[U-Boot] [PATCH 00/11] ARM: uniphier: recond round of UniPhier updates for v2017.03
- Make SPL optional for ARMv8 SoCs (main motivation is to use ATF) - Refactor SoC init code - Add PXs3 SoC support (DT, pinctrl driver, SoC code)
Masahiro Yamada (11): ARM: uniphier: add missing static and const qualifier ARM: uniphier: make SPL optional for ARVv8 SoCs ARM: uniphier: add uniphier_v8_defconfig ARM: uniphier: replace <linux/err.h> with <linux/errno.h> ARM: uniphier: replace <common.h> with <linux/delay.h> where possible ARM: uniphier: simplify SoC ID get function ARM: uniphier: add macro to generate SoC data look-up function ARM: dts: uniphier: compile only DT files that make sense pinctrl: uniphier: support UniPhier PXs3 pinctrl driver ARM: dts: uniphier: add PXs3 SoC/board support ARM: uniphier: add PXs3 SoC support
arch/arm/Kconfig | 11 +- arch/arm/dts/Makefile | 29 +- arch/arm/dts/uniphier-pxs3-ref.dts | 51 ++++ arch/arm/dts/uniphier-pxs3.dtsi | 328 ++++++++++++++++++++++ arch/arm/mach-uniphier/Kconfig | 54 ++-- arch/arm/mach-uniphier/Makefile | 4 +- arch/arm/mach-uniphier/arm32/psci.c | 12 +- arch/arm/mach-uniphier/arm64/Makefile | 5 +- arch/arm/mach-uniphier/board_init.c | 57 ++-- arch/arm/mach-uniphier/boot-mode/boot-mode-ld20.c | 6 +- arch/arm/mach-uniphier/boot-mode/boot-mode.c | 32 +-- arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c | 20 +- arch/arm/mach-uniphier/boot-mode/spl_board.c | 6 +- arch/arm/mach-uniphier/clk/Makefile | 1 + arch/arm/mach-uniphier/clk/dpll-ld4.c | 2 +- arch/arm/mach-uniphier/clk/dpll-pro4.c | 2 +- arch/arm/mach-uniphier/clk/dpll-sld8.c | 2 +- arch/arm/mach-uniphier/clk/pll-base-ld20.c | 3 +- arch/arm/mach-uniphier/clk/pll-ld4.c | 2 +- arch/arm/mach-uniphier/clk/pll-pro4.c | 2 +- arch/arm/mach-uniphier/clk/pll-pxs3.c | 7 + arch/arm/mach-uniphier/cpu-info.c | 76 +++++ arch/arm/mach-uniphier/cpu_info.c | 73 ----- arch/arm/mach-uniphier/debug-uart/debug-uart.c | 20 +- arch/arm/mach-uniphier/dram/cmd_ddrphy.c | 10 +- arch/arm/mach-uniphier/dram/ddrphy-ld4.c | 2 +- arch/arm/mach-uniphier/dram/ddrphy-training.c | 2 +- arch/arm/mach-uniphier/dram/umc-ld20.c | 3 +- arch/arm/mach-uniphier/dram/umc-ld4.c | 2 +- arch/arm/mach-uniphier/dram/umc-pro4.c | 2 +- arch/arm/mach-uniphier/dram/umc-pxs2.c | 2 +- arch/arm/mach-uniphier/dram/umc-sld8.c | 2 +- arch/arm/mach-uniphier/dram_init.c | 4 +- arch/arm/mach-uniphier/init.h | 1 + arch/arm/mach-uniphier/memconf.c | 2 +- arch/arm/mach-uniphier/pinctrl-glue.c | 2 +- arch/arm/mach-uniphier/sbc/Makefile | 1 + arch/arm/mach-uniphier/sg-regs.h | 6 - arch/arm/mach-uniphier/soc-info.c | 34 +++ arch/arm/mach-uniphier/soc-info.h | 103 +++---- arch/arm/mach-uniphier/soc_info.c | 84 ------ arch/arm/mach-uniphier/spl_board_init.c | 38 +-- configs/uniphier_ld11_defconfig | 3 +- configs/uniphier_ld20_defconfig | 3 +- configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_pro4_defconfig | 1 + configs/uniphier_pxs2_ld6b_defconfig | 1 + configs/uniphier_sld3_defconfig | 1 + configs/uniphier_v8_defconfig | 34 +++ doc/README.uniphier | 4 + drivers/pinctrl/uniphier/Kconfig | 24 +- drivers/pinctrl/uniphier/Makefile | 1 + drivers/pinctrl/uniphier/pinctrl-uniphier-pxs3.c | 140 +++++++++ include/configs/uniphier.h | 6 +- 54 files changed, 918 insertions(+), 406 deletions(-) create mode 100644 arch/arm/dts/uniphier-pxs3-ref.dts create mode 100644 arch/arm/dts/uniphier-pxs3.dtsi create mode 100644 arch/arm/mach-uniphier/clk/pll-pxs3.c create mode 100644 arch/arm/mach-uniphier/cpu-info.c delete mode 100644 arch/arm/mach-uniphier/cpu_info.c create mode 100644 arch/arm/mach-uniphier/soc-info.c delete mode 100644 arch/arm/mach-uniphier/soc_info.c create mode 100644 configs/uniphier_v8_defconfig create mode 100644 drivers/pinctrl/uniphier/pinctrl-uniphier-pxs3.c
These are file-internal and constant.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/board_init.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_init.c b/arch/arm/mach-uniphier/board_init.c index 93330b0..8233a52 100644 --- a/arch/arm/mach-uniphier/board_init.c +++ b/arch/arm/mach-uniphier/board_init.c @@ -87,7 +87,7 @@ struct uniphier_initdata { void (*misc_init)(void); };
-struct uniphier_initdata uniphier_initdata[] = { +static const struct uniphier_initdata uniphier_initdata[] = { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) { .soc_id = SOC_UNIPHIER_SLD3, @@ -169,7 +169,7 @@ struct uniphier_initdata uniphier_initdata[] = { #endif };
-static struct uniphier_initdata *uniphier_get_initdata( +static const struct uniphier_initdata *uniphier_get_initdata( enum uniphier_soc_id soc_id) { int i; @@ -184,7 +184,7 @@ static struct uniphier_initdata *uniphier_get_initdata(
int board_init(void) { - struct uniphier_initdata *initdata; + const struct uniphier_initdata *initdata; enum uniphier_soc_id soc_id; int ret;
We may want to run different firmware before running U-Boot. For example, ARM Trusted Firmware runs before U-Boot, making U-Boot a non-secure world boot loader. In this case, the SoC might be initialized there, which enables us to skip SPL entirely.
This commit removes "select SPL" to make it configurable. This also enables the Multi SoC support for the UniPhier ARMv8 SoCs. (CONFIG_ARCH_UNIPHIER_V8_MULTI) Thanks to the driver model and Device Tree, the U-Boot proper part is now written in a generic way. The board/SoC parameters reside in DT. The Multi SoC support increases the memory footprint a bit, but the U-Boot proper does not have strict memory constraint. This will mitigate the per-SoC (sometimes per-board) defconfig burden.
arch/arm/Kconfig | 11 ++++---- arch/arm/mach-uniphier/Kconfig | 49 +++++++++++++++++++++++------------ arch/arm/mach-uniphier/arm64/Makefile | 5 +++- arch/arm/mach-uniphier/board_init.c | 5 ++-- configs/uniphier_ld11_defconfig | 3 ++- configs/uniphier_ld20_defconfig | 3 ++- configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_pro4_defconfig | 1 + configs/uniphier_pxs2_ld6b_defconfig | 1 + configs/uniphier_sld3_defconfig | 1 + include/configs/uniphier.h | 6 +++-- 11 files changed, 56 insertions(+), 30 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 855871c..2554a2c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -894,12 +894,11 @@ config ARCH_UNIPHIER select OF_CONTROL select OF_LIBFDT select PINCTRL - select SPL - select SPL_DM - select SPL_LIBCOMMON_SUPPORT - select SPL_LIBGENERIC_SUPPORT - select SPL_OF_CONTROL - select SPL_PINCTRL + select SPL_DM if SPL + select SPL_LIBCOMMON_SUPPORT if SPL + select SPL_LIBGENERIC_SUPPORT if SPL + select SPL_OF_CONTROL if SPL + select SPL_PINCTRL if SPL select SUPPORT_SPL help Support for UniPhier SoC family developed by Socionext Inc. diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index aa3909a..e732ac1 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -13,66 +13,81 @@ config ARCH_UNIPHIER_32BIT config ARCH_UNIPHIER_64BIT bool select ARM64 - select SPL_SEPARATE_BSS - select ARMV8_MULTIENTRY - select ARMV8_SPIN_TABLE + select SPL_SEPARATE_BSS if SPL + select ARMV8_MULTIENTRY if SPL + select ARMV8_SPIN_TABLE if SPL
choice prompt "UniPhier SoC select" default ARCH_UNIPHIER_PRO4
config ARCH_UNIPHIER_SLD3 - bool "UniPhier PH1-sLD3 SoC" + bool "UniPhier sLD3 SoC" select ARCH_UNIPHIER_32BIT
config ARCH_UNIPHIER_LD4_SLD8 - bool "UniPhier PH1-LD4/PH1-sLD8 SoC" + bool "UniPhier LD4/sLD8 SoCs" select ARCH_UNIPHIER_32BIT
config ARCH_UNIPHIER_PRO4 - bool "UniPhier PH1-Pro4 SoC" + bool "UniPhier Pro4 SoC" select ARCH_UNIPHIER_32BIT
config ARCH_UNIPHIER_PRO5_PXS2_LD6B - bool "UniPhier PH1-Pro5/ProXstream2/PH1-LD6b SoC" + bool "UniPhier Pro5/PXs2/LD6b SoCs" select ARCH_UNIPHIER_32BIT
-config ARCH_UNIPHIER_LD11 - bool "UniPhier PH1-LD11 SoC" +config ARCH_UNIPHIER_LD11_SINGLE + bool "UniPhier LD11 SoC" select ARCH_UNIPHIER_64BIT
-config ARCH_UNIPHIER_LD20 - bool "UniPhier PH1-LD20 SoC" +config ARCH_UNIPHIER_LD20_SINGLE + bool "UniPhier LD20 SoC" + select ARCH_UNIPHIER_64BIT + +config ARCH_UNIPHIER_V8_MULTI + bool "UniPhier V8 SoCs" + depends on !SPL select ARCH_UNIPHIER_64BIT - select OF_BOARD_SETUP
endchoice
config ARCH_UNIPHIER_LD4 - bool "Enable UniPhier PH1-LD4 SoC support" + bool "Enable UniPhier LD4 SoC support" depends on ARCH_UNIPHIER_LD4_SLD8 default y
config ARCH_UNIPHIER_SLD8 - bool "Enable UniPhier PH1-sLD8 SoC support" + bool "Enable UniPhier sLD8 SoC support" depends on ARCH_UNIPHIER_LD4_SLD8 default y
config ARCH_UNIPHIER_PRO5 - bool "Enable UniPhier PH1-Pro5 SoC support" + bool "Enable UniPhier Pro5 SoC support" depends on ARCH_UNIPHIER_PRO5_PXS2_LD6B default y
config ARCH_UNIPHIER_PXS2 - bool "Enable UniPhier ProXstream2 SoC support" + bool "Enable UniPhier Pxs2 SoC support" depends on ARCH_UNIPHIER_PRO5_PXS2_LD6B default y
config ARCH_UNIPHIER_LD6B - bool "Enable UniPhier PH1-LD6b SoC support" + bool "Enable UniPhier LD6b SoC support" depends on ARCH_UNIPHIER_PRO5_PXS2_LD6B default y
+config ARCH_UNIPHIER_LD11 + bool "Enable UniPhier LD11 SoC support" if ARCH_UNIPHIER_V8_MULTI + depends on ARCH_UNIPHIER_LD11_SINGLE || ARCH_UNIPHIER_V8_MULTI + default y + +config ARCH_UNIPHIER_LD20 + bool "Enable UniPhier LD20 SoC support" if ARCH_UNIPHIER_V8_MULTI + depends on ARCH_UNIPHIER_LD20_SINGLE || ARCH_UNIPHIER_V8_MULTI + select OF_BOARD_SETUP + default y + config CACHE_UNIPHIER bool "Enable the UniPhier L2 cache controller" depends on ARCH_UNIPHIER_32BIT diff --git a/arch/arm/mach-uniphier/arm64/Makefile b/arch/arm/mach-uniphier/arm64/Makefile index 5ed030a..eb34c20 100644 --- a/arch/arm/mach-uniphier/arm64/Makefile +++ b/arch/arm/mach-uniphier/arm64/Makefile @@ -5,6 +5,9 @@ ifdef CONFIG_SPL_BUILD obj-y += timer.o else -obj-y += mem_map.o smp.o smp_kick_cpus.o +obj-y += mem_map.o +ifdef CONFIG_ARMV8_MULTIENTRY +obj-y += smp.o smp_kick_cpus.o obj-$(CONFIG_ARCH_UNIPHIER_LD20) += arm-cci500.o endif +endif diff --git a/arch/arm/mach-uniphier/board_init.c b/arch/arm/mach-uniphier/board_init.c index 8233a52..2269291 100644 --- a/arch/arm/mach-uniphier/board_init.c +++ b/arch/arm/mach-uniphier/board_init.c @@ -73,8 +73,9 @@ static void uniphier_ld20_misc_init(void) writel(0x0000b500, 0x6184e024); writel(0x00000001, 0x6184e000); } - +#ifdef CONFIG_ARMV8_MULTIENTRY cci500_init(2); +#endif } #endif
