[U-Boot] [RFC][PATCH 09/19] i2c, omap24xx: only set bus_initialized, if uboot is relocated
Signed-off-by: Heiko Schocher hs@denx.de --- drivers/i2c/omap24xx_i2c.c | 4 +++- 1 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 3256133..15ad39a 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -38,6 +38,7 @@ static unsigned int current_bus;
void i2c_init (int speed, int slaveadd) { + DECLARE_GLOBAL_DATA_PTR; int psc, fsscll, fssclh; int hsscll = 0, hssclh = 0; u32 scll, sclh; @@ -127,7 +128,8 @@ void i2c_init (int speed, int slaveadd) writew (0xFFFF, &i2c_base->stat); writew (0, &i2c_base->cnt);
- bus_initialized[current_bus] = 1; + if (gd->flags & GD_FLG_RELOC) + bus_initialized[current_bus] = 1; }
static int i2c_read_byte (u8 devaddr, u8 regoffset, u8 * value)
Heiko Schocher
