[PATCH v2] rockchip: rv1126: Migrate to OF_UPSTREAM
Migrate RV1126 boards that exists in Linux v6.8 to use OF_UPSTREAM.
Following targets is migrated to use OF_UPSTREAM:
- rv1126-edgeble-neu2 : Board is an industrial form factor IO board. - sonoff-ihost-rv1126 : Gateway device designed to provide a Smart Home Hub.
Cc: Tim Lunn tim@feathertop.org Cc: Jagan Teki jagan@edgeble.ai Signed-off-by: Anand Moon linux.amoon@gmail.com --- v2: remove the dt-bindings for clock and power fix the typo in commit message
Tested on neu2 board. --- arch/arm/dts/Makefile | 3 - arch/arm/dts/rv1126-edgeble-neu2-io.dts | 112 ---- arch/arm/dts/rv1126-edgeble-neu2.dtsi | 345 ---------- arch/arm/dts/rv1126-pinctrl.dtsi | 341 ---------- arch/arm/dts/rv1126-sonoff-ihost.dts | 29 - arch/arm/dts/rv1126-sonoff-ihost.dtsi | 404 ----------- arch/arm/dts/rv1126.dtsi | 623 ----------------- arch/arm/mach-rockchip/Kconfig | 1 + configs/neu2-io-rv1126_defconfig | 2 +- configs/sonoff-ihost-rv1126_defconfig | 2 +- .../dt-bindings/clock/rockchip,rv1126-cru.h | 632 ------------------ .../dt-bindings/power/rockchip,rv1126-power.h | 35 - 12 files changed, 3 insertions(+), 2526 deletions(-) delete mode 100644 arch/arm/dts/rv1126-edgeble-neu2-io.dts delete mode 100644 arch/arm/dts/rv1126-edgeble-neu2.dtsi delete mode 100644 arch/arm/dts/rv1126-pinctrl.dtsi delete mode 100644 arch/arm/dts/rv1126-sonoff-ihost.dts delete mode 100644 arch/arm/dts/rv1126-sonoff-ihost.dtsi delete mode 100644 arch/arm/dts/rv1126.dtsi delete mode 100644 include/dt-bindings/clock/rockchip,rv1126-cru.h delete mode 100644 include/dt-bindings/power/rockchip,rv1126-power.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 087645f354..79fc100dce 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -97,9 +97,6 @@ dtb-$(CONFIG_ROCKCHIP_RK3368) += \ rk3368-geekbox.dtb \ rk3368-px5-evb.dtb \
-dtb-$(CONFIG_ROCKCHIP_RV1126) += \ - rv1126-edgeble-neu2-io.dtb - dtb-$(CONFIG_ARCH_S5P4418) += \ s5p4418-nanopi2.dtb
diff --git a/arch/arm/dts/rv1126-edgeble-neu2-io.dts b/arch/arm/dts/rv1126-edgeble-neu2-io.dts deleted file mode 100644 index 0c2396b8f8..0000000000 --- a/arch/arm/dts/rv1126-edgeble-neu2-io.dts +++ /dev/null @@ -1,112 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2020 Rockchip Electronics Co., Ltd. - * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. - */ - -/dts-v1/; -#include "rv1126.dtsi" -#include "rv1126-edgeble-neu2.dtsi" - -/ { - model = "Edgeble Neu2 IO Board"; - compatible = "edgeble,neural-compute-module-2-io", - "edgeble,neural-compute-module-2", "rockchip,rv1126"; - - aliases { - serial2 = &uart2; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - vcc12v_dcin: vcc12v-dcin-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - v3v3_sys: v3v3-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "v3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&gmac { - assigned-clocks = <&cru CLK_GMAC_SRC>, <&cru CLK_GMAC_TX_RX>, - <&cru CLK_GMAC_ETHERNET_OUT>; - assigned-clock-parents = <&cru CLK_GMAC_SRC_M1>, <&cru RGMII_MODE_CLK>; - assigned-clock-rates = <125000000>, <0>, <25000000>; - clock_in_out = "input"; - phy-handle = <&phy>; - phy-mode = "rgmii"; - phy-supply = <&vcc_3v3>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmiim1_miim &rgmiim1_bus2 &rgmiim1_bus4 &clk_out_ethernetm1_pins>; - tx_delay = <0x2a>; - rx_delay = <0x1a>; - status = "okay"; -}; - -&mdio { - phy: ethernet-phy@0 { - compatible = "ethernet-phy-id001c.c916", - "ethernet-phy-ieee802.3-c22"; - reg = <0x0>; - pinctrl-names = "default"; - pinctrl-0 = <ð_phy_rst>; - reset-assert-us = <20000>; - reset-deassert-us = <100000>; - reset-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_LOW>; - }; -}; - -&pinctrl { - ethernet { - eth_phy_rst: eth-phy-rst { - rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; -}; - -&pwm11 { - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_bus4 &sdmmc0_det>; - rockchip,default-sample-phase = <90>; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr104; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; diff --git a/arch/arm/dts/rv1126-edgeble-neu2.dtsi b/arch/arm/dts/rv1126-edgeble-neu2.dtsi deleted file mode 100644 index 7ea8d7d16f..0000000000 --- a/arch/arm/dts/rv1126-edgeble-neu2.dtsi +++ /dev/null @@ -1,345 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2020 Rockchip Electronics Co., Ltd. - * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. - */ - -/ { - compatible = "edgeble,neural-compute-module-2", "rockchip,rv1126"; - - aliases { - mmc0 = &emmc; - }; - - vccio_flash: vccio-flash-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&flash_vol_sel>; - regulator-name = "vccio_flash"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_3v3>; - }; - - sdio_pwrseq: pwrseq-sdio { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk809 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - reset-gpios = <&gpio1 RK_PD0 GPIO_ACTIVE_LOW>; - }; -}; - -&cpu0 { - cpu-supply = <&vdd_arm>; -}; - -&emmc { - bus-width = <8>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 &emmc_cmd &emmc_clk>; - rockchip,default-sample-phase = <90>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vccio_flash>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - status = "okay"; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PB1 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc5-supply = <&vcc_buck5>; - vcc6-supply = <&vcc_buck5>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc5v0_sys>; - - regulators { - vdd_npu_vepu: DCDC_REG1 { - regulator-name = "vdd_npu_vepu"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <650000>; - regulator-max-microvolt = <950000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_arm: DCDC_REG2 { - regulator-name = "vdd_arm"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <725000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc3v3_sys: DCDC_REG4 { - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_buck5: DCDC_REG5 { - regulator-name = "vcc_buck5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <2200000>; - regulator-max-microvolt = <2200000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <2200000>; - }; - }; - - vcc_0v8: LDO_REG1 { - regulator-name = "vcc_0v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_pmu: LDO_REG2 { - regulator-name = "vcc1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdd0v8_pmu: LDO_REG3 { - regulator-name = "vcc0v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <800000>; - }; - }; - - vcc_1v8: LDO_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_dovdd: LDO_REG5 { - regulator-name = "vcc_dovdd"; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_dvdd: LDO_REG6 { - regulator-name = "vcc_dvdd"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_avdd: LDO_REG7 { - regulator-name = "vcc_avdd"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG8 { - regulator-name = "vccio_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_sd: LDO_REG9 { - regulator-name = "vcc3v3_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_5v0: SWITCH_REG1 { - regulator-name = "vcc_5v0"; - }; - - vcc_3v3: SWITCH_REG2 { - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - }; - }; - }; -}; - -&pinctrl { - bt { - bt_enable: bt-enable { - rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - flash { - flash_vol_sel: flash-vol-sel { - rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - wifi { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmuio0-supply = <&vcc1v8_pmu>; - pmuio1-supply = <&vcc3v3_sys>; - vccio1-supply = <&vccio_flash>; - vccio2-supply = <&vccio_sd>; - vccio3-supply = <&vcc_1v8>; - vccio4-supply = <&vcc_dovdd>; - vccio5-supply = <&vcc_1v8>; - vccio6-supply = <&vcc_1v8>; - vccio7-supply = <&vcc_dovdd>; - status = "okay"; -}; - -&saradc { - vref-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sfc { - pinctrl-names = "default"; - pinctrl-0 = <&fspi_pins>; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <50000000>; - spi-rx-bus-width = <4>; - spi-tx-bus-width = <1>; - }; -}; - -&sdio { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - max-frequency = <100000000>; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc1_clk &sdmmc1_cmd &sdmmc1_bus4>; - rockchip,default-sample-phase = <90>; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v3_sys>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; - #address-cells = <1>; - #size-cells = <0>; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_ctsn &uart0_rtsn>; - status = "okay"; - - bluetooth { - compatible = "qcom,qca9377-bt"; - clocks = <&rk809 1>; - enable-gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_HIGH>; /* BT_RST */ - max-speed = <2000000>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_enable>; - vddxo-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - }; -}; diff --git a/arch/arm/dts/rv1126-pinctrl.dtsi b/arch/arm/dts/rv1126-pinctrl.dtsi deleted file mode 100644 index f84f5f2d96..0000000000 --- a/arch/arm/dts/rv1126-pinctrl.dtsi +++ /dev/null @@ -1,341 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2020 Fuzhou Rockchip Electronics Co., Ltd - */ - -#include <dt-bindings/pinctrl/rockchip.h> -#include "rockchip-pinconf.dtsi" - -/* - * This file is auto generated by pin2dts tool, please keep these code - * by adding changes at end of this file. - */ -&pinctrl { - clk_out_ethernet { - /omit-if-no-ref/ - clk_out_ethernetm1_pins: clk-out-ethernetm1-pins { - rockchip,pins = - /* clk_out_ethernet_m1 */ - <2 RK_PC5 2 &pcfg_pull_none>; - }; - }; - emmc { - /omit-if-no-ref/ - emmc_rstnout: emmc-rstnout { - rockchip,pins = - /* emmc_rstn */ - <1 RK_PA3 2 &pcfg_pull_none>; - }; - /omit-if-no-ref/ - emmc_bus8: emmc-bus8 { - rockchip,pins = - /* emmc_d0 */ - <0 RK_PC4 2 &pcfg_pull_up_drv_level_2>, - /* emmc_d1 */ - <0 RK_PC5 2 &pcfg_pull_up_drv_level_2>, - /* emmc_d2 */ - <0 RK_PC6 2 &pcfg_pull_up_drv_level_2>, - /* emmc_d3 */ - <0 RK_PC7 2 &pcfg_pull_up_drv_level_2>, - /* emmc_d4 */ - <0 RK_PD0 2 &pcfg_pull_up_drv_level_2>, - /* emmc_d5 */ - <0 RK_PD1 2 &pcfg_pull_up_drv_level_2>, - /* emmc_d6 */ - <0 RK_PD2 2 &pcfg_pull_up_drv_level_2>, - /* emmc_d7 */ - <0 RK_PD3 2 &pcfg_pull_up_drv_level_2>; - }; - /omit-if-no-ref/ - emmc_clk: emmc-clk { - rockchip,pins = - /* emmc_clko */ - <0 RK_PD7 2 &pcfg_pull_up_drv_level_2>; - }; - /omit-if-no-ref/ - emmc_cmd: emmc-cmd { - rockchip,pins = - /* emmc_cmd */ - <0 RK_PD5 2 &pcfg_pull_up_drv_level_2>; - }; - }; - fspi { - /omit-if-no-ref/ - fspi_pins: fspi-pins { - rockchip,pins = - /* fspi_clk */ - <1 RK_PA3 3 &pcfg_pull_down>, - /* fspi_cs0n */ - <0 RK_PD4 3 &pcfg_pull_up>, - /* fspi_d0 */ - <1 RK_PA0 3 &pcfg_pull_up>, - /* fspi_d1 */ - <1 RK_PA1 3 &pcfg_pull_up>, - /* fspi_d2 */ - <0 RK_PD6 3 &pcfg_pull_up>, - /* fspi_d3 */ - <1 RK_PA2 3 &pcfg_pull_up>; - }; - }; - i2c0 { - /omit-if-no-ref/ - i2c0_xfer: i2c0-xfer { - rockchip,pins = - /* i2c0_scl */ - <0 RK_PB4 1 &pcfg_pull_none_drv_level_0_smt>, - /* i2c0_sda */ - <0 RK_PB5 1 &pcfg_pull_none_drv_level_0_smt>; - }; - }; - i2c2 { - /omit-if-no-ref/ - i2c2_xfer: i2c2-xfer { - rockchip,pins = - /* i2c2_scl */ - <0 RK_PC2 1 &pcfg_pull_none_drv_level_0_smt>, - /* i2c2_sda */ - <0 RK_PC3 1 &pcfg_pull_none_drv_level_0_smt>; - }; - }; - pwm2 { - /omit-if-no-ref/ - pwm2m0_pins: pwm2m0-pins { - rockchip,pins = - /* pwm2_pin_m0 */ - <0 RK_PC0 3 &pcfg_pull_none>; - }; - }; - pwm11 { - /omit-if-no-ref/ - pwm11m0_pins: pwm11m0-pins { - rockchip,pins = - /* pwm11_pin_m0 */ - <3 RK_PA7 6 &pcfg_pull_none>; - }; - }; - rgmii { - /omit-if-no-ref/ - rgmiim1_miim: rgmiim1-miim { - rockchip,pins = - /* rgmii_mdc_m1 */ - <2 RK_PC2 2 &pcfg_pull_none>, - /* rgmii_mdio_m1 */ - <2 RK_PC1 2 &pcfg_pull_none>; - }; - /omit-if-no-ref/ - rgmiim1_rxer: rgmiim1-rxer { - rockchip,pins = - /* rgmii_rxer_m1 */ - <2 RK_PC0 2 &pcfg_pull_none>; - }; - /omit-if-no-ref/ - rgmiim1_bus2: rgmiim1-bus2 { - rockchip,pins = - /* rgmii_rxd0_m1 */ - <2 RK_PB5 2 &pcfg_pull_none>, - /* rgmii_rxd1_m1 */ - <2 RK_PB6 2 &pcfg_pull_none>, - /* rgmii_rxdv_m1 */ - <2 RK_PB4 2 &pcfg_pull_none>, - /* rgmii_txd0_m1 */ - <2 RK_PC3 2 &pcfg_pull_none_drv_level_3>, - /* rgmii_txd1_m1 */ - <2 RK_PC4 2 &pcfg_pull_none_drv_level_3>, - /* rgmii_txen_m1 */ - <2 RK_PC6 2 &pcfg_pull_none_drv_level_3>; - }; - /omit-if-no-ref/ - rgmiim1_bus4: rgmiim1-bus4 { - rockchip,pins = - /* rgmii_rxclk_m1 */ - <2 RK_PD3 2 &pcfg_pull_none>, - /* rgmii_rxd2_m1 */ - <2 RK_PC7 2 &pcfg_pull_none>, - /* rgmii_rxd3_m1 */ - <2 RK_PD0 2 &pcfg_pull_none>, - /* rgmii_txclk_m1 */ - <2 RK_PD2 2 &pcfg_pull_none_drv_level_3>, - /* rgmii_txd2_m1 */ - <2 RK_PD1 2 &pcfg_pull_none_drv_level_3>, - /* rgmii_txd3_m1 */ - <2 RK_PA4 2 &pcfg_pull_none_drv_level_3>; - }; - /omit-if-no-ref/ - rgmiim1_mclkinout: rgmiim1-mclkinout { - rockchip,pins = - /* rgmii_clk_m1 */ - <2 RK_PB7 2 &pcfg_pull_none>; - }; - }; - sdmmc0 { - /omit-if-no-ref/ - sdmmc0_bus4: sdmmc0-bus4 { - rockchip,pins = - /* sdmmc0_d0 */ - <1 RK_PA4 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc0_d1 */ - <1 RK_PA5 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc0_d2 */ - <1 RK_PA6 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc0_d3 */ - <1 RK_PA7 1 &pcfg_pull_up_drv_level_2>; - }; - /omit-if-no-ref/ - sdmmc0_clk: sdmmc0-clk { - rockchip,pins = - /* sdmmc0_clk */ - <1 RK_PB0 1 &pcfg_pull_up_drv_level_2>; - }; - /omit-if-no-ref/ - sdmmc0_cmd: sdmmc0-cmd { - rockchip,pins = - /* sdmmc0_cmd */ - <1 RK_PB1 1 &pcfg_pull_up_drv_level_2>; - }; - /omit-if-no-ref/ - sdmmc0_det: sdmmc0-det { - rockchip,pins = - <0 RK_PA3 1 &pcfg_pull_none>; - }; - /omit-if-no-ref/ - sdmmc0_pwr: sdmmc0-pwr { - rockchip,pins = - <0 RK_PC0 1 &pcfg_pull_none>; - }; - }; - sdmmc1 { - /omit-if-no-ref/ - sdmmc1_bus4: sdmmc1-bus4 { - rockchip,pins = - /* sdmmc1_d0 */ - <1 RK_PB4 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc1_d1 */ - <1 RK_PB5 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc1_d2 */ - <1 RK_PB6 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc1_d3 */ - <1 RK_PB7 1 &pcfg_pull_up_drv_level_2>; - }; - /omit-if-no-ref/ - sdmmc1_clk: sdmmc1-clk { - rockchip,pins = - /* sdmmc1_clk */ - <1 RK_PB2 1 &pcfg_pull_up_drv_level_2>; - }; - /omit-if-no-ref/ - sdmmc1_cmd: sdmmc1-cmd { - rockchip,pins = - /* sdmmc1_cmd */ - <1 RK_PB3 1 &pcfg_pull_up_drv_level_2>; - }; - /omit-if-no-ref/ - sdmmc1_det: sdmmc1-det { - rockchip,pins = - <1 RK_PD0 2 &pcfg_pull_none>; - }; - /omit-if-no-ref/ - sdmmc1_pwr: sdmmc1-pwr { - rockchip,pins = - <1 RK_PD1 2 &pcfg_pull_none>; - }; - }; - uart0 { - /omit-if-no-ref/ - uart0_xfer: uart0-xfer { - rockchip,pins = - /* uart0_rx */ - <1 RK_PC2 1 &pcfg_pull_up>, - /* uart0_tx */ - <1 RK_PC3 1 &pcfg_pull_up>; - }; - /omit-if-no-ref/ - uart0_ctsn: uart0-ctsn { - rockchip,pins = - <1 RK_PC1 1 &pcfg_pull_none>; - }; - /omit-if-no-ref/ - uart0_rtsn: uart0-rtsn { - rockchip,pins = - <1 RK_PC0 1 &pcfg_pull_none>; - }; - /omit-if-no-ref/ - uart0_rtsn_gpio: uart0-rts-pin { - rockchip,pins = - <1 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - uart1 { - /omit-if-no-ref/ - uart1m0_xfer: uart1m0-xfer { - rockchip,pins = - /* uart1_rx_m0 */ - <0 RK_PB7 2 &pcfg_pull_up>, - /* uart1_tx_m0 */ - <0 RK_PB6 2 &pcfg_pull_up>; - }; - }; - uart2 { - /omit-if-no-ref/ - uart2m1_xfer: uart2m1-xfer { - rockchip,pins = - /* uart2_rx_m1 */ - <3 RK_PA3 1 &pcfg_pull_up>, - /* uart2_tx_m1 */ - <3 RK_PA2 1 &pcfg_pull_up>; - }; - }; - uart3 { - /omit-if-no-ref/ - uart3m0_xfer: uart3m0-xfer { - rockchip,pins = - /* uart3_rx_m0 */ - <3 RK_PC7 4 &pcfg_pull_up>, - /* uart3_tx_m0 */ - <3 RK_PC6 4 &pcfg_pull_up>; - }; - /omit-if-no-ref/ - uart3m2_xfer: uart3m2-xfer { - rockchip,pins = - /* uart3_rx_m2 */ - <3 RK_PA1 4 &pcfg_pull_up>, - /* uart3_tx_m2 */ - <3 RK_PA0 4 &pcfg_pull_up>; - }; - }; - uart4 { - /omit-if-no-ref/ - uart4m0_xfer: uart4m0-xfer { - rockchip,pins = - /* uart4_rx_m0 */ - <3 RK_PA5 4 &pcfg_pull_up>, - /* uart4_tx_m0 */ - <3 RK_PA4 4 &pcfg_pull_up>; - }; - /omit-if-no-ref/ - uart4m2_xfer: uart4m2-xfer { - rockchip,pins = - /* uart4_rx_m2 */ - <1 RK_PD4 3 &pcfg_pull_up>, - /* uart4_tx_m2 */ - <1 RK_PD5 3 &pcfg_pull_up>; - }; - }; - uart5 { - /omit-if-no-ref/ - uart5m0_xfer: uart5m0-xfer { - rockchip,pins = - /* uart5_rx_m0 */ - <3 RK_PA7 4 &pcfg_pull_up>, - /* uart5_tx_m0 */ - <3 RK_PA6 4 &pcfg_pull_up>; - }; - /omit-if-no-ref/ - uart5m2_xfer: uart5m2-xfer { - rockchip,pins = - /* uart5_rx_m2 */ - <2 RK_PA1 3 &pcfg_pull_up>, - /* uart5_tx_m2 */ - <2 RK_PA0 3 &pcfg_pull_up>; - }; - }; -}; diff --git a/arch/arm/dts/rv1126-sonoff-ihost.dts b/arch/arm/dts/rv1126-sonoff-ihost.dts deleted file mode 100644 index 77386a48d8..0000000000 --- a/arch/arm/dts/rv1126-sonoff-ihost.dts +++ /dev/null @@ -1,29 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2020 Rockchip Electronics Co., Ltd. - */ - -/dts-v1/; -#include "rv1126.dtsi" -#include "rv1126-sonoff-ihost.dtsi" - -/ { - model = "Sonoff iHost 4G"; - compatible = "itead,sonoff-ihost", "rockchip,rv1126"; -}; - -&cpu0 { - cpu-supply = <&vdd_arm>; -}; - -&cpu1 { - cpu-supply = <&vdd_arm>; -}; - -&cpu2 { - cpu-supply = <&vdd_arm>; -}; - -&cpu3 { - cpu-supply = <&vdd_arm>; -}; diff --git a/arch/arm/dts/rv1126-sonoff-ihost.dtsi b/arch/arm/dts/rv1126-sonoff-ihost.dtsi deleted file mode 100644 index 32b329e87a..0000000000 --- a/arch/arm/dts/rv1126-sonoff-ihost.dtsi +++ /dev/null @@ -1,404 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2020 Rockchip Electronics Co., Ltd. - * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. - */ - -/ { - aliases { - ethernet0 = &gmac; - mmc0 = &emmc; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - vcc5v0_sys: regulator-vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - sdio_pwrseq: pwrseq-sdio { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk809 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - reset-gpios = <&gpio1 RK_PD0 GPIO_ACTIVE_LOW>; - }; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - mmc-hs200-1_8v; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 &emmc_cmd &emmc_clk &emmc_rstnout>; - rockchip,default-sample-phase = <90>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - status = "okay"; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PB1 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc5-supply = <&vcc_buck5>; - vcc6-supply = <&vcc_buck5>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc5v0_sys>; - - regulators { - vdd_npu_vepu: DCDC_REG1 { - regulator-name = "vdd_npu_vepu"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <650000>; - regulator-max-microvolt = <950000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_arm: DCDC_REG2 { - regulator-name = "vdd_arm"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <725000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc3v3_sys: DCDC_REG4 { - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_buck5: DCDC_REG5 { - regulator-name = "vcc_buck5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <2200000>; - regulator-max-microvolt = <2200000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <2200000>; - }; - }; - - vcc_0v8: LDO_REG1 { - regulator-name = "vcc_0v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_pmu: LDO_REG2 { - regulator-name = "vcc1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdd0v8_pmu: LDO_REG3 { - regulator-name = "vcc0v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <800000>; - }; - }; - - vcc_1v8: LDO_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_dovdd: LDO_REG5 { - regulator-name = "vcc_dovdd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_dvdd: LDO_REG6 { - regulator-name = "vcc_dvdd"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_avdd: LDO_REG7 { - regulator-name = "vcc_avdd"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG8 { - regulator-name = "vccio_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_sd: LDO_REG9 { - regulator-name = "vcc3v3_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_5v0: SWITCH_REG1 { - regulator-name = "vcc_5v0"; - }; - - vcc_3v3: SWITCH_REG2 { - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - }; - }; - }; -}; - -&i2c2 { - status = "okay"; - clock-frequency = <400000>; - - pcf8563: rtc@51 { - compatible = "nxp,pcf8563"; - reg = <0x51>; - #clock-cells = <0>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; - clock-output-names = "xin32k"; - }; -}; - -&gmac { - assigned-clocks = <&cru CLK_GMAC_SRC_M1>, <&cru CLK_GMAC_SRC>, - <&cru CLK_GMAC_TX_RX>; - assigned-clock-parents = <&cru CLK_GMAC_RGMII_M1>, <&cru CLK_GMAC_SRC_M1>, - <&cru RMII_MODE_CLK>; - assigned-clock-rates = <0>, <50000000>; - clock_in_out = "output"; - phy-handle = <&phy>; - phy-mode = "rmii"; - phy-supply = <&vcc_3v3>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmiim1_miim &rgmiim1_rxer &rgmiim1_bus2 &rgmiim1_mclkinout>; - status = "okay"; -}; - -&mdio { - phy: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0x0>; - pinctrl-names = "default"; - pinctrl-0 = <ð_phy_rst>; - reset-active-low; - reset-assert-us = <50000>; - reset-deassert-us = <10000>; - reset-gpios = <&gpio2 RK_PA6 GPIO_ACTIVE_LOW>; - }; -}; - -&pinctrl { - ethernet { - eth_phy_rst: eth-phy-rst { - rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - bt { - bt_enable: bt-enable { - rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_dev: bt-wake-dev { - rockchip,pins = <1 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_host: bt-wake-host { - rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - wifi { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmuio0-supply = <&vcc1v8_pmu>; - pmuio1-supply = <&vcc3v3_sys>; - vccio1-supply = <&vcc_1v8>; - vccio2-supply = <&vccio_sd>; - vccio3-supply = <&vcc_1v8>; - vccio4-supply = <&vcc_dovdd>; - vccio5-supply = <&vcc_1v8>; - vccio6-supply = <&vcc_1v8>; - vccio7-supply = <&vcc_dovdd>; - status = "okay"; -}; - -&saradc { - vref-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdio { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - max-frequency = <100000000>; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc1_clk &sdmmc1_cmd &sdmmc1_bus4>; - rockchip,default-sample-phase = <90>; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v3_sys>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_bus4 &sdmmc0_det>; - rockchip,default-sample-phase = <90>; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr104; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_ctsn &uart0_rtsn>; - uart-has-rtscts; - status = "okay"; - - bluetooth { - compatible = "realtek,rtl8723ds-bt"; - device-wake-gpios = <&gpio1 RK_PC7 GPIO_ACTIVE_HIGH>; /* BT_WAKE */ - enable-gpios = <&gpio1 RK_PC6 GPIO_ACTIVE_HIGH>; /* BT_RST */ - host-wake-gpios = <&gpio1 RK_PC5 GPIO_ACTIVE_HIGH>; /* BT_WAKE_HOST */ - max-speed = <2000000>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_enable>, <&bt_wake_dev>, <&bt_wake_host>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - pinctrl-names = "default"; - pinctrl-0 = <&uart3m2_xfer>; - status = "okay"; -}; - -&uart4 { - pinctrl-names = "default"; - pinctrl-0 = <&uart4m2_xfer>; - status = "okay"; -}; diff --git a/arch/arm/dts/rv1126.dtsi b/arch/arm/dts/rv1126.dtsi deleted file mode 100644 index bb603cae13..0000000000 --- a/arch/arm/dts/rv1126.dtsi +++ /dev/null @@ -1,623 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd. - */ - -#include <dt-bindings/clock/rockchip,rv1126-cru.