[U-Boot] [PATCH v2 0/2] avb2.0: fix multiple compilation issues in sandbox
This series of two patches fixes compilation issues when AVB 2.0 is enabled for the 'sandbox' architecture:
1. Since libavb library alone is highly portable, it introduce dedicated Kconfig symbol for AVB compiler-dependent operations, so it's possible to build libavb separately. 2. Add CONFIG_FASTBOOT dependency, as fastboot buffer is re-used in partition verification operations. 3. Use blk_dread()/blk_dwrite() in mmc_read()/mmc_write() AVB operation implementations. This fixes compilation issues when CONFIG_BLK is enabled.
Changes for v2: - Updated eb81cae89f ("avb2.0: add proper dependencies") commit message (added more details). - Extended description of AVB_VERIFY Kconfig symbol. - Replaced CONFIG_LIBAVB to CONFIG_AVB_VERIFY in common/Makefile.
Igor Opaniuk (2): avb2.0: add proper dependencies avb2.0: use block API in AVB ops
cmd/Kconfig | 2 +- common/Kconfig | 10 ++++++++++ common/Makefile | 2 +- common/avb_verify.c | 9 +++++---- doc/README.avb2 | 1 + 5 files changed, 18 insertions(+), 6 deletions(-)
-- 2.7.4
1. Since libavb library alone is highly portable, introduce dedicated Kconfig symbol for AVB bootloader-dependent operations, so it's possible to build libavb separately. AVB bootloader-dependent operations include: * Helpers to process strings in order to build OS bootargs. * Helpers to access MMC, similar to drivers/fastboot/fb_mmc.c. * Helpers to alloc/init/free avb ops. 2. Add CONFIG_FASTBOOT dependency, as fastboot buffer is re-used in partition verification operations.
Reported-by: Eugeniu Rosca rosca.eugeniu@gmail.com Signed-off-by: Igor Opaniuk igor.opaniuk@linaro.org --- cmd/Kconfig | 2 +- common/Kconfig | 10 ++++++++++ common/Makefile | 2 +- doc/README.avb2 | 1 + 4 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index aec2090..b3e030c 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1771,7 +1771,7 @@ config CMD_TRACE
config CMD_AVB bool "avb - Android Verified Boot 2.0 operations" - depends on LIBAVB + depends on AVB_VERIFY default n help Enables a "avb" command to perform verification of partitions using diff --git a/common/Kconfig b/common/Kconfig index 4c7a1a9..04fcb91 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -631,6 +631,16 @@ config HASH and the algorithms it supports are defined in common/hash.c. See also CMD_HASH for command-line access.
+config AVB_VERIFY + bool "Build Android Verified Boot operations" + depends on LIBAVB && FASTBOOT + help + This option enables compilation of bootloader-dependent operations, + used by Android Verified Boot 2.0 library (libavb). Includes: + * Helpers to process strings in order to build OS bootargs. + * Helpers to access MMC, similar to drivers/fastboot/fb_mmc.c. + * Helpers to alloc/init/free avb ops. + endmenu
menu "Update support" diff --git a/common/Makefile b/common/Makefile index 66584f8..7100541 100644 --- a/common/Makefile +++ b/common/Makefile @@ -121,4 +121,4 @@ obj-$(CONFIG_$(SPL_)LOG_CONSOLE) += log_console.o obj-y += s_record.o obj-y += xyzModem.o
-obj-$(CONFIG_LIBAVB) += avb_verify.o +obj-$(CONFIG_AVB_VERIFY) += avb_verify.o diff --git a/doc/README.avb2 b/doc/README.avb2 index 67784b5..120279f 100644 --- a/doc/README.avb2 +++ b/doc/README.avb2 @@ -58,6 +58,7 @@ Slot verification result: ERROR_IO ----------------------------------- The following options must be enabled: CONFIG_LIBAVB=y +CONFIG_AVB_VERIFY=y CONFIG_CMD_AVB=y
Hi Igor,
On Tue, Jul 17, 2018 at 02:33:25PM +0300, Igor Opaniuk wrote:
- Since libavb library alone is highly portable, introduce dedicated
- Helpers to process strings in order to build OS bootargs.
- Helpers to access MMC, similar to drivers/fastboot/fb_mmc.c.
- Helpers to alloc/init/free avb ops.
- Add CONFIG_FASTBOOT dependency, as fastboot buffer is
With this patch I am now able to compile libavb natively for x86_64, as well as cross-compile it for arm and aarch64, w/o the avb_verify wrapper. Thanks for the improvements in the patch/Kconfig description.
Reviewed-by: Eugeniu Rosca rosca.eugeniu@gmail.com Tested-by: Eugeniu Rosca rosca.eugeniu@gmail.com
Reported-by: Eugeniu Rosca rosca.eugeniu@gmail.com Signed-off-by: Igor Opaniuk igor.opaniuk@linaro.org Reviewed-by: Eugeniu Rosca rosca.eugeniu@gmail.com Tested-by: Eugeniu Rosca rosca.eugeniu@gmail.com
Signed-off-by: Igor Opaniuk igor.opaniuk@linaro.org --- common/avb_verify.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/common/avb_verify.c b/common/avb_verify.c index f9a00f8..20e35ad 100644 --- a/common/avb_verify.c +++ b/common/avb_verify.c @@ -5,6 +5,7 @@ */
#include <avb_verify.h> +#include <blk.h> #include <fastboot.h> #include <image.h> #include <malloc.h> @@ -288,8 +289,8 @@ static unsigned long mmc_read_and_flush(struct mmc_part *part, tmp_buf = buffer; }
- blks = part->mmc->block_dev.block_read(part->mmc_blk, - start, sectors, tmp_buf); + blks = blk_dread(part->mmc_blk, + start, sectors, tmp_buf); /* flush cache after read */ flush_cache((ulong)tmp_buf, sectors * part->info.blksz);
@@ -327,8 +328,8 @@ static unsigned long mmc_write(struct mmc_part *part, lbaint_t start, tmp_buf = buffer; }
- return part->mmc->block_dev.block_write(part->mmc_blk, - start, sectors, tmp_buf); + return blk_dwrite(part->mmc_blk, + start, sectors, tmp_buf); }
static struct mmc_part *get_partition(AvbOps *ops, const char *partition)
- blks = blk_dread(part->mmc_blk,
/* flush cache after read */ flush_cache((ulong)tmp_buf, sectors * part->info.blksz);start, sectors, tmp_buf);
- return blk_dwrite(part->mmc_blk,
2.7.4
I confirm this patch fixes below compilation failure on sandbox (LIBAVB=y, AVB_VERIFY=y, FASTBOOT=y, BLK=y):
common/avb_verify.c: In function ‘mmc_read_and_flush’: common/avb_verify.c:291:18: error: ‘struct mmc’ has no member named ‘block_dev’ blks = part->mmc->block_dev.block_read(part->mmc_blk, ^~ common/avb_verify.c: In function ‘mmc_write’: common/avb_verify.c:330:18: error: ‘struct mmc’ has no member named ‘block_dev’ return part->mmc->block_dev.block_write(part->mmc_blk,
With this patch, avb_verify compiles equally well with BLK=y and BLK=n.
Thanks, Eugeniu.
Signed-off-by: Igor Opaniuk igor.opaniuk@linaro.org Tested-by: Eugeniu Rosca rosca.eugeniu@gmail.com
Eugeniu Rosca
Igor Opaniuk
