[PATCH v2 0/4] board: fsl: lx2160ardb: add networking support for RevC
This patch set adds networking support for the LX2160A-RDB revC board. The main difference is that the 10G Aquantia PHYs are at different MDIO bus addresses. To address this, the u-boot's DTS (in case of DM_ETH) and the kernel's DTS need to undergo a fixup.
This patch set applies cleanly on top of the following, yet unnaccepted, patch: https://patchwork.ozlabs.org/project/uboot/patch/20210417180332.1164345-1-wa...
Changes in v2: - in 1/4: trigger the i2c node fixup if the board rev is 'C' or greater
Florin Chiculita (3): board: fsl: lx2160ardb: add api for obtaining board revision board: fsl: lx2160ardb: add support for lx2160ardb revC board board: fsl: lx2160ardb: add dts fixup function for RevC
Ioana Ciornei (1): board: fsl: lx2160ardb: add dts fixup for RevC
board/freescale/lx2160a/eth_lx2160ardb.c | 160 ++++++++++++++++++++++- board/freescale/lx2160a/lx2160a.c | 21 ++- board/freescale/lx2160a/lx2160a.h | 7 +- include/configs/lx2160ardb.h | 5 +- 4 files changed, 186 insertions(+), 7 deletions(-)
From: Florin Chiculita florinlaurentiu.chiculita@nxp.com
Add new API for obtaining board revision and trigger the i2c node fixup with this new API.
Signed-off-by: Florin Chiculita florinlaurentiu.chiculita@nxp.com Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com --- board/freescale/lx2160a/lx2160a.c | 13 ++++++++++--- board/freescale/lx2160a/lx2160a.h | 6 +++++- 2 files changed, 15 insertions(+), 4 deletions(-)
diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index 8f75b48f956b..9f1a6979258c 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -564,6 +564,15 @@ int config_board_mux(void) } #endif
+#if CONFIG_IS_ENABLED(TARGET_LX2160ARDB) +u8 get_board_rev(void) +{ + u8 board_rev = (QIXIS_READ(arch) & 0xf) - 1 + 'A'; + + return board_rev; +} +#endif + unsigned long get_board_sys_clk(void) { #if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) @@ -847,7 +856,6 @@ int ft_board_setup(void *blob, struct bd_info *bd) u64 mc_memory_base = 0; u64 mc_memory_size = 0; u16 total_memory_banks; - u8 board_rev;
ft_cpu_setup(blob, bd);
@@ -903,8 +911,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) fdt_fixup_icid(blob);
if (IS_ENABLED(CONFIG_TARGET_LX2160ARDB)) { - board_rev = (QIXIS_READ(arch) & 0xf) - 1 + 'A'; - if (board_rev == 'C') + if (get_board_rev() >= 'C') fdt_fixup_i2c_thermal_node(blob); }
diff --git a/board/freescale/lx2160a/lx2160a.h b/board/freescale/lx2160a/lx2160a.h index 52b020765dc6..cf56cefb45a3 100644 --- a/board/freescale/lx2160a/lx2160a.h +++ b/board/freescale/lx2160a/lx2160a.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2020 NXP + * Copyright 2020-2021 NXP */
#ifndef __LX2160_H @@ -58,4 +58,8 @@ #endif #endif
+#if CONFIG_IS_ENABLED(TARGET_LX2160ARDB) +u8 get_board_rev(void); +#endif + #endif /* __LX2160_H */
New RevC LX2160A-RDB board doesn't have any 40G PHY and the 10G Aquantia PHYs have different MDIO bus addresses, thus a different init is required. This patch adds support for the non-DM_ETH use of the LX2160ARDB RevC board.
