[U-Boot] [patch] socfpga: fix clock manager register definition
Structure defining clock manager hardware was wrong, leading to wrong registers being accessed and hang in MMC init.
This fixes structure to match hardware.
Signed-off-by: Pavel Machek pavel@denx.de
diff --git a/arch/arm/cpu/armv7/socfpga/clock_manager.c b/arch/arm/cpu/armv7/socfpga/clock_manager.c index 23d697d..0228ac8 100644 --- a/arch/arm/cpu/armv7/socfpga/clock_manager.c +++ b/arch/arm/cpu/armv7/socfpga/clock_manager.c @@ -110,8 +110,8 @@ void cm_basic_init(const cm_config_t *cfg) * gatting off the rest of the periperal clocks. */ writel(~CLKMGR_PERPLLGRP_EN_NANDCLK_MASK & - readl(&clock_manager_base->per_pll_en), - &clock_manager_base->per_pll_en); + readl(&clock_manager_base->per_pll.en), + &clock_manager_base->per_pll.en);
/* DO NOT GATE OFF DEBUG CLOCKS & BRIDGE CLOCKS */ writel(CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK | @@ -120,12 +120,12 @@ void cm_basic_init(const cm_config_t *cfg) CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK | CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK | CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK, - &clock_manager_base->main_pll_en); + &clock_manager_base->main_pll.en);
- writel(0, &clock_manager_base->sdr_pll_en); + writel(0, &clock_manager_base->sdr_pll.en);
/* now we can gate off the rest of the peripheral clocks */ - writel(0, &clock_manager_base->per_pll_en); + writel(0, &clock_manager_base->per_pll.en);
/* Put all plls in bypass */ cm_write_bypass( @@ -142,11 +142,11 @@ void cm_basic_init(const cm_config_t *cfg) * Some code might have messed with them. */ writel(CLKMGR_MAINPLLGRP_VCO_RESET_VALUE, - &clock_manager_base->main_pll_vco); + &clock_manager_base->main_pll.vco); writel(CLKMGR_PERPLLGRP_VCO_RESET_VALUE, - &clock_manager_base->per_pll_vco); + &clock_manager_base->per_pll.vco); writel(CLKMGR_SDRPLLGRP_VCO_RESET_VALUE, - &clock_manager_base->sdr_pll_vco); + &clock_manager_base->sdr_pll.vco);
/* * The clocks to the flash devices and the L4_MAIN clocks can @@ -156,14 +156,14 @@ void cm_basic_init(const cm_config_t *cfg) * after exiting safe mode but before ungating the clocks. */ writel(CLKMGR_PERPLLGRP_SRC_RESET_VALUE, - &clock_manager_base->per_pll_src); + &clock_manager_base->per_pll.src); writel(CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE, - &clock_manager_base->main_pll_l4src); + &clock_manager_base->main_pll.l4src);
/* read back for the required 5 us delay. */ - readl(&clock_manager_base->main_pll_vco); - readl(&clock_manager_base->per_pll_vco); - readl(&clock_manager_base->sdr_pll_vco); + readl(&clock_manager_base->main_pll.vco); + readl(&clock_manager_base->per_pll.vco); + readl(&clock_manager_base->sdr_pll.vco);
/* @@ -172,17 +172,17 @@ void cm_basic_init(const cm_config_t *cfg) */ writel(cfg->main_vco_base | CLEAR_BGP_EN_PWRDN | CLKMGR_MAINPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->main_pll_vco); + &clock_manager_base->main_pll.vco);
writel(cfg->peri_vco_base | CLEAR_BGP_EN_PWRDN | CLKMGR_PERPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->per_pll_vco); + &clock_manager_base->per_pll.vco);
writel(CLKMGR_SDRPLLGRP_VCO_OUTRESET_SET(0) | CLKMGR_SDRPLLGRP_VCO_OUTRESETALL_SET(0) | cfg->sdram_vco_base | CLEAR_BGP_EN_PWRDN | CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->sdr_pll_vco); + &clock_manager_base->sdr_pll.vco);
/* * Time starts here @@ -194,38 +194,38 @@ void cm_basic_init(const cm_config_t *cfg) timeout = 7;
/* main mpu */ - writel(cfg->mpuclk, &clock_manager_base->main_pll_mpuclk); + writel(cfg->mpuclk, &clock_manager_base->main_pll.mpuclk);
