[U-Boot] [PATCH v2] Adds general Freescale external debugger support
This patch adds general Freescale powerpc external debugger support. Patch is tested on 85xx/QorIQ platforms in u-boot with CodeWarrior. CONFIG_EXT_DEBUGGER should be defined if the u-boot needs to be debugged by external debugger. To use the external debug funciton, the make command can be just as make CONFIG_EXT_DEBUGGER=1 or define CONFIG_EXT_DEBUGGER in the board header file.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com Cc: Wood Scott-B07421 B07421@freescale.com Cc: Kumar Gala galak@kernel.crashing.org --- Consider the comment from Wolfgang Denk http://lists.denx.de/pipermail/u-boot/2010-October/080689.html
README | 4 ++++ arch/powerpc/config.mk | 3 +++ 2 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/README b/README index 755d17c..6162fa6 100644 --- a/README +++ b/README @@ -2885,6 +2885,10 @@ Low Level (hardware related) configuration options: that is executed before the actual U-Boot. E.g. when compiling a NAND SPL.
+- CONFIG_EXT_DEBUGGER + Adds external debugger support. Extra build option will be + added to support external debugger. + Building the Software: ======================
diff --git a/arch/powerpc/config.mk b/arch/powerpc/config.mk index 2912604..9af9647 100644 --- a/arch/powerpc/config.mk +++ b/arch/powerpc/config.mk @@ -53,3 +53,6 @@ endif ifeq ($(CROSS_COMPILE),powerpc-openbsd-) PLATFORM_CPPFLAGS+= -D__PPC__ endif +ifdef CONFIG_EXT_DEBUGGER +PLATFORM_CPPFLAGS+= -ggdb -Wa,-gdwarf2 +endif
Dear Roy Zang,
In message 1296381492-31346-1-git-send-email-tie-fei.zang@freescale.com you wrote:
How exactly do you define "external debugger"? Does that mean that there is an "internal debugger"? Are you thinking of "bedbug" here?
And in which way is this specific to "Freescale external debuggers" as you describe it in the Subject?
I don't see where this is specific to the Power architecture either - expect that you only tested it there.
My understanding is that you enable debug settings for the GNU debugger.
Do these need to be architecture specific? Probably not.
Do these need to be enabled by a new #define? What would be the disadvantages of having these options always enabled, for all architectures?
Am 01/30/2011 08:43 PM, schrieb Wolfgang Denk:
I do remember that we needed architecture-dependent debug options on a system I worked on in the past, because the preferred debug format was different on different platforms (all using gcc/binutils/gdb).
Always having debug info in the ELF file should not cause problems IMHO, and one set of settings per platform should be enough.
cu Michael
Dear Michael Schwingen,
Can you please be a bit more specific here?
I can only tell from memory, since this was some years ago - IIRC, we needed dwarf debug info on some platforms and stabs on others. I can't provide exact details, since the current toolchains work fine without such tweaking - I only wanted to point out that if you need to specify the exact debug format, then it might be platform-specific.
A simple "-g" should be fine in the common area.
cu Michael
-----Original Message----- From: Michael Schwingen [mailto:rincewind@discworld.dascon.de] Sent: Monday, January 31, 2011 19:18 PM To: Wolfgang Denk Cc: Zang Roy-R61911; u-boot@lists.denx.de; Kumar Gala; Wood Scott-B07421 Subject: Re: [U-Boot] [PATCH v2] Adds general Freescale external debugger support
Hi, Wolfgang Considering the name, how about CONFIG_POWERPC_GNU_DEBUGGER? thanks. Roy
-----Original Message----- From: Michael Schwingen [mailto:rincewind@discworld.dascon.de] Sent: Monday, January 31, 2011 6:50 AM To: Wolfgang Denk Cc: Zang Roy-R61911; u-boot@lists.denx.de; Kumar Gala; Wood Scott-B07421 Subject: Re: [U-Boot] [PATCH v2] Adds general Freescale external debugger support
[snip]
Including the debug information, size should be consideration. Roy
On Mon, 7 Mar 2011 01:18:28 -0600 Zang Roy-R61911 R61911@freescale.com wrote:
[snip]
It doesn't get included in the .bin which is flashed on the target -- you're worried about the developer's hard disk being too small?
-Scott
participants (5)
Michael Schwingen
Roy Zang
Scott Wood
Zang Roy-R61911
