[U-Boot] [PATCH v3] sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/Kconfig
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs.
This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- Changes in v2: -Only select CONFIG_OF_BOARD_SETUP when CONFIG_VIDEO is set, rather then always Changes in v3: -Back to always enabling CONFIG_OF_BOARD_SETUP on sunxi + fix the compile warning in ft_board_setup when CONFIG_VIDEO_DT_SIMPLEFB is not set --- arch/arm/Kconfig | 1 + board/sunxi/board.c | 9 ++++++--- configs/A10-OLinuXino-Lime_defconfig | 1 - configs/A10s-OLinuXino-M_defconfig | 1 - configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 1 - configs/A20-OLinuXino-Lime_defconfig | 1 - configs/A20-OLinuXino_MICRO_defconfig | 1 - configs/A20-Olimex-SOM-EVB_defconfig | 1 - configs/Ainol_AW1_defconfig | 1 - configs/Ampe_A76_defconfig | 1 - configs/Auxtek-T003_defconfig | 1 - configs/Auxtek-T004_defconfig | 1 - configs/Bananapi_defconfig | 1 - configs/Bananapro_defconfig | 1 - configs/CHIP_defconfig | 1 - configs/CSQ_CS908_defconfig | 1 - configs/Chuwi_V7_CW0825_defconfig | 1 - configs/Colombus_defconfig | 1 - configs/Cubieboard2_defconfig | 1 - configs/Cubieboard_defconfig | 1 - configs/Cubietruck_defconfig | 1 - configs/Empire_electronix_d709_defconfig | 1 - configs/Hummingbird_A31_defconfig | 1 - configs/Hyundai_A7HD_defconfig | 1 - configs/Lamobo_R1_defconfig | 1 - configs/Linksprite_pcDuino3_Nano_defconfig | 1 - configs/Linksprite_pcDuino3_defconfig | 1 - configs/Linksprite_pcDuino_defconfig | 1 - configs/MK808C_defconfig | 1 - configs/MSI_Primo73_defconfig | 1 - configs/MSI_Primo81_defconfig | 1 - configs/Marsboard_A10_defconfig | 1 - configs/Mele_A1000G_quad_defconfig | 1 - configs/Mele_A1000_defconfig | 1 - configs/Mele_I7_defconfig | 1 - configs/Mele_M3_defconfig | 1 - configs/Mele_M5_defconfig | 1 - configs/Mele_M9_defconfig | 1 - configs/Mini-X_defconfig | 1 - configs/Orangepi_defconfig | 1 - configs/Orangepi_mini_defconfig | 1 - configs/Sinlinx_SinA31s_defconfig | 1 - configs/Sinlinx_SinA33_defconfig | 1 - configs/Sinovoip_BPI_M2_defconfig | 1 - configs/UTOO_P66_defconfig | 1 - configs/Wexler_TAB7200_defconfig | 1 - configs/Wits_Pro_A20_DKT_defconfig | 1 - configs/Wobo_i5_defconfig | 1 - configs/Yones_Toptech_BD1078_defconfig | 1 - configs/ba10_tv_box_defconfig | 1 - configs/dserve_dsrv9703c_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/i12-tvbox_defconfig | 1 - configs/iNet_3F_defconfig | 1 - configs/iNet_3W_defconfig | 1 - configs/iNet_86VS_defconfig | 1 - configs/inet1_defconfig | 1 - configs/inet97fv2_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/inet9f_rev03_defconfig | 1 - configs/jesurun_q5_defconfig | 1 - configs/mixtile_loftq_defconfig | 1 - configs/mk802_a10s_defconfig | 1 - configs/mk802_defconfig | 1 - configs/mk802ii_defconfig | 1 - configs/pov_protab2_ips9_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - configs/r7-tv-dongle_defconfig | 1 - configs/sunxi_Gemei_G9_defconfig | 1 - 75 files changed, 7 insertions(+), 76 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index e5f57ef..ab986d3 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -531,6 +531,7 @@ config ARCH_SUNXI select DM_KEYBOARD select DM_SERIAL select DM_USB + select OF_BOARD_SETUP select OF_CONTROL select OF_SEPARATE select SPL_STACK_R if !MACH_SUN9I diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 2e2a1f5..2d5335f 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -607,11 +607,14 @@ int misc_init_r(void) } #endif
-#ifdef CONFIG_OF_BOARD_SETUP int ft_board_setup(void *blob, bd_t *bd) { + int __maybe_unused r; + #ifdef CONFIG_VIDEO_DT_SIMPLEFB - return sunxi_simplefb_setup(blob); + r = sunxi_simplefb_setup(blob); + if (r) + return r; #endif + return 0; } -#endif /* CONFIG_OF_BOARD_SETUP */ diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 6235d1f..af96f5b 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -8,7 +8,6 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPC(3)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 3cddc12..cba2cfd 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -9,7 +9,6 @@ CONFIG_USB1_VBUS_PIN="PB10" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index 6000d9b..45cc5ab 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -13,7 +13,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 6342f6b..11691a2 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 95c67d6..b5181c6 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -8,7 +8,6 @@ CONFIG_USB0_VBUS_DET="PH5" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index dc6413b..e27698d 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -6,7 +6,6 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPC(3)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 13a3999..03481f6 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -9,7 +9,6 @@ CONFIG_VIDEO_VGA=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 66d8f98..001d31b 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -11,7 +11,6 @@ CONFIG_USB0_VBUS_DET="PH5" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index cf9f161..67bea5a 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -14,7 +14,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-ainol-aw1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index 949f1e0..82e01ba 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-ampe-a76" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index f149b67..8f1be3e 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -8,7 +8,6 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t003" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index c176059..434b007 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -6,7 +6,6 @@ CONFIG_USB1_VBUS_PIN="PG13" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t004" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index f7e0bb7..6cbb76c 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -7,7 +7,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 9197b00..646cb2a 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -9,7 +9,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index c6bd7b2..4f99d1e 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -7,7 +7,6 @@ CONFIG_USB0_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-r8-chip" CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 4a395cd..e027a47 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -7,7 +7,6 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-cs908" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index db1b8b1..dedf772 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -14,7 +14,6 @@ CONFIG_VIDEO_LCD_PANEL_HITACHI_TX18D42VM=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-chuwi-v7-cw0825" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index c21733d..feaeb98 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -17,7 +17,6 @@ CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index 3f3e15a..2f5e75d 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -6,7 +6,6 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index eadd791..a45fbb0 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -6,7 +6,6 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 0025308..8cbaea6 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -11,7 +11,6 @@ CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 5de4381..5973fbf 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-d709" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index 92986ca..83f2004 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -9,7 +9,6 @@ CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index 8ffdd92..45739cd 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-hyundai-a7hd" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index f0433b9..d460c32 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -7,7 +7,6 @@ CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,SATAPWR=SUNXI_GPB(3)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index e5c400d..ca3b1dd 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -8,7 +8,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(2)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index d1f93ea..1f245e7 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -6,7 +6,6 @@ CONFIG_DRAM_ZQ=122 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPH(2)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index 