[U-Boot] [PATCH 3/3 V4] Add board support for hawkboard
Signed-off-by: Sughosh Ganu urwithsughosh@gmail.com --- Changes since V3 * Added README.hawkboard * Moved setting of select_chip to nand_boot function * Removed the superfluous entry in board/davinci/da8xxevm/Makefile added earlier.
MAINTAINERS | 5 + arch/arm/include/asm/arch-davinci/da8xx_common.h | 3 + arch/arm/include/asm/arch-davinci/hardware.h | 5 +- board/davinci/common/Makefile | 2 +- board/davinci/common/davinci_pinmux.c | 105 +++++++++++ board/davinci/common/misc.c | 75 -------- board/davinci/da8xxevm/Makefile | 1 + board/davinci/da8xxevm/hawkboard.c | 69 ++++++++ board/davinci/da8xxevm/hawkboard_nand_spl.c | 164 +++++++++++++++++ boards.cfg | 3 + doc/README.hawkboard | 93 ++++++++++ include/configs/hawkboard.h | 204 ++++++++++++++++++++++ nand_spl/board/davinci/da8xxevm/Makefile | 141 +++++++++++++++ nand_spl/board/davinci/da8xxevm/u-boot.lds | 75 ++++++++ nand_spl/nand_boot.c | 1 + 15 files changed, 869 insertions(+), 77 deletions(-) create mode 100644 board/davinci/common/davinci_pinmux.c create mode 100644 board/davinci/da8xxevm/hawkboard.c create mode 100644 board/davinci/da8xxevm/hawkboard_nand_spl.c create mode 100644 doc/README.hawkboard create mode 100644 include/configs/hawkboard.h create mode 100644 nand_spl/board/davinci/da8xxevm/Makefile create mode 100644 nand_spl/board/davinci/da8xxevm/u-boot.lds
diff --git a/MAINTAINERS b/MAINTAINERS index 9258cb1..2a7d23d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -851,6 +851,11 @@ Alex Z lart SA1100 dnp1110 SA1110
+Syed Mohammed Khasim sm.khasim@gmail.com +Sughosh Ganu urwithsughosh@gmail.com + + hawkboard ARM926EJS (OMAP-L138) + -------------------------------------------------------------------------
Unknown / orphaned boards: diff --git a/arch/arm/include/asm/arch-davinci/da8xx_common.h b/arch/arm/include/asm/arch-davinci/da8xx_common.h index 7ae63a6..bc3092d 100644 --- a/arch/arm/include/asm/arch-davinci/da8xx_common.h +++ b/arch/arm/include/asm/arch-davinci/da8xx_common.h @@ -19,6 +19,9 @@ #ifndef __COMMON_H #define __COMMON_H
+#define HAWKBOARD_KICK0_UNLOCK 0x83e70b13 +#define HAWKBOARD_KICK1_UNLOCK 0x95a4f1e0 + struct lpsc_resource { const int lpsc_no; }; diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index 3520cf8..d006ac1 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -379,7 +379,10 @@ int clk_get(enum davinci_clk_ids id); /* Boot config */ struct davinci_syscfg_regs { dv_reg revid; - dv_reg rsvd[71]; + dv_reg rsvd[13]; + dv_reg kick0; + dv_reg kick1; + dv_reg rsvd1[56]; dv_reg pinmux[20]; dv_reg suspsrc; dv_reg chipsig; diff --git a/board/davinci/common/Makefile b/board/davinci/common/Makefile index 8d9ea00..dd022f6 100644 --- a/board/davinci/common/Makefile +++ b/board/davinci/common/Makefile @@ -29,7 +29,7 @@ endif
LIB = $(obj)lib$(VENDOR).a
-COBJS := misc.o +COBJS := misc.o davinci_pinmux.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/davinci/common/davinci_pinmux.c b/board/davinci/common/davinci_pinmux.c new file mode 100644 index 0000000..ce58f71 --- /dev/null +++ b/board/davinci/common/davinci_pinmux.c @@ -0,0 +1,105 @@ +/* + * DaVinci pinmux functions. + * + * Copyright (C) 2009 Nick Thompson, GE Fanuc Ltd, nick.thompson@gefanuc.com + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2008 Lyrtech <www.lyrtech.com> + * Copyright (C) 2004 Texas Instruments. