[U-Boot-Users] [PATCH] 16-bit NAND support
This is a patch to add 16-bit NAND support to u-boot. It doesn't change any existing 8-bit NAND code so it shouldn't affect any existing boards that have 8-bit chips. I tested it in 2 TI OMAP boards, one using software to access chip, the other one using hardware NAND controller.
Regards, Jian
In message BA2832125C3C994384FCC051CDFC7369B8A34F@dlee2k05.ent.ti.com you wrote:
Did you actually _check_ if it has impact on exiting boards? Impact on parameters like code size, for example?
Hi, I have applied ur patch to my u-boot1.1.1 code and one error is generated.The log is shown below.can any one please tell me what can be the problem.And also pls tell me how do I select that whether I m going to use 8bit Nand flash or 16bit Nand flash.Is there any CONFIG variable is required to define.I m working on a 16bit Nand flash from the Samsung.
patching file include/linux/mtd/nand.h patching file include/linux/mtd/nand_ids.h patching file common/cmd_nand.c Hunk #2 FAILED at 23. Hunk #3 succeeded at 390 (offset -4 lines). Hunk #5 succeeded at 710 (offset -4 lines). Hunk #7 succeeded at 863 (offset -4 lines). Hunk #9 succeeded at 983 (offset -4 lines). Hunk #11 succeeded at 1043 (offset -4 lines). Hunk #13 succeeded at 1144 (offset -4 lines). Hunk #15 succeeded at 1222 (offset -4 lines). Hunk #17 succeeded at 1303 (offset -4 lines). Hunk #19 succeeded at 1374 (offset -4 lines). Hunk #21 succeeded at 1466 (offset -4 lines). 1 out of 22 hunks FAILED -- saving rejects to file common/cmd_nand.c.rej
Bye
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net] On Behalf Of Zhang, Jian Sent: Wednesday, November 03, 2004 3:52 AM To: u-boot-users@lists.sourceforge.net Cc: Zhang, Jian; Johnson, Steve-OMAP Subject: [U-Boot-Users] [PATCH] 16-bit NAND support
Regards, Jian
Please use current code (top of CVS).
Added, thanks.
Please don't forget the CHANGELOG entry, and _please_ stick to the Coding Style!
Pankaj GOYAL
Zhang, Jian