/* main main clock */ - writel(cfg->mainclk, &clock_manager_base->main_pll_mainclk); + writel(cfg->mainclk, &clock_manager_base->main_pll.mainclk);
/* main for dbg */ - writel(cfg->dbgatclk, &clock_manager_base->main_pll_dbgatclk); + writel(cfg->dbgatclk, &clock_manager_base->main_pll.dbgatclk);
/* main for cfgs2fuser0clk */ writel(cfg->cfg2fuser0clk, - &clock_manager_base->main_pll_cfgs2fuser0clk); + &clock_manager_base->main_pll.cfgs2fuser0clk);
/* Peri emac0 50 MHz default to RMII */ - writel(cfg->emac0clk, &clock_manager_base->per_pll_emac0clk); + writel(cfg->emac0clk, &clock_manager_base->per_pll.emac0clk);
/* Peri emac1 50 MHz default to RMII */ - writel(cfg->emac1clk, &clock_manager_base->per_pll_emac1clk); + writel(cfg->emac1clk, &clock_manager_base->per_pll.emac1clk);
/* Peri QSPI */ - writel(cfg->mainqspiclk, &clock_manager_base->main_pll_mainqspiclk); + writel(cfg->mainqspiclk, &clock_manager_base->main_pll.mainqspiclk);
- writel(cfg->perqspiclk, &clock_manager_base->per_pll_perqspiclk); + writel(cfg->perqspiclk, &clock_manager_base->per_pll.perqspiclk);
/* Peri pernandsdmmcclk */ writel(cfg->pernandsdmmcclk, - &clock_manager_base->per_pll_pernandsdmmcclk); + &clock_manager_base->per_pll.pernandsdmmcclk);
/* Peri perbaseclk */ - writel(cfg->perbaseclk, &clock_manager_base->per_pll_perbaseclk); + writel(cfg->perbaseclk, &clock_manager_base->per_pll.perbaseclk);
/* Peri s2fuser1clk */ - writel(cfg->s2fuser1clk, &clock_manager_base->per_pll_s2fuser1clk); + writel(cfg->s2fuser1clk, &clock_manager_base->per_pll.s2fuser1clk);
/* 7 us must have elapsed before we can enable the VCO */ while (get_timer(start) < timeout) @@ -234,29 +234,29 @@ void cm_basic_init(const cm_config_t *cfg) /* Enable vco */ /* main pll vco */ writel(cfg->main_vco_base | VCO_EN_BASE, - &clock_manager_base->main_pll_vco); + &clock_manager_base->main_pll.vco);
/* periferal pll */ writel(cfg->peri_vco_base | VCO_EN_BASE, - &clock_manager_base->per_pll_vco); + &clock_manager_base->per_pll.vco);
/* sdram pll vco */ writel(CLKMGR_SDRPLLGRP_VCO_OUTRESET_SET(0) | CLKMGR_SDRPLLGRP_VCO_OUTRESETALL_SET(0) | cfg->sdram_vco_base | VCO_EN_BASE, - &clock_manager_base->sdr_pll_vco); + &clock_manager_base->sdr_pll.vco);
/* L3 MP and L3 SP */ - writel(cfg->maindiv, &clock_manager_base->main_pll_maindiv); + writel(cfg->maindiv, &clock_manager_base->main_pll.maindiv);
- writel(cfg->dbgdiv, &clock_manager_base->main_pll_dbgdiv); + writel(cfg->dbgdiv, &clock_manager_base->main_pll.dbgdiv);
- writel(cfg->tracediv, &clock_manager_base->main_pll_tracediv); + writel(cfg->tracediv, &clock_manager_base->main_pll.tracediv);
/* L4 MP, L4 SP, can0, and can1 */ - writel(cfg->perdiv, &clock_manager_base->per_pll_div); + writel(cfg->perdiv, &clock_manager_base->per_pll.div);
- writel(cfg->gpiodiv, &clock_manager_base->per_pll_gpiodiv); + writel(cfg->gpiodiv, &clock_manager_base->per_pll.gpiodiv);
#define LOCKED_MASK \ (CLKMGR_INTER_SDRPLLLOCKED_MASK | \ @@ -267,70 +267,70 @@ void cm_basic_init(const cm_config_t *cfg)
/* write the sdram clock counters before toggling outreset all */ writel(cfg->ddrdqsclk & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK, - &clock_manager_base->sdr_pll_ddrdqsclk); + &clock_manager_base->sdr_pll.ddrdqsclk);
writel(cfg->ddr2xdqsclk & CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_MASK, - &clock_manager_base->sdr_pll_ddr2xdqsclk); + &clock_manager_base->sdr_pll.ddr2xdqsclk);
writel(cfg->ddrdqclk & CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_MASK, - &clock_manager_base->sdr_pll_ddrdqclk); + &clock_manager_base->sdr_pll.ddrdqclk);
writel(cfg->s2fuser2clk & CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_MASK, - &clock_manager_base->sdr_pll_s2fuser2clk); + &clock_manager_base->sdr_pll.s2fuser2clk);