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/arch/hardware.h> +#include <asm/io.h> +#include <asm/arch/davinci_misc.h> + +/* + * Change the setting of a pin multiplexer field. + * + * Takes an array of pinmux settings similar to: + * + * struct pinmux_config uart_pins[] = { + * { &davinci_syscfg_regs->pinmux[8], 2, 7 }, + * { &davinci_syscfg_regs->pinmux[9], 2, 0 } + * }; + * + * Stepping through the array, each pinmux[n] register has the given value + * set in the pin mux field specified. + * + * The number of pins in the array must be passed (ARRAY_SIZE can provide + * this value conveniently). + * + * Returns 0 if all field numbers and values are in the correct range, + * else returns -1. + */ +int davinci_configure_pin_mux(const struct pinmux_config *pins, + const int n_pins) +{ + int i; + + /* check for invalid pinmux values */ + for (i = 0; i < n_pins; i++) { + if (pins[i].field >= PIN_MUX_NUM_FIELDS || + (pins[i].value & ~PIN_MUX_FIELD_MASK) != 0) + return -1; + } + + /* configure the pinmuxes */ + for (i = 0; i < n_pins; i++) { + const int offset = pins[i].field * PIN_MUX_FIELD_SIZE; + const unsigned int value = pins[i].value << offset; + const unsigned int mask = PIN_MUX_FIELD_MASK << offset; + const dv_reg *mux = pins[i].mux; + + writel(value | (readl(mux) & (~mask)), mux); + } + + return 0; +} + +/* + * Configure multiple pinmux resources. + * + * Takes an pinmux_resource array of pinmux_config and pin counts: + * + * const struct pinmux_resource pinmuxes[] = { + * PINMUX_ITEM(uart_pins), + * PINMUX_ITEM(i2c_pins), + * }; + * + * The number of items in the array must be passed (ARRAY_SIZE can provide + * this value conveniently). + * + * Each item entry is configured in the defined order. If configuration + * of any item fails, -1 is returned and none of the following items are + * configured. On success, 0 is returned. + */ +int davinci_configure_pin_mux_items(const struct pinmux_resource *item, + const int n_items) +{ + int i; + + for (i = 0; i < n_items; i++) { + if (davinci_configure_pin_mux(item[i].pins, + item[i].n_pins) != 0) + return -1; + } + + return 0; +} diff --git a/board/davinci/common/misc.c b/board/davinci/common/misc.c index 71e7822..e97e61c 100644 --- a/board/davinci/common/misc.c +++ b/board/davinci/common/misc.c @@ -105,78 +105,3 @@ void davinci_sync_env_enetaddr(uint8_t *rom_enetaddr) }
#endif /* DAVINCI_EMAC */ - -/* - * Change the setting of a pin multiplexer field. - * - * Takes an array of pinmux settings similar to: - * - * struct pinmux_config uart_pins[] = { - * { &davinci_syscfg_regs->pinmux[8], 2, 7 }, - * { &davinci_syscfg_regs->pinmux[9], 2, 0 } - * }; - * - * Stepping through the array, each pinmux[n] register has the given value - * set in the pin mux field specified. - * - * The number of pins in the array must be passed (ARRAY_SIZE can provide - * this value conveniently). - * - * Returns 0 if all field numbers and values are in the correct range, - * else returns -1. - */ -int davinci_configure_pin_mux(const struct pinmux_config *pins, - const int n_pins) -{ - int i; - - /* check for invalid pinmux values */ - for (i = 0; i < n_pins; i++) { - if (pins[i].field >= PIN_MUX_NUM_FIELDS || - (pins[i].value & ~PIN_MUX_FIELD_MASK) != 0) - return -1; - } - - /* configure the pinmuxes */ - for (i = 0; i < n_pins; i++) { - const int offset = pins[i].field * PIN_MUX_FIELD_SIZE; - const unsigned int value = pins[i].value << offset; - const