@@ -235,7 +236,7 @@ int board_init(void)
led_puts("U6");
-#ifdef CONFIG_ARM64 +#ifdef CONFIG_ARMV8_MULTIENTRY uniphier_smp_kick_all_cpus(); #endif
diff --git a/configs/uniphier_ld11_defconfig b/configs/uniphier_ld11_defconfig index 9c77b10..deddac4 100644 --- a/configs/uniphier_ld11_defconfig +++ b/configs/uniphier_ld11_defconfig @@ -2,11 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_UNIPHIER=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_ARCH_UNIPHIER_LD11=y +CONFIG_ARCH_UNIPHIER_LD11_SINGLE=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld11-ref" # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_XIMG is not set diff --git a/configs/uniphier_ld20_defconfig b/configs/uniphier_ld20_defconfig index 190ebd5..272304f 100644 --- a/configs/uniphier_ld20_defconfig +++ b/configs/uniphier_ld20_defconfig @@ -2,11 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_UNIPHIER=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_ARCH_UNIPHIER_LD20=y +CONFIG_ARCH_UNIPHIER_LD20_SINGLE=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld20-ref" # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_XIMG is not set diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 8391a0a..dad0a34 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -9,6 +9,7 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld4-ref" # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/uniphier_pro4_defconfig b/configs/uniphier_pro4_defconfig index c8a7573..36f9743 100644 --- a/configs/uniphier_pro4_defconfig +++ b/configs/uniphier_pro4_defconfig @@ -8,6 +8,7 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-pro4-ref" # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/uniphier_pxs2_ld6b_defconfig b/configs/uniphier_pxs2_ld6b_defconfig index 560b11b..5e3b044 100644 --- a/configs/uniphier_pxs2_ld6b_defconfig +++ b/configs/uniphier_pxs2_ld6b_defconfig @@ -9,6 +9,7 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-pxs2-vodka" # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/uniphier_sld3_defconfig b/configs/uniphier_sld3_defconfig index 7e30acc..29f43cd 100644 --- a/configs/uniphier_sld3_defconfig +++ b/configs/uniphier_sld3_defconfig @@ -9,6 +9,7 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-sld3-ref" # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 74f1373..bf4cfea 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -85,7 +85,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1
-#ifdef CONFIG_ARM64 +#ifdef CONFIG_ARMV8_MULTIENTRY #define CPU_RELEASE_ADDR 0x80000000 #define COUNTER_FREQUENCY 50000000 #define CONFIG_GICV3 @@ -95,7 +95,7 @@ #elif defined(CONFIG_ARCH_UNIPHIER_LD20) #define GICR_BASE 0x5fe80000 #endif -#else +#elif !defined(CONFIG_ARM64) /* Time clock 1MHz */ #define CONFIG_SYS_TIMER_RATE 1000000 #endif @@ -276,6 +276,7 @@ /* subtract sizeof(struct image_header) */ #define CONFIG_SYS_UBOOT_BASE (0x60000 - 0x40)
+#ifdef CONFIG_SPL #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_MAX_FOOTPRINT 0x10000 #define CONFIG_SPL_MAX_SIZE 0x10000 @@ -285,5 +286,6 @@ #define CONFIG_SPL_BSS_START_ADDR 0x30016000 #endif #define CONFIG_SPL_BSS_MAX_SIZE 0x2000 +#endif
#endif /* __CONFIG_UNIPHIER_COMMON_H__ */
This defconfig does not support SPL. If you use this, the basic SoC initialization must be done in firmware that runs before U-Boot. (Generally, ARM Trusted Firmware is expected to do this job).
configs/uniphier_v8_defconfig | 34 ++++++++++++++++++++++++++++++++++ 1 file changed, 34 insertions(+) create mode 100644 configs/uniphier_v8_defconfig
diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig new file mode 100644 index 0000000..d02b84e --- /dev/null +++ b/configs/uniphier_v8_defconfig @@ -0,0 +1,34 @@ +CONFIG_ARM=y +CONFIG_ARCH_UNIPHIER=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ARCH_UNIPHIER_V8_MULTI=y +CONFIG_MICRO_SUPPORT_CARD=y +CONFIG_SYS_TEXT_BASE=0x84000000 +CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld20-ref" +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +# CONFIG_CMD_MISC is not set +CONFIG_CMD_FAT=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_GPIO_UNIPHIER=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_MMC_UNIPHIER=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_CADENCE=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3_UNIPHIER=y +CONFIG_USB_STORAGE=y
These files only need error number macros. Actually, IS_ERR(), PTR_ERR(), ERR_PTR(), etc. are not useful for U-Boot. Avoid unnecessary header includes.
arch/arm/mach-uniphier/boot-mode/boot-mode.c | 2 +- arch/arm/mach-uniphier/clk/dpll-ld4.c | 2 +- arch/arm/mach-uniphier/clk/dpll-pro4.c | 2 +- arch/arm/mach-uniphier/dram/ddrphy-ld4.c | 2 +- arch/arm/mach-uniphier/dram/ddrphy-training.c | 2 +- arch/arm/mach-uniphier/dram/umc-ld20.c | 3 ++- arch/arm/mach-uniphier/dram/umc-ld4.c | 2 +- arch/arm/mach-uniphier/dram/umc-pro4.c | 2 +- arch/arm/mach-uniphier/dram/umc-pxs2.c | 2 +- arch/arm/mach-uniphier/dram/umc-sld8.c | 2 +- arch/arm/mach-uniphier/dram_init.c | 2 +- arch/arm/mach-uniphier/memconf.c | 2 +- arch/arm/mach-uniphier/pinctrl-glue.c | 2 +- 13 files changed, 14 insertions(+), 13 deletions(-)
diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode.c b/arch/arm/mach-uniphier/boot-mode/boot-mode.c index 1d53140..ebe0578 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode.c @@ -7,7 +7,7 @@ #include <common.h> #include <mmc.h> #include <spl.h> -#include <linux/err.h> +#include <linux/errno.h>
#include "../sbc/sbc-regs.h" #include "../soc-info.h" diff --git a/arch/arm/mach-uniphier/clk/dpll-ld4.c b/arch/arm/mach-uniphier/clk/dpll-ld4.c index a40b30d..56361ff 100644 --- a/arch/arm/mach-uniphier/clk/dpll-ld4.c +++ b/arch/arm/mach-uniphier/clk/dpll-ld4.c @@ -6,7 +6,7 @@ */
#include <common.h> -#include <linux/err.h> +#include <linux/errno.h> #include <linux/io.h>
#include "../init.h" diff --git a/arch/arm/mach-uniphier/clk/dpll-pro4.c b/arch/arm/mach-uniphier/clk/dpll-pro4.c index 3ac48d6..d6b6262 100644 --- a/arch/arm/mach-uniphier/clk/dpll-pro4.c +++ b/arch/arm/mach-uniphier/clk/dpll-pro4.c @@ -6,7 +6,7 @@ */
#include "../init.h" diff --git a/arch/arm/mach-uniphier/dram/ddrphy-ld4.c b/arch/arm/mach-uniphier/dram/ddrphy-ld4.c index 620668e..c20730d 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-ld4.c +++ b/arch/arm/mach-uniphier/dram/ddrphy-ld4.c @@ -6,7 +6,7 @@ */
#include "ddrphy-init.h" diff --git a/arch/arm/mach-uniphier/dram/ddrphy-training.c b/arch/arm/mach-uniphier/dram/ddrphy-training.c index 005ca18..fa29a43 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-training.c +++ b/arch/arm/mach-uniphier/dram/ddrphy-training.c @@ -6,7 +6,7 @@ */
#include "ddrphy-init.h" diff --git a/arch/arm/mach-uniphier/dram/umc-ld20.c b/arch/arm/mach-uniphier/dram/umc-ld20.c index df6cc01..61f62ae 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld20.c +++ b/arch/arm/mach-uniphier/dram/umc-ld20.c @@ -8,7 +8,8 @@
#include <common.h> #include <linux/bitops.h> -#include <linux/err.h> +#include <linux/compat.h> +#include <linux/errno.h> #include <linux/io.h> #include <linux/sizes.h> #include <asm/processor.h> diff --git a/arch/arm/mach-uniphier/dram/umc-ld4.c b/arch/arm/mach-uniphier/dram/umc-ld4.c index 90e7f2d..06aa054 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld4.c +++ b/arch/arm/mach-uniphier/dram/umc-ld4.c @@ -7,7 +7,7 @@ */
#include <common.h> -#include <linux/err.h> +#include <linux/errno.h> #include <linux/io.h> #include <linux/sizes.h> #include <asm/processor.h> diff --git a/arch/arm/mach-uniphier/dram/umc-pro4.c b/arch/arm/mach-uniphier/dram/umc-pro4.c index 5447fa9..740247a 100644 --- a/arch/arm/mach-uniphier/dram/umc-pro4.c +++ b/arch/arm/mach-uniphier/dram/umc-pro4.c @@ -7,7 +7,7 @@ */
#include <common.h> -#include <linux/err.h> +#include <linux/errno.h> #include <linux/io.h> #include <linux/sizes.h> #include <asm/processor.h> diff --git a/arch/arm/mach-uniphier/dram/umc-pxs2.c b/arch/arm/mach-uniphier/dram/umc-pxs2.c index b4da3d2..90465dd 100644 --- a/arch/arm/mach-uniphier/dram/umc-pxs2.c +++ b/arch/arm/mach-uniphier/dram/umc-pxs2.c @@ -8,7 +8,7 @@ */
#include <common.h> -#include <linux/err.h> +#include <linux/errno.h> #include <linux/io.h> #include <linux/sizes.h> #include <asm/processor.h> diff --git a/arch/arm/mach-uniphier/dram/umc-sld8.c b/arch/arm/mach-uniphier/dram/umc-sld8.c index 61369f1..a0c2871 100644 --- a/arch/arm/mach-uniphier/dram/umc-sld8.c +++ b/arch/arm/mach-uniphier/dram/umc-sld8.c @@ -7,7 +7,7 @@ */
#include <common.h> -#include <linux/err.h> +#include <linux/errno.h> #include <linux/io.h> #include <linux/sizes.h> #include <asm/processor.h> diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index 489366c..87418f4 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -7,7 +7,7 @@ #include <common.h> #include <libfdt.h> #include <fdtdec.h> -#include <linux/err.h> +#include <linux/errno.h>
#include "init.h" #include "soc-info.h" diff --git a/arch/arm/mach-uniphier/memconf.c b/arch/arm/mach-uniphier/memconf.c index 205ccf1..dcfc645 100644 --- a/arch/arm/mach-uniphier/memconf.c +++ b/arch/arm/mach-uniphier/memconf.c @@ -7,7 +7,7 @@ */
diff --git a/arch/arm/mach-uniphier/pinctrl-glue.c b/arch/arm/mach-uniphier/pinctrl-glue.c index 48549e3..c52c6a6 100644 --- a/arch/arm/mach-uniphier/pinctrl-glue.c +++ b/arch/arm/mach-uniphier/pinctrl-glue.c @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include <linux/err.h> +#include <linux/errno.h> #include <dm/device.h> #include <dm/pinctrl.h> #include <dm/uclass.h>
The <common.h> includes too many headers. Actually, these files needed to include it for udelay() declaration. Now we can replace it with <linux/delay.h> thanks to commit 5bc516ed661a ("delay: collect {m, n, u}delay declarations to include/linux/delay.h").
