[U-Boot] [PATCH 1/2] mpc52xx, mucmc52, uc101: config cleanup
- as this boards are similiar, collect common config option in manroland-common.h - add OF support - update default environment
Signed-off-by: Heiko Schocher hs@denx.de --- board/mucmc52/mucmc52.c | 7 + board/uc101/uc101.c | 7 + include/configs/manroland-common.h | 336 ++++++++++++++++++++++++++++++++++++ include/configs/mucmc52.h | 256 +-------------------------- include/configs/uc101.h | 266 +--------------------------- 5 files changed, 368 insertions(+), 504 deletions(-) create mode 100644 include/configs/manroland-common.h
diff --git a/board/mucmc52/mucmc52.c b/board/mucmc52/mucmc52.c index 7181bd8..bac49be 100644 --- a/board/mucmc52/mucmc52.c +++ b/board/mucmc52/mucmc52.c @@ -398,3 +398,10 @@ void pci_init_board (void) pci_mpc5xxx_init (&hose); } #endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/board/uc101/uc101.c b/board/uc101/uc101.c index 7df349f..4030b9d 100644 --- a/board/uc101/uc101.c +++ b/board/uc101/uc101.c @@ -371,3 +371,10 @@ void hw_watchdog_reset(void) *(vu_long *)MPC5XXX_GPT0_ENABLE = GPT_OUT_0; } #endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/include/configs/manroland-common.h b/include/configs/manroland-common.h new file mode 100644 index 0000000..7c2f2c1 --- /dev/null +++ b/include/configs/manroland-common.h @@ -0,0 +1,336 @@ +/* + * (C) Copyright 2009 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MANROLAND_COMMON_H +#define __MANROLAND_COMMON_H + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_MPC5xxx 1 /* This is an MPC5xxx CPU */ +#define CONFIG_MPC5200 1 /* (more precisely an MPC5200 CPU) */ + +#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ + +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#define CONFIG_BOARD_EARLY_INIT_R + +#define CONFIG_HIGH_BATS 1 /* High BATs supported */ + +/* + * Serial console configuration + */ +#define CONFIG_PSC_CONSOLE 1 /* console is on PSC1 */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200,\ + 230400 } + +/* Partitions */ +#define CONFIG_DOS_PARTITION + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DISPLAY +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_DTT +#define CONFIG_CMD_IDE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_NFS +#define CONFIG_CMD_MII +#define CONFIG_CMD_SNTP + +#define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */ + +#if (TEXT_BASE == 0xFFF00000) /* Boot low */ +# define CONFIG_SYS_LOWBOOT 1 +#endif + +/* + * Autobooting + */ +#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ + +#define CONFIG_PREBOOT "echo;" \ + "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ + "echo" + +#undef CONFIG_BOOTARGS + +#define xstr(s) str(s) +#define str(s) #s + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addwdt=setenv bootargs ${bootargs} wdt=off\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "kernel_addr=ff810000\0" \ + "fdt_addr="xstr(CONFIG_SYS_FLASH_BASE)"\0" \ + "flash_nfs=run nfsargs addip addcon addwdt;" \ + "bootm ${kernel_addr} - ${fdt_addr}\0" \ + "rootpath=/opt/eldk/ppc_82xx\0" \ + "kernel_addr_r=300000\0" \ + "fdt_addr_r=200000\0" \ + "fdt_file=" xstr(CONFIG_HOSTNAME) "/" \ + xstr(CONFIG_HOSTNAME) ".dtb\0" \ + "kernel_file=" xstr(CONFIG_HOSTNAME) "/uImage \0" \ + "load_fdt=tftp ${fdt_addr_r} ${fdt_file};\0" \ + "load_kernel=tftp ${kernel_addr_r} ${kernel_file};\0" \ + "addcon=setenv bootargs ${bootargs} console=ttyPSC0,${baudrate}\0"\ + "net_nfs=run load_fdt load_kernel; " \ + "run nfsargs addip addcon addwdt;" \ + "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.bin \0" \ + "u-boot_addr_r=200000\0" \ + "load=tftp ${u-boot_addr_r} ${u-boot}\0" \ + "update=protect off " xstr(TEXT_BASE) " +${filesize};" \ + "erase " xstr(TEXT_BASE) " +${filesize};" \ + "cp.b ${u-boot_addr_r} " xstr(TEXT_BASE) \ + " ${filesize};" \ + "protect on " xstr(TEXT_BASE) " +${filesize}\0" \ + "" + +#define CONFIG_BOOTCOMMAND "run