unsigned int mask = PIN_MUX_FIELD_MASK << offset; - const dv_reg *mux = pins[i].mux; - - writel(value | (readl(mux) & (~mask)), mux); - } - - return 0; -} - -/* - * Configure multiple pinmux resources. - * - * Takes an pinmux_resource array of pinmux_config and pin counts: - * - * const struct pinmux_resource pinmuxes[] = { - * PINMUX_ITEM(uart_pins), - * PINMUX_ITEM(i2c_pins), - * }; - * - * The number of items in the array must be passed (ARRAY_SIZE can provide - * this value conveniently). - * - * Each item entry is configured in the defined order. If configuration - * of any item fails, -1 is returned and none of the following items are - * configured. On success, 0 is returned. - */ -int davinci_configure_pin_mux_items(const struct pinmux_resource *item, - const int n_items) -{ - int i; - - for (i = 0; i < n_items; i++) { - if (davinci_configure_pin_mux(item[i].pins, - item[i].n_pins) != 0) - return -1; - } - - return 0; -} diff --git a/board/davinci/da8xxevm/Makefile b/board/davinci/da8xxevm/Makefile index 17cbe86..1a67351 100644 --- a/board/davinci/da8xxevm/Makefile +++ b/board/davinci/da8xxevm/Makefile @@ -30,6 +30,7 @@ LIB = $(obj)lib$(BOARD).a COBJS-y += common.o COBJS-$(CONFIG_MACH_DAVINCI_DA830_EVM) += da830evm.o COBJS-$(CONFIG_MACH_DAVINCI_DA850_EVM) += da850evm.o +COBJS-$(CONFIG_MACH_DAVINCI_HAWK) += hawkboard.o
COBJS := $(COBJS-y)
diff --git a/board/davinci/da8xxevm/hawkboard.c b/board/davinci/da8xxevm/hawkboard.c new file mode 100644 index 0000000..b672c9d --- /dev/null +++ b/board/davinci/da8xxevm/hawkboard.c @@ -0,0 +1,69 @@ +/* + * Modified for Hawkboard - Syed Mohammed Khasim khasim@beagleboard.org + * + * Copyright (C) 2008 Sekhar Nori, Texas Instruments, Inc. nsekhar@ti.com + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2004 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#include <common.h> +#include <asm/errno.h> +#include <asm/arch/hardware.h> +#include <asm/io.h> +#include <asm/arch/davinci_misc.h> +#include <ns16550.h> +#include <asm/arch/da8xx_common.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + /* arch number of the board */ + gd->bd->bi_arch_number = MACH_TYPE_OMAPL138_HAWKBOARD; + + /* address of boot parameters */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + return 0; +} + +int board_early_init_f(void) +{ + /* + * Kick Registers need to be set to allow access to Pin Mux registers + */ + writel(HAWKBOARD_KICK0_UNLOCK, &davinci_syscfg_regs->kick0); + writel(HAWKBOARD_KICK1_UNLOCK, &davinci_syscfg_regs->kick1); + + /* set cfgchip3 to select mii */ + writel(readl(&davinci_syscfg_regs->cfgchip3) & + ~(1 << 8), &davinci_syscfg_regs->cfgchip3); + + return 0; +} + +int misc_init_r(void) +{ + char buf[32]; + + printf("ARM Clock : %s MHz\n", + strmhz(buf, clk_get(DAVINCI_ARM_CLKID))); + + return 0; +} diff --git a/board/davinci/da8xxevm/hawkboard_nand_spl.c b/board/davinci/da8xxevm/hawkboard_nand_spl.c new file mode 100644 index 0000000..b1f6b44 --- /dev/null +++ b/board/davinci/da8xxevm/hawkboard_nand_spl.c @@ -0,0 +1,164 @@ +/* + * Modified for Hawkboard - Syed Mohammed Khasim khasim@beagleboard.org + * + * Copyright (C) 2008 Sekhar Nori, Texas Instruments, Inc. nsekhar@ti.com + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2004 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#include <common.h> +#include <asm/errno.h> +#include <asm/arch/hardware.h> +#include <asm/io.h> +#include <asm/arch/davinci_misc.h> +#include <ns16550.h> +#include <asm/arch/da8xx_common.