arch/arm/mach-uniphier/clk/dpll-sld8.c | 2 +- arch/arm/mach-uniphier/clk/pll-base-ld20.c | 3 ++- arch/arm/mach-uniphier/clk/pll-ld4.c | 2 +- arch/arm/mach-uniphier/clk/pll-pro4.c | 2 +- 4 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-uniphier/clk/dpll-sld8.c b/arch/arm/mach-uniphier/clk/dpll-sld8.c index 7faa5e8..4a0010b 100644 --- a/arch/arm/mach-uniphier/clk/dpll-sld8.c +++ b/arch/arm/mach-uniphier/clk/dpll-sld8.c @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include <common.h> +#include <linux/delay.h> #include <linux/io.h>
#include "../init.h" diff --git a/arch/arm/mach-uniphier/clk/pll-base-ld20.c b/arch/arm/mach-uniphier/clk/pll-base-ld20.c index caa631d..c66f083 100644 --- a/arch/arm/mach-uniphier/clk/pll-base-ld20.c +++ b/arch/arm/mach-uniphier/clk/pll-base-ld20.c @@ -5,8 +5,9 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include <common.h> #include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/errno.h> #include <linux/io.h> #include <linux/sizes.h>
diff --git a/arch/arm/mach-uniphier/clk/pll-ld4.c b/arch/arm/mach-uniphier/clk/pll-ld4.c index 13257e4..55ac0ae 100644 --- a/arch/arm/mach-uniphier/clk/pll-ld4.c +++ b/arch/arm/mach-uniphier/clk/pll-ld4.c @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
#include "../init.h" diff --git a/arch/arm/mach-uniphier/clk/pll-pro4.c b/arch/arm/mach-uniphier/clk/pll-pro4.c index cdd1fd4..e4d1f72 100644 --- a/arch/arm/mach-uniphier/clk/pll-pro4.c +++ b/arch/arm/mach-uniphier/clk/pll-pro4.c @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
Currently, uniphier_get_soc_type() converts the SoC ID (this is read from the revision register) to an enum symbol to use it for SoC identification. Come to think of it, there is no need for the conversion in the first place. Using the SoC ID from the register as-is a straightforward way.
arch/arm/mach-uniphier/Makefile | 4 +- arch/arm/mach-uniphier/arm32/psci.c | 12 ++-- arch/arm/mach-uniphier/board_init.c | 26 +++---- arch/arm/mach-uniphier/boot-mode/boot-mode-ld20.c | 6 +- arch/arm/mach-uniphier/boot-mode/boot-mode.c | 30 ++++---- arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c | 20 +++--- arch/arm/mach-uniphier/boot-mode/spl_board.c | 6 +- arch/arm/mach-uniphier/cpu-info.c | 73 +++++++++++++++++++ arch/arm/mach-uniphier/cpu_info.c | 73 ------------------- arch/arm/mach-uniphier/debug-uart/debug-uart.c | 20 +++--- arch/arm/mach-uniphier/dram/cmd_ddrphy.c | 10 +-- arch/arm/mach-uniphier/dram_init.c | 2 +- arch/arm/mach-uniphier/sg-regs.h | 6 -- arch/arm/mach-uniphier/soc-info.c | 34 +++++++++ arch/arm/mach-uniphier/soc-info.h | 88 +++++------------------ arch/arm/mach-uniphier/soc_info.c | 84 ---------------------- arch/arm/mach-uniphier/spl_board_init.c | 26 +++---- 17 files changed, 206 insertions(+), 314 deletions(-) create mode 100644 arch/arm/mach-uniphier/cpu-info.c delete mode 100644 arch/arm/mach-uniphier/cpu_info.c create mode 100644 arch/arm/mach-uniphier/soc-info.c delete mode 100644 arch/arm/mach-uniphier/soc_info.c
diff --git a/arch/arm/mach-uniphier/Makefile b/arch/arm/mach-uniphier/Makefile index ab2c6dc..abfdccc 100644 --- a/arch/arm/mach-uniphier/Makefile +++ b/arch/arm/mach-uniphier/Makefile @@ -10,7 +10,7 @@ obj-y += bcu/
else
-obj-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o +obj-$(CONFIG_DISPLAY_CPUINFO) += cpu-info.o obj-y += dram_init.o obj-y += board_init.o obj-$(CONFIG_BOARD_LATE_INIT) += board_late_init.o @@ -22,7 +22,7 @@ obj-y += pinctrl-glue.o endif
obj-y += boards.o -obj-y += soc_info.o +obj-y += soc-info.o obj-y += boot-mode/ obj-y += clk/ obj-y += dram/ diff --git a/arch/arm/mach-uniphier/arm32/psci.c b/arch/arm/mach-uniphier/arm32/psci.c index e668265..65a468d 100644 --- a/arch/arm/mach-uniphier/arm32/psci.c +++ b/arch/arm/mach-uniphier/arm32/psci.c @@ -28,13 +28,13 @@ u32 uniphier_smp_booted[CONFIG_ARMV7_PSCI_NR_CPUS];
static int uniphier_get_nr_cpus(void) { - switch (uniphier_get_soc_type()) { - case SOC_UNIPHIER_SLD3: - case SOC_UNIPHIER_PRO4: - case SOC_UNIPHIER_PRO5: + switch (uniphier_get_soc_id()) { + case UNIPHIER_SLD3_ID: + case UNIPHIER_PRO4_ID: + case UNIPHIER_PRO5_ID: return 2; - case SOC_UNIPHIER_PXS2: - case SOC_UNIPHIER_LD6B: + case UNIPHIER_PXS2_ID: + case UNIPHIER_LD6B_ID: return 4; default: return 1; diff --git a/arch/arm/mach-uniphier/board_init.c b/arch/arm/mach-uniphier/board_init.c index 2269291..413b338 100644 --- a/arch/arm/mach-uniphier/board_init.c +++ b/arch/arm/mach-uniphier/board_init.c @@ -80,7 +80,7 @@ static void uniphier_ld20_misc_init(void) #endif
struct uniphier_initdata { - enum uniphier_soc_id soc_id; + unsigned int soc_id; bool nand_2cs; void (*sbc_init)(void); void (*pll_init)(void); @@ -91,7 +91,7 @@ struct uniphier_initdata { static const struct uniphier_initdata uniphier_initdata[] = { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) { - .soc_id = SOC_UNIPHIER_SLD3, + .soc_id = UNIPHIER_SLD3_ID, .nand_2cs = true, .sbc_init = uniphier_sbc_init_admulti, .pll_init = uniphier_sld3_pll_init, @@ -100,7 +100,7 @@ static const struct uniphier_initdata uniphier_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) { - .soc_id = SOC_UNIPHIER_LD4, + .soc_id = UNIPHIER_LD4_ID, .nand_2cs = true, .sbc_init = uniphier_ld4_sbc_init, .pll_init = uniphier_ld4_pll_init, @@ -109,7 +109,7 @@ static const struct uniphier_initdata uniphier_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO4) { - .soc_id = SOC_UNIPHIER_PRO4, + .soc_id = UNIPHIER_PRO4_ID, .nand_2cs = false, .sbc_init = uniphier_sbc_init_savepin, .pll_init = uniphier_pro4_pll_init, @@ -118,7 +118,7 @@ static const struct uniphier_initdata uniphier_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_SLD8) { - .soc_id = SOC_UNIPHIER_SLD8, + .soc_id = UNIPHIER_SLD8_ID, .nand_2cs = true, .sbc_init = uniphier_ld4_sbc_init, .pll_init = uniphier_ld4_pll_init, @@ -127,7 +127,7 @@ static const struct uniphier_initdata uniphier_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) { - .soc_id = SOC_UNIPHIER_PRO5, + .soc_id = UNIPHIER_PRO5_ID, .nand_2cs = true, .sbc_init = uniphier_sbc_init_savepin, .clk_init = uniphier_pro5_clk_init, @@ -135,7 +135,7 @@ static const struct uniphier_initdata uniphier_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) { - .soc_id = SOC_UNIPHIER_PXS2, + .soc_id = UNIPHIER_PXS2_ID, .nand_2cs = true, .sbc_init = uniphier_pxs2_sbc_init, .clk_init = uniphier_pxs2_clk_init, @@ -143,7 +143,7 @@ static const struct uniphier_initdata uniphier_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_LD6B) { - .soc_id = SOC_UNIPHIER_LD6B, + .soc_id = UNIPHIER_LD6B_ID, .nand_2cs = true, .sbc_init = uniphier_pxs2_sbc_init, .clk_init = uniphier_pxs2_clk_init, @@ -151,7 +151,7 @@ static const struct uniphier_initdata uniphier_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_LD11) { - .soc_id = SOC_UNIPHIER_LD11, + .soc_id = UNIPHIER_LD11_ID, .nand_2cs = false, .sbc_init = uniphier_ld11_sbc_init, .pll_init = uniphier_ld11_pll_init, @@ -161,7 +161,7 @@ static const struct uniphier_initdata uniphier_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_LD20) { - .soc_id = SOC_UNIPHIER_LD20, + .soc_id = UNIPHIER_LD20_ID, .nand_2cs = false, .sbc_init = uniphier_ld11_sbc_init, .pll_init = uniphier_ld20_pll_init, @@ -171,7 +171,7 @@ static const struct uniphier_initdata uniphier_initdata[] = { };
static const struct uniphier_initdata *uniphier_get_initdata( - enum uniphier_soc_id soc_id) + unsigned int soc_id) { int i;
@@ -186,12 +186,12 @@ static const struct uniphier_initdata *uniphier_get_initdata( int board_init(void) { const struct uniphier_initdata *initdata; - enum uniphier_soc_id soc_id; + unsigned int soc_id; int ret;
led_puts("U0");
- soc_id = uniphier_get_soc_type(); + soc_id = uniphier_get_soc_id(); initdata = uniphier_get_initdata(soc_id); if (!initdata) { pr_err("unsupported board\n"); diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode-ld20.c b/arch/arm/mach-uniphier/boot-mode/boot-mode-ld20.c index 24255a0..9de7ab4 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode-ld20.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode-ld20.c @@ -57,14 +57,14 @@ u32 uniphier_ld20_boot_device(void) int boot_mode; u32 usb_boot_mask;
- switch (uniphier_get_soc_type()) { + switch (uniphier_get_soc_id()) { #if defined(CONFIG_ARCH_UNIPHIER_LD11) - case SOC_UNIPHIER_LD11: + case UNIPHIER_LD11_ID: usb_boot_mask = 0x00000080; break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD20) - case SOC_UNIPHIER_LD20: + case UNIPHIER_LD20_ID: usb_boot_mask = 0x00000780; break; #endif diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode.c b/arch/arm/mach-uniphier/boot-mode/boot-mode.c index ebe0578..a552770 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode.c @@ -18,30 +18,30 @@ u32 spl_boot_device_raw(void) if (boot_is_swapped()) return BOOT_DEVICE_NOR;
- switch (uniphier_get_soc_type()) { + switch (uniphier_get_soc_id()) { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) - case SOC_UNIPHIER_SLD3: + case UNIPHIER_SLD3_ID: return uniphier_sld3_boot_device(); #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) || defined(CONFIG_ARCH_UNIPHIER_PRO4) || \ defined(CONFIG_ARCH_UNIPHIER_SLD8) - case SOC_UNIPHIER_LD4: - case SOC_UNIPHIER_PRO4: - case SOC_UNIPHIER_SLD8: + case UNIPHIER_LD4_ID: + case UNIPHIER_PRO4_ID: + case UNIPHIER_SLD8_ID: return uniphier_ld4_boot_device(); #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) - case SOC_UNIPHIER_PRO5: + case UNIPHIER_PRO5_ID: return uniphier_pro5_boot_device(); #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) || defined(CONFIG_ARCH_UNIPHIER_LD6B) - case SOC_UNIPHIER_PXS2: - case SOC_UNIPHIER_LD6B: + case UNIPHIER_PXS2_ID: + case UNIPHIER_LD6B_ID: return uniphier_pxs2_boot_device(); #endif #if defined(CONFIG_ARCH_UNIPHIER_LD11) || defined(CONFIG_ARCH_UNIPHIER_LD20) - case SOC_UNIPHIER_LD11: - case SOC_UNIPHIER_LD20: + case UNIPHIER_LD11_ID: + case UNIPHIER_LD20_ID: return uniphier_ld20_boot_device(); #endif default: @@ -55,17 +55,17 @@ u32 spl_boot_device(void)
