[U-Boot] installing linux only (not crouton) on HP Chromebook 11
Hello!
I own a couple HP Chromebook 11's, model SPRING-G3A-B3S-Q2F, the kind which only charge from the micro usb. I would like to erase ChromeOS and install only Linux. Is this possible?
I've already installed Ubuntu via crouton, but I am curious if it is possible to lose the ChromeOS altogether. I have tried this script from John Lewis: https://johnlewis.ie/custom-chromebook-firmware/rom-download/
However, I believe because the HP CB11 uses the U-Boot bios, this script is not compatible.
Any other options? If not that's ok ... they were cheap :) Thank you!
Hello Sean,
On Fri, Feb 3, 2017 at 8:26 AM, Sean Felipe Wolfe stjohnskid@gmail.com wrote:
Hello!
Yes it is possible. Remember to create spi chip backup first, as chromebooks contain device specific data in some partitions. [1]
Any other options? If not that's ok ... they were cheap :) Thank you! ____________________
Before fully replacing factory bootloader with mainline, imho better to start with chainloading mainline U-Boot from SD card, this requires only to enable developer mode [2]
Chainloaded U-Boot will boot linux from SD card or USB flash, check for example Arch Linux for Samsung Chromebook ARM [3]
[1] https://www.chromium.org/a/chromium.org/dev/chromium-os/developer-informatio... [2] https://www.chromium.org/a/chromium.org/dev/chromium-os/developer-informatio... [3] https://archlinuxarm.org/platforms/armv7/samsung/samsung-chromebook#wiki ___________________________
Misha Komarovskiy
Sean Felipe Wolfe
