[U-Boot] [PATCH 1/5] arm: socfpga: dts: altr, rst-mgr.h: Move to SPDX license identifiers
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- include/dt-bindings/reset/altr,rst-mgr.h | 9 +-------- 1 file changed, 1 insertion(+), 8 deletions(-)
diff --git a/include/dt-bindings/reset/altr,rst-mgr.h b/include/dt-bindings/reset/altr,rst-mgr.h index 3f04908..351d8cd 100644 --- a/include/dt-bindings/reset/altr,rst-mgr.h +++ b/include/dt-bindings/reset/altr,rst-mgr.h @@ -1,14 +1,7 @@ /* * Copyright (c) 2014, Steffen Trumtrar s.trumtrar@pengutronix.de * - * This software is licensed under the terms of the GNU General Public - * License version 2, as published by the Free Software Foundation, and - * may be copied, distributed, and modified under those terms. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. + * SPDX-License-Identifier: GPL-2.0 */
#ifndef _DT_BINDINGS_RESET_ALTR_RST_MGR_H
As suggested by Pavel, lets combine the two calls into one.
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- arch/arm/cpu/armv7/socfpga/reset_manager.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/socfpga/reset_manager.c b/arch/arm/cpu/armv7/socfpga/reset_manager.c index af9db85..25921e7 100644 --- a/arch/arm/cpu/armv7/socfpga/reset_manager.c +++ b/arch/arm/cpu/armv7/socfpga/reset_manager.c @@ -110,6 +110,6 @@ void socfpga_spim_enable(void) { const void *reset = &reset_manager_base->per_mod_reset;
- clrbits_le32(reset, 1 << RSTMGR_PERMODRST_SPIM0_LSB); - clrbits_le32(reset, 1 << RSTMGR_PERMODRST_SPIM1_LSB); + clrbits_le32(reset, (1 << RSTMGR_PERMODRST_SPIM0_LSB) | + (1 << RSTMGR_PERMODRST_SPIM1_LSB)); }
Acked-by: Pavel Machek pavel@denx.de
- clrbits_le32(reset, (1 << RSTMGR_PERMODRST_SPIM0_LSB) |
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- arch/arm/include/asm/arch-socfpga/clock_manager.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-socfpga/clock_manager.h b/arch/arm/include/asm/arch-socfpga/clock_manager.h index fa49f6a..5449726 100644 --- a/arch/arm/include/asm/arch-socfpga/clock_manager.h +++ b/arch/arm/include/asm/arch-socfpga/clock_manager.h @@ -14,6 +14,7 @@ unsigned long cm_get_sdram_clk_hz(void); unsigned int cm_get_l4_sp_clk_hz(void); unsigned int cm_get_mmc_controller_clk_hz(void); unsigned int cm_get_qspi_controller_clk_hz(void); +unsigned int cm_get_spi_controller_clk_hz(void); #endif
typedef struct {
typedef struct {
As suggested by Pavel, here some fixes to the designware SPI driver:
- Spelling fixes - Comment for timeout added - Removed n_bytes completely (bits_per_word is enough for this) - Unput clock now not defined via macro. The function to get the clock value is now called directly from within the driver
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de Cc: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com --- drivers/spi/designware_spi.c | 39 ++++++++++++++++++++------------------- 1 file changed, 20 insertions(+), 19 deletions(-)
diff --git a/drivers/spi/designware_spi.c b/drivers/spi/designware_spi.c index 1bc0d04..98c9f03 100644 --- a/drivers/spi/designware_spi.c +++ b/drivers/spi/designware_spi.c @@ -3,7 +3,8 @@ * * Copyright (C) 2014 Stefan Roese sr@denx.de * - * Very loosly based on the Linux driver version which is: + * Very loosely based on the Linux driver: + * drivers/spi/spi-dw.c, which is: * Copyright (c) 2009, Intel Corporation. * * SPDX-License-Identifier: GPL-2.0 @@ -17,6 +18,7 @@ #include <fdtdec.h> #include <linux/compat.h> #include <asm/io.h> +#include <asm/arch/clock_manager.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -81,7 +83,7 @@ DECLARE_GLOBAL_DATA_PTR; #define SR_TX_ERR (1 << 5) #define SR_DCOL (1 << 6)
-#define RX_TIMEOUT 1000 +#define RX_TIMEOUT 1000 /* timeout in ms */
struct dw_spi_platdata { s32 frequency; /* Default clock frequency, -1 for none */ @@ -95,7 +97,6 @@ struct dw_spi_priv {
int bits_per_word; u8 cs; /* chip select pin */ - u8 n_bytes; /* current is a 1/2/4 byte op */ u8 tmode; /* TR/TO/RO/EEPROM */ u8 type; /* SPI/SSP/MicroWire */ int len; @@ -185,7 +186,6 @@ static int dw_spi_probe(struct udevice *bus)
/* Currently only bits_per_word == 8 supported */ priv->bits_per_word = 8; - priv->n_bytes = 1;
priv->tmode = 0; /* Tx & Rx */
@@ -200,19 +200,19 @@ static inline u32 tx_max(struct dw_spi_priv *priv) { u32 tx_left, tx_room, rxtx_gap;
