Please pull u-boot-marvell/next
Hi Tom,
please pull these Marvell patches into next:
---------------------------------------------------------------- - Enable CONFIG_TIMER for all Kirkwood / MVEBU boards (Stefan) - u-boot-spl.kwb/SPL: Add / improve size limit setup / detection (Pali) - mvebu: theadorable: Misc updates in defconfig und dts (Stefan) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=264&view=resu...
Thanks, Stefan
The following changes since commit e9a1ff9724348408144c7f1c5b5cc26130ba46e5:
Merge branch 'master' into next (2022-09-19 16:07:12 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git next
for you to fetch changes up to 7a6102a6133a1f7a368c91626bb1707bed2bac45:
kirkwood: lsxl: Sync defconfigs (2022-09-20 06:39:43 +0200)
---------------------------------------------------------------- Pali Rohár (3): Makefile: Add missing CONFIG_BOARD_SIZE_LIMIT check for u-boot-spl.kwb arm: mvebu: turris_omnia: Add CONFIG_BOARD_SIZE_LIMIT arm: mvebu: Add default SPL_SIZE_LIMIT for 32-bit SoCs
Stefan Roese (9): arm: mvebu: theadorable: Misc defconfig changes arm: mvebu: theadorable: Update eth & mdio DT nodes timer: orion-timer: Add support for other Armada SoC's timer: orion-timer: Add timer_get_boot_us() for BOOTSTAGE support arm: mvebu: Use CONFIG_TIMER on all MVEBU & KIRKWOOD platforms arm: mvebu: dts: Makefile: Compile Armada 375 dtb in a separate step arm: mvebu: dts: armada-375.dtsi: Add timer0 & timer1 arm: mvebu: dts: mvebu-u-boot.dtsi: Add "u-boot, dm-pre-reloc" to timer DT node kirkwood: lsxl: Sync defconfigs
Makefile | 1 + arch/arm/Kconfig | 4 ++ arch/arm/dts/Makefile | 6 +- arch/arm/dts/armada-375.dtsi | 4 +- arch/arm/dts/armada-xp-theadorable.dts | 27 ++++---- arch/arm/dts/mvebu-u-boot.dtsi | 11 ++++ arch/arm/mach-mvebu/include/mach/config.h | 5 -- common/spl/Kconfig | 1 + configs/lschlv2_defconfig | 2 - configs/lsxhl_defconfig | 2 - configs/theadorable_debug_defconfig | 3 + configs/turris_omnia_defconfig | 2 + drivers/timer/Kconfig | 5 +- drivers/timer/orion-timer.c | 103 ++++++++++++++++++++++++++---- 14 files changed, 137 insertions(+), 39 deletions(-)
Stefan Roese