Signed-off-by: Florin Chiculita florinlaurentiu.chiculita@nxp.com Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com --- board/freescale/lx2160a/eth_lx2160ardb.c | 52 +++++++++++++++++++++++- include/configs/lx2160ardb.h | 5 ++- 2 files changed, 55 insertions(+), 2 deletions(-)
diff --git a/board/freescale/lx2160a/eth_lx2160ardb.c b/board/freescale/lx2160a/eth_lx2160ardb.c index 15cbc58d59a7..8fd2a501de16 100644 --- a/board/freescale/lx2160a/eth_lx2160ardb.c +++ b/board/freescale/lx2160a/eth_lx2160ardb.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018, 2020 NXP + * Copyright 2018-2021 NXP * */
@@ -41,6 +41,49 @@ static bool get_inphi_phy_id(struct mii_dev *bus, int addr, int devad) return false; }
+int setup_eth_rev_c(u32 srds_p) +{ + struct mii_dev *bus; + int i; + + /* difference between SerDes1 protocols 18/19 is 4x10G vs. 40G */ + switch (srds_p) { + case 19: + wriop_init_dpmac_enet_if(WRIOP1_DPMAC2, + PHY_INTERFACE_MODE_XLAUI); + break; + case 18: + for (i = WRIOP1_DPMAC7; i <= WRIOP1_DPMAC10; i++) + wriop_init_dpmac_enet_if(i, PHY_INTERFACE_MODE_XFI); + break; + default: + printf("SerDes1 protocol 0x%x is not supported on LX2160ARDB\n", + srds_p); + return -1; + } + + /* common interfaces for SerDes1 protocols 18 and 19 initialization */ + wriop_set_phy_address(WRIOP1_DPMAC3, 0, AQR113C_PHY_ADDR1); + wriop_set_phy_address(WRIOP1_DPMAC4, 0, AQR113C_PHY_ADDR2); + wriop_set_phy_address(WRIOP1_DPMAC5, 0, INPHI_PHY_ADDR1); + wriop_set_phy_address(WRIOP1_DPMAC6, 0, INPHI_PHY_ADDR1); + wriop_set_phy_address(WRIOP1_DPMAC17, 0, RGMII_PHY_ADDR1); + wriop_set_phy_address(WRIOP1_DPMAC18, 0, RGMII_PHY_ADDR2); + + /* assign DPMAC/PHY to MDIO bus */ + bus = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO1_NAME); + wriop_set_mdio(WRIOP1_DPMAC3, bus); + wriop_set_mdio(WRIOP1_DPMAC4, bus); + wriop_set_mdio(WRIOP1_DPMAC17, bus); + wriop_set_mdio(WRIOP1_DPMAC18, bus); + + bus = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO2_NAME); + wriop_set_mdio(WRIOP1_DPMAC5, bus); + wriop_set_mdio(WRIOP1_DPMAC6, bus); + + return 0; +} + int board_eth_init(struct bd_info *bis) { #if defined(CONFIG_FSL_MC_ENET) @@ -70,6 +113,13 @@ int board_eth_init(struct bd_info *bis) fm_memac_mdio_init(bis, &mdio_info);
dev = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO2_NAME); + + /* new LX2160A-RDB2 revC board uses phy-less 25G/40G interfaces */ + if (get_board_rev() == 'C') { + setup_eth_rev_c(srds_s1); + goto next; + } + switch (srds_s1) { case 19: wriop_set_phy_address(WRIOP1_DPMAC2, 0, diff --git a/include/configs/lx2160ardb.h b/include/configs/lx2160ardb.h index 097f1224c90f..a7e9753dc174 100644 --- a/include/configs/lx2160ardb.h +++ b/include/configs/lx2160ardb.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2018,2020 NXP + * Copyright 2018-2021 NXP */
#ifndef __LX2_RDB_H @@ -21,6 +21,9 @@ #if defined(CONFIG_FSL_MC_ENET) #define CONFIG_MII #define CONFIG_ETHPRIME "DPMAC1@xgmii" + +#define AQR113C_PHY_ADDR1 0x0 +#define AQR113C_PHY_ADDR2 0x08 #endif
/* EMC2305 */
Since the new RevC LX2160A-RDB board has its 10G Aquantia PHYs at different MDIO bus addresses, we must update both the kernel DTS and u-boot's DTS (in case of DM_ETH) in case the board is indeed RevC. Use the newly introduced get_board_rev() function to trigger a fixup of the kernel DTS to properly match the actual PHY addresses. All this is encapsulated in the fdt_fixup_board_phy_revc() function which will be used in the next patch.
