[PATCH] wandboard: Pass mmc aliases
Originally, the mmc aliases node was present in imx6qdl-wandboard.dtsi.
After the sync with Linux in commit d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with linux"), the aliases node is gone as the upstream version does not have it.
This causes a regression in which the SD card cannot be found anymore:
Since commit the aliases node has been removed U-Boot 2022.10-00999-gcca41ed3d63f-dirty (Nov 03 2022 - 22:07:38 -0300)
CPU: Freescale i.MX6QP rev1.0 at 792 MHz Reset cause: POR DRAM: 2 GiB Core: 62 devices, 17 uclasses, devicetree: separate PMIC: PFUZE100 ID=0x10 MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... MMC: no card present *** Warning - No block device, using default environment
Fix it by passing the alias node in the u-boot.dtsi file to restore the original behaviour where the SD card (esdhc3) was mapped to mmc0.
Fixes: d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with linux") Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/dts/imx6dl-wandboard-revd1-u-boot.dtsi | 1 + arch/arm/dts/imx6q-wandboard-revd1-u-boot.dtsi | 1 + arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi | 9 +++++++++ arch/arm/dts/imx6qp-wandboard-revd1-u-boot.dtsi | 1 + 4 files changed, 12 insertions(+) create mode 100644 arch/arm/dts/imx6dl-wandboard-revd1-u-boot.dtsi create mode 100644 arch/arm/dts/imx6q-wandboard-revd1-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qp-wandboard-revd1-u-boot.dtsi
diff --git a/arch/arm/dts/imx6dl-wandboard-revd1-u-boot.dtsi b/arch/arm/dts/imx6dl-wandboard-revd1-u-boot.dtsi new file mode 100644 index 000000000000..6785db754b79 --- /dev/null +++ b/arch/arm/dts/imx6dl-wandboard-revd1-u-boot.dtsi @@ -0,0 +1 @@ +#include "imx6qdl-wandboard-u-boot.dtsi" diff --git a/arch/arm/dts/imx6q-wandboard-revd1-u-boot.dtsi b/arch/arm/dts/imx6q-wandboard-revd1-u-boot.dtsi new file mode 100644 index 000000000000..6785db754b79 --- /dev/null +++ b/arch/arm/dts/imx6q-wandboard-revd1-u-boot.dtsi @@ -0,0 +1 @@ +#include "imx6qdl-wandboard-u-boot.dtsi" diff --git a/arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi b/arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi new file mode 100644 index 000000000000..46c4b3b31f4a --- /dev/null +++ b/arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include "imx6qdl-u-boot.dtsi" + +/ { + aliases { + mmc0 = &usdhc3; + }; +}; diff --git a/arch/arm/dts/imx6qp-wandboard-revd1-u-boot.dtsi b/arch/arm/dts/imx6qp-wandboard-revd1-u-boot.dtsi new file mode 100644 index 000000000000..6785db754b79 --- /dev/null +++ b/arch/arm/dts/imx6qp-wandboard-revd1-u-boot.dtsi @@ -0,0 +1 @@ +#include "imx6qdl-wandboard-u-boot.dtsi"
The conversion to DM_SERIAL is mandatory, so select this option.
Signed-off-by: Fabio Estevam festevam@denx.de --- configs/wandboard_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 70b4cf9ffaa3..33d9db56e1cb 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -72,6 +72,7 @@ CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC=y CONFIG_DM_PMIC_PFUZE100=y CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_DM_THERMAL=y CONFIG_USB=y
Fabio Estevam