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define pinmux(x) (&davinci_syscfg_regs->pinmux[x]) + +static const struct pinmux_config mii_pins[] = { + { pinmux(2), 8, 1 }, + { pinmux(2), 8, 2 }, + { pinmux(2), 8, 3 }, + { pinmux(2), 8, 4 }, + { pinmux(2), 8, 5 }, + { pinmux(2), 8, 6 }, + { pinmux(2), 8, 7 } +}; + +static const struct pinmux_config mdio_pins[] = { + { pinmux(4), 8, 0 }, + { pinmux(4), 8, 1 } +}; + +static const struct pinmux_config nand_pins[] = { + { pinmux(7), 1, 1 }, + { pinmux(7), 1, 2 }, + { pinmux(7), 1, 4 }, + { pinmux(7), 1, 5 }, + { pinmux(9), 1, 0 }, + { pinmux(9), 1, 1 }, + { pinmux(9), 1, 2 }, + { pinmux(9), 1, 3 }, + { pinmux(9), 1, 4 }, + { pinmux(9), 1, 5 }, + { pinmux(9), 1, 6 }, + { pinmux(9), 1, 7 }, + { pinmux(12), 1, 5 }, + { pinmux(12), 1, 6 } +}; + +static const struct pinmux_config uart2_pins[] = { + { pinmux(0), 4, 6 }, + { pinmux(0), 4, 7 }, + { pinmux(4), 2, 4 }, + { pinmux(4), 2, 5 } +}; + +static const struct pinmux_config i2c_pins[] = { + { pinmux(4), 2, 4 }, + { pinmux(4), 2, 5 } +}; + +static const struct pinmux_resource pinmuxes[] = { + PINMUX_ITEM(mii_pins), + PINMUX_ITEM(mdio_pins), + PINMUX_ITEM(i2c_pins), + PINMUX_ITEM(nand_pins), + PINMUX_ITEM(uart2_pins), +}; + +static const struct lpsc_resource lpsc[] = { + { DAVINCI_LPSC_AEMIF }, /* NAND, NOR */ + { DAVINCI_LPSC_SPI1 }, /* Serial Flash */ + { DAVINCI_LPSC_EMAC }, /* image download */ + { DAVINCI_LPSC_UART2 }, /* console */ + { DAVINCI_LPSC_GPIO }, +}; + +void board_init_f(ulong bootflag) +{ + /* + * Kick Registers need to be set to allow access to Pin Mux registers + */ + writel(HAWKBOARD_KICK0_UNLOCK, &davinci_syscfg_regs->kick0); + writel(HAWKBOARD_KICK1_UNLOCK, &davinci_syscfg_regs->kick1); + + /* setup the SUSPSRC for ARM to control emulation suspend */ + writel(readl(&davinci_syscfg_regs->suspsrc) & + ~(DAVINCI_SYSCFG_SUSPSRC_EMAC | DAVINCI_SYSCFG_SUSPSRC_I2C | + DAVINCI_SYSCFG_SUSPSRC_SPI1 | DAVINCI_SYSCFG_SUSPSRC_TIMER0 | + DAVINCI_SYSCFG_SUSPSRC_UART2), &davinci_syscfg_regs->suspsrc); + + /* Power on required peripherals + * ARM does not have acess by default to PSC0 and PSC1 + * assuming here that the DSP bootloader has set the IOPU + * such that PSC access is available to ARM + */ + da8xx_configure_lpsc_items(lpsc, ARRAY_SIZE(lpsc)); + + /* configure pinmux settings */ + davinci_configure_pin_mux_items(pinmuxes, + ARRAY_SIZE(pinmuxes)); + + writel(readl(&davinci_uart2_ctrl_regs->pwremu_mgmt) | + (DAVINCI_UART_PWREMU_MGMT_FREE) | + (DAVINCI_UART_PWREMU_MGMT_URRST) | + (DAVINCI_UART_PWREMU_MGMT_UTRST), + &davinci_uart2_ctrl_regs->pwremu_mgmt); + + NS16550_init((NS16550_t)(DAVINCI_UART2_BASE), + CONFIG_SYS_NS16550_CLK / 16 / CONFIG_BAUDRATE); + + puts("Nand boot...\n"); + + relocate_code(CONFIG_SYS_NAND_U_BOOT_RELOC_SP, (gd_t *)gd, + CONFIG_SYS_NAND_U_BOOT_DST); +} + +void board_init_r(gd_t *gd, ulong dest_addr) +{ + nand_boot(); +} + +void puts(const char *str) +{ + while (*str) + putc(*str++); +} + +void putc(char c) +{ + if (gd->flags & GD_FLG_SILENT) + return; + + if (c == '\n') + NS16550_putc((NS16550_t)(DAVINCI_UART2_BASE), '\r'); + + NS16550_putc((NS16550_t)(DAVINCI_UART2_BASE), c); +} + +void hang(void) +{ + puts("### ERROR ### Please RESET the board ###\n"); + for (;;) + ; +} diff --git a/boards.cfg b/boards.cfg index 6c2a667..e2c73eb 