[U-Boot] [PATCH 2/7] Rename SC520 Configuration Options
Options are now all uniformly CONFIG_SYS_SC520_<option>
Signed-off-by: Graeme Russ <graeme.russ at gmail.com> --- board/sc520_cdp/sc520_cdp.c | 16 ++++++++-------- cpu/i386/sc520/sc520.c | 6 +++--- cpu/i386/timer.c | 2 +- include/configs/eNET.h | 12 ++++++------ include/configs/sc520_cdp.h | 14 +++++++------- include/configs/sc520_spunk.h | 10 +++++----- 6 files changed, 30 insertions(+), 30 deletions(-)
diff --git a/board/sc520_cdp/sc520_cdp.c b/board/sc520_cdp/sc520_cdp.c index 779f957..1ddce7e 100644 --- a/board/sc520_cdp/sc520_cdp.c +++ b/board/sc520_cdp/sc520_cdp.c @@ -575,10 +575,10 @@ int spi_eeprom_write(int x, int offset, uchar *buffer, int len)
void spi_init_f(void) { -#ifdef CONFIG_SC520_CDP_USE_SPI +#ifdef CONFIG_SYS_SC520_CDP_USE_SPI spi_eeprom_probe(1); #endif -#ifdef CONFIG_SC520_CDP_USE_MW +#ifdef CONFIG_SYS_SC520_CDP_USE_MW mw_eeprom_probe(2); #endif } @@ -595,13 +595,13 @@ ssize_t spi_read(uchar *addr, int alen, uchar *buffer, int len) offset |= addr[i]; }
-#ifdef CONFIG_SC520_CDP_USE_SPI +#ifdef CONFIG_SYS_SC520_CDP_USE_SPI res = spi_eeprom_read(1, offset, buffer, len); #endif -#ifdef CONFIG_SC520_CDP_USE_MW +#ifdef CONFIG_SYS_SC520_CDP_USE_MW res = mw_eeprom_read(2, offset, buffer, len); #endif -#if !defined(CONFIG_SC520_CDP_USE_SPI) && !defined(CONFIG_SC520_CDP_USE_MW) +#if !defined(CONFIG_SYS_SC520_CDP_USE_SPI) && !defined(CONFIG_SYS_SC520_CDP_USE_MW) res = 0; #endif return res; @@ -619,13 +619,13 @@ ssize_t spi_write(uchar *addr, int alen, uchar *buffer, int len) offset |= addr[i]; }
-#ifdef CONFIG_SC520_CDP_USE_SPI +#ifdef CONFIG_SYS_SC520_CDP_USE_SPI res = spi_eeprom_write(1, offset, buffer, len); #endif -#ifdef CONFIG_SC520_CDP_USE_MW +#ifdef CONFIG_SYS_SC520_CDP_USE_MW res = mw_eeprom_write(2, offset, buffer, len); #endif -#if !defined(CONFIG_SC520_CDP_USE_SPI) && !defined(CONFIG_SC520_CDP_USE_MW) +#if !defined(CONFIG_SYS_SC520_CDP_USE_SPI) && !defined(CONFIG_SYS_SC520_CDP_USE_MW) res = 0; #endif return res; diff --git a/cpu/i386/sc520/sc520.c b/cpu/i386/sc520/sc520.c index b958f8d..2ac3fd4 100644 --- a/cpu/i386/sc520/sc520.c +++ b/cpu/i386/sc520/sc520.c @@ -28,7 +28,7 @@ #include <common.h> #include <config.h> #include <pci.h> -#ifdef CONFIG_SC520_SSI +#ifdef CONFIG_SYS_SC520_SSI #include <asm/ic/ssi.h> #endif #include <asm/io.h> @@ -390,7 +390,7 @@ void pci_sc520_init(struct pci_controller *hose)
#endif
-#ifdef CONFIG_SYS_TIMER_SC520 +#ifdef CONFIG_SYS_SC520_TIMER
void reset_timer(void) @@ -504,7 +504,7 @@ u8 ssi_rx_byte(void) return read_mmcr_byte(SC520_SSIRCV); }
-#ifdef CONFIG_SYS_RESET_SC520 +#ifdef CONFIG_SYS_SC520_RESET void reset_cpu(ulong addr) { printf("Resetting using SC520 MMCR\n"); diff --git a/cpu/i386/timer.c b/cpu/i386/timer.c index 46db23f..79039c2 100644 --- a/cpu/i386/timer.c +++ b/cpu/i386/timer.c @@ -72,7 +72,7 @@ int timer_init(void) }
-#ifdef CONFIG_SYS_TIMER_GENERIC +#ifdef CONFIG_SYS_GENERIC_TIMER
/* the unit for these is CONFIG_SYS_HZ */
diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 447c7bc..2ae79d8 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -40,8 +40,8 @@ #define DEBUG_PARSER
