[U-Boot] [PATCH] pci: mx6: fix occasional link failures
According to the IMX6 reference manuals, REF_SSP_EN (Reference clock enable for SS function) must remain deasserted until the reference clock is running at the appropriate frequency.
Without this patch we find a high link failure rate (>5%) on certain IMX6 boards at various temperatures.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- drivers/pci/pcie_imx.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index c48737e..a3982c4 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -509,10 +509,6 @@ static int imx6_pcie_deassert_core_reset(void)
imx6_pcie_toggle_power();
- /* Enable PCIe */ - clrbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_TEST_POWERDOWN); - setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_REF_SSP_EN); - enable_pcie_clock();
/* @@ -521,6 +517,10 @@ static int imx6_pcie_deassert_core_reset(void) */ mdelay(50);
+ /* Enable PCIe */ + clrbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_TEST_POWERDOWN); + setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_REF_SSP_EN); + imx6_pcie_toggle_reset();
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Hi Tim,
Looks good, thanks.
Reviewed-by: Fabio Estevam fabio.estevam@freescale.com
Also Cc Richard and Rogerio in case they have any comment.
/* Enable PCIe */
enable_pcie_clock(); /*
/* Enable PCIe */
imx6_pcie_toggle_reset(); return 0;
On Friday, August 08, 2014 at 03:02:27 PM, Fabio Estevam wrote:
Hi Tim,
Looks good, thanks.
Can you guys test it on FSL hardware ?
Sure, I am running u-boot-imx with Tim's patch applied and this additional debug patch that shows the number of reboots and PCI linkups:
drivers/pci/pcie_imx.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index a3982c4..1ee77f9 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -20,6 +20,8 @@ #include <linux/sizes.h> #include <errno.h>
+#define DEBUG + #define PCI_ACCESS_READ 0 #define PCI_ACCESS_WRITE 1
@@ -573,6 +575,10 @@ void imx_pcie_init(void) static struct pci_controller pcc; struct pci_controller *hose = &pcc; int ret; +#ifdef DEBUG + u32 dbg_reg_addr = 0x020cc068; + u32 dbg_reg = readl(dbg_reg_addr) + 1; +#endif
memset(&pcc, 0, sizeof(pcc));
@@ -607,7 +613,14 @@ void imx_pcie_init(void) if (!ret) { pci_register_hose(hose); hose->last_busno = pci_hose_scan(hose); +#ifdef DEBUG + dbg_reg += 1<<16; +#endif } +#ifdef DEBUG + writel(dbg_reg, dbg_reg_addr); + printf("PCIe Successes/Attempts: %d/%d\n", dbg_reg >> 16, dbg_reg & 0xffff); +#endif }
Then I do:
=> setenv bootcmd reset => save => reboot
,connect an Intel Wifi 7260HMW card to the mx6qsabresd and let the system rebooting in loop.
It has been running with no PCI linkup failures here:
U-Boot 2014.07-16451-g7496820-dirty (Aug 08 2014 - 11:34:13)
CPU: Freescale i.MX6Q rev1.1 at 792 MHz Reset cause: WDOG Board: MX6-SabreSD I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 00:01.0 - 16c3:abcd - Bridge device 01:00.0 - 8086:08b1 - Network controller PCIe Successes/Attempts: 2350/2350 No panel detected: default to Hannstar-XGA Display: Hannstar-XGA (1024x768) In: serial Out: serial Err: serial PMIC: PFUZE100 ID=0x10 Net: FEC [PRIME]
So here goes my:
Tested-by: Fabio Estevam fabio.estevam@freescale.com
Regards,
Fabio Estevam
Well you do realize that this addition changes the timing of the code and also generates writes on the AXI bus, right? I would be much fonder of your testing if you did it with a pristine code and monitored the number of successful cases with plain logging of the serial console and a grep. This should be easy and would avoid the problems with modified code.
Hi Marek,
Ok, so with the debug patch applied I let it running overnight and it ran 39k+ times without PCI linkup failures.
I agree with your comments and now I am doing as you suggested:
Running top of tree u-boot-imx with only Tim's patch applied.
Then I do:
sudo minicom | tee pci.txt to collect the logs.
After one hour of testing:
/tmp$ cat pci.txt | grep CPU | wc -l 2251
/tmp$ cat pci.txt | grep Bridge | wc -l 2251
Could you help testing the kernel patch?
Regards,
Fabio Estevam
Then I do:
The test has been running more than 11k times without a failure.
Will finish the tests now and let my board to rest a little bit :-)
Then I do:
Thanks!
Hi Tim,
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
Tim Harvey