Signed-off-by: Florin Chiculita florinlaurentiu.chiculita@nxp.com Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com --- board/freescale/lx2160a/eth_lx2160ardb.c | 106 +++++++++++++++++++++++ board/freescale/lx2160a/lx2160a.h | 1 + 2 files changed, 107 insertions(+)
diff --git a/board/freescale/lx2160a/eth_lx2160ardb.c b/board/freescale/lx2160a/eth_lx2160ardb.c index 8fd2a501de16..c693ad9a0a4a 100644 --- a/board/freescale/lx2160a/eth_lx2160ardb.c +++ b/board/freescale/lx2160a/eth_lx2160ardb.c @@ -231,6 +231,112 @@ void reset_phy(void) } #endif /* CONFIG_RESET_PHY_R */
+static int fdt_get_dpmac_node(void *fdt, int dpmac_id) +{ + char dpmac_str[] = "dpmacs@00"; + int offset, dpmacs_offset; + + /* get the dpmac offset */ + dpmacs_offset = fdt_path_offset(fdt, "/soc/fsl-mc/dpmacs"); + if (dpmacs_offset < 0) + dpmacs_offset = fdt_path_offset(fdt, "/fsl-mc/dpmacs"); + + if (dpmacs_offset < 0) { + printf("dpmacs node not found in device tree\n"); + return dpmacs_offset; + } + + sprintf(dpmac_str, "dpmac@%x", dpmac_id); + offset = fdt_subnode_offset(fdt, dpmacs_offset, dpmac_str); + if (offset < 0) { + sprintf(dpmac_str, "ethernet@%x", dpmac_id); + offset = fdt_subnode_offset(fdt, dpmacs_offset, dpmac_str); + if (offset < 0) { + printf("dpmac@%x/ethernet@%x node not found in device tree\n", + dpmac_id, dpmac_id); + return offset; + } + } + + return offset; +} + +static int fdt_update_phy_addr(void *fdt, int dpmac_id, int phy_addr) +{ + char dpmac_str[] = "dpmacs@00"; + const u32 *phyhandle; + int offset; + int err; + + /* get the dpmac offset */ + offset = fdt_get_dpmac_node(fdt, dpmac_id); + if (offset < 0) + return offset; + + /* get dpmac phy-handle */ + sprintf(dpmac_str, "dpmac@%x", dpmac_id); + phyhandle = (u32 *)fdt_getprop(fdt, offset, "phy-handle", NULL); + if (!phyhandle) { + printf("%s node not found in device tree\n", dpmac_str); + return offset; + } + + offset = fdt_node_offset_by_phandle(fdt, fdt32_to_cpu(*phyhandle)); + if (offset < 0) { + printf("Could not get the ph node offset for dpmac %d\n", + dpmac_id); + return offset; + } + + phy_addr = cpu_to_fdt32(phy_addr); + err = fdt_setprop(fdt, offset, "reg", &phy_addr, sizeof(phy_addr)); + if (err < 0) { + printf("Could not set phy node's reg for dpmac %d: %s.\n", + dpmac_id, fdt_strerror(err)); + return err; + } + + return 0; +} + +static int fdt_delete_phy_handle(void *fdt, int dpmac_id) +{ + const u32 *phyhandle; + int offset; + + /* get the dpmac offset */ + offset = fdt_get_dpmac_node(fdt, dpmac_id); + if (offset < 0) + return offset; + + /* verify if the node has a phy-handle */ + phyhandle = (u32 *)fdt_getprop(fdt, offset, "phy-handle", NULL); + if (!phyhandle) + return 0; + + return