/* * after locking, but before taking out of bypass * assert/deassert outresetall */ - uint32_t mainvco = readl(&clock_manager_base->main_pll_vco); + uint32_t mainvco = readl(&clock_manager_base->main_pll.vco);
/* assert main outresetall */ writel(mainvco | CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->main_pll_vco); + &clock_manager_base->main_pll.vco);
- uint32_t periphvco = readl(&clock_manager_base->per_pll_vco); + uint32_t periphvco = readl(&clock_manager_base->per_pll.vco);
/* assert pheriph outresetall */ writel(periphvco | CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->per_pll_vco); + &clock_manager_base->per_pll.vco);
/* assert sdram outresetall */ writel(cfg->sdram_vco_base | VCO_EN_BASE| CLKMGR_SDRPLLGRP_VCO_OUTRESETALL_SET(1), - &clock_manager_base->sdr_pll_vco); + &clock_manager_base->sdr_pll.vco);
/* deassert main outresetall */ writel(mainvco & ~CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->main_pll_vco); + &clock_manager_base->main_pll.vco);
/* deassert pheriph outresetall */ writel(periphvco & ~CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->per_pll_vco); + &clock_manager_base->per_pll.vco);
/* deassert sdram outresetall */ writel(CLKMGR_SDRPLLGRP_VCO_OUTRESETALL_SET(0) | cfg->sdram_vco_base | VCO_EN_BASE, - &clock_manager_base->sdr_pll_vco); + &clock_manager_base->sdr_pll.vco);
/* * now that we've toggled outreset all, all the clocks * are aligned nicely; so we can change any phase. */ cm_write_with_phase(cfg->ddrdqsclk, - (uint32_t)&clock_manager_base->sdr_pll_ddrdqsclk, + (uint32_t)&clock_manager_base->sdr_pll.ddrdqsclk, CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK);
/* SDRAM DDR2XDQSCLK */ cm_write_with_phase(cfg->ddr2xdqsclk, - (uint32_t)&clock_manager_base->sdr_pll_ddr2xdqsclk, + (uint32_t)&clock_manager_base->sdr_pll.ddr2xdqsclk, CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK);
cm_write_with_phase(cfg->ddrdqclk, - (uint32_t)&clock_manager_base->sdr_pll_ddrdqclk, + (uint32_t)&clock_manager_base->sdr_pll.ddrdqclk, CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK);
cm_write_with_phase(cfg->s2fuser2clk, - (uint32_t)&clock_manager_base->sdr_pll_s2fuser2clk, + (uint32_t)&clock_manager_base->sdr_pll.s2fuser2clk, CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK);
/* Take all three PLLs out of bypass when safe mode is cleared. */ @@ -351,11 +351,11 @@ void cm_basic_init(const cm_config_t *cfg) * now that safe mode is clear with clocks gated * it safe to change the source mux for the flashes the the L4_MAIN */ - writel(cfg->persrc, &clock_manager_base->per_pll_src); - writel(cfg->l4src, &clock_manager_base->main_pll_l4src); + writel(cfg->persrc, &clock_manager_base->per_pll.src); + writel(cfg->l4src, &clock_manager_base->main_pll.l4src);
/* Now ungate non-hw-managed clocks */ - writel(~0, &clock_manager_base->main_pll_en); - writel(~0, &clock_manager_base->per_pll_en); - writel(~0, &clock_manager_base->sdr_pll_en); + writel(~0, &clock_manager_base->main_pll.en); + writel(~0, &clock_manager_base->per_pll.en); + writel(~0, &clock_manager_base->sdr_pll.en); } diff --git a/arch/arm/include/asm/arch-socfpga/clock_manager.h b/arch/arm/include/asm/arch-socfpga/clock_manager.h index 966add3..babac0e 100644 --- a/arch/arm/include/asm/arch-socfpga/clock_manager.h +++ b/arch/arm/include/asm/arch-socfpga/clock_manager.h @@ -43,6 +43,52 @@ typedef struct {
extern void cm_basic_init(const cm_config_t *cfg);