#define CONFIG_X86 1 /* Intel X86 CPU */ -#define CONFIG_SC520 1 /* AMD SC520 */ -#define CONFIG_SC520_SSI +#define CONFIG_SYS_SC520 1 /* AMD SC520 */ +#define CONFIG_SYS_SC520_SSI #define CONFIG_SHOW_BOOT_PROGRESS 1 #define CONFIG_LAST_STAGE_INIT 1
@@ -142,10 +142,10 @@ * CPU Features */ #define CONFIG_SYS_SC520_HIGH_SPEED 0 /* 100 or 133MHz */ -#undef CONFIG_SYS_RESET_SC520 /* use SC520 MMCR's to reset cpu */ -#define CONFIG_SYS_TIMER_SC520 /* use SC520 swtimers */ -#undef CONFIG_SYS_TIMER_GENERIC /* use the i8254 PIT timers */ -#undef CONFIG_SYS_TIMER_TSC /* use the Pentium TSC timers */ +#undef CONFIG_SYS_SC520_RESET /* use SC520 MMCR's to reset cpu */ +#define CONFIG_SYS_SC520_TIMER /* use SC520 swtimers */ +#undef CONFIG_SYS_GENERIC_TIMER /* use the i8254 PIT timers */ +#undef CONFIG_SYS_TSC_TIMER /* use the Pentium TSC timers */ #define CONFIG_SYS_USE_SIO_UART 0 /* prefer the uarts on the SIO to those * in the SC520 on the CDP */
diff --git a/include/configs/sc520_cdp.h b/include/configs/sc520_cdp.h index 9f2357b..cb0de42 100644 --- a/include/configs/sc520_cdp.h +++ b/include/configs/sc520_cdp.h @@ -35,7 +35,7 @@ */
#define CONFIG_X86 1 /* This is a X86 CPU */ -#define CONFIG_SC520 1 /* Include support for AMD SC520 */ +#define CONFIG_SYS_SC520 1 /* Include support for AMD SC520 */ #define CONFIG_ALI152X 1 /* Include support for Ali 152x SIO */
#define CONFIG_SYS_SDRAM_PRECHARGE_DELAY 6 /* 6T */ @@ -47,10 +47,10 @@ #define CONFIG_SYS_SDRAM_CAS_LATENCY_3T
#define CONFIG_SYS_SC520_HIGH_SPEED 0 /* 100 or 133MHz */ -#undef CONFIG_SYS_RESET_SC520 /* use SC520 MMCR's to reset cpu */ -#undef CONFIG_SYS_TIMER_SC520 /* use SC520 swtimers */ -#define CONFIG_SYS_TIMER_GENERIC 1 /* use the i8254 PIT timers */ -#undef CONFIG_SYS_TIMER_TSC /* use the Pentium TSC timers */ +#undef CONFIG_SYS_SC520_RESET /* use SC520 MMCR's to reset cpu */ +#undef CONFIG_SYS_SC520_TIMER /* use SC520 swtimers */ +#define CONFIG_SYS_GENERIC_TIMER 1 /* use the i8254 PIT timers */ +#undef CONFIG_SYS_TSC_TIMER /* use the Pentium TSC timers */ #define CONFIG_SYS_USE_SIO_UART 0 /* prefer the uarts on the SIO to those * in the SC520 on the CDP */
@@ -147,8 +147,8 @@ #define CONFIG_SPI #define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment EEPROM 16k is SPI is used or 128 bytes if MW is used*/ #define CONFIG_ENV_OFFSET 0 -#define CONFIG_SC520_CDP_USE_SPI /* Store configuration in the SPI part */ -#undef CONFIG_SC520_CDP_USE_MW /* Store configuration in the MicroWire part */ +#define CONFIG_SYS_SC520_CDP_USE_SPI /* Store configuration in the SPI part */ +#undef CONFIG_SYS_SC520_CDP_USE_MW /* Store configuration in the MicroWire part */ #define CONFIG_SPI_X 1
/* diff --git a/include/configs/sc520_spunk.h b/include/configs/sc520_spunk.h index 50af732..3e86184 100644 --- a/include/configs/sc520_spunk.h +++ b/include/configs/sc520_spunk.h @@ -34,7 +34,7 @@ */
#define CONFIG_SYS_SDRAM_PRECHARGE_DELAY 6 /* 6T */ #define CONFIG_SYS_SDRAM_REFRESH_RATE 78 /* 7.8uS (choices are 7.8, 15.6, 31.2 or 62.5uS) */ @@ -45,10 +45,10 @@ #define CONFIG_SYS_SDRAM_CAS_LATENCY_3T
#define CONFIG_SYS_STACK_SIZE 0x8000 /* Size of bootloader stack */
Dear Graeme Russ,
Applied to "next" branch. Thanks.
Graeme Russ
