[U-Boot] [PATCH v2] mx6dl: Add initial support for Wandboard dual lite
Add initial support for Wandboard dual lite.
Wandboard is a development board that has two variants: one version based on mx6 dual lite and another one based on mx6 solo.
For details on the features of Wandboard, please refer to: http://www.wandboard.org/
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- This applies on top of Eric's series for adding nitrogen6x boards support.
Changes since v1: - Use get_ram_size - Remove ARP_TIMEOUT - Remove unneeded "1u"
MAINTAINERS | 1 + arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 3 + board/wandboard/Makefile | 29 ++++ board/wandboard/wandboard.c | 180 ++++++++++++++++++++++++ boards.cfg | 1 + include/configs/wandboard.h | 208 ++++++++++++++++++++++++++++ 6 files changed, 422 insertions(+) create mode 100644 board/wandboard/Makefile create mode 100644 board/wandboard/wandboard.c create mode 100644 include/configs/wandboard.h
diff --git a/MAINTAINERS b/MAINTAINERS index 42e7664..9e1e169 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -659,6 +659,7 @@ Fabio Estevam fabio.estevam@freescale.com mx53smd i.MX53 mx6qsabresd i.MX6Q mx6qsabreauto i.MX6Q + wandboard i.MX6DL
Daniel Gorsulowski daniel.gorsulowski@esd.eu
diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 9494e41..9846f1b 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -50,6 +50,8 @@ #define NO_MUX_I 0 #define NO_PAD_I 0 enum { + MX6_PAD_CSI0_DAT10__UART1_TXD = IOMUX_PAD(0x0360, 0x004C, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__UART1_RXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x08FC, 1, 0), MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN2__IPU1_DI0_PIN2 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), @@ -90,6 +92,7 @@ enum { MX6_PAD_EIM_D27__UART2_RXD = IOMUX_PAD(0x0540, 0x0170, 4, 0x0904, 1, 0), MX6_PAD_EIM_D28__I2C1_SDA = IOMUX_PAD(0x0544, 0x0174, 1 | IOMUX_CONFIG_SION, 0x086C, 1, 0), MX6_PAD_EIM_D28__GPIO_3_28 = IOMUX_PAD(0x0544, 0x0174, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D29__GPIO_3_29 = IOMUX_PAD(0x0548, 0x0178, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDC__ENET_MDC = IOMUX_PAD(0x05B8, 0x01E8, 1, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_MDIO = IOMUX_PAD(0x05BC, 0x01EC, 1, 0x0810, 0, 0), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK = IOMUX_PAD(0x05C0, 0x01F0, 1, 0x0000, 0, 0), diff --git a/board/wandboard/Makefile b/board/wandboard/Makefile new file mode 100644 index 0000000..014ea6c --- /dev/null +++ b/board/wandboard/Makefile @@ -0,0 +1,29 @@ +# +# (C) Copyright 2013 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := wandboard.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c new file mode 100644 index 0000000..e2839d8 --- /dev/null +++ b/board/wandboard/wandboard.c @@ -0,0 +1,180 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + */ + +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/io.h> +#include <common.h> +#include <fsl_esdhc.h> +#include <mmc.h> +#include <miiphy.h> +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define ETH_PHY_RESET IMX_GPIO_NR(3, 29) + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_CSI0_DAT10__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT11__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc3_pads[] = { + MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static iomux_v3_cfg_t const enet_pads[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* AR8031 PHY Reset */ + MX6_PAD_EIM_D29__GPIO_3_29 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +static void setup_iomux_enet(void) +{ + imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); + + /* Reset AR8031 PHY */ + gpio_direction_output(ETH_PHY_RESET, 0); + udelay(500); + gpio_set_value(ETH_PHY_RESET, 1); +} + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC3_BASE_ADDR}, +}; + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} + +static int mx6_rgmii_rework(struct phy_device *phydev) +{ + unsigned short val; + + /* To enable AR8031 ouput a 125MHz clk from CLK_25M */ + phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x7); + phy_write(phydev, MDIO_DEVAD_NONE, 0xe, 0x8016); + phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x4007); + + val = phy_read(phydev, MDIO_DEVAD_NONE, 0xe); + val &= 0xffe3; + val |= 0x18; + phy_write(phydev, MDIO_DEVAD_NONE, 0xe, val); + + /* introduce tx clock delay */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x5); + val = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e); + val |= 0x0100; + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, val); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + mx6_rgmii_rework(phydev); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int ret; + + setup_iomux_enet(); + + ret = cpu_eth_init(bis); + if (ret) + printf("FEC MXC: %s:failed\n", __func__); + + return 0; +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +u32 get_board_rev(void) +{ + return 0x61011; +} + +int checkboard(void) +{ + puts("Board: Wandboard\n"); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index 7c3e5f5..3518609 100644 --- a/boards.cfg +++ b/boards.cfg @@ -259,6 +259,7 @@ nitrogen6q arm armv7 nitrogen6x boundar nitrogen6q2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q nitrogen6s arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S +wandboard_dl arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL cm_t35 arm armv7 cm_t35 - omap3 omap3_overo arm armv7 overo - omap3 omap3_pandora arm armv7 pandora - omap3 diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h new file mode 100644 index 0000000..2b156a3 --- /dev/null +++ b/include/configs/wandboard.h @@ -0,0 +1,208 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * + * Configuration settings for the Wandboard. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_MACH_TYPE 4412 + +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 1 + +#define CONFIG_PREBOOT "" + +#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 + +/* MMC Configuration */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* Ethernet Configuration */ +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 1 +#define CONFIG_PHYLIB +#define CONFIG_PHY_ATHEROS + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ + "console=ttymxc0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx6dl-wandboard.dtb\0" \ + "fdt_addr=0x11000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev=0\0" \ + "mmcpart=2\0" \ + "mmcroot=/dev/mmcblk0p3 rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x10010000 +#define CONFIG_SYS_MEMTEST_SCRATCH 0x10800000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE 0x40000000 + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE (8 * 1024) + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +#endif /* __CONFIG_H * */
Dear Fabio Estevam,
Changes since v1:
- Use get_ram_size
Thanks. I have still a question:
- gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
I see this new code does not reference imx_ddr_size() any more. If it's so easy to switch to get_ram_size(), should we not then also convert the existing MX53 and MX6 boards to using get_ram_size(), and remove the then unneeded imx_ddr_size() code?
Or would there be any drawbacks?
Hi Wolfgang,
On 03/10/2013 12:51 AM, Wolfgang Denk wrote:
Dear Fabio Estevam,
Changes since v1:
- Use get_ram_size
In the specific case of Nitrogen6X, we're defining different configurations for each of the memory arrangements, so we could skip the call to imx_ddr_size().
For that matter, we could skip the call to get_ram_size() entirely because we're configuring each of the DDR settings very explicitly.
Since there are timing difference between the x128M and x256M DDR chips we're using, we've split them off into separate files:
1066mhz_4x128mx16.cfg 1066mhz_4x256mx16.cfg
and defined two board configurations to select between the two.
Regards,
Eric
Dear Eric Nelson,
Well, that was the starting point of my questions - don;t you want to have a single image runnign on all of your systems? That's exactly get_ram_size() has been made for...
get_ram_size() is not about configuring, but about verifying / checking the result of such a configuration.
That's OK - but this is still no reason not to support all these configurations in a single U-Boot image. After all, this is exactly how U-Boot has been designed right from the beginning.
Eric Nelson
Fabio Estevam