net_nfs" + +#define CONFIG_MISC_INIT_R 1 + +/* + * IPB Bus clocking configuration. + */ +#define CONFIG_SYS_IPBCLK_EQUALS_XLBCLK /* define for 133MHz speed */ + +/* + * I2C configuration + */ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ +#define CONFIG_SYS_I2C_MODULE 2 /* Select I2C module #1 or #2 */ + +#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ +#define CONFIG_SYS_I2C_SLAVE 0x7F + +/* + * EEPROM configuration + */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 + +/* + * RTC configuration + */ +#define CONFIG_RTC_PCF8563 +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 + +/* I2C SYSMON (LM75) */ +#define CONFIG_DTT_LM81 1 /* ON Semi's LM75 */ +#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ +#define CONFIG_SYS_DTT_MAX_TEMP 70 +#define CONFIG_SYS_DTT_LOW_TEMP -30 +#define CONFIG_SYS_DTT_HYSTERESIS 3 + +/* + * Flash configuration + */ +#define CONFIG_SYS_FLASH_BASE 0xFF800000 + +#define CONFIG_SYS_FLASH_SIZE 0x00800000 /* 8 MByte */ + +#define CONFIG_ENV_ADDR (TEXT_BASE+0x40000) /* second sector */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks + (= chip selects) */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout [ms]*/ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout [ms]*/ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_CFI_AMD_RESET + +/* + * Environment settings + */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) + +/* + * Memory map + */ +#define CONFIG_SYS_MBAR 0xF0000000 +#define CONFIG_SYS_DEFAULT_MBAR 0x80000000 + +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END -\ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SRAM_BASE 0x80100000 /* CS 1 */ +#define CONFIG_SYS_DISPLAY_BASE 0x80600000 /* CS 3 */ + +/* Settings for XLB = 132 MHz */ +#define SDRAM_DDR 1 +#define SDRAM_MODE 0x018D0000 +#define SDRAM_EMODE 0x40090000 +#define SDRAM_CONTROL 0x714f0f00 +#define SDRAM_CONFIG1 0x73722930 +#define SDRAM_CONFIG2 0x47770000 +#define SDRAM_TAPDELAY 0x10000000 + +/* Use ON-Chip SRAM until RAM will be available */ +#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM +#ifdef CONFIG_POST +/* preserve space for the post_word at end of on-chip SRAM */ +#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#else +#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#endif + +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) +# define CONFIG_SYS_RAMBOOT 1 +#endif + +#define CONFIG_SYS_MONITOR_LEN (192 << 10) +#define CONFIG_SYS_MALLOC_LEN (512 << 10) +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) + +/* + * Ethernet configuration + */ +#define CONFIG_MPC5xxx_FEC 1 +#define CONFIG_MPC5xxx_FEC_MII100 +#define CONFIG_PHY_ADDR 0x00 +#define CONFIG_MII 1 + +/*use Hardware WDT */ +#define CONFIG_HW_WATCHDOG + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args*/ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* Enable an alternate, more extensive memory test */ +#define CONFIG_SYS_ALT_MEMTEST + +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value*/ +#endif + +/* + * Enable loopw command. + */ +#define CONFIG_LOOPW + +/* + * Various low-level settings + */ +#if defined(CONFIG_MPC5200) +#define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI +#define CONFIG_SYS_HID0_FINAL HID0_ICE +#else +#define CONFIG_SYS_HID0_INIT 0 +#define CONFIG_SYS_HID0_FINAL 0 +#endif + +#define CONFIG_SYS_BOOTCS_START CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_BOOTCS_SIZE CONFIG_SYS_FLASH_SIZE +#define CONFIG_SYS_CS0_START CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_CS0_SIZE CONFIG_SYS_FLASH_SIZE + +/* 8Mbit SRAM @0x80100000 */ +#define CONFIG_SYS_CS1_START CONFIG_SYS_SRAM_BASE + +#define CONFIG_SYS_CS_BURST 0x00000000 +#define CONFIG_SYS_CS_DEADCYCLE 0x33333333 + +/*----------------------------------------------------------------------- + * IDE/ATA stuff Supports IDE harddisk + *----------------------------------------------------------------------- + */ + +#undef CONFIG_IDE_8xx_PCCARD /* Use IDE with PC Card Adapter */ + +#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ +#undef CONFIG_IDE_LED /* LED for ide not supported */ + +#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ + +#define CONFIG_IDE_PREINIT 1 + +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 + +#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA + +/* Offset for data I/O */ +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) + +/* Offset for normal register accesses */ +#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) + +/* Offset for alternate registers */ +#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) + +/* Interval between registers */ +#define CONFIG_SYS_ATA_STRIDE 4 + +#define CONFIG_ATAPI 1 + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +#define OF_CPU "PowerPC,5200@0" +#define OF_SOC "soc5200@f0000000" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc5200@f0000000/serial@2000" + +#endif /* __MANROLAND_COMMON_H */ diff --git a/include/configs/mucmc52.h b/include/configs/mucmc52.h index ae60cd2..e0e6751 100644 --- a/include/configs/mucmc52.h +++ b/include/configs/mucmc52.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2008 + * (C) Copyright 2008-2009 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * * (C) Copyright 2003-2005 @@ -32,260 +32,50 @@ * (easy to change) */
-#define CONFIG_MPC5xxx 1 /* This is an MPC5xxx CPU */ -#define CONFIG_MPC5200 1 /* (more precisely an MPC5200 CPU) */ -#define CONFIG_MUCMC52 1 /* MUCMC52 board */ +#define CONFIG_MUCMC52 1 /* MUCMC52 board */ +#define CONFIG_HOSTNAME mucmc52
-#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ - -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ - -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CONFIG_SYS_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -#define CONFIG_BOARD_EARLY_INIT_R +#include "manroland-common.h"
#define CONFIG_LAST_STAGE_INIT - -#define CONFIG_HIGH_BATS 1 /* High BATs supported */ /* * Serial console configuration */ -#define CONFIG_PSC_CONSOLE 1 /* console is on PSC1 */ #define CONFIG_BAUDRATE 38400 /* ... at 38400 bps */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } - -/* Partitions */ -#define CONFIG_DOS_PARTITION
-/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DISPLAY -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C -#define CONFIG_CMD_DTT -#define CONFIG_CMD_IDE -#define CONFIG_CMD_MII -#define CONFIG_CMD_NFS #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING -#define CONFIG_CMD_SNTP - -#define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */ - -#if (TEXT_BASE == 0xFFF00000) /* Boot low */ -# define CONFIG_SYS_LOWBOOT 1 -#endif - -/* - * Autobooting - */ -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_PREBOOT "echo;" \ - "echo Type "run flash_nfs" to mount root filesystem over NFS;" \ - "echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "rootpath=/opt/eldk/ppc_82xx\0" \ - "" - -#define CONFIG_BOOTCOMMAND "run net_nfs" - -#define CONFIG_MISC_INIT_R 1 - -/* - * IPB Bus clocking configuration. - */ -#undef CONFIG_SYS_IPBCLK_EQUALS_XLBCLK /* define for 133MHz speed */ - -/* - * I2C configuration - */ -#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ -#define CONFIG_SYS_I2C_MODULE 2 /* Select I2C module #1 or #2 */ - -#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - -/* - * EEPROM configuration - */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 - -/* - * RTC configuration - */ -#define CONFIG_RTC_PCF8563 -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 - -/* I2C SYSMON (LM75) */ -#define CONFIG_DTT_LM81 1 /* ON Semi's LM75 */ -#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ -#define CONFIG_SYS_DTT_MAX_TEMP 70 -#define CONFIG_SYS_DTT_LOW_TEMP -30 -#define CONFIG_SYS_DTT_HYSTERESIS 3
