[U-Boot] [PATCH 1/2][v2] powerpc: spiflash:Add corenet devices support in eSPI SPL
Existing eSPI SPL framework assumes booting from spi-image with boot_format header which contains final u-boot Image offset and size. No such header is present in case of corenet devices like T1040 as corenet deivces use PBI-RCW based intialization.
So, for corenet deives, SPL bootloader use values provided at compilation time. These values can be defined in board specific config file.
Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- Changes for v2: Updated description based on Sun York's inputs
drivers/mtd/spi/fsl_espi_spl.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/spi/fsl_espi_spl.c b/drivers/mtd/spi/fsl_espi_spl.c index 6263d8c..e5ac79b 100644 --- a/drivers/mtd/spi/fsl_espi_spl.c +++ b/drivers/mtd/spi/fsl_espi_spl.c @@ -31,6 +31,10 @@ void spi_boot(void) hang(); }
+#ifdef CONFIG_FSL_CORENET + offset = CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS; + code_len = CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE; +#else /* * Load U-Boot image from SPI flash into RAM */ @@ -50,6 +54,7 @@ void spi_boot(void) code_len = *(u32 *)(buf + ESPI_BOOT_IMAGE_SIZE); /* Skip spl code */ code_len = code_len - CONFIG_SPL_MAX_SIZE; +#endif /* copy code to DDR */ spi_flash_read(flash, offset, code_len, (void *)CONFIG_SYS_SPI_FLASH_U_BOOT_DST);
Priyanka Jain