mode = spl_boot_device_raw();
- switch (uniphier_get_soc_type()) { + switch (uniphier_get_soc_id()) { #if defined(CONFIG_ARCH_UNIPHIER_PXS2) || defined(CONFIG_ARCH_UNIPHIER_LD6B) - case SOC_UNIPHIER_PXS2: - case SOC_UNIPHIER_LD6B: + case UNIPHIER_PXS2_ID: + case UNIPHIER_LD6B_ID: if (mode == BOOT_DEVICE_USB) mode = BOOT_DEVICE_NOR; break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD11) || defined(CONFIG_ARCH_UNIPHIER_LD20) - case SOC_UNIPHIER_LD11: - case SOC_UNIPHIER_LD20: + case UNIPHIER_LD11_ID: + case UNIPHIER_LD20_ID: if (mode == BOOT_DEVICE_MMC1 || mode == BOOT_DEVICE_USB) mode = BOOT_DEVICE_BOARD; break; diff --git a/arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c b/arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c index a8ee382..670d4f6 100644 --- a/arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c +++ b/arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c @@ -14,34 +14,34 @@ static int do_pinmon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { printf("Boot Swap: %s\n\n", boot_is_swapped() ? "ON" : "OFF");
- switch (uniphier_get_soc_type()) { + switch (uniphier_get_soc_id()) { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) - case SOC_UNIPHIER_SLD3: + case UNIPHIER_SLD3_ID: uniphier_sld3_boot_mode_show(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) || defined(CONFIG_ARCH_UNIPHIER_PRO4) || \ defined(CONFIG_ARCH_UNIPHIER_SLD8) - case SOC_UNIPHIER_LD4: - case SOC_UNIPHIER_PRO4: - case SOC_UNIPHIER_SLD8: + case UNIPHIER_LD4_ID: + case UNIPHIER_PRO4_ID: + case UNIPHIER_SLD8_ID: uniphier_ld4_boot_mode_show(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) - case SOC_UNIPHIER_PRO5: + case UNIPHIER_PRO5_ID: uniphier_pro5_boot_mode_show(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) || defined(CONFIG_ARCH_UNIPHIER_LD6B) - case SOC_UNIPHIER_PXS2: - case SOC_UNIPHIER_LD6B: + case UNIPHIER_PXS2_ID: + case UNIPHIER_LD6B_ID: uniphier_pxs2_boot_mode_show(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD11) || defined(CONFIG_ARCH_UNIPHIER_LD20) - case SOC_UNIPHIER_LD11: - case SOC_UNIPHIER_LD20: + case UNIPHIER_LD11_ID: + case UNIPHIER_LD20_ID: uniphier_ld20_boot_mode_show(); break; #endif diff --git a/arch/arm/mach-uniphier/boot-mode/spl_board.c b/arch/arm/mach-uniphier/boot-mode/spl_board.c index a6b6686..0aac924 100644 --- a/arch/arm/mach-uniphier/boot-mode/spl_board.c +++ b/arch/arm/mach-uniphier/boot-mode/spl_board.c @@ -40,11 +40,11 @@ int uniphier_rom_get_mmc_funcptr(int (**send_cmd)(u32, u32), { const struct uniphier_romfunc_table *table;
- switch (uniphier_get_soc_type()) { - case SOC_UNIPHIER_LD11: + switch (uniphier_get_soc_id()) { + case UNIPHIER_LD11_ID: table = &uniphier_ld11_romfunc_table; break; - case SOC_UNIPHIER_LD20: + case UNIPHIER_LD20_ID: table = &uniphier_ld20_romfunc_table; break; default: diff --git a/arch/arm/mach-uniphier/cpu-info.c b/arch/arm/mach-uniphier/cpu-info.c new file mode 100644 index 0000000..94bd98e --- /dev/null +++ b/arch/arm/mach-uniphier/cpu-info.c @@ -0,0 +1,73 @@ +/* + * Copyright (C) 2013-2015 Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/errno.h> +#include <linux/io.h> + +#include "soc-info.h" + +int print_cpuinfo(void) +{ + unsigned int id, model, rev, required_model = 1, required_rev = 1; + + id = uniphier_get_soc_id(); + model = uniphier_get_soc_model(); + rev = uniphier_get_soc_revision(); + + puts("CPU: "); + + switch (id) { + case UNIPHIER_SLD3_ID: + puts("sLD3 (MN2WS0220)"); + required_model = 2; + break; + case UNIPHIER_LD4_ID: + puts("LD4 (MN2WS0250)"); + required_rev = 2; + break; + case UNIPHIER_PRO4_ID: + puts("Pro4 (MN2WS0230)"); + break; + case UNIPHIER_SLD8_ID: + puts("sLD8 (MN2WS0270)"); + break; + case UNIPHIER_PRO5_ID: + puts("Pro5 (MN2WS0300)"); + break; + case UNIPHIER_PXS2_ID: + puts("PXs2 (MN2WS0310)"); + break; + case UNIPHIER_LD6B_ID: + puts("LD6b (MN2WS0320)"); + break; + case UNIPHIER_LD11_ID: + puts("LD11 (SC1405AP1)"); + break; + case UNIPHIER_LD20_ID: + puts("LD20 (SC1401AJ1)"); + break; + default: + printf("Unknown Processor ID (0x%x)\n", id); + return -1; + } + + printf(" model %d", model); + + printf(" (rev. %d)\n", rev); + + if (model < required_model) { + printf("Sorry, this model is not supported.\n"); + printf("Required model is %d.", required_model); + return -1; + } else if (rev < required_rev) { + printf("Sorry, this revision is not supported.\n"); + printf("Required revision is %d.", required_rev); + return -1; + } + + return 0; +} diff --git a/arch/arm/mach-uniphier/cpu_info.c b/arch/arm/mach-uniphier/cpu_info.c deleted file mode 100644 index 6ad4c76..0000000 --- a/arch/arm/mach-uniphier/cpu_info.c +++ /dev/null @@ -1,73 +0,0 @@ -/* - * Copyright (C) 2013-2015 Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <linux/io.h> - -#include "sg-regs.h" - -int print_cpuinfo(void) -{ - u32 revision, type, model, rev, required_model = 1, required_rev = 1; - - revision = readl(SG_REVISION); - type = (revision & SG_REVISION_TYPE_MASK) >> SG_REVISION_TYPE_SHIFT; - model = (revision & SG_REVISION_MODEL_MASK) >> SG_REVISION_MODEL_SHIFT; - rev = (revision & SG_REVISION_REV_MASK) >> SG_REVISION_REV_SHIFT; - - puts("CPU: "); - - switch (type) { - case 0x25: - puts("PH1-sLD3 (MN2WS0220)"); - required_model = 2; - break; - case 0x26: - puts("PH1-LD4 (MN2WS0250)"); - required_rev = 2; - break; - case 0x28: - puts("PH1-Pro4 (MN2WS0230)"); - break; - case 0x29: - puts("PH1-sLD8 (MN2WS0270)"); - break; - case 0x2A: - puts("PH1-Pro5 (MN2WS0300)"); - break; - case 0x2E: - puts("ProXstream2 (MN2WS0310)"); - break; - case 0x2F: - puts("PH1-LD6b (MN2WS0320)"); - break; - case 0x31: - puts("PH1-LD11 (SC1405AP1)"); - break; - case 0x32: - puts("PH1-LD20 (SC1401AJ1)"); - break; - default: - printf("Unknown Processor ID (0x%x)\n", revision); - return -1; - } - - printf(" model %d", model); - - printf(" (rev. %d)\n", rev); - - if (model < required_model) { - printf("Sorry, this model is not supported.\n"); - printf("Required model is %d.", required_model); - return -1; - } else if (rev < required_rev) { - printf("Sorry, this revision is not supported.\n"); - printf("Required revision is %d.", required_rev); - return -1; - } - - return 0; -} diff --git a/arch/arm/mach-uniphier/debug-uart/debug-uart.c b/arch/arm/mach-uniphier/debug-uart/debug-uart.c index d884785..72a514d 100644 --- a/arch/arm/mach-uniphier/debug-uart/debug-uart.c +++ b/arch/arm/mach-uniphier/debug-uart/debug-uart.c @@ -32,45 +32,45 @@ void _debug_uart_init(void) void __iomem *base = (void __iomem *)CONFIG_DEBUG_UART_BASE; unsigned int divisor;
- switch (uniphier_get_soc_type()) { + switch (uniphier_get_soc_id()) { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) - case SOC_UNIPHIER_SLD3: + case UNIPHIER_SLD3_ID: divisor = uniphier_sld3_debug_uart_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) - case SOC_UNIPHIER_LD4: + case UNIPHIER_LD4_ID: divisor = uniphier_ld4_debug_uart_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO4) - case SOC_UNIPHIER_PRO4: + case UNIPHIER_PRO4_ID: divisor = uniphier_pro4_debug_uart_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_SLD8) - case SOC_UNIPHIER_SLD8: + case UNIPHIER_SLD8_ID: divisor = uniphier_sld8_debug_uart_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) - case SOC_UNIPHIER_PRO5: + case UNIPHIER_PRO5_ID: divisor = uniphier_pro5_debug_uart_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) - case SOC_UNIPHIER_PXS2: + case UNIPHIER_PXS2_ID: divisor = uniphier_pxs2_debug_uart_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD6B) - case SOC_UNIPHIER_LD6B: + case UNIPHIER_LD6B_ID: divisor = uniphier_ld6b_debug_uart_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD11) || defined(CONFIG_ARCH_UNIPHIER_LD20) - case SOC_UNIPHIER_LD11: - case SOC_UNIPHIER_LD20: + case UNIPHIER_LD11_ID: + case UNIPHIER_LD20_ID: divisor = uniphier_ld20_debug_uart_init(); break; #endif diff --git a/arch/arm/mach-uniphier/dram/cmd_ddrphy.c b/arch/arm/mach-uniphier/dram/cmd_ddrphy.c index 9730330..d6d9db3 100644 --- a/arch/arm/mach-uniphier/dram/cmd_ddrphy.c +++ b/arch/arm/mach-uniphier/dram/cmd_ddrphy.c @@ -245,17 +245,17 @@ static int do_ddr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) char *cmd = argv[1]; const struct phy_param *phy_param;
- switch (uniphier_get_soc_type()) { - case SOC_UNIPHIER_LD4: + switch (uniphier_get_soc_id()) { + case UNIPHIER_LD4_ID: phy_param = uniphier_ld4_phy_param; break; - case SOC_UNIPHIER_PRO4: + case UNIPHIER_PRO4_ID: phy_param = uniphier_pro4_phy_param; break; - case SOC_UNIPHIER_SLD8: + case UNIPHIER_SLD8_ID: phy_param = uniphier_sld8_phy_param; break; - case SOC_UNIPHIER_LD11: + case UNIPHIER_LD11_ID: phy_param = uniphier_ld11_phy_param; break; default: diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index 87418f4..2cf5f36 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -97,7 +97,7 @@ int ft_board_setup(void *fdt, bd_t *bd) const unsigned long rsv_size = 64; int ch, ret;
- if (uniphier_get_soc_type() != SOC_UNIPHIER_LD20) + if (uniphier_get_soc_id() != UNIPHIER_LD20_ID) return 0;
param = uniphier_get_board_param(); diff --git a/arch/arm/mach-uniphier/sg-regs.h b/arch/arm/mach-uniphier/sg-regs.h index a179d61..f25e4ed 100644 --- a/arch/arm/mach-uniphier/sg-regs.h +++ b/arch/arm/mach-uniphier/sg-regs.h @@ -15,12 +15,6 @@