/* * Flash configuration */ -#define CONFIG_SYS_FLASH_BASE 0xFF800000 - -#define CONFIG_SYS_FLASH_SIZE 0x00800000 /* 8 MByte */ -#define CONFIG_SYS_MAX_FLASH_SECT 67 /* max num of sects on one chip */ - -#define CONFIG_ENV_ADDR (TEXT_BASE+0x40000) /* second sector */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks - (= chip selects) */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_CFI_AMD_RESET +#define CONFIG_SYS_MAX_FLASH_SECT 67
/* * Environment settings */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SIZE 0x4000 #define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
/* * Memory map */ -#define CONFIG_SYS_MBAR 0xF0000000 -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_DEFAULT_MBAR 0x80000000 -#define CONFIG_SYS_DISPLAY_BASE 0x80600000 #define CONFIG_SYS_STATUS1_BASE 0x80600200 #define CONFIG_SYS_STATUS2_BASE 0x80600300 #define CONFIG_SYS_PMI_UNI_BASE 0x80800000 #define CONFIG_SYS_PMI_BROAD_BASE 0x80810000
-/* Settings for XLB = 132 MHz */ -#define SDRAM_DDR 1 -#define SDRAM_MODE 0x018D0000 -#define SDRAM_EMODE 0x40090000 -#define SDRAM_CONTROL 0x714f0f00 -#define SDRAM_CONFIG1 0x73722930 -#define SDRAM_CONFIG2 0x47770000 -#define SDRAM_TAPDELAY 0x10000000 - -/* Use ON-Chip SRAM until RAM will be available */ -#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#ifdef CONFIG_POST -/* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE -#else -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE -#endif - -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_BASE TEXT_BASE -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT 1 -#endif - -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (512 << 10) /* Reserve 128 kB for malloc() */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/* - * Ethernet configuration - */ -#define CONFIG_MPC5xxx_FEC 1 -#define CONFIG_MPC5xxx_FEC_MII100 -#define CONFIG_PHY_ADDR 0x00 -#define CONFIG_MII 1 /* MII PHY management */ - /* * GPIO configuration */ #define CONFIG_SYS_GPS_PORT_CONFIG 0x8D550644
-/*use Hardware WDT */ -#define CONFIG_HW_WATCHDOG +#define CONFIG_SYS_MEMTEST_START 0x00100000 +#define CONFIG_SYS_MEMTEST_END 0x00f00000
-/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CONFIG_SYS_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -/* Enable an alternate, more extensive memory test */ -#define CONFIG_SYS_ALT_MEMTEST - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00f00000 /* 1 ... 15 MB in DRAM */ +#define CONFIG_SYS_LOAD_ADDR 0x100000
-#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ - -/* - * Enable loopw commando. This has only affect, if CONFIG_SYS_CMD_MEM is defined, - * which is normally part of the default commands (CFV_CMD_DFL) - */ -#define CONFIG_LOOPW - -/* - * Various low-level settings - */ -#if defined(CONFIG_MPC5200) -#define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI -#define CONFIG_SYS_HID0_FINAL HID0_ICE -#else -#define CONFIG_SYS_HID0_INIT 0 -#define CONFIG_SYS_HID0_FINAL 0 -#endif - -#define CONFIG_SYS_BOOTCS_START CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_BOOTCS_SIZE CONFIG_SYS_FLASH_SIZE #define CONFIG_SYS_BOOTCS_CFG 0x0004FB00 -#define CONFIG_SYS_CS0_START CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_CS0_SIZE CONFIG_SYS_FLASH_SIZE
/* 8Mbit SRAM @0x80100000 */ -#define CONFIG_SYS_CS1_START 0x80100000 #define CONFIG_SYS_CS1_SIZE 0x00100000 #define CONFIG_SYS_CS1_CFG 0x00019B00
@@ -309,42 +99,12 @@ #define CONFIG_SYS_CS7_SIZE 0x00008000 #define CONFIG_SYS_CS7_CFG 0xFF00F930
-#define CONFIG_SYS_CS_BURST 0x00000000 -#define CONFIG_SYS_CS_DEADCYCLE 0x33333333 - /*----------------------------------------------------------------------- * IDE/ATA stuff Supports IDE harddisk *----------------------------------------------------------------------- */ - -#undef CONFIG_IDE_8xx_PCCARD /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ #define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 2 drives per IDE bus */