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/power/rockchip,rv1126-power.h> -#include <dt-bindings/soc/rockchip,boot-mode.h> - -/ { - #address-cells = <1>; - #size-cells = <1>; - - compatible = "rockchip,rv1126"; - - interrupt-parent = <&gic>; - - aliases { - i2c0 = &i2c0; - i2c2 = &i2c2; - serial0 = &uart0; - serial1 = &uart1; - serial2 = &uart2; - serial3 = &uart3; - serial4 = &uart4; - serial5 = &uart5; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu0: cpu@f00 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0xf00>; - enable-method = "psci"; - clocks = <&cru ARMCLK>; - }; - - cpu1: cpu@f01 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0xf01>; - enable-method = "psci"; - clocks = <&cru ARMCLK>; - }; - - cpu2: cpu@f02 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0xf02>; - enable-method = "psci"; - clocks = <&cru ARMCLK>; - }; - - cpu3: cpu@f03 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0xf03>; - enable-method = "psci"; - clocks = <&cru ARMCLK>; - }; - }; - - arm-pmu { - compatible = "arm,cortex-a7-pmu"; - interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - clock-frequency = <24000000>; - }; - - display_subsystem { - compatible = "rockchip,display-subsystem"; - ports = <&vop_out>; - }; - - xin24m: oscillator { - compatible = "fixed-clock"; - clock-frequency = <24000000>; - clock-output-names = "xin24m"; - #clock-cells = <0>; - }; - - grf: syscon@fe000000 { - compatible = "rockchip,rv1126-grf", "syscon", "simple-mfd"; - reg = <0xfe000000 0x20000>; - }; - - pmugrf: syscon@fe020000 { - compatible = "rockchip,rv1126-pmugrf", "syscon", "simple-mfd"; - reg = <0xfe020000 0x1000>; - - pmu_io_domains: io-domains { - compatible = "rockchip,rv1126-pmu-io-voltage-domain"; - status = "disabled"; - }; - }; - - qos_emmc: qos@fe860000 { - compatible = "rockchip,rv1126-qos", "syscon"; - reg = <0xfe860000 0x20>; - }; - - qos_nandc: qos@fe860080 { - compatible = "rockchip,rv1126-qos", "syscon"; - reg = <0xfe860080 0x20>; - }; - - qos_sfc: qos@fe860200 { - compatible = "rockchip,rv1126-qos", "syscon"; - reg = <0xfe860200 0x20>; - }; - - qos_sdio: qos@fe86c000 { - compatible = "rockchip,rv1126-qos", "syscon"; - reg = <0xfe86c000 0x20>; - }; - - qos_iep: qos@fe8a0000 { - compatible = "rockchip,rv1126-qos", "syscon"; - reg = <0xfe8a0000 0x20>; - }; - - qos_rga_rd: qos@fe8a0080 { - compatible = "rockchip,rv1126-qos", "syscon"; - reg = <0xfe8a0080 0x20>; - }; - - qos_rga_wr: qos@fe8a0100 { - compatible = "rockchip,rv1126-qos", "syscon"; - reg = <0xfe8a0100 0x20>; - }; - - qos_vop: qos@fe8a0180 { - compatible = "rockchip,rv1126-qos", "syscon"; - reg = <0xfe8a0180 0x20>; - }; - - gic: interrupt-controller@feff0000 { - compatible = "arm,gic-400"; - interrupt-controller; - #interrupt-cells = <3>; - #address-cells = <0>; - - reg = <0xfeff1000 0x1000>, - <0xfeff2000 0x2000>, - <0xfeff4000 0x2000>, - <0xfeff6000 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - }; - - pmu: power-management@ff3e0000 { - compatible = "rockchip,rv1126-pmu", "syscon", "simple-mfd"; - reg = <0xff3e0000 0x1000>; - - power: power-controller { - compatible = "rockchip,rv1126-power-controller"; - #power-domain-cells = <1>; - #address-cells = <1>; - #size-cells = <0>; - - power-domain@RV1126_PD_NVM { - reg = <RV1126_PD_NVM>; - clocks = <&cru HCLK_EMMC>, - <&cru CLK_EMMC>, - <&cru HCLK_NANDC>, - <&cru CLK_NANDC>, - <&cru HCLK_SFC>, - <&cru HCLK_SFCXIP>, - <&cru SCLK_SFC>; - pm_qos = <&qos_emmc>, - <&qos_nandc>, - <&qos_sfc>; - #power-domain-cells = <0>; - }; - - power-domain@RV1126_PD_SDIO { - reg = <RV1126_PD_SDIO>; - clocks = <&cru HCLK_SDIO>, - <&cru CLK_SDIO>; - pm_qos = <&qos_sdio>; - #power-domain-cells = <0>; - }; - - power-domain@RV1126_PD_VO { - reg = <RV1126_PD_VO>; - clocks = <&cru ACLK_RGA>, - <&cru HCLK_RGA>, - <&cru CLK_RGA_CORE>, - <&cru ACLK_VOP>, - <&cru HCLK_VOP>, - <&cru DCLK_VOP>, - <&cru PCLK_DSIHOST>, - <&cru ACLK_IEP>, - <&cru HCLK_IEP>, - <&cru CLK_IEP_CORE>; - pm_qos = <&qos_rga_rd>, - <&qos_rga_wr>, - <&qos_vop>, - <&qos_iep>; - #power-domain-cells = <0>; - }; - }; - }; - - i2c0: i2c@ff3f0000 { - compatible = "rockchip,rv1126-i2c", "rockchip,rk3399-i2c"; - reg = <0xff3f0000 0x1000>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - rockchip,grf = <&pmugrf>; - clocks = <&pmucru CLK_I2C0>, <&pmucru PCLK_I2C0>; - clock-names = "i2c", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@ff400000 { - compatible = "rockchip,rv1126-i2c", "rockchip,rk3399-i2c"; - reg = <0xff400000 0x1000>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - rockchip,grf = <&pmugrf>; - clocks = <&pmucru CLK_I2C2>, <&pmucru PCLK_I2C2>; - clock-names = "i2c", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - uart1: serial@ff410000 { - compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; - reg = <0xff410000 0x100>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <24000000>; - clocks = <&pmucru SCLK_UART1>, <&pmucru PCLK_UART1>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac 7>, <&dmac 6>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart1m0_xfer>; - reg-shift = <2>; - reg-io-width = <4>; - status = "disabled"; - }; - - pwm2: pwm@ff430020 { - compatible = "rockchip,rv1126-pwm", "rockchip,rk3328-pwm"; - reg = <0xff430020 0x10>; - clock-names = "pwm", "pclk"; - clocks = <&pmucru CLK_PWM0>, <&pmucru PCLK_PWM0>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm2m0_pins>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pmucru: clock-controller@ff480000 { - compatible = "rockchip,rv1126-pmucru"; - reg = <0xff480000 0x1000>; - rockchip,grf = <&grf>; - #clock-cells = <1>; - #reset-cells = <1>; - }; - - cru: clock-controller@ff490000 { - compatible = "rockchip,rv1126-cru"; - reg = <0xff490000 0x1000>; - clocks = <&xin24m>; - clock-names = "xin24m"; - rockchip,grf = <&grf>; - #clock-cells = <1>; - #reset-cells = <1>; - }; - - dmac: dma-controller@ff4e0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0xff4e0000 0x4000>; - interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC>; - clock-names = "apb_pclk"; - }; - - pwm11: pwm@ff550030 { - compatible = "rockchip,rv1126-pwm", "rockchip,rk3328-pwm"; - reg = <0xff550030 0x10>; - clock-names = "pwm", "pclk"; - clocks = <&cru CLK_PWM2>, <&cru PCLK_PWM2>; - pinctrl-0 = <&pwm11m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - uart0: serial@ff560000 { - compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; - reg = <0xff560000 0x100>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <24000000>; - clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac 5>, <&dmac 4>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer>; - reg-shift = <2>; - reg-io-width = <4>; - status = "disabled"; - }; - - uart2: serial@ff570000 { - compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; - reg = <0xff570000 0x100>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <24000000>; - clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac 9>, <&dmac 8>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart2m1_xfer>; - reg-shift = <2>; - reg-io-width = <4>; - status = "disabled"; - }; - - uart3: serial@ff580000 { - compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; - reg = <0xff580000 0x100>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <24000000>; - clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac 11>, <&dmac 10>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart3m0_xfer>; - reg-shift = <2>; - reg-io-width = <4>; - status = "disabled"; - }; - - uart4: serial@ff590000 { - compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; - reg = <0xff590000 0x100>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <24000000>; - clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac 13>, <&dmac 12>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart4m0_xfer>; - reg-shift = <2>; - reg-io-width = <4>; - status = "disabled"; - }; - - uart5: serial@ff5a0000 { - compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; - reg = <0xff5a0000 0x100>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <24000000>; - clocks = <&cru SCLK_UART5>, <&cru PCLK_UART5>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac 15>, <&dmac 14>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart5m0_xfer>; - reg-shift = <2>; - reg-io-width = <4>; - status = "disabled"; - }; - - saradc: adc@ff5e0000 { - compatible = "rockchip,rv1126-saradc", "rockchip,rk3399-saradc"; - reg = <0xff5e0000 0x100>; - interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; - #io-channel-cells = <1>; - clocks = <&cru CLK_SARADC>, <&cru PCLK_SARADC>; - clock-names = "saradc", "apb_pclk"; - resets = <&cru SRST_SARADC_P>; - reset-names = "saradc-apb"; - status = "disabled"; - }; - - timer0: timer@ff660000 { - compatible = "rockchip,rv1126-timer", "rockchip,rk3288-timer"; - reg = <0xff660000 0x20>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_TIMER>, <&cru CLK_TIMER0>; - clock-names = "pclk", "timer"; - }; - - vop: vop@ffb00000 { - compatible = "rockchip,rv1126-vop"; - reg = <0xffb00000 0x200>, <0xffb00a00 0x400>; - interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; - clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; - clocks = <&cru ACLK_VOP>, <&cru DCLK_VOP>, <&cru HCLK_VOP>; - reset-names = "axi", "ahb", "dclk"; - resets = <&cru SRST_VOP_A>, <&cru SRST_VOP_H>, <&cru SRST_VOP_D>; - iommus = <&vop_mmu>; - power-domains = <&power RV1126_PD_VO>; - status = "disabled"; - - vop_out: port { - #address-cells = <1>; - #size-cells = <0>; - - vop_out_rgb: endpoint@0 { - reg = <0>; - }; - - vop_out_dsi: endpoint@1 { - reg = <1>; - }; - }; - }; - - vop_mmu: iommu@ffb00f00 { - compatible = "rockchip,iommu"; - reg = <0xffb00f00 0x100>; - interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; - clock-names = "aclk", "iface"; - clocks = <&cru ACLK_VOP>, <&cru HCLK_VOP>; - #iommu-cells = <0>; - power-domains = <&power RV1126_PD_VO>; - status = "disabled"; - }; - - gmac: ethernet@ffc40000 { - compatible = "rockchip,rv1126-gmac", "snps,dwmac-4.20a"; - reg = <0xffc40000 0x4000>; - interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq", "eth_wake_irq"; - rockchip,grf = <&grf>; - clocks = <&cru CLK_GMAC_SRC>, <&cru CLK_GMAC_TX_RX>, - <&cru CLK_GMAC_TX_RX>, <&cru CLK_GMAC_REF>, - <&cru ACLK_GMAC>, <&cru PCLK_GMAC>, - <&cru CLK_GMAC_TX_RX>, <&cru CLK_GMAC_PTPREF>; - clock-names = "stmmaceth", "mac_clk_rx", - "mac_clk_tx", "clk_mac_ref", - "aclk_mac", "pclk_mac", - "clk_mac_speed", "ptp_ref"; - resets = <&cru SRST_GMAC_A>; - reset-names = "stmmaceth"; - - snps,mixed-burst; - snps,tso; - - snps,axi-config = <&stmmac_axi_setup>; - snps,mtl-rx-config = <&mtl_rx_setup>; - snps,mtl-tx-config = <&mtl_tx_setup>; - status = "disabled"; - - mdio: mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <0x1>; - #size-cells = <0x0>; - }; - - stmmac_axi_setup: stmmac-axi-config { - snps,wr_osr_lmt = <4>; - snps,rd_osr_lmt = <8>; - snps,blen = <0 0 0 0 16 8 4>; - }; - - mtl_rx_setup: rx-queues-config { - snps,rx-queues-to-use = <1>; - queue0 {}; - }; - - mtl_tx_setup: tx-queues-config { - snps,tx-queues-to-use = <1>; - queue0 {}; - }; - }; - - emmc: mmc@ffc50000 { - compatible = "rockchip,rv1126-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0xffc50000 0x4000>; - interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_EMMC>, <&cru CLK_EMMC>, - <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <200000000>; - power-domains = <&power RV1126_PD_NVM>; - status = "disabled"; - }; - - sdmmc: mmc@ffc60000 { - compatible = "rockchip,rv1126-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0xffc60000 0x4000>; - interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_SDMMC>, <&cru CLK_SDMMC>, - <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <200000000>; - status = "disabled"; - }; - - sdio: mmc@ffc70000 { - compatible = "rockchip,rv1126-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0xffc70000 0x4000>; - interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_SDIO>, <&cru CLK_SDIO>, - <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <200000000>; - power-domains = <&power RV1126_PD_SDIO>; - status = "disabled"; - }; - - sfc: spi@ffc90000 { - compatible = "rockchip,sfc"; - reg = <0xffc90000 0x4000>; - interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; - assigned-clocks = <&cru SCLK_SFC>; - assigned-clock-rates = <80000000>; - clock-names = "clk_sfc", "hclk_sfc"; - clocks = <&cru SCLK_SFC>, <&cru HCLK_SFC>; - power-domains = <&power RV1126_PD_NVM>; - status = "disabled"; - }; - - pinctrl: pinctrl { - compatible = "rockchip,rv1126-pinctrl"; - rockchip,grf = <&grf>; - rockchip,pmu = <&pmugrf>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - gpio0: gpio@ff460000 { - compatible = "rockchip,gpio-bank"; - reg = <0xff460000 0x100>; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&pmucru PCLK_GPIO0>, <&pmucru DBCLK_GPIO0>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio1: gpio@ff620000 { - compatible = "rockchip,gpio-bank"; - reg = <0xff620000 0x100>; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO1>, <&cru DBCLK_GPIO1>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@ff630000 { - compatible = "rockchip,gpio-bank"; - reg = <0xff630000 0x100>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO2>, <&cru DBCLK_GPIO2>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@ff640000 { - compatible = "rockchip,gpio-bank"; - reg = <0xff640000 0x100>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO3>, <&cru DBCLK_GPIO3>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio4: gpio@ff650000 { - compatible = "rockchip,gpio-bank"; - reg = <0xff650000 0x100>; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO4>, <&cru DBCLK_GPIO4>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - }; -}; - -#include "rv1126-pinctrl.dtsi" diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index ec3697f358..661e7fd1c9 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -427,6 +427,7 @@ config ROCKCHIP_RV1126 imply SPL_ROCKCHIP_COMMON_BOARD imply SPL_SERIAL imply SPL_SYSCON + imply OF_UPSTREAM
config ROCKCHIP_USB_UART bool "Route uart output to usb pins" diff --git a/configs/neu2-io-rv1126_defconfig b/configs/neu2-io-rv1126_defconfig index dc27b9e6fe..2a4c9b45a0 100644 --- a/configs/neu2-io-rv1126_defconfig +++ b/configs/neu2-io-rv1126_defconfig @@ -5,7 +5,7 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_SYS_ARCH_TIMER=y CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_DEFAULT_DEVICE_TREE="rv1126-edgeble-neu2-io" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rv1126-edgeble-neu2-io" CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RV1126=y CONFIG_TARGET_RV1126_NEU2=y diff --git a/configs/sonoff-ihost-rv1126_defconfig b/configs/sonoff-ihost-rv1126_defconfig index dfc71b1397..4890644c7e 100644 --- a/configs/sonoff-ihost-rv1126_defconfig +++ b/configs/sonoff-ihost-rv1126_defconfig @@ -5,7 +5,7 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_SYS_ARCH_TIMER=y CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_DEFAULT_DEVICE_TREE="rv1126-sonoff-ihost" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rv1126-sonoff-ihost" CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RV1126=y CONFIG_TARGET_RV1126_SONOFF_IHOST=y diff --git a/include/dt-bindings/clock/rockchip,rv1126-cru.h b/include/dt-bindings/clock/rockchip,rv1126-cru.h deleted file mode 100644 index e89a3a5a4a..0000000000 --- a/include/dt-bindings/clock/rockchip,rv1126-cru.h +++ /dev/null @@ -1,632 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (c) 2019 Rockchip Electronics Co. Ltd. - * Author: Finley Xiao finley.xiao@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RV1126_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RV1126_H - -/* pmucru-clocks indices */ - -/* pll clocks */ -#define PLL_GPLL 1 - -/* sclk (special clocks) */ -#define CLK_OSC0_DIV32K 2 -#define CLK_RTC32K 3 -#define CLK_WIFI_DIV 4 -#define CLK_WIFI_OSC0 5 -#define CLK_WIFI 6 -#define CLK_PMU 7 -#define SCLK_UART1_DIV 8 -#define SCLK_UART1_FRACDIV 9 -#define SCLK_UART1_MUX 10 -#define SCLK_UART1 11 -#define CLK_I2C0 12 -#define CLK_I2C2 13 -#define CLK_CAPTURE_PWM0 14 -#define CLK_PWM0 15 -#define CLK_CAPTURE_PWM1 16 -#define CLK_PWM1 17 -#define CLK_SPI0 18 -#define DBCLK_GPIO0 19 -#define CLK_PMUPVTM 20 -#define CLK_CORE_PMUPVTM 21 -#define CLK_REF12M 22 -#define CLK_USBPHY_OTG_REF 23 -#define CLK_USBPHY_HOST_REF 24 -#define CLK_REF24M 25 -#define CLK_MIPIDSIPHY_REF 26 - -/* pclk */ -#define PCLK_PDPMU 30 -#define PCLK_PMU 31 -#define PCLK_UART1 32 -#define PCLK_I2C0 33 -#define PCLK_I2C2 34 -#define PCLK_PWM0 35 -#define PCLK_PWM1 36 -#define PCLK_SPI0 37 -#define PCLK_GPIO0 38 -#define PCLK_PMUSGRF 39 -#define PCLK_PMUGRF 40 -#define PCLK_PMUCRU 41 -#define PCLK_CHIPVEROTP 42 -#define PCLK_PDPMU_NIU 43 -#define PCLK_PMUPVTM 44 -#define PCLK_SCRKEYGEN 45 - -#define CLKPMU_NR_CLKS (PCLK_SCRKEYGEN + 1) - -/* cru-clocks indices */ - -/* pll clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_HPLL 4 - -/* sclk (special clocks) */ -#define ARMCLK 5 -#define USB480M 6 -#define CLK_CORE_CPUPVTM 7 -#define CLK_CPUPVTM 8 -#define CLK_SCR1 9 -#define CLK_SCR1_CORE 10 -#define CLK_SCR1_RTC 11 -#define CLK_SCR1_JTAG 12 -#define SCLK_UART0_DIV 13 -#define SCLK_UART0_FRAC 14 -#define SCLK_UART0_MUX 15 -#define SCLK_UART0 16 -#define SCLK_UART2_DIV 17 -#define SCLK_UART2_FRAC 18 -#define SCLK_UART2_MUX 19 -#define SCLK_UART2 20 -#define SCLK_UART3_DIV 21 -#define SCLK_UART3_FRAC 22 -#define SCLK_UART3_MUX 23 -#define SCLK_UART3 24 -#define SCLK_UART4_DIV 25 -#define SCLK_UART4_FRAC 26 -#define SCLK_UART4_MUX 27 -#define SCLK_UART4 28 -#define SCLK_UART5_DIV 29 -#define SCLK_UART5_FRAC 30 -#define SCLK_UART5_MUX 31 -#define SCLK_UART5 32 -#define CLK_I2C1 33 -#define CLK_I2C3 34 -#define CLK_I2C4 35 -#define CLK_I2C5 36 -#define CLK_SPI1 37 -#define CLK_CAPTURE_PWM2 38 -#define CLK_PWM2 39 -#define DBCLK_GPIO1 40 -#define DBCLK_GPIO2 41 -#define DBCLK_GPIO3 42 -#define DBCLK_GPIO4 43 -#define CLK_SARADC 44 -#define CLK_TIMER0 45 -#define CLK_TIMER1 46 -#define CLK_TIMER2 47 -#define CLK_TIMER3 48 -#define CLK_TIMER4 49 -#define CLK_TIMER5 50 -#define CLK_CAN 51 -#define CLK_NPU_TSADC 52 -#define CLK_NPU_TSADCPHY 53 -#define CLK_CPU_TSADC 54 -#define CLK_CPU_TSADCPHY 55 -#define CLK_CRYPTO_CORE 56 -#define CLK_CRYPTO_PKA 57 -#define MCLK_I2S0_TX_DIV 58 -#define MCLK_I2S0_TX_FRACDIV 59 -#define MCLK_I2S0_TX_MUX 60 -#define MCLK_I2S0_TX 61 -#define MCLK_I2S0_RX_DIV 62 -#define MCLK_I2S0_RX_FRACDIV 63 -#define MCLK_I2S0_RX_MUX 64 -#define MCLK_I2S0_RX 65 -#define MCLK_I2S0_TX_OUT2IO 66 -#define MCLK_I2S0_RX_OUT2IO 67 -#define MCLK_I2S1_DIV 68 -#define MCLK_I2S1_FRACDIV 69 -#define MCLK_I2S1_MUX 70 -#define MCLK_I2S1 71 -#define MCLK_I2S1_OUT2IO 72 -#define MCLK_I2S2_DIV 73 -#define MCLK_I2S2_FRACDIV 74 -#define MCLK_I2S2_MUX 75 -#define MCLK_I2S2 76 -#define MCLK_I2S2_OUT2IO 77 -#define MCLK_PDM 78 -#define SCLK_ADUPWM_DIV 79 -#define SCLK_AUDPWM_FRACDIV 80 -#define SCLK_AUDPWM_MUX 81 -#define SCLK_AUDPWM 82 -#define CLK_ACDCDIG_ADC 83 -#define CLK_ACDCDIG_DAC 84 -#define CLK_ACDCDIG_I2C 85 -#define CLK_VENC_CORE 86 -#define CLK_VDEC_CORE 87 -#define CLK_VDEC_CA 88 -#define CLK_VDEC_HEVC_CA 89 -#define CLK_RGA_CORE 90 -#define CLK_IEP_CORE 91 -#define CLK_ISP_DIV 92 -#define CLK_ISP_NP5 93 -#define CLK_ISP_NUX 94 -#define CLK_ISP 95 -#define CLK_CIF_OUT_DIV 96 -#define CLK_CIF_OUT_FRACDIV 97 -#define CLK_CIF_OUT_MUX 98 -#define CLK_CIF_OUT 99 -#define CLK_MIPICSI_OUT_DIV 100 -#define CLK_MIPICSI_OUT_FRACDIV 101 -#define CLK_MIPICSI_OUT_MUX 102 -#define CLK_MIPICSI_OUT 103 -#define CLK_ISPP_DIV 104 -#define CLK_ISPP_NP5 105 -#define CLK_ISPP_NUX 106 -#define CLK_ISPP 107 -#define CLK_SDMMC 108 -#define SCLK_SDMMC_DRV 109 -#define SCLK_SDMMC_SAMPLE 110 -#define CLK_SDIO 111 -#define SCLK_SDIO_DRV 112 -#define SCLK_SDIO_SAMPLE 113 -#define CLK_EMMC 114 -#define SCLK_EMMC_DRV 115 -#define SCLK_EMMC_SAMPLE 116 -#define CLK_NANDC 117 -#define SCLK_SFC 118 -#define CLK_USBHOST_UTMI_OHCI 119 -#define CLK_USBOTG_REF 120 -#define CLK_GMAC_DIV 121 -#define CLK_GMAC_RGMII_M0 122 -#define CLK_GMAC_SRC_M0 123 -#define CLK_GMAC_RGMII_M1 124 -#define CLK_GMAC_SRC_M1 125 -#define CLK_GMAC_SRC 126 -#define CLK_GMAC_REF 127 -#define CLK_GMAC_TX_SRC 128 -#define CLK_GMAC_TX_DIV5 129 -#define CLK_GMAC_TX_DIV50 130 -#define RGMII_MODE_CLK 131 -#define CLK_GMAC_RX_SRC 132 -#define CLK_GMAC_RX_DIV2 133 -#define CLK_GMAC_RX_DIV20 134 -#define RMII_MODE_CLK 135 -#define CLK_GMAC_TX_RX 136 -#define CLK_GMAC_PTPREF 137 -#define CLK_GMAC_ETHERNET_OUT 138 -#define CLK_DDRPHY 139 -#define CLK_DDR_MON 140 -#define TMCLK_DDR_MON 141 -#define CLK_NPU_DIV 142 -#define CLK_NPU_NP5 143 -#define CLK_CORE_NPU 144 -#define CLK_CORE_NPUPVTM 145 -#define CLK_NPUPVTM 146 -#define SCLK_DDRCLK 147 -#define CLK_OTP 148 - -/* dclk */ -#define DCLK_DECOM 150 -#define DCLK_VOP_DIV 151 -#define DCLK_VOP_FRACDIV 152 -#define DCLK_VOP_MUX 153 -#define DCLK_VOP 