/* Revision */ #define SG_REVISION (SG_CTRL_BASE | 0x0000) -#define SG_REVISION_TYPE_SHIFT 16 -#define SG_REVISION_TYPE_MASK (0xff << SG_REVISION_TYPE_SHIFT) -#define SG_REVISION_MODEL_SHIFT 8 -#define SG_REVISION_MODEL_MASK (0x3 << SG_REVISION_MODEL_SHIFT) -#define SG_REVISION_REV_SHIFT 0 -#define SG_REVISION_REV_MASK (0x1f << SG_REVISION_REV_SHIFT)
/* Memory Configuration */ #define SG_MEMCONF (SG_CTRL_BASE | 0x0400) diff --git a/arch/arm/mach-uniphier/soc-info.c b/arch/arm/mach-uniphier/soc-info.c new file mode 100644 index 0000000..e0a63be --- /dev/null +++ b/arch/arm/mach-uniphier/soc-info.c @@ -0,0 +1,34 @@ +/* + * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <linux/io.h> +#include <linux/types.h> + +#include "sg-regs.h" +#include "soc-info.h" + +static unsigned int __uniphier_get_revision_field(unsigned int mask, + unsigned int shift) +{ + u32 revision = readl(SG_REVISION); + + return (revision >> shift) & mask; +} + +unsigned int uniphier_get_soc_id(void) +{ + return __uniphier_get_revision_field(0xff, 16); +} + +unsigned int uniphier_get_soc_model(void) +{ + return __uniphier_get_revision_field(0x3, 8); +} + +unsigned int uniphier_get_soc_revision(void) +{ + return __uniphier_get_revision_field(0x1f, 0); +} diff --git a/arch/arm/mach-uniphier/soc-info.h b/arch/arm/mach-uniphier/soc-info.h index d9b38b3..aeaaf83 100644 --- a/arch/arm/mach-uniphier/soc-info.h +++ b/arch/arm/mach-uniphier/soc-info.h @@ -4,73 +4,21 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __MACH_SOC_INFO_H__ -#define __MACH_SOC_INFO_H__ - -enum uniphier_soc_id { - SOC_UNIPHIER_SLD3, - SOC_UNIPHIER_LD4, - SOC_UNIPHIER_PRO4, - SOC_UNIPHIER_SLD8, - SOC_UNIPHIER_PRO5, - SOC_UNIPHIER_PXS2, - SOC_UNIPHIER_LD6B, - SOC_UNIPHIER_LD11, - SOC_UNIPHIER_LD20, - SOC_UNIPHIER_UNKNOWN, -}; - -#define UNIPHIER_NR_ENABLED_SOCS \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_SLD3) + \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_LD4) + \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_PRO4) + \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_SLD8) + \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_PRO5) + \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_PXS2) + \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_LD6B) + \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_LD11) + \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_LD20) - -#define UNIPHIER_MULTI_SOC ((UNIPHIER_NR_ENABLED_SOCS) > 1) - -#if UNIPHIER_MULTI_SOC -enum uniphier_soc_id uniphier_get_soc_type(void); -#else -static inline enum uniphier_soc_id uniphier_get_soc_type(void) -{ -#if defined(CONFIG_ARCH_UNIPHIER_SLD3) - return SOC_UNIPHIER_SLD3; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_LD4) - return SOC_UNIPHIER_LD4; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_PRO4) - return SOC_UNIPHIER_PRO4; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_SLD8) - return SOC_UNIPHIER_SLD8; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_PRO5) - return SOC_UNIPHIER_PRO5; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_PXS2) - return SOC_UNIPHIER_PXS2; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_LD6B) - return SOC_UNIPHIER_LD6B; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_LD11) - return SOC_UNIPHIER_LD11; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_LD20) - return SOC_UNIPHIER_LD20; -#endif - - return SOC_UNIPHIER_UNKNOWN; -} -#endif - -int uniphier_get_soc_model(void); -int uniphier_get_soc_revision(void); - -#endif /* __MACH_SOC_INFO_H__ */ +#ifndef __UNIPHIER_SOC_INFO_H__ +#define __UNIPHIER_SOC_INFO_H__ + +#define UNIPHIER_SLD3_ID 0x25 +#define UNIPHIER_LD4_ID 0x26 +#define UNIPHIER_PRO4_ID 0x28 +#define UNIPHIER_SLD8_ID 0x29 +#define UNIPHIER_PRO5_ID 0x2a +#define UNIPHIER_PXS2_ID 0x2e +#define UNIPHIER_LD6B_ID 0x2f +#define UNIPHIER_LD11_ID 0x31 +#define UNIPHIER_LD20_ID 0x32 + +unsigned int uniphier_get_soc_id(void); +unsigned int uniphier_get_soc_model(void); +unsigned int uniphier_get_soc_revision(void); + +#endif /* __UNIPHIER_SOC_INFO_H__ */ diff --git a/arch/arm/mach-uniphier/soc_info.c b/arch/arm/mach-uniphier/soc_info.c deleted file mode 100644 index 046104b..0000000 --- a/arch/arm/mach-uniphier/soc_info.c +++ /dev/null @@ -1,84 +0,0 @@ -/* - * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <linux/io.h> -#include <linux/types.h> - -#include "sg-regs.h" -#include "soc-info.h" - -#if UNIPHIER_MULTI_SOC -enum uniphier_soc_id uniphier_get_soc_type(void) -{ - u32 revision = readl(SG_REVISION); - enum uniphier_soc_id ret; - - switch ((revision & SG_REVISION_TYPE_MASK) >> SG_REVISION_TYPE_SHIFT) { -#ifdef CONFIG_ARCH_UNIPHIER_SLD3 - case 0x25: - ret = SOC_UNIPHIER_SLD3; - break; -#endif -#ifdef CONFIG_ARCH_UNIPHIER_LD4 - case 0x26: - ret = SOC_UNIPHIER_LD4; - break; -#endif -#ifdef CONFIG_ARCH_UNIPHIER_PRO4 - case 0x28: - ret = SOC_UNIPHIER_PRO4; - break; -#endif -#ifdef CONFIG_ARCH_UNIPHIER_SLD8 - case 0x29: - ret = SOC_UNIPHIER_SLD8; - break; -#endif -#ifdef CONFIG_ARCH_UNIPHIER_PRO5 - case 0x2A: - ret = SOC_UNIPHIER_PRO5; - break; -#endif -#ifdef CONFIG_ARCH_UNIPHIER_PXS2 - case 0x2E: - ret = SOC_UNIPHIER_PXS2; - break; -#endif -#ifdef CONFIG_ARCH_UNIPHIER_LD6B - case 0x2F: - ret = SOC_UNIPHIER_LD6B; - break; -#endif -#ifdef CONFIG_ARCH_UNIPHIER_LD11 - case 0x31: - ret = SOC_UNIPHIER_LD11; - break; -#endif -#ifdef CONFIG_ARCH_UNIPHIER_LD20 - case 0x32: - ret = SOC_UNIPHIER_LD20; - break; -#endif - default: - ret = SOC_UNIPHIER_UNKNOWN; - break; - } - - return ret; -} -#endif - -int uniphier_get_soc_model(void) -{ - return (readl(SG_REVISION) & SG_REVISION_MODEL_MASK) >> - SG_REVISION_MODEL_SHIFT; -} - -int uniphier_get_soc_revision(void) -{ - return (readl(SG_REVISION) & SG_REVISION_REV_MASK) >> - SG_REVISION_REV_SHIFT; -} diff --git a/arch/arm/mach-uniphier/spl_board_init.c b/arch/arm/mach-uniphier/spl_board_init.c index f4e1cb9..83851ef 100644 --- a/arch/arm/mach-uniphier/spl_board_init.c +++ b/arch/arm/mach-uniphier/spl_board_init.c @@ -14,7 +14,7 @@ #include "soc-info.h"
struct uniphier_spl_initdata { - enum uniphier_soc_id soc_id; + unsigned int soc_id; void (*bcu_init)(const struct uniphier_board_data *bd); void (*early_clk_init)(void); int (*dpll_init)(const struct uniphier_board_data *bd); @@ -26,7 +26,7 @@ struct uniphier_spl_initdata { static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) { - .soc_id = SOC_UNIPHIER_SLD3, + .soc_id = UNIPHIER_SLD3_ID, .bcu_init = uniphier_sld3_bcu_init, .early_clk_init = uniphier_sld3_early_clk_init, .dpll_init = uniphier_sld3_dpll_init, @@ -37,7 +37,7 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) { - .soc_id = SOC_UNIPHIER_LD4, + .soc_id = UNIPHIER_LD4_ID, .bcu_init = uniphier_ld4_bcu_init, .early_clk_init = uniphier_sld3_early_clk_init, .dpll_init = uniphier_ld4_dpll_init, @@ -48,7 +48,7 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO4) { - .soc_id = SOC_UNIPHIER_PRO4, + .soc_id = UNIPHIER_PRO4_ID, .early_clk_init = uniphier_sld3_early_clk_init, .dpll_init = uniphier_pro4_dpll_init, .memconf_init = uniphier_memconf_2ch_init, @@ -58,7 +58,7 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_SLD8) { - .soc_id = SOC_UNIPHIER_SLD8, + .soc_id = UNIPHIER_SLD8_ID, .bcu_init = uniphier_ld4_bcu_init, .early_clk_init = uniphier_sld3_early_clk_init, .dpll_init = uniphier_sld8_dpll_init, @@ -69,7 +69,7 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) { - .soc_id = SOC_UNIPHIER_PRO5, + .soc_id = UNIPHIER_PRO5_ID, .early_clk_init = uniphier_sld3_early_clk_init, .dpll_init = uniphier_pro5_dpll_init, .memconf_init = uniphier_memconf_2ch_init, @@ -79,7 +79,7 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) { - .soc_id = SOC_UNIPHIER_PXS2, + .soc_id = UNIPHIER_PXS2_ID, .early_clk_init = uniphier_sld3_early_clk_init, .dpll_init = uniphier_pxs2_dpll_init, .memconf_init = uniphier_memconf_3ch_init, @@ -89,7 +89,7 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_LD6B) { - .soc_id = SOC_UNIPHIER_LD6B, + .soc_id = UNIPHIER_LD6B_ID, .early_clk_init = uniphier_sld3_early_clk_init, .dpll_init = uniphier_pxs2_dpll_init, .memconf_init = uniphier_memconf_3ch_init, @@ -99,7 +99,7 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_LD11) { - .soc_id = SOC_UNIPHIER_LD11, + .soc_id = UNIPHIER_LD11_ID, .early_clk_init = uniphier_ld11_early_clk_init, .dpll_init = uniphier_ld11_dpll_init, .memconf_init = uniphier_memconf_2ch_init, @@ -109,7 +109,7 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { #endif #if defined(CONFIG_ARCH_UNIPHIER_LD20) { - .soc_id = SOC_UNIPHIER_LD20, + .soc_id = UNIPHIER_LD20_ID, .early_clk_init = uniphier_ld11_early_clk_init, .dpll_init = uniphier_ld20_dpll_init, .memconf_init = uniphier_memconf_3ch_init, @@ -120,7 +120,7 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { };
static const struct uniphier_spl_initdata *uniphier_get_spl_initdata( - enum uniphier_soc_id soc_id) + unsigned int soc_id) { int i;
@@ -136,7 +136,7 @@ void spl_board_init(void) { const struct uniphier_board_data *bd; const struct uniphier_spl_initdata *initdata; - enum uniphier_soc_id soc_id; + unsigned int soc_id; int ret;
#ifdef CONFIG_DEBUG_UART @@ -147,7 +147,7 @@ void spl_board_init(void) if (!bd) hang();
- soc_id = uniphier_get_soc_type(); + soc_id = uniphier_get_soc_id(); initdata = uniphier_get_spl_initdata(soc_id); if (!initdata) hang();
There are similar functions that look up SoC data by the SoC ID. The new macro UNIPHIER_DEFINE_SOCDATA_FUNC will be helpful to avoid the code duplication.