-#define CONFIG_IDE_PREINIT 1 - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) - -/* Interval between registers */ -#define CONFIG_SYS_ATA_STRIDE 4 - -#define CONFIG_ATAPI 1 - /* * PCI Mapping: * 0x40000000 - 0x4fffffff - PCI Memory diff --git a/include/configs/uc101.h b/include/configs/uc101.h index 87cb4e5..deb385f 100644 --- a/include/configs/uc101.h +++ b/include/configs/uc101.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2003-2006 + * (C) Copyright 2003-2009 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * * See file CREDITS for list of people who contributed to this @@ -29,29 +29,15 @@ * (easy to change) */
-#define CONFIG_MPC5xxx 1 /* This is an MPC5xxx CPU */ -#define CONFIG_MPC5200 1 /* (more precisely an MPC5200 CPU) */ -#define CONFIG_UC101 1 /* UC101 board */ +#define CONFIG_UC101 1 /* UC101 board */ +#define CONFIG_HOSTNAME uc101
-#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ - -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ - -#define CONFIG_BOARD_EARLY_INIT_R - -#define CONFIG_HIGH_BATS 1 /* High BATs supported */ +#include "manroland-common.h"
/* * Serial console configuration */ -#define CONFIG_PSC_CONSOLE 1 /* console is on PSC1 */ #define CONFIG_BAUDRATE 115200 /* ... at 115200 bps */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } - -/* Partitions */ -#define CONFIG_DOS_PARTITION -
/* * BOOTP options @@ -61,243 +47,40 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DISPLAY -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C -#define CONFIG_CMD_DTT -#define CONFIG_CMD_IDE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_NFS -#define CONFIG_CMD_MII -#define CONFIG_CMD_SNTP - - -#define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */ - -#if (TEXT_BASE == 0xFFF00000) /* Boot low */ -# define CONFIG_SYS_LOWBOOT 1 -#endif - -/* - * Autobooting - */ -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_PREBOOT "echo;" \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ - "echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addwdt=setenv bootargs ${bootargs} wdt=off" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "net_nfs=tftp 300000 ${bootfile};run nfsargs addip addwdt;bootm\0" \ - "rootpath=/opt/eldk/ppc_82xx\0" \ - "" - -#define CONFIG_BOOTCOMMAND "run net_nfs" - -#define CONFIG_MISC_INIT_R 1 - -/* - * IPB Bus clocking configuration. - */ -#define CONFIG_SYS_IPBCLK_EQUALS_XLBCLK /* define for 133MHz speed */ - -/* - * I2C configuration - */ -#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ -#define CONFIG_SYS_I2C_MODULE 2 /* Select I2C module #1 or #2 */ - -#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - -/* - * EEPROM configuration - */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 - -/* - * RTC configuration - */ -#define CONFIG_RTC_PCF8563 -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 - -/* I2C SYSMON (LM75) */ -#define CONFIG_DTT_LM81 1 /* ON Semi's LM75 */ -#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ -#define CONFIG_SYS_DTT_MAX_TEMP 70 -#define CONFIG_SYS_DTT_LOW_TEMP -30 -#define CONFIG_SYS_DTT_HYSTERESIS 3 - /* * Flash configuration */ -#define CONFIG_SYS_FLASH_BASE 0xFF800000 - -#define CONFIG_SYS_FLASH_SIZE 0x00800000 /* 8 MByte */ -#define CONFIG_SYS_MAX_FLASH_SECT 140 /* max num of sects on one chip */ - -#define CONFIG_ENV_ADDR (TEXT_BASE+0x40000) /* second sector */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks - (= chip selects) */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_CFI_AMD_RESET +#define CONFIG_SYS_MAX_FLASH_SECT 140
/* * Environment settings */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SIZE 0x4000 #define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
/* * Memory map */ -#define CONFIG_SYS_MBAR 0xF0000000 -#define CONFIG_SYS_DEFAULT_MBAR 0x80000000 - -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SRAM_BASE 0x80100000 /* CS 1 */ -#define CONFIG_SYS_DISPLAY_BASE 0x80600000 /* CS 3 */ #define CONFIG_SYS_IB_MASTER 0xc0510000 /* CS 6 */ #define CONFIG_SYS_IB_EPLD 0xc0500000 /* CS 7 */