154 -#define DCLK_CIF 155 -#define DCLK_CIFLITE 156 - -/* aclk */ -#define ACLK_PDBUS 160 -#define ACLK_DMAC 161 -#define ACLK_DCF 162 -#define ACLK_SPINLOCK 163 -#define ACLK_DECOM 164 -#define ACLK_PDCRYPTO 165 -#define ACLK_CRYPTO 166 -#define ACLK_PDVEPU 167 -#define ACLK_VENC 168 -#define ACLK_PDVDEC 169 -#define ACLK_PDJPEG 170 -#define ACLK_VDEC 171 -#define ACLK_JPEG 172 -#define ACLK_PDVO 173 -#define ACLK_RGA 174 -#define ACLK_VOP 175 -#define ACLK_IEP 176 -#define ACLK_PDVI_DIV 177 -#define ACLK_PDVI_NP5 178 -#define ACLK_PDVI 179 -#define ACLK_ISP 180 -#define ACLK_CIF 181 -#define ACLK_CIFLITE 182 -#define ACLK_PDISPP_DIV 183 -#define ACLK_PDISPP_NP5 184 -#define ACLK_PDISPP 185 -#define ACLK_ISPP 186 -#define ACLK_PDPHP 187 -#define ACLK_PDUSB 188 -#define ACLK_USBOTG 189 -#define ACLK_PDGMAC 190 -#define ACLK_GMAC 191 -#define ACLK_PDNPU_DIV 192 -#define ACLK_PDNPU_NP5 193 -#define ACLK_PDNPU 194 -#define ACLK_NPU 195 - -/* hclk */ -#define HCLK_PDCORE_NIU 200 -#define HCLK_PDUSB 201 -#define HCLK_PDCRYPTO 202 -#define HCLK_CRYPTO 203 -#define HCLK_PDAUDIO 204 -#define HCLK_I2S0 205 -#define HCLK_I2S1 206 -#define HCLK_I2S2 207 -#define HCLK_PDM 208 -#define HCLK_AUDPWM 209 -#define HCLK_PDVEPU 210 -#define HCLK_VENC 211 -#define HCLK_PDVDEC 212 -#define HCLK_PDJPEG 213 -#define HCLK_VDEC 214 -#define HCLK_JPEG 215 -#define HCLK_PDVO 216 -#define HCLK_RGA 217 -#define HCLK_VOP 218 -#define HCLK_IEP 219 -#define HCLK_PDVI 220 -#define HCLK_ISP 221 -#define HCLK_CIF 222 -#define HCLK_CIFLITE 223 -#define HCLK_PDISPP 224 -#define HCLK_ISPP 225 -#define HCLK_PDPHP 226 -#define HCLK_PDSDMMC 227 -#define HCLK_SDMMC 228 -#define HCLK_PDSDIO 229 -#define HCLK_SDIO 230 -#define HCLK_PDNVM 231 -#define HCLK_EMMC 232 -#define HCLK_NANDC 233 -#define HCLK_SFC 234 -#define HCLK_SFCXIP 235 -#define HCLK_PDBUS 236 -#define HCLK_USBHOST 237 -#define HCLK_USBHOST_ARB 238 -#define HCLK_PDNPU 239 -#define HCLK_NPU 240 - -/* pclk */ -#define PCLK_CPUPVTM 245 -#define PCLK_PDBUS 246 -#define PCLK_DCF 247 -#define PCLK_WDT 248 -#define PCLK_MAILBOX 249 -#define PCLK_UART0 250 -#define PCLK_UART2 251 -#define PCLK_UART3 252 -#define PCLK_UART4 253 -#define PCLK_UART5 254 -#define PCLK_I2C1 255 -#define PCLK_I2C3 256 -#define PCLK_I2C4 257 -#define PCLK_I2C5 258 -#define PCLK_SPI1 259 -#define PCLK_PWM2 261 -#define PCLK_GPIO1 262 -#define PCLK_GPIO2 263 -#define PCLK_GPIO3 264 -#define PCLK_GPIO4 265 -#define PCLK_SARADC 266 -#define PCLK_TIMER 267 -#define PCLK_DECOM 268 -#define PCLK_CAN 269 -#define PCLK_NPU_TSADC 270 -#define PCLK_CPU_TSADC 271 -#define PCLK_ACDCDIG 272 -#define PCLK_PDVO 273 -#define PCLK_DSIHOST 274 -#define PCLK_PDVI 275 -#define PCLK_CSIHOST 276 -#define PCLK_PDGMAC 277 -#define PCLK_GMAC 278 -#define PCLK_PDDDR 279 -#define PCLK_DDR_MON 280 -#define PCLK_PDNPU 281 -#define PCLK_NPUPVTM 282 -#define PCLK_PDTOP 283 -#define PCLK_TOPCRU 284 -#define PCLK_TOPGRF 285 -#define PCLK_CPUEMADET 286 -#define PCLK_DDRPHY 287 -#define PCLK_DSIPHY 289 -#define PCLK_CSIPHY0 290 -#define PCLK_CSIPHY1 291 -#define PCLK_USBPHY_HOST 292 -#define PCLK_USBPHY_OTG 293 -#define PCLK_OTP 294 - -#define CLK_NR_CLKS (PCLK_OTP + 1) - -/* pmu soft-reset indices */ - -/* pmu_cru_softrst_con0 */ -#define SRST_PDPMU_NIU_P 0 -#define SRST_PMU_SGRF_P 1 -#define SRST_PMU_SGRF_REMAP_P 2 -#define SRST_I2C0_P 3 -#define SRST_I2C0 4 -#define SRST_I2C2_P 7 -#define SRST_I2C2 8 -#define SRST_UART1_P 9 -#define SRST_UART1 10 -#define SRST_PWM0_P 11 -#define SRST_PWM0 12 -#define SRST_PWM1_P 13 -#define SRST_PWM1 14 -#define SRST_DDR_FAIL_SAFE 15 - -/* pmu_cru_softrst_con1 */ -#define SRST_GPIO0_P 17 -#define SRST_GPIO0_DB 18 -#define SRST_SPI0_P 19 -#define SRST_SPI0 20 -#define SRST_PMUGRF_P 21 -#define SRST_CHIPVEROTP_P 22 -#define SRST_PMUPVTM 24 -#define SRST_PMUPVTM_P 25 -#define SRST_PMUCRU_P 30 - -/* soft-reset indices */ - -/* cru_softrst_con0 */ -#define SRST_CORE0_PO 0 -#define SRST_CORE1_PO 1 -#define SRST_CORE2_PO 2 -#define SRST_CORE3_PO 3 -#define SRST_CORE0 4 -#define SRST_CORE1 5 -#define SRST_CORE2 6 -#define SRST_CORE3 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 -#define SRST_NL2 12 -#define SRST_CORE_NIU_A 13 -#define SRST_DBG_DAPLITE_P 14 -#define SRST_DAPLITE_P 15 - -/* cru_softrst_con1 */ -#define SRST_PDBUS_NIU1_A 16 -#define SRST_PDBUS_NIU1_H 17 -#define SRST_PDBUS_NIU1_P 18 -#define SRST_PDBUS_NIU2_A 19 -#define SRST_PDBUS_NIU2_H 20 -#define SRST_PDBUS_NIU3_A 21 -#define SRST_PDBUS_NIU3_H 22 -#define SRST_PDBUS_HOLD_NIU1_A 23 -#define SRST_DBG_NIU_P 24 -#define SRST_PDCORE_NIIU_H 25 -#define SRST_MUC_NIU 26 -#define SRST_DCF_A 29 -#define SRST_DCF_P 30 -#define SRST_SYSTEM_SRAM_A 31 - -/* cru_softrst_con2 */ -#define SRST_I2C1_P 32 -#define SRST_I2C1 33 -#define SRST_I2C3_P 34 -#define SRST_I2C3 35 -#define SRST_I2C4_P 36 -#define SRST_I2C4 37 -#define SRST_I2C5_P 38 -#define SRST_I2C5 39 -#define SRST_SPI1_P 40 -#define SRST_SPI1 41 -#define SRST_MCU_CORE 42 -#define SRST_PWM2_P 44 -#define SRST_PWM2 45 -#define SRST_SPINLOCK_A 46 - -/* cru_softrst_con3 */ -#define SRST_UART0_P 48 -#define SRST_UART0 49 -#define SRST_UART2_P 50 -#define SRST_UART2 51 -#define SRST_UART3_P 52 -#define SRST_UART3 53 -#define SRST_UART4_P 54 -#define SRST_UART4 55 -#define SRST_UART5_P 56 -#define SRST_UART5 57 -#define SRST_WDT_P 58 -#define SRST_SARADC_P 59 -#define SRST_GRF_P 61 -#define SRST_TIMER_P 62 -#define SRST_MAILBOX_P 63 - -/* cru_softrst_con4 */ -#define SRST_TIMER0 64 -#define SRST_TIMER1 65 -#define SRST_TIMER2 66 -#define SRST_TIMER3 67 -#define SRST_TIMER4 68 -#define SRST_TIMER5 69 -#define SRST_INTMUX_P 70 -#define SRST_GPIO1_P 72 -#define SRST_GPIO1_DB 73 -#define SRST_GPIO2_P 74 -#define SRST_GPIO2_DB 75 -#define SRST_GPIO3_P 76 -#define SRST_GPIO3_DB 77 -#define SRST_GPIO4_P 78 -#define SRST_GPIO4_DB 79 - -/* cru_softrst_con5 */ -#define SRST_CAN_P 80 -#define SRST_CAN 81 -#define SRST_DECOM_A 85 -#define SRST_DECOM_P 86 -#define SRST_DECOM_D 87 -#define SRST_PDCRYPTO_NIU_A 88 -#define SRST_PDCRYPTO_NIU_H 89 -#define SRST_CRYPTO_A 90 -#define SRST_CRYPTO_H 91 -#define SRST_CRYPTO_CORE 92 -#define SRST_CRYPTO_PKA 93 -#define SRST_SGRF_P 95 - -/* cru_softrst_con6 */ -#define SRST_PDAUDIO_NIU_H 96 -#define SRST_PDAUDIO_NIU_P 97 -#define SRST_I2S0_H 98 -#define SRST_I2S0_TX_M 99 -#define SRST_I2S0_RX_M 100 -#define SRST_I2S1_H 101 -#define SRST_I2S1_M 102 -#define SRST_I2S2_H 103 -#define SRST_I2S2_M 104 -#define SRST_PDM_H 105 -#define SRST_PDM_M 106 -#define SRST_AUDPWM_H 107 -#define SRST_AUDPWM 108 -#define SRST_ACDCDIG_P 109 -#define SRST_ACDCDIG 110 - -/* cru_softrst_con7 */ -#define SRST_PDVEPU_NIU_A 112 -#define SRST_PDVEPU_NIU_H 113 -#define SRST_VENC_A 114 -#define SRST_VENC_H 115 -#define SRST_VENC_CORE 116 -#define SRST_PDVDEC_NIU_A 117 -#define SRST_PDVDEC_NIU_H 118 -#define SRST_VDEC_A 119 -#define SRST_VDEC_H 120 -#define SRST_VDEC_CORE 121 -#define SRST_VDEC_CA 122 -#define SRST_VDEC_HEVC_CA 123 -#define SRST_PDJPEG_NIU_A 124 -#define SRST_PDJPEG_NIU_H 125 -#define SRST_JPEG_A 126 -#define SRST_JPEG_H 127 - -/* cru_softrst_con8 */ -#define SRST_PDVO_NIU_A 128 -#define SRST_PDVO_NIU_H 129 -#define SRST_PDVO_NIU_P 130 -#define SRST_RGA_A 131 -#define SRST_RGA_H 132 -#define SRST_RGA_CORE 133 -#define SRST_VOP_A 134 -#define SRST_VOP_H 135 -#define SRST_VOP_D 136 -#define SRST_TXBYTEHS_DSIHOST 137 -#define SRST_DSIHOST_P 138 -#define SRST_IEP_A 139 -#define SRST_IEP_H 140 -#define SRST_IEP_CORE 141 -#define SRST_ISP_RX_P 142 - -/* cru_softrst_con9 */ -#define SRST_PDVI_NIU_A 144 -#define SRST_PDVI_NIU_H 145 -#define SRST_PDVI_NIU_P 146 -#define SRST_ISP 147 -#define SRST_CIF_A 148 -#define SRST_CIF_H 149 -#define SRST_CIF_D 150 -#define SRST_CIF_P 151 -#define SRST_CIF_I 152 -#define SRST_CIF_RX_P 153 -#define SRST_PDISPP_NIU_A 154 -#define SRST_PDISPP_NIU_H 155 -#define SRST_ISPP_A 156 -#define SRST_ISPP_H 157 -#define SRST_ISPP 158 -#define SRST_CSIHOST_P 159 - -/* cru_softrst_con10 */ -#define SRST_PDPHPMID_NIU_A 160 -#define SRST_PDPHPMID_NIU_H 161 -#define SRST_PDNVM_NIU_H 163 -#define SRST_SDMMC_H 164 -#define SRST_SDIO_H 165 -#define SRST_EMMC_H 166 -#define SRST_SFC_H 167 -#define SRST_SFCXIP_H 168 -#define SRST_SFC 169 -#define SRST_NANDC_H 170 -#define SRST_NANDC 171 -#define SRST_PDSDMMC_H 173 -#define SRST_PDSDIO_H 174 - -/* cru_softrst_con11 */ -#define SRST_PDUSB_NIU_A 176 -#define SRST_PDUSB_NIU_H 177 -#define SRST_USBHOST_H 178 -#define SRST_USBHOST_ARB_H 179 -#define SRST_USBHOST_UTMI 180 -#define SRST_USBOTG_A 181 -#define SRST_USBPHY_OTG_P 182 -#define SRST_USBPHY_HOST_P 183 -#define SRST_USBPHYPOR_OTG 184 -#define SRST_USBPHYPOR_HOST 185 -#define SRST_PDGMAC_NIU_A 188 -#define SRST_PDGMAC_NIU_P 189 -#define SRST_GMAC_A 190 - -/* cru_softrst_con12 */ -#define SRST_DDR_DFICTL_P 193 -#define SRST_DDR_MON_P 194 -#define SRST_DDR_STANDBY_P 195 -#define SRST_DDR_GRF_P 196 -#define SRST_DDR_MSCH_P 197 -#define SRST_DDR_SPLIT_A 198 -#define SRST_DDR_MSCH 199 -#define SRST_DDR_DFICTL 202 -#define SRST_DDR_STANDBY 203 -#define SRST_NPUMCU_NIU 205 -#define SRST_DDRPHY_P 206 -#define SRST_DDRPHY 207 - -/* cru_softrst_con13 */ -#define SRST_PDNPU_NIU_A 208 -#define SRST_PDNPU_NIU_H 209 -#define SRST_PDNPU_NIU_P 210 -#define SRST_NPU_A 211 -#define SRST_NPU_H 212 -#define SRST_NPU 213 -#define SRST_NPUPVTM_P 214 -#define SRST_NPUPVTM 215 -#define SRST_NPU_TSADC_P 216 -#define SRST_NPU_TSADC 217 -#define SRST_NPU_TSADCPHY 218 -#define SRST_CIFLITE_A 220 -#define SRST_CIFLITE_H 221 -#define SRST_CIFLITE_D 222 -#define SRST_CIFLITE_RX_P 223 - -/* cru_softrst_con14 */ -#define SRST_TOPNIU_P 224 -#define SRST_TOPCRU_P 225 -#define SRST_TOPGRF_P 226 -#define SRST_CPUEMADET_P 227 -#define SRST_CSIPHY0_P 228 -#define SRST_CSIPHY1_P 229 -#define SRST_DSIPHY_P 230 -#define SRST_CPU_TSADC_P 232 -#define SRST_CPU_TSADC 233 -#define SRST_CPU_TSADCPHY 234 -#define SRST_CPUPVTM_P 235 -#define SRST_CPUPVTM 236 - -#endif diff --git a/include/dt-bindings/power/rockchip,rv1126-power.h b/include/dt-bindings/power/rockchip,rv1126-power.h deleted file mode 100644 index 38a68e000d..0000000000 --- a/include/dt-bindings/power/rockchip,rv1126-power.h +++ /dev/null @@ -1,35 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ - -#ifndef __DT_BINDINGS_POWER_RV1126_POWER_H__ -#define __DT_BINDINGS_POWER_RV1126_POWER_H__ - -/* VD_CORE */ -#define RV1126_PD_CPU_0 0 -#define RV1126_PD_CPU_1 1 -#define RV1126_PD_CPU_2 2 -#define RV1126_PD_CPU_3 3 -#define RV1126_PD_CORE_ALIVE 4 - -/* VD_PMU */ -#define RV1126_PD_PMU 5 -#define RV1126_PD_PMU_ALIVE 6 - -/* VD_NPU */ -#define RV1126_PD_NPU 7 - -/* VD_VEPU */ -#define RV1126_PD_VEPU 8 - -/* VD_LOGIC */ -#define RV1126_PD_VI 9 -#define RV1126_PD_VO 10 -#define RV1126_PD_ISPP 11 -#define RV1126_PD_VDPU 12 -#define RV1126_PD_CRYPTO 13 -#define RV1126_PD_DDR 14 -#define RV1126_PD_NVM 15 -#define RV1126_PD_SDIO 16 -#define RV1126_PD_USB 17 -#define RV1126_PD_LOGIC_ALIVE 18 - -#endif
Hi Anand,
On 5/10/24 14:43, Anand Moon wrote:
Migrate RV1126 boards that exists in Linux v6.8 to use OF_UPSTREAM.