arch/arm/mach-uniphier/board_init.c | 20 +++----------------- arch/arm/mach-uniphier/soc-info.h | 18 ++++++++++++++++++ arch/arm/mach-uniphier/spl_board_init.c | 18 ++---------------- 3 files changed, 23 insertions(+), 33 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_init.c b/arch/arm/mach-uniphier/board_init.c index 413b338..ac7e3a6 100644 --- a/arch/arm/mach-uniphier/board_init.c +++ b/arch/arm/mach-uniphier/board_init.c @@ -169,32 +169,18 @@ static const struct uniphier_initdata uniphier_initdata[] = { }, #endif }; - -static const struct uniphier_initdata *uniphier_get_initdata( - unsigned int soc_id) -{ - int i; - - for (i = 0; i < ARRAY_SIZE(uniphier_initdata); i++) { - if (uniphier_initdata[i].soc_id == soc_id) - return &uniphier_initdata[i]; - } - - return NULL; -} +UNIPHIER_DEFINE_SOCDATA_FUNC(uniphier_get_initdata, uniphier_initdata)
int board_init(void) { const struct uniphier_initdata *initdata; - unsigned int soc_id; int ret;
led_puts("U0");
- soc_id = uniphier_get_soc_id(); - initdata = uniphier_get_initdata(soc_id); + initdata = uniphier_get_initdata(); if (!initdata) { - pr_err("unsupported board\n"); + pr_err("unsupported SoC\n"); return -EINVAL; }
diff --git a/arch/arm/mach-uniphier/soc-info.h b/arch/arm/mach-uniphier/soc-info.h index aeaaf83..a85df23 100644 --- a/arch/arm/mach-uniphier/soc-info.h +++ b/arch/arm/mach-uniphier/soc-info.h @@ -7,6 +7,9 @@ #ifndef __UNIPHIER_SOC_INFO_H__ #define __UNIPHIER_SOC_INFO_H__
+#include <linux/kernel.h> +#include <linux/stddef.h> + #define UNIPHIER_SLD3_ID 0x25 #define UNIPHIER_LD4_ID 0x26 #define UNIPHIER_PRO4_ID 0x28 @@ -21,4 +24,19 @@ unsigned int uniphier_get_soc_id(void); unsigned int uniphier_get_soc_model(void); unsigned int uniphier_get_soc_revision(void);
+#define UNIPHIER_DEFINE_SOCDATA_FUNC(__func_name, __table) \ +static typeof(&__table[0]) __func_name(void) \ +{ \ + unsigned int soc_id; \ + int i; \ + \ + soc_id = uniphier_get_soc_id(); \ + for (i = 0; i < ARRAY_SIZE(__table); i++) { \ + if (__table[i].soc_id == soc_id) \ + return &__table[i]; \ + } \ + \ + return NULL; \ +} + #endif /* __UNIPHIER_SOC_INFO_H__ */ diff --git a/arch/arm/mach-uniphier/spl_board_init.c b/arch/arm/mach-uniphier/spl_board_init.c index 83851ef..da749a3 100644 --- a/arch/arm/mach-uniphier/spl_board_init.c +++ b/arch/arm/mach-uniphier/spl_board_init.c @@ -118,25 +118,12 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { }, #endif }; - -static const struct uniphier_spl_initdata *uniphier_get_spl_initdata( - unsigned int soc_id) -{ - int i; - - for (i = 0; i < ARRAY_SIZE(uniphier_spl_initdata); i++) { - if (uniphier_spl_initdata[i].soc_id == soc_id) - return &uniphier_spl_initdata[i]; - } - - return NULL; -} +UNIPHIER_DEFINE_SOCDATA_FUNC(uniphier_get_spl_initdata, uniphier_spl_initdata)
void spl_board_init(void) { const struct uniphier_board_data *bd; const struct uniphier_spl_initdata *initdata; - unsigned int soc_id; int ret;
#ifdef CONFIG_DEBUG_UART @@ -147,8 +134,7 @@ void spl_board_init(void) if (!bd) hang();
- soc_id = uniphier_get_soc_id(); - initdata = uniphier_get_spl_initdata(soc_id); + initdata = uniphier_get_spl_initdata(); if (!initdata) hang();
All the UniPhier DT files are compiled if CONFIG_ARCH_UNIPHIER is enabled, but not all of them actually work. For example, when U-Boot is compiled for ARM 32 bit, 64 bit DT files are also built, and vice versa. Compile only the combination that makes sense.
arch/arm/dts/Makefile | 27 ++++++++++++++++++--------- 1 file changed, 18 insertions(+), 9 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 66ea0b3..3dbbaa7 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -81,19 +81,28 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-xp-synology-ds414.dtb \ armada-xp-theadorable.dtb
-dtb-$(CONFIG_ARCH_UNIPHIER) += \ - uniphier-ld11-ref.dtb \ - uniphier-ld20-ref.dtb \ - uniphier-ld4-ref.dtb \ - uniphier-ld6b-ref.dtb \ +dtb-$(CONFIG_ARCH_UNIPHIER_LD11) += \ + uniphier-ld11-ref.dtb +dtb-$(CONFIG_ARCH_UNIPHIER_LD20) += \ + uniphier-ld20-ref.dtb +dtb-$(CONFIG_ARCH_UNIPHIER_LD4) += \ + uniphier-ld4-ref.dtb +dtb-$(CONFIG_ARCH_UNIPHIER_LD6B) += \ + uniphier-ld6b-ref.dtb +dtb-$(CONFIG_ARCH_UNIPHIER_PRO4) += \ uniphier-pro4-ace.dtb \ uniphier-pro4-ref.dtb \ - uniphier-pro4-sanji.dtb \ - uniphier-pro5-4kbox.dtb \ + uniphier-pro4-sanji.dtb +dtb-$(CONFIG_ARCH_UNIPHIER_PRO5) += \ + uniphier-pro5-4kbox.dtb +dtb-$(CONFIG_ARCH_UNIPHIER_PXS2) += \ uniphier-pxs2-gentil.dtb \ - uniphier-pxs2-vodka.dtb \ - uniphier-sld3-ref.dtb \ + uniphier-pxs2-vodka.dtb +dtb-$(CONFIG_ARCH_UNIPHIER_SLD3) += \ + uniphier-sld3-ref.dtb +dtb-$(CONFIG_ARCH_UNIPHIER_SLD8) += \ uniphier-sld8-ref.dtb + dtb-$(CONFIG_ARCH_ZYNQ) += zynq-zc702.dtb \ zynq-zc706.dtb \ zynq-zed.dtb \
Add pin configuration and pinmux support for UniPhier PXs3 SoC.
