[U-Boot] [PATCH] mtd: nand: omap_gpmc: Make ready/busy pins configurable
Commit fb384c4720ca7496775d6578f184bf628db73456 introduced the use of WAIT0 pin for determining whether the NAND is ready or not. This only works if all NAND chips are connected to WAIT0. If some chips are connected to the other available pin WAIT1, nand_wait() does not really wait and prints a WARN_ON message.
This patch allows the board to provide configuration of which chip is connected to which WAITx signal. For example, one can define in include/configs/foo.h:
#define CONFIG_NAND_OMAP_GPMC_WSCFG 0,0,1,1
This would mean that chips using to CS0 and 1 are connected to WAIT0 and chips with CS2 and 3 are connected to WAIT1.
Signed-off-by: Michal Sojka sojka@merica.cz
Cc: Tom Rini trini@ti.com Cc: Stefan Roese sr@denx.de --- drivers/mtd/nand/omap_gpmc.c | 13 +++++++++++-- 1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index 459904d..57fc7b9 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -36,7 +36,8 @@ static __maybe_unused struct nand_ecclayout omap_ecclayout; struct omap_nand_info { struct bch_control *control; enum omap_ecc ecc_scheme; - int cs; + uint8_t cs; + uint8_t ws; /* wait status pin (0,1) */ };
/* We are wasting a bit of memory but al least we are safe */ @@ -76,7 +77,9 @@ static void omap_nand_hwcontrol(struct mtd_info *mtd, int32_t cmd, /* Check wait pin as dev ready indicator */ static int omap_dev_ready(struct mtd_info *mtd) { - return gpmc_cfg->status & (1 << 8); + register struct nand_chip *this = mtd->priv; + struct omap_nand_info *info = this->priv; + return gpmc_cfg->status & (1 << (8 + info->ws)); }
/* @@ -853,6 +856,12 @@ int board_nand_init(struct nand_chip *nand) nand->IO_ADDR_W = (void __iomem *)&gpmc_cfg->cs[cs].nand_cmd; omap_nand_info[cs].control = NULL; omap_nand_info[cs].cs = cs; +#if !defined(CONFIG_NAND_OMAP_GPMC_WSCFG) + omap_nand_info[cs].ws = 0; +#else + int8_t ws[CONFIG_SYS_MAX_NAND_DEVICE] = { CONFIG_NAND_OMAP_GPMC_WSCFG }; + omap_nand_info[cs].ws = ws[cs]; +#endif nand->priv = &omap_nand_info[cs]; nand->cmd_ctrl = omap_nand_hwcontrol; nand->options |= NAND_NO_PADDING | NAND_CACHEPRG;
- int cs;
uint8_t cs;
- omap_nand_info[cs].ws = 0;
+#else
- int8_t ws[CONFIG_SYS_MAX_NAND_DEVICE] = { CONFIG_NAND_OMAP_GPMC_WSCFG };
Doesn't this declaration trigger a compilation warning?
- omap_nand_info[cs].ws = ws[cs];
I've attached a new version of this patch. It removed the ifdef from the code. Please take a look at it and let me know what you think.
Thanks, Stefan
Hi Stefan,
- int cs;
uint8_t cs;
+#else
Not with gcc-4.8.3 that we use.
Yes, it's better and it works for us. Just one point - what about making the variable const as in the patch below?
Thanks, -Michal
-------------8<------------------ Commit fb384c4720ca7496775d6578f184bf628db73456 introduced the use of WAIT0 pin for determining whether the NAND is ready or not. This only works if all NAND chips are connected to WAIT0. If some chips are connected to the other available pin WAIT1, nand_wait() does not really wait and prints a WARN_ON message.
Cc: Tom Rini trini@ti.com Cc: Stefan Roese sr@denx.de --- drivers/mtd/nand/omap_gpmc.c | 16 ++++++++++++++-- 1 file changed, 14 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index 459904d..4f9120d 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -30,13 +30,22 @@ static u8 bch8_polynomial[] = {0xef, 0x51, 0x2e, 0x09, 0xed, 0x93, 0x9a, 0xc2, static uint8_t cs_next; static __maybe_unused struct nand_ecclayout omap_ecclayout;
+#if defined(CONFIG_NAND_OMAP_GPMC_WSCFG) +static const int8_t wscfg[CONFIG_SYS_MAX_NAND_DEVICE] = + { CONFIG_NAND_OMAP_GPMC_WSCFG }; +#else +/* wscfg is preset to zero since its a static variable */ +static const int8_t wscfg[CONFIG_SYS_MAX_NAND_DEVICE]; +#endif + /* * Driver configurations */ struct omap_nand_info { struct bch_control *control; enum omap_ecc ecc_scheme; - int cs; + uint8_t cs; + uint8_t ws; /* wait status pin (0,1) */ };
/* We are wasting a bit of memory but al least we are safe */ @@ -76,7 +85,9 @@ static void omap_nand_hwcontrol(struct mtd_info *mtd, int32_t cmd, /* Check wait pin as dev ready indicator */ static int omap_dev_ready(struct mtd_info *mtd) { - return gpmc_cfg->status & (1 << 8); + register struct nand_chip *this = mtd->priv; + struct omap_nand_info *info = this->priv; + return gpmc_cfg->status & (1 << (8 + info->ws)); }
/* @@ -853,6 +864,7 @@ int board_nand_init(struct nand_chip *nand) nand->IO_ADDR_W = (void __iomem *)&gpmc_cfg->cs[cs].nand_cmd; omap_nand_info[cs].control = NULL; omap_nand_info[cs].cs = cs; + omap_nand_info[cs].ws = wscfg[cs]; nand->priv = &omap_nand_info[cs]; nand->cmd_ctrl = omap_nand_hwcontrol; nand->options |= NAND_NO_PADDING | NAND_CACHEPRG;
Hi Michal,
On 17.02.2015 14:52, Michal Sojka wrote:
<snip>
Even better. Please submit it as a regular patch (v2) and my:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Michal Sojka
Stefan Roese