100644 --- a/boards.cfg +++ b/boards.cfg @@ -372,6 +372,9 @@ davinci_sffsdr arm arm926ejs sffsdr davinci davinci davinci_sonata arm arm926ejs sonata davinci davinci da830evm arm arm926ejs da8xxevm davinci davinci da850evm arm arm926ejs da8xxevm davinci davinci +hawkboard arm arm926ejs da8xxevm davinci davinci hawkboard:SYS_TEXT_BASE=0xc1180000 +hawkboard_nand arm arm926ejs da8xxevm davinci davinci hawkboard:SYS_TEXT_BASE=0xc1080000,NAND_U_BOOT +hawkboard_uart arm arm926ejs da8xxevm davinci davinci hawkboard:SYS_TEXT_BASE=0xc1080000 guruplug arm arm926ejs - Marvell kirkwood mv88f6281gtw_ge arm arm926ejs - Marvell kirkwood openrd_base arm arm926ejs - Marvell kirkwood diff --git a/doc/README.hawkboard b/doc/README.hawkboard new file mode 100644 index 0000000..b7afec4 --- /dev/null +++ b/doc/README.hawkboard @@ -0,0 +1,93 @@ +Summary +======= +The README is for the boot procedure used for TI's OMAP-L138 based +hawkboard. The hawkboard comes with a 128MiB Nand flash and a 128MiB +DDR SDRAM along with a host of other controllers. + +The hawkboard is booted in three stages. The initial bootloader which +executes upon reset is the Rom Boot Loader(RBL) which sits in the +internal ROM of the omap. The RBL initialises the memory and the nand +controller, and copies the image stored at a predefined location(block +1) of the nand flash. The image loaded by the RBL to the memory is the +AIS signed nand_spl image. This, in turns copies the u-boot binary +from the nand flash to the memory and jumps to the u-boot entry point. + +AIS is an image format defined by TI for the images that are to be +loaded to memory by the RBL. The image is divided into a series of +sections and the image's entry point is specified. Each section comes +with meta data like the target address the section is to be copied to +and the size of the section, which is used by the RBL to load the +image. At the end of the image the RBL jumps to the image entry +point. + +The secondary stage bootloader(nand_spl) which is loaded by the RBL +then loads the u-boot from a predefined location in the nand to the +memory and jumps to the u-boot entry point. + +The reason a secondary stage bootloader is used is because the ECC +layout expected by the RBL is not the same as that used by +u-boot/linux. This also implies that for flashing the nand_spl image, +we need to use the u-boot which uses the ECC layout expected by the +RBL[1]. Booting u-boot over UART(UART boot) is explained here[2]. + + +Compilation +=========== +Three images might be needed + +* nand_spl - This is the secondary bootloader which boots the u-boot + binary. + + hawkboard_nand_config + + The nand_spl ELF gets generated under nand_spl/u-boot-spl. This + needs to be processed with the AISGen tool for generating the AIS + signed image to be flashed. Steps for generating the AIS image are + explained here[3]. + +* u-boot binary - This is the image flashed to the nand and copied to + the memory by the nand_spl. + + hawkboard_config + +* u-boot for uart boot - This is same as the u-boot binary generated + above, with the sole difference of the CONFIG_SYS_TEXT_BASE being + 0xc1080000, as expected by the RBL. + + hawkboard_uart_config + + +Flashing the images to Nand +=========================== +The nand_spl AIS image needs to be flashed to the block 1 of the +Nand flash, as that is the location the RBL expects the image[4]. For +flashing