drivers/pinctrl/uniphier/Kconfig | 24 ++-- drivers/pinctrl/uniphier/Makefile | 1 + drivers/pinctrl/uniphier/pinctrl-uniphier-pxs3.c | 140 +++++++++++++++++++++++ 3 files changed, 156 insertions(+), 9 deletions(-) create mode 100644 drivers/pinctrl/uniphier/pinctrl-uniphier-pxs3.c
diff --git a/drivers/pinctrl/uniphier/Kconfig b/drivers/pinctrl/uniphier/Kconfig index 689e576..a6e51ca 100644 --- a/drivers/pinctrl/uniphier/Kconfig +++ b/drivers/pinctrl/uniphier/Kconfig @@ -4,57 +4,63 @@ config PINCTRL_UNIPHIER bool
config PINCTRL_UNIPHIER_SLD3 - bool "UniPhier PH1-sLD3 SoC pinctrl driver" + bool "UniPhier sLD3 SoC pinctrl driver" depends on ARCH_UNIPHIER_SLD3 default y select PINCTRL_UNIPHIER
config PINCTRL_UNIPHIER_LD4 - bool "UniPhier PH1-LD4 SoC pinctrl driver" + bool "UniPhier LD4 SoC pinctrl driver" depends on ARCH_UNIPHIER_LD4 default y select PINCTRL_UNIPHIER
config PINCTRL_UNIPHIER_PRO4 - bool "UniPhier PH1-Pro4 SoC pinctrl driver" + bool "UniPhier Pro4 SoC pinctrl driver" depends on ARCH_UNIPHIER_PRO4 default y select PINCTRL_UNIPHIER
config PINCTRL_UNIPHIER_SLD8 - bool "UniPhier PH1-sLD8 SoC pinctrl driver" + bool "UniPhier sLD8 SoC pinctrl driver" depends on ARCH_UNIPHIER_SLD8 default y select PINCTRL_UNIPHIER
config PINCTRL_UNIPHIER_PRO5 - bool "UniPhier PH1-Pro5 SoC pinctrl driver" + bool "UniPhier Pro5 SoC pinctrl driver" depends on ARCH_UNIPHIER_PRO5 default y select PINCTRL_UNIPHIER
config PINCTRL_UNIPHIER_PXS2 - bool "UniPhier ProXstream2 SoC pinctrl driver" + bool "UniPhier PXs2 SoC pinctrl driver" depends on ARCH_UNIPHIER_PXS2 default y select PINCTRL_UNIPHIER
config PINCTRL_UNIPHIER_LD6B - bool "UniPhier PH1-LD6b SoC pinctrl driver" + bool "UniPhier LD6b SoC pinctrl driver" depends on ARCH_UNIPHIER_LD6B default y select PINCTRL_UNIPHIER
config PINCTRL_UNIPHIER_LD11 - bool "UniPhier PH1-LD11 SoC pinctrl driver" + bool "UniPhier LD11 SoC pinctrl driver" depends on ARCH_UNIPHIER_LD11 default y select PINCTRL_UNIPHIER
config PINCTRL_UNIPHIER_LD20 - bool "UniPhier PH1-LD20 SoC pinctrl driver" + bool "UniPhier LD20 SoC pinctrl driver" depends on ARCH_UNIPHIER_LD20 default y select PINCTRL_UNIPHIER
+config PINCTRL_UNIPHIER_PXS3 + bool "UniPhier PXs3 SoC pinctrl driver" + depends on ARCH_UNIPHIER_PXS3 + default y + select PINCTRL_UNIPHIER + endif diff --git a/drivers/pinctrl/uniphier/Makefile b/drivers/pinctrl/uniphier/Makefile index fd003ad..b805765 100644 --- a/drivers/pinctrl/uniphier/Makefile +++ b/drivers/pinctrl/uniphier/Makefile @@ -13,3 +13,4 @@ obj-$(CONFIG_PINCTRL_UNIPHIER_PXS2) += pinctrl-uniphier-pxs2.o obj-$(CONFIG_PINCTRL_UNIPHIER_LD6B) += pinctrl-uniphier-ld6b.o obj-$(CONFIG_PINCTRL_UNIPHIER_LD11) += pinctrl-uniphier-ld11.o obj-$(CONFIG_PINCTRL_UNIPHIER_LD20) += pinctrl-uniphier-ld20.o +obj-$(CONFIG_PINCTRL_UNIPHIER_PXS3) += pinctrl-uniphier-pxs3.o diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs3.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs3.c new file mode 100644 index 0000000..65b56da --- /dev/null +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs3.c @@ -0,0 +1,140 @@ +/* + * Copyright (C) 2017 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dm/device.h> +#include <dm/pinctrl.h> + +#include "pinctrl-uniphier.h" + +static const unsigned emmc_pins[] = {31, 32, 33, 34, 35, 36, 37, 38}; +static const int emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0}; +static const unsigned emmc_dat8_pins[] = {39, 40, 41, 42}; +static const int emmc_dat8_muxvals[] = {0, 0, 0, 0}; +static const unsigned ether_rgmii_pins[] = {52, 53, 54, 55, 56, 57, 58, 59, 60, + 61, 62, 63, 64, 65, 66, 67}; +static const int ether_rgmii_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0}; +static const unsigned ether_rmii_pins[] = {52, 53, 54, 55, 56, 57, 58, 59, 61, + 63, 64, 67}; +static const int ether_rmii_muxvals[] = {0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1}; +static const unsigned ether1_rgmii_pins[] = {68, 69, 70, 71, 72, 73, 74, 75, 76, + 77, 78, 79, 80, 81, 82, 83}; +static const int ether1_rgmii_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0}; +static const unsigned ether1_rmii_pins[] = {68, 69, 70, 71, 72, 73, 74, 75, 77, + 79, 80, 83}; +static const int ether1_rmii_muxvals[] = {0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1}; +static const unsigned i2c0_pins[] = {104, 105}; +static const int i2c0_muxvals[] = {0, 0}; +static const unsigned i2c1_pins[] = {106, 107}; +static const int i2c1_muxvals[] = {0, 0}; +static const unsigned i2c2_pins[] = {108, 109}; +static const int i2c2_muxvals[] = {0, 0}; +static const unsigned i2c3_pins[] = {110, 111}; +static const int i2c3_muxvals[] = {0, 0}; +static const unsigned nand_pins[] = {16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, + 27, 28, 29, 30}; +static const int nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; +static const unsigned sd_pins[] = {43, 44, 45, 46, 47, 48, 49, 50, 51}; +static const int sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; +static const unsigned system_bus_pins[] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, + 12, 13, 14}; +static const int system_bus_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0}; +static const unsigned system_bus_cs1_pins[] = {15}; +static const int system_bus_cs1_muxvals[] = {0}; +static const unsigned uart0_pins[] = {92, 93}; +static const int uart0_muxvals[] = {0, 0}; +static const unsigned uart1_pins[] = {94, 95}; +static const int uart1_muxvals[] = {0, 0}; +static const unsigned uart2_pins[] = {96, 97}; +static const int uart2_muxvals[] = {0, 0}; +static const unsigned uart3_pins[] = {98, 99}; +static const int uart3_muxvals[] = {0, 0}; +static const unsigned usb0_pins[] = {84, 85}; +static const int usb0_muxvals[] = {0, 0}; +static const unsigned usb1_pins[] = {86, 87}; +static const int usb1_muxvals[] = {0, 0}; +static const unsigned usb2_pins[] = {88, 89}; +static const int usb2_muxvals[] = {0, 0}; +static const unsigned usb3_pins[] = {90, 91}; +static const int usb3_muxvals[] = {0, 0}; + +static const struct uniphier_pinctrl_group uniphier_pxs3_groups[] = { + UNIPHIER_PINCTRL_GROUP(emmc), + UNIPHIER_PINCTRL_GROUP(emmc_dat8), + UNIPHIER_PINCTRL_GROUP(ether_rgmii), + UNIPHIER_PINCTRL_GROUP(ether_rmii), + UNIPHIER_PINCTRL_GROUP(ether1_rgmii), + UNIPHIER_PINCTRL_GROUP(ether1_rmii), + UNIPHIER_PINCTRL_GROUP(i2c0), + UNIPHIER_PINCTRL_GROUP(i2c1), + UNIPHIER_PINCTRL_GROUP(i2c2), + UNIPHIER_PINCTRL_GROUP(i2c3), + UNIPHIER_PINCTRL_GROUP(nand), + UNIPHIER_PINCTRL_GROUP(sd), + UNIPHIER_PINCTRL_GROUP_SPL(system_bus), + UNIPHIER_PINCTRL_GROUP_SPL(system_bus_cs1), + UNIPHIER_PINCTRL_GROUP_SPL(uart0), + UNIPHIER_PINCTRL_GROUP_SPL(uart1), + UNIPHIER_PINCTRL_GROUP_SPL(uart2), + UNIPHIER_PINCTRL_GROUP_SPL(uart3), + UNIPHIER_PINCTRL_GROUP(usb0), + UNIPHIER_PINCTRL_GROUP(usb1), + UNIPHIER_PINCTRL_GROUP(usb2), + UNIPHIER_PINCTRL_GROUP(usb3), +}; + +static const char * const uniphier_pxs3_functions[] = { + UNIPHIER_PINMUX_FUNCTION(emmc), + UNIPHIER_PINMUX_FUNCTION(ether_rgmii), + UNIPHIER_PINMUX_FUNCTION(ether_rmii), + UNIPHIER_PINMUX_FUNCTION(ether1_rgmii), + UNIPHIER_PINMUX_FUNCTION(ether1_rmii), + UNIPHIER_PINMUX_FUNCTION(i2c0), + UNIPHIER_PINMUX_FUNCTION(i2c1), + UNIPHIER_PINMUX_FUNCTION(i2c2), + UNIPHIER_PINMUX_FUNCTION(i2c3), + UNIPHIER_PINMUX_FUNCTION(nand), + UNIPHIER_PINMUX_FUNCTION(sd), + UNIPHIER_PINMUX_FUNCTION_SPL(system_bus), + UNIPHIER_PINMUX_FUNCTION_SPL(uart0), + UNIPHIER_PINMUX_FUNCTION_SPL(uart1), + UNIPHIER_PINMUX_FUNCTION_SPL(uart2), + UNIPHIER_PINMUX_FUNCTION_SPL(uart3), + UNIPHIER_PINMUX_FUNCTION(usb0), + UNIPHIER_PINMUX_FUNCTION(usb1), + UNIPHIER_PINMUX_FUNCTION(usb2), + UNIPHIER_PINMUX_FUNCTION(usb3), +}; + +static struct uniphier_pinctrl_socdata uniphier_pxs3_pinctrl_socdata = { + .groups = uniphier_pxs3_groups, + .groups_count = ARRAY_SIZE(uniphier_pxs3_groups), + .functions = uniphier_pxs3_functions, + .functions_count = ARRAY_SIZE(uniphier_pxs3_functions), + .caps = UNIPHIER_PINCTRL_CAPS_PERPIN_IECTRL, +}; + +static int uniphier_pxs3_pinctrl_probe(struct udevice *dev) +{ + return uniphier_pinctrl_probe(dev, &uniphier_pxs3_pinctrl_socdata); +} + +static const struct udevice_id uniphier_pxs3_pinctrl_match[] = { + { .compatible = "socionext,uniphier-pxs3-pinctrl" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(uniphier_pxs3_pinctrl) = { + .name = "uniphier-pxs3-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(uniphier_pxs3_pinctrl_match), + .probe = uniphier_pxs3_pinctrl_probe, + .priv_auto_alloc_size = sizeof(struct uniphier_pinctrl_priv), + .ops = &uniphier_pinctrl_ops, +};
Initial commit for the PXs3 SoC DT.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/dts/Makefile | 2 + arch/arm/dts/uniphier-pxs3-ref.dts | 51 ++++++ arch/arm/dts/uniphier-pxs3.dtsi | 328 +++++++++++++++++++++++++++++++++++++ 3 files changed, 381 insertions(+) create mode 100644 arch/arm/dts/uniphier-pxs3-ref.dts create mode 100644 arch/arm/dts/uniphier-pxs3.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3dbbaa7..6a7924e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -98,6 +98,8 @@ dtb-$(CONFIG_ARCH_UNIPHIER_PRO5) += \ dtb-$(CONFIG_ARCH_UNIPHIER_PXS2) += \ uniphier-pxs2-gentil.dtb \ uniphier-pxs2-vodka.dtb +dtb-$(CONFIG_ARCH_UNIPHIER_PXS3) += \ + uniphier-pxs3-ref.dtb dtb-$(CONFIG_ARCH_UNIPHIER_SLD3) += \ uniphier-sld3-ref.dtb dtb-$(CONFIG_ARCH_UNIPHIER_SLD8) += \ diff --git a/arch/arm/dts/uniphier-pxs3-ref.dts b/arch/arm/dts/uniphier-pxs3-ref.dts new file mode 100644 index 0000000..27f0cb0 --- /dev/null +++ b/arch/arm/dts/uniphier-pxs3-ref.dts @@ -0,0 +1,51 @@ +/* + * Device Tree Source for UniPhier PXs3 Reference Board + * + * Copyright (C) 2017 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +/dts-v1/; +/include/ "uniphier-pxs3.dtsi" +/include/ "uniphier-ref-daughter.dtsi" +/include/ "uniphier-support-card.dtsi" + +/ { + model = "UniPhier PXs3 Reference Board"; + compatible = "socionext,uniphier-pxs3-ref", "socionext,uniphier-pxs3"; + + aliases { + serial0 = &serial0; + serial1 = &serial1; + serial2 = &serial2; + serial3 = &serial3; + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + i2c6 = &i2c6; + }; + + memory { + device_type = "memory"; + reg = <0 0x80000000 0 0xa0000000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +ðsc { + interrupts = <0 48 4>; +}; + +&serial0 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; +}; diff --git a/arch/arm/dts/uniphier-pxs3.dtsi b/arch/arm/dts/uniphier-pxs3.dtsi new file mode 100644 index 0000000..3b30eef --- /dev/null +++ b/arch/arm/dts/uniphier-pxs3.dtsi @@ -0,0 +1,328 @@ +/* + * Device Tree Source for UniPhier PXs3 SoC + * + * Copyright (C) 2017 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +/memreserve/ 0x80000000 0x00080000; + +/ { + compatible = "socionext,uniphier-pxs3"; + #address-cells = <2>; + #size-cells = <2>; + interrupt-parent = <&gic>; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu0>; + }; + core1 { + cpu = <&cpu1>; + }; + core2 { + cpu = <&cpu2>; + }; + core3 { + cpu = <&cpu3>; + }; + }; + }; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0 0x000>; + enable-method = "psci"; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0 0x001>; + enable-method = "psci"; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0 0x002>; + enable-method = "psci"; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0 0x003>; + enable-method = "psci"; + }; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + clocks { + refclk: ref { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <1 13 4>, + <1 14 4>, + <1 11 4>, + <1 10 4>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0 0xffffffff>; + + serial0: serial@54006800 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006800 0x40>; + interrupts = <0 33 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + clocks = <&peri_clk 0>; + clock-frequency = <58820000>; + }; + + serial1: serial@54006900 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006900 0x40>; + interrupts = <0 35 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + clocks = <&peri_clk 1>; + clock-frequency = <58820000>; + }; + + serial2: serial@54006a00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006a00 0x40>; + interrupts = <0 37 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + clocks = <&peri_clk 2>; + clock-frequency = <58820000>; + }; + + serial3: serial@54006b00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006b00 0x40>; + interrupts = <0 177 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + clocks = <&peri_clk 3>; + clock-frequency = <58820000>; + }; + + i2c0: i2c@58780000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58780000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 41 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + clocks = <&peri_clk 4>; + clock-frequency = <100000>; + }; + + i2c1: i2c@58781000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58781000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 42 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + clocks = <&peri_clk 5>; + clock-frequency = <100000>; + }; + + i2c2: i2c@58782000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58782000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 43 4>; + clocks = <&peri_clk 6>; + clock-frequency = <100000>; + }; + + i2c3: i2c@58783000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58783000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 44 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clocks = <&peri_clk 7>; + clock-frequency = <100000>; + }; + + /* chip-internal connection for HDMI */ + i2c6: i2c@58786000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58786000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 26 4>; + clocks = <&peri_clk 10>; + clock-frequency = <400000>; + }; + + system_bus: system-bus@58c00000 { + compatible = "socionext,uniphier-system-bus"; + status = "disabled"; + reg = <0x58c00000 0x400>; + #address-cells = <2>; + #size-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_system_bus>; + }; + + smpctrl@59800000 { + compatible = "socionext,uniphier-smpctrl"; + reg = <0x59801000 0x400>; + }; + + sdctrl@59810000 { + compatible = "socionext,uniphier-pxs3-sdctrl", + "simple-mfd", "syscon"; + reg = <0x59810000 0x800>; + + sd_clk: clock { + compatible = "socionext,uniphier-pxs3-sd-clock"; + #clock-cells = <1>; + }; + + sd_rst: reset { + compatible = "socionext,uniphier-pxs3-sd-reset"; + #reset-cells = <1>; + }; + }; + + perictrl@59820000 { + compatible = "socionext,uniphier-pxs3-perictrl", + "simple-mfd", "syscon"; + reg = <0x59820000 0x200>; + + peri_clk: clock { + compatible = "socionext,uniphier-pxs3-peri-clock"; + #clock-cells = <1>; + }; + + peri_rst: reset { + compatible = "socionext,uniphier-pxs3-peri-reset"; + #reset-cells = <1>; + }; + }; + + emmc: sdhc@5a000000 { + compatible = "socionext,uniphier-sd4hc", "cdns,sd4hc"; + status = "disabled"; + reg = <0x5a000000 0x400>; + interrupts = <0 78 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_emmc_1v8>; + clocks = <&sys_clk 4>; + bus-width = <8>; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + }; + + sd: sdhc@5a400000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x5a400000 0x800>; + interrupts = <0 76 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sd>; + clocks = <&sd_clk 0>; + reset-names = "host"; + resets = <&sd_rst 0>; + bus-width = <4>; + cap-sd-highspeed; + }; + + soc-glue@5f800000 { + compatible = "socionext,uniphier-pxs3-soc-glue", + "simple-mfd", "syscon"; + reg = <0x5f800000 0x2000>; + + pinctrl: pinctrl { + compatible = "socionext,uniphier-pxs3-pinctrl"; + }; + }; + + aidet@5fc20000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5fc20000 0x200>; + }; + + gic: interrupt-controller@5fe00000 { + compatible = "arm,gic-v3"; + reg = <0x5fe00000 0x10000>, /* GICD */ + <0x5fe80000 0x80000>; /* GICR */ + interrupt-controller; + #interrupt-cells = <3>; + interrupts = <1 9 4>; + }; + + sysctrl@61840000 { + compatible = "socionext,uniphier-pxs3-sysctrl", + "simple-mfd", "syscon"; + reg = <0x61840000 0x10000>; + + sys_clk: clock { + compatible = "socionext,uniphier-pxs3-clock"; + #clock-cells = <1>; + }; + + sys_rst: reset { + compatible = "socionext,uniphier-pxs3-reset"; + #reset-cells = <1>; + }; + }; + + nand: nand@68000000 { + compatible = "socionext,denali-nand-v5b"; + status = "disabled"; + reg-names = "nand_data", "denali_reg"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + interrupts = <0 65 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nand>; + clocks = <&sys_clk 2>; + nand-ecc-strength = <8>; + }; + }; +}; + +/include/ "uniphier-pinctrl.dtsi"
Initial support for PXs3 SoC.
arch/arm/mach-uniphier/Kconfig | 5 +++++ arch/arm/mach-uniphier/board_init.c | 8 ++++++++ arch/arm/mach-uniphier/clk/Makefile | 1 + arch/arm/mach-uniphier/clk/pll-pxs3.c | 7 +++++++ arch/arm/mach-uniphier/cpu-info.c | 3 +++ arch/arm/mach-uniphier/init.h | 1 + arch/arm/mach-uniphier/sbc/Makefile | 1 + arch/arm/mach-uniphier/soc-info.h | 1 + doc/README.uniphier | 4 ++++ 9 files changed, 31 insertions(+) create mode 100644 arch/arm/mach-uniphier/clk/pll-pxs3.c
diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index e732ac1..cd9ba6b 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -88,6 +88,11 @@ config ARCH_UNIPHIER_LD20 select OF_BOARD_SETUP default y
+config ARCH_UNIPHIER_PXS3 + bool "Enable UniPhier PXs3 SoC support" + depends on ARCH_UNIPHIER_V8_MULTI + default y + config CACHE_UNIPHIER bool "Enable the UniPhier L2 cache controller" depends on ARCH_UNIPHIER_32BIT diff --git a/arch/arm/mach-uniphier/board_init.c b/arch/arm/mach-uniphier/board_init.c index ac7e3a6..e89a4c5 100644 --- a/arch/arm/mach-uniphier/board_init.c +++ b/arch/arm/mach-uniphier/board_init.c @@ -168,6 +168,14 @@ static const struct uniphier_initdata uniphier_initdata[] = { .misc_init = uniphier_ld20_misc_init, }, #endif +#if defined(CONFIG_ARCH_UNIPHIER_PXS3) + { + .soc_id = UNIPHIER_PXS3_ID, + .nand_2cs = false, + .sbc_init = uniphier_pxs2_sbc_init, + .pll_init = uniphier_pxs3_pll_init, + }, +#endif }; UNIPHIER_DEFINE_SOCDATA_FUNC(uniphier_get_initdata, uniphier_initdata)
diff --git a/arch/arm/mach-uniphier/clk/Makefile b/arch/arm/mach-uniphier/clk/Makefile index 37df04b..43df670 100644 --- a/arch/arm/mach-uniphier/clk/Makefile +++ b/arch/arm/mach-uniphier/clk/Makefile @@ -25,6 +25,7 @@ obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += clk-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += clk-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD11) += clk-ld11.o pll-ld11.o obj-$(CONFIG_ARCH_UNIPHIER_LD20) += pll-ld20.o +obj-$(CONFIG_ARCH_UNIPHIER_PXS3) += pll-pxs3.o
endif
diff --git a/arch/arm/mach-uniphier/clk/pll-pxs3.c b/arch/arm/mach-uniphier/clk/pll-pxs3.c new file mode 100644 index 0000000..e29d9d0 --- /dev/null +++ b/arch/arm/mach-uniphier/clk/pll-pxs3.c @@ -0,0 +1,7 @@ +/* + * SPDX-License-Identifier: GPL-2.0+ + */ + +void uniphier_pxs3_pll_init(void) +{ +} diff --git a/arch/arm/mach-uniphier/cpu-info.c b/arch/arm/mach-uniphier/cpu-info.c index 94bd98e..75586a3 100644 --- a/arch/arm/mach-uniphier/cpu-info.c +++ b/arch/arm/mach-uniphier/cpu-info.c @@ -50,6 +50,9 @@ int print_cpuinfo(void) case UNIPHIER_LD20_ID: puts("LD20 (SC1401AJ1)"); break; + case UNIPHIER_PXS3_ID: + puts("PXs3"); + break; default: printf("Unknown Processor ID (0x%x)\n", id); return -1; diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index d207806..3aeb5b1 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -112,6 +112,7 @@ void uniphier_ld4_pll_init(void); void uniphier_pro4_pll_init(void); void uniphier_ld11_pll_init(void); void uniphier_ld20_pll_init(void); +void uniphier_pxs3_pll_init(void);
void uniphier_ld4_clk_init(void); void uniphier_pro4_clk_init(void); diff --git a/arch/arm/mach-uniphier/sbc/Makefile b/arch/arm/mach-uniphier/sbc/Makefile index b85b1fe..fe9d85a 100644 --- a/arch/arm/mach-uniphier/sbc/Makefile +++ b/arch/arm/mach-uniphier/sbc/Makefile @@ -10,3 +10,4 @@ obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += sbc-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += sbc-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD11) += sbc-ld11.o obj-$(CONFIG_ARCH_UNIPHIER_LD20) += sbc-ld11.o +obj-$(CONFIG_ARCH_UNIPHIER_PXS3) += sbc-pxs2.o diff --git a/arch/arm/mach-uniphier/soc-info.h b/arch/arm/mach-uniphier/soc-info.h index a85df23..e87ff9c 100644 --- a/arch/arm/mach-uniphier/soc-info.h +++ b/arch/arm/mach-uniphier/soc-info.h @@ -19,6 +19,7 @@ #define UNIPHIER_LD6B_ID 0x2f #define UNIPHIER_LD11_ID 0x31 #define UNIPHIER_LD20_ID 0x32 +#define UNIPHIER_PXS3_ID 0x35
unsigned int uniphier_get_soc_id(void); unsigned int uniphier_get_soc_model(void); diff --git a/doc/README.uniphier b/doc/README.uniphier index a42eaa9..539b1f2 100644 --- a/doc/README.uniphier +++ b/doc/README.uniphier @@ -62,6 +62,10 @@ LD20 reference board: $ make uniphier_ld20_defconfig $ make CROSS_COMPILE=aarch64-linux-gnu-
+PXs3 reference board: + $ make uniphier_v8_defconfig + $ make CROSS_COMPILE=aarch64-linux-gnu- DEVICE_TREE=uniphier-pxs3-ref + You may wish to change the "CROSS_COMPILE=..." to use your favorite compiler.
2017-01-21 18:05 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
- Make SPL optional for ARMv8 SoCs (main motivation is to use ATF)
- Refactor SoC init code
- Add PXs3 SoC support (DT, pinctrl driver, SoC code)
Masahiro Yamada (11): ARM: uniphier: add missing static and const qualifier ARM: uniphier: make SPL optional for ARVv8 SoCs ARM: uniphier: add uniphier_v8_defconfig ARM: uniphier: replace <linux/err.h> with <linux/errno.h> ARM: uniphier: replace <common.h> with <linux/delay.h> where possible ARM: uniphier: simplify SoC ID get function ARM: uniphier: add macro to generate SoC data look-up function ARM: dts: uniphier: compile only DT files that make sense pinctrl: uniphier: support UniPhier PXs3 pinctrl driver ARM: dts: uniphier: add PXs3 SoC/board support ARM: uniphier: add PXs3 SoC support
Series, applied to u-boot-uniphier/master.
Masahiro Yamada
