[U-Boot] yaffs2 u-boot patching support
Hello ubooters and yaffsers
I was commissioned to refresh yaffs2 in u-boot and add a mechanism to support dynamic yaffs partition set up (way simpler than screwing around with mtd part) and manual configuration.
Rather than do this as a once off, I set this scripting up so that this can be done at any time (painlessly I hope) to bring in the fresh code (as per Linux patching).
Basically...
Get latest from yaffs git.
cd yaffs2-dir/direct/u-boot
./patch-u-boot.sh uboot-dir
Edit your u-boot config file and add
#define CONFIG_YAFFS2 1
Rebuild u-boot (mrproper probably a Good Idea). Job done.
OK, so how does the new dynamic partition stuff work?
There are 2 new commands: ydevconfig configures a mount point "partition" and ydevls lists the mount points and their state
So for example let us say we want a mount point called foo on NAND device 0 starting at block 55 and ending at block 999.
ydevconfig foo 0 55 999
Now you want to mount it.
ymount foo
Access files and do stuff...
yls foo yls -l foo # more info ymkdir foo/dir ...
You can have multiple mountpoints in use at the same time though they are not allowed to overlap.
inband tags is selected automatically if there is insufficient space in oobavail to store the tags.
Have fun.
Charles
Just to put this out there, if you're not submitting patches to get the code into git, should the current support in-tree be removed?
I think it is worth having yaffs in the main code base, but not the old stuff.
The primary reason to have a "patch-in" script is to allow people to refresh the yaffs they are using in a pretty painless way.
-- Charles
OK, but why not just update mainline? When you posted the original message, the next branch of master was open. Today master is open. I'm pretty sure that a pull request from the yaffs2 maintainers to update the codebase would be accepted if it's self contained to fs/yaffs2 and reviewed if it touches stuff outside. This isn't the old days... Thanks!
Hi Charles,
Well, why do not push your patches directly to ML ? This increases surely the number of testers, and after ypur patches will be merged thare is not need for external scripts.
Stefano
Hi Charles,
I have sent a pull request to the list. https://github.com/cdhmanning/u-boot-yaffs2
-- CHarles
Charles Manning
Stefano Babic