Following targets is migrated to use OF_UPSTREAM:
- rv1126-edgeble-neu2 : Board is an industrial form factor IO board.
- sonoff-ihost-rv1126 : Gateway device designed to provide a Smart Home Hub.
This looks fine to me.
Tested on Sonoff iHost
Reviewed-By: Tim Lunn tim@feathertop.org Tested-By: Tim Lunn tim@feathertop.org
Cc: Tim Lunn tim@feathertop.org Cc: Jagan Teki jagan@edgeble.ai Signed-off-by: Anand Moon linux.amoon@gmail.com
v2: remove the dt-bindings for clock and power fix the typo in commit message
Tested on neu2 board.
arch/arm/dts/Makefile | 3 - arch/arm/dts/rv1126-edgeble-neu2-io.dts | 112 ---- arch/arm/dts/rv1126-edgeble-neu2.dtsi | 345 ---------- arch/arm/dts/rv1126-pinctrl.dtsi | 341 ---------- arch/arm/dts/rv1126-sonoff-ihost.dts | 29 - arch/arm/dts/rv1126-sonoff-ihost.dtsi | 404 ----------- arch/arm/dts/rv1126.dtsi | 623 ----------------- arch/arm/mach-rockchip/Kconfig | 1 + configs/neu2-io-rv1126_defconfig | 2 +- configs/sonoff-ihost-rv1126_defconfig | 2 +- .../dt-bindings/clock/rockchip,rv1126-cru.h | 632 ------------------ .../dt-bindings/power/rockchip,rv1126-power.h | 35 - 12 files changed, 3 insertions(+), 2526 deletions(-) delete mode 100644 arch/arm/dts/rv1126-edgeble-neu2-io.dts delete mode 100644 arch/arm/dts/rv1126-edgeble-neu2.dtsi delete mode 100644 arch/arm/dts/rv1126-pinctrl.dtsi delete mode 100644 arch/arm/dts/rv1126-sonoff-ihost.dts delete mode 100644 arch/arm/dts/rv1126-sonoff-ihost.dtsi delete mode 100644 arch/arm/dts/rv1126.dtsi delete mode 100644 include/dt-bindings/clock/rockchip,rv1126-cru.h delete mode 100644 include/dt-bindings/power/rockchip,rv1126-power.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 087645f354..79fc100dce 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -97,9 +97,6 @@ dtb-$(CONFIG_ROCKCHIP_RK3368) += \ rk3368-geekbox.dtb \ rk3368-px5-evb.dtb \
-dtb-$(CONFIG_ROCKCHIP_RV1126) += \
- rv1126-edgeble-neu2-io.dtb
- dtb-$(CONFIG_ARCH_S5P4418) += \ s5p4418-nanopi2.dtb
diff --git a/arch/arm/dts/rv1126-edgeble-neu2-io.dts b/arch/arm/dts/rv1126-edgeble-neu2-io.dts deleted file mode 100644 index 0c2396b8f8..0000000000 --- a/arch/arm/dts/rv1126-edgeble-neu2-io.dts +++ /dev/null @@ -1,112 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2020 Rockchip Electronics Co., Ltd.
- Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd.
-/dts-v1/; -#include "rv1126.dtsi" -#include "rv1126-edgeble-neu2.dtsi"
- model = "Edgeble Neu2 IO Board";
- compatible = "edgeble,neural-compute-module-2-io",
"edgeble,neural-compute-module-2", "rockchip,rv1126";
- aliases {
serial2 = &uart2;
- chosen {
- vcc12v_dcin: vcc12v-dcin-regulator {
regulator-name = "vcc12v_dcin";
regulator-boot-on;
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-boot-on;
vin-supply = <&vcc12v_dcin>;
- v3v3_sys: v3v3-sys-regulator {
regulator-name = "v3v3_sys";
regulator-boot-on;
vin-supply = <&vcc5v0_sys>;
-&gmac {
- assigned-clocks = <&cru CLK_GMAC_SRC>, <&cru CLK_GMAC_TX_RX>,
<&cru CLK_GMAC_ETHERNET_OUT>;
- assigned-clock-parents = <&cru CLK_GMAC_SRC_M1>, <&cru RGMII_MODE_CLK>;
- assigned-clock-rates = <125000000>, <0>, <25000000>;
- clock_in_out = "input";
- phy-mode = "rgmii";
- pinctrl-0 = <&rgmiim1_miim &rgmiim1_bus2 &rgmiim1_bus4 &clk_out_ethernetm1_pins>;
- tx_delay = <0x2a>;
- rx_delay = <0x1a>;
- status = "okay";
-&mdio {
compatible = "ethernet-phy-id001c.c916",
reg = <0x0>;
reset-assert-us = <20000>;
reset-deassert-us = <100000>;
reset-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_LOW>;
-&pinctrl {
- ethernet {
rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>;
-&pwm11 {
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr104;
- status = "okay";
-&uart2 {
- status = "okay";
-}; diff --git a/arch/arm/dts/rv1126-edgeble-neu2.dtsi b/arch/arm/dts/rv1126-edgeble-neu2.dtsi deleted file mode 100644 index 7ea8d7d16f..0000000000 --- a/arch/arm/dts/rv1126-edgeble-neu2.dtsi +++ /dev/null @@ -1,345 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- compatible = "edgeble,neural-compute-module-2", "rockchip,rv1126";
- aliases {
mmc0 = &emmc;
- vccio_flash: vccio-flash-regulator {
enable-active-high;
gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&flash_vol_sel>;
regulator-name = "vccio_flash";
regulator-boot-on;
vin-supply = <&vcc_3v3>;
-&cpu0 {
-&emmc {
- bus-width = <8>;
- non-removable;
- pinctrl-0 = <&emmc_bus8 &emmc_cmd &emmc_clk>;
- vqmmc-supply = <&vccio_flash>;
- status = "okay";
-&i2c0 {
- status = "okay";
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_0v8: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: LDO_REG4 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&pinctrl {
- bt {
- flash {
- pmic {
- wifi {
-&pmu_io_domains {
- status = "okay";
-&saradc {
- status = "okay";
-&sfc {
- status = "okay";
- flash@0 {
reg = <0>;
-&sdio {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
-&uart0 {
- status = "okay";
- bluetooth {
- Copyright (c) 2020 Fuzhou Rockchip Electronics Co., Ltd
- This file is auto generated by pin2dts tool, please keep these code
- by adding changes at end of this file.
-&pinctrl {
/omit-if-no-ref/
rockchip,pins =
- emmc {
/omit-if-no-ref/
rockchip,pins =
/* emmc_rstn */
/omit-if-no-ref/
rockchip,pins =
/* emmc_d0 */
/* emmc_d1 */
/* emmc_d2 */
/* emmc_d3 */
/* emmc_d4 */
/* emmc_d5 */
/* emmc_d6 */
/* emmc_d7 */
/omit-if-no-ref/
rockchip,pins =
/* emmc_clko */
/omit-if-no-ref/
rockchip,pins =
/* emmc_cmd */
- fspi {
/omit-if-no-ref/
rockchip,pins =
/* fspi_clk */
/* fspi_cs0n */
/* fspi_d0 */
/* fspi_d1 */
/* fspi_d2 */
/* fspi_d3 */
- i2c0 {
/omit-if-no-ref/
rockchip,pins =
/* i2c0_scl */
/* i2c0_sda */
- i2c2 {
/omit-if-no-ref/
rockchip,pins =
/* i2c2_scl */
/* i2c2_sda */
- pwm2 {
/omit-if-no-ref/
rockchip,pins =
/* pwm2_pin_m0 */
- pwm11 {
/omit-if-no-ref/
rockchip,pins =
/* pwm11_pin_m0 */
- rgmii {
/omit-if-no-ref/
rockchip,pins =
/* rgmii_mdc_m1 */
/* rgmii_mdio_m1 */
/omit-if-no-ref/
rockchip,pins =
/* rgmii_rxer_m1 */
/omit-if-no-ref/
rockchip,pins =
/* rgmii_rxd0_m1 */
/* rgmii_rxd1_m1 */
/* rgmii_rxdv_m1 */
/* rgmii_txd0_m1 */
/* rgmii_txd1_m1 */
/* rgmii_txen_m1 */
/omit-if-no-ref/
rockchip,pins =
/* rgmii_rxd2_m1 */
/* rgmii_rxd3_m1 */
/* rgmii_txd2_m1 */
/* rgmii_txd3_m1 */
/omit-if-no-ref/
rockchip,pins =
/* rgmii_clk_m1 */
- sdmmc0 {
/omit-if-no-ref/
rockchip,pins =
/* sdmmc0_d0 */
/* sdmmc0_d1 */
/* sdmmc0_d2 */
/* sdmmc0_d3 */
/omit-if-no-ref/
rockchip,pins =
/* sdmmc0_clk */
/omit-if-no-ref/
rockchip,pins =
/* sdmmc0_cmd */
/omit-if-no-ref/
rockchip,pins =
/omit-if-no-ref/
rockchip,pins =
- sdmmc1 {
/omit-if-no-ref/
rockchip,pins =
/* sdmmc1_d0 */
/* sdmmc1_d1 */
/* sdmmc1_d2 */
/* sdmmc1_d3 */
/omit-if-no-ref/
rockchip,pins =
/* sdmmc1_clk */
/omit-if-no-ref/
rockchip,pins =
/* sdmmc1_cmd */
/omit-if-no-ref/
rockchip,pins =
/omit-if-no-ref/
rockchip,pins =
- uart0 {
/omit-if-no-ref/
rockchip,pins =
/* uart0_rx */
/* uart0_tx */
/omit-if-no-ref/
rockchip,pins =
/omit-if-no-ref/
rockchip,pins =
/omit-if-no-ref/
rockchip,pins =
- uart1 {
/omit-if-no-ref/
rockchip,pins =
/* uart1_rx_m0 */
/* uart1_tx_m0 */
- uart2 {
/omit-if-no-ref/
rockchip,pins =
/* uart2_rx_m1 */
/* uart2_tx_m1 */
- uart3 {
/omit-if-no-ref/
rockchip,pins =
/* uart3_rx_m0 */
/* uart3_tx_m0 */
/omit-if-no-ref/
rockchip,pins =
/* uart3_rx_m2 */
/* uart3_tx_m2 */
- uart4 {
/omit-if-no-ref/
rockchip,pins =
/* uart4_rx_m0 */
/* uart4_tx_m0 */
/omit-if-no-ref/
rockchip,pins =
/* uart4_rx_m2 */
/* uart4_tx_m2 */
- uart5 {
/omit-if-no-ref/
rockchip,pins =
/* uart5_rx_m0 */
/* uart5_tx_m0 */
/omit-if-no-ref/
rockchip,pins =
/* uart5_rx_m2 */
/* uart5_tx_m2 */
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
- aliases {
ethernet0 = &gmac;
mmc0 = &emmc;
- chosen {
regulator-boot-on;
-&emmc {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&i2c0 {
- status = "okay";
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_0v8: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: LDO_REG4 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&i2c2 {
- status = "okay";
- pcf8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
-&gmac {
- status = "okay";
-&mdio {
reg = <0x0>;
reset-active-low;
-&pinctrl {
- ethernet {
- bt {
- pmic {
- wifi {
-&pmu_io_domains {
- status = "okay";
-&saradc {
- status = "okay";
-&sdio {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr104;
- status = "okay";
-&uart0 {
- uart-has-rtscts;
- status = "okay";
- bluetooth {
-&uart2 {
- status = "okay";
-&uart3 {
- status = "okay";
-&uart4 {
- status = "okay";
- Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd.