the nand_spl, boot over the u-boot specified in [1], and +flash the image + +=> tftpboot 0xc0700000 <nand_spl_ais.bin> +=> nand erase 0x20000 0x20000 +=> nand write.e 0xc0700000 0x20000 <nand_spl_size> + +The u-boot binary is flashed at location 0xe0000(block 6) of the nand +flash. The nand_spl loader expects the u-boot at this location. For +flashing the u-boot binary + +=> tftpboot 0xc0700000 u-boot.bin +=> nand erase 0xe0000 0x40000 +=> nand write.e 0xc0700000 0xe0000 <u-boot-size> + + +Links +===== + +[1] + http://code.google.com/p/hawkboard/downloads/detail?name=u-boot_uart_ais_v1.... + +[2] + http://elinux.org/Hawkboard#Booting_u-boot_over_UART + +[3] + http://elinux.org/Hawkboard#Signing_u-boot_for_UART_boot + +[4] + http://processors.wiki.ti.com/index.php/RBL_UBL_and_host_program#RBL_booting... diff --git a/include/configs/hawkboard.h b/include/configs/hawkboard.h new file mode 100644 index 0000000..a11e776 --- /dev/null +++ b/include/configs/hawkboard.h @@ -0,0 +1,204 @@ +/* + * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/ + * + * Based on davinci_dvevm.h. Original Copyrights follow: + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * Board + */ +#define CONFIG_SYS_USE_NAND 1 + +/* + * SoC Configuration + */ +#define CONFIG_MACH_DAVINCI_HAWK +#define CONFIG_ARM926EJS /* arm926ejs CPU core */ +#define CONFIG_SOC_DA8XX /* TI DA8xx SoC */ +#define CONFIG_SYS_CLK_FREQ clk_get(DAVINCI_ARM_CLKID) +#define CONFIG_SYS_OSCIN_FREQ 24000000 +#define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE +#define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SKIP_LOWLEVEL_INIT +#if defined CONFIG_NAND_SPL +#define CONFIG_SKIP_RELOCATE_UBOOT +#endif +#define CONFIG_BOARD_EARLY_INIT_F + +/* + * Memory Info + */ +#define CONFIG_SYS_MALLOC_LEN (1*1024*1024) /* malloc() len */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ +#define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE +#define PHYS_SDRAM_1_SIZE (128 << 20) /* SDRAM size 128MB */ +#define CONFIG_SYS_SDRAM_BASE 0xc0000000 +#define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 -\ + CONFIG_SYS_GBL_DATA_SIZE) + +/* memtest start addr */ +#define CONFIG_SYS_MEMTEST_START (PHYS_SDRAM_1) + +/* memtest will be run on 16MB */ +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + 16*1024*1024) + +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define CONFIG_STACKSIZE (256*1024) /* regular stack */ + +/* + * Serial Driver info + */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE +#define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Network & Ethernet Configuration + */ +#define CONFIG_EMAC_MDIO_PHY_NUM 0x7 +#if !defined(CONFIG_NAND_SPL) +#define CONFIG_DRIVER_TI_EMAC +#endif +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI + +/* + * Nand Flash + */ +#ifdef CONFIG_SYS_USE_NAND +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE (128 << 10) +#define CONFIG_SYS_NAND_BASE DAVINCI_ASYNC_EMIF_DATA_CE3_BASE +#define CONFIG_CLE_MASK 0x10 +#define CONFIG_ALE_MASK 0x8 +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_NAND_DAVINCI +#define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST +#define CFG_DAVINCI_STD_NAND_LAYOUT +#define CONFIG_SYS_NAND_CS 3 +#define CONFIG_SYS_NAND_PAGE_2K +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ +/* Max number of NAND devices */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE_LIST { 