fdt_delprop(fdt, offset, "phy-handle"); +} + +int fdt_fixup_board_phy_revc(void *fdt) +{ + int ret; + + if (get_board_rev() != 'C') + return 0; + + /* DPMACs 3,4 have their Aquantia PHYs at new addresses */ + ret = fdt_update_phy_addr(fdt, 3, AQR113C_PHY_ADDR1); + if (ret) + return ret; + + ret = fdt_update_phy_addr(fdt, 4, AQR113C_PHY_ADDR2); + if (ret) + return ret; + + /* There is no PHY for the DPMAC2, so remove the phy-handle */ + return fdt_delete_phy_handle(fdt, 2); +} + int fdt_fixup_board_phy(void *fdt) { int mdio_offset; diff --git a/board/freescale/lx2160a/lx2160a.h b/board/freescale/lx2160a/lx2160a.h index cf56cefb45a3..e9b318339af3 100644 --- a/board/freescale/lx2160a/lx2160a.h +++ b/board/freescale/lx2160a/lx2160a.h @@ -60,6 +60,7 @@
#if CONFIG_IS_ENABLED(TARGET_LX2160ARDB) u8 get_board_rev(void); +int fdt_fixup_board_phy_revc(void *fdt); #endif
-----Original Message----- From: Ioana Ciornei ioana.ciornei@nxp.com Sent: Monday, April 26, 2021 6:31 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: u-boot@lists.denx.de; Florin Laurentiu Chiculita florinlaurentiu.chiculita@nxp.com; Wasim Khan (OSS) wasim.khan@oss.nxp.com; Ioana Ciornei ioana.ciornei@nxp.com Subject: [PATCH v2 3/4] board: fsl: lx2160ardb: add dts fixup function for RevC
+static int fdt_get_dpmac_node(void *fdt, int dpmac_id) {
- char dpmac_str[] = "dpmacs@00";
- int offset, dpmacs_offset;
- /* get the dpmac offset */
- dpmacs_offset = fdt_path_offset(fdt, "/soc/fsl-mc/dpmacs");
- if (dpmacs_offset < 0)
- if (dpmacs_offset < 0) {
- sprintf(dpmac_str, "dpmac@%x", dpmac_id);
- offset = fdt_subnode_offset(fdt, dpmacs_offset, dpmac_str);
- if (offset < 0) {
if (offset < 0) {
device tree\n",
return offset;
- return offset;
+static int fdt_update_phy_addr(void *fdt, int dpmac_id, int phy_addr) {
- const u32 *phyhandle;
- int offset;
- int err;
- offset = fdt_get_dpmac_node(fdt, dpmac_id);
- if (offset < 0)
return offset;
- /* get dpmac phy-handle */
- phyhandle = (u32 *)fdt_getprop(fdt, offset, "phy-handle", NULL);
- if (!phyhandle) {
return offset;
- offset = fdt_node_offset_by_phandle(fdt, fdt32_to_cpu(*phyhandle));
- if (offset < 0) {
dpmac_id);
return offset;
- phy_addr = cpu_to_fdt32(phy_addr);
- err = fdt_setprop(fdt, offset, "reg", &phy_addr, sizeof(phy_addr));
- if (err < 0) {
return err;
+static int fdt_delete_phy_handle(void *fdt, int dpmac_id) {
- int offset;
- if (offset < 0)
return offset;
- /* verify if the node has a phy-handle */
- if (!phyhandle)
- return fdt_delprop(fdt, offset, "phy-handle"); }
+int fdt_fixup_board_phy_revc(void *fdt) {
- int ret;
- if (get_board_rev() != 'C')
Do we want to check for < 'C' version or != here? Is fdt_fixup_board_phy_revc() rquired only for Rev C version or >= Rev C?