-/* Settings for XLB = 132 MHz */ -#define SDRAM_DDR 1 -#define SDRAM_MODE 0x018D0000 -#define SDRAM_EMODE 0x40090000 -#define SDRAM_CONTROL 0x714f0f00 -#define SDRAM_CONFIG1 0x73722930 -#define SDRAM_CONFIG2 0x47770000 -#define SDRAM_TAPDELAY 0x10000000 - /* SRAM */ -#define SRAM_BASE CONFIG_SYS_SRAM_BASE /* SRAM base address */ +#define SRAM_BASE CONFIG_SYS_SRAM_BASE #define SRAM_LEN 0x1fffff #define SRAM_END (SRAM_BASE + SRAM_LEN)
-/* Use ON-Chip SRAM until RAM will be available */ -#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#ifdef CONFIG_POST -/* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE -#else -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE -#endif - - -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_BASE TEXT_BASE -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT 1 -#endif - -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (512 << 10) /* Reserve 128 kB for malloc() */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/* - * Ethernet configuration - */ -#define CONFIG_MPC5xxx_FEC 1 -#define CONFIG_MPC5xxx_FEC_MII100 -#define CONFIG_PHY_ADDR 0x00 -#define CONFIG_MII 1 - /* * GPIO configuration */ #define CONFIG_SYS_GPS_PORT_CONFIG 0x4d558044
-/*use Hardware WDT */ -#define CONFIG_HW_WATCHDOG - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -/* Enable an alternate, more extensive memory test */ -#define CONFIG_SYS_ALT_MEMTEST - -#define CONFIG_SYS_MEMTEST_START 0x00300000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00f00000 /* 3 ... 15 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x300000 /* default load address */ +#define CONFIG_SYS_MEMTEST_START 0x00300000 +#define CONFIG_SYS_MEMTEST_END 0x00f00000
-#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ +#define CONFIG_SYS_LOAD_ADDR 0x300000
-#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/* - * Enable loopw command. - */ -#define CONFIG_LOOPW - -/* - * Various low-level settings - */ -#if defined(CONFIG_MPC5200) -#define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI -#define CONFIG_SYS_HID0_FINAL HID0_ICE -#else -#define CONFIG_SYS_HID0_INIT 0 -#define CONFIG_SYS_HID0_FINAL 0 -#endif - -#define CONFIG_SYS_BOOTCS_START CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_BOOTCS_SIZE CONFIG_SYS_FLASH_SIZE #define CONFIG_SYS_BOOTCS_CFG 0x00045D00 -#define CONFIG_SYS_CS0_START CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_CS0_SIZE CONFIG_SYS_FLASH_SIZE
/* 8Mbit SRAM @0x80100000 */ -#define CONFIG_SYS_CS1_START CONFIG_SYS_SRAM_BASE #define CONFIG_SYS_CS1_SIZE 0x00200000 #define CONFIG_SYS_CS1_CFG 0x21D00
@@ -316,41 +99,12 @@ #define CONFIG_SYS_CS7_SIZE 0x00010000 #define CONFIG_SYS_CS7_CFG 0x00081800
-#undef CONFIG_IDE_8xx_PCCARD /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 2 /* max. 2 drives per IDE bus */ - -#define CONFIG_IDE_PREINIT 1 - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) - -/* Interval between registers */ -#define CONFIG_SYS_ATA_STRIDE 4 - -#define CONFIG_ATAPI 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 2 drives per IDE bus*/
/*---------------------------------------------------------------------*/ /* Display addresses */
Dear Heiko Schocher,
- add OF support
Applied to mpc5xxx repo.
Hi Heiko,
- add OF support
- High Level Configuration Options
- (easy to change)
Are you sure that this is a good choice to put in a manufacturer common header file? Isn't the probability of this becoming incorrect nearly 100% for the next board from this manufacturer?
I'd advise to keep CPU stuff in the individual board config files - maybe, if you really want, create a "manroland-mpc52xx-common.h". The rest of the common configs should be re-evaluated in the same spirit.
Cheers Detlev
Dear Detlev Zundel,
And right you are. Thanks for pointing out.
Heiko, please rework. I haven't pushed the repo out yet, so I just remove that commit again.