0x62000000, } +#define NAND_MAX_CHIPS 1 +/* Block 0--not used by bootcode */ +#define CONFIG_ENV_OFFSET 0x0 + +#define CONFIG_SYS_NAND_PAGE_SIZE (2 << 10) +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0xe0000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x40000 +#define CONFIG_SYS_NAND_U_BOOT_DST 0xc1180000 +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST +#define CONFIG_SYS_NAND_U_BOOT_RELOC_SP (CONFIG_SYS_NAND_U_BOOT_DST - \ + CONFIG_SYS_NAND_U_BOOT_SIZE - \ + CONFIG_SYS_MALLOC_LEN - \ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_NAND_ECCPOS { \ + 24, 25, 26, 27, 28, \ + 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, \ + 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, \ + 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, \ + 59, 60, 61, 62, 63 } +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 10 +#define CONFIG_SYS_NAND_ECCSTEPS (CONFIG_SYS_NAND_PAGE_SIZE / \ + CONFIG_SYS_NAND_ECCSIZE) +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_ECCTOTAL (CONFIG_SYS_NAND_ECCBYTES * \ + CONFIG_SYS_NAND_ECCSTEPS) +#endif /* CONFIG_SYS_USE_NAND */ + +/* + * U-Boot general configuration + */ +#define CONFIG_MISC_INIT_R +#define CONFIG_BOOTFILE "uImage" /* Boot file name */ +#define CONFIG_SYS_PROMPT "hawkboard > " /* Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ +#define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC + +/* + * Linux Information + */ +#define LINUX_BOOT_PARAM_ADDR (CONFIG_SYS_MEMTEST_START + 0x100) +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTARGS \ + "mem=128M console=ttyS2,115200n8 root=/dev/ram0 rw initrd=0xc1180000,"\ + "4M ip=static" +#define CONFIG_BOOTDELAY 3 + +/* + * U-Boot commands + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_ENV +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_MEMORY + +#ifdef CONFIG_SYS_USE_NAND +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_NAND +#endif + +#ifndef CONFIG_DRIVER_TI_EMAC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_MII +#undef CONFIG_CMD_PING +#endif + +#endif /* __CONFIG_H */ diff --git a/nand_spl/board/davinci/da8xxevm/Makefile b/nand_spl/board/davinci/da8xxevm/Makefile new file mode 100644 index 0000000..6102675 --- /dev/null +++ b/nand_spl/board/davinci/da8xxevm/Makefile @@ -0,0 +1,141 @@ +# +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +CONFIG_NAND_SPL = y + +include $(TOPDIR)/config.mk + +LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds +LDFLAGS = -Bstatic -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(PLATFORM_LDFLAGS) +AFLAGS += -DCONFIG_PRELOADER -DCONFIG_NAND_SPL +CFLAGS += -DCONFIG_PRELOADER -DCONFIG_NAND_SPL + +SOBJS = start.o _udivsi3.o _divsi3.o +COBJS = cpu.o davinci_nand.o ns16550.o div0.o davinci_pinmux.o psc.o \ + common.o hawkboard_nand_spl.o nand_boot.o + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/nand_spl/board/$(BOARDDIR) + +nandobj := $(OBJTREE)/nand_spl/ + +ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin \ + $(nandobj)u-boot-spl-16k.bin + +all: $(ALL) + +$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ + +$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot.lds + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + -Map $(nandobj)u-boot-spl.map \ + -o $(nandobj)u-boot-spl + +$(nandobj)u-boot.lds: $(LDSCRIPT) + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ + +# create symbolic links for common files + +# from board directory +$(obj)davinci_pinmux.c: + @rm -f $@ + @ln -s $(TOPDIR)/board/davinci/common/davinci_pinmux.c $@ + +# from drivers/mtd/nand directory +$(obj)davinci_nand.