[U-Boot] [PATCH 1/1] efi_loader: struct efi_simple_text_input_protocol
%s/efi_simple_input_interface/efi_simple_text_input_protocol/
We should be consistent in the naming of the EFI protocol interface structures. The protocol is called EFI_SIMPLE_TEXT_INPUT_PROTOCOL.
%s/ExtendedVerification/extended_verification/
Use consistent naming of function parameters. Do not use CamelCase.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/serial/serial_efi.c | 2 +- include/efi_api.h | 10 +++++----- include/efi_loader.h | 2 +- include/efi_selftest.h | 2 +- lib/efi_loader/efi_console.c | 6 +++--- lib/efi_selftest/efi_selftest_console.c | 2 +- 6 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/serial/serial_efi.c b/drivers/serial/serial_efi.c index 399dfd65fe..1b54d1880f 100644 --- a/drivers/serial/serial_efi.c +++ b/drivers/serial/serial_efi.c @@ -17,7 +17,7 @@
/* Information about the efi console */ struct serial_efi_priv { - struct efi_simple_input_interface *con_in; + struct efi_simple_text_input_protocol *con_in; struct efi_simple_text_output_protocol *con_out; struct efi_input_key key; bool have_key; diff --git a/include/efi_api.h b/include/efi_api.h index 1efc448184..26e88f494c 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -308,7 +308,7 @@ struct efi_system_table { u16 *fw_vendor; /* physical addr of wchar_t vendor string */ u32 fw_revision; efi_handle_t con_in_handle; - struct efi_simple_input_interface *con_in; + struct efi_simple_text_input_protocol *con_in; efi_handle_t con_out_handle; struct efi_simple_text_output_protocol *con_out; efi_handle_t stderr_handle; @@ -598,11 +598,11 @@ struct efi_input_key { EFI_GUID(0x387477c1, 0x69c7, 0x11d2, \ 0x8e, 0x39, 0x0, 0xa0, 0xc9, 0x69, 0x72, 0x3b)
-struct efi_simple_input_interface { - efi_status_t(EFIAPI *reset)(struct efi_simple_input_interface *this, - bool ExtendedVerification); +struct efi_simple_text_input_protocol { + efi_status_t(EFIAPI *reset)(struct efi_simple_text_input_protocol *this, + bool extended_verification); efi_status_t(EFIAPI *read_key_stroke)( - struct efi_simple_input_interface *this, + struct efi_simple_text_input_protocol *this, struct efi_input_key *key); struct efi_event *wait_for_key; }; diff --git a/include/efi_loader.h b/include/efi_loader.h index 736e82c506..3bf059b447 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -92,7 +92,7 @@ extern struct efi_runtime_services efi_runtime_services; extern struct efi_system_table systab;
extern struct efi_simple_text_output_protocol efi_con_out; -extern struct efi_simple_input_interface efi_con_in; +extern struct efi_simple_text_input_protocol efi_con_in; extern struct efi_console_control_protocol efi_console_control; extern const struct efi_device_path_to_text_protocol efi_device_path_to_text; /* implementation of the EFI_DEVICE_PATH_UTILITIES_PROTOCOL */ diff --git a/include/efi_selftest.h b/include/efi_selftest.h index d0a76d70ca..59b3c080bd 100644 --- a/include/efi_selftest.h +++ b/include/efi_selftest.h @@ -53,7 +53,7 @@ enum efi_test_phase { };
extern struct efi_simple_text_output_protocol *con_out; -extern struct efi_simple_input_interface *con_in; +extern struct efi_simple_text_input_protocol *con_in;
/* * Exit the boot services. diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 277eb91e52..426567c946 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -391,7 +391,7 @@ struct efi_simple_text_output_protocol efi_con_out = { };
static efi_status_t EFIAPI efi_cin_reset( - struct efi_simple_input_interface *this, + struct efi_simple_text_input_protocol *this, bool extended_verification) { EFI_ENTRY("%p, %d", this, extended_verification); @@ -446,7 +446,7 @@ out: }
static efi_status_t EFIAPI efi_cin_read_key_stroke( - struct efi_simple_input_interface *this, + struct efi_simple_text_input_protocol *this, struct efi_input_key *key) { struct efi_input_key pressed_key = { @@ -558,7 +558,7 @@ static efi_status_t EFIAPI efi_cin_read_key_stroke( return EFI_EXIT(EFI_SUCCESS); }
-struct efi_simple_input_interface efi_con_in = { +struct efi_simple_text_input_protocol efi_con_in = { .reset = efi_cin_reset, .read_key_stroke = efi_cin_read_key_stroke, .wait_for_key = NULL, diff --git a/lib/efi_selftest/efi_selftest_console.c b/lib/efi_selftest/efi_selftest_console.c index eb139c127c..42f51b6520 100644 --- a/lib/efi_selftest/efi_selftest_console.c +++ b/lib/efi_selftest/efi_selftest_console.c @@ -9,7 +9,7 @@ #include <vsprintf.h>
struct efi_simple_text_output_protocol *con_out; -struct efi_simple_input_interface *con_in; +struct efi_simple_text_input_protocol *con_in;
/* * Print a MAC address to an u16 string
