[U-Boot] [PATCH] pci: tegra: actually program REFCLK_CFG* on recent SoCs
On recent SoCs, tegra_pcie_phy_enable() isn't called; but instead tegra_pcie_enable_controller() calls tegra_xusb_phy_enable(). However, part of tegra_pcie_phy_enable() needs to happen in all cases. Move that code to tegra_pcie_port_enable() instead.
For reference, NVIDIA's downstream Linux kernel performs this operation in tegra_pcie_enable_rp_features(), which is called immediately after tegra_pcie_port_enable(). Since that function doesn't exist in the U-Boot driver, we'll just add it to the tail of tegra_pcie_port_enable() instead.
Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/pci/pci_tegra.c | 19 ++++++++++--------- 1 file changed, 10 insertions(+), 9 deletions(-)
diff --git a/drivers/pci/pci_tegra.c b/drivers/pci/pci_tegra.c index 1aa56fc93739..352cdef56ab4 100644 --- a/drivers/pci/pci_tegra.c +++ b/drivers/pci/pci_tegra.c @@ -620,11 +620,6 @@ static int tegra_pcie_phy_enable(struct tegra_pcie *pcie) value |= PADS_PLL_CTL_RST_B4SM; pads_writel(pcie, value, soc->pads_pll_ctl);
- /* configure the reference clock driver */ - pads_writel(pcie, soc->pads_refclk_cfg0, PADS_REFCLK_CFG0); - if (soc->num_ports > 2) - pads_writel(pcie, soc->pads_refclk_cfg1, PADS_REFCLK_CFG1); - /* wait for the PLL to lock */ err = tegra_pcie_pll_wait(pcie, 500); if (err < 0) { @@ -818,20 +813,21 @@ static void tegra_pcie_port_reset(struct tegra_pcie_port *port)
static void tegra_pcie_port_enable(struct tegra_pcie_port *port) { - const struct tegra_pcie_soc *soc = port->pcie->soc; + struct tegra_pcie *pcie = port->pcie; + const struct tegra_pcie_soc *soc = pcie->soc; unsigned long ctrl = tegra_pcie_port_get_pex_ctrl(port); unsigned long value;
/* enable reference clock */ - value = afi_readl(port->pcie, ctrl); + value = afi_readl(pcie, ctrl); value |= AFI_PEX_CTRL_REFCLK_EN;
- if (port->pcie->soc->has_pex_clkreq_en) + if (pcie->soc->has_pex_clkreq_en) value |= AFI_PEX_CTRL_CLKREQ_EN;
value |= AFI_PEX_CTRL_OVERRIDE_EN;
- afi_writel(port->pcie, value, ctrl); + afi_writel(pcie, value, ctrl);
tegra_pcie_port_reset(port);
@@ -840,6 +836,11 @@ static void tegra_pcie_port_enable(struct tegra_pcie_port *port) value |= RP_VEND_CTL2_PCA_ENABLE; rp_writel(port, value, RP_VEND_CTL2); } + + /* configure the reference clock driver */ + pads_writel(pcie, soc->pads_refclk_cfg0, PADS_REFCLK_CFG0); + if (soc->num_ports > 2) + pads_writel(pcie, soc->pads_refclk_cfg1, PADS_REFCLK_CFG1); }
static bool tegra_pcie_port_check_link(struct tegra_pcie_port *port)
Stephen Warren