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/mtd/nand/davinci_nand.c $@ + +# from nand_spl directory +$(obj)nand_boot.c: + @rm -f $@ + @ln -s $(TOPDIR)/nand_spl/nand_boot.c $@ + +# from drivers/serial directory +$(obj)ns16550.c: + @rm -f $@ + @ln -sf $(TOPDIR)/drivers/serial/ns16550.c $@ + +# from cpu directory +$(obj)start.S: + @rm -f $@ + ln -s $(TOPDIR)/arch/arm/cpu/arm926ejs/start.S $@ + +# from lib directory +$(obj)_udivsi3.S: + @rm -f $@ + ln -s $(TOPDIR)/arch/arm/lib/_udivsi3.S $@ + +# from lib directory +$(obj)_divsi3.S: + @rm -f $@ + ln -s $(TOPDIR)/arch/arm/lib/_divsi3.S $@ + +# from lib directory +$(obj)div0.c: + @rm -f $@ + ln -s $(TOPDIR)/arch/arm/lib/div0.c $@ + +# from SoC directory +$(obj)cpu.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/arm926ejs/davinci/cpu.c $@ + +# from board directory +$(obj)hawkboard_nand_spl.c: + @rm -f $@ + ln -s $(TOPDIR)/board/davinci/da8xxevm/hawkboard_nand_spl.c $@ + +# from board directory +$(obj)common.c: + @rm -f $@ + ln -s $(TOPDIR)/board/davinci/da8xxevm/common.c $@ + +$(obj)psc.c: + @rm -f $@ + ln -s $(TOPDIR)/arch/arm/cpu/arm926ejs/davinci/psc.c $@ + + +######################################################################### + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/nand_spl/board/davinci/da8xxevm/u-boot.lds b/nand_spl/board/davinci/da8xxevm/u-boot.lds new file mode 100644 index 0000000..f6ccf08 --- /dev/null +++ b/nand_spl/board/davinci/da8xxevm/u-boot.lds @@ -0,0 +1,75 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0xc1080000; + + . = ALIGN(4); + .text : + { + start.o (.text) + cpu.o (.text) + nand_boot.o (.text) + + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { + *(.data) + __datarel_start = .; + *(.data.rel) + __datarelrolocal_start = .; + *(.data.rel.ro.local) + __datarellocal_start = .; + *(.data.rel.local) + __datarelro_start = .; + *(.data.rel.ro) + } + + . = ALIGN(4); + __rel_dyn_start = .; + __rel_dyn_end = .; + __dynsym_start = .; + + __got_start = .; + . = ALIGN(4); + .got : { *(.got) } + + __got_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/nand_spl/nand_boot.c b/nand_spl/nand_boot.c index b9fd6f5..76b8566 100644 --- a/nand_spl/nand_boot.c +++ b/nand_spl/nand_boot.c @@ -236,6 +236,7 @@ void nand_boot(void) /* * Init board specific nand support */ + nand_chip.select_chip = NULL; nand_info.priv = &nand_chip; nand_chip.IO_ADDR_R = nand_chip.IO_ADDR_W = (void __iomem *)CONFIG_SYS_NAND_BASE; nand_chip.dev_ready = NULL; /* preset to NULL */
Applies cleanly to 908614f20f7f0f5df736eed21b88e81ebbf14e86 of git://git.denx.de/u-boot.git; no checkpatch warnings or errors.
Tested on da850evm with NAND, env.oob and tftp.
Tested-by: Ben Gardiner bengardiner@nanometrics.ca
Best Regards, Ben Gardiner
--- Nanometrics Inc. http://www.nanometrics.ca
Changes since V3
- Added README.hawkboard
- Moved setting of select_chip to nand_boot function
- Removed the superfluous entry in board/davinci/da8xxevm/Makefile added earlier.
Can this be reviewed please. I would need to make some changes for the nand_spl due to the removal of CONFIG_SKIP_RELOCATE_UBOOT. I can post the next version incorporating all the review comments along with this change. Thanks.
-sughosh
Ben Gardiner
Sughosh Ganu