2b71e90..7e2f942 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -6,7 +6,6 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pcduino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index aba8d01..32c65fb 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -5,7 +5,6 @@ CONFIG_DRAM_CLK=384 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-mk808c" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index 7903510..73fd4e8 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -10,7 +10,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-primo73" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index b77f9e0..11f3203 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -13,7 +13,6 @@ CONFIG_VIDEO_LCD_PANEL_MIPI_4_LANE_513_MBPS_VIA_SSD2828=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-primo81" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index ef71194..806fb64 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -4,7 +4,6 @@ CONFIG_MACH_SUN4I=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-marsboard" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index e04bc75..6127098 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -7,7 +7,6 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mele-a1000g-quad" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 95068c8..93707e4 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -6,7 +6,6 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 0b83431..bfe2a29 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -7,7 +7,6 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-i7" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 5dd61c0..0ed5da1 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -9,7 +9,6 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 3cdd67f..fdb5ba4 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -8,7 +8,6 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,STATUSLED=234" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index 6ae2e0b..da76226 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -7,7 +7,6 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-m9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index 8425d1f..8013359 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -6,7 +6,6 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mini-xplus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index bd43df3..330ee47 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -10,7 +10,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 1e790e8..4156c35 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -12,7 +12,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 9254bb2..ae1f1e8 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -11,7 +11,6 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sina31s" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 2dd8d7e..20d3f93 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -6,7 +6,6 @@ CONFIG_DRAM_ZQ=15291 CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-sinlinx-sina33" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index c61ed7b..a5f8e6a 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -7,7 +7,6 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index 46e697a..dc71dde 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -20,7 +20,6 @@ CONFIG_VIDEO_LCD_TL059WV5C0=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-utoo-p66" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index ce1e1fd..a01b4c1 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -13,7 +13,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wexler-tab7200" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 31d09d4..c3ceedb 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -11,7 +11,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index 7cc9051..eb1b531 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -7,7 +7,6 @@ CONFIG_USB1_VBUS_PIN="PG12" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-wobo-i5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index 2e11f7c..cdde2bc 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -19,7 +19,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-yones-toptech-bd1078" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index 944547c..ce4a584 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -9,7 +9,6 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-ba10-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index 45c6047..029ca89 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-dserve-dsrv9703c" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index d700760..09ad330 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -17,7 +17,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ga10h-v1.1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index a78d3b6..a8d339c 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-gt90h-v4" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index daa4e9d..a15a15a 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -6,7 +6,6 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,MACPWR=SUNXI_GPH(21)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index 1fbf66a..3f1624c 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -14,7 +14,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3f" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index 7d91aec..6c4cd56 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -14,7 +14,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3w" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index ba04b60..00e1458 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -13,7 +13,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-86vs" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index 0b9c604..1c68293 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -14,7 +14,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index 744051a..a7b3a9f 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -13,7 +13,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet97fv2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index 1897daa..c0c6cb2 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-98v-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index 662f2e2..0a17cf7 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -13,7 +13,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet9f-rev03" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 1a165f0..443a1c7 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -7,7 +7,6 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(19)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index a5722e7..07865d8 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -8,7 +8,6 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index 316b7e8..03e58cd 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -7,7 +7,6 @@ CONFIG_USB1_VBUS_PIN="PB10" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index bc24b4c..922f8c3 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -5,7 +5,6 @@ CONFIG_USB2_VBUS_PIN="PH12" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index 6636e7f..2a359be 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -4,7 +4,6 @@ CONFIG_MACH_SUN4I=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802ii" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index 99884ed..d9b3b45 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -14,7 +14,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pov-protab2-ips9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index b6ff528..205359e 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 398546a..927ab2a 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index 3c32387..755f4ee 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index aed4fba..a8dfa0d 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index edbf2ea..d6387fc 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -6,7 +6,6 @@ CONFIG_USB1_VBUS_PIN="PG13" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-r7-tv-dongle" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index 7f737f2..d3de194 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -11,7 +11,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-gemei-g9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set
I agree this approach is better: Acked-by: Ian Campbell ijc@hellion.org.uk
Hans de Goede
Ian Campbell