- aliases {
i2c0 = &i2c0;
i2c2 = &i2c2;
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
serial4 = &uart4;
serial5 = &uart5;
- cpus {
#size-cells = <0>;
cpu0: cpu@f00 {
reg = <0xf00>;
cpu1: cpu@f01 {
reg = <0xf01>;
cpu2: cpu@f02 {
reg = <0xf02>;
cpu3: cpu@f03 {
reg = <0xf03>;
- arm-pmu {
- psci {
method = "smc";
- timer {
ports = <&vop_out>;
#clock-cells = <0>;
#size-cells = <0>;
<&cru CLK_EMMC>,
<&cru HCLK_NANDC>,
<&cru CLK_NANDC>,
<&cru HCLK_SFC>,
<&cru HCLK_SFCXIP>,
<&cru SCLK_SFC>;
<&qos_nandc>,
<&qos_sfc>;
<&cru CLK_SDIO>;
<&cru HCLK_RGA>,
<&cru ACLK_VOP>,
<&cru HCLK_VOP>,
<&cru DCLK_VOP>,
<&cru ACLK_IEP>,
<&cru HCLK_IEP>,
<&qos_rga_wr>,
<&qos_vop>,
<&qos_iep>;
#size-cells = <0>;
#size-cells = <0>;
reg-shift = <2>;
reg-io-width = <4>;
#pwm-cells = <3>;
#clock-cells = <1>;
#reset-cells = <1>;
clocks = <&xin24m>;
#clock-cells = <1>;
#reset-cells = <1>;
#dma-cells = <1>;
#pwm-cells = <3>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
vop_out: port {
#size-cells = <0>;
reg = <0>;
reg = <1>;
#iommu-cells = <0>;
snps,mixed-burst;
snps,tso;
mdio: mdio {
queue0 {};
queue0 {};
#size-cells = <1>;
ranges;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
imply OF_UPSTREAM
- Copyright (c) 2019 Rockchip Electronics Co. Ltd.
- Author: Finley Xiao finley.xiao@rock-chips.com
-#endif
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- aliases {
serial2 = &uart2;
- chosen {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&gmac {
- status = "okay";
-&mdio {
reg = <0x0>;
-&pinctrl {
- ethernet {
-&pwm11 {
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr104;
- status = "okay";
-&uart2 {
- status = "okay";
- aliases {
mmc0 = &emmc;
enable-active-high;
regulator-boot-on;
-&cpu0 {
-&emmc {
- bus-width = <8>;
- non-removable;
- status = "okay";
-&i2c0 {
- status = "okay";
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_0v8: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: LDO_REG4 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&pinctrl {
- bt {
rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
- flash {
flash_vol_sel: flash-vol-sel {
rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
- wifi {
-&pmu_io_domains {
- vccio1-supply = <&vccio_flash>;
- status = "okay";
-&saradc {
- status = "okay";
-&sfc {
- pinctrl-0 = <&fspi_pins>;
- status = "okay";
- flash@0 {
compatible = "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <50000000>;
spi-rx-bus-width = <4>;
spi-tx-bus-width = <1>;
-&sdio {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
-&uart0 {
- status = "okay";
- bluetooth {
compatible = "qcom,qca9377-bt";
enable-gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_HIGH>; /* BT_RST */
pinctrl-0 = <&bt_enable>;
vddxo-supply = <&vcc3v3_sys>;
vddio-supply = <&vcc_1v8>;
-}; diff --git a/arch/arm/dts/rv1126-pinctrl.dtsi b/arch/arm/dts/rv1126-pinctrl.dtsi deleted file mode 100644 index f84f5f2d96..0000000000 --- a/arch/arm/dts/rv1126-pinctrl.dtsi +++ /dev/null @@ -1,341 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-#include <dt-bindings/pinctrl/rockchip.h> -#include "rockchip-pinconf.dtsi"
-&pinctrl {
- clk_out_ethernet {
/omit-if-no-ref/
clk_out_ethernetm1_pins: clk-out-ethernetm1-pins {
rockchip,pins =
/* clk_out_ethernet_m1 */
<2 RK_PC5 2 &pcfg_pull_none>;
- emmc {
/omit-if-no-ref/
emmc_rstnout: emmc-rstnout {
rockchip,pins =
/* emmc_rstn */
<1 RK_PA3 2 &pcfg_pull_none>;
/omit-if-no-ref/
emmc_bus8: emmc-bus8 {
rockchip,pins =
/* emmc_d0 */
<0 RK_PC4 2 &pcfg_pull_up_drv_level_2>,
/* emmc_d1 */
<0 RK_PC5 2 &pcfg_pull_up_drv_level_2>,
/* emmc_d2 */
<0 RK_PC6 2 &pcfg_pull_up_drv_level_2>,
/* emmc_d3 */
<0 RK_PC7 2 &pcfg_pull_up_drv_level_2>,
/* emmc_d4 */
<0 RK_PD0 2 &pcfg_pull_up_drv_level_2>,
/* emmc_d5 */
<0 RK_PD1 2 &pcfg_pull_up_drv_level_2>,
/* emmc_d6 */
<0 RK_PD2 2 &pcfg_pull_up_drv_level_2>,
/* emmc_d7 */
<0 RK_PD3 2 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
emmc_clk: emmc-clk {
rockchip,pins =
/* emmc_clko */
<0 RK_PD7 2 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
emmc_cmd: emmc-cmd {
rockchip,pins =
/* emmc_cmd */
<0 RK_PD5 2 &pcfg_pull_up_drv_level_2>;
- fspi {
/omit-if-no-ref/
fspi_pins: fspi-pins {
rockchip,pins =
/* fspi_clk */
<1 RK_PA3 3 &pcfg_pull_down>,
/* fspi_cs0n */
<0 RK_PD4 3 &pcfg_pull_up>,
/* fspi_d0 */
<1 RK_PA0 3 &pcfg_pull_up>,
/* fspi_d1 */
<1 RK_PA1 3 &pcfg_pull_up>,
/* fspi_d2 */
<0 RK_PD6 3 &pcfg_pull_up>,
/* fspi_d3 */
<1 RK_PA2 3 &pcfg_pull_up>;
- i2c0 {
/omit-if-no-ref/
i2c0_xfer: i2c0-xfer {
rockchip,pins =
/* i2c0_scl */
<0 RK_PB4 1 &pcfg_pull_none_drv_level_0_smt>,
/* i2c0_sda */
<0 RK_PB5 1 &pcfg_pull_none_drv_level_0_smt>;
- i2c2 {
/omit-if-no-ref/
i2c2_xfer: i2c2-xfer {
rockchip,pins =
/* i2c2_scl */
<0 RK_PC2 1 &pcfg_pull_none_drv_level_0_smt>,
/* i2c2_sda */
<0 RK_PC3 1 &pcfg_pull_none_drv_level_0_smt>;
- pwm2 {
/omit-if-no-ref/
pwm2m0_pins: pwm2m0-pins {
rockchip,pins =
/* pwm2_pin_m0 */
<0 RK_PC0 3 &pcfg_pull_none>;
- pwm11 {
/omit-if-no-ref/
pwm11m0_pins: pwm11m0-pins {
rockchip,pins =
/* pwm11_pin_m0 */
<3 RK_PA7 6 &pcfg_pull_none>;
- rgmii {
/omit-if-no-ref/
rgmiim1_miim: rgmiim1-miim {
rockchip,pins =
/* rgmii_mdc_m1 */
<2 RK_PC2 2 &pcfg_pull_none>,
/* rgmii_mdio_m1 */
<2 RK_PC1 2 &pcfg_pull_none>;
/omit-if-no-ref/
rgmiim1_rxer: rgmiim1-rxer {
rockchip,pins =
/* rgmii_rxer_m1 */
<2 RK_PC0 2 &pcfg_pull_none>;
/omit-if-no-ref/
rgmiim1_bus2: rgmiim1-bus2 {
rockchip,pins =
/* rgmii_rxd0_m1 */
<2 RK_PB5 2 &pcfg_pull_none>,
/* rgmii_rxd1_m1 */
<2 RK_PB6 2 &pcfg_pull_none>,
/* rgmii_rxdv_m1 */
<2 RK_PB4 2 &pcfg_pull_none>,
/* rgmii_txd0_m1 */
<2 RK_PC3 2 &pcfg_pull_none_drv_level_3>,
/* rgmii_txd1_m1 */
<2 RK_PC4 2 &pcfg_pull_none_drv_level_3>,
/* rgmii_txen_m1 */
<2 RK_PC6 2 &pcfg_pull_none_drv_level_3>;
/omit-if-no-ref/
rgmiim1_bus4: rgmiim1-bus4 {
rockchip,pins =
/* rgmii_rxclk_m1 */
<2 RK_PD3 2 &pcfg_pull_none>,
/* rgmii_rxd2_m1 */
<2 RK_PC7 2 &pcfg_pull_none>,
/* rgmii_rxd3_m1 */
<2 RK_PD0 2 &pcfg_pull_none>,
/* rgmii_txclk_m1 */
<2 RK_PD2 2 &pcfg_pull_none_drv_level_3>,
/* rgmii_txd2_m1 */
<2 RK_PD1 2 &pcfg_pull_none_drv_level_3>,
/* rgmii_txd3_m1 */
<2 RK_PA4 2 &pcfg_pull_none_drv_level_3>;
/omit-if-no-ref/
rgmiim1_mclkinout: rgmiim1-mclkinout {
rockchip,pins =
/* rgmii_clk_m1 */
<2 RK_PB7 2 &pcfg_pull_none>;
- sdmmc0 {
/omit-if-no-ref/
sdmmc0_bus4: sdmmc0-bus4 {
rockchip,pins =
/* sdmmc0_d0 */
<1 RK_PA4 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc0_d1 */
<1 RK_PA5 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc0_d2 */
<1 RK_PA6 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc0_d3 */
<1 RK_PA7 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc0_clk: sdmmc0-clk {
rockchip,pins =
/* sdmmc0_clk */
<1 RK_PB0 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc0_cmd: sdmmc0-cmd {
rockchip,pins =
/* sdmmc0_cmd */
<1 RK_PB1 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc0_det: sdmmc0-det {
rockchip,pins =
<0 RK_PA3 1 &pcfg_pull_none>;
/omit-if-no-ref/
sdmmc0_pwr: sdmmc0-pwr {
rockchip,pins =
<0 RK_PC0 1 &pcfg_pull_none>;
- sdmmc1 {
/omit-if-no-ref/
sdmmc1_bus4: sdmmc1-bus4 {
rockchip,pins =
/* sdmmc1_d0 */
<1 RK_PB4 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc1_d1 */
<1 RK_PB5 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc1_d2 */
<1 RK_PB6 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc1_d3 */
<1 RK_PB7 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc1_clk: sdmmc1-clk {
rockchip,pins =
/* sdmmc1_clk */
<1 RK_PB2 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc1_cmd: sdmmc1-cmd {
rockchip,pins =
/* sdmmc1_cmd */
<1 RK_PB3 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc1_det: sdmmc1-det {
rockchip,pins =
<1 RK_PD0 2 &pcfg_pull_none>;
/omit-if-no-ref/
sdmmc1_pwr: sdmmc1-pwr {
rockchip,pins =
<1 RK_PD1 2 &pcfg_pull_none>;
- uart0 {
/omit-if-no-ref/
uart0_xfer: uart0-xfer {
rockchip,pins =
/* uart0_rx */
<1 RK_PC2 1 &pcfg_pull_up>,
/* uart0_tx */
<1 RK_PC3 1 &pcfg_pull_up>;
/omit-if-no-ref/
uart0_ctsn: uart0-ctsn {
rockchip,pins =
<1 RK_PC1 1 &pcfg_pull_none>;
/omit-if-no-ref/
uart0_rtsn: uart0-rtsn {
rockchip,pins =
<1 RK_PC0 1 &pcfg_pull_none>;
/omit-if-no-ref/
uart0_rtsn_gpio: uart0-rts-pin {
rockchip,pins =
<1 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>;
- uart1 {
/omit-if-no-ref/
uart1m0_xfer: uart1m0-xfer {
rockchip,pins =
/* uart1_rx_m0 */
<0 RK_PB7 2 &pcfg_pull_up>,
/* uart1_tx_m0 */
<0 RK_PB6 2 &pcfg_pull_up>;
- uart2 {
/omit-if-no-ref/
uart2m1_xfer: uart2m1-xfer {
rockchip,pins =
/* uart2_rx_m1 */
<3 RK_PA3 1 &pcfg_pull_up>,
/* uart2_tx_m1 */
<3 RK_PA2 1 &pcfg_pull_up>;
- uart3 {
/omit-if-no-ref/
uart3m0_xfer: uart3m0-xfer {
rockchip,pins =
/* uart3_rx_m0 */
<3 RK_PC7 4 &pcfg_pull_up>,
/* uart3_tx_m0 */
<3 RK_PC6 4 &pcfg_pull_up>;
/omit-if-no-ref/
uart3m2_xfer: uart3m2-xfer {
rockchip,pins =
/* uart3_rx_m2 */
<3 RK_PA1 4 &pcfg_pull_up>,
/* uart3_tx_m2 */
<3 RK_PA0 4 &pcfg_pull_up>;
- uart4 {
/omit-if-no-ref/
uart4m0_xfer: uart4m0-xfer {
rockchip,pins =
/* uart4_rx_m0 */
<3 RK_PA5 4 &pcfg_pull_up>,
/* uart4_tx_m0 */
<3 RK_PA4 4 &pcfg_pull_up>;
/omit-if-no-ref/
uart4m2_xfer: uart4m2-xfer {
rockchip,pins =
/* uart4_rx_m2 */
<1 RK_PD4 3 &pcfg_pull_up>,
/* uart4_tx_m2 */
<1 RK_PD5 3 &pcfg_pull_up>;
- uart5 {
/omit-if-no-ref/
uart5m0_xfer: uart5m0-xfer {
rockchip,pins =
/* uart5_rx_m0 */
<3 RK_PA7 4 &pcfg_pull_up>,
/* uart5_tx_m0 */
<3 RK_PA6 4 &pcfg_pull_up>;
/omit-if-no-ref/
uart5m2_xfer: uart5m2-xfer {
rockchip,pins =
/* uart5_rx_m2 */
<2 RK_PA1 3 &pcfg_pull_up>,
/* uart5_tx_m2 */
<2 RK_PA0 3 &pcfg_pull_up>;
-}; diff --git a/arch/arm/dts/rv1126-sonoff-ihost.dts b/arch/arm/dts/rv1126-sonoff-ihost.dts deleted file mode 100644 index 77386a48d8..0000000000 --- a/arch/arm/dts/rv1126-sonoff-ihost.dts +++ /dev/null @@ -1,29 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-/dts-v1/; -#include "rv1126.dtsi" -#include "rv1126-sonoff-ihost.dtsi"