- tx_left = (priv->tx_end - priv->tx) / priv->n_bytes; + tx_left = (priv->tx_end - priv->tx) / (priv->bits_per_word >> 3); tx_room = priv->fifo_len - dw_readw(priv, DW_SPI_TXFLR);
/* * Another concern is about the tx/rx mismatch, we - * though to use (priv->fifo_len - rxflr - txflr) as + * thought about using (priv->fifo_len - rxflr - txflr) as * one maximum value for tx, but it doesn't cover the * data which is out of tx/rx fifo and inside the * shift registers. So a control from sw point of * view is taken. */ rxtx_gap = ((priv->rx_end - priv->rx) - (priv->tx_end - priv->tx)) / - priv->n_bytes; + (priv->bits_per_word >> 3);
return min3(tx_left, tx_room, (u32)(priv->fifo_len - rxtx_gap)); } @@ -220,7 +220,7 @@ static inline u32 tx_max(struct dw_spi_priv *priv) /* Return the max entries we should read out of rx fifo */ static inline u32 rx_max(struct dw_spi_priv *priv) { - u32 rx_left = (priv->rx_end - priv->rx) / priv->n_bytes; + u32 rx_left = (priv->rx_end - priv->rx) / (priv->bits_per_word >> 3);
return min_t(u32, rx_left, dw_readw(priv, DW_SPI_RXFLR)); } @@ -233,14 +233,14 @@ static void dw_writer(struct dw_spi_priv *priv) while (max--) { /* Set the tx word if the transfer's original "tx" is not null */ if (priv->tx_end - priv->len) { - if (priv->n_bytes == 1) + if (priv->bits_per_word == 8) txw = *(u8 *)(priv->tx); else txw = *(u16 *)(priv->tx); } dw_writew(priv, DW_SPI_DR, txw); debug("%s: tx=0x%02x\n", __func__, txw); - priv->tx += priv->n_bytes; + priv->tx += priv->bits_per_word >> 3; } }
@@ -261,14 +261,18 @@ static int dw_reader(struct dw_spi_priv *priv) while (max--) { rxw = dw_readw(priv, DW_SPI_DR); debug("%s: rx=0x%02x\n", __func__, rxw); - /* Care rx only if the transfer's original "rx" is not null */ + + /* + * Care about rx only if the transfer's original "rx" is + * not null + */ if (priv->rx_end - priv->len) { - if (priv->n_bytes == 1) + if (priv->bits_per_word == 8) *(u8 *)(priv->rx) = rxw; else *(u16 *)(priv->rx) = rxw; } - priv->rx += priv->n_bytes; + priv->rx += priv->bits_per_word >> 3; }
return 0; @@ -297,7 +301,6 @@ static int dw_spi_xfer(struct udevice *dev, unsigned int bitlen, u8 *rx = din; int ret = 0; u32 cr0 = 0; - u8 bits = 0; u32 cs;
/* spi core configured to do 8 bit transfers */ @@ -306,9 +309,7 @@ static int dw_spi_xfer(struct udevice *dev, unsigned int bitlen, return -1; }
- bits = priv->bits_per_word; - priv->n_bytes = bits >> 3; - cr0 = (bits - 1) | (priv->type << SPI_FRF_OFFSET) | + cr0 = (priv->bits_per_word - 1) | (priv->type << SPI_FRF_OFFSET) | (priv->mode << SPI_MODE_OFFSET) | (priv->tmode << SPI_TMOD_OFFSET);
@@ -322,7 +323,7 @@ static int dw_spi_xfer(struct udevice *dev, unsigned int bitlen, cr0 &= ~SPI_TMOD_MASK; cr0 |= (priv->tmode << SPI_TMOD_OFFSET);
- priv->len = bitlen / 8; + priv->len = bitlen >> 3; debug("%s: rx=%p tx=%p len=%d [bytes]\n", __func__, rx, tx, priv->len);
priv->tx = (void *)tx; @@ -368,7 +369,7 @@ static int dw_spi_set_speed(struct udevice *bus, uint speed) spi_enable_chip(priv, 0);
/* clk_div doesn't support odd number */ - clk_div = CONFIG_DW_SPI_REF_CLK / speed; + clk_div = cm_get_spi_controller_clk_hz() / speed; clk_div = (clk_div + 1) & 0xfffe; dw_writel(priv, DW_SPI_BAUDR, clk_div);
- Spelling fixes
Remove the now unnecessary clocking info from the SoCFPGA config header. As this info in now used directly in the SPI driver itself.
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- include/configs/socfpga_common.h | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 281534f..0953974 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -215,10 +215,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_DM #define CONFIG_DM_SPI #define CONFIG_DESIGNWARE_SPI -#ifndef __ASSEMBLY__ -unsigned int cm_get_spi_controller_clk_hz(void); -#define CONFIG_DW_SPI_REF_CLK cm_get_spi_controller_clk_hz() -#endif #define CONFIG_CMD_SPI #endif
Thanks! Pavel
On Sunday, November 16, 2014 at 12:46:58 PM, Stefan Roese wrote:
Hi!
Applied all, thank you!
Can you please verify u-boot-socfpga branch topic/drivers/spi-20141119 and test if all stil works please ?
Best regards, Marek Vasut
Hi Marek,
Hi!
Looks good. Tested successfully on SoCrates.
Thanks, Stefan
Pavel Machek
Stefan Roese