+struct socfpga_clock_manager_main_pll { + u32 vco; + u32 misc; + u32 mpuclk; + u32 mainclk; + u32 dbgatclk; + u32 mainqspiclk; + u32 mainnandsdmmcclk; + u32 cfgs2fuser0clk; + u32 en; + u32 maindiv; + u32 dbgdiv; + u32 tracediv; + u32 l4src; + u32 stat; + u32 _pad_0x38_0x40[2]; +}; + +struct socfpga_clock_manager_per_pll { + u32 vco; + u32 misc; + u32 emac0clk; + u32 emac1clk; + u32 perqspiclk; + u32 pernandsdmmcclk; + u32 perbaseclk; + u32 s2fuser1clk; + u32 en; + u32 div; + u32 gpiodiv; + u32 src; + u32 stat; + u32 _pad_0x34_0x40[3]; +}; + +struct socfpga_clock_manager_sdr_pll { + u32 vco; + u32 ctrl; + u32 ddrdqsclk; + u32 ddr2xdqsclk; + u32 ddrdqclk; + u32 s2fuser2clk; + u32 en; + u32 stat; +}; + struct socfpga_clock_manager { u32 ctrl; u32 bypass; @@ -51,50 +97,10 @@ struct socfpga_clock_manager { u32 dbctrl; u32 stat; u32 _pad_0x18_0x3f[10]; - u32 mainpllgrp; - u32 perpllgrp; - u32 sdrpllgrp; + struct socfpga_clock_manager_main_pll main_pll; + struct socfpga_clock_manager_per_pll per_pll; + struct socfpga_clock_manager_sdr_pll sdr_pll; u32 _pad_0xe0_0x200[72]; - - u32 main_pll_vco; - u32 main_pll_misc; - u32 main_pll_mpuclk; - u32 main_pll_mainclk; - u32 main_pll_dbgatclk; - u32 main_pll_mainqspiclk; - u32 main_pll_mainnandsdmmcclk; - u32 main_pll_cfgs2fuser0clk; - u32 main_pll_en; - u32 main_pll_maindiv; - u32 main_pll_dbgdiv; - u32 main_pll_tracediv; - u32 main_pll_l4src; - u32 main_pll_stat; - u32 main_pll__pad_0x38_0x40[2]; - - u32 per_pll_vco; - u32 per_pll_misc; - u32 per_pll_emac0clk; - u32 per_pll_emac1clk; - u32 per_pll_perqspiclk; - u32 per_pll_pernandsdmmcclk; - u32 per_pll_perbaseclk; - u32 per_pll_s2fuser1clk; - u32 per_pll_en; - u32 per_pll_div; - u32 per_pll_gpiodiv; - u32 per_pll_src; - u32 per_pll_stat; - u32 per_pll__pad_0x34_0x40[3]; - - u32 sdr_pll_vco; - u32 sdr_pll_ctrl; - u32 sdr_pll_ddrdqsclk; - u32 sdr_pll_ddr2xdqsclk; - u32 sdr_pll_ddrdqclk; - u32 sdr_pll_s2fuser2clk; - u32 sdr_pll_en; - u32 sdr_pll_stat; };
#define CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK 0x00000200 diff --git a/drivers/mmc/socfpga_dw_mmc.c b/drivers/mmc/socfpga_dw_mmc.c index 1ed2081..747e08f 100644 --- a/drivers/mmc/socfpga_dw_mmc.c +++ b/drivers/mmc/socfpga_dw_mmc.c @@ -26,7 +26,7 @@ static void socfpga_dwmci_clksel(struct dwmci_host *host) unsigned int smplsel;
/* Disable SDMMC clock. */ - clrbits_le32(&clock_manager_base->per_pll_en, + clrbits_le32(&clock_manager_base->per_pll.en, CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK);
/* Configures drv_sel and smpl_sel */ @@ -41,7 +41,7 @@ static void socfpga_dwmci_clksel(struct dwmci_host *host) readl(&system_manager_base->sdmmcgrp_ctrl));
/* Enable SDMMC clock */ - setbits_le32(&clock_manager_base->per_pll_en, + setbits_le32(&clock_manager_base->per_pll.en, CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK); }
clrbits_le32() please ... and please fix globally. [...] Best regards, Marek Vasut
But that's clearly something for separate patch, so I'd still like your ack on this one :-). Pavel
I cannot ACK a patch for hardware which I don't understand enough. Still, you're already messing with the register layout, feel free to do a two-part patchset, but please use the clrsetbits_le32() ...
Hi!
Thanks for taking the patches, but where can I see the resulting tree?
u-boot/master should be http://git.denx.de/?p=u-boot.git;a=summary, that seems to have 6defdc0b5552ab1af4a66a8abac8196cbb6b9e15 as current version.
pavel@amd:~/wagabuibui/u-boot$ git log 6defdc0b5552ab1af4a66a8abac8196cbb6b9e15 | grep "This fixes structure to match hardware." pavel@amd:~/wagabuibui/u-boot$ git show 6defdc0b5552ab1af4a66a8abac8196cbb6b9e15 commit 6defdc0b5552ab1af4a66a8abac8196cbb6b9e15 Merge: 8f005b3 b640b46 Author: Tom Rini trini@ti.com Date: Fri Aug 29 13:47:42 2014 -0400
Merge branch 'master' of git://git.denx.de/u-boot-ti
Do I need to wait for a push?
Thanks, Pavel
Pavel Machek