- model = "Sonoff iHost 4G";
- compatible = "itead,sonoff-ihost", "rockchip,rv1126";
-&cpu0 {
- cpu-supply = <&vdd_arm>;
-&cpu1 {
-&cpu2 {
-&cpu3 {
-}; diff --git a/arch/arm/dts/rv1126-sonoff-ihost.dtsi b/arch/arm/dts/rv1126-sonoff-ihost.dtsi deleted file mode 100644 index 32b329e87a..0000000000 --- a/arch/arm/dts/rv1126-sonoff-ihost.dtsi +++ /dev/null @@ -1,404 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- aliases {
ethernet0 = &gmac;
mmc0 = &emmc;
- chosen {
stdout-path = "serial2:1500000n8";
- vcc5v0_sys: regulator-vcc5v0-sys {
compatible = "regulator-fixed";
regulator-name = "vcc5v0_sys";
regulator-boot-on;
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
- sdio_pwrseq: pwrseq-sdio {
compatible = "mmc-pwrseq-simple";
clocks = <&rk809 1>;
clock-names = "ext_clock";
pinctrl-0 = <&wifi_enable_h>;
reset-gpios = <&gpio1 RK_PD0 GPIO_ACTIVE_LOW>;
-&emmc {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- pinctrl-0 = <&emmc_bus8 &emmc_cmd &emmc_clk &emmc_rstnout>;
- vmmc-supply = <&vcc_3v3>;
- status = "okay";
-&i2c0 {
- status = "okay";
- rk809: pmic@20 {
compatible = "rockchip,rk809";
reg = <0x20>;
interrupts = <RK_PB1 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <1>;
clock-output-names = "rk808-clkout1", "rk808-clkout2";
pinctrl-0 = <&pmic_int_l>;
rockchip,system-power-controller;
wakeup-source;
vcc1-supply = <&vcc5v0_sys>;
vcc2-supply = <&vcc5v0_sys>;
vcc3-supply = <&vcc5v0_sys>;
vcc4-supply = <&vcc5v0_sys>;
vcc5-supply = <&vcc_buck5>;
vcc6-supply = <&vcc_buck5>;
vcc7-supply = <&vcc5v0_sys>;
vcc8-supply = <&vcc3v3_sys>;
vcc9-supply = <&vcc5v0_sys>;
regulators {
vdd_npu_vepu: DCDC_REG1 {
regulator-name = "vdd_npu_vepu";
regulator-boot-on;
regulator-initial-mode = <0x2>;
regulator-min-microvolt = <650000>;
regulator-max-microvolt = <950000>;
regulator-ramp-delay = <6001>;
vdd_arm: DCDC_REG2 {
regulator-name = "vdd_arm";
regulator-boot-on;
regulator-min-microvolt = <725000>;
regulator-max-microvolt = <1350000>;
vcc_ddr: DCDC_REG3 {
regulator-name = "vcc_ddr";
regulator-boot-on;
regulator-state-mem {
regulator-on-in-suspend;
vcc3v3_sys: DCDC_REG4 {
regulator-name = "vcc3v3_sys";
regulator-boot-on;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-suspend-microvolt = <3300000>;
vcc_buck5: DCDC_REG5 {
regulator-name = "vcc_buck5";
regulator-always-on;
regulator-boot-on;
regulator-min-microvolt = <2200000>;
regulator-max-microvolt = <2200000>;
regulator-suspend-microvolt = <2200000>;
vcc_0v8: LDO_REG1 {
regulator-name = "vcc_0v8";
regulator-boot-on;
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <800000>;
regulator-off-in-suspend;
vcc1v8_pmu: LDO_REG2 {
regulator-name = "vcc1v8_pmu";
regulator-boot-on;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-suspend-microvolt = <1800000>;
vdd0v8_pmu: LDO_REG3 {
regulator-name = "vcc0v8_pmu";
regulator-boot-on;
regulator-suspend-microvolt = <800000>;
vcc_1v8: LDO_REG4 {
regulator-name = "vcc_1v8";
regulator-boot-on;
vcc_dovdd: LDO_REG5 {
regulator-name = "vcc_dovdd";
regulator-boot-on;
vcc_dvdd: LDO_REG6 {
regulator-name = "vcc_dvdd";
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
vcc_avdd: LDO_REG7 {
regulator-name = "vcc_avdd";
regulator-min-microvolt = <2800000>;
regulator-max-microvolt = <2800000>;
vccio_sd: LDO_REG8 {
regulator-name = "vccio_sd";
regulator-boot-on;
vcc3v3_sd: LDO_REG9 {
regulator-name = "vcc3v3_sd";
regulator-boot-on;
vcc_5v0: SWITCH_REG1 {
regulator-name = "vcc_5v0";
vcc_3v3: SWITCH_REG2 {
regulator-name = "vcc_3v3";
regulator-boot-on;
-&i2c2 {
- status = "okay";
- clock-frequency = <400000>;
- pcf8563: rtc@51 {
compatible = "nxp,pcf8563";
reg = <0x51>;
#clock-cells = <0>;
interrupt-parent = <&gpio0>;
interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>;
clock-output-names = "xin32k";
-&gmac {
- assigned-clocks = <&cru CLK_GMAC_SRC_M1>, <&cru CLK_GMAC_SRC>,
<&cru CLK_GMAC_TX_RX>;
- assigned-clock-parents = <&cru CLK_GMAC_RGMII_M1>, <&cru CLK_GMAC_SRC_M1>,
<&cru RMII_MODE_CLK>;
- assigned-clock-rates = <0>, <50000000>;
- clock_in_out = "output";
- phy-handle = <&phy>;
- phy-mode = "rmii";
- phy-supply = <&vcc_3v3>;
- pinctrl-0 = <&rgmiim1_miim &rgmiim1_rxer &rgmiim1_bus2 &rgmiim1_mclkinout>;
- status = "okay";
-&mdio {
- phy: ethernet-phy@0 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <0x0>;
pinctrl-0 = <ð_phy_rst>;
reset-active-low;
reset-assert-us = <50000>;
reset-deassert-us = <10000>;
reset-gpios = <&gpio2 RK_PA6 GPIO_ACTIVE_LOW>;
-&pinctrl {
- ethernet {
eth_phy_rst: eth-phy-rst {
rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_down>;
- bt {
bt_enable: bt-enable {
rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
bt_wake_dev: bt-wake-dev {
rockchip,pins = <1 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>;
bt_wake_host: bt-wake-host {
rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
pmic_int_l: pmic-int-l {
rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>;
- wifi {
wifi_enable_h: wifi-enable-h {
rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
-&pmu_io_domains {
- pmuio0-supply = <&vcc1v8_pmu>;
- pmuio1-supply = <&vcc3v3_sys>;
- vccio1-supply = <&vcc_1v8>;
- vccio2-supply = <&vccio_sd>;
- vccio3-supply = <&vcc_1v8>;
- vccio4-supply = <&vcc_dovdd>;
- vccio5-supply = <&vcc_1v8>;
- vccio6-supply = <&vcc_1v8>;
- vccio7-supply = <&vcc_dovdd>;
- status = "okay";
-&saradc {
- vref-supply = <&vcc_1v8>;
- status = "okay";
-&sdio {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- max-frequency = <100000000>;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdmmc1_clk &sdmmc1_cmd &sdmmc1_bus4>;
- rockchip,default-sample-phase = <90>;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc3v3_sys>;
- vqmmc-supply = <&vcc_1v8>;
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- card-detect-delay = <200>;
- pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_bus4 &sdmmc0_det>;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr104;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
-&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_ctsn &uart0_rtsn>;
- uart-has-rtscts;
- status = "okay";
- bluetooth {
compatible = "realtek,rtl8723ds-bt";
device-wake-gpios = <&gpio1 RK_PC7 GPIO_ACTIVE_HIGH>; /* BT_WAKE */
enable-gpios = <&gpio1 RK_PC6 GPIO_ACTIVE_HIGH>; /* BT_RST */
host-wake-gpios = <&gpio1 RK_PC5 GPIO_ACTIVE_HIGH>; /* BT_WAKE_HOST */
max-speed = <2000000>;
pinctrl-0 = <&bt_enable>, <&bt_wake_dev>, <&bt_wake_host>;
-&uart2 {
- status = "okay";
-&uart3 {
- pinctrl-0 = <&uart3m2_xfer>;
- status = "okay";
-&uart4 {
- pinctrl-0 = <&uart4m2_xfer>;
- status = "okay";
-}; diff --git a/arch/arm/dts/rv1126.dtsi b/arch/arm/dts/rv1126.dtsi deleted file mode 100644 index bb603cae13..0000000000 --- a/arch/arm/dts/rv1126.dtsi +++ /dev/null @@ -1,623 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-#include <dt-bindings/clock/rockchip,rv1126-cru.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/power/rockchip,rv1126-power.h> -#include <dt-bindings/soc/rockchip,boot-mode.h>
- compatible = "rockchip,rv1126";
- interrupt-parent = <&gic>;
- aliases {
i2c0 = &i2c0;
i2c2 = &i2c2;
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
serial4 = &uart4;
serial5 = &uart5;
- cpus {
#size-cells = <0>;
cpu0: cpu@f00 {
device_type = "cpu";
compatible = "arm,cortex-a7";
reg = <0xf00>;
enable-method = "psci";
clocks = <&cru ARMCLK>;
cpu1: cpu@f01 {
reg = <0xf01>;
cpu2: cpu@f02 {
reg = <0xf02>;
cpu3: cpu@f03 {
reg = <0xf03>;
- arm-pmu {
compatible = "arm,cortex-a7-pmu";
interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>;
- psci {
compatible = "arm,psci-1.0";
method = "smc";
- timer {
compatible = "arm,armv7-timer";
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>,
<GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>,
<GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>,
<GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
- display_subsystem {
compatible = "rockchip,display-subsystem";
ports = <&vop_out>;
- xin24m: oscillator {
compatible = "fixed-clock";
clock-output-names = "xin24m";
#clock-cells = <0>;
- grf: syscon@fe000000 {
compatible = "rockchip,rv1126-grf", "syscon", "simple-mfd";
reg = <0xfe000000 0x20000>;
- pmugrf: syscon@fe020000 {
compatible = "rockchip,rv1126-pmugrf", "syscon", "simple-mfd";
reg = <0xfe020000 0x1000>;
pmu_io_domains: io-domains {
compatible = "rockchip,rv1126-pmu-io-voltage-domain";
- qos_emmc: qos@fe860000 {
reg = <0xfe860000 0x20>;
- qos_nandc: qos@fe860080 {
reg = <0xfe860080 0x20>;
- qos_sfc: qos@fe860200 {
#size-cells = <0>;
<&cru CLK_EMMC>,
<&cru HCLK_NANDC>,
<&cru CLK_NANDC>,
<&cru HCLK_SFC>,
<&cru HCLK_SFCXIP>,
<&cru SCLK_SFC>;
<&qos_nandc>,
<&qos_sfc>;
<&cru CLK_SDIO>;
<&cru HCLK_RGA>,
<&cru ACLK_VOP>,
<&cru HCLK_VOP>,
<&cru DCLK_VOP>,
<&cru ACLK_IEP>,
<&cru HCLK_IEP>,
<&qos_rga_wr>,
<&qos_vop>,
<&qos_iep>;
#size-cells = <0>;
#size-cells = <0>;
reg-shift = <2>;
reg-io-width = <4>;
#pwm-cells = <3>;
#clock-cells = <1>;
#reset-cells = <1>;
clocks = <&xin24m>;
#clock-cells = <1>;
#reset-cells = <1>;
#dma-cells = <1>;
#pwm-cells = <3>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
vop_out: port {
#size-cells = <0>;
reg = <0>;
reg = <1>;
#iommu-cells = <0>;
snps,mixed-burst;
snps,tso;
mdio: mdio {
queue0 {};
queue0 {};
#size-cells = <1>;
ranges;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
imply OF_UPSTREAM
-#endif
Hi Kever,
It looks like I have used the my personal Signed-off-by send v3 with correct Signed-off-by with edegeble.ai id. can you apply the modified patch?
Thanks,
- Kever
Thanks -Anand
Anand Moon
Kever Yang
Tim Lunn