Regards Priyanka
- if (offset < 0) {
if (offset < 0) {
device tree\n",
return offset;
- return offset;
- int offset;
- int err;
- if (offset < 0)
return offset;
- if (!phyhandle) {
return offset;
- if (offset < 0) {
dpmac_id);
return offset;
- if (err < 0) {
return err;
- int offset;
- if (offset < 0)
return offset;
- if (!phyhandle)
- int ret;
- /* DPMACs 3,4 have their Aquantia PHYs at new addresses */
- ret = fdt_update_phy_addr(fdt, 3, AQR113C_PHY_ADDR1);
- if (ret)
return ret;
- ret = fdt_update_phy_addr(fdt, 4, AQR113C_PHY_ADDR2);
- if (ret)
return ret;
- /* There is no PHY for the DPMAC2, so remove the phy-handle */
- return fdt_delete_phy_handle(fdt, 2);
2.17.1
Kindly ensure build for all lx2160a platforms, fix build issues like below 2021-06-16T15:10:30.1450001Z aarch64: + lx2162aqds_tfa 2021-06-16T15:10:30.1450811Z +board/freescale/lx2160a/lx2160a.c: In function 'board_fix_fdt': 2021-06-16T15:10:30.1451830Z +board/freescale/lx2160a/lx2160a.c:196:3: error: implicit declaration of function 'fdt_fixup_board_phy_revc'; did you mean 'fdt_fixup_board_enet'? [-Werror=implicit-function-declaration] 2021-06-16T15:10:30.1452462Z + 196 | fdt_fixup_board_phy_revc(fdt); 2021-06-16T15:10:30.1452800Z + | ^~~~~~~~~~~~~~~~~~~~~~~~ 2021-06-16T15:10:30.1453131Z + | fdt_fixup_board_enet 2021-06-16T15:10:30.1453705Z +board/freescale/lx2160a/lx2160a.c: In function 'ft_board_setup': 2021-06-16T15:10:30.1454548Z +board/freescale/lx2160a/lx2160a.c:922:6: error: implicit declaration of function 'get_board_rev' [-Werror=implicit-function-declaration] 2021-06-16T15:10:30.1455235Z + 922 | if (get_board_rev() >= 'C') 2021-06-16T15:10:30.1455569Z + | ^~~~~~~~~~~~~ 2021-06-16T15:10:30.1456345Z +board/freescale/lx2160a/lx2160a.c:923:3: error: implicit declaration of function 'fdt_fixup_i2c_thermal_node' [-Werror=implicit-function-declaration] 2021-06-16T15:10:30.1456912Z + 923 | fdt_fixup_i2c_thermal_node(blob); 2021-06-16T15:10:30.1457254Z + | ^~~~~~~~~~~~~~~~~~~~~~~~~~ 2021-06-16T15:10:30.1457608Z +cc1: all warnings being treated as errors 2021-06-16T15:10:30.1457987Z +make[2]: *** [board/freescale/lx2160a/lx2160a.o] Error 1 2021-06-16T15:10:30.1458374Z +make[1]: *** [board/freescale/lx2160a] Error 2 2021-06-16T15:10:30.1458878Z +make: *** [sub-make] Error 2 2021-06-16T15:10:30.1459042Z 2021-06-16T15:10:49.8594009Z 2 0 3 /8 -3 0:01:07 : lx2162aqds_tfa 2021-06-16T15:10:49.8606363Z
https://dev.azure.com/u-boot/a1096300-2999-4ec4-a21a-4c22075e3771/_apis/buil...
Regards Priyanka
Use the newly fdt_fixup_board_phy_revc() function introduced to updated both kernel's DTS and u-boot's DTS in case we are running with DM_ETH.
Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com Signed-off-by: Florin Chiculita florinlaurentiu.chiculita@nxp.com --- board/freescale/lx2160a/eth_lx2160ardb.c | 2 +- board/freescale/lx2160a/lx2160a.c | 8 ++++++++ 2 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/board/freescale/lx2160a/eth_lx2160ardb.c b/board/freescale/lx2160a/eth_lx2160ardb.c index c693ad9a0a4a..30a3af9f4737 100644 --- a/board/freescale/lx2160a/eth_lx2160ardb.c +++ b/board/freescale/lx2160a/eth_lx2160ardb.c @@ -366,5 +366,5 @@ int fdt_fixup_board_phy(void *fdt) } }
- return ret; + return fdt_fixup_board_phy_revc(fdt); } diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index 9f1a6979258c..0736735e6f0d 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -189,6 +189,11 @@ int board_fix_fdt(void *fdt) "fsl,lx2160a-pcie"); }
+ /* Fixup u-boot's DTS in case this is a revC board and + * we're using DM_ETH. + */ + if (IS_ENABLED(CONFIG_TARGET_LX2160ARDB) && IS_ENABLED(CONFIG_DM_ETH)) + fdt_fixup_board_phy_revc(fdt); return 0; } #endif @@ -723,6 +728,9 @@ void fdt_fixup_board_enet(void *fdt) fdt_status_okay(fdt, offset); #ifndef CONFIG_DM_ETH fdt_fixup_board_phy(fdt); +#else + if (IS_ENABLED(CONFIG_TARGET_LX2160ARDB)) + fdt_fixup_board_phy_revc(fdt); #endif } else { fdt_status_fail(fdt, offset);
Ioana Ciornei
Priyanka Jain