- as this boards are similiar, collect common config option in manroland-common.h and manroland-mpc52xx-common.h for mpc52xx specific common options for this manufacturer. - add OF support - update default environment
- changes since v1: added suggestion from Detlev Zundel, to collect mpc52xx specific config options in manroland-mpc52xx-common.h
board/mucmc52/mucmc52.c | 7 + board/uc101/uc101.c | 7 + include/configs/manroland-common.h | 139 +++++++++++++++ include/configs/manroland-mpc52xx-common.h | 230 ++++++++++++++++++++++++ include/configs/mucmc52.h | 257 +-------------------------- include/configs/uc101.h | 267 ++-------------------------- 6 files changed, 403 insertions(+), 504 deletions(-) create mode 100644 include/configs/manroland-common.h create mode 100644 include/configs/manroland-mpc52xx-common.h
diff --git a/board/mucmc52/mucmc52.c b/board/mucmc52/mucmc52.c index 7181bd8..bac49be 100644 --- a/board/mucmc52/mucmc52.c +++ b/board/mucmc52/mucmc52.c @@ -398,3 +398,10 @@ void pci_init_board (void) pci_mpc5xxx_init (&hose); } #endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/board/uc101/uc101.c b/board/uc101/uc101.c index 7df349f..4030b9d 100644 --- a/board/uc101/uc101.c +++ b/board/uc101/uc101.c @@ -371,3 +371,10 @@ void hw_watchdog_reset(void) *(vu_long *)MPC5XXX_GPT0_ENABLE = GPT_OUT_0; } #endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/include/configs/manroland-common.h b/include/configs/manroland-common.h new file mode 100644 index 0000000..ffc94e1 --- /dev/null +++ b/include/configs/manroland-common.h @@ -0,0 +1,139 @@ +/* + * (C) Copyright 2009 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MANROLAND_COMMON_H +#define __MANROLAND_COMMON_H + +/* + * High Level Configuration Options + * (easy to change) + */ + +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#define CONFIG_BOARD_EARLY_INIT_R + +/* Partitions */ +#define CONFIG_DOS_PARTITION + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DISPLAY +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_DTT +#define CONFIG_CMD_IDE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_NFS +#define CONFIG_CMD_MII +#define CONFIG_CMD_SNTP + +#define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */ + +/* + * Autobooting + */ +#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ + +#define CONFIG_PREBOOT "echo;" \ + "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ + "echo" + +#undef CONFIG_BOOTARGS + +#define xstr(s) str(s) +#define str(s) #s + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addwdt=setenv bootargs ${bootargs} wdt=off\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "kernel_addr=ff810000\0" \ + "fdt_addr="xstr(CONFIG_SYS_FLASH_BASE)"\0" \ + "flash_nfs=run nfsargs addip addcon addwdt;" \ + "bootm ${kernel_addr} - ${fdt_addr}\0" \ + "rootpath=/opt/eldk/ppc_82xx\0" \ + "kernel_addr_r=300000\0" \ + "fdt_addr_r=200000\0" \ + "fdt_file=" xstr(CONFIG_HOSTNAME) "/" \ + xstr(CONFIG_HOSTNAME) ".dtb\0" \ + "kernel_file=" xstr(CONFIG_HOSTNAME) "/uImage \0" \ + "load_fdt=tftp ${fdt_addr_r} ${fdt_file};\0" \ + "load_kernel=tftp ${kernel_addr_r} ${kernel_file};\0" \ + "addcon=setenv bootargs ${bootargs} console=ttyPSC0,${baudrate}\0"\ + "net_nfs=run load_fdt load_kernel; " \ + "run nfsargs addip addcon addwdt;" \ + "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.bin \0" \ + "u-boot_addr_r=200000\0" \ + "load=tftp ${u-boot_addr_r} ${u-boot}\0" \ + "update=protect off " xstr(TEXT_BASE) " +${filesize};" \ + "erase " xstr(TEXT_BASE) " +${filesize};" \ + "cp.b ${u-boot_addr_r} " xstr(TEXT_BASE) \ + " ${filesize};" \ + "protect on " xstr(TEXT_BASE) " +${filesize}\0" \ + "" + +#define CONFIG_BOOTCOMMAND "run net_nfs" + +#define CONFIG_MISC_INIT_R 1 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args*/ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* Enable an alternate, more extensive memory test */ +#define CONFIG_SYS_ALT_MEMTEST + +/* + * Enable loopw command. + */ +#define CONFIG_LOOPW + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +#endif /* __MANROLAND_COMMON_H */ diff --git a/include/configs/manroland-mpc52xx-common.h b/include/configs/manroland-mpc52xx-common.h new file mode 100644 index 0000000..b29ef9b --- /dev/null +++ b/include/configs/manroland-mpc52xx-common.h @@ -0,0 +1,230 @@ +/* + * (C) Copyright 2009 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MANROLAND_MPC52XX__COMMON_H +#define __MANROLAND_MPC52XX__COMMON_H + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_MPC5xxx 1 /* This is an MPC5xxx CPU */ +#define CONFIG_MPC5200 1 /* (more precisely an MPC5200 CPU) */ + +#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ + +#define CONFIG_HIGH_BATS 1 /* High BATs supported */ + +/* + * Serial console configuration + */ +#define CONFIG_PSC_CONSOLE 1 /* console is on PSC1 */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200,\ + 230400 } + +#if (TEXT_BASE == 0xFFF00000) /* Boot low */ +# define CONFIG_SYS_LOWBOOT 1 +#endif + +/* + * IPB Bus clocking configuration