_m2_defconfig | 2 +- configs/imx7_cm_defconfig | 2 +- configs/imx8mm-cl-iot-gate-optee_defconfig | 8 +- configs/imx8mm-cl-iot-gate_defconfig | 8 +- configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 8 +- configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 8 +- configs/imx8mm-mx8menlo_defconfig | 8 +- configs/imx8mm_beacon_defconfig | 8 +- configs/imx8mm_beacon_fspi_defconfig | 8 +- configs/imx8mm_data_modul_edm_sbc_defconfig | 8 +- configs/imx8mm_evk_defconfig | 8 +- configs/imx8mm_evk_fspi_defconfig | 8 +- configs/imx8mm_phg_defconfig | 8 +- configs/imx8mm_venice_defconfig | 6 +- configs/imx8mn_beacon_2g_defconfig | 8 +- configs/imx8mn_beacon_defconfig | 8 +- configs/imx8mn_beacon_fspi_defconfig | 8 +- configs/imx8mn_bsh_smm_s2_defconfig | 8 +- configs/imx8mn_bsh_smm_s2pro_defconfig | 8 +- configs/imx8mn_ddr4_evk_defconfig | 8 +- configs/imx8mn_evk_defconfig | 8 +- configs/imx8mn_var_som_defconfig | 8 +- configs/imx8mn_venice_defconfig | 8 +- configs/imx8mp-icore-mx8mp-edimm2.2_defconfig | 8 +- configs/imx8mp_beacon_defconfig | 8 +- configs/imx8mp_data_modul_edm_sbc_defconfig | 8 +- configs/imx8mp_dhcom_pdk2_defconfig | 8 +- configs/imx8mp_dhcom_pdk3_defconfig | 8 +- configs/imx8mp_evk_defconfig | 8 +- configs/imx8mp_rsb3720a1_4G_defconfig | 8 +- configs/imx8mp_rsb3720a1_6G_defconfig | 8 +- configs/imx8mp_venice_defconfig | 8 +- configs/imx8mq_cm_defconfig | 8 +- configs/imx8mq_evk_defconfig | 8 +- configs/imx8mq_phanbell_defconfig | 8 +- configs/imx8mq_reform2_defconfig | 8 +- configs/imx8qm_mek_defconfig | 8 +- configs/imx8qxp_mek_defconfig | 8 +- configs/imx8ulp_evk_defconfig | 8 +- configs/imx93_11x11_evk_defconfig | 8 +- configs/imx93_11x11_evk_ld_defconfig | 8 +- configs/iot2050_defconfig | 4 +- configs/j7200_evm_a72_defconfig | 4 +- configs/j7200_evm_r5_defconfig | 8 +- configs/j721e_evm_a72_defconfig | 4 +- configs/j721e_evm_r5_defconfig | 8 +- configs/j721s2_evm_a72_defconfig | 4 +- configs/j721s2_evm_r5_defconfig | 8 +- configs/jetson-tk1_defconfig | 8 +- configs/k2e_evm_defconfig | 4 +- configs/k2g_evm_defconfig | 4 +- configs/k2hk_evm_defconfig | 4 +- configs/k2l_evm_defconfig | 4 +- configs/kontron-sl-mx6ul_defconfig | 2 +- configs/kontron-sl-mx8mm_defconfig | 8 +- configs/kontron_pitx_imx8m_defconfig | 8 +- configs/kontron_sl28_defconfig | 2 +- configs/kp_imx6q_tpc_defconfig | 2 +- configs/librem5_defconfig | 8 +- configs/liteboard_defconfig | 2 +- configs/ls1021aiot_sdcard_defconfig | 6 +- configs/ls1021aqds_nand_defconfig | 6 +- configs/ls1021aqds_sdcard_ifc_defconfig | 6 +- configs/ls1021aqds_sdcard_qspi_defconfig | 6 +- configs/ls1021atsn_sdcard_defconfig | 6 +- ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 6 +- configs/ls1021atwr_sdcard_ifc_defconfig | 6 +- configs/ls1021atwr_sdcard_qspi_defconfig | 6 +- configs/ls1043aqds_nand_defconfig | 6 +- configs/ls1043aqds_sdcard_ifc_defconfig | 2 +- configs/ls1043aqds_sdcard_qspi_defconfig | 2 +- configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 6 +- configs/ls1043ardb_nand_defconfig | 6 +- .../ls1043ardb_sdcard_SECURE_BOOT_defconfig | 2 +- configs/ls1043ardb_sdcard_defconfig | 2 +- configs/ls1046aqds_nand_defconfig | 2 +- configs/ls1046aqds_sdcard_ifc_defconfig | 2 +- configs/ls1046aqds_sdcard_qspi_defconfig | 2 +- configs/ls1046ardb_emmc_defconfig | 2 +- configs/ls1046ardb_qspi_spl_defconfig | 4 +- .../ls1046ardb_sdcard_SECURE_BOOT_defconfig | 2 +- configs/ls1046ardb_sdcard_defconfig | 2 +- configs/ls1088aqds_sdcard_ifc_defconfig | 2 +- configs/ls1088aqds_sdcard_qspi_defconfig | 2 +- ...1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1088ardb_sdcard_qspi_defconfig | 2 +- configs/ls2080aqds_nand_defconfig | 2 +- configs/ls2080aqds_sdcard_defconfig | 2 +- configs/ls2080ardb_nand_defconfig | 2 +- configs/mccmon6_nor_defconfig | 4 +- configs/mccmon6_sd_defconfig | 2 +- configs/medcom-wide_defconfig | 8 +- configs/msc_sm2s_imx8mp_defconfig | 8 +- configs/mx6cuboxi_defconfig | 2 +- configs/mx6memcal_defconfig | 2 +- configs/mx6sabreauto_defconfig | 2 +- configs/mx6sabresd_defconfig | 2 +- configs/mx6slevk_spl_defconfig | 2 +- configs/mx6ul_14x14_evk_defconfig | 2 +- configs/mx6ul_9x9_evk_defconfig | 2 +- configs/myir_mys_6ulx_defconfig | 2 +- configs/novena_defconfig | 2 +- configs/nyan-big_defconfig | 8 +- configs/omap35_logic_defconfig | 6 +- configs/omap35_logic_somlv_defconfig | 6 +- configs/omap3_beagle_defconfig | 4 +- configs/omap3_evm_defconfig | 4 +- configs/omap3_logic_defconfig | 6 +- configs/omap3_logic_somlv_defconfig | 6 +- configs/omap4_panda_defconfig | 4 +- configs/omap4_sdp4430_defconfig | 4 +- configs/omapl138_lcdk_defconfig | 8 +- configs/openpiton_riscv64_spl_defconfig | 2 +- configs/opos6uldev_defconfig | 2 +- configs/paz00_defconfig | 8 +- configs/pcm058_defconfig | 2 +- configs/phycore-am335x-r2-regor_defconfig | 4 +- configs/phycore-am335x-r2-wega_defconfig | 4 +- configs/phycore-imx8mm_defconfig | 8 +- configs/phycore-imx8mp_defconfig | 8 +- configs/phycore_pcl063_defconfig | 2 +- configs/phycore_pcl063_ull_defconfig | 2 +- configs/pico-dwarf-imx6ul_defconfig | 2 +- configs/pico-dwarf-imx7d_defconfig | 2 +- configs/pico-hobbit-imx6ul_defconfig | 2 +- configs/pico-hobbit-imx7d_defconfig | 2 +- configs/pico-imx6_defconfig | 2 +- configs/pico-imx6ul_defconfig | 2 +- configs/pico-imx7d_bl33_defconfig | 2 +- configs/pico-imx7d_defconfig | 2 +- configs/pico-imx8mq_defconfig | 8 +- configs/pico-nymph-imx7d_defconfig | 2 +- configs/pico-pi-imx6ul_defconfig | 2 +- configs/pico-pi-imx7d_defconfig | 2 +- configs/plutux_defconfig | 8 +- configs/pxm2_defconfig | 6 +- configs/qemu-riscv32_spl_defconfig | 2 +- configs/qemu-riscv64_spl_defconfig | 2 +- configs/rastaban_defconfig | 6 +- configs/ringneck-px30_defconfig | 2 +- configs/riotboard_defconfig | 4 +- configs/rut_defconfig | 6 +- configs/sama5d27_giantboard_defconfig | 4 +- configs/sama5d27_som1_ek_mmc1_defconfig | 4 +- configs/sama5d27_som1_ek_mmc_defconfig | 4 +- configs/sama5d27_som1_ek_qspiflash_defconfig | 4 +- configs/sama5d27_wlsom1_ek_mmc_defconfig | 4 +- .../sama5d27_wlsom1_ek_qspiflash_defconfig | 4 +- configs/sama5d2_icp_mmc_defconfig | 4 +- configs/sama5d2_xplained_emmc_defconfig | 4 +- configs/sama5d2_xplained_mmc_defconfig | 4 +- configs/sama5d2_xplained_qspiflash_defconfig | 4 +- configs/sama5d2_xplained_spiflash_defconfig | 4 +- configs/sama5d3_xplained_mmc_defconfig | 4 +- configs/sama5d3_xplained_nandflash_defconfig | 4 +- configs/sama5d3xek_mmc_defconfig | 4 +- configs/sama5d3xek_nandflash_defconfig | 4 +- configs/sama5d3xek_spiflash_defconfig | 4 +- configs/sama5d4_xplained_mmc_defconfig | 4 +- configs/sama5d4_xplained_nandflash_defconfig | 4 +- configs/sama5d4_xplained_spiflash_defconfig | 4 +- configs/sama5d4ek_mmc_defconfig | 4 +- configs/sama5d4ek_nandflash_defconfig | 4 +- configs/sama5d4ek_spiflash_defconfig | 4 +- configs/seaboard_defconfig | 8 +- configs/seeed_npi_imx6ull_defconfig | 2 +- configs/sifive_unleashed_defconfig | 2 +- configs/sifive_unmatched_defconfig | 2 +- configs/smartweb_defconfig | 4 +- configs/sniper_defconfig | 6 +- configs/socfpga_agilex_atf_defconfig | 8 +- configs/socfpga_agilex_defconfig | 8 +- configs/socfpga_agilex_vab_defconfig | 8 +- configs/socfpga_arria10_defconfig | 8 +- configs/socfpga_chameleonv3_defconfig | 8 +- configs/socfpga_n5x_atf_defconfig | 8 +- configs/socfpga_n5x_defconfig | 8 +- configs/socfpga_n5x_vab_defconfig | 8 +- configs/socfpga_stratix10_atf_defconfig | 8 +- configs/socfpga_stratix10_defconfig | 8 +- configs/starfive_visionfive2_defconfig | 8 +- configs/stm32746g-eval_spl_defconfig | 2 +- configs/stm32f746-disco_spl_defconfig | 2 +- configs/stm32f769-disco_spl_defconfig | 2 +- ...stm32mp15-icore-stm32mp1-ctouch2_defconfig | 8 +- ...tm32mp15-icore-stm32mp1-edimm2.2_defconfig | 8 +- ...-microgea-stm32mp1-microdev2-of7_defconfig | 8 +- ...mp15-microgea-stm32mp1-microdev2_defconfig | 8 +- configs/stm32mp15_basic_defconfig | 8 +- configs/stm32mp15_dhcom_basic_defconfig | 8 +- configs/stm32mp15_dhcor_basic_defconfig | 8 +- configs/syzygy_hub_defconfig | 6 +- configs/taurus_defconfig | 8 +- configs/tec-ng_defconfig | 8 +- configs/tec_defconfig | 8 +- configs/thuban_defconfig | 6 +- configs/topic_miami_defconfig | 4 +- configs/topic_miamilite_defconfig | 4 +- configs/topic_miamiplus_defconfig | 4 +- configs/transformer_t30_defconfig | 8 +- configs/trimslice_defconfig | 8 +- configs/udoo_defconfig | 2 +- configs/udoo_neo_defconfig | 2 +- configs/variscite_dart6ul_defconfig | 2 +- configs/venice2_defconfig | 8 +- configs/ventana_defconfig | 8 +- configs/verdin-am62_r5_defconfig | 8 +- configs/verdin-imx8mm_defconfig | 8 +- configs/verdin-imx8mp_defconfig | 8 +- configs/vining_2000_defconfig | 2 +- configs/vyasa-rk3288_defconfig | 2 +- configs/wandboard_defconfig | 2 +- configs/x3_t30_defconfig | 8 +- configs/xilinx_zynq_virt_defconfig | 6 +- configs/xilinx_zynqmp_mini_emmc0_defconfig | 8 +- configs/xilinx_zynqmp_mini_emmc1_defconfig | 8 +- configs/xilinx_zynqmp_mini_qspi_defconfig | 8 +- configs/xilinx_zynqmp_virt_defconfig | 10 +- configs/zynq_cse_nand_defconfig | 8 +- configs/zynq_cse_nor_defconfig | 8 +- configs/zynq_cse_qspi_defconfig | 8 +- doc/arch/sandbox/sandbox.rst | 4 +- doc/develop/devicetree/control.rst | 3 + doc/develop/falcon.rst | 2 +- drivers/core/Kconfig | 6 +- drivers/core/fdtaddr.c | 6 +- drivers/core/of_access.c | 81 +++++- drivers/core/ofnode.c | 213 +++++++++++++- drivers/core/read.c | 6 +- drivers/core/util.c | 2 +- drivers/misc/cros_ec_sandbox.c | 9 +- drivers/pci/pci-uclass.c | 2 +- drivers/pci/pci_mvebu.c | 3 +- drivers/pci/pci_tegra.c | 2 +- drivers/pci/pcie_mediatek.c | 4 +- drivers/serial/Kconfig | 2 +- drivers/serial/ns16550.c | 15 +- dts/Kconfig | 8 + include/asm-generic/global_data.h | 11 + include/bloblist.h | 23 ++ include/bootstage.h | 26 ++ include/command.h | 3 + include/configs/socfpga_common.h | 2 +- include/configs/socfpga_soc64_common.h | 2 +- include/dm/fdtaddr.h | 3 +- include/dm/of_access.h | 37 +++ include/dm/ofnode.h | 114 +++++++- include/dm/read.h | 8 +- include/fdtdec.h | 3 +- include/ns16550.h | 4 +- include/of_live.h | 18 ++ include/serial.h | 2 + include/spl.h | 28 +- include/system-constants.h | 20 +- lib/fdtdec.c | 44 ++- lib/of_live.c | 141 ++++++++++ test/dm/ofnode.c | 266 ++++++++++++++++-- test/dm/pci.c | 14 +- test/lib/kconfig.c | 4 +- 371 files changed, 2067 insertions(+), 1138 deletions(-)
Add helper function to allow reading a single indexed u64 value from a device-tree property containing multiple u64 values, that is an array of u64's.
Co-developed-by: Ashok Reddy Soma ashok.reddy.soma@amd.com Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com Signed-off-by: Michal Simek michal.simek@amd.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Simon Glass sjg@chromium.org ---
(no changes since v1)
arch/sandbox/dts/test.dts | 1 + drivers/core/of_access.c | 16 ++++++++++++---- drivers/core/ofnode.c | 30 ++++++++++++++++++++++++++++++ include/dm/of_access.h | 19 +++++++++++++++++++ include/dm/ofnode.h | 12 ++++++++++++ test/dm/ofnode.c | 8 ++++++++ 6 files changed, 82 insertions(+), 4 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 63fda15da764..d4693e3c7a93 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -301,6 +301,7 @@ uint-value = <(-1234)>; int64-value = /bits/ 64 <0x1111222233334444>; int-array = <5678 9123 4567>; + int64-array = /bits/ 64 <0x1111222233334444 0x4444333322221111>; str-value = "test string"; interrupts-extended = <&irq 3 0>; acpi,name = "GHIJ"; diff --git a/drivers/core/of_access.c b/drivers/core/of_access.c index 57f10445b122..1bb4d8eab709 100644 --- a/drivers/core/of_access.c +++ b/drivers/core/of_access.c @@ -570,26 +570,34 @@ int of_read_u32_index(const struct device_node *np, const char *propname, return 0; }
-int of_read_u64(const struct device_node *np, const char *propname, u64 *outp) +int of_read_u64_index(const struct device_node *np, const char *propname, + int index, u64 *outp) { const __be64 *val;
debug("%s: %s: ", __func__, propname); if (!np) return -EINVAL; - val = of_find_property_value_of_size(np, propname, sizeof(*outp)); + + val = of_find_property_value_of_size(np, propname, + sizeof(*outp) * (index + 1)); if (IS_ERR(val)) { debug("(not found)\n"); return PTR_ERR(val); }
- *outp = be64_to_cpup(val); + *outp = be64_to_cpup(val + index); debug("%#llx (%lld)\n", (unsigned long long)*outp, - (unsigned long long)*outp); + (unsigned long long)*outp);
return 0; }
+int of_read_u64(const struct device_node *np, const char *propname, u64 *outp) +{ + return of_read_u64_index(np, propname, 0, outp); +} + int of_property_match_string(const struct device_node *np, const char *propname, const char *string) { diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index a4dc9bde085c..8311282abf69 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -344,6 +344,36 @@ int ofnode_read_u32_index(ofnode node, const char *propname, int index, return 0; }
+int ofnode_read_u64_index(ofnode node, const char *propname, int index, + u64 *outp) +{ + const fdt64_t *cell; + int len; + + assert(ofnode_valid(node)); + + if (ofnode_is_np(node)) + return of_read_u64_index(ofnode_to_np(node), propname, index, + outp); + + cell = fdt_getprop(ofnode_to_fdt(node), ofnode_to_offset(node), + propname, &len); + if (!cell) { + debug("(not found)\n"); + return -EINVAL; + } + + if (len < (sizeof(u64) * (index + 1))) { + debug("(not large enough)\n"); + return -EOVERFLOW; + } + + *outp = fdt64_to_cpu(cell[index]); + debug("%#llx (%lld)\n", *outp, *outp); + + return 0; +} + u32 ofnode_read_u32_index_default(ofnode node, const char *propname, int index, u32 def) { diff --git a/include/dm/of_access.h b/include/dm/of_access.h index c556a18f7d9c..9361d0a87bfb 100644 --- a/include/dm/of_access.h +++ b/include/dm/of_access.h @@ -333,6 +333,25 @@ int of_read_u32(const struct device_node *np, const char *propname, u32 *outp); int of_read_u32_index(const struct device_node *np, const char *propname, int index, u32 *outp);
+/** + * of_read_u64_index() - Find and read a 64-bit value from a multi-value + * property + * + * @np: device node from which the property value is to be read. + * @propname: name of the property to be searched. + * @index: index of the u32 in the list of values + * @outp: pointer to return value, modified only if return value is 0. + * + * Search for a property in a device node and read a 64-bit value from + * it. + * + * Return: + * 0 on success, -EINVAL if the property does not exist, or -EOVERFLOW if the + * property data isn't large enough. + */ +int of_read_u64_index(const struct device_node *np, const char *propname, + int index, u64 *outp); + /** * of_read_u64() - Find and read a 64-bit integer from a property * diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 0f38b3e736de..0a85db31f360 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -434,6 +434,18 @@ int ofnode_read_u32(ofnode node, const char *propname, u32 *outp); int ofnode_read_u32_index(ofnode node, const char *propname, int index, u32 *outp);
+/** + * ofnode_read_u64_index() - Read a 64-bit integer from a multi-value property + * + * @node: valid node reference to read property from + * @propname: name of the property to read from + * @index: index of the integer to return + * @outp: place to put value (if found) + * Return: 0 if OK, -ve on error + */ +int ofnode_read_u64_index(ofnode node, const char *propname, int index, + u64 *outp); + /** * ofnode_read_s32() - Read a 32-bit integer from a property * diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index 6fbebc7da085..b74f5c2ebcff 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -967,6 +967,14 @@ static int dm_test_ofnode_u64(struct unit_test_state *uts) ut_asserteq_64(0x1111222233334444, val); ut_asserteq(-EINVAL, ofnode_read_u64(node, "missing", &val));
+ ut_assertok(ofnode_read_u64_index(node, "int64-array", 0, &val)); + ut_asserteq_64(0x1111222233334444, val); + ut_assertok(ofnode_read_u64_index(node, "int64-array", 1, &val)); + ut_asserteq_64(0x4444333322221111, val); + ut_asserteq(-EOVERFLOW, + ofnode_read_u64_index(node, "int64-array", 2, &val)); + ut_asserteq(-EINVAL, ofnode_read_u64_index(node, "missing", 0, &val)); + return 0; } DM_TEST(dm_test_ofnode_u64, UT_TESTF_SCAN_FDT);
We like to put the SPL first so it is clear that it relates to SPL. Rename various malloc-related options which have crept in, to stick to this convention.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Martyn Welch martyn.welch@collabora.com Reviewed-by: Svyatoslav Ryhel clamor95@gmail.com ---
Kconfig | 2 +- README | 2 +- arch/arm/cpu/armv7/ls102xa/fdt.c | 2 +- common/spl/Kconfig | 14 +++++++------- common/spl/Kconfig.nxp | 2 +- common/spl/spl.c | 6 +++--- common/spl/spl_fit.c | 2 +- configs/am335x_baltos_defconfig | 4 ++-- configs/am335x_boneblack_vboot_defconfig | 4 ++-- configs/am335x_evm_defconfig | 4 ++-- configs/am335x_evm_spiboot_defconfig | 4 ++-- configs/am335x_guardian_defconfig | 4 ++-- configs/am335x_hs_evm_defconfig | 4 ++-- configs/am335x_hs_evm_uart_defconfig | 4 ++-- configs/am335x_igep003x_defconfig | 4 ++-- configs/am335x_pdu001_defconfig | 4 ++-- configs/am335x_shc_defconfig | 4 ++-- configs/am335x_shc_ict_defconfig | 4 ++-- configs/am335x_shc_netboot_defconfig | 4 ++-- configs/am335x_shc_sdboot_defconfig | 4 ++-- configs/am335x_sl50_defconfig | 4 ++-- configs/am3517_evm_defconfig | 4 ++-- configs/am43xx_evm_defconfig | 4 ++-- configs/am43xx_evm_rtconly_defconfig | 4 ++-- configs/am43xx_evm_usbhost_boot_defconfig | 4 ++-- configs/am43xx_hs_evm_defconfig | 4 ++-- configs/am57xx_evm_defconfig | 4 ++-- configs/am57xx_hs_evm_defconfig | 4 ++-- configs/am57xx_hs_evm_usb_defconfig | 4 ++-- configs/am62ax_evm_r5_defconfig | 6 +++--- configs/am62x_evm_r5_defconfig | 8 ++++---- configs/am64x_evm_a53_defconfig | 4 ++-- configs/am64x_evm_r5_defconfig | 8 ++++---- configs/am65x_evm_a53_defconfig | 4 ++-- configs/am65x_evm_r5_defconfig | 8 ++++---- configs/am65x_evm_r5_usbdfu_defconfig | 8 ++++---- configs/am65x_evm_r5_usbmsc_defconfig | 8 ++++---- configs/am65x_hs_evm_a53_defconfig | 4 ++-- configs/am65x_hs_evm_r5_defconfig | 8 ++++---- configs/apalis-tk1_defconfig | 8 ++++---- configs/apalis_imx6_defconfig | 2 +- configs/apalis_t30_defconfig | 8 ++++---- configs/axm_defconfig | 8 ++++---- configs/beaver_defconfig | 8 ++++---- configs/bitmain_antminer_s9_defconfig | 4 ++-- configs/brppt1_mmc_defconfig | 4 ++-- configs/brppt2_defconfig | 2 +- configs/brsmarc1_defconfig | 4 ++-- configs/brxre1_defconfig | 4 ++-- configs/cardhu_defconfig | 8 ++++---- configs/cei-tk1-som_defconfig | 8 ++++---- configs/cgtqmx8_defconfig | 8 ++++---- configs/chiliboard_defconfig | 4 ++-- configs/cl-som-imx7_defconfig | 2 +- configs/cm_fx6_defconfig | 2 +- configs/cm_t43_defconfig | 4 ++-- configs/colibri_imx6_defconfig | 2 +- configs/colibri_t20_defconfig | 8 ++++---- configs/colibri_t30_defconfig | 8 ++++---- configs/da850evm_defconfig | 8 ++++---- configs/da850evm_nand_defconfig | 8 ++++---- configs/dalmore_defconfig | 8 ++++---- configs/deneb_defconfig | 8 ++++---- configs/devkit8000_defconfig | 6 +++--- configs/dh_imx6_defconfig | 2 +- configs/display5_defconfig | 2 +- configs/display5_factory_defconfig | 2 +- configs/dra7xx_evm_defconfig | 4 ++-- configs/dra7xx_hs_evm_defconfig | 4 ++-- configs/dra7xx_hs_evm_usb_defconfig | 4 ++-- configs/draco_defconfig | 6 +++--- configs/endeavoru_defconfig | 8 ++++---- configs/etamin_defconfig | 6 +++--- configs/gardena-smart-gateway-at91sam_defconfig | 4 ++-- configs/ge_b1x5v2_defconfig | 2 +- configs/giedi_defconfig | 8 ++++---- configs/grouper_common_defconfig | 8 ++++---- configs/gwventana_emmc_defconfig | 2 +- configs/gwventana_nand_defconfig | 2 +- configs/harmony_defconfig | 8 ++++---- configs/igep00x0_defconfig | 4 ++-- configs/imx6dl_icore_nand_defconfig | 2 +- configs/imx6dl_mamoj_defconfig | 2 +- configs/imx6q_bosch_acc_defconfig | 2 +- configs/imx6q_icore_nand_defconfig | 2 +- configs/imx6q_logic_defconfig | 2 +- configs/imx6qdl_icore_mipi_defconfig | 2 +- configs/imx6qdl_icore_mmc_defconfig | 2 +- configs/imx6qdl_icore_nand_defconfig | 2 +- configs/imx6qdl_icore_rqs_defconfig | 2 +- configs/imx6ul_geam_mmc_defconfig | 2 +- configs/imx6ul_geam_nand_defconfig | 2 +- configs/imx6ul_isiot_emmc_defconfig | 2 +- configs/imx6ul_isiot_nand_defconfig | 2 +- configs/imx6ulz_smm_m2_defconfig | 2 +- configs/imx7_cm_defconfig | 2 +- configs/imx8mm-cl-iot-gate-optee_defconfig | 8 ++++---- configs/imx8mm-cl-iot-gate_defconfig | 8 ++++---- configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 8 ++++---- configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 8 ++++---- configs/imx8mm-mx8menlo_defconfig | 8 ++++---- configs/imx8mm_beacon_defconfig | 8 ++++---- configs/imx8mm_beacon_fspi_defconfig | 8 ++++---- configs/imx8mm_data_modul_edm_sbc_defconfig | 8 ++++---- configs/imx8mm_evk_defconfig | 8 ++++---- configs/imx8mm_evk_fspi_defconfig | 8 ++++---- configs/imx8mm_phg_defconfig | 8 ++++---- configs/imx8mm_venice_defconfig | 6 +++--- configs/imx8mn_beacon_2g_defconfig | 8 ++++---- configs/imx8mn_beacon_defconfig | 8 ++++---- configs/imx8mn_beacon_fspi_defconfig | 8 ++++---- configs/imx8mn_bsh_smm_s2_defconfig | 8 ++++---- configs/imx8mn_bsh_smm_s2pro_defconfig | 8 ++++---- configs/imx8mn_ddr4_evk_defconfig | 8 ++++---- configs/imx8mn_evk_defconfig | 8 ++++---- configs/imx8mn_var_som_defconfig | 8 ++++---- configs/imx8mn_venice_defconfig | 8 ++++---- configs/imx8mp-icore-mx8mp-edimm2.2_defconfig | 8 ++++---- configs/imx8mp_beacon_defconfig | 8 ++++---- configs/imx8mp_data_modul_edm_sbc_defconfig | 8 ++++---- configs/imx8mp_dhcom_pdk2_defconfig | 8 ++++---- configs/imx8mp_dhcom_pdk3_defconfig | 8 ++++---- configs/imx8mp_evk_defconfig | 8 ++++---- configs/imx8mp_rsb3720a1_4G_defconfig | 8 ++++---- configs/imx8mp_rsb3720a1_6G_defconfig | 8 ++++---- configs/imx8mp_venice_defconfig | 8 ++++---- configs/imx8mq_cm_defconfig | 8 ++++---- configs/imx8mq_evk_defconfig | 8 ++++---- configs/imx8mq_phanbell_defconfig | 8 ++++---- configs/imx8mq_reform2_defconfig | 8 ++++---- configs/imx8qm_mek_defconfig | 8 ++++---- configs/imx8qxp_mek_defconfig | 8 ++++---- configs/imx8ulp_evk_defconfig | 8 ++++---- configs/imx93_11x11_evk_defconfig | 8 ++++---- configs/imx93_11x11_evk_ld_defconfig | 8 ++++---- configs/iot2050_defconfig | 4 ++-- configs/j7200_evm_a72_defconfig | 4 ++-- configs/j7200_evm_r5_defconfig | 8 ++++---- configs/j721e_evm_a72_defconfig | 4 ++-- configs/j721e_evm_r5_defconfig | 8 ++++---- configs/j721s2_evm_a72_defconfig | 4 ++-- configs/j721s2_evm_r5_defconfig | 8 ++++---- configs/jetson-tk1_defconfig | 8 ++++---- configs/k2e_evm_defconfig | 4 ++-- configs/k2g_evm_defconfig | 4 ++-- configs/k2hk_evm_defconfig | 4 ++-- configs/k2l_evm_defconfig | 4 ++-- configs/kontron-sl-mx6ul_defconfig | 2 +- configs/kontron-sl-mx8mm_defconfig | 8 ++++---- configs/kontron_pitx_imx8m_defconfig | 8 ++++---- configs/kontron_sl28_defconfig | 2 +- configs/kp_imx6q_tpc_defconfig | 2 +- configs/librem5_defconfig | 8 ++++---- configs/liteboard_defconfig | 2 +- configs/ls1021aiot_sdcard_defconfig | 6 +++--- configs/ls1021aqds_nand_defconfig | 6 +++--- configs/ls1021aqds_sdcard_ifc_defconfig | 6 +++--- configs/ls1021aqds_sdcard_qspi_defconfig | 6 +++--- configs/ls1021atsn_sdcard_defconfig | 6 +++--- .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 6 +++--- configs/ls1021atwr_sdcard_ifc_defconfig | 6 +++--- configs/ls1021atwr_sdcard_qspi_defconfig | 6 +++--- configs/ls1043aqds_nand_defconfig | 6 +++--- configs/ls1043aqds_sdcard_ifc_defconfig | 2 +- configs/ls1043aqds_sdcard_qspi_defconfig | 2 +- configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 6 +++--- configs/ls1043ardb_nand_defconfig | 6 +++--- configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 2 +- configs/ls1043ardb_sdcard_defconfig | 2 +- configs/ls1046aqds_nand_defconfig | 2 +- configs/ls1046aqds_sdcard_ifc_defconfig | 2 +- configs/ls1046aqds_sdcard_qspi_defconfig | 2 +- configs/ls1046ardb_emmc_defconfig | 2 +- configs/ls1046ardb_qspi_spl_defconfig | 2 +- configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 2 +- configs/ls1046ardb_sdcard_defconfig | 2 +- configs/ls1088aqds_sdcard_ifc_defconfig | 2 +- configs/ls1088aqds_sdcard_qspi_defconfig | 2 +- .../ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1088ardb_sdcard_qspi_defconfig | 2 +- configs/ls2080aqds_nand_defconfig | 2 +- configs/ls2080aqds_sdcard_defconfig | 2 +- configs/ls2080ardb_nand_defconfig | 2 +- configs/mccmon6_nor_defconfig | 2 +- configs/mccmon6_sd_defconfig | 2 +- configs/medcom-wide_defconfig | 8 ++++---- configs/msc_sm2s_imx8mp_defconfig | 8 ++++---- configs/mx6cuboxi_defconfig | 2 +- configs/mx6memcal_defconfig | 2 +- configs/mx6sabreauto_defconfig | 2 +- configs/mx6sabresd_defconfig | 2 +- configs/mx6slevk_spl_defconfig | 2 +- configs/mx6ul_14x14_evk_defconfig | 2 +- configs/mx6ul_9x9_evk_defconfig | 2 +- configs/myir_mys_6ulx_defconfig | 2 +- configs/novena_defconfig | 2 +- configs/nyan-big_defconfig | 8 ++++---- configs/omap35_logic_defconfig | 4 ++-- configs/omap35_logic_somlv_defconfig | 4 ++-- configs/omap3_beagle_defconfig | 4 ++-- configs/omap3_evm_defconfig | 4 ++-- configs/omap3_logic_defconfig | 4 ++-- configs/omap3_logic_somlv_defconfig | 4 ++-- configs/omap4_panda_defconfig | 4 ++-- configs/omap4_sdp4430_defconfig | 4 ++-- configs/omapl138_lcdk_defconfig | 8 ++++---- configs/openpiton_riscv64_spl_defconfig | 2 +- configs/opos6uldev_defconfig | 2 +- configs/paz00_defconfig | 8 ++++---- configs/pcm058_defconfig | 2 +- configs/phycore-am335x-r2-regor_defconfig | 4 ++-- configs/phycore-am335x-r2-wega_defconfig | 4 ++-- configs/phycore-imx8mm_defconfig | 8 ++++---- configs/phycore-imx8mp_defconfig | 8 ++++---- configs/phycore_pcl063_defconfig | 2 +- configs/phycore_pcl063_ull_defconfig | 2 +- configs/pico-dwarf-imx6ul_defconfig | 2 +- configs/pico-dwarf-imx7d_defconfig | 2 +- configs/pico-hobbit-imx6ul_defconfig | 2 +- configs/pico-hobbit-imx7d_defconfig | 2 +- configs/pico-imx6_defconfig | 2 +- configs/pico-imx6ul_defconfig | 2 +- configs/pico-imx7d_bl33_defconfig | 2 +- configs/pico-imx7d_defconfig | 2 +- configs/pico-imx8mq_defconfig | 8 ++++---- configs/pico-nymph-imx7d_defconfig | 2 +- configs/pico-pi-imx6ul_defconfig | 2 +- configs/pico-pi-imx7d_defconfig | 2 +- configs/plutux_defconfig | 8 ++++---- configs/pxm2_defconfig | 6 +++--- configs/qemu-riscv32_spl_defconfig | 2 +- configs/qemu-riscv64_spl_defconfig | 2 +- configs/rastaban_defconfig | 6 +++--- configs/ringneck-px30_defconfig | 2 +- configs/riotboard_defconfig | 2 +- configs/rut_defconfig | 6 +++--- configs/sama5d27_giantboard_defconfig | 4 ++-- configs/sama5d27_som1_ek_mmc1_defconfig | 4 ++-- configs/sama5d27_som1_ek_mmc_defconfig | 4 ++-- configs/sama5d27_som1_ek_qspiflash_defconfig | 4 ++-- configs/sama5d27_wlsom1_ek_mmc_defconfig | 4 ++-- configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 4 ++-- configs/sama5d2_icp_mmc_defconfig | 4 ++-- configs/sama5d2_xplained_emmc_defconfig | 4 ++-- configs/sama5d2_xplained_mmc_defconfig | 4 ++-- configs/sama5d2_xplained_qspiflash_defconfig | 4 ++-- configs/sama5d2_xplained_spiflash_defconfig | 4 ++-- configs/sama5d3_xplained_mmc_defconfig | 4 ++-- configs/sama5d3_xplained_nandflash_defconfig | 4 ++-- configs/sama5d3xek_mmc_defconfig | 4 ++-- configs/sama5d3xek_nandflash_defconfig | 4 ++-- configs/sama5d3xek_spiflash_defconfig | 4 ++-- configs/sama5d4_xplained_mmc_defconfig | 4 ++-- configs/sama5d4_xplained_nandflash_defconfig | 4 ++-- configs/sama5d4_xplained_spiflash_defconfig | 4 ++-- configs/sama5d4ek_mmc_defconfig | 4 ++-- configs/sama5d4ek_nandflash_defconfig | 4 ++-- configs/sama5d4ek_spiflash_defconfig | 4 ++-- configs/seaboard_defconfig | 8 ++++---- configs/seeed_npi_imx6ull_defconfig | 2 +- configs/sifive_unleashed_defconfig | 2 +- configs/sifive_unmatched_defconfig | 2 +- configs/smartweb_defconfig | 4 ++-- configs/sniper_defconfig | 6 +++--- configs/socfpga_agilex_atf_defconfig | 8 ++++---- configs/socfpga_agilex_defconfig | 8 ++++---- configs/socfpga_agilex_vab_defconfig | 8 ++++---- configs/socfpga_arria10_defconfig | 8 ++++---- configs/socfpga_chameleonv3_defconfig | 8 ++++---- configs/socfpga_n5x_atf_defconfig | 8 ++++---- configs/socfpga_n5x_defconfig | 8 ++++---- configs/socfpga_n5x_vab_defconfig | 8 ++++---- configs/socfpga_stratix10_atf_defconfig | 8 ++++---- configs/socfpga_stratix10_defconfig | 8 ++++---- configs/starfive_visionfive2_defconfig | 8 ++++---- configs/stm32mp15-icore-stm32mp1-ctouch2_defconfig | 8 ++++---- .../stm32mp15-icore-stm32mp1-edimm2.2_defconfig | 8 ++++---- ...2mp15-microgea-stm32mp1-microdev2-of7_defconfig | 8 ++++---- ...stm32mp15-microgea-stm32mp1-microdev2_defconfig | 8 ++++---- configs/stm32mp15_basic_defconfig | 8 ++++---- configs/stm32mp15_dhcom_basic_defconfig | 8 ++++---- configs/stm32mp15_dhcor_basic_defconfig | 8 ++++---- configs/syzygy_hub_defconfig | 4 ++-- configs/taurus_defconfig | 8 ++++---- configs/tec-ng_defconfig | 8 ++++---- configs/tec_defconfig | 8 ++++---- configs/thuban_defconfig | 6 +++--- configs/topic_miami_defconfig | 4 ++-- configs/topic_miamilite_defconfig | 4 ++-- configs/topic_miamiplus_defconfig | 4 ++-- configs/transformer_t30_defconfig | 8 ++++---- configs/trimslice_defconfig | 8 ++++---- configs/udoo_defconfig | 2 +- configs/udoo_neo_defconfig | 2 +- configs/variscite_dart6ul_defconfig | 2 +- configs/venice2_defconfig | 8 ++++---- configs/ventana_defconfig | 8 ++++---- configs/verdin-am62_r5_defconfig | 8 ++++---- configs/verdin-imx8mm_defconfig | 8 ++++---- configs/verdin-imx8mp_defconfig | 8 ++++---- configs/vining_2000_defconfig | 2 +- configs/wandboard_defconfig | 2 +- configs/x3_t30_defconfig | 8 ++++---- configs/xilinx_zynq_virt_defconfig | 4 ++-- configs/xilinx_zynqmp_mini_emmc0_defconfig | 8 ++++---- configs/xilinx_zynqmp_mini_emmc1_defconfig | 8 ++++---- configs/xilinx_zynqmp_mini_qspi_defconfig | 8 ++++---- configs/xilinx_zynqmp_virt_defconfig | 8 ++++---- configs/zynq_cse_nand_defconfig | 8 ++++---- configs/zynq_cse_nor_defconfig | 8 ++++---- configs/zynq_cse_qspi_defconfig | 8 ++++---- drivers/core/Kconfig | 6 +++--- drivers/serial/Kconfig | 2 +- include/configs/socfpga_common.h | 2 +- include/configs/socfpga_soc64_common.h | 2 +- include/system-constants.h | 6 +++--- 316 files changed, 794 insertions(+), 794 deletions(-)
diff --git a/Kconfig b/Kconfig index 2d4b82149860..aadb9d145b17 100644 --- a/Kconfig +++ b/Kconfig @@ -308,7 +308,7 @@ config SPL_SYS_MALLOC_F_LEN particular needs this to operate, so that it can allocate the initial serial device and any others that are needed.
- It is possible to enable CFG_SYS_SPL_MALLOC_START to start a new + It is possible to enable CFG_SPL_SYS_MALLOC_START to start a new malloc() region in SDRAM once it is inited.
config TPL_SYS_MALLOC_F_LEN diff --git a/README b/README index 15a19caf740f..a1f90642274d 100644 --- a/README +++ b/README @@ -1297,7 +1297,7 @@ Configuration Settings: - CONFIG_SYS_MALLOC_SIMPLE Provides a simple and small malloc() and calloc() for those boards which do not use the full malloc in SPL (which is - enabled with CONFIG_SYS_SPL_MALLOC). + enabled with CONFIG_SPL_SYS_MALLOC).
- CFG_SYS_BOOTMAPSZ: Maximum size of memory mapped by the startup code of diff --git a/arch/arm/cpu/armv7/ls102xa/fdt.c b/arch/arm/cpu/armv7/ls102xa/fdt.c index a5c5c780ae8a..1c3d24bcad94 100644 --- a/arch/arm/cpu/armv7/ls102xa/fdt.c +++ b/arch/arm/cpu/armv7/ls102xa/fdt.c @@ -136,7 +136,7 @@ void ft_cpu_setup(void *blob, struct bd_info *bd) */ off = fdt_add_mem_rsv(blob, CONFIG_TEXT_BASE - UBOOT_HEAD_LEN, CONFIG_SYS_MONITOR_LEN + - CONFIG_SYS_SPL_MALLOC_SIZE + UBOOT_HEAD_LEN); + CONFIG_SPL_SYS_MALLOC_SIZE + UBOOT_HEAD_LEN); if (off < 0) printf("Failed to reserve memory for SD boot deep sleep: %s\n", fdt_strerror(off)); diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 1c2fe78e3e06..b9d96fbe1355 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -402,21 +402,21 @@ config SPL_SEPARATE_BSS location is used. Normally we put the device tree at the end of BSS but with this option enabled, it goes at _image_binary_end.
-config SYS_SPL_MALLOC +config SPL_SYS_MALLOC bool "Enable malloc pool in SPL" depends on SPL_FRAMEWORK
-config HAS_CUSTOM_SPL_MALLOC_START +config SPL_HAS_CUSTOM_MALLOC_START bool "For the SPL malloc pool, define a custom starting address" - depends on SYS_SPL_MALLOC + depends on SPL_SYS_MALLOC
-config CUSTOM_SYS_SPL_MALLOC_ADDR +config SPL_CUSTOM_SYS_MALLOC_ADDR hex "SPL malloc addr" - depends on HAS_CUSTOM_SPL_MALLOC_START + depends on SPL_HAS_CUSTOM_MALLOC_START
-config SYS_SPL_MALLOC_SIZE +config SPL_SYS_MALLOC_SIZE hex "Size of the SPL malloc pool" - depends on SYS_SPL_MALLOC + depends on SPL_SYS_MALLOC default 0x100000
config SPL_READ_ONLY diff --git a/common/spl/Kconfig.nxp b/common/spl/Kconfig.nxp index fc696cf0cee2..53e9b9f8d341 100644 --- a/common/spl/Kconfig.nxp +++ b/common/spl/Kconfig.nxp @@ -59,7 +59,7 @@ config SPL_RELOC_TEXT_BASE config SPL_RELOC_STACK hex "Address of the start of the stack SPL will use after relocation." help - If unspecified, this is equal to CFG_SYS_SPL_MALLOC_START. Starting + If unspecified, this is equal to CFG_SPL_SYS_MALLOC_START. Starting address of the malloc pool used in SPL. When this option is set the full malloc is used in SPL and it is set up by spl_init() and before that, the simple malloc() can be used if CONFIG_SYS_MALLOC_F is defined. diff --git a/common/spl/spl.c b/common/spl/spl.c index 0062f3f45d9a..1e50043cf77b 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -754,8 +754,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2)
spl_set_bd();
-#if defined(CONFIG_SYS_SPL_MALLOC) - mem_malloc_init(SYS_SPL_MALLOC_START, CONFIG_SYS_SPL_MALLOC_SIZE); +#if defined(CONFIG_SPL_SYS_MALLOC) + mem_malloc_init(SPL_SYS_MALLOC_START, CONFIG_SPL_SYS_MALLOC_SIZE); gd->flags |= GD_FLG_FULL_MALLOC_INIT; #endif if (!(gd->flags & GD_FLG_SPL_INIT)) { @@ -886,7 +886,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) default: debug("Unsupported OS image.. Jumping nevertheless..\n"); } -#if CONFIG_VAL(SYS_MALLOC_F_LEN) && !defined(CONFIG_SYS_SPL_MALLOC_SIZE) +#if CONFIG_VAL(SYS_MALLOC_F_LEN) && !defined(CONFIG_SPL_SYS_MALLOC_SIZE) debug("SPL malloc() used 0x%lx bytes (%ld KB)\n", gd->malloc_ptr, gd->malloc_ptr / 1024); #endif diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 730639f7562c..1bfdc0af4969 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -530,7 +530,7 @@ static void *spl_get_fit_load_buffer(size_t size) buf = malloc_cache_aligned(size); if (!buf) { pr_err("Could not get FIT buffer of %lu bytes\n", (ulong)size); - pr_err("\tcheck CONFIG_SYS_SPL_MALLOC_SIZE\n"); + pr_err("\tcheck CONFIG_SPL_SYS_MALLOC_SIZE\n"); buf = spl_get_load_buffer(0, size); } return buf; diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 6ef3c78390af..c4b8e6785ebb 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -18,8 +18,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run usbboot;run mmcboot;setenv mmcdev 1; setenv bootpart 1:2; run mmcboot;run nandboot;" CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index e581accc2172..531703010ab5 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -23,8 +23,8 @@ CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_BOOTCOMMAND="run findfdt; run init_console; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_MUSB_NEW=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_NET=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index a179f1ed5f21..08e3f22b1fe2 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -20,8 +20,8 @@ CONFIG_BOOTCOMMAND="run findfdt; run init_console; run finduuid; run distro_boot CONFIG_LOGLEVEL=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_ETH=y # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 09d5e803a3e9..e72a936983b3 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -23,8 +23,8 @@ CONFIG_BOOTCOMMAND="run findfdt; run init_console; run finduuid; run distro_boot CONFIG_LOGLEVEL=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FIT_IMAGE_TINY=y # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 7c4085d0849f..01d848ceede1 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -31,8 +31,8 @@ CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index a3a4ab361c31..4f5e2088c566 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -21,8 +21,8 @@ CONFIG_LOGLEVEL=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_MAX_SIZE=0xb0b0 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FIT_IMAGE_TINY=y # CONFIG_SPL_ENV_SUPPORT is not set # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 6e4d327880ce..dc7fc4b0aa40 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -24,8 +24,8 @@ CONFIG_LOGLEVEL=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_MAX_SIZE=0x9ab0 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FIT_IMAGE_TINY=y # CONFIG_SPL_ENV_SUPPORT is not set # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 37e1259a8b15..04ddba706ba5 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -19,8 +19,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt;run mmcboot;run nandboot;run netboot;" CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am335x_pdu001_defconfig b/configs/am335x_pdu001_defconfig index e68efde33b65..557949c651ec 100644 --- a/configs/am335x_pdu001_defconfig +++ b/configs/am335x_pdu001_defconfig @@ -24,8 +24,8 @@ CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_BOOTCOMMAND="run eval_boot_device;part uuid mmc ${mmc_boot}:${root_fs_partition} root_fs_partuuid;setenv bootargs console=${console} vt.global_cursor_default=0 root=PARTUUID=${root_fs_partuuid} rootfstype=ext4 rootwait rootdelay=1;fatload mmc ${mmc_boot} ${fdtaddr} ${fdtfile};fatload mmc ${mmc_boot} ${loadaddr} ${bootfile};bootz ${loadaddr} - ${fdtaddr}" CONFIG_BOARD_LATE_INIT=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_I2C=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 51b25fda643a..c902354863b7 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -33,8 +33,8 @@ CONFIG_BOOTCOMMAND="if mmc dev 1; mmc rescan; then run emmc_setup; else echo ERR CONFIG_DEFAULT_FDT_FILE="am335x-shc" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 5766f71c1c88..1cbb57fb529e 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -31,8 +31,8 @@ CONFIG_BOOTCOMMAND="if mmc dev 0; mmc rescan; then run sd_setup; else echo ERROR CONFIG_DEFAULT_FDT_FILE="am335x-shc" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 5073efa01abd..7ac1ef818703 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -34,8 +34,8 @@ CONFIG_BOOTCOMMAND="run fusecmd; if run netboot; then echo Booting from network; CONFIG_DEFAULT_FDT_FILE="am335x-shc" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index f35df6c23c6e..127f095c02a2 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -34,8 +34,8 @@ CONFIG_BOOTCOMMAND="if mmc dev 0; mmc rescan; then run sd_setup; else echo ERROR CONFIG_DEFAULT_FDT_FILE="am335x-shc" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 44c23019e495..9ba376feda8e 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -23,8 +23,8 @@ CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index fcb0b3d32bc5..dda235492784 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -22,8 +22,8 @@ CONFIG_BOOTDELAY=10 CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device $mmcdev; if run loadbootenv; then run importbootenv; fi; echo Checking if uenvcmd is set ...; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi; echo Running default loadimage ...; setenv bootfile zImage; if run loadimage; then run loadfdt; run mmcboot; fi; else run nandboot; fi" CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 323862009fc3..6571afd345e8 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -18,8 +18,8 @@ CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_MAX_SIZE=0x439e0 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_ETH=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 9cafe9c10c89..e84aed4d54da 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -18,8 +18,8 @@ CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_MAX_SIZE=0x439e0 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 406c0fc2d7c3..0cae3242b045 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -17,8 +17,8 @@ CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_MAX_SIZE=0x37690 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 01428ac7aa73..115ce68d680a 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -24,8 +24,8 @@ CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_MAX_SIZE=0x36100 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_ETH=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 6db59225c280..b4c04acec792 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -30,8 +30,8 @@ CONFIG_AVB_VERIFY=y CONFIG_ANDROID_AB=y CONFIG_SPL_MAX_SIZE=0x7bc00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 94ffce1a9986..d137cc3c57bd 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -33,8 +33,8 @@ CONFIG_AVB_VERIFY=y CONFIG_ANDROID_AB=y CONFIG_SPL_MAX_SIZE=0x7a8b0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 9ed59ac9aecc..4b6815684c1c 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -35,8 +35,8 @@ CONFIG_AVB_VERIFY=y CONFIG_ANDROID_AB=y CONFIG_SPL_MAX_SIZE=0x74eb0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/am62ax_evm_r5_defconfig b/configs/am62ax_evm_r5_defconfig index 05c30cbba194..2c53673debb0 100644 --- a/configs/am62ax_evm_r5_defconfig +++ b/configs/am62ax_evm_r5_defconfig @@ -36,9 +36,9 @@ CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 diff --git a/configs/am62x_evm_r5_defconfig b/configs/am62x_evm_r5_defconfig index 489ee943fe31..ae3789bad3dc 100644 --- a/configs/am62x_evm_r5_defconfig +++ b/configs/am62x_evm_r5_defconfig @@ -43,10 +43,10 @@ CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 718ad176cb36..9c41055b1e90 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -41,8 +41,8 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index b501c17b87a2..ddc41480583c 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -44,10 +44,10 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 4301553af8d2..c3b444884924 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -43,8 +43,8 @@ CONFIG_SPL_BSS_START_ADDR=0x80a00000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index d5196c2024ee..b2f1e721b36d 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -40,10 +40,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0xc00 CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 diff --git a/configs/am65x_evm_r5_usbdfu_defconfig b/configs/am65x_evm_r5_usbdfu_defconfig index 88f68aa70e46..f610b2dd94e3 100644 --- a/configs/am65x_evm_r5_usbdfu_defconfig +++ b/configs/am65x_evm_r5_usbdfu_defconfig @@ -37,10 +37,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0xc00 CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/am65x_evm_r5_usbmsc_defconfig b/configs/am65x_evm_r5_usbmsc_defconfig index 8da49c78c82e..70ba50083b88 100644 --- a/configs/am65x_evm_r5_usbmsc_defconfig +++ b/configs/am65x_evm_r5_usbmsc_defconfig @@ -36,10 +36,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0xc00 CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index 3f9626e45503..ca90eea421af 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -43,8 +43,8 @@ CONFIG_SPL_BSS_START_ADDR=0x80a00000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/am65x_hs_evm_r5_defconfig b/configs/am65x_hs_evm_r5_defconfig index 0c7b53ca2c08..8b3b3fcb136e 100644 --- a/configs/am65x_hs_evm_r5_defconfig +++ b/configs/am65x_hs_evm_r5_defconfig @@ -36,10 +36,10 @@ CONFIG_SPL_BSS_START_ADDR=0x41c7effc CONFIG_SPL_BSS_MAX_SIZE=0xc00 CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index fda85c2d6ae3..59bca77cc658 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -29,10 +29,10 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=32 CONFIG_SYS_CBSIZE=1024 CONFIG_SYS_PBSIZE=1054 diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 5f0f78191c4a..f3062b360a62 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -40,7 +40,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_MISC_INIT_R=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=48 diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 83aab2450bea..b7e87de62e49 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -24,10 +24,10 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=32 CONFIG_SYS_CBSIZE=1024 CONFIG_SYS_PBSIZE=1054 diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 5d6dd2ae9133..00e02e023747 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -45,10 +45,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x600 # CONFIG_SPL_LEGACY_IMAGE_FORMAT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x20ba0000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x460000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x20ba0000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x460000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 0d8a74be7aac..b1fbe55b072a 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -22,10 +22,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2084 # CONFIG_CMD_IMI is not set diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index 3995d41ce1bf..8893358a8843 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -34,8 +34,8 @@ CONFIG_SPL_BSS_START_ADDR=0x100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x2000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x2000000 CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=2075 diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 653620263cd9..165e4d91fcc5 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -37,8 +37,8 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 CONFIG_SPL_I2C=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_POWER=y diff --git a/configs/brppt2_defconfig b/configs/brppt2_defconfig index 05ee4c5797e6..73bc6240068f 100644 --- a/configs/brppt2_defconfig +++ b/configs/brppt2_defconfig @@ -32,7 +32,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run b_default" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_I2C=y CONFIG_SPL_DM_SPI_FLASH=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 94943fccf1ac..419fe4529de3 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -38,8 +38,8 @@ CONFIG_BOARD_TYPES=y CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_I2C=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index b50aef0aad92..3ef35f0a6753 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -34,8 +34,8 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 CONFIG_SPL_I2C=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_POWER=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 4fe4621f0378..e076215f28d4 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -21,10 +21,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2084 # CONFIG_CMD_IMI is not set diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index b920ac2ae402..e7221678dd83 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -25,10 +25,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2086 # CONFIG_CMD_IMI is not set diff --git a/configs/cgtqmx8_defconfig b/configs/cgtqmx8_defconfig index 32e0647c93c0..e699430bf9fc 100644 --- a/configs/cgtqmx8_defconfig +++ b/configs/cgtqmx8_defconfig @@ -36,10 +36,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x1000 # CONFIG_SPL_BINMAN_UBOOT_SYMBOLS is not set CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x120000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x3000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x120000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x3000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SYS_MMCSD_FS_BOOT_PARTITION=0 diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 0c3fd428407c..06642d282d1f 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -24,8 +24,8 @@ CONFIG_BOOTCOMMAND="run mmcboot; run nandboot; run netboot" CONFIG_DEFAULT_FDT_FILE="am335x-chiliboard.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index 2277d19a2d85..69eba97f4e63 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -32,7 +32,7 @@ CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 CONFIG_SPL_BOARD_INIT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x80 CONFIG_SPL_I2C=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 56527dadd0d0..c20e0fb89420 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -33,7 +33,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd; run legacy_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="usb start;sf probe" CONFIG_MISC_INIT_R=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x80 CONFIG_SPL_I2C=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 12d010ab64ba..32c4ec45d4bc 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -33,8 +33,8 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set # CONFIG_MISC_INIT_R is not set CONFIG_SPL_MAX_SIZE=0x37690 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x480 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index be1037b6cbb4..f41895ce704e 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -39,7 +39,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_MISC_INIT_R=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=48 diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index eb2e202f6f26..f6ac66456a03 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -22,10 +22,10 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x90000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x90000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=32 CONFIG_SYS_CBSIZE=1024 CONFIG_SYS_PBSIZE=1055 diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 8098ff7abc1d..31b3ee84a3e4 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -23,10 +23,10 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=32 CONFIG_SYS_CBSIZE=1024 CONFIG_SYS_PBSIZE=1055 diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 2001327ab08a..91f2370a2368 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -46,10 +46,10 @@ CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xc0f70000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x110000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0f70000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x110000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index eddaa49f0f29..5fd0bd13c92a 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -42,10 +42,10 @@ CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xc0f70000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x110000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0f70000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x110000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 92f4436eebd9..5ef9b358673a 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -21,10 +21,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2086 # CONFIG_CMD_IMI is not set diff --git a/configs/deneb_defconfig b/configs/deneb_defconfig index 0d714bd313b1..051de7b5c58a 100644 --- a/configs/deneb_defconfig +++ b/configs/deneb_defconfig @@ -47,10 +47,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x1000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x120000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x3000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x120000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x3000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_POWER_DOMAIN=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index caeb0094cdaf..1431e54dc95e 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -19,9 +19,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_BSS_START_ADDR=0x80000500 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80208000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index c1094b4eda90..e01776c77961 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -39,7 +39,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x11400 CONFIG_SPL_WATCHDOG=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 551e2a97a335..9c4334af15c5 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -39,7 +39,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="if run check_em_pad; then run recovery;else if test ${BOOT_FROM} = FACTORY; then run factory_nfs;else run boot_mmc;fi;fi" CONFIG_MISC_INIT_R=y CONFIG_SPL_BOOTCOUNT_LIMIT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index a5396f7e54cf..67ba7658861a 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -36,7 +36,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="echo SDP Display5 recovery" CONFIG_MISC_INIT_R=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DMA=y CONFIG_SPL_I2C=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 14dff6322155..b61c311d8030 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -30,8 +30,8 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_MAX_SIZE=0x7bc00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 0d6d9efd4e27..d5da5923bbad 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -33,8 +33,8 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_MAX_SIZE=0x7a8b0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 506a65aac3dc..4acb392f0de0 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -34,8 +34,8 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_MAX_SIZE=0x74eb0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/draco_defconfig b/configs/draco_defconfig index b71b23faac79..4966ffd2a047 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -38,9 +38,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_BSS_START_ADDR=0x80000000 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80208000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/endeavoru_defconfig b/configs/endeavoru_defconfig index 38f26f2dcc57..baaa28aac3dd 100644 --- a/configs/endeavoru_defconfig +++ b/configs/endeavoru_defconfig @@ -26,10 +26,10 @@ CONFIG_BOOTCOMMAND="if run check_button; then bootmenu; fi; run bootcmd_mmc0; po CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2084 CONFIG_CMD_BOOTMENU=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 43cfed9fb347..f3a9f712508d 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -39,9 +39,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_BSS_START_ADDR=0x80000000 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80208000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index f6a674018670..439fcc057539 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -43,8 +43,8 @@ CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_RAW_ONLY=y diff --git a/configs/ge_b1x5v2_defconfig b/configs/ge_b1x5v2_defconfig index b3b69a642a49..8f58454175f5 100644 --- a/configs/ge_b1x5v2_defconfig +++ b/configs/ge_b1x5v2_defconfig @@ -39,7 +39,7 @@ CONFIG_LOG_MAX_LEVEL=8 CONFIG_LOG_DEFAULT_LEVEL=4 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_MISC_INIT_R=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x11400 CONFIG_HUSH_PARSER=y diff --git a/configs/giedi_defconfig b/configs/giedi_defconfig index 75d5d89823f0..8b2f7c23e59c 100644 --- a/configs/giedi_defconfig +++ b/configs/giedi_defconfig @@ -47,10 +47,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x1000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x120000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x3000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x120000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x3000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_POWER_DOMAIN=y diff --git a/configs/grouper_common_defconfig b/configs/grouper_common_defconfig index 8dc88851f5a9..e445e64931d2 100644 --- a/configs/grouper_common_defconfig +++ b/configs/grouper_common_defconfig @@ -26,10 +26,10 @@ CONFIG_BOOTCOMMAND="if run check_button; then bootmenu; fi; run bootcmd_mmc0; po CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2084 CONFIG_CMD_BOOTMENU=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 3c558ba7f928..eb29268c6fa7 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -44,7 +44,7 @@ CONFIG_MISC_INIT_R=y CONFIG_PCI_INIT_R=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_DMA=y CONFIG_SPL_I2C=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index a41a89248714..17a86d6447d0 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -44,7 +44,7 @@ CONFIG_MISC_INIT_R=y CONFIG_PCI_INIT_R=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_DMA=y CONFIG_SPL_I2C=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 8b49505a6505..a1dfc0a738f0 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -19,10 +19,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x90000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x90000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2085 # CONFIG_CMD_IMI is not set diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index a0078e15ef40..e0cc39959669 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -20,8 +20,8 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index f4adda5b6d41..856123dc34a7 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -25,7 +25,7 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run $modeboot" -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index 8c7c13ebc88c..933a9d83f344 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -18,7 +18,7 @@ CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_LTO=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_SPL_ARGS_ADDR=0x13000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y diff --git a/configs/imx6q_bosch_acc_defconfig b/configs/imx6q_bosch_acc_defconfig index c44d43aacaf1..05bab034e0f9 100644 --- a/configs/imx6q_bosch_acc_defconfig +++ b/configs/imx6q_bosch_acc_defconfig @@ -35,7 +35,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run mmc_mmc_fit" CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_RAW_IMAGE_SUPPORT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xaa # CONFIG_SPL_CRYPTO is not set CONFIG_SPL_WATCHDOG=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index 3b579bac4603..8e53700e8365 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -26,7 +26,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run $modeboot" -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 74733c4de323..b307fea5f25c 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -29,7 +29,7 @@ CONFIG_BOOTCOMMAND="run autoboot" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL_RAW_IMAGE_SUPPORT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 4fdd891cc3e2..ecb8fb2ba57b 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -34,7 +34,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run $modeboot" CONFIG_SPL_RAW_IMAGE_SUPPORT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 319e808e4696..42889188cc30 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -37,7 +37,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run $modeboot" CONFIG_SPL_RAW_IMAGE_SUPPORT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index 3b579bac4603..8e53700e8365 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -26,7 +26,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run $modeboot" -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 697e4c288032..2ab42979fa60 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -31,7 +31,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run $modeboot" CONFIG_SPL_RAW_IMAGE_SUPPORT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 87d693cff548..857569f99ee8 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -30,7 +30,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run $modeboot" CONFIG_SPL_RAW_IMAGE_SUPPORT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index 0b989e648473..3bf99aedc08b 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -26,7 +26,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run $modeboot" -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index e7242cad981c..73caf9a552c7 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -30,7 +30,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run $modeboot" CONFIG_SPL_RAW_IMAGE_SUPPORT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 8318197fdef2..68a716ce8e4f 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -26,7 +26,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run $modeboot" -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y diff --git a/configs/imx6ulz_smm_m2_defconfig b/configs/imx6ulz_smm_m2_defconfig index f3da19deb078..d6edc7190041 100644 --- a/configs/imx6ulz_smm_m2_defconfig +++ b/configs/imx6ulz_smm_m2_defconfig @@ -23,7 +23,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_BSS_START_ADDR=0x84100000 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/imx7_cm_defconfig b/configs/imx7_cm_defconfig index c43aed4a94c4..30bf4eb3b0ca 100644 --- a/configs/imx7_cm_defconfig +++ b/configs/imx7_cm_defconfig @@ -28,7 +28,7 @@ CONFIG_DEFAULT_FDT_FILE="ask" CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 diff --git a/configs/imx8mm-cl-iot-gate-optee_defconfig b/configs/imx8mm-cl-iot-gate-optee_defconfig index 11fdc7ffe81a..f94be32cf0ac 100644 --- a/configs/imx8mm-cl-iot-gate-optee_defconfig +++ b/configs/imx8mm-cl-iot-gate-optee_defconfig @@ -31,10 +31,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm-cl-iot-gate_defconfig b/configs/imx8mm-cl-iot-gate_defconfig index bdabb80edbb5..92c9b90c2a4c 100644 --- a/configs/imx8mm-cl-iot-gate_defconfig +++ b/configs/imx8mm-cl-iot-gate_defconfig @@ -33,10 +33,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig index 6d283ec562c6..523224820de5 100644 --- a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig +++ b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig @@ -30,10 +30,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_POWER=y diff --git a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig index 38c0c87b22f6..19160437f141 100644 --- a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig +++ b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig @@ -30,10 +30,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_POWER=y diff --git a/configs/imx8mm-mx8menlo_defconfig b/configs/imx8mm-mx8menlo_defconfig index 13bd19515123..6dff20e739d0 100644 --- a/configs/imx8mm-mx8menlo_defconfig +++ b/configs/imx8mm-mx8menlo_defconfig @@ -43,10 +43,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_beacon_defconfig b/configs/imx8mm_beacon_defconfig index 52edb2ed19de..de4ea8496f7c 100644 --- a/configs/imx8mm_beacon_defconfig +++ b/configs/imx8mm_beacon_defconfig @@ -33,10 +33,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_beacon_fspi_defconfig b/configs/imx8mm_beacon_fspi_defconfig index e1b75d6416f2..a3cdd069db72 100644 --- a/configs/imx8mm_beacon_fspi_defconfig +++ b/configs/imx8mm_beacon_fspi_defconfig @@ -36,10 +36,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_data_modul_edm_sbc_defconfig b/configs/imx8mm_data_modul_edm_sbc_defconfig index e2bca406113f..b201d833e5dc 100644 --- a/configs/imx8mm_data_modul_edm_sbc_defconfig +++ b/configs/imx8mm_data_modul_edm_sbc_defconfig @@ -54,10 +54,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig index ac9810fe1b7a..361e81441404 100644 --- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -31,10 +31,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_evk_fspi_defconfig b/configs/imx8mm_evk_fspi_defconfig index 75f0a9502890..2308022053dc 100644 --- a/configs/imx8mm_evk_fspi_defconfig +++ b/configs/imx8mm_evk_fspi_defconfig @@ -34,10 +34,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_phg_defconfig b/configs/imx8mm_phg_defconfig index 9fdce5c8b523..23e2c1163126 100644 --- a/configs/imx8mm_phg_defconfig +++ b/configs/imx8mm_phg_defconfig @@ -31,10 +31,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index a485910a5299..c584294c07dc 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -38,9 +38,9 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_beacon_2g_defconfig b/configs/imx8mn_beacon_2g_defconfig index 975fcc2481aa..3508bd881461 100644 --- a/configs/imx8mn_beacon_2g_defconfig +++ b/configs/imx8mn_beacon_2g_defconfig @@ -43,10 +43,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig index f4ecdc88f39c..c3263f96d0f8 100644 --- a/configs/imx8mn_beacon_defconfig +++ b/configs/imx8mn_beacon_defconfig @@ -42,10 +42,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_beacon_fspi_defconfig b/configs/imx8mn_beacon_fspi_defconfig index f5e57fb50bca..26db542d3be2 100644 --- a/configs/imx8mn_beacon_fspi_defconfig +++ b/configs/imx8mn_beacon_fspi_defconfig @@ -42,10 +42,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_bsh_smm_s2_defconfig b/configs/imx8mn_bsh_smm_s2_defconfig index f356b9cc4665..735cc5d10445 100644 --- a/configs/imx8mn_bsh_smm_s2_defconfig +++ b/configs/imx8mn_bsh_smm_s2_defconfig @@ -36,10 +36,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_DMA=y diff --git a/configs/imx8mn_bsh_smm_s2pro_defconfig b/configs/imx8mn_bsh_smm_s2pro_defconfig index 57d113102843..96f752b7fea4 100644 --- a/configs/imx8mn_bsh_smm_s2pro_defconfig +++ b/configs/imx8mn_bsh_smm_s2pro_defconfig @@ -37,10 +37,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index 4faeb473fa7d..9f1670bf6bc4 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -35,10 +35,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig index 230ce6be3745..535129bb6792 100644 --- a/configs/imx8mn_evk_defconfig +++ b/configs/imx8mn_evk_defconfig @@ -38,10 +38,10 @@ CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_var_som_defconfig b/configs/imx8mn_var_som_defconfig index b346b14ebdd2..9ae0902c69a1 100644 --- a/configs/imx8mn_var_som_defconfig +++ b/configs/imx8mn_var_som_defconfig @@ -40,10 +40,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index 39f930ae2cae..ff016373f75d 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -41,10 +41,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig b/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig index 494be362172d..1642ad1eb31a 100644 --- a/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig +++ b/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig @@ -38,10 +38,10 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_beacon_defconfig b/configs/imx8mp_beacon_defconfig index c6a3e35e73a3..5c9de2e0026b 100644 --- a/configs/imx8mp_beacon_defconfig +++ b/configs/imx8mp_beacon_defconfig @@ -52,10 +52,10 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_data_modul_edm_sbc_defconfig b/configs/imx8mp_data_modul_edm_sbc_defconfig index d3b629caf5c6..fa8c2ff6e2a7 100644 --- a/configs/imx8mp_data_modul_edm_sbc_defconfig +++ b/configs/imx8mp_data_modul_edm_sbc_defconfig @@ -60,10 +60,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x400 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x4c000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_dhcom_pdk2_defconfig b/configs/imx8mp_dhcom_pdk2_defconfig index 24c87aae781f..e30bb437cb0c 100644 --- a/configs/imx8mp_dhcom_pdk2_defconfig +++ b/configs/imx8mp_dhcom_pdk2_defconfig @@ -58,10 +58,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x400 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x4c000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_dhcom_pdk3_defconfig b/configs/imx8mp_dhcom_pdk3_defconfig index 3e89e0f8293c..c955ef640917 100644 --- a/configs/imx8mp_dhcom_pdk3_defconfig +++ b/configs/imx8mp_dhcom_pdk3_defconfig @@ -59,10 +59,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x400 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x4c000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index 73e30db4eedc..9596b11d90ca 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -38,10 +38,10 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_rsb3720a1_4G_defconfig b/configs/imx8mp_rsb3720a1_4G_defconfig index 02ce80c7832d..e6a1cc09ecae 100644 --- a/configs/imx8mp_rsb3720a1_4G_defconfig +++ b/configs/imx8mp_rsb3720a1_4G_defconfig @@ -47,10 +47,10 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_rsb3720a1_6G_defconfig b/configs/imx8mp_rsb3720a1_6G_defconfig index d0bf25a6f5f5..8838936e1248 100644 --- a/configs/imx8mp_rsb3720a1_6G_defconfig +++ b/configs/imx8mp_rsb3720a1_6G_defconfig @@ -47,10 +47,10 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_venice_defconfig b/configs/imx8mp_venice_defconfig index 294206ba8b26..82485529ae0f 100644 --- a/configs/imx8mp_venice_defconfig +++ b/configs/imx8mp_venice_defconfig @@ -41,10 +41,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x400 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mq_cm_defconfig b/configs/imx8mq_cm_defconfig index 89a7485bd1d8..fd08e35f0795 100644 --- a/configs/imx8mq_cm_defconfig +++ b/configs/imx8mq_cm_defconfig @@ -35,10 +35,10 @@ CONFIG_SPL_BSS_START_ADDR=0x180000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index 7b135bf9fad2..674d15c5bf68 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -38,10 +38,10 @@ CONFIG_SPL_BSS_START_ADDR=0x180000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mq_phanbell_defconfig b/configs/imx8mq_phanbell_defconfig index 114ddab10b4c..875cf54925ba 100644 --- a/configs/imx8mq_phanbell_defconfig +++ b/configs/imx8mq_phanbell_defconfig @@ -38,10 +38,10 @@ CONFIG_SPL_BSS_START_ADDR=0x180000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mq_reform2_defconfig b/configs/imx8mq_reform2_defconfig index a17a180d433c..da0d424f2ad9 100644 --- a/configs/imx8mq_reform2_defconfig +++ b/configs/imx8mq_reform2_defconfig @@ -41,10 +41,10 @@ CONFIG_SPL_BSS_START_ADDR=0x180000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index 7f7a20e5a2f9..0336b96b000e 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -40,10 +40,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x1000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x120000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x3000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x120000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x3000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_POWER_DOMAIN=y diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index f34b988c2e10..2c83e97bbf43 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -40,10 +40,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x1000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x120000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x3000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x120000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x3000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_POWER_DOMAIN=y diff --git a/configs/imx8ulp_evk_defconfig b/configs/imx8ulp_evk_defconfig index c08db70b96f8..40a4dca250c1 100644 --- a/configs/imx8ulp_evk_defconfig +++ b/configs/imx8ulp_evk_defconfig @@ -37,10 +37,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x22040000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x8000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x22040000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x8000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_WATCHDOG=y diff --git a/configs/imx93_11x11_evk_defconfig b/configs/imx93_11x11_evk_defconfig index 65f473885c6d..2de5ee4e9b4b 100644 --- a/configs/imx93_11x11_evk_defconfig +++ b/configs/imx93_11x11_evk_defconfig @@ -35,10 +35,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x83200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x83200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 CONFIG_SPL_I2C=y diff --git a/configs/imx93_11x11_evk_ld_defconfig b/configs/imx93_11x11_evk_ld_defconfig index 27165da8b97e..089751516205 100644 --- a/configs/imx93_11x11_evk_ld_defconfig +++ b/configs/imx93_11x11_evk_ld_defconfig @@ -36,10 +36,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x83200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x83200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 CONFIG_SPL_I2C=y diff --git a/configs/iot2050_defconfig b/configs/iot2050_defconfig index bcbaa92ee89b..bdd85d43824e 100644 --- a/configs/iot2050_defconfig +++ b/configs/iot2050_defconfig @@ -50,8 +50,8 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DM_MAILBOX=y diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index ba5914d3b605..e392553a7ee1 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -42,8 +42,8 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1800 CONFIG_SPL_DMA=y diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index c4dd33627bd1..42ff450aa082 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -37,10 +37,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0xa000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 214fa8b2f35d..3f36d655a9e5 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -42,8 +42,8 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index cf7bc872b5f1..803b38bd39bd 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -42,10 +42,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0xa000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 09addcbb25df..df7f6b0f07a9 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -41,8 +41,8 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 1e66ac23d05b..6fd90defd595 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -43,10 +43,10 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index d80862815821..01f84c4ef2ba 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -24,10 +24,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2089 # CONFIG_CMD_IMI is not set diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 44bed00ec973..7eea78d000d4 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -36,8 +36,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xc10fff8 CONFIG_SPL_BSS_MAX_SIZE=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x8000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x8000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 45c7fade320d..98b9dcb69994 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -35,8 +35,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xc0afff8 CONFIG_SPL_BSS_MAX_SIZE=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x8000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x8000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index a26517804846..21aa39431324 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -36,8 +36,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xc20fff8 CONFIG_SPL_BSS_MAX_SIZE=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x8000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x8000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 55ddd3cce96a..4c9e79c1a8d8 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -36,8 +36,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xc10fff8 CONFIG_SPL_BSS_MAX_SIZE=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x8000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x8000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/kontron-sl-mx6ul_defconfig b/configs/kontron-sl-mx6ul_defconfig index d54e60395d21..3e38b4978a48 100644 --- a/configs/kontron-sl-mx6ul_defconfig +++ b/configs/kontron-sl-mx6ul_defconfig @@ -33,7 +33,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x11400 CONFIG_SPL_WATCHDOG=y diff --git a/configs/kontron-sl-mx8mm_defconfig b/configs/kontron-sl-mx8mm_defconfig index 9558cf1a2d14..3d7d3c2fa595 100644 --- a/configs/kontron-sl-mx8mm_defconfig +++ b/configs/kontron-sl-mx8mm_defconfig @@ -38,10 +38,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/kontron_pitx_imx8m_defconfig b/configs/kontron_pitx_imx8m_defconfig index 295cc51c4fd7..01c54e7d2334 100644 --- a/configs/kontron_pitx_imx8m_defconfig +++ b/configs/kontron_pitx_imx8m_defconfig @@ -37,10 +37,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x180000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/kontron_sl28_defconfig b/configs/kontron_sl28_defconfig index 21a397933e7f..c5c95d11c369 100644 --- a/configs/kontron_sl28_defconfig +++ b/configs/kontron_sl28_defconfig @@ -47,7 +47,7 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x900 CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/kp_imx6q_tpc_defconfig b/configs/kp_imx6q_tpc_defconfig index dbfb0bafec1c..3a7763c44351 100644 --- a/configs/kp_imx6q_tpc_defconfig +++ b/configs/kp_imx6q_tpc_defconfig @@ -28,7 +28,7 @@ CONFIG_AUTOBOOT_STOP_STR="." # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL_RAW_IMAGE_SUPPORT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_POWER=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/librem5_defconfig b/configs/librem5_defconfig index 973b2ea20c41..21b84e4be804 100644 --- a/configs/librem5_defconfig +++ b/configs/librem5_defconfig @@ -42,10 +42,10 @@ CONFIG_SPL_BSS_START_ADDR=0x180000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index 83be20fb9072..1ff5b3c0cbe5 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -25,7 +25,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev};if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" CONFIG_DEFAULT_FDT_FILE="imx6ul-liteboard.dtb" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index b271792570e6..22b861584a3a 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -44,9 +44,9 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x82080000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x82080000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index ee569eaac6c6..b9636d3140a2 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -54,9 +54,9 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80200000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80200000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 25bd6c72a55d..c5d01354af1e 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -53,9 +53,9 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x820c0000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x820c0000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 2845386007f1..8e4b21836127 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -52,9 +52,9 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x820c0000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x820c0000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig index 7a8b157926b0..d10482705ab7 100644 --- a/configs/ls1021atsn_sdcard_defconfig +++ b/configs/ls1021atsn_sdcard_defconfig @@ -46,9 +46,9 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x82100000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x82100000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 4a42427b001f..0b895747ce45 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -54,9 +54,9 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x82104000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x82104000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 34b229e6f23f..52712bb390e6 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -55,9 +55,9 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x82100000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x82100000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 3738107321fb..51c4c7ac6f81 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -56,9 +56,9 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x82100000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x82100000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index e5f570a3b3c1..e62261d4809a 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -61,9 +61,9 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80200000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80200000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 6cb961d33dcc..12ad4ce08caa 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -62,7 +62,7 @@ CONFIG_SPL_BSS_START_ADDR=0x8f000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 4e41508251da..813a147f810f 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -62,7 +62,7 @@ CONFIG_SPL_BSS_START_ADDR=0x8f000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index d9ff0fd16a58..316716e5421b 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -46,9 +46,9 @@ CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80200000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80200000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index ad118187432e..9754c56e1d8f 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -52,9 +52,9 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80200000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80200000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index fe0dd04f1f90..bb4d03dcea66 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -47,7 +47,7 @@ CONFIG_SPL_BSS_START_ADDR=0x8f000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index aa5404cbb50e..c9db9e30d223 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -53,7 +53,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 95616f970549..78b94adb24e8 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -62,7 +62,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 179fa70f4ee2..75255492e828 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -63,7 +63,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index b571eaadf629..6e353a1db1e3 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -63,7 +63,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 924ff78b4593..c265040df6db 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -53,7 +53,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index eb0184c59276..e11a90f09b20 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -55,7 +55,7 @@ CONFIG_SPL_BSS_START_ADDR=0x8f000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 2813c79f5975..589117434e66 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -50,7 +50,7 @@ CONFIG_SPL_BSS_START_ADDR=0x8f000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index a621859aa792..8e1061fbc5d5 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -53,7 +53,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 1f52769ac216..735449a718ad 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -50,7 +50,7 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index 93d07829b4b9..52d7f94ea5d4 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -51,7 +51,7 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index c0812a983d5c..8c6a8105d9ad 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -51,7 +51,7 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index b98825cdb92a..699678f3526b 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -52,7 +52,7 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 1afaac2686dc..6920eefb4ae5 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -42,7 +42,7 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index b45819f87b3e..4965b4a49519 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -42,7 +42,7 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index a406bae1ec76..acc8c031d7b6 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -48,7 +48,7 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 6afddd2356e1..88a72b392993 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -24,7 +24,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_BOARD_INIT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index c95ee2524288..83f2b1a42dbf 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -26,7 +26,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_BOARD_INIT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index e99bb8f5b522..3492c9d2d54d 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -19,10 +19,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x90000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x90000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2089 # CONFIG_CMD_IMI is not set diff --git a/configs/msc_sm2s_imx8mp_defconfig b/configs/msc_sm2s_imx8mp_defconfig index 323a7040261a..ad12a69e3240 100644 --- a/configs/msc_sm2s_imx8mp_defconfig +++ b/configs/msc_sm2s_imx8mp_defconfig @@ -35,10 +35,10 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index b23c78984d13..a1ab269b37de 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -28,7 +28,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="if hdmidet; then usb start; setenv stdin serial,usbkbd; setenv stdout serial,vidconsole; setenv stderr serial,vidconsole; else setenv stdin serial; setenv stdout serial; setenv stderr serial; fi;" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y diff --git a/configs/mx6memcal_defconfig b/configs/mx6memcal_defconfig index a488ce41fb8f..6dd64b6da1ba 100644 --- a/configs/mx6memcal_defconfig +++ b/configs/mx6memcal_defconfig @@ -15,7 +15,7 @@ CONFIG_SPL=y CONFIG_SYS_MEMTEST_START=0x10000000 CONFIG_SYS_MEMTEST_END=0x20000000 CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index ee518cab6dc2..deb0b655356b 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -31,7 +31,7 @@ CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};if mmc rescan; then if run loa CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL_LEGACY_IMAGE_FORMAT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 0a8b0477b48f..edc92f804da9 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -31,7 +31,7 @@ CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};if mmc rescan; then if run loa CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL_LEGACY_IMAGE_FORMAT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index fee3c6fc950c..8db45764d5d9 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -27,7 +27,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 0e036606c1b3..f727423a38bb 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -29,7 +29,7 @@ CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc resc # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 740968d98e47..1e4ec0b017a9 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -29,7 +29,7 @@ CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc resc # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y diff --git a/configs/myir_mys_6ulx_defconfig b/configs/myir_mys_6ulx_defconfig index 8e3938dcaa82..456d1b86541b 100644 --- a/configs/myir_mys_6ulx_defconfig +++ b/configs/myir_mys_6ulx_defconfig @@ -20,7 +20,7 @@ CONFIG_FIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 3cb0cb8712e0..278e3fd8adb1 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -32,7 +32,7 @@ CONFIG_BOOTARGS="console=ttymxc1,115200 " CONFIG_BOOTCOMMAND="run distro_bootcmd ; run net_nfs" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_MISC_INIT_R=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index cc64facd5f2b..bc1b2e35b100 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -30,10 +30,10 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0xef8100 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2087 # CONFIG_CMD_IMI is not set diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index b8c48e6bf506..3534753dd3e1 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -26,8 +26,8 @@ CONFIG_DEFAULT_FDT_FILE="logicpd-torpedo-35xx-devkit.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index d9b7e0de5d54..835252acc9bd 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -27,8 +27,8 @@ CONFIG_DEFAULT_FDT_FILE="logicpd-som-lv-35xx-devkit.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index a1d43018aa15..1b9adcff893d 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -20,8 +20,8 @@ CONFIG_DEFAULT_FDT_FILE="omap3-beagle.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 34f7d8c8c415..fa2b84a500b9 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -20,8 +20,8 @@ CONFIG_DEFAULT_FDT_FILE="omap3-evm.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 90c1b6cabffa..e747a0c1e932 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -25,8 +25,8 @@ CONFIG_PREBOOT="setenv preboot;saveenv;" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 17fda31a1e78..b9d6284faad6 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -27,8 +27,8 @@ CONFIG_DEFAULT_FDT_FILE="logicpd-som-lv-37xx-devkit.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 5571722ea6d8..d126d2c07b0a 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -15,8 +15,8 @@ CONFIG_DEFAULT_FDT_FILE="omap4-panda.dtb" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_MAX_SIZE=0xbc00 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 0a8a1c77ea44..53710351d041 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -19,8 +19,8 @@ CONFIG_DEFAULT_FDT_FILE="omap4-sdp.dtb" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_MAX_SIZE=0xbc00 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SPL_I2C is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SYS_MAXARGS=64 diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index dec7a4bf3170..47feff21bd40 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -41,10 +41,10 @@ CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xc0f70000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x110000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0f70000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x110000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xb5 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/openpiton_riscv64_spl_defconfig b/configs/openpiton_riscv64_spl_defconfig index b7696d7cf307..4371c0350a51 100644 --- a/configs/openpiton_riscv64_spl_defconfig +++ b/configs/openpiton_riscv64_spl_defconfig @@ -30,7 +30,7 @@ CONFIG_SPL_BSS_START_ADDR=0x82000000 # CONFIG_SPL_LEGACY_IMAGE_FORMAT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y # CONFIG_SPL_BANNER_PRINT is not set CONFIG_SPL_CPU=y CONFIG_SPL_FS_EXT4=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index c4d738af3fca..068928ffa98a 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -34,7 +34,7 @@ CONFIG_DEFAULT_FDT_FILE="imx6ul-opos6uldev.dtb" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL_BOARD_INIT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_WATCHDOG=y CONFIG_SPL_YMODEM_SUPPORT=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 8c125c39b2f9..cc2ef1ed528a 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -17,10 +17,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x90000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x90000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2087 # CONFIG_CMD_IMI is not set diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index f8b587275f8b..15ae95e89438 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -32,7 +32,7 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run mmcboot;run nandboot" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_BOARD_INIT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x18a CONFIG_SPL_DMA=y CONFIG_SPL_FS_EXT4=y diff --git a/configs/phycore-am335x-r2-regor_defconfig b/configs/phycore-am335x-r2-regor_defconfig index d74078c7bed8..e37fd1bfab9b 100644 --- a/configs/phycore-am335x-r2-regor_defconfig +++ b/configs/phycore-am335x-r2-regor_defconfig @@ -24,8 +24,8 @@ CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="am335x-regor-rdk.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_I2C=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index 0f75d56c881c..08b857ea9c0a 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -24,8 +24,8 @@ CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="am335x-wega-rdk.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 CONFIG_SPL_I2C=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/phycore-imx8mm_defconfig b/configs/phycore-imx8mm_defconfig index 4a27d15cb113..10fd667722fc 100644 --- a/configs/phycore-imx8mm_defconfig +++ b/configs/phycore-imx8mm_defconfig @@ -34,10 +34,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index 7bf404be860b..2ba91563d39a 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -38,10 +38,10 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig index 2d06621963cc..11db9681a8c7 100644 --- a/configs/phycore_pcl063_defconfig +++ b/configs/phycore_pcl063_defconfig @@ -19,7 +19,7 @@ CONFIG_SYS_MEMTEST_END=0x90000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 diff --git a/configs/phycore_pcl063_ull_defconfig b/configs/phycore_pcl063_ull_defconfig index 327ea56cb8a5..f0a2398ebdbe 100644 --- a/configs/phycore_pcl063_ull_defconfig +++ b/configs/phycore_pcl063_ull_defconfig @@ -19,7 +19,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run mmc_mmc_fit" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 diff --git a/configs/pico-dwarf-imx6ul_defconfig b/configs/pico-dwarf-imx6ul_defconfig index 4fd588051cd8..e9a5302cb7d6 100644 --- a/configs/pico-dwarf-imx6ul_defconfig +++ b/configs/pico-dwarf-imx6ul_defconfig @@ -26,7 +26,7 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-dwarf.dtb" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_BOOTMENU=y diff --git a/configs/pico-dwarf-imx7d_defconfig b/configs/pico-dwarf-imx7d_defconfig index 2cd906a63da0..613ed6cc94aa 100644 --- a/configs/pico-dwarf-imx7d_defconfig +++ b/configs/pico-dwarf-imx7d_defconfig @@ -25,7 +25,7 @@ CONFIG_DEFAULT_FDT_FILE="imx7d-pico-dwarf.dtb" CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 # CONFIG_CMD_BOOTD is not set diff --git a/configs/pico-hobbit-imx6ul_defconfig b/configs/pico-hobbit-imx6ul_defconfig index c430b4d62226..b3a1023271c5 100644 --- a/configs/pico-hobbit-imx6ul_defconfig +++ b/configs/pico-hobbit-imx6ul_defconfig @@ -27,7 +27,7 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-hobbit.dtb" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_BOOTMENU=y diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index b63281e53322..82d70c7f37af 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -25,7 +25,7 @@ CONFIG_DEFAULT_FDT_FILE="imx7d-pico-hobbit.dtb" CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 # CONFIG_CMD_BOOTD is not set diff --git a/configs/pico-imx6_defconfig b/configs/pico-imx6_defconfig index be7b119ba78d..39aa63c1aaa6 100644 --- a/configs/pico-imx6_defconfig +++ b/configs/pico-imx6_defconfig @@ -27,7 +27,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run default_boot" CONFIG_DEFAULT_FDT_FILE="ask" CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index a6cbc5133175..6f84b6aeb49b 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -27,7 +27,7 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="ask" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_BOOTMENU=y diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index 546e1e6545d3..289cf6ba7c1a 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -27,7 +27,7 @@ CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index f11e1f4ef413..dbe4c5245b47 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -25,7 +25,7 @@ CONFIG_DEFAULT_FDT_FILE="ask" CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 # CONFIG_CMD_BOOTD is not set diff --git a/configs/pico-imx8mq_defconfig b/configs/pico-imx8mq_defconfig index 4ee9b88c32be..f2c342eb8f32 100644 --- a/configs/pico-imx8mq_defconfig +++ b/configs/pico-imx8mq_defconfig @@ -38,10 +38,10 @@ CONFIG_SPL_BSS_START_ADDR=0x180000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/pico-nymph-imx7d_defconfig b/configs/pico-nymph-imx7d_defconfig index 2cd906a63da0..613ed6cc94aa 100644 --- a/configs/pico-nymph-imx7d_defconfig +++ b/configs/pico-nymph-imx7d_defconfig @@ -25,7 +25,7 @@ CONFIG_DEFAULT_FDT_FILE="imx7d-pico-dwarf.dtb" CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 # CONFIG_CMD_BOOTD is not set diff --git a/configs/pico-pi-imx6ul_defconfig b/configs/pico-pi-imx6ul_defconfig index 3c822d10a4f4..1eee1e6c2ff5 100644 --- a/configs/pico-pi-imx6ul_defconfig +++ b/configs/pico-pi-imx6ul_defconfig @@ -27,7 +27,7 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-pi.dtb" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_BOOTMENU=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index 3e26aae40053..c5e34219eced 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -25,7 +25,7 @@ CONFIG_DEFAULT_FDT_FILE="imx7d-pico-pi.dtb" CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 # CONFIG_CMD_BOOTD is not set diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index ab9aef5e478d..4a4816874bf1 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -20,10 +20,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x90000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x90000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2084 # CONFIG_CMD_IMI is not set diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 88a6dbd7db06..4697959b8603 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -38,9 +38,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_BSS_START_ADDR=0x80000000 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80208000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/qemu-riscv32_spl_defconfig b/configs/qemu-riscv32_spl_defconfig index 9a81bdd767dc..e63d6fd93469 100644 --- a/configs/qemu-riscv32_spl_defconfig +++ b/configs/qemu-riscv32_spl_defconfig @@ -18,7 +18,7 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 diff --git a/configs/qemu-riscv64_spl_defconfig b/configs/qemu-riscv64_spl_defconfig index bb10145e6e7c..b048bb8aed01 100644 --- a/configs/qemu-riscv64_spl_defconfig +++ b/configs/qemu-riscv64_spl_defconfig @@ -17,7 +17,7 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 7e4580f2cc7a..7c443d518ed2 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -38,9 +38,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_BSS_START_ADDR=0x80000000 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80208000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/ringneck-px30_defconfig b/configs/ringneck-px30_defconfig index cdec0c52e6a2..b4666d0e90f5 100644 --- a/configs/ringneck-px30_defconfig +++ b/configs/ringneck-px30_defconfig @@ -42,7 +42,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 98fef09e18ca..f8bc8c639692 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -30,7 +30,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_RAW_IMAGE_SUPPORT=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_FS_LOAD_ARGS_NAME="imx6dl-riotboard.dtb" diff --git a/configs/rut_defconfig b/configs/rut_defconfig index ba89b4d24cd8..40c17a588821 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -38,9 +38,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_BSS_START_ADDR=0x80000000 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80208000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/sama5d27_giantboard_defconfig b/configs/sama5d27_giantboard_defconfig index e58b45425092..677658dca137 100644 --- a/configs/sama5d27_giantboard_defconfig +++ b/configs/sama5d27_giantboard_defconfig @@ -46,8 +46,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 65466ebb5c67..ec82311b16c4 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -43,8 +43,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index cb47dc6baa68..f3037445149c 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -44,8 +44,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index 702495e1c91f..eed190d2ef42 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -42,8 +42,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index 79210090122f..2b8461da1c25 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -43,8 +43,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_AT91_MCK_BYPASS=y diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index a7c84746e3e6..f47183ae5c92 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -43,8 +43,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DM_SPI_FLASH=y diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index 9456b9e1e134..7ad94ecbdeee 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -44,8 +44,8 @@ CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 9ef0ff4aa9a7..7c373360a9b2 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -43,8 +43,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index aed9edafdf70..26b281f70859 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -45,8 +45,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index c9a20723f5a1..9ed35e3113e4 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -46,8 +46,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index c01a0c4cc7c8..b87a63f2d232 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -47,8 +47,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 9b4affe1c49e..fc0de8c3e835 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -42,8 +42,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 2fcb2b75e804..a1b6122f8eb4 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -39,8 +39,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_BASE=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index bfe19e0169f9..631e85ea0598 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -44,8 +44,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 2978a7e2d7da..6278a6c68a7e 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -41,8 +41,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_BASE=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 1d30843e08b1..5f47f8b6ba9c 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -44,8 +44,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index befe26b18e9d..9f0349e7f58c 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -44,8 +44,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index 749c8ba30e6e..d12f749d7f49 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -41,8 +41,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_BASE=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 02a0de3ed271..0d239ef00085 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -46,8 +46,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 48607e1ca439..4139fcfadb2b 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -44,8 +44,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 60c936b04792..27bfcdf00848 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -41,8 +41,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_BASE=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index aee8169fdc0f..f41c4e9eddbf 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -44,8 +44,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index f8759f255465..2d9b7955273c 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -18,10 +18,10 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x90000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x90000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2086 # CONFIG_CMD_IMI is not set diff --git a/configs/seeed_npi_imx6ull_defconfig b/configs/seeed_npi_imx6ull_defconfig index 9dec10ef3925..d4f2a88ee462 100644 --- a/configs/seeed_npi_imx6ull_defconfig +++ b/configs/seeed_npi_imx6ull_defconfig @@ -21,7 +21,7 @@ CONFIG_FIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y diff --git a/configs/sifive_unleashed_defconfig b/configs/sifive_unleashed_defconfig index f9f03463ee7f..f99ce30b910c 100644 --- a/configs/sifive_unleashed_defconfig +++ b/configs/sifive_unleashed_defconfig @@ -29,7 +29,7 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x85000000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_DM_RESET=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/sifive_unmatched_defconfig b/configs/sifive_unmatched_defconfig index 867611b6b4ed..826cf977c340 100644 --- a/configs/sifive_unmatched_defconfig +++ b/configs/sifive_unmatched_defconfig @@ -35,7 +35,7 @@ CONFIG_PCI_INIT_R=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x85000000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_DM_RESET=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 836e0c002dee..21c9c39be49c 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -41,8 +41,8 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x20000000 CONFIG_SPL_BSS_MAX_SIZE=0x4000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x460000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x460000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index c762d75aec1b..703805916f9e 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -18,9 +18,9 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_BSS_START_ADDR=0x80000000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80208000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 diff --git a/configs/socfpga_agilex_atf_defconfig b/configs/socfpga_agilex_atf_defconfig index ba0dbb8496bf..453010076ca6 100644 --- a/configs/socfpga_agilex_atf_defconfig +++ b/configs/socfpga_agilex_atf_defconfig @@ -35,10 +35,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x3ff00000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x3fa00000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x3fa00000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x02000000 diff --git a/configs/socfpga_agilex_defconfig b/configs/socfpga_agilex_defconfig index 406fe712fe46..bddfd4b20cef 100644 --- a/configs/socfpga_agilex_defconfig +++ b/configs/socfpga_agilex_defconfig @@ -33,10 +33,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x3ff00000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x3fa00000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x3fa00000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x3c00000 diff --git a/configs/socfpga_agilex_vab_defconfig b/configs/socfpga_agilex_vab_defconfig index 7c83ec971ac9..e5f32c055c08 100644 --- a/configs/socfpga_agilex_vab_defconfig +++ b/configs/socfpga_agilex_vab_defconfig @@ -36,10 +36,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x3ff00000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x3fa00000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x3fa00000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x02000000 diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index 82b16418a6fc..30d28e195884 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -30,10 +30,10 @@ CONFIG_CLOCKS=y CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_NO_BSS_LIMIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xffe2b000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x15000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xffe2b000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x15000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FPGA=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_chameleonv3_defconfig b/configs/socfpga_chameleonv3_defconfig index 441942c2f2ba..457ad4b29774 100644 --- a/configs/socfpga_chameleonv3_defconfig +++ b/configs/socfpga_chameleonv3_defconfig @@ -14,10 +14,10 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_NO_BSS_LIMIT=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xffe2b000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x15000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xffe2b000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x15000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FPGA=y diff --git a/configs/socfpga_n5x_atf_defconfig b/configs/socfpga_n5x_atf_defconfig index 78595c5d9ec6..bd4a8b84af76 100644 --- a/configs/socfpga_n5x_atf_defconfig +++ b/configs/socfpga_n5x_atf_defconfig @@ -34,10 +34,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x3ff00000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x3fa00000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x3fa00000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x02000000 diff --git a/configs/socfpga_n5x_defconfig b/configs/socfpga_n5x_defconfig index 99a12df91ac8..745f4ed59d77 100644 --- a/configs/socfpga_n5x_defconfig +++ b/configs/socfpga_n5x_defconfig @@ -30,10 +30,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x3ff00000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x3fa00000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x3fa00000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x3c00000 diff --git a/configs/socfpga_n5x_vab_defconfig b/configs/socfpga_n5x_vab_defconfig index e8c62d0575f6..86429bf6ec2a 100644 --- a/configs/socfpga_n5x_vab_defconfig +++ b/configs/socfpga_n5x_vab_defconfig @@ -35,10 +35,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x3ff00000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x3fa00000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x3fa00000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x02000000 diff --git a/configs/socfpga_stratix10_atf_defconfig b/configs/socfpga_stratix10_atf_defconfig index 2d4f70592d22..0ca1da965102 100644 --- a/configs/socfpga_stratix10_atf_defconfig +++ b/configs/socfpga_stratix10_atf_defconfig @@ -35,10 +35,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x3ff00000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x3fa00000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x3fa00000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x02000000 CONFIG_SPL_ATF=y diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 7d078dd18e0f..add3d15c8581 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -35,10 +35,10 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x3ff00000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x3fa00000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x3fa00000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x3C00000 CONFIG_SPL_TARGET="spl/u-boot-spl-dtb.hex" diff --git a/configs/starfive_visionfive2_defconfig b/configs/starfive_visionfive2_defconfig index e9b63e5b8472..586f29298511 100644 --- a/configs/starfive_visionfive2_defconfig +++ b/configs/starfive_visionfive2_defconfig @@ -54,10 +54,10 @@ CONFIG_SPL_PAD_TO=0x0 CONFIG_SPL_BSS_START_ADDR=0x8040000 CONFIG_SPL_BSS_MAX_SIZE=0x10000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x400000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x400000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=0x2 CONFIG_SPL_I2C=y diff --git a/configs/stm32mp15-icore-stm32mp1-ctouch2_defconfig b/configs/stm32mp15-icore-stm32mp1-ctouch2_defconfig index e01745498c09..189703fee07f 100644 --- a/configs/stm32mp15-icore-stm32mp1-ctouch2_defconfig +++ b/configs/stm32mp15-icore-stm32mp1-ctouch2_defconfig @@ -22,10 +22,10 @@ CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x3db00 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xc0300000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1d00000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0300000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1d00000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/stm32mp15-icore-stm32mp1-edimm2.2_defconfig b/configs/stm32mp15-icore-stm32mp1-edimm2.2_defconfig index e72684683e71..6e8fc2f5cdaa 100644 --- a/configs/stm32mp15-icore-stm32mp1-edimm2.2_defconfig +++ b/configs/stm32mp15-icore-stm32mp1-edimm2.2_defconfig @@ -22,10 +22,10 @@ CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x3db00 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xc0300000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1d00000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0300000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1d00000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/stm32mp15-microgea-stm32mp1-microdev2-of7_defconfig b/configs/stm32mp15-microgea-stm32mp1-microdev2-of7_defconfig index b910d474ca7e..d6cb330bae11 100644 --- a/configs/stm32mp15-microgea-stm32mp1-microdev2-of7_defconfig +++ b/configs/stm32mp15-microgea-stm32mp1-microdev2-of7_defconfig @@ -22,10 +22,10 @@ CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x3db00 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xc0300000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1d00000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0300000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1d00000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/stm32mp15-microgea-stm32mp1-microdev2_defconfig b/configs/stm32mp15-microgea-stm32mp1-microdev2_defconfig index 5007e6246d4a..a99fc89be31a 100644 --- a/configs/stm32mp15-microgea-stm32mp1-microdev2_defconfig +++ b/configs/stm32mp15-microgea-stm32mp1-microdev2_defconfig @@ -22,10 +22,10 @@ CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x3db00 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xc0300000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1d00000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0300000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1d00000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 9ea5aaa7145a..2cb2ad64b27d 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -32,10 +32,10 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x3db00 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xc0300000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1d00000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0300000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1d00000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/stm32mp15_dhcom_basic_defconfig b/configs/stm32mp15_dhcom_basic_defconfig index af7416659c18..289040e011a5 100644 --- a/configs/stm32mp15_dhcom_basic_defconfig +++ b/configs/stm32mp15_dhcom_basic_defconfig @@ -40,10 +40,10 @@ CONFIG_SPL_MAX_FOOTPRINT=0x3db00 CONFIG_SPL_BOOTCOUNT_LIMIT=y CONFIG_SPL_LEGACY_IMAGE_FORMAT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xc0300000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1d00000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0300000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1d00000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/stm32mp15_dhcor_basic_defconfig b/configs/stm32mp15_dhcor_basic_defconfig index b7f372f9e4df..fe45e2b7d513 100644 --- a/configs/stm32mp15_dhcor_basic_defconfig +++ b/configs/stm32mp15_dhcor_basic_defconfig @@ -38,10 +38,10 @@ CONFIG_SPL_MAX_FOOTPRINT=0x3db00 CONFIG_SPL_BOOTCOUNT_LIMIT=y CONFIG_SPL_LEGACY_IMAGE_FORMAT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xc0300000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1d00000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0300000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1d00000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index bf2345482536..7bcb3191000e 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -28,8 +28,8 @@ CONFIG_SPL_BSS_START_ADDR=0x100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x2000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x2000000 CONFIG_SPL_FS_LOAD_ARGS_NAME="system.dtb" CONFIG_SPL_OS_BOOT=y CONFIG_SYS_SPL_ARGS_ADDR=0x10000000 diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 81a83771cdea..0db0a75cbb80 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -49,10 +49,10 @@ CONFIG_SPL_BSS_MAX_SIZE=0x600 # CONFIG_SPL_LEGACY_IMAGE_FORMAT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x20ba0000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x460000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x20ba0000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x460000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 4776e92683d6..607112c2cb29 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -21,10 +21,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2084 # CONFIG_CMD_IMI is not set diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 8a5d959a5c02..de76f1a39e6f 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -19,10 +19,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x90000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x90000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2081 # CONFIG_CMD_IMI is not set diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 6302c1a4151a..a1370bd2b9d2 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -38,9 +38,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_BSS_START_ADDR=0x80000000 -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80208000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index ef1b66e9069a..5c845592f3d9 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -33,8 +33,8 @@ CONFIG_SPL_BSS_START_ADDR=0x100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x2000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x2000000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index af829ac15b82..3a464a52483b 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -33,8 +33,8 @@ CONFIG_SPL_BSS_START_ADDR=0x100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x2000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x2000000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 9287b1d79aa4..6e66081bf3ba 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -33,8 +33,8 @@ CONFIG_SPL_BSS_START_ADDR=0x100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x2000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x2000000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/transformer_t30_defconfig b/configs/transformer_t30_defconfig index 6fe6f2548dc1..a46dfed74aeb 100644 --- a/configs/transformer_t30_defconfig +++ b/configs/transformer_t30_defconfig @@ -26,10 +26,10 @@ CONFIG_BOOTCOMMAND="setenv gpio_button 150; if run check_button; then poweroff; CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2084 CONFIG_CMD_BOOTMENU=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 9ec08bda883d..0e49272a80d3 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -21,10 +21,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x90000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x90000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2087 # CONFIG_CMD_IMI is not set diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index ab8cb489db79..e128a62cd005 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -23,7 +23,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index e06de7be6826..853472f4f495 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -21,7 +21,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y # CONFIG_CMD_BMODE is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" diff --git a/configs/variscite_dart6ul_defconfig b/configs/variscite_dart6ul_defconfig index 1cfa3421fd13..1cf4a8fe56a4 100644 --- a/configs/variscite_dart6ul_defconfig +++ b/configs/variscite_dart6ul_defconfig @@ -19,7 +19,7 @@ CONFIG_FIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run mmc_mmc_fit" -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index ebd1754fc8ba..77e6ffeb945b 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -21,10 +21,10 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2086 # CONFIG_CMD_IMI is not set diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 2da8ba94d628..0524758b0567 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -18,10 +18,10 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x90000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x90000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2085 # CONFIG_CMD_IMI is not set diff --git a/configs/verdin-am62_r5_defconfig b/configs/verdin-am62_r5_defconfig index 878195a61aca..794b6216b90b 100644 --- a/configs/verdin-am62_r5_defconfig +++ b/configs/verdin-am62_r5_defconfig @@ -38,10 +38,10 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x140000 CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index 09e14c6f8c40..3e3848085c34 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -43,10 +43,10 @@ CONFIG_SPL_BSS_START_ADDR=0x910000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index 2df0f4f34433..e499ed851c4a 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -53,10 +53,10 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index cbb82593d09b..e5d34959fcad 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -33,7 +33,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 0493ef2f67ce..7c1727f8b12b 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -33,7 +33,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" diff --git a/configs/x3_t30_defconfig b/configs/x3_t30_defconfig index 540c43096d8f..6fbb9d6481c9 100644 --- a/configs/x3_t30_defconfig +++ b/configs/x3_t30_defconfig @@ -27,10 +27,10 @@ CONFIG_BOOTCOMMAND="if run check_button; then bootmenu; fi; run bootcmd_mmc1; ru CONFIG_SPL_FOOTPRINT_LIMIT=y CONFIG_SPL_MAX_FOOTPRINT=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2084 CONFIG_CMD_BOOTMENU=y diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 990057734595..4ea5caff547f 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -37,8 +37,8 @@ CONFIG_SPL_BSS_START_ADDR=0x100000 CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x2000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x2000000 CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_FS_LOAD_ARGS_NAME="system.dtb" CONFIG_SPL_FPGA=y diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index cf7c7eda8c94..72b1ad4660ad 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -26,10 +26,10 @@ CONFIG_CLOCKS=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x20000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x20000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_MAXARGS=64 diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index a4a43b58a85e..310aad445a55 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -26,10 +26,10 @@ CONFIG_CLOCKS=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x20000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x20000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_MAXARGS=64 diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index e6a9dd31a572..4c732398fc5b 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -27,10 +27,10 @@ CONFIG_CLOCKS=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x20000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x20000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 26260841c590..59be5f42493a 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -36,10 +36,10 @@ CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_BSS_MAX_SIZE=0x80000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x20000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x20000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_FPGA=y diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 64cdffbb9a45..19f653f40d0d 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -28,10 +28,10 @@ CONFIG_SPL_BSS_START_ADDR=0x20000 CONFIG_SPL_BSS_MAX_SIZE=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x2000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x2000000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 54620b2382ec..64df1f0b83e1 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -28,10 +28,10 @@ CONFIG_SPL_BSS_START_ADDR=0x20000 CONFIG_SPL_BSS_MAX_SIZE=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x2000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x2000000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index 08c500930fd5..8c75b3233d72 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -35,10 +35,10 @@ CONFIG_SPL_BSS_START_ADDR=0x20000 CONFIG_SPL_BSS_MAX_SIZE=0x8000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x2000000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x2000000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 # CONFIG_CMDLINE_EDITING is not set diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index f0d848f45d8e..4c5a00f6f9c2 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -14,7 +14,7 @@ config SPL_DM help Enable driver model in SPL. You will need to provide a suitable malloc() implementation. If you are not using the - full malloc() enabled by CFG_SYS_SPL_MALLOC_START, + full malloc() enabled by CFG_SPL_SYS_MALLOC_START, consider using CONFIG_SPL_SYS_MALLOC_SIMPLE. In that case you must provide CONFIG_SPL_SYS_MALLOC_F_LEN to set the size. In most cases driver model will only allocate a few uclasses @@ -27,7 +27,7 @@ config TPL_DM help Enable driver model in TPL. You will need to provide a suitable malloc() implementation. If you are not using the - full malloc() enabled by CFG_SYS_SPL_MALLOC_START, + full malloc() enabled by CFG_SPL_SYS_MALLOC_START, consider using CONFIG_TPL_SYS_MALLOC_SIMPLE. In that case you must provide CONFIG_SPL_SYS_MALLOC_F_LEN to set the size. In most cases driver model will only allocate a few uclasses @@ -42,7 +42,7 @@ config VPL_DM help Enable driver model in VPL. You will need to provide a suitable malloc() implementation. If you are not using the - full malloc() enabled by CFG_SYS_SPL_MALLOC_START, + full malloc() enabled by CFG_SPL_SYS_MALLOC_START, consider using CONFIG_SPL_SYS_MALLOC_SIMPLE.
config DM_WARN diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 7ca42df6a7e2..f5478a9ccd07 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -160,7 +160,7 @@ config SERIAL_PROBE_ALL config SPL_DM_SERIAL bool "Enable Driver Model for serial drivers in SPL" depends on DM_SERIAL && SPL_DM - select SYS_SPL_MALLOC_F + select SPL_SYS_MALLOC_F default y help Enable driver model for serial in SPL. This replaces diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 0c96c9c24fed..4838bfd4f137 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -18,7 +18,7 @@ #define CFG_SYS_INIT_RAM_ADDR 0xFFE00000 /* SPL memory allocation configuration, this is for FAT implementation */ #define CFG_SYS_INIT_RAM_SIZE (SOCFPGA_PHYS_OCRAM_SIZE - \ - CONFIG_SYS_SPL_MALLOC_SIZE) + CONFIG_SPL_SYS_MALLOC_SIZE) #endif
/* diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 66ecb168a0a0..820372c28b38 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -112,7 +112,7 @@ unsigned int cm_get_l4_sys_free_clk_hz(void); * SDRAM * 0x0000_0000 ...... Start of SDRAM_1 * unused / empty space for image loading - * Size 64MB ...... MALLOC (size CONFIG_SYS_SPL_MALLOC_SIZE) + * Size 64MB ...... MALLOC (size CONFIG_SPL_SYS_MALLOC_SIZE) * Size 1MB ...... BSS (size CONFIG_SPL_BSS_MAX_SIZE) * 0x8000_0000 ...... End of SDRAM_1 (assume 2GB) * diff --git a/include/system-constants.h b/include/system-constants.h index 0d6b71b35a06..f0a191be590e 100644 --- a/include/system-constants.h +++ b/include/system-constants.h @@ -22,10 +22,10 @@ /* * Typically, we have the SPL malloc pool at the end of the BSS area. */ -#ifdef CONFIG_HAS_CUSTOM_SPL_MALLOC_START -#define SYS_SPL_MALLOC_START CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR +#ifdef CONFIG_SPL_HAS_CUSTOM_MALLOC_START +#define SPL_SYS_MALLOC_START CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR #else -#define SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ +#define SPL_SYS_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ CONFIG_SPL_BSS_MAX_SIZE) #endif
Rename this so that SPL is first, as per U-Boot convention. Also add PAYLOAD_ since this is where in memory the parameters for the payload have been stored.
Changes in v2: - Rename based on Tom's feedback
arch/arm/cpu/armv8/fsl-layerscape/doc/README.falcon | 2 +- common/spl/Kconfig | 2 +- common/spl/spl.c | 8 ++++---- common/spl/spl_ext.c | 4 ++-- common/spl/spl_fat.c | 4 ++-- common/spl/spl_mmc.c | 2 +- common/spl/spl_nand.c | 10 +++++----- common/spl/spl_nor.c | 8 ++++---- common/spl/spl_spi.c | 2 +- common/spl/spl_ubi.c | 2 +- common/spl/spl_xip.c | 2 +- configs/am3517_evm_defconfig | 2 +- configs/devkit8000_defconfig | 2 +- configs/display5_defconfig | 2 +- configs/display5_factory_defconfig | 2 +- configs/gwventana_emmc_defconfig | 2 +- configs/gwventana_nand_defconfig | 2 +- configs/igep00x0_defconfig | 2 +- configs/imx28_xea_defconfig | 2 +- configs/imx6dl_mamoj_defconfig | 2 +- configs/imx6q_logic_defconfig | 2 +- configs/imx6qdl_icore_mipi_defconfig | 2 +- configs/imx6qdl_icore_mmc_defconfig | 2 +- configs/imx6qdl_icore_rqs_defconfig | 2 +- configs/ls1046ardb_qspi_spl_defconfig | 2 +- configs/mccmon6_nor_defconfig | 2 +- configs/omap35_logic_defconfig | 2 +- configs/omap35_logic_somlv_defconfig | 2 +- configs/omap3_logic_defconfig | 2 +- configs/omap3_logic_somlv_defconfig | 2 +- configs/riotboard_defconfig | 2 +- configs/stm32746g-eval_spl_defconfig | 2 +- configs/stm32f746-disco_spl_defconfig | 2 +- configs/stm32f769-disco_spl_defconfig | 2 +- configs/syzygy_hub_defconfig | 2 +- configs/vyasa-rk3288_defconfig | 2 +- configs/xilinx_zynq_virt_defconfig | 2 +- configs/xilinx_zynqmp_virt_defconfig | 2 +- doc/develop/falcon.rst | 2 +- 39 files changed, 51 insertions(+), 51 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.falcon b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.falcon index b3c6693a42c2..2bbe4e2d1235 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.falcon +++ b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.falcon @@ -30,7 +30,7 @@ to understand the device tree in FIT image should be the one actually used, or leave it absent to favor the stored sectors. It is easier to deploy the FIT image with embedded static device tree to multiple boards.
-Macro CONFIG_SYS_SPL_ARGS_ADDR serves two purposes. One is the pointer to load +Macro CONFIG_SPL_PAYLOAD_ARGS_ADDR serves two purposes. One is the pointer to load the stored sectors to. Normally this is the static device tree. The second purpose is the memory location of signature header for secure boot. After the FIT image is loaded into memory, it is validated against the signature header diff --git a/common/spl/Kconfig b/common/spl/Kconfig index b9d96fbe1355..463235979427 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1063,7 +1063,7 @@ config SPL_OS_BOOT Enable booting directly to an OS from SPL. for more info read doc/README.falcon
-config SYS_SPL_ARGS_ADDR +config SPL_PAYLOAD_ARGS_ADDR hex "Address in memory to load 'args' file for Falcon Mode to" depends on SPL_OS_BOOT default 0x88000000 if ARCH_OMAP2PLUS diff --git a/common/spl/spl.c b/common/spl/spl.c index 1e50043cf77b..acd154986e15 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -818,8 +818,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2) }
memset(&spl_image, '\0', sizeof(spl_image)); -#ifdef CONFIG_SYS_SPL_ARGS_ADDR - spl_image.arg = (void *)CONFIG_SYS_SPL_ARGS_ADDR; +#ifdef CONFIG_SPL_PAYLOAD_ARGS_ADDR + spl_image.arg = (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR; #endif spl_image.boot_device = BOOT_DEVICE_NONE; board_boot_order(spl_boot_list); @@ -877,8 +877,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2) #if CONFIG_IS_ENABLED(OS_BOOT) case IH_OS_LINUX: debug("Jumping to Linux\n"); -#if defined(CONFIG_SYS_SPL_ARGS_ADDR) - spl_fixup_fdt((void *)CONFIG_SYS_SPL_ARGS_ADDR); +#if defined(CONFIG_SPL_PAYLOAD_ARGS_ADDR) + spl_fixup_fdt((void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR); #endif spl_board_prepare_for_linux(); jump_to_image_linux(&spl_image); diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index 2bf34344391c..902564a60776 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -97,7 +97,7 @@ int spl_load_image_ext_os(struct spl_image_info *spl_image, puts("spl: ext4fs_open failed\n"); goto defaults; } - err = ext4fs_read((void *)CONFIG_SYS_SPL_ARGS_ADDR, 0, filelen, &actlen); + err = ext4fs_read((void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR, 0, filelen, &actlen); if (err < 0) { printf("spl: error reading image %s, err - %d, falling back to default\n", file, err); @@ -127,7 +127,7 @@ defaults: if (err < 0) puts("spl: ext4fs_open failed\n");
- err = ext4fs_read((void *)CONFIG_SYS_SPL_ARGS_ADDR, 0, filelen, &actlen); + err = ext4fs_read((void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR, 0, filelen, &actlen); if (err < 0) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: error reading image %s, err - %d\n", diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index f8a5b80a3bd2..c6e2526ade12 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -128,7 +128,7 @@ int spl_load_image_fat_os(struct spl_image_info *spl_image, #if defined(CONFIG_SPL_ENV_SUPPORT) && defined(CONFIG_SPL_OS_BOOT) file = env_get("falcon_args_file"); if (file) { - err = file_fat_read(file, (void *)CONFIG_SYS_SPL_ARGS_ADDR, 0); + err = file_fat_read(file, (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR, 0); if (err <= 0) { printf("spl: error reading image %s, err - %d, falling back to default\n", file, err); @@ -153,7 +153,7 @@ defaults: #endif
err = file_fat_read(CONFIG_SPL_FS_LOAD_ARGS_NAME, - (void *)CONFIG_SYS_SPL_ARGS_ADDR, 0); + (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR, 0); if (err <= 0) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: error reading image %s, err - %d\n", diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 20f687e13891..0ab85d2168c1 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -235,7 +235,7 @@ static int mmc_load_image_raw_os(struct spl_image_info *spl_image, count = blk_dread(mmc_get_blk_desc(mmc), CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR, CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS, - (void *) CONFIG_SYS_SPL_ARGS_ADDR); + (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR); if (count != CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("mmc_load_image_raw_os: mmc block read error\n"); diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index dc45204fc0e6..6cc34004f49d 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -159,11 +159,11 @@ static int spl_nand_load_image(struct spl_image_info *spl_image, CONFIG_CMD_SPL_WRITE_SIZE, (void *)CONFIG_TEXT_BASE); /* copy to destintion */ - for (dst = (int *)CONFIG_SYS_SPL_ARGS_ADDR, - src = (int *)CONFIG_TEXT_BASE; - src < (int *)(CONFIG_TEXT_BASE + - CONFIG_CMD_SPL_WRITE_SIZE); - src++, dst++) { + for (dst = (int *)CONFIG_SPL_PAYLOAD_ARGS_ADDR, + src = (int *)CONFIG_TEXT_BASE; + src < (int *)(CONFIG_TEXT_BASE + + CONFIG_CMD_SPL_WRITE_SIZE); + src++, dst++) { writel(readl(src), dst); }
diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index 5b65b96a77db..79d4f1d7aa87 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -54,8 +54,8 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, CONFIG_SYS_OS_BASE, (void *)header);
-#if defined CONFIG_SYS_SPL_ARGS_ADDR && defined CONFIG_CMD_SPL_NOR_OFS - memcpy((void *)CONFIG_SYS_SPL_ARGS_ADDR, +#if defined CONFIG_SPL_PAYLOAD_ARGS_ADDR && defined CONFIG_CMD_SPL_NOR_OFS + memcpy((void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR, (void *)CONFIG_CMD_SPL_NOR_OFS, CONFIG_CMD_SPL_WRITE_SIZE); #endif @@ -74,8 +74,8 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, (void *)(CONFIG_SYS_OS_BASE + sizeof(struct legacy_img_hdr)), spl_image->size); -#ifdef CONFIG_SYS_SPL_ARGS_ADDR - spl_image->arg = (void *)CONFIG_SYS_SPL_ARGS_ADDR; +#ifdef CONFIG_SPL_PAYLOAD_ARGS_ADDR + spl_image->arg = (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR; #endif
return 0; diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index 2aff025f76ee..d69069a75bfe 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -47,7 +47,7 @@ static int spi_load_image_os(struct spl_image_info *spl_image, /* Read device tree. */ spi_flash_read(flash, CFG_SYS_SPI_ARGS_OFFS, CFG_SYS_SPI_ARGS_SIZE, - (void *)CONFIG_SYS_SPL_ARGS_ADDR); + (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR);
return 0; } diff --git a/common/spl/spl_ubi.c b/common/spl/spl_ubi.c index bcac25cd021c..d7ab9efd1108 100644 --- a/common/spl/spl_ubi.c +++ b/common/spl/spl_ubi.c @@ -50,7 +50,7 @@ int spl_ubi_load_image(struct spl_image_info *spl_image, volumes[0].vol_id = CONFIG_SPL_UBI_LOAD_KERNEL_ID; volumes[0].load_addr = (void *)CONFIG_SYS_LOAD_ADDR; volumes[1].vol_id = CONFIG_SPL_UBI_LOAD_ARGS_ID; - volumes[1].load_addr = (void *)CONFIG_SYS_SPL_ARGS_ADDR; + volumes[1].load_addr = (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR;
ret = ubispl_load_volumes(&info, volumes, 2); if (!ret) { diff --git a/common/spl/spl_xip.c b/common/spl/spl_xip.c index 77c23ba05978..959915ffa610 100644 --- a/common/spl/spl_xip.c +++ b/common/spl/spl_xip.c @@ -14,7 +14,7 @@ static int spl_xip(struct spl_image_info *spl_image, { #if CONFIG_IS_ENABLED(OS_BOOT) if (!spl_start_uboot()) { - spl_image->arg = (void *)CONFIG_SYS_SPL_ARGS_ADDR; + spl_image->arg = (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR; spl_image->name = "Linux"; spl_image->os = IH_OS_LINUX; spl_image->load_addr = CONFIG_SYS_LOAD_ADDR; diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index dda235492784..7b449c703b6c 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -33,7 +33,7 @@ CONFIG_SPL_NAND_ECC=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SPL_NAND_BASE=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x84000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x84000000 CONFIG_SYS_NAND_SPL_KERNEL_OFFS=0x2a0000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1700 diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 1431e54dc95e..ef16da176a91 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -28,7 +28,7 @@ CONFIG_SPL_NAND_ECC=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SPL_NAND_BASE=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x80000100 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x80000100 CONFIG_SYS_NAND_SPL_KERNEL_OFFS=0x280000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x500 diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 9c4334af15c5..00b6f692e3d9 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -46,7 +46,7 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_SAVEENV=y CONFIG_SPL_I2C=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x18000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x100 CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x3F00 diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 67ba7658861a..911b75a317a6 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -41,7 +41,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_DMA=y CONFIG_SPL_I2C=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x18000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x100 CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x3F00 diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index eb29268c6fa7..1970c2290db7 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -49,7 +49,7 @@ CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_DMA=y CONFIG_SPL_I2C=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x18000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1000 CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x800 diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 17a86d6447d0..1bc943341514 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -50,7 +50,7 @@ CONFIG_SPL_DMA=y CONFIG_SPL_I2C=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x18000000 CONFIG_SYS_NAND_SPL_KERNEL_OFFS=0x1200000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1000 diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index e0cc39959669..5e2a8e04c660 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -42,7 +42,7 @@ CONFIG_SPL_UBI_LOAD_KERNEL_ID=3 CONFIG_SPL_UBI_LOAD_ARGS_ID=4 CONFIG_SPL_ONENAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x84000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x84000000 CONFIG_SYS_NAND_SPL_KERNEL_OFFS=0x280000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1700 diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig index 96d15e89af80..4035f798d15d 100644 --- a/configs/imx28_xea_defconfig +++ b/configs/imx28_xea_defconfig @@ -51,7 +51,7 @@ CONFIG_SPL_DMA=y CONFIG_SPL_MMC_TINY=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x44000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x44000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x800 CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x400 diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index 933a9d83f344..35ded27c8355 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -20,7 +20,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x13000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x13000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1000 CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x800 diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index b307fea5f25c..71d6bf0e114c 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -36,7 +36,7 @@ CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x18000000 CONFIG_SYS_NAND_SPL_KERNEL_OFFS=0x500000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1000 diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index ecb8fb2ba57b..59c3da32dce4 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -36,7 +36,7 @@ CONFIG_BOOTCOMMAND="run $modeboot" CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x18000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1000 CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x800 diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 42889188cc30..836b3d1814d1 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -39,7 +39,7 @@ CONFIG_BOOTCOMMAND="run $modeboot" CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x18000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1000 CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x800 diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 2ab42979fa60..aa44cdc52d9e 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -33,7 +33,7 @@ CONFIG_BOOTCOMMAND="run $modeboot" CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x18000000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1000 CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x800 diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index e11a90f09b20..d8beb3c053a1 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -61,7 +61,7 @@ CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x90000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x90000000 CONFIG_SYS_OS_BASE=0x40980000 CONFIG_SPL_WATCHDOG=y CONFIG_SPL_TARGET="spl/u-boot-spl.pbl" diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 88a72b392993..5e8fbd01bf9e 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -29,7 +29,7 @@ CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x18000000 CONFIG_SYS_OS_BASE=0x8180000 CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 3534753dd3e1..990f05c72e50 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -37,7 +37,7 @@ CONFIG_SPL_NAND_ECC=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SPL_NAND_BASE=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x84000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x84000000 CONFIG_SYS_NAND_SPL_KERNEL_OFFS=0x280000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1700 diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 835252acc9bd..c768d398523e 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -38,7 +38,7 @@ CONFIG_SPL_NAND_ECC=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SPL_NAND_BASE=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x84000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x84000000 CONFIG_SYS_NAND_SPL_KERNEL_OFFS=0x280000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1700 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index e747a0c1e932..48a87722d5ea 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -36,7 +36,7 @@ CONFIG_SPL_NAND_ECC=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SPL_NAND_BASE=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x84000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x84000000 CONFIG_SYS_NAND_SPL_KERNEL_OFFS=0x280000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1700 diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index b9d6284faad6..ac684a907820 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -38,7 +38,7 @@ CONFIG_SPL_NAND_ECC=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SPL_NAND_BASE=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x84000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x84000000 CONFIG_SYS_NAND_SPL_KERNEL_OFFS=0x280000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1700 diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index f8bc8c639692..6ab405d7f98d 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -35,7 +35,7 @@ CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_FS_LOAD_ARGS_NAME="imx6dl-riotboard.dtb" CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x13000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x13000000 CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_GPIO=y diff --git a/configs/stm32746g-eval_spl_defconfig b/configs/stm32746g-eval_spl_defconfig index 03e123e44a2e..8b60365cc24e 100644 --- a/configs/stm32746g-eval_spl_defconfig +++ b/configs/stm32746g-eval_spl_defconfig @@ -37,7 +37,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_XIP_SUPPORT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x80c0000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x80c0000 CONFIG_SPL_DM_RESET=y CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_GPT=y diff --git a/configs/stm32f746-disco_spl_defconfig b/configs/stm32f746-disco_spl_defconfig index 84aaec1e3390..0a3042b3279a 100644 --- a/configs/stm32f746-disco_spl_defconfig +++ b/configs/stm32f746-disco_spl_defconfig @@ -37,7 +37,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_XIP_SUPPORT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x80c0000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x80c0000 CONFIG_SPL_DM_RESET=y CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_GPT=y diff --git a/configs/stm32f769-disco_spl_defconfig b/configs/stm32f769-disco_spl_defconfig index dd17cad73622..f570cbbe73aa 100644 --- a/configs/stm32f769-disco_spl_defconfig +++ b/configs/stm32f769-disco_spl_defconfig @@ -36,7 +36,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_XIP_SUPPORT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x81c0000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x81c0000 CONFIG_SPL_DM_RESET=y CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_GPT=y diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index 7bcb3191000e..78cbaa7a0b83 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -32,7 +32,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x2000000 CONFIG_SPL_FS_LOAD_ARGS_NAME="system.dtb" CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x10000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x10000000 CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=2071 CONFIG_SYS_BOOTM_LEN=0x3c00000 diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index 9bca6fe2eeaa..0ae901a72391 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -32,7 +32,7 @@ CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0xffe5000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0xffe5000 CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x8800 CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x8000 diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 4ea5caff547f..9589848e8e1c 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -43,7 +43,7 @@ CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_FS_LOAD_ARGS_NAME="system.dtb" CONFIG_SPL_FPGA=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x10000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x10000000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 59be5f42493a..7f79167db716 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -44,7 +44,7 @@ CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_FPGA=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x8000000 +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x8000000 CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y diff --git a/doc/develop/falcon.rst b/doc/develop/falcon.rst index a569d1a29517..2f25fc8532f5 100644 --- a/doc/develop/falcon.rst +++ b/doc/develop/falcon.rst @@ -63,7 +63,7 @@ CONFIG_CMD_SPL Enable the "spl export" command. The command "spl export" is then available in U-Boot mode.
-CONFIG_SYS_SPL_ARGS_ADDR +CONFIG_SPL_PAYLOAD_ARGS_ADDR Address in RAM where the parameters must be copied by SPL. In most cases, it is <start_of_ram> + 0x100.
Use IF_ENABLED_INT() to avoid needing to use the preprocessor.
Changes in v2: - Improve readability by moving the size part to the header file
common/spl/spl.c | 8 ++++---- include/system-constants.h | 7 ++++++- 2 files changed, 10 insertions(+), 5 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index acd154986e15..90e6dc2b5c9b 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -754,10 +754,10 @@ void board_init_r(gd_t *dummy1, ulong dummy2)
spl_set_bd();
-#if defined(CONFIG_SPL_SYS_MALLOC) - mem_malloc_init(SPL_SYS_MALLOC_START, CONFIG_SPL_SYS_MALLOC_SIZE); - gd->flags |= GD_FLG_FULL_MALLOC_INIT; -#endif + if (IS_ENABLED(CONFIG_SPL_SYS_MALLOC)) { + mem_malloc_init(SPL_SYS_MALLOC_START, SPL_SYS_MALLOC_SIZE); + gd->flags |= GD_FLG_FULL_MALLOC_INIT; + } if (!(gd->flags & GD_FLG_SPL_INIT)) { if (spl_init()) hang(); diff --git a/include/system-constants.h b/include/system-constants.h index f0a191be590e..dca6a86b01f5 100644 --- a/include/system-constants.h +++ b/include/system-constants.h @@ -24,9 +24,14 @@ */ #ifdef CONFIG_SPL_HAS_CUSTOM_MALLOC_START #define SPL_SYS_MALLOC_START CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR -#else +#elif defined(CONFIG_SPL_BSS_START_ADDR) #define SPL_SYS_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ CONFIG_SPL_BSS_MAX_SIZE) +#else +/* feature not enabled: this value avoids compiler errors but is not used */ +#define SPL_SYS_MALLOC_START 0 #endif +#define SPL_SYS_MALLOC_SIZE \ + IF_ENABLED_INT(CONFIG_SPL_SYS_MALLOC, CONFIG_SPL_SYS_MALLOC_SIZE)
#endif
It doesn't make sense to have some boards do this differently. Drop the condition in the hope that the maintainers can figure out any run-time problems.
Changes in v2: - Explicitly copy two maintainers as it seems only Mario was auto-cc'd
common/spl/spl.c | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 90e6dc2b5c9b..80a3a3f1516e 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -762,13 +762,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) if (spl_init()) hang(); } -#if !defined(CONFIG_PPC) && !defined(CONFIG_ARCH_MX6) - /* - * timer_init() does not exist on PPC systems. The timer is initialized - * and enabled (decrementer) in interrupt_init() here. - */ timer_init(); -#endif if (CONFIG_IS_ENABLED(BLOBLIST)) { ret = bloblist_init(); if (ret) {
Avoid using the preprocessor for these checks.
(no changes since v1)
common/spl/spl.c | 10 ++++------ include/spl.h | 8 ++++++-- 2 files changed, 10 insertions(+), 8 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 80a3a3f1516e..9870e9a65468 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -782,13 +782,11 @@ void board_init_r(gd_t *dummy1, ulong dummy2) } }
-#if CONFIG_IS_ENABLED(BOARD_INIT) - spl_board_init(); -#endif + if (CONFIG_IS_ENABLED(BOARD_INIT)) + spl_board_init();
-#if defined(CONFIG_SPL_WATCHDOG) && CONFIG_IS_ENABLED(WDT) - initr_watchdog(); -#endif + if (IS_ENABLED(CONFIG_SPL_WATCHDOG) && CONFIG_IS_ENABLED(WDT)) + initr_watchdog();
if (IS_ENABLED(CONFIG_SPL_OS_BOOT) || CONFIG_IS_ENABLED(HANDOFF) || IS_ENABLED(CONFIG_SPL_ATF)) diff --git a/include/spl.h b/include/spl.h index 92bcaa90a4af..d16cea3ea50b 100644 --- a/include/spl.h +++ b/include/spl.h @@ -707,9 +707,13 @@ int spl_early_init(void); */ int spl_init(void);
-#ifdef CONFIG_SPL_BOARD_INIT +/* + * spl_board_init() - Do board-specific init in SPL + * + * If xPL_BOARD_INIT is enabled, this is called from board_init_r() before + * jumping to the next phase. + */ void spl_board_init(void); -#endif
/** * spl_was_boot_source() - check if U-Boot booted from SPL
Move the condition to the header file to improve readability.
Changes in v2: - Change the approach to use the header file
common/spl/spl.c | 10 ++++------ include/system-constants.h | 7 +++++++ 2 files changed, 11 insertions(+), 6 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 9870e9a65468..703f45cd8044 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -810,9 +810,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2) }
memset(&spl_image, '\0', sizeof(spl_image)); -#ifdef CONFIG_SPL_PAYLOAD_ARGS_ADDR - spl_image.arg = (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR; -#endif + if (IS_ENABLED(CONFIG_SPL_OS_BOOT)) + spl_image.arg = (void *)SPL_PAYLOAD_ARGS_ADDR; spl_image.boot_device = BOOT_DEVICE_NONE; board_boot_order(spl_boot_list);
@@ -869,9 +868,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2) #if CONFIG_IS_ENABLED(OS_BOOT) case IH_OS_LINUX: debug("Jumping to Linux\n"); -#if defined(CONFIG_SPL_PAYLOAD_ARGS_ADDR) - spl_fixup_fdt((void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR); -#endif + if (IS_ENABLED(CONFIG_SPL_OS_BOOT)) + spl_fixup_fdt((void *)SPL_PAYLOAD_ARGS_ADDR); spl_board_prepare_for_linux(); jump_to_image_linux(&spl_image); #endif diff --git a/include/system-constants.h b/include/system-constants.h index dca6a86b01f5..59371568d1e7 100644 --- a/include/system-constants.h +++ b/include/system-constants.h @@ -34,4 +34,11 @@ #define SPL_SYS_MALLOC_SIZE \ IF_ENABLED_INT(CONFIG_SPL_SYS_MALLOC, CONFIG_SPL_SYS_MALLOC_SIZE)
+/* deal with an optional value */ +#ifdef CONFIG_SPL_OS_BOOT +#define SPL_PAYLOAD_ARGS_ADDR CONFIG_SPL_PAYLOAD_ARGS_ADDR +#else +#define SPL_PAYLOAD_ARGS_ADDR 0 +#endif + #endif
This code is pretty ugly, with many #ifdefs
There are quite a lot of IH_OS_U_BOOT values so the compiler struggles to create a jump table here. Also, most of the options are normally disabled.
Change it to an else...if construct instead. Add an accessor for the spl_image field behind an #ifdef to avoid needing #ifdef in the C code.
common/spl/spl.c | 32 ++++++++++---------------------- include/spl.h | 9 +++++++++ 2 files changed, 19 insertions(+), 22 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 703f45cd8044..8511c66d7394 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -748,7 +748,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) BOOT_DEVICE_NONE, }; struct spl_image_info spl_image; - int ret; + int ret, os;
debug(">>" SPL_TPL_PROMPT "board_init_r()\n");
@@ -841,39 +841,27 @@ void board_init_r(gd_t *dummy1, ulong dummy2) ret); }
- switch (spl_image.os) { - case IH_OS_U_BOOT: + os = spl_image.os; + if (os == IH_OS_U_BOOT) { debug("Jumping to %s...\n", spl_phase_name(spl_next_phase())); - break; -#if CONFIG_IS_ENABLED(ATF) - case IH_OS_ARM_TRUSTED_FIRMWARE: + } else if (CONFIG_IS_ENABLED(ATF) && os == IH_OS_ARM_TRUSTED_FIRMWARE) { debug("Jumping to U-Boot via ARM Trusted Firmware\n"); - spl_fixup_fdt(spl_image.fdt_addr); + spl_fixup_fdt(spl_image_fdt_addr(&spl_image)); spl_invoke_atf(&spl_image); - break; -#endif -#if CONFIG_IS_ENABLED(OPTEE_IMAGE) - case IH_OS_TEE: + } else if (CONFIG_IS_ENABLED(OPTEE_IMAGE) && os == IH_OS_TEE) { debug("Jumping to U-Boot via OP-TEE\n"); - spl_board_prepare_for_optee(spl_image.fdt_addr); + spl_board_prepare_for_optee(spl_image_fdt_addr(&spl_image)); jump_to_image_optee(&spl_image); - break; -#endif -#if CONFIG_IS_ENABLED(OPENSBI) - case IH_OS_OPENSBI: + } else if (CONFIG_IS_ENABLED(OPENSBI) && os == IH_OS_OPENSBI) { debug("Jumping to U-Boot via RISC-V OpenSBI\n"); spl_invoke_opensbi(&spl_image); - break; -#endif -#if CONFIG_IS_ENABLED(OS_BOOT) - case IH_OS_LINUX: + } else if (CONFIG_IS_ENABLED(OS_BOOT) && os == IH_OS_LINUX) { debug("Jumping to Linux\n"); if (IS_ENABLED(CONFIG_SPL_OS_BOOT)) spl_fixup_fdt((void *)SPL_PAYLOAD_ARGS_ADDR); spl_board_prepare_for_linux(); jump_to_image_linux(&spl_image); -#endif - default: + } else { debug("Unsupported OS image.. Jumping nevertheless..\n"); } #if CONFIG_VAL(SYS_MALLOC_F_LEN) && !defined(CONFIG_SPL_SYS_MALLOC_SIZE) diff --git a/include/spl.h b/include/spl.h index d16cea3ea50b..60b55b75195b 100644 --- a/include/spl.h +++ b/include/spl.h @@ -263,6 +263,15 @@ struct spl_image_info { #endif };
+static inline void *spl_image_fdt_addr(struct spl_image_info *info) +{ +#if CONFIG_IS_ENABLED(LOAD_FIT) || CONFIG_IS_ENABLED(LOAD_FIT_FULL) + return info->fdt_addr; +#else + return 0; +#endif +} + /** * Information required to load data from a device *
Use an accessor in the header file to avoid this.
Changes in v2: - Use the same condition for both pieces to avoid possible problems
common/spl/spl.c | 9 +++++---- include/asm-generic/global_data.h | 7 +++++++ 2 files changed, 12 insertions(+), 4 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 8511c66d7394..5f57b51ca2d1 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -864,10 +864,11 @@ void board_init_r(gd_t *dummy1, ulong dummy2) } else { debug("Unsupported OS image.. Jumping nevertheless..\n"); } -#if CONFIG_VAL(SYS_MALLOC_F_LEN) && !defined(CONFIG_SPL_SYS_MALLOC_SIZE) - debug("SPL malloc() used 0x%lx bytes (%ld KB)\n", gd->malloc_ptr, - gd->malloc_ptr / 1024); -#endif + if (IS_ENABLED(CONFIG_SYS_MALLOC_F) && + !IS_ENABLED(CONFIG_SPL_SYS_MALLOC_SIZE)) + debug("SPL malloc() used 0x%lx bytes (%ld KB)\n", + gd_malloc_ptr(), gd_malloc_ptr() / 1024); + bootstage_mark_name(get_bootstage_id(false), "end phase"); #ifdef CONFIG_BOOTSTAGE_STASH ret = bootstage_stash((void *)CONFIG_BOOTSTAGE_STASH_ADDR, diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 8fc205ded1a3..edf9ff6823f2 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -573,6 +573,13 @@ static_assert(sizeof(struct global_data) == GD_SIZE); #define gd_malloc_start() 0 #define gd_set_malloc_start(val) #endif + +#if CONFIG_VAL(SYS_MALLOC_F_LEN) +#define gd_malloc_ptr() gd->malloc_ptr +#else +#define gd_malloc_ptr() 0L +#endif + /** * enum gd_flags - global data flags *
This feature has some helpers in its header file so that its functions resolve to nothing when the feature is disabled. Add a few more and use these to simplify the code.
With this there are no more #ifdefs in board_init_r()
common/spl/spl.c | 15 +++------------ include/bootstage.h | 26 ++++++++++++++++++++++++++ 2 files changed, 29 insertions(+), 12 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 5f57b51ca2d1..8541bef00466 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -542,17 +542,11 @@ static int spl_common_init(bool setup_malloc) ret); return ret; } -#ifdef CONFIG_BOOTSTAGE_STASH if (!u_boot_first_phase()) { - const void *stash = map_sysmem(CONFIG_BOOTSTAGE_STASH_ADDR, - CONFIG_BOOTSTAGE_STASH_SIZE); - - ret = bootstage_unstash(stash, CONFIG_BOOTSTAGE_STASH_SIZE); + ret = bootstage_unstash_default(); if (ret) - debug("%s: Failed to unstash bootstage: ret=%d\n", - __func__, ret); + log_debug("Failed to unstash bootstage: ret=%d\n", ret); } -#endif /* CONFIG_BOOTSTAGE_STASH */ bootstage_mark_name(get_bootstage_id(true), spl_phase_name(spl_phase())); #if CONFIG_IS_ENABLED(LOG) @@ -870,12 +864,9 @@ void board_init_r(gd_t *dummy1, ulong dummy2) gd_malloc_ptr(), gd_malloc_ptr() / 1024);
bootstage_mark_name(get_bootstage_id(false), "end phase"); -#ifdef CONFIG_BOOTSTAGE_STASH - ret = bootstage_stash((void *)CONFIG_BOOTSTAGE_STASH_ADDR, - CONFIG_BOOTSTAGE_STASH_SIZE); + ret = bootstage_stash_default(); if (ret) debug("Failed to stash bootstage: err=%d\n", ret); -#endif
if (IS_ENABLED(CONFIG_SPL_VIDEO_REMOVE)) { struct udevice *dev; diff --git a/include/bootstage.h b/include/bootstage.h index 685939ccffc0..38388afc259b 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -244,6 +244,8 @@ void show_boot_progress(int val);
#ifdef ENABLE_BOOTSTAGE
+#include <mapmem.h> + /* This is the full bootstage implementation */
/** @@ -364,6 +366,20 @@ int bootstage_stash(void *base, int size); */ int bootstage_unstash(const void *base, int size);
+static inline int bootstage_stash_default(void) +{ + return bootstage_stash(map_sysmem(CONFIG_BOOTSTAGE_STASH_ADDR, 0), + CONFIG_BOOTSTAGE_STASH_SIZE); +} + +static inline int bootstage_unstash_default(void) +{ + const void *stash = map_sysmem(CONFIG_BOOTSTAGE_STASH_ADDR, + CONFIG_BOOTSTAGE_STASH_SIZE); + + return bootstage_unstash(stash, CONFIG_BOOTSTAGE_STASH_SIZE); +} + /** * bootstage_get_size() - Get the size of the bootstage data * @@ -440,6 +456,16 @@ static inline int bootstage_unstash(const void *base, int size) return 0; /* Pretend to succeed */ }
+static inline int bootstage_stash_default(void) +{ + return 0; /* Pretend to succeed */ +} + +static inline int bootstage_unstash_default(void) +{ + return 0; /* Pretend to succeed */ +} + static inline int bootstage_get_size(void) { return 0;
We have two functions called spl_load_fit_image(), one in spl.c and one in spl_fit.c
Rename the second one, to indicate that it relates to simple FIT parsing, rather than the full version.
common/spl/spl_fit.c | 21 ++++++++++----------- 1 file changed, 10 insertions(+), 11 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 1bfdc0af4969..8e7d033dd1a4 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -207,7 +207,7 @@ static int get_aligned_image_size(struct spl_load_info *info, int data_size, }
/** - * spl_load_fit_image(): load the image described in a certain FIT node + * load_simple_fit(): load the image described in a certain FIT node * @info: points to information about the device to load data from * @sector: the start sector of the FIT image on the device * @ctx: points to the FIT context structure @@ -220,9 +220,9 @@ static int get_aligned_image_size(struct spl_load_info *info, int data_size, * * Return: 0 on success or a negative error number. */ -static int spl_load_fit_image(struct spl_load_info *info, ulong sector, - const struct spl_fit_info *ctx, int node, - struct spl_image_info *image_info) +static int load_simple_fit(struct spl_load_info *info, ulong sector, + const struct spl_fit_info *ctx, int node, + struct spl_image_info *image_info) { int offset; size_t length; @@ -385,8 +385,7 @@ static int spl_fit_append_fdt(struct spl_image_info *spl_image, else return node; } else { - ret = spl_load_fit_image(info, sector, ctx, node, - &image_info); + ret = load_simple_fit(info, sector, ctx, node, &image_info); if (ret < 0) return ret; } @@ -425,8 +424,8 @@ static int spl_fit_append_fdt(struct spl_image_info *spl_image, __func__); } image_info.load_addr = (ulong)tmpbuffer; - ret = spl_load_fit_image(info, sector, ctx, - node, &image_info); + ret = load_simple_fit(info, sector, ctx, node, + &image_info); if (ret < 0) break;
@@ -616,7 +615,7 @@ static int spl_fit_load_fpga(struct spl_fit_info *ctx, warn_deprecated("'fpga' property in config node. Use 'loadables'");
/* Load the image and set up the fpga_image structure */ - ret = spl_load_fit_image(info, sector, ctx, node, &fpga_image); + ret = load_simple_fit(info, sector, ctx, node, &fpga_image); if (ret) { printf("%s: Cannot load the FPGA: %i\n", __func__, ret); return ret; @@ -741,7 +740,7 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, }
/* Load the image and set up the spl_image structure */ - ret = spl_load_fit_image(info, sector, &ctx, node, spl_image); + ret = load_simple_fit(info, sector, &ctx, node, spl_image); if (ret) return ret;
@@ -782,7 +781,7 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, continue;
image_info.load_addr = 0; - ret = spl_load_fit_image(info, sector, &ctx, node, &image_info); + ret = load_simple_fit(info, sector, &ctx, node, &image_info); if (ret < 0) { printf("%s: can't load image loadables index %d (ret = %d)\n", __func__, index, ret);
For some reason this code was put in the main spl.c file. Move it out to the FIT implementation where it belongs.
common/spl/spl.c | 108 +++---------------------------------------- common/spl/spl_fit.c | 93 +++++++++++++++++++++++++++++++++++++ include/spl.h | 11 +++++ 3 files changed, 111 insertions(+), 101 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 8541bef00466..1f0412b96b32 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -260,102 +260,6 @@ void spl_set_header_raw_uboot(struct spl_image_info *spl_image) } #endif
-#if CONFIG_IS_ENABLED(LOAD_FIT_FULL) -/* Parse and load full fitImage in SPL */ -static int spl_load_fit_image(struct spl_image_info *spl_image, - const struct legacy_img_hdr *header) -{ - struct bootm_headers images; - const char *fit_uname_config = NULL; - uintptr_t fdt_hack; - const char *uname; - ulong fw_data = 0, dt_data = 0, img_data = 0; - ulong fw_len = 0, dt_len = 0, img_len = 0; - int idx, conf_noffset; - int ret; - -#ifdef CONFIG_SPL_FIT_SIGNATURE - images.verify = 1; -#endif - ret = fit_image_load(&images, (ulong)header, - NULL, &fit_uname_config, - IH_ARCH_DEFAULT, IH_TYPE_STANDALONE, -1, - FIT_LOAD_OPTIONAL, &fw_data, &fw_len); - if (ret >= 0) { - printf("DEPRECATED: 'standalone = ' property."); - printf("Please use either 'firmware =' or 'kernel ='\n"); - } else { - ret = fit_image_load(&images, (ulong)header, NULL, - &fit_uname_config, IH_ARCH_DEFAULT, - IH_TYPE_FIRMWARE, -1, FIT_LOAD_OPTIONAL, - &fw_data, &fw_len); - } - - if (ret < 0) { - ret = fit_image_load(&images, (ulong)header, NULL, - &fit_uname_config, IH_ARCH_DEFAULT, - IH_TYPE_KERNEL, -1, FIT_LOAD_OPTIONAL, - &fw_data, &fw_len); - } - - if (ret < 0) - return ret; - - spl_image->size = fw_len; - spl_image->entry_point = fw_data; - spl_image->load_addr = fw_data; - if (fit_image_get_os(header, ret, &spl_image->os)) - spl_image->os = IH_OS_INVALID; - spl_image->name = genimg_get_os_name(spl_image->os); - - debug(SPL_TPL_PROMPT "payload image: %32s load addr: 0x%lx size: %d\n", - spl_image->name, spl_image->load_addr, spl_image->size); - -#ifdef CONFIG_SPL_FIT_SIGNATURE - images.verify = 1; -#endif - ret = fit_image_load(&images, (ulong)header, NULL, &fit_uname_config, - IH_ARCH_DEFAULT, IH_TYPE_FLATDT, -1, - FIT_LOAD_OPTIONAL, &dt_data, &dt_len); - if (ret >= 0) { - spl_image->fdt_addr = (void *)dt_data; - - if (spl_image->os == IH_OS_U_BOOT) { - /* HACK: U-Boot expects FDT at a specific address */ - fdt_hack = spl_image->load_addr + spl_image->size; - fdt_hack = (fdt_hack + 3) & ~3; - debug("Relocating FDT to %p\n", spl_image->fdt_addr); - memcpy((void *)fdt_hack, spl_image->fdt_addr, dt_len); - } - } - - conf_noffset = fit_conf_get_node((const void *)header, - fit_uname_config); - if (conf_noffset < 0) - return 0; - - for (idx = 0; - uname = fdt_stringlist_get((const void *)header, conf_noffset, - FIT_LOADABLE_PROP, idx, - NULL), uname; - idx++) - { -#ifdef CONFIG_SPL_FIT_SIGNATURE - images.verify = 1; -#endif - ret = fit_image_load(&images, (ulong)header, - &uname, &fit_uname_config, - IH_ARCH_DEFAULT, IH_TYPE_LOADABLE, -1, - FIT_LOAD_OPTIONAL_NON_ZERO, - &img_data, &img_len); - if (ret < 0) - return ret; - } - - return 0; -} -#endif - __weak int spl_parse_board_header(struct spl_image_info *spl_image, const struct spl_boot_device *bootdev, const void *image_header, size_t size) @@ -375,12 +279,14 @@ int spl_parse_image_header(struct spl_image_info *spl_image, const struct spl_boot_device *bootdev, const struct legacy_img_hdr *header) { -#if CONFIG_IS_ENABLED(LOAD_FIT_FULL) - int ret = spl_load_fit_image(spl_image, header); + int ret;
- if (!ret) - return ret; -#endif + if (CONFIG_IS_ENABLED(LOAD_FIT_FULL)) { + ret = spl_load_fit_image(spl_image, header); + + if (!ret) + return ret; + } if (image_get_magic(header) == IH_MAGIC) { int ret;
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 8e7d033dd1a4..5b5f6c620457 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -826,3 +826,96 @@ int spl_load_simple_fit(struct spl_image_info *spl_image,
return 0; } + +/* Parse and load full fitImage in SPL */ +int spl_load_fit_image(struct spl_image_info *spl_image, + const struct legacy_img_hdr *header) +{ + struct bootm_headers images; + const char *fit_uname_config = NULL; + uintptr_t fdt_hack; + const char *uname; + ulong fw_data = 0, dt_data = 0, img_data = 0; + ulong fw_len = 0, dt_len = 0, img_len = 0; + int idx, conf_noffset; + int ret; + +#ifdef CONFIG_SPL_FIT_SIGNATURE + images.verify = 1; +#endif + ret = fit_image_load(&images, (ulong)header, + NULL, &fit_uname_config, + IH_ARCH_DEFAULT, IH_TYPE_STANDALONE, -1, + FIT_LOAD_OPTIONAL, &fw_data, &fw_len); + if (ret >= 0) { + printf("DEPRECATED: 'standalone = ' property."); + printf("Please use either 'firmware =' or 'kernel ='\n"); + } else { + ret = fit_image_load(&images, (ulong)header, NULL, + &fit_uname_config, IH_ARCH_DEFAULT, + IH_TYPE_FIRMWARE, -1, FIT_LOAD_OPTIONAL, + &fw_data, &fw_len); + } + + if (ret < 0) { + ret = fit_image_load(&images, (ulong)header, NULL, + &fit_uname_config, IH_ARCH_DEFAULT, + IH_TYPE_KERNEL, -1, FIT_LOAD_OPTIONAL, + &fw_data, &fw_len); + } + + if (ret < 0) + return ret; + + spl_image->size = fw_len; + spl_image->entry_point = fw_data; + spl_image->load_addr = fw_data; + if (fit_image_get_os(header, ret, &spl_image->os)) + spl_image->os = IH_OS_INVALID; + spl_image->name = genimg_get_os_name(spl_image->os); + + debug(SPL_TPL_PROMPT "payload image: %32s load addr: 0x%lx size: %d\n", + spl_image->name, spl_image->load_addr, spl_image->size); + +#ifdef CONFIG_SPL_FIT_SIGNATURE + images.verify = 1; +#endif + ret = fit_image_load(&images, (ulong)header, NULL, &fit_uname_config, + IH_ARCH_DEFAULT, IH_TYPE_FLATDT, -1, + FIT_LOAD_OPTIONAL, &dt_data, &dt_len); + if (ret >= 0) { + spl_image->fdt_addr = (void *)dt_data; + + if (spl_image->os == IH_OS_U_BOOT) { + /* HACK: U-Boot expects FDT at a specific address */ + fdt_hack = spl_image->load_addr + spl_image->size; + fdt_hack = (fdt_hack + 3) & ~3; + debug("Relocating FDT to %p\n", spl_image->fdt_addr); + memcpy((void *)fdt_hack, spl_image->fdt_addr, dt_len); + } + } + + conf_noffset = fit_conf_get_node((const void *)header, + fit_uname_config); + if (conf_noffset < 0) + return 0; + + for (idx = 0; + uname = fdt_stringlist_get((const void *)header, conf_noffset, + FIT_LOADABLE_PROP, idx, + NULL), uname; + idx++) { +#ifdef CONFIG_SPL_FIT_SIGNATURE + images.verify = 1; +#endif + ret = fit_image_load(&images, (ulong)header, + &uname, &fit_uname_config, + IH_ARCH_DEFAULT, IH_TYPE_LOADABLE, -1, + FIT_LOAD_OPTIONAL_NON_ZERO, + &img_data, &img_len); + if (ret < 0) + return ret; + } + + return 0; +} diff --git a/include/spl.h b/include/spl.h index 60b55b75195b..e958ace2cc62 100644 --- a/include/spl.h +++ b/include/spl.h @@ -910,4 +910,15 @@ struct legacy_img_hdr *spl_get_load_buffer(ssize_t offset, size_t size);
void board_boot_order(u32 *spl_boot_list); void spl_save_restore_data(void); + +/** + * spl_load_fit_image() - Fully parse and a FIT image in SPL + * + * @spl_image: SPL Image data to fill in + * @header: Pointer to FIT image + * Return 0 if OK, -ve on error + */ +int spl_load_fit_image(struct spl_image_info *spl_image, + const struct legacy_img_hdr *header); + #endif
Rather than open-coding the property names, use the existing constants provided for this purpose. This better aligns the simple-FIT code with the full FIT implementation.
common/spl/spl_fit.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 5b5f6c620457..03ff9a5db9a8 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -43,7 +43,7 @@ static int find_node_from_desc(const void *fit, int node, const char *str) for (child = fdt_first_subnode(fit, node); child >= 0; child = fdt_next_subnode(fit, child)) { int len; - const char *desc = fdt_getprop(fit, child, "description", &len); + const char *desc = fdt_getprop(fit, child, FIT_DESC_PROP, &len);
if (!desc) continue; @@ -475,10 +475,11 @@ static int spl_fit_record_loadable(const struct spl_fit_info *ctx, int index, node = spl_fit_get_image_node(ctx, "loadables", index);
ret = fdt_record_loadable(blob, index, name, image->load_addr, - image->size, image->entry_point, - fdt_getprop(ctx->fit, node, "type", NULL), - fdt_getprop(ctx->fit, node, "os", NULL), - fdt_getprop(ctx->fit, node, "arch", NULL)); + image->size, image->entry_point, + fdt_getprop(ctx->fit, node, FIT_TYPE_PROP, NULL), + fdt_getprop(ctx->fit, node, FIT_OS_PROP, NULL), + fdt_getprop(ctx->fit, node, FIT_ARCH_PROP, NULL)); + return ret; }
The bloblist should not be finalised until the image is fully set up. This allows any final handoff information to be included in the bloblist.
common/spl/spl.c | 24 ++++++++++++------------ 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 1f0412b96b32..b554ea0b1944 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -728,18 +728,6 @@ void board_init_r(gd_t *dummy1, ulong dummy2) }
spl_perform_fixups(&spl_image); - if (CONFIG_IS_ENABLED(HANDOFF)) { - ret = write_spl_handoff(); - if (ret) - printf(SPL_TPL_PROMPT - "SPL hand-off write failed (err=%d)\n", ret); - } - if (CONFIG_IS_ENABLED(BLOBLIST)) { - ret = bloblist_finish(); - if (ret) - printf("Warning: Failed to finish bloblist (ret=%d)\n", - ret); - }
os = spl_image.os; if (os == IH_OS_U_BOOT) { @@ -786,6 +774,18 @@ void board_init_r(gd_t *dummy1, ulong dummy2) dev->name, rc); } } + if (CONFIG_IS_ENABLED(HANDOFF)) { + ret = write_spl_handoff(); + if (ret) + printf(SPL_TPL_PROMPT + "SPL hand-off write failed (err=%d)\n", ret); + } + if (CONFIG_IS_ENABLED(BLOBLIST)) { + ret = bloblist_finish(); + if (ret) + printf("Warning: Failed to finish bloblist (ret=%d)\n", + ret); + }
spl_board_prepare_for_boot(); jump_to_image_no_args(&spl_image);
Follow the order used by memcpy() as it may be less confusing.
boot/vbe_request.c | 2 +- boot/vbe_simple_os.c | 2 +- drivers/core/ofnode.c | 2 +- include/dm/ofnode.h | 6 +++--- test/dm/ofnode.c | 9 ++++----- 5 files changed, 10 insertions(+), 11 deletions(-)
diff --git a/boot/vbe_request.c b/boot/vbe_request.c index 2f218d4bf97c..917251afa1ca 100644 --- a/boot/vbe_request.c +++ b/boot/vbe_request.c @@ -187,7 +187,7 @@ static int bootmeth_vbe_ft_fixup(void *ctx, struct event *event) ret = ofnode_add_subnode(dest_parent, name, &dest); if (ret && ret != -EEXIST) return log_msg_ret("add", ret); - ret = ofnode_copy_props(node, dest); + ret = ofnode_copy_props(dest, node); if (ret) return log_msg_ret("cp", ret);
diff --git a/boot/vbe_simple_os.c b/boot/vbe_simple_os.c index 3285e438a568..84626cdeaf24 100644 --- a/boot/vbe_simple_os.c +++ b/boot/vbe_simple_os.c @@ -94,7 +94,7 @@ static int bootmeth_vbe_simple_ft_fixup(void *ctx, struct event *event)
/* Copy over the vbe properties for fwupd */ log_debug("Fixing up: %s\n", dev->name); - ret = ofnode_copy_props(dev_ofnode(dev), subnode); + ret = ofnode_copy_props(subnode, dev_ofnode(dev)); if (ret) return log_msg_ret("cp", ret);
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 8311282abf69..8227eac1e4fe 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1672,7 +1672,7 @@ int ofnode_add_subnode(ofnode node, const char *name, ofnode *subnodep) return ret; /* 0 or -EEXIST */ }
-int ofnode_copy_props(ofnode src, ofnode dst) +int ofnode_copy_props(ofnode dst, ofnode src) { struct ofprop prop;
diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 0a85db31f360..abdfa58036d5 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1545,7 +1545,7 @@ int ofnode_add_subnode(ofnode parent, const char *name, ofnode *nodep); /** * ofnode_copy_props() - copy all properties from one node to another * - * Makes a copy of all properties from the source note in the destination node. + * Makes a copy of all properties from the source node to the destination node. * Existing properties in the destination node remain unchanged, except that * any with the same name are overwritten, including changing the size of the * property. @@ -1553,9 +1553,9 @@ int ofnode_add_subnode(ofnode parent, const char *name, ofnode *nodep); * For livetree, properties are copied / allocated, so the source tree does not * need to be present afterwards. * + * @dst: Destination node to write properties to * @src: Source node to read properties from - * @dst: Destination node to write properties too */ -int ofnode_copy_props(ofnode src, ofnode dst); +int ofnode_copy_props(ofnode dst, ofnode src);
#endif diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index b74f5c2ebcff..49fa5d27e6ec 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -1190,12 +1190,11 @@ static int dm_test_ofnode_too_many(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_too_many, UT_TESTF_SCAN_FDT);
-static int check_copy_props(struct unit_test_state *uts, ofnode src, - ofnode dst) +static int check_copy_props(struct unit_test_state *uts, ofnode dst, ofnode src) { u32 reg[2], val;
- ut_assertok(ofnode_copy_props(src, dst)); + ut_assertok(ofnode_copy_props(dst, src));
ut_assertok(ofnode_read_u32(dst, "ping-expect", &val)); ut_asserteq(3, val); @@ -1227,7 +1226,7 @@ static int dm_test_ofnode_copy_props(struct unit_test_state *uts) src = ofnode_path("/b-test"); dst = ofnode_path("/some-bus");
- ut_assertok(check_copy_props(uts, src, dst)); + ut_assertok(check_copy_props(uts, dst, src));
/* check a property that is in the destination already */ ut_asserteq_str("mux0", ofnode_read_string(dst, "mux-control-names")); @@ -1243,7 +1242,7 @@ static int dm_test_ofnode_copy_props_ot(struct unit_test_state *uts)
src = ofnode_path("/b-test"); dst = oftree_path(otree, "/node/subnode2"); - ut_assertok(check_copy_props(uts, src, dst)); + ut_assertok(check_copy_props(uts, dst, src));
return 0; }
We need the UT_TESTF_SCAN_FDT flag set for these tests to run with flat tree. In some cases it is missing, so add it.
test/dm/ofnode.c | 33 ++++++++++++++++++--------------- 1 file changed, 18 insertions(+), 15 deletions(-)
diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index 49fa5d27e6ec..a29c9aae870b 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -114,7 +114,7 @@ static int dm_test_ofnode_compatible_ot(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_compatible_ot, UT_TESTF_OTHER_FDT); +DM_TEST(dm_test_ofnode_compatible_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
static int dm_test_ofnode_get_by_phandle(struct unit_test_state *uts) { @@ -146,7 +146,8 @@ static int dm_test_ofnode_get_by_phandle_ot(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_get_by_phandle_ot, UT_TESTF_OTHER_FDT); +DM_TEST(dm_test_ofnode_get_by_phandle_ot, + UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
static int check_prop_values(struct unit_test_state *uts, ofnode start, const char *propname, const char *propval, @@ -196,7 +197,8 @@ static int dm_test_ofnode_by_prop_value_ot(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_by_prop_value_ot, UT_TESTF_OTHER_FDT); +DM_TEST(dm_test_ofnode_by_prop_value_ot, + UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
static int dm_test_ofnode_fmap(struct unit_test_state *uts) { @@ -237,7 +239,7 @@ static int dm_test_ofnode_read(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_read, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); +DM_TEST(dm_test_ofnode_read, UT_TESTF_SCAN_FDT);
static int dm_test_ofnode_read_ot(struct unit_test_state *uts) { @@ -256,7 +258,7 @@ static int dm_test_ofnode_read_ot(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_read_ot, UT_TESTF_OTHER_FDT); +DM_TEST(dm_test_ofnode_read_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
static int dm_test_ofnode_phandle(struct unit_test_state *uts) { @@ -452,7 +454,8 @@ static int dm_test_ofnode_get_child_count_ot(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_get_child_count_ot, UT_TESTF_OTHER_FDT); +DM_TEST(dm_test_ofnode_get_child_count_ot, + UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
static int dm_test_ofnode_is_enabled(struct unit_test_state *uts) { @@ -526,7 +529,7 @@ static int dm_test_ofnode_get_reg_ot(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_get_reg_ot, UT_TESTF_OTHER_FDT); +DM_TEST(dm_test_ofnode_get_reg_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
static int dm_test_ofnode_get_path(struct unit_test_state *uts) { @@ -566,7 +569,7 @@ static int dm_test_ofnode_get_path_ot(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_get_path_ot, UT_TESTF_OTHER_FDT); +DM_TEST(dm_test_ofnode_get_path_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
static int dm_test_ofnode_conf(struct unit_test_state *uts) { @@ -581,7 +584,7 @@ static int dm_test_ofnode_conf(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_conf, 0); +DM_TEST(dm_test_ofnode_conf, UT_TESTF_SCAN_FDT);
static int dm_test_ofnode_for_each_compatible_node(struct unit_test_state *uts) { @@ -646,7 +649,7 @@ static int dm_test_ofnode_string(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_string, 0); +DM_TEST(dm_test_ofnode_string, UT_TESTF_SCAN_FDT);
static int dm_test_ofnode_string_err(struct unit_test_state *uts) { @@ -717,7 +720,7 @@ static int dm_test_ofnode_get_phy(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_get_phy, 0); +DM_TEST(dm_test_ofnode_get_phy, UT_TESTF_SCAN_FDT);
/** * make_ofnode_fdt() - Create an FDT for testing with ofnode @@ -901,7 +904,7 @@ static int dm_test_ofnode_write_copy_ot(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_write_copy_ot, UT_TESTF_OTHER_FDT); +DM_TEST(dm_test_ofnode_write_copy_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
static int dm_test_ofnode_u32(struct unit_test_state *uts) { @@ -1103,7 +1106,7 @@ static int dm_test_ofnode_by_compatible_ot(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_by_compatible_ot, UT_TESTF_OTHER_FDT); +DM_TEST(dm_test_ofnode_by_compatible_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
static int dm_test_ofnode_find_subnode(struct unit_test_state *uts) { @@ -1272,7 +1275,7 @@ static int dm_test_livetree_align(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_livetree_align, UT_TESTF_LIVE_TREE); +DM_TEST(dm_test_livetree_align, UT_TESTF_SCAN_FDT | UT_TESTF_LIVE_TREE);
/* check that it is possible to load an arbitrary livetree */ static int dm_test_livetree_ensure(struct unit_test_state *uts) @@ -1291,4 +1294,4 @@ static int dm_test_livetree_ensure(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_livetree_ensure, 0); +DM_TEST(dm_test_livetree_ensure, UT_TESTF_SCAN_FDT);
Add comments to the functions where the test name does not indicate what is being tested. Rename functions in a few cases, so that a search for the function will also file its test.
test/dm/ofnode.c | 46 +++++++++++++++++++++++++++++++++++++++------- 1 file changed, 39 insertions(+), 7 deletions(-)
diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index a29c9aae870b..84ed7f92b235 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -91,6 +91,7 @@ void free_oftree(oftree tree) free(tree.np); }
+/* test ofnode_device_is_compatible() */ static int dm_test_ofnode_compatible(struct unit_test_state *uts) { ofnode root_node = ofnode_path("/"); @@ -134,6 +135,7 @@ static int dm_test_ofnode_get_by_phandle(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_get_by_phandle, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+/* test oftree_get_by_phandle() with a the 'other' oftree */ static int dm_test_ofnode_get_by_phandle_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); @@ -188,6 +190,7 @@ static int dm_test_ofnode_by_prop_value(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_by_prop_value, UT_TESTF_SCAN_FDT);
+/* test ofnode_by_prop_value() with a the 'other' oftree */ static int dm_test_ofnode_by_prop_value_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); @@ -200,6 +203,7 @@ static int dm_test_ofnode_by_prop_value_ot(struct unit_test_state *uts) DM_TEST(dm_test_ofnode_by_prop_value_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
+/* test ofnode_read_fmap_entry() */ static int dm_test_ofnode_fmap(struct unit_test_state *uts) { struct fmap_entry entry; @@ -215,6 +219,7 @@ static int dm_test_ofnode_fmap(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_fmap, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+/* test ofnode_read_prop() */ static int dm_test_ofnode_read(struct unit_test_state *uts) { const u32 *val; @@ -241,6 +246,7 @@ static int dm_test_ofnode_read(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_read, UT_TESTF_SCAN_FDT);
+/* test ofnode_read_prop() with the 'other' tree */ static int dm_test_ofnode_read_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); @@ -260,6 +266,7 @@ static int dm_test_ofnode_read_ot(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_read_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
+/* test ofnode_count_/parse_phandle_with_args() */ static int dm_test_ofnode_phandle(struct unit_test_state *uts) { struct ofnode_phandle_args args; @@ -335,6 +342,7 @@ static int dm_test_ofnode_phandle(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_phandle, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+/* test ofnode_count_/parse_phandle_with_args() with 'other' tree */ static int dm_test_ofnode_phandle_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); @@ -363,6 +371,7 @@ static int dm_test_ofnode_phandle_ot(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_phandle_ot, UT_TESTF_OTHER_FDT);
+/* test ofnode_read_chosen_string/node/prop() */ static int dm_test_ofnode_read_chosen(struct unit_test_state *uts) { const char *str; @@ -392,6 +401,7 @@ static int dm_test_ofnode_read_chosen(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_read_chosen, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+/* test ofnode_get_aliases_node/prop() */ static int dm_test_ofnode_read_aliases(struct unit_test_state *uts) { const void *val; @@ -435,6 +445,7 @@ static int dm_test_ofnode_get_child_count(struct unit_test_state *uts) DM_TEST(dm_test_ofnode_get_child_count, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+/* test ofnode_get_child_count() with 'other' tree */ static int dm_test_ofnode_get_child_count_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); @@ -469,6 +480,7 @@ static int dm_test_ofnode_is_enabled(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_is_enabled, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+/* test ofnode_is_enabled() with 'other' tree */ static int dm_test_ofnode_is_enabled_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); @@ -482,6 +494,7 @@ static int dm_test_ofnode_is_enabled_ot(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_is_enabled_ot, UT_TESTF_OTHER_FDT);
+/* test ofnode_get_addr/size() */ static int dm_test_ofnode_get_reg(struct unit_test_state *uts) { ofnode node; @@ -518,6 +531,7 @@ static int dm_test_ofnode_get_reg(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_get_reg, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+/* test ofnode_get_addr() with 'other' tree */ static int dm_test_ofnode_get_reg_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); @@ -552,6 +566,7 @@ static int dm_test_ofnode_get_path(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_get_path, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+/* test ofnode_get_path() with 'other' tree */ static int dm_test_ofnode_get_path_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); @@ -571,6 +586,7 @@ static int dm_test_ofnode_get_path_ot(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_get_path_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
+/* test ofnode_conf_read_bool/int/str() */ static int dm_test_ofnode_conf(struct unit_test_state *uts) { ut_assert(!ofnode_conf_read_bool("missing")); @@ -604,6 +620,7 @@ static int dm_test_ofnode_for_each_compatible_node(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_for_each_compatible_node, UT_TESTF_SCAN_FDT);
+/* test dm_test_ofnode_string_count/index/list() */ static int dm_test_ofnode_string(struct unit_test_state *uts) { const char **val; @@ -651,6 +668,7 @@ static int dm_test_ofnode_string(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_string, UT_TESTF_SCAN_FDT);
+/* test error returns from ofnode_read_string_count/index/list() */ static int dm_test_ofnode_string_err(struct unit_test_state *uts) { const char **val; @@ -700,7 +718,7 @@ static int dm_test_ofnode_string_err(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_string_err, UT_TESTF_LIVE_TREE);
-static int dm_test_ofnode_get_phy(struct unit_test_state *uts) +static int dm_test_ofnode_read_phy_mode(struct unit_test_state *uts) { ofnode eth_node, phy_node; phy_interface_t mode; @@ -720,7 +738,7 @@ static int dm_test_ofnode_get_phy(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_get_phy, UT_TESTF_SCAN_FDT); +DM_TEST(dm_test_ofnode_read_phy_mode, UT_TESTF_SCAN_FDT);
/** * make_ofnode_fdt() - Create an FDT for testing with ofnode @@ -754,11 +772,11 @@ static int make_ofnode_fdt(struct unit_test_state *uts, void *fdt, int size, return 0; }
-static int dm_test_ofnode_root(struct unit_test_state *uts) +/* Check that aliases work on the control FDT */ +static int dm_test_ofnode_aliases(struct unit_test_state *uts) { ofnode node;
- /* Check that aliases work on the control FDT */ node = ofnode_get_aliases_node("ethernet3"); ut_assert(ofnode_valid(node)); ut_asserteq_str("sbe5", ofnode_get_name(node)); @@ -767,8 +785,15 @@ static int dm_test_ofnode_root(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_root, UT_TESTF_SCAN_FDT); +DM_TEST(dm_test_ofnode_aliases, UT_TESTF_SCAN_FDT);
+/** + * dm_test_ofnode_root_mult() - Check aliaes on control and 'other' tree + * + * Check that aliases work only with the control FDT, not with 'other' tree. + * This is not actually the desired behaviour. If aliases are implemented for + * any tree, then this test should be changed. + */ static int dm_test_ofnode_root_mult(struct unit_test_state *uts) { char fdt[256]; @@ -801,6 +826,7 @@ static int dm_test_ofnode_root_mult(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_root_mult, UT_TESTF_SCAN_FDT);
+/* test ofnode_set_enabled(), ofnode_write_prop() on a livetree */ static int dm_test_ofnode_livetree_writing(struct unit_test_state *uts) { struct udevice *dev; @@ -890,6 +916,7 @@ static int dm_test_ofnode_write_copy(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_write_copy, UT_TESTF_SCAN_FDT);
+/* test writing a property to the 'other' tree */ static int dm_test_ofnode_write_copy_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); @@ -906,6 +933,7 @@ static int dm_test_ofnode_write_copy_ot(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_write_copy_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
+/* test ofnode_read_u32_index/default() */ static int dm_test_ofnode_u32(struct unit_test_state *uts) { ofnode node; @@ -933,6 +961,7 @@ static int dm_test_ofnode_u32(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_u32, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+/* test ofnode_read_u32_array() */ static int dm_test_ofnode_u32_array(struct unit_test_state *uts) { ofnode node; @@ -959,7 +988,7 @@ static int dm_test_ofnode_u32_array(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_u32_array, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
-static int dm_test_ofnode_u64(struct unit_test_state *uts) +static int dm_test_ofnode_read_u64(struct unit_test_state *uts) { ofnode node; u64 val; @@ -980,7 +1009,7 @@ static int dm_test_ofnode_u64(struct unit_test_state *uts)
return 0; } -DM_TEST(dm_test_ofnode_u64, UT_TESTF_SCAN_FDT); +DM_TEST(dm_test_ofnode_read_u64, UT_TESTF_SCAN_FDT);
static int dm_test_ofnode_add_subnode(struct unit_test_state *uts) { @@ -1091,6 +1120,7 @@ static int dm_test_ofnode_by_compatible(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_by_compatible, UT_TESTF_SCAN_FDT);
+/* check ofnode_by_compatible() on the 'other' tree */ static int dm_test_ofnode_by_compatible_ot(struct unit_test_state *uts) { const char *compat = "sandbox-other2"; @@ -1125,6 +1155,7 @@ static int dm_test_ofnode_find_subnode(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_find_subnode, UT_TESTF_SCAN_FDT);
+/* test ofnode_find_subnode() on the 'other' tree */ static int dm_test_ofnode_find_subnode_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); @@ -1238,6 +1269,7 @@ static int dm_test_ofnode_copy_props(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_copy_props, UT_TESTF_SCAN_FDT);
+/* test ofnode_copy_props() with the 'other' tree */ static int dm_test_ofnode_copy_props_ot(struct unit_test_state *uts) { ofnode src, dst;
Provide a function to create a new, empty tree.
drivers/core/ofnode.c | 56 +++++++++++++++++++++++++++++++++++++++---- include/dm/ofnode.h | 9 +++++++ include/of_live.h | 8 +++++++ lib/of_live.c | 19 +++++++++++++++ test/dm/ofnode.c | 16 +++++++++++++ 5 files changed, 104 insertions(+), 4 deletions(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 8227eac1e4fe..7100fc630352 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -47,6 +47,17 @@ static int oftree_find(const void *fdt) return -1; }
+static int check_tree_count(void) +{ + if (oftree_count == CONFIG_OFNODE_MULTI_TREE_MAX) { + log_warning("Too many registered device trees (max %d)\n", + CONFIG_OFNODE_MULTI_TREE_MAX); + return -E2BIG; + } + + return 0; +} + static oftree oftree_ensure(void *fdt) { oftree tree; @@ -69,11 +80,8 @@ static oftree oftree_ensure(void *fdt) if (gd->flags & GD_FLG_RELOC) { i = oftree_find(fdt); if (i == -1) { - if (oftree_count == CONFIG_OFNODE_MULTI_TREE_MAX) { - log_warning("Too many registered device trees (max %d)\n", - CONFIG_OFNODE_MULTI_TREE_MAX); + if (check_tree_count()) return oftree_null(); - }
/* register the new tree */ i = oftree_count++; @@ -92,6 +100,41 @@ static oftree oftree_ensure(void *fdt) return tree; }
+int oftree_new(oftree *treep) +{ + oftree tree = oftree_null(); + int ret; + + if (of_live_active()) { + struct device_node *root; + + ret = of_live_create_empty(&root); + if (ret) + return log_msg_ret("liv", ret); + tree = oftree_from_np(root); + } else { + const int size = 1024; + void *fdt; + + ret = check_tree_count(); + if (ret) + return log_msg_ret("fla", ret); + + /* register the new tree with a small size */ + fdt = malloc(size); + if (!fdt) + return log_msg_ret("fla", -ENOMEM); + ret = fdt_create_empty_tree(fdt, size); + if (ret) + return log_msg_ret("fla", -EINVAL); + oftree_list[oftree_count++] = fdt; + tree.fdt = fdt; + } + *treep = tree; + + return 0; +} + void oftree_dispose(oftree tree) { if (of_live_active()) @@ -193,6 +236,11 @@ static inline int oftree_find(const void *fdt) return 0; }
+int oftree_new(oftree *treep) +{ + return -ENOSYS; +} + #endif /* OFNODE_MULTI_TREE */
/** diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index abdfa58036d5..fa6a83188995 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -126,6 +126,15 @@ static inline ofnode noffset_to_ofnode(ofnode other_node, int of_offset)
+/** + * oftree_new() - Create a new, empty tree + * + * @treep: Returns a pointer to the tree, on success + * Returns: 0 on success, -ENOMEM if out of memory, -E2BIG if !OF_LIVE and + * there are too many (flattrees) already + */ +int oftree_new(oftree *treep); + /** * ofnode_to_np() - convert an ofnode to a live DT node pointer * diff --git a/include/of_live.h b/include/of_live.h index 05e86ac06b1a..81cb9bd13e2c 100644 --- a/include/of_live.h +++ b/include/of_live.h @@ -46,4 +46,12 @@ int unflatten_device_tree(const void *blob, struct device_node **mynodes); */ void of_live_free(struct device_node *root);
+/** + * of_live_create_empty() - Create a new, empty tree + * + * @rootp: Returns the root node of the created tree + * Return: 0 if OK, -ENOMEM if out of memory + */ +int of_live_create_empty(struct device_node **rootp); + #endif diff --git a/lib/of_live.c b/lib/of_live.c index 25f7af61061e..e4eee3855476 100644 --- a/lib/of_live.c +++ b/lib/of_live.c @@ -336,3 +336,22 @@ void of_live_free(struct device_node *root) /* the tree is stored as a contiguous block of memory */ free(root); } + +int of_live_create_empty(struct device_node **rootp) +{ + struct device_node *root; + + root = calloc(1, sizeof(struct device_node)); + if (!root) + return -ENOMEM; + root->name = strdup(""); + if (!root->name) { + free(root); + return -ENOMEM; + } + root->type = "<NULL>"; + root->full_name = ""; + *rootp = root; + + return 0; +} diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index 84ed7f92b235..63b651df84eb 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -1327,3 +1327,19 @@ static int dm_test_livetree_ensure(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_livetree_ensure, UT_TESTF_SCAN_FDT); + +static int dm_test_oftree_new(struct unit_test_state *uts) +{ + ofnode node, subnode, check; + oftree tree; + + ut_assertok(oftree_new(&tree)); + node = oftree_root(tree); + ut_assert(ofnode_valid(node)); + ut_assertok(ofnode_add_subnode(node, "edmund", &subnode)); + check = ofnode_find_subnode(node, "edmund"); + ut_asserteq(check.of_offset, subnode.of_offset); + + return 0; +} +DM_TEST(dm_test_oftree_new, UT_TESTF_SCAN_FDT);
Add a function to copy a node to another place under a new name. This is useful at least for testing, since copying a test node with existing properties is easier than writing the code to generate it all afresh.
drivers/core/ofnode.c | 20 ++++++++++++++ include/dm/ofnode.h | 15 +++++++++++ test/dm/ofnode.c | 63 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 98 insertions(+)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 7100fc630352..ba8385af7b46 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1743,3 +1743,23 @@ int ofnode_copy_props(ofnode dst, ofnode src)
return 0; } + +int ofnode_copy_node(ofnode dst_parent, const char *name, ofnode src, + ofnode *nodep) +{ + ofnode node; + int ret; + + ret = ofnode_add_subnode(dst_parent, name, &node); + if (ret) { + if (ret == -EEXIST) + *nodep = node; + return log_msg_ret("add", ret); + } + ret = ofnode_copy_props(node, src); + if (ret) + return log_msg_ret("cpy", ret); + *nodep = node; + + return 0; +} diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index fa6a83188995..80708a3644c4 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1567,4 +1567,19 @@ int ofnode_add_subnode(ofnode parent, const char *name, ofnode *nodep); */ int ofnode_copy_props(ofnode dst, ofnode src);
+/** + * ofnode_copy_node() - Copy a node to another place + * + * If a node with this name already exists in dst_parent, this returns an + * .error + * + * @dst_parent: Parent of the newly copied node + * @name: Name to give the new node + * @src: Source node to copy + * @nodep: Returns the new node, or the existing node if there is one + * Return: 0 if OK, -EEXIST if dst_parent already has a node with this parent + */ +int ofnode_copy_node(ofnode dst_parent, const char *name, ofnode src, + ofnode *nodep); + #endif diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index 63b651df84eb..fe7916c27222 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -1343,3 +1343,66 @@ static int dm_test_oftree_new(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_oftree_new, UT_TESTF_SCAN_FDT); + +static int check_copy_node(struct unit_test_state *uts, ofnode dst, ofnode src, + ofnode *nodep) +{ + u32 reg[2], val; + ofnode node; + + ut_assertok(ofnode_copy_node(dst, "copy-test", src, &node)); + + ut_assertok(ofnode_read_u32(node, "ping-expect", &val)); + ut_asserteq(3, val); + + ut_asserteq_str("denx,u-boot-fdt-test", + ofnode_read_string(node, "compatible")); + + /* check that a property with the same name is overwritten */ + ut_assertok(ofnode_read_u32_array(node, "reg", reg, ARRAY_SIZE(reg))); + ut_asserteq(3, reg[0]); + ut_asserteq(1, reg[1]); + + /* reset the compatible so the live tree does not change */ + ut_assertok(ofnode_write_string(node, "compatible", "nothing")); + *nodep = node; + + return 0; +} + +static int dm_test_ofnode_copy_node(struct unit_test_state *uts) +{ + ofnode src, dst, node, try; + + /* + * These nodes are chosen so that the src node is before the destination + * node in the tree. This doesn't matter with livetree, but with + * flattree any attempt to insert a property earlier in the tree will + * mess up the offsets after it. + */ + src = ofnode_path("/b-test"); + dst = ofnode_path("/some-bus"); + + ut_assertok(check_copy_node(uts, dst, src, &node)); + + /* check trying to copy over an existing node */ + ut_asserteq(-EEXIST, ofnode_copy_node(dst, "copy-test", src, &try)); + ut_asserteq(try.of_offset, node.of_offset); + + return 0; +} +DM_TEST(dm_test_ofnode_copy_node, UT_TESTF_SCAN_FDT); + +/* test ofnode_copy_node() with the 'other' tree */ +static int dm_test_ofnode_copy_node_ot(struct unit_test_state *uts) +{ + oftree otree = get_other_oftree(uts); + ofnode src, dst, node; + + src = ofnode_path("/b-test"); + dst = oftree_path(otree, "/node/subnode2"); + ut_assertok(check_copy_node(uts, dst, src, &node)); + + return 0; +} +DM_TEST(dm_test_ofnode_copy_node_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT);
Add a function to delete a node in an existing tree.
drivers/core/of_access.c | 65 ++++++++++++++++++++++++++++++++++++++++ drivers/core/ofnode.c | 23 ++++++++++++++ include/dm/of_access.h | 18 +++++++++++ include/dm/ofnode.h | 13 ++++++++ test/dm/ofnode.c | 31 +++++++++++++++++++ 5 files changed, 150 insertions(+)
diff --git a/drivers/core/of_access.c b/drivers/core/of_access.c index 1bb4d8eab709..0df5c867c8b3 100644 --- a/drivers/core/of_access.c +++ b/drivers/core/of_access.c @@ -1040,3 +1040,68 @@ int of_add_subnode(struct device_node *parent, const char *name, int len,
return 0; } + +int __of_remove_property(struct device_node *np, struct property *prop) +{ + struct property **next; + + for (next = &np->properties; *next; next = &(*next)->next) { + if (*next == prop) + break; + } + if (*next == NULL) + return -ENODEV; + + /* found the node */ + *next = prop->next; + + return 0; +} + +int of_remove_property(struct device_node *np, struct property *prop) +{ + int rc; + + mutex_lock(&of_mutex); + + rc = __of_remove_property(np, prop); + + mutex_unlock(&of_mutex); + + return rc; +} + +int of_remove_node(struct device_node *to_remove) +{ + struct device_node *parent = to_remove->parent; + struct device_node *np, *prev; + + if (!parent) + return -EPERM; + prev = NULL; + __for_each_child_of_node(parent, np) { + if (np == to_remove) + break; + prev = np; + } + if (!np) + return -EFAULT; + + /* if there is a previous node, link it to this one's sibling */ + if (prev) + prev->sibling = np->sibling; + else + parent->child = np->sibling; + + /* + * don't free it, since if this is an unflattened tree, all the memory + * was alloced in one block; this pointer will be somewhere in the + * middle of that + * + * TODO(sjg@chromium.org): Consider marking nodes as 'allocated'? + * + * free(np); + */ + + return 0; +} diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index ba8385af7b46..fe143f990915 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1720,6 +1720,29 @@ int ofnode_add_subnode(ofnode node, const char *name, ofnode *subnodep) return ret; /* 0 or -EEXIST */ }
+int ofnode_delete(ofnode *nodep) +{ + ofnode node = *nodep; + int ret; + + assert(ofnode_valid(node)); + if (ofnode_is_np(node)) { + ret = of_remove_node(ofnode_to_np(node)); + } else { + void *fdt = ofnode_to_fdt(node); + int offset = ofnode_to_offset(node); + + ret = fdt_del_node(fdt, offset); + if (ret) + ret = -EFAULT; + } + if (ret) + return ret; + *nodep = ofnode_null(); + + return 0; +} + int ofnode_copy_props(ofnode dst, ofnode src) { struct ofprop prop; diff --git a/include/dm/of_access.h b/include/dm/of_access.h index 9361d0a87bfb..de740d44674c 100644 --- a/include/dm/of_access.h +++ b/include/dm/of_access.h @@ -597,4 +597,22 @@ int of_write_prop(struct device_node *np, const char *propname, int len, int of_add_subnode(struct device_node *node, const char *name, int len, struct device_node **subnodep);
+/** + * of_remove_property() - Remove a property from a node + * + * @np: Node to remove from + * @prop: Pointer to property to remove + * Return 0 if OK, -ENODEV if the property could not be found in the node + */ +int of_remove_property(struct device_node *np, struct property *prop); + +/** + * of_remove_node() - Remove a node from the tree + * + * @to_remove: Node to remove + * Return: 0 if OK, -EPERM if it is the root node (wWhich cannot be removed), + * -ENOENT if the tree is broken (to_remove is not a child of its parent) + */ +int of_remove_node(struct device_node *to_remove); + #endif diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 80708a3644c4..8be617b21043 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1582,4 +1582,17 @@ int ofnode_copy_props(ofnode dst, ofnode src); int ofnode_copy_node(ofnode dst_parent, const char *name, ofnode src, ofnode *nodep);
+/** + * ofnode_delete() - Delete a node + * + * Delete a node from the tree + * + * @nodep: Pointer to node to delete (set to ofnode_null() on success) + * Return: 0 if OK, -ENOENT if the node does not exist, -EPERM if it is the root + * node (wWhich cannot be removed), -EFAULT if the tree is broken (to_remove is + * not a child of its parent), + * + */ +int ofnode_delete(ofnode *nodep); + #endif diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index fe7916c27222..cb7fc907c824 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -1406,3 +1406,34 @@ static int dm_test_ofnode_copy_node_ot(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_ofnode_copy_node_ot, UT_TESTF_SCAN_FDT | UT_TESTF_OTHER_FDT); + +static int dm_test_ofnode_delete(struct unit_test_state *uts) +{ + ofnode node; + + /* + * At present the livetree is not restored after changes made in tests. + * See test_pre_run() for how this is done with the other FDT and + * dm_test_pre_run() where it sets up the root-tree pointer. So use + * nodes which don't matter to other tests. + * + * We could fix this by detecting livetree changes and regenerating it + * before the next test if needed. + */ + node = ofnode_path("/leds/iracibble"); + ut_assert(ofnode_valid(node)); + ut_assertok(ofnode_delete(&node)); + ut_assert(!ofnode_valid(node)); + ut_assert(!ofnode_valid(ofnode_path("/leds/iracibble"))); + + node = ofnode_path("/leds/default_on"); + ut_assert(ofnode_valid(node)); + ut_assertok(ofnode_delete(&node)); + ut_assert(!ofnode_valid(node)); + ut_assert(!ofnode_valid(ofnode_path("/leds/default_on"))); + + ut_asserteq(2, ofnode_get_child_count(ofnode_path("/leds"))); + + return 0; +} +DM_TEST(dm_test_ofnode_delete, UT_TESTF_SCAN_FDT);
Add a way to flatten a devicetree into binary form. For livetree this involves generating the devicetree using fdt_property() and other calls. For flattree it simply involves providing the buffer containing the tree.
drivers/core/ofnode.c | 18 +++++++ include/dm/ofnode.h | 13 +++++ include/of_live.h | 10 ++++ lib/of_live.c | 122 ++++++++++++++++++++++++++++++++++++++++++ test/dm/ofnode.c | 24 +++++++++ 5 files changed, 187 insertions(+)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index fe143f990915..4dc7589c1d23 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -243,6 +243,24 @@ int oftree_new(oftree *treep)
+int oftree_to_fdt(oftree tree, struct abuf *buf) +{ + int ret; + + if (of_live_active()) { + ret = of_live_flatten(ofnode_to_np(oftree_root(tree)), buf); + if (ret) + return log_msg_ret("flt", ret); + } else { + void *fdt = oftree_lookup_fdt(tree); + + abuf_init(buf); + abuf_set(buf, fdt, fdt_totalsize(fdt)); + } + + return 0; +} + /** * ofnode_from_tree_offset() - get an ofnode from a tree offset (flat tree) * diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 8be617b21043..f3ef1bff6db6 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -17,6 +17,7 @@ /* Enable checks to protect against invalid calls */ #undef OF_CHECKS
+struct abuf; struct resource;
#include <dm/ofnode_decl.h> @@ -135,6 +136,18 @@ static inline ofnode noffset_to_ofnode(ofnode other_node, int of_offset) */ int oftree_new(oftree *treep);
+/** + * oftree_to_fdt() - Convert an oftree to a flat FDT + * + * @tree: tree to flatten (if livetree) or copy (if not) + * @buf: Returns inited buffer containing the newly created flat tree. Note + * that for flat tree the buffer is not allocated. In either case the caller + * must call abut_uninit() to free any memory used by @buf + * Return: 0 on success, -ENOMEM if out of memory, other -ve value for any other + * error + */ +int oftree_to_fdt(oftree tree, struct abuf *buf); + /** * ofnode_to_np() - convert an ofnode to a live DT node pointer * diff --git a/include/of_live.h b/include/of_live.h index 81cb9bd13e2c..67bd5f02c744 100644 --- a/include/of_live.h +++ b/include/of_live.h @@ -9,6 +9,7 @@ #ifndef _OF_LIVE_H #define _OF_LIVE_H
+struct abuf; struct device_node;
/** @@ -54,4 +55,13 @@ void of_live_free(struct device_node *root); */ int of_live_create_empty(struct device_node **rootp);
+/** + * of_live_flatten() - Create an FDT from a hierarchical tree + * + * @root: Root node of tree to convert + * @buf: Buffer to return the tree (inited by this function) + * Return: 0 if OK, -ENOMEM if out of memory + */ +int of_live_flatten(const struct device_node *root, struct abuf *buf); + #endif diff --git a/lib/of_live.c b/lib/of_live.c index e4eee3855476..812c488f6067 100644 --- a/lib/of_live.c +++ b/lib/of_live.c @@ -8,13 +8,21 @@ * Copyright (c) 2017 Google, Inc */
+#define LOG_CATEGORY LOGC_DT + #include <common.h> +#include <abuf.h> #include <log.h> #include <linux/libfdt.h> #include <of_live.h> #include <malloc.h> #include <dm/of_access.h> #include <linux/err.h> +#include <linux/sizes.h> + +enum { + BUF_STEP = SZ_64K, +};
static void *unflatten_dt_alloc(void **mem, unsigned long size, unsigned long align) @@ -355,3 +363,117 @@ int of_live_create_empty(struct device_node **rootp)
return 0; } + +static int check_space(int ret, struct abuf *buf) +{ + if (ret == -FDT_ERR_NOSPACE) { + if (!abuf_realloc_inc(buf, BUF_STEP)) + return log_msg_ret("spc", -ENOMEM); + ret = fdt_resize(abuf_data(buf), abuf_data(buf), + abuf_size(buf)); + if (ret) + return log_msg_ret("res", -EFAULT); + + return -EAGAIN; + } + + return 0; +} + +/** + * flatten_node() - Write out the node and its properties into a flat tree + */ +static int flatten_node(struct abuf *buf, const struct device_node *node) +{ + const struct device_node *np; + const struct property *pp; + int ret; + + ret = fdt_begin_node(abuf_data(buf), node->name); + ret = check_space(ret, buf); + if (ret == -EAGAIN) { + ret = fdt_begin_node(abuf_data(buf), node->name); + if (ret) { + log_debug("Internal error a %d\n", ret); + return -EFAULT; + } + } + if (ret) + return log_msg_ret("beg", ret); + + /* First write out the properties */ + for (pp = node->properties; !ret && pp; pp = pp->next) { + ret = fdt_property(abuf_data(buf), pp->name, pp->value, + pp->length); + ret = check_space(ret, buf); + if (ret == -EAGAIN) { + ret = fdt_property(abuf_data(buf), pp->name, pp->value, + pp->length); + } + } + + /* Next write out the subnodes */ + for (np = node->child; np; np = np->sibling) { + ret = flatten_node(buf, np); + if (ret) + return log_msg_ret("sub", ret); + } + + ret = fdt_end_node(abuf_data(buf)); + ret = check_space(ret, buf); + if (ret == -EAGAIN) { + ret = fdt_end_node(abuf_data(buf)); + if (ret) { + log_debug("Internal error b %d\n", ret); + return -EFAULT; + } + } + if (ret) + return log_msg_ret("end", ret); + + return 0; +} + +int of_live_flatten(const struct device_node *root, struct abuf *buf) +{ + int ret; + + abuf_init(buf); + if (!abuf_realloc(buf, BUF_STEP)) + return log_msg_ret("ini", -ENOMEM); + + ret = fdt_create(abuf_data(buf), abuf_size(buf)); + if (!ret) + ret = fdt_finish_reservemap(abuf_data(buf)); + if (ret) { + log_debug("Failed to start FDT (err=%d)\n", ret); + return log_msg_ret("sta", -EINVAL); + } + + ret = flatten_node(buf, root); + if (ret) + return log_msg_ret("flt", ret); + + ret = fdt_finish(abuf_data(buf)); + ret = check_space(ret, buf); + if (ret == -EAGAIN) { + ret = fdt_finish(abuf_data(buf)); + if (ret) { + log_debug("Internal error c %d\n", ret); + return -EFAULT; + } + } + if (ret) + return log_msg_ret("fin", ret); + + ret = fdt_pack(abuf_data(buf)); + if (ret) { + log_debug("Failed to pack (err=%d)\n", ret); + return log_msg_ret("pac", -EFAULT); + } + + if (!abuf_realloc(buf, fdt_totalsize(abuf_data(buf)))) + return log_msg_ret("abu", -EFAULT); + + return 0; +} diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index cb7fc907c824..d2b393750ffc 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -17,6 +17,7 @@ */
#include <common.h> +#include <abuf.h> #include <dm.h> #include <log.h> #include <of_live.h> @@ -26,6 +27,7 @@ #include <dm/root.h> #include <dm/test.h> #include <dm/uclass-internal.h> +#include <linux/sizes.h> #include <test/test.h> #include <test/ut.h>
@@ -1437,3 +1439,25 @@ static int dm_test_ofnode_delete(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_ofnode_delete, UT_TESTF_SCAN_FDT); + +static int dm_test_oftree_to_fdt(struct unit_test_state *uts) +{ + oftree tree, check; + struct abuf buf, buf2; + + tree = oftree_default(); + ut_assertok(oftree_to_fdt(tree, &buf)); + ut_assert(abuf_size(&buf) > SZ_16K); + + /* convert it back to a tree and see if it looks OK */ + check = oftree_from_fdt(abuf_data(&buf)); + ut_assert(oftree_valid(check)); + + ut_assertok(oftree_to_fdt(check, &buf2)); + ut_assert(abuf_size(&buf2) > SZ_16K); + ut_asserteq(abuf_size(&buf), abuf_size(&buf2)); + ut_asserteq_mem(abuf_data(&buf), abuf_data(&buf2), abuf_size(&buf)); + + return 0; +} +DM_TEST(dm_test_oftree_to_fdt, UT_TESTF_SCAN_FDT);
Add functions to write a boolean property. This involves deleting it if the value is false.
Add a new ofnode_has_property() as well. Add a comment about the behaviour of of_read_property() when the property value is empty.
(no changes since v1)
drivers/core/ofnode.c | 36 ++++++++++++++++++++++++++++++++++-- include/dm/ofnode.h | 32 +++++++++++++++++++++++++++++++- test/dm/ofnode.c | 25 +++++++++++++++++++++++++ 3 files changed, 90 insertions(+), 3 deletions(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 4dc7589c1d23..0229695dba1f 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -491,12 +491,12 @@ u64 ofnode_read_u64_default(ofnode node, const char *propname, u64 def)
bool ofnode_read_bool(ofnode node, const char *propname) { - const void *prop; + bool prop;
assert(ofnode_valid(node)); debug("%s: %s: ", __func__, propname);
- prop = ofnode_get_property(node, propname, NULL); + prop = ofnode_has_property(node, propname);
debug("%s\n", prop ? "true" : "false");
@@ -1168,6 +1168,14 @@ const void *ofnode_get_property(ofnode node, const char *propname, int *lenp) propname, lenp); }
+bool ofnode_has_property(ofnode node, const char *propname) +{ + if (ofnode_is_np(node)) + return of_find_property(ofnode_to_np(node), propname, NULL); + else + return ofnode_get_property(node, propname, NULL); +} + int ofnode_first_property(ofnode node, struct ofprop *prop) { prop->node = node; @@ -1616,6 +1624,30 @@ int ofnode_write_u32(ofnode node, const char *propname, u32 value) return ofnode_write_prop(node, propname, val, sizeof(value), false); }
+int ofnode_write_bool(ofnode node, const char *propname, bool value) +{ + if (value) + return ofnode_write_prop(node, propname, NULL, 0, false); + else + return ofnode_delete_prop(node, propname); +} + +int ofnode_delete_prop(ofnode node, const char *propname) +{ + if (ofnode_is_np(node)) { + struct property *prop; + int len; + + prop = of_find_property(ofnode_to_np(node), propname, &len); + if (prop) + return of_remove_property(ofnode_to_np(node), prop); + return 0; + } else { + return fdt_delprop(ofnode_to_fdt(node), ofnode_to_offset(node), + propname); + } +} + int ofnode_set_enabled(ofnode node, bool value) { assert(ofnode_valid(node)); diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index f3ef1bff6db6..58c6849534ea 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1036,10 +1036,19 @@ int ofnode_decode_panel_timing(ofnode node, * @node: node to read * @propname: property to read * @lenp: place to put length on success - * Return: pointer to property, or NULL if not found + * Return: pointer to property value, or NULL if not found or empty */ const void *ofnode_get_property(ofnode node, const char *propname, int *lenp);
+/** + * ofnode_has_property() - check if a node has a named property + * + * @node: node to read + * @propname: property to read + * Return: true if the property exists in the node, false if not + */ +bool ofnode_has_property(ofnode node, const char *propname); + /** * ofnode_first_property()- get the reference of the first property * @@ -1451,6 +1460,27 @@ int ofnode_write_string(ofnode node, const char *propname, const char *value); */ int ofnode_write_u32(ofnode node, const char *propname, u32 value);
+/** + * ofnode_write_bool() - Set a boolean property of an ofnode + * + * This either adds or deleted a property with a zero-length value + * + * @node: The node for whose string property should be set + * @propname: The name of the string property to set + * @value: The new value of the boolean property + * Return: 0 if successful, -ve on error + */ +int ofnode_write_bool(ofnode node, const char *propname, bool value); + +/** + * ofnode_delete_prop() - Delete a property + * + * @node: Node containing the property to delete + * @propname: Name of property to delete + * Return: 0 if successful, -ve on error + */ +int ofnode_delete_prop(ofnode node, const char *propname); + /** * ofnode_set_enabled() - Enable or disable a device tree node given by its * ofnode diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index d2b393750ffc..af844a50308e 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -1461,3 +1461,28 @@ static int dm_test_oftree_to_fdt(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_oftree_to_fdt, UT_TESTF_SCAN_FDT); + +/* test ofnode_read_bool() and ofnode_write_bool() */ +static int dm_test_bool(struct unit_test_state *uts) +{ + const char *propname = "missing-bool-value"; + ofnode node; + + node = ofnode_path("/a-test"); + ut_assert(ofnode_read_bool(node, "bool-value")); + ut_assert(!ofnode_read_bool(node, propname)); + ut_assert(!ofnode_has_property(node, propname)); + + ut_assertok(ofnode_write_bool(node, propname, true)); + ut_assert(ofnode_read_bool(node, propname)); + ut_assert(ofnode_has_property(node, propname)); + ut_assert(ofnode_read_bool(node, "bool-value")); + + ut_assertok(ofnode_write_bool(node, propname, false)); + ut_assert(!ofnode_read_bool(node, propname)); + ut_assert(!ofnode_has_property(node, propname)); + ut_assert(ofnode_read_bool(node, "bool-value")); + + return 0; +} +DM_TEST(dm_test_bool, UT_TESTF_SCAN_FDT);
Add support for writing a single 64-bit value into a property.
Repurpose the existing tests to handle this case too.
drivers/core/ofnode.c | 17 ++++++++++++++++- include/dm/ofnode.h | 10 ++++++++++ test/dm/ofnode.c | 15 +++++++++++++-- 3 files changed, 39 insertions(+), 3 deletions(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 0229695dba1f..2ef4114cb6f8 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1621,7 +1621,22 @@ int ofnode_write_u32(ofnode node, const char *propname, u32 value) return -ENOMEM; *val = cpu_to_fdt32(value);
- return ofnode_write_prop(node, propname, val, sizeof(value), false); + return ofnode_write_prop(node, propname, val, sizeof(value), true); +} + +int ofnode_write_u64(ofnode node, const char *propname, u64 value) +{ + fdt64_t *val; + + assert(ofnode_valid(node)); + + log_debug("%s = %llx", propname, (unsigned long long)value); + val = malloc(sizeof(*val)); + if (!val) + return -ENOMEM; + *val = cpu_to_fdt64(value); + + return ofnode_write_prop(node, propname, val, sizeof(value), true); }
int ofnode_write_bool(ofnode node, const char *propname, bool value) diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 58c6849534ea..726d8f82ddf2 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1460,6 +1460,16 @@ int ofnode_write_string(ofnode node, const char *propname, const char *value); */ int ofnode_write_u32(ofnode node, const char *propname, u32 value);
+/** + * ofnode_write_u64() - Set an integer property of an ofnode + * + * @node: The node for whose string property should be set + * @propname: The name of the string property to set + * @value: The new value of the 64-bit integer property + * Return: 0 if successful, -ve on error + */ +int ofnode_write_u64(ofnode node, const char *propname, u64 value); + /** * ofnode_write_bool() - Set a boolean property of an ofnode * diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index af844a50308e..5e63efdfa891 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -990,7 +990,8 @@ static int dm_test_ofnode_u32_array(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_u32_array, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
-static int dm_test_ofnode_read_u64(struct unit_test_state *uts) +/* test ofnode_read_u64() and ofnode_write_u64() */ +static int dm_test_ofnode_u64(struct unit_test_state *uts) { ofnode node; u64 val; @@ -999,6 +1000,10 @@ static int dm_test_ofnode_read_u64(struct unit_test_state *uts) ut_assert(ofnode_valid(node)); ut_assertok(ofnode_read_u64(node, "int64-value", &val)); ut_asserteq_64(0x1111222233334444, val); + ut_assertok(ofnode_write_u64(node, "new-int64-value", 0x9876543210)); + ut_assertok(ofnode_read_u64(node, "new-int64-value", &val)); + ut_asserteq_64(0x9876543210, val); + ut_asserteq(-EINVAL, ofnode_read_u64(node, "missing", &val));
ut_assertok(ofnode_read_u64_index(node, "int64-array", 0, &val)); @@ -1009,9 +1014,15 @@ static int dm_test_ofnode_read_u64(struct unit_test_state *uts) ofnode_read_u64_index(node, "int64-array", 2, &val)); ut_asserteq(-EINVAL, ofnode_read_u64_index(node, "missing", 0, &val));
+ ut_assertok(ofnode_write_u64(node, "int64-array", 0x9876543210)); + ut_assertok(ofnode_read_u64_index(node, "int64-array", 0, &val)); + ut_asserteq_64(0x9876543210, val); + ut_asserteq(-EOVERFLOW, + ofnode_read_u64_index(node, "int64-array", 1, &val)); + return 0; } -DM_TEST(dm_test_ofnode_read_u64, UT_TESTF_SCAN_FDT); +DM_TEST(dm_test_ofnode_u64, UT_TESTF_SCAN_FDT);
Add a few simple tests for getting the root node, since this is handled as a special case in the implementation.
test/dm/ofnode.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index 5e63efdfa891..af3aa1e2ec51 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -228,6 +228,9 @@ static int dm_test_ofnode_read(struct unit_test_state *uts) ofnode node; int size;
+ node = oftree_path(oftree_default(), "/"); + ut_assert(ofnode_valid(node)); + node = ofnode_path("/a-test"); ut_assert(ofnode_valid(node));
@@ -256,6 +259,9 @@ static int dm_test_ofnode_read_ot(struct unit_test_state *uts) ofnode node; int size;
+ node = oftree_path(otree, "/"); + ut_assert(ofnode_valid(node)); + node = oftree_path(otree, "/node/subnode"); ut_assert(ofnode_valid(node));
This should not happen in the argument-parsing function. Move it to the main program.
Add some debugging for reading/writing.
arch/sandbox/cpu/start.c | 19 +++++++++++-------- arch/sandbox/cpu/state.c | 1 + 2 files changed, 12 insertions(+), 8 deletions(-)
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 1026898727f5..5dc4db8bf605 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -272,17 +272,9 @@ SANDBOX_CMDLINE_OPT_SHORT(program, 'p', 1, "U-Boot program name"); static int sandbox_cmdline_cb_memory(struct sandbox_state *state, const char *arg) { - int err; - /* For now assume we always want to write it */ state->write_ram_buf = true; state->ram_buf_fname = arg; - - err = os_read_ram_buf(arg); - if (err) { - printf("Failed to read RAM buffer '%s': %d\n", arg, err); - return err; - } state->ram_buf_read = true;
return 0; @@ -512,6 +504,17 @@ int sandbox_main(int argc, char *argv[]) if (os_parse_args(state, argc, argv)) return 1;
+ if (state->ram_buf_fname) { + ret = os_read_ram_buf(state->ram_buf_fname); + if (ret) { + printf("Failed to read RAM buffer '%s': %d\n", + state->ram_buf_fname, ret); + } else { + state->ram_buf_read = true; + log_debug("Read RAM buffer from '%s'\n", state->ram_buf_fname); + } + } + /* Remove old memory file if required */ if (state->ram_buf_rm && state->ram_buf_fname) { os_unlink(state->ram_buf_fname); diff --git a/arch/sandbox/cpu/state.c b/arch/sandbox/cpu/state.c index d67834988fd4..fcc0028ff4a2 100644 --- a/arch/sandbox/cpu/state.c +++ b/arch/sandbox/cpu/state.c @@ -513,6 +513,7 @@ int state_uninit(void) printf("Failed to write RAM buffer\n"); return err; } + log_debug("Wrote RAM to file '%s'\n", state->ram_buf_fname); }
if (state->write_state) {
This currently relies on sandbox attempting to read a state file. At present it always does, even when there is no state file, in which case it fails, but still inits the EC.
That is a bug, so update this driver to set the current image always, even if no state is read.
drivers/misc/cros_ec_sandbox.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/cros_ec_sandbox.c b/drivers/misc/cros_ec_sandbox.c index 8dbe0b188a48..1201535f4af4 100644 --- a/drivers/misc/cros_ec_sandbox.c +++ b/drivers/misc/cros_ec_sandbox.c @@ -81,6 +81,7 @@ struct ec_pwm_channel { /** * struct ec_state - Information about the EC state * + * @valid: true if this struct contains valid state data * @vbnv_context: Vboot context data stored by EC * @ec_config: FDT config information about the EC (e.g. flashmap) * @flash_data: Contents of flash memory @@ -95,6 +96,7 @@ struct ec_pwm_channel { * @pwm: Information per PWM channel */ struct ec_state { + bool valid; u8 vbnv_context[EC_VBNV_BLOCK_SIZE_V2]; struct fdt_cros_ec ec_config; uint8_t *flash_data; @@ -145,6 +147,7 @@ static int cros_ec_read_state(const void *blob, int node) memcpy(ec->flash_data, prop, len); debug("%s: Loaded EC flash data size %#x\n", __func__, len); } + ec->valid = true;
return 0; } @@ -589,6 +592,7 @@ static int process_cmd(struct ec_state *ec, printf(" ** Unknown EC command %#02x\n", req_hdr->command); return -1; } + debug(" - EC command %#0x, result %d\n", req_hdr->command, len);
return len; } @@ -675,7 +679,10 @@ int cros_ec_probe(struct udevice *dev) ofnode node; int err;
- memcpy(ec, &s_state, sizeof(*ec)); + if (s_state.valid) + memcpy(ec, &s_state, sizeof(*ec)); + else + ec->current_image = EC_IMAGE_RO; err = cros_ec_decode_ec_flash(dev, &ec->ec_config); if (err) { debug("%s: Cannot device EC flash\n", __func__);
We should not read this unless requested. Make it conditional on the option being provided.
Add some debugging to show the state being written.
arch/sandbox/cpu/start.c | 8 +++++--- arch/sandbox/cpu/state.c | 1 + 2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 5dc4db8bf605..efbc60e66805 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -522,9 +522,11 @@ int sandbox_main(int argc, char *argv[]) state->ram_buf_fname = NULL; }
- ret = sandbox_read_state(state, state->state_fname); - if (ret) - goto err; + if (state->read_state && state->state_fname) { + ret = sandbox_read_state(state, state->state_fname); + if (ret) + goto err; + }
if (state->handle_signals) { ret = os_setup_signal_handlers(); diff --git a/arch/sandbox/cpu/state.c b/arch/sandbox/cpu/state.c index fcc0028ff4a2..e38bb248b7ff 100644 --- a/arch/sandbox/cpu/state.c +++ b/arch/sandbox/cpu/state.c @@ -521,6 +521,7 @@ int state_uninit(void) printf("Failed to write sandbox state\n"); return -1; } + log_debug("Wrote state to file '%s'\n", state->ram_buf_fname); }
/* Delete this at the last moment so as not to upset gdb too much */
Move this down by 4KB so that it is large enough to hold the devicetree.
Also fix up the devicetree address in the documetation while we are here.
common/Kconfig | 2 +- doc/arch/sandbox/sandbox.rst | 4 ++-- test/lib/kconfig.c | 4 ++-- 3 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 21eaa5e815f9..5e79b5422178 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -1012,7 +1012,7 @@ endchoice
config BLOBLIST_ADDR hex "Address of bloblist" - default 0xc000 if SANDBOX + default 0xb000 if SANDBOX depends on BLOBLIST_FIXED help Sets the address of the bloblist, set up by the first part of U-Boot diff --git a/doc/arch/sandbox/sandbox.rst b/doc/arch/sandbox/sandbox.rst index a3631de74932..23902dee89e7 100644 --- a/doc/arch/sandbox/sandbox.rst +++ b/doc/arch/sandbox/sandbox.rst @@ -614,8 +614,8 @@ that are mapped into that memory: ======= ======================== =============================== Addr Config Usage ======= ======================== =============================== - 0 CONFIG_SYS_FDT_LOAD_ADDR Device tree - c000 CONFIG_BLOBLIST_ADDR Blob list + 100 CONFIG_SYS_FDT_LOAD_ADDR Device tree + b000 CONFIG_BLOBLIST_ADDR Blob list 10000 CFG_MALLOC_F_ADDR Early memory allocation f0000 CONFIG_PRE_CON_BUF_ADDR Pre-console buffer 100000 CONFIG_TRACE_EARLY_ADDR Early trace buffer (if enabled). Also used diff --git a/test/lib/kconfig.c b/test/lib/kconfig.c index 76225ba8ffa9..3914f699659f 100644 --- a/test/lib/kconfig.c +++ b/test/lib/kconfig.c @@ -22,9 +22,9 @@ static int lib_test_is_enabled(struct unit_test_state *uts) ut_asserteq(0, CONFIG_IS_ENABLED(OF_PLATDATA)); ut_asserteq(0, CONFIG_IS_ENABLED(_UNDEFINED));
- ut_asserteq(0xc000, + ut_asserteq(0xb000, IF_ENABLED_INT(CONFIG_BLOBLIST_FIXED, CONFIG_BLOBLIST_ADDR)); - ut_asserteq(0xc000, + ut_asserteq(0xb000, CONFIG_IF_ENABLED_INT(BLOBLIST_FIXED, BLOBLIST_ADDR));
Typically the bloblist is set up after the devicetree is present. This makes sense because bloblist may use malloc() to allocate the space it needs.
However sometimes the devicetree itself may be present in the bloblist. In that case it is at a known location in memory so we can init the bloblist very early, before devicetree.
Add a flag to indicate whether the bloblist has been inited. Add a function to init it only if needed. Use that in the init sequence.
common/bloblist.c | 13 ++++++++++++- common/board_f.c | 4 +--- include/asm-generic/global_data.h | 4 ++++ include/bloblist.h | 18 ++++++++++++++++++ 4 files changed, 35 insertions(+), 4 deletions(-)
diff --git a/common/bloblist.c b/common/bloblist.c index 2144b10e1d04..6f2a4577708d 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -476,6 +476,17 @@ int bloblist_init(void) log_debug("Found existing bloblist size %lx at %lx\n", size, addr); } + if (ret) + return log_msg_ret("ini", ret); + gd->flags |= GD_FLG_BLOBLIST_READY; + + return 0; +}
- return ret; +int bloblist_maybe_init(void) +{ + if (CONFIG_IS_ENABLED(BLOBLIST) && !(gd->flags & GD_FLG_BLOBLIST_READY)) + return bloblist_init(); + + return 0; } diff --git a/common/board_f.c b/common/board_f.c index aef395b1354e..244b0c5685e7 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -841,9 +841,7 @@ static const init_fnc_t init_sequence_f[] = { log_init, initf_bootstage, /* uses its own timer, so does not need DM */ event_init, -#ifdef CONFIG_BLOBLIST - bloblist_init, -#endif + bloblist_maybe_init, setup_spl_handoff, #if defined(CONFIG_CONSOLE_RECORD_INIT_F) console_record_init, diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index edf9ff6823f2..b0485f3dd2a3 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -674,6 +674,10 @@ enum gd_flags { * @GD_FLG_OF_TAG_MIGRATE: Device tree has old u-boot,dm- tags */ GD_FLG_OF_TAG_MIGRATE = 0x200000, + /** + * @GD_FLG_BLOBLIST_READY: bloblist is ready for use + */ + GD_FLG_BLOBLIST_READY = 0x400000, };
#endif /* __ASSEMBLY__ */ diff --git a/include/bloblist.h b/include/bloblist.h index 7ea72c6bd46d..080cc46a1266 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -413,8 +413,26 @@ void bloblist_reloc(void *to, uint to_size, void *from, uint from_size); * standard passage. The size is detected automatically so CONFIG_BLOBLIST_SIZE * can be 0. * + * Sets GD_FLG_BLOBLIST_READY in global_data flags on success + * * Return: 0 if OK, -ve on error */ int bloblist_init(void);
+#if CONFIG_IS_ENABLED(BLOBLIST) +/** + * bloblist_maybe_init() - Init the bloblist system if not already done + * + * Calls bloblist_init() if the GD_FLG_BLOBLIST_READY flag is not et + * + * Return: 0 if OK, -ve on error + */ +int bloblist_maybe_init(void); +#else +static inline int bloblist_maybe_init(void) +{ + return 0; +} +#endif /* BLOBLIST */ + #endif /* __BLOBLIST_H */
Standard passage provides for a bloblist to be passed from one firmware phase to the next. That can be used to pass the devicetree along as well. Add an option to support this.
Tests for this will be added as part of the Universal Payload work.
Changes in v2: - No changes as it still seems unclear what should be done
common/bloblist.c | 2 ++ doc/develop/devicetree/control.rst | 3 ++ dts/Kconfig | 8 ++++++ include/bloblist.h | 5 ++++ include/fdtdec.h | 3 +- lib/fdtdec.c | 44 ++++++++++++++++++++++-------- 6 files changed, 52 insertions(+), 13 deletions(-)
diff --git a/common/bloblist.c b/common/bloblist.c index 6f2a4577708d..b07ede11cfe2 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -48,9 +48,11 @@ static struct tag_name { { BLOBLISTT_ACPI_TABLES, "ACPI tables for x86" }, { BLOBLISTT_SMBIOS_TABLES, "SMBIOS tables for x86" }, { BLOBLISTT_VBOOT_CTX, "Chrome OS vboot context" }, + { BLOBLISTT_CONTROL_FDT, "Control FDT" },
/* BLOBLISTT_PROJECT_AREA */ { BLOBLISTT_U_BOOT_SPL_HANDOFF, "SPL hand-off" }, + { BLOBLISTT_VBE, "VBE" }, { BLOBLISTT_U_BOOT_VIDEO, "SPL video handoff" },
/* BLOBLISTT_VENDOR_AREA */ diff --git a/doc/develop/devicetree/control.rst b/doc/develop/devicetree/control.rst index cbb65c9b177f..56e00090166f 100644 --- a/doc/develop/devicetree/control.rst +++ b/doc/develop/devicetree/control.rst @@ -108,6 +108,9 @@ If CONFIG_OF_BOARD is defined, a board-specific routine will provide the devicetree at runtime, for example if an earlier bootloader stage creates it and passes it to U-Boot.
+If CONFIG_OF_BLOBLIST is defined, the devicetree comes from a bloblist passed +from a previous stage. + If CONFIG_SANDBOX is defined, then it will be read from a file on startup. Use the -d flag to U-Boot to specify the file to read, -D for the default and -T for the test devicetree, used to run sandbox unit tests. diff --git a/dts/Kconfig b/dts/Kconfig index 9152f5885e9a..6c1edbddb57b 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -105,6 +105,14 @@ config OF_EMBED
endchoice
+config OF_BLOBLIST + bool "DTB is provided by a bloblist" + help + Select this to read the devicetree from the bloblist. This allows + using a bloblist to transfer the devicetree between U-Boot phases. + The devicetree is stored in the bloblist by an early phase so that + U-Boot can read it. + config OF_BOARD bool "Provided by the board (e.g a previous loader) at runtime" default y if SANDBOX || OF_HAS_PRIOR_STAGE diff --git a/include/bloblist.h b/include/bloblist.h index 080cc46a1266..e16d122f4fb1 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -103,6 +103,11 @@ enum bloblist_tag_t { BLOBLISTT_ACPI_TABLES = 0x104, /* ACPI tables for x86 */ BLOBLISTT_SMBIOS_TABLES = 0x105, /* SMBIOS tables for x86 */ BLOBLISTT_VBOOT_CTX = 0x106, /* Chromium OS verified boot context */ + /* + * Devicetree for use by firmware. On some platforms this is passed to + * the OS also + */ + BLOBLISTT_CONTROL_FDT = 0x107,
/* * Project-specific tags are permitted here. Projects can be open source diff --git a/include/fdtdec.h b/include/fdtdec.h index bd1149f46d08..1888c4645619 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -72,7 +72,7 @@ struct bd_info; * U-Boot is packaged as an ELF file, e.g. for debugging purposes * @FDTSRC_ENV: Provided by the fdtcontroladdr environment variable. This should * be used for debugging/development only - * @FDTSRC_NONE: No devicetree at all + * @FDTSRC_BLOBLIST: Provided by a bloblist from an earlier phase */ enum fdt_source_t { FDTSRC_SEPARATE, @@ -80,6 +80,7 @@ enum fdt_source_t { FDTSRC_BOARD, FDTSRC_EMBED, FDTSRC_ENV, + FDTSRC_BLOBLIST, };
/* diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 7a6916764835..bd88e6a418eb 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -7,7 +7,11 @@ */
#ifndef USE_HOSTCC + +#define LOG_CATEGORY LOGC_DT + #include <common.h> +#include <bloblist.h> #include <boot_fit.h> #include <display_options.h> #include <dm.h> @@ -87,6 +91,7 @@ static const char *const fdt_src_name[] = { [FDTSRC_BOARD] = "board", [FDTSRC_EMBED] = "embed", [FDTSRC_ENV] = "env", + [FDTSRC_BLOBLIST] = "bloblist", };
const char *fdtdec_get_srcname(void) @@ -1666,20 +1671,35 @@ int fdtdec_setup(void) int ret;
/* The devicetree is typically appended to U-Boot */ - if (IS_ENABLED(CONFIG_OF_SEPARATE)) { - gd->fdt_blob = fdt_find_separate(); - gd->fdt_src = FDTSRC_SEPARATE; - } else { /* embed dtb in ELF file for testing / development */ - gd->fdt_blob = dtb_dt_embedded(); - gd->fdt_src = FDTSRC_EMBED; - } - - /* Allow the board to override the fdt address. */ - if (IS_ENABLED(CONFIG_OF_BOARD)) { - gd->fdt_blob = board_fdt_blob_setup(&ret); + if (CONFIG_IS_ENABLED(OF_BLOBLIST)) { + ret = bloblist_maybe_init(); if (ret) return ret; - gd->fdt_src = FDTSRC_BOARD; + gd->fdt_blob = bloblist_find(BLOBLISTT_CONTROL_FDT, 0); + if (!gd->fdt_blob) { + printf("Not FDT found in bloblist\n"); + bloblist_show_list(); + return -ENOENT; + } + gd->fdt_src = FDTSRC_BLOBLIST; + bloblist_show_list(); + log_debug("Devicetree is in bloblist at %p\n", gd->fdt_blob); + } else { + if (IS_ENABLED(CONFIG_OF_SEPARATE)) { + gd->fdt_blob = fdt_find_separate(); + gd->fdt_src = FDTSRC_SEPARATE; + } else { /* embed dtb in ELF file for testing / development */ + gd->fdt_blob = dtb_dt_embedded(); + gd->fdt_src = FDTSRC_EMBED; + } + + /* Allow the board to override the fdt address. */ + if (IS_ENABLED(CONFIG_OF_BOARD)) { + gd->fdt_blob = board_fdt_blob_setup(&ret); + if (ret) + return ret; + gd->fdt_src = FDTSRC_BOARD; + } }
/* Allow the early environment to override the fdt address */
Hi Simon,
I commented on the v1 thread, but let's continue the discussion here
Changes in v2:
What I argued before is that we don't need to be this explicit. The bloblist can carry a bunch of options that might be used by U-Boot. It would be better if we had a more generic approach instead of adding Kconfig options per bloblist entry
#ifndef USE_HOSTCC
So, instead of adding OF_BLOBLIST, just move this code under OF_BOARD, inside an IS_ENABLED(BLOBLIST) check. If a bloblist is required and the previous stage loader is supposed to provide a DT we can just throw an error and stop booting
return -ENOENT;
Regards /Ilias
Hi Ilias,
On Mon, 25 Sept 2023 at 13:48, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon,
Changes in v2:
Yes, fair enough. It would really get out of hand if we had a lot of Kconfig options for everything that could be in a bloblist.
I believe someone objected to this in the other thread, so there may be board-specific issues to resolve.
#ifndef USE_HOSTCC
This is the bit I don't get.
The OF_BOARD thing is a hack, in that the board can do what it likes. It is our way of handling board-specific mechanisms.
But I am wanting a standard mechanism, i.e. like 'standard passage', a way of passing the DT through the phases.
If I put this under OF_BOARD, then the board gets to override the mechanism, so which is it?
You say 'we can just throw and error' but what is the error? If the DT is provided via the bloblist, there is no error. If it is not, I already show an error and halt as you can see in the code below.
I guess I'm just confused about what you are saying here.
return -ENOENT;
Regards /Ilias
Hi Simon
On Tue, 26 Sept 2023 at 14:37, Simon Glass sjg@chromium.org wrote:
Hi Ilias,
Hi Simon,
Changes in v2:
I had the same objection to that first version as well
#ifndef USE_HOSTCC
No, it's the other way around in my head. OF_BOARD description is 'a previous stage loader hands me over the DT', which is a superset of the bloblist. Whether it comes in a firmware handoff format, or a hacky register the previous bootloader filled in is a detail we have to deal with and we need to keep backwards compatibility.
Maybe adding a coding snip would help if (IS_ENABLED(CONFIG_OF_BOARD)) { if (CONFIG_IS_ENABLED(BLOBLIST)) { <- This instead of OF_BLOBLIST ret = bloblist_maybe_init(); if (ret) return ret; /* Dynamically scan for a DT in the bloblist. */ gd->fdt_blob = bloblist_find(BLOBLISTT_CONTROL_FDT, 0); if (!gd->fdt_blob) { printf("Not FDT found in bloblist\n"); bloblist_show_list(); // We can choose to not return an error here and keep scanning in case the DT is in a register, but I am fine with both return -ENOENT; } gd->fdt_src = FDTSRC_BLOBLIST; bloblist_show_list(); log_debug("Devicetree is in bloblist at %p\n", gd->fdt_blob); // We can also bail out of this entirely if we do find a DT via a bloblist. } else { gd->fdt_blob = board_fdt_blob_setup(&ret); if (ret) return ret; gd->fdt_src = FDTSRC_BOARD; } }
I haven't even compiled the code above, but it should give you a better idea of what I am suggesting
Hope that helps /Ilias
return -ENOENT;
Regards /Ilias
Hi Ilias,
On Tue, 26 Sept 2023 at 06:32, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon
Hi Ilias,
Hi Simon,
Changes in v2:
#ifndef USE_HOSTCC
OK I see...yes that is along the lines of what I thought you meant.
But OF_BOARD does not mean 'previous stage loader hands me over the DT'. I means call board_fdt_blob_setup() which could do anything. If some boards use that function to implement getting a DT from the prior stage, that's fine, but it isn't limited to that.
There is an HAS_PRIOR_STAGE option which sets OF_BOARD at present. But that doesn't seem right in the long term.
The goal here is to standardise the passing of DT from a prior stage, so that all boards (except perhaps the dark child rpi) use standard passage (bloblist) to do so. That should not depend on OF_BOARD and in fact I would like to make OF_BOARD the exception, used when OF_BLOBLIST doesn't suit.
return -ENOENT;
Hi Simon,
I think it is limited. The help message says 'Provider of DTB for DT control' and OF_BOARD help message is 'Provided by the board (e.g a previous loader) at runtime '. In fact, that's exactly what I tried to clean up with commit e7fb789612e39. Sandbox had its special OF_HOSTFILE for the DT. We cleaned that up and then reintroduced it with a different name in commit 275b4832f6bf91c.
In any case, if people want to do 'more' we have CONFIG_OF_BOARD_SETUP/FIXUP which should be used instead for other platform-specific stuff. While at it OF_PRIOR_STAGE is a much better name that OF_BOARD. So we could get rid of OF_PRIOR_STAGE and rename OF_BOARD to that.
The function name that is called in the setup phase is board_fdt_blob_setup(), so it's explicitly targeting the fdt setup, or at least that's what the name suggets. Grepping for CONFIG_OF_BOARD matches in board/AndesTech/ae350/ae350.c board/armltd/vexpress64/vexpress64.c board/raspberrypi/rpi/rpi.c board/sifive/unleashed/unleashed.c board/sifive/unmatched/unmatched.c board/starfive/visionfive2/starfive_visionfive2.c board/xilinx/common/board.c: All these just use it to setup the DT, apart from the rpi which additionally sets up some memory for the DT.
Apart from that it's used on a few platform drivers to setup so DM flags (most of them set DM_FLAG_PRE_RELOC), but we can easily change that and use The only affected files are drivers/pinctrl/broadcom/pinctrl-bcm283x.c drivers/serial/serial_bcm283x_mu.c drivers/serial/serial_bcm283x_pl011.c
So making OF_BOARD do the right thing is trivial and I can work with you on that. I don't think it's too much effort anyway
We are on the same page regarding the standardization. But I think shoehorning an OF_BLOBLIST just papers over the problem. The board should ideally have 2 options 1. a previous loader gives me the DT in X random ways (one of them is the bloblist) 2. U-Boot provides it because it was built with it A user can always load his own special DT if he wants to, but that's done at a later stage.
But if we clean it up properly we can 1. Do Not allow people to sneak in random options in OF_BOARD or whatever and keep the options sane and clean 2. enable BLOBLIST by default in all supported platforms and push to make it the default. We can even be stricter and crash on boot if BLOBLIST is selected and we can't find the DT in there. That would have a similar effect to selecting it as a Kconfig option
Thanks /Ilias
return -ENOENT;
Hi Ilias,
On Tue, 26 Sept 2023 at 07:13, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon,
That commit adds HAS_PRIOR_STATE, though, not anything to do with sandbox.
OK. Perhaps it is just the OF_BOARD name that I object to?
To do that, we have to work out what to do with board-specific setup.
What is the right thing you refer to here?
- a previous loader gives me the DT in X random ways (one of them is
OK
- Do Not allow people to sneak in random options in OF_BOARD or
I am certainly keen to remove OF_BOARD, or print a warning when it is used.
- enable BLOBLIST by default in all supported platforms and push to
Yes, that's what I am doing with this patch. So we end up with:
OF_SEPARATE - packed with U-Boot OF_BLOBLIST - comes in a bloblist OF_BOARD - escape hatch, please don't use
Thanks /Ilias
return -ENOENT;
Hi Simon
On Mon, 2 Oct 2023 at 04:23, Simon Glass sjg@chromium.org wrote:
Hi Ilias,
Hi Simon,
OK
That's not what I am suggesting though. Let me try and sum it up in case it helps
- Remove OF_PRIOR_STAGE - Rename OF_BOARD -> OF_PRIOR_STAGE - Add the bloblist scanning code for DT under the OF_PRIOR_STAGE
Thanks /Ilias
Thanks /Ilias
> + gd->fdt_blob = bloblist_find(BLOBLISTT_CONTROL_FDT, 0); > + if (!gd->fdt_blob) { > + printf("Not FDT found in bloblist\n"); > + bloblist_show_list(); > + return -ENOENT; > + }
Hi Ilias,
On Mon, 2 Oct 2023 at 01:33, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon
Hi Ilias,
Hi Simon,
> > So, instead of adding OF_BLOBLIST, just move this code under OF_BOARD, > inside an IS_ENABLED(BLOBLIST) check. If a bloblist is required and > the previous stage loader is supposed to provide a DT we can just > throw an error and stop booting
OK
What happens if the bloblist does not contain a DT?
What do we do with boards with have a magic way of getting the DT, not using bloblist?
Thanks /Ilias
Thanks /Ilias
> > > > + gd->fdt_blob = bloblist_find(BLOBLISTT_CONTROL_FDT, 0); > > + if (!gd->fdt_blob) { > > + printf("Not FDT found in bloblist\n"); > > + bloblist_show_list(); > > + return -ENOENT; > > + } > > [...] >
This uses ARRAY_SIZE() but does not include the header file which declares it. Fix this, so that command.h can be included without common.h
include/command.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/command.h b/include/command.h index ae7bb4a30b05..8aebf7a95bf8 100644 --- a/include/command.h +++ b/include/command.h @@ -15,6 +15,9 @@
#include <linux/compiler_attributes.h>
+/* For ARRAY_SIZE() */ +#include <linux/kernel.h> + #ifndef NULL #define NULL 0 #endif
The PCI helpers read only the base address for a PCI region. In some cases the size is needed as well, e.g. to pass along to a driver which needs to know the size of its register area.
Update the functions to allow the size to be returned. For serial, record the information and provided it with the serial_info() call.
A limitation still exists in that the size is not available when OF_LIVE is enabled, so take account of that in the tests.
arch/sandbox/dts/test.dts | 6 +++--- drivers/core/fdtaddr.c | 6 +++--- drivers/core/ofnode.c | 11 ++++++++--- drivers/core/read.c | 6 ++++-- drivers/core/util.c | 2 +- drivers/pci/pci-uclass.c | 2 +- drivers/pci/pci_mvebu.c | 3 ++- drivers/pci/pci_tegra.c | 2 +- drivers/pci/pcie_mediatek.c | 4 ++-- drivers/serial/ns16550.c | 15 ++++++++++----- include/dm/fdtaddr.h | 3 ++- include/dm/ofnode.h | 4 +++- include/dm/read.h | 8 +++++--- include/ns16550.h | 4 +++- include/serial.h | 2 ++ test/dm/pci.c | 14 ++++++++++---- 16 files changed, 60 insertions(+), 32 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index d4693e3c7a93..20024101d8ad 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -1098,8 +1098,8 @@ pci@1,0 { compatible = "pci-generic"; /* reg 0 is at 0x14, using FDT_PCI_SPACE_MEM32 */ - reg = <0x02000814 0 0 0 0 - 0x01000810 0 0 0 0>; + reg = <0x02000814 0 0 0x80 0 + 0x01000810 0 0 0xc0 0>; sandbox,emul = <&swap_case_emul0_1>; }; p2sb-pci@2,0 { @@ -1126,7 +1126,7 @@ pci@1f,0 { compatible = "pci-generic"; /* reg 0 is at 0x10, using FDT_PCI_SPACE_IO */ - reg = <0x0100f810 0 0 0 0>; + reg = <0x0100f810 0 0 0x100 0>; sandbox,emul = <&swap_case_emul0_1f>; }; }; diff --git a/drivers/core/fdtaddr.c b/drivers/core/fdtaddr.c index 546db675aaf6..b79d138c4196 100644 --- a/drivers/core/fdtaddr.c +++ b/drivers/core/fdtaddr.c @@ -215,7 +215,7 @@ void *devfdt_map_physmem(const struct udevice *dev, unsigned long size) return map_physmem(addr, size, MAP_NOCACHE); }
-fdt_addr_t devfdt_get_addr_pci(const struct udevice *dev) +fdt_addr_t devfdt_get_addr_pci(const struct udevice *dev, fdt_size_t *sizep) { ulong addr;
@@ -226,12 +226,12 @@ fdt_addr_t devfdt_get_addr_pci(const struct udevice *dev) int ret;
ret = ofnode_read_pci_addr(dev_ofnode(dev), FDT_PCI_SPACE_MEM32, - "reg", &pci_addr); + "reg", &pci_addr, sizep); if (ret) { /* try if there is any i/o-mapped register */ ret = ofnode_read_pci_addr(dev_ofnode(dev), FDT_PCI_SPACE_IO, "reg", - &pci_addr); + &pci_addr, sizep); if (ret) return FDT_ADDR_T_NONE; } diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 2ef4114cb6f8..c9cec456f430 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1270,7 +1270,8 @@ const uint8_t *ofnode_read_u8_array_ptr(ofnode node, const char *propname, }
int ofnode_read_pci_addr(ofnode node, enum fdt_pci_space type, - const char *propname, struct fdt_pci_addr *addr) + const char *propname, struct fdt_pci_addr *addr, + fdt_size_t *size) { const fdt32_t *cell; int len; @@ -1298,14 +1299,18 @@ int ofnode_read_pci_addr(ofnode node, enum fdt_pci_space type, (ulong)fdt32_to_cpu(cell[1]), (ulong)fdt32_to_cpu(cell[2])); if ((fdt32_to_cpu(*cell) & type) == type) { + const unaligned_fdt64_t *ptr; + addr->phys_hi = fdt32_to_cpu(cell[0]); addr->phys_mid = fdt32_to_cpu(cell[1]); addr->phys_lo = fdt32_to_cpu(cell[2]); + ptr = (const unaligned_fdt64_t *)(cell + 3); + if (size) + *size = fdt64_to_cpu(*ptr); break; }
- cell += (FDT_PCI_ADDR_CELLS + - FDT_PCI_SIZE_CELLS); + cell += FDT_PCI_ADDR_CELLS + FDT_PCI_SIZE_CELLS; }
if (i == num) { diff --git a/drivers/core/read.c b/drivers/core/read.c index 49066b59cdaf..419013451f0c 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -405,13 +405,15 @@ int dev_read_alias_highest_id(const char *stem) return fdtdec_get_alias_highest_id(gd->fdt_blob, stem); }
-fdt_addr_t dev_read_addr_pci(const struct udevice *dev) +fdt_addr_t dev_read_addr_pci(const struct udevice *dev, fdt_size_t *sizep) { ulong addr;
addr = dev_read_addr(dev); + if (sizep) + *sizep = 0; if (addr == FDT_ADDR_T_NONE && !of_live_active()) - addr = devfdt_get_addr_pci(dev); + addr = devfdt_get_addr_pci(dev, sizep);
return addr; } diff --git a/drivers/core/util.c b/drivers/core/util.c index aa60fdd15bc4..81497df85ffd 100644 --- a/drivers/core/util.c +++ b/drivers/core/util.c @@ -30,7 +30,7 @@ int pci_get_devfn(struct udevice *dev)
/* Extract the devfn from fdt_pci_addr */ ret = ofnode_read_pci_addr(dev_ofnode(dev), FDT_PCI_SPACE_CONFIG, - "reg", &addr); + "reg", &addr, NULL); if (ret) { if (ret != -ENOENT) return -EINVAL; diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 0adcdceb1d34..c670f8754e8c 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -122,7 +122,7 @@ static void pci_dev_find_ofnode(struct udevice *bus, phys_addr_t bdf,
dev_for_each_subnode(node, bus) { ret = ofnode_read_pci_addr(node, FDT_PCI_SPACE_CONFIG, "reg", - &addr); + &addr, NULL); if (ret) continue;
diff --git a/drivers/pci/pci_mvebu.c b/drivers/pci/pci_mvebu.c index 93a7508d8a2a..25878bde5342 100644 --- a/drivers/pci/pci_mvebu.c +++ b/drivers/pci/pci_mvebu.c @@ -640,7 +640,8 @@ static int mvebu_pcie_port_parse_dt(ofnode node, ofnode parent, struct mvebu_pci pcie->is_x4 = true;
/* devfn is in bits [15:8], see PCI_DEV usage */ - ret = ofnode_read_pci_addr(node, FDT_PCI_SPACE_CONFIG, "reg", &pci_addr); + ret = ofnode_read_pci_addr(node, FDT_PCI_SPACE_CONFIG, "reg", &pci_addr, + NULL); if (ret < 0) { printf("%s: property "reg" is invalid\n", pcie->name); goto err; diff --git a/drivers/pci/pci_tegra.c b/drivers/pci/pci_tegra.c index 29d54117e939..ae90bd2fbf11 100644 --- a/drivers/pci/pci_tegra.c +++ b/drivers/pci/pci_tegra.c @@ -461,7 +461,7 @@ static int tegra_pcie_parse_port_info(ofnode node, uint *index, uint *lanes)
*lanes = err;
- err = ofnode_read_pci_addr(node, 0, "reg", &addr); + err = ofnode_read_pci_addr(node, 0, "reg", &addr, NULL); if (err < 0) { pr_err("failed to parse "reg" property\n"); return err; diff --git a/drivers/pci/pcie_mediatek.c b/drivers/pci/pcie_mediatek.c index c6e30e246227..e59ebd13ad0b 100644 --- a/drivers/pci/pcie_mediatek.c +++ b/drivers/pci/pcie_mediatek.c @@ -660,7 +660,7 @@ static int mtk_pcie_probe(struct udevice *dev) if (!ofnode_is_enabled(subnode)) continue;
- err = ofnode_read_pci_addr(subnode, 0, "reg", &addr); + err = ofnode_read_pci_addr(subnode, 0, "reg", &addr, NULL); if (err) return err;
@@ -699,7 +699,7 @@ static int mtk_pcie_probe_v2(struct udevice *dev) if (!ofnode_is_enabled(subnode)) continue;
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index eab9537fbae5..a349e5e132a1 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -479,6 +479,7 @@ static int ns16550_serial_getinfo(struct udevice *dev, info->addr_space = SERIAL_ADDRESS_SPACE_MEMORY; #endif info->addr = plat->base; + info->size = plat->size; info->reg_width = plat->reg_width; info->reg_shift = plat->reg_shift; info->reg_offset = plat->reg_offset; @@ -487,7 +488,8 @@ static int ns16550_serial_getinfo(struct udevice *dev, return 0; }
-static int ns16550_serial_assign_base(struct ns16550_plat *plat, fdt_addr_t base) +static int ns16550_serial_assign_base(struct ns16550_plat *plat, + fdt_addr_t base, fdt_size_t size) { if (base == FDT_ADDR_T_NONE) return -EINVAL; @@ -497,6 +499,7 @@ static int ns16550_serial_assign_base(struct ns16550_plat *plat, fdt_addr_t base #else plat->base = (unsigned long)map_physmem(base, 0, MAP_NOCACHE); #endif + plat->size = size;
return 0; } @@ -507,6 +510,7 @@ int ns16550_serial_probe(struct udevice *dev) struct ns16550 *const com_port = dev_get_priv(dev); struct reset_ctl_bulk reset_bulk; fdt_addr_t addr; + fdt_addr_t size; int ret;
/* @@ -514,8 +518,8 @@ int ns16550_serial_probe(struct udevice *dev) * or via a PCI bridge, assign plat->base before probing hardware. */ if (device_is_on_pci_bus(dev)) { - addr = devfdt_get_addr_pci(dev); - ret = ns16550_serial_assign_base(plat, addr); + addr = devfdt_get_addr_pci(dev, &size); + ret = ns16550_serial_assign_base(plat, addr, size); if (ret) return ret; } @@ -543,11 +547,12 @@ int ns16550_serial_of_to_plat(struct udevice *dev) struct ns16550_plat *plat = dev_get_plat(dev); const u32 port_type = dev_get_driver_data(dev); fdt_addr_t addr; + fdt_size_t size; struct clk clk; int err;
- addr = dev_read_addr(dev); - err = ns16550_serial_assign_base(plat, addr); + addr = dev_read_addr_size(dev, &size); + err = ns16550_serial_assign_base(plat, addr, size); if (err && !device_is_on_pci_bus(dev)) return err;
diff --git a/include/dm/fdtaddr.h b/include/dm/fdtaddr.h index dcdc19137cc9..6d2fa8f1044b 100644 --- a/include/dm/fdtaddr.h +++ b/include/dm/fdtaddr.h @@ -168,8 +168,9 @@ fdt_addr_t devfdt_get_addr_size_name(const struct udevice *dev, * devfdt_get_addr_pci() - Read an address and handle PCI address translation * * @dev: Device to read from + * @sizep: If non-NULL, returns size of address space * Return: address or FDT_ADDR_T_NONE if not found */ -fdt_addr_t devfdt_get_addr_pci(const struct udevice *dev); +fdt_addr_t devfdt_get_addr_pci(const struct udevice *dev, fdt_size_t *sizep);
#endif diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 726d8f82ddf2..97cad9716112 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1152,13 +1152,15 @@ const uint8_t *ofnode_read_u8_array_ptr(ofnode node, const char *propname, * @type: pci address type (FDT_PCI_SPACE_xxx) * @propname: name of property to find * @addr: returns pci address in the form of fdt_pci_addr + * @size: if non-null, returns register-space size * Return: * 0 if ok, -ENOENT if the property did not exist, -EINVAL if the * format of the property was invalid, -ENXIO if the requested * address type was not found */ int ofnode_read_pci_addr(ofnode node, enum fdt_pci_space type, - const char *propname, struct fdt_pci_addr *addr); + const char *propname, struct fdt_pci_addr *addr, + fdt_size_t *size);
/** * ofnode_read_pci_vendev() - look up PCI vendor and device id diff --git a/include/dm/read.h b/include/dm/read.h index c2615f72f405..3c2eea6f0c4b 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -346,9 +346,10 @@ void *dev_read_addr_ptr(const struct udevice *dev); * fdtdec_get_addr() and friends. * * @dev: Device to read from + * @sizep: If non-NULL, returns size of address space found * Return: address or FDT_ADDR_T_NONE if not found */ -fdt_addr_t dev_read_addr_pci(const struct udevice *dev); +fdt_addr_t dev_read_addr_pci(const struct udevice *dev, fdt_size_t *sizep);
/** * dev_remap_addr() - Get the reg property of a device as a @@ -996,9 +997,10 @@ static inline void *dev_read_addr_ptr(const struct udevice *dev) return devfdt_get_addr_ptr(dev); }
-static inline fdt_addr_t dev_read_addr_pci(const struct udevice *dev) +static inline fdt_addr_t dev_read_addr_pci(const struct udevice *dev, + fdt_size_t *sizep) { - return devfdt_get_addr_pci(dev); + return devfdt_get_addr_pci(dev, sizep); }
static inline void *dev_remap_addr(const struct udevice *dev) diff --git a/include/ns16550.h b/include/ns16550.h index e7e68663d030..7f481300083a 100644 --- a/include/ns16550.h +++ b/include/ns16550.h @@ -58,6 +58,7 @@ enum ns16550_flags { * struct ns16550_plat - information about a NS16550 port * * @base: Base register address + * @size: Size of register area in bytes * @reg_width: IO accesses size of registers (in bytes, 1 or 4) * @reg_shift: Shift size of registers (0=byte, 1=16bit, 2=32bit...) * @reg_offset: Offset to start of registers (normally 0) @@ -67,7 +68,8 @@ enum ns16550_flags { * @bdf: PCI slot/function (pci_dev_t) */ struct ns16550_plat { - unsigned long base; + ulong base; + ulong size; int reg_width; int reg_shift; int reg_offset; diff --git a/include/serial.h b/include/serial.h index 42bdf3759c00..205889d28be9 100644 --- a/include/serial.h +++ b/include/serial.h @@ -137,6 +137,7 @@ enum adr_space_type { * @type: type of the UART chip * @addr_space: address space to access the registers * @addr: physical address of the registers + * @size: size of the register area in bytes * @reg_width: size (in bytes) of the IO accesses to the registers * @reg_offset: offset to apply to the @addr from the start of the registers * @reg_shift: quantity to shift the register offsets by @@ -147,6 +148,7 @@ struct serial_device_info { enum serial_chip_type type; enum adr_space_type addr_space; ulong addr; + ulong size; u8 reg_width; u8 reg_offset; u8 reg_shift; diff --git a/test/dm/pci.c b/test/dm/pci.c index 70a736cfdb8a..8c5e7da9e629 100644 --- a/test/dm/pci.c +++ b/test/dm/pci.c @@ -301,10 +301,12 @@ static int dm_test_pci_addr_flat(struct unit_test_state *uts) { struct udevice *swap1f, *swap1; ulong io_addr, mem_addr; + fdt_addr_t size;
ut_assertok(dm_pci_bus_find_bdf(PCI_BDF(0, 0x1f, 0), &swap1f)); io_addr = dm_pci_read_bar32(swap1f, 0); - ut_asserteq(io_addr, dev_read_addr_pci(swap1f)); + ut_asserteq(io_addr, dev_read_addr_pci(swap1f, &size)); + ut_asserteq(0, size);
/* * This device has both I/O and MEM spaces but the MEM space appears @@ -312,7 +314,8 @@ static int dm_test_pci_addr_flat(struct unit_test_state *uts) */ ut_assertok(dm_pci_bus_find_bdf(PCI_BDF(0, 0x1, 0), &swap1)); mem_addr = dm_pci_read_bar32(swap1, 1); - ut_asserteq(mem_addr, dev_read_addr_pci(swap1)); + ut_asserteq(mem_addr, dev_read_addr_pci(swap1, &size)); + ut_asserteq(0, size);
return 0; } @@ -329,12 +332,15 @@ DM_TEST(dm_test_pci_addr_flat, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT | static int dm_test_pci_addr_live(struct unit_test_state *uts) { struct udevice *swap1f, *swap1; + fdt_size_t size;
ut_assertok(dm_pci_bus_find_bdf(PCI_BDF(0, 0x1f, 0), &swap1f)); - ut_asserteq_64(FDT_ADDR_T_NONE, dev_read_addr_pci(swap1f)); + ut_asserteq_64(FDT_ADDR_T_NONE, dev_read_addr_pci(swap1f, &size)); + ut_asserteq(0, size);
ut_assertok(dm_pci_bus_find_bdf(PCI_BDF(0, 0x1, 0), &swap1)); - ut_asserteq_64(FDT_ADDR_T_NONE, dev_read_addr_pci(swap1)); + ut_asserteq_64(FDT_ADDR_T_NONE, dev_read_addr_pci(swap1, &size)); + ut_asserteq(0, size);
return 0; }
Ilias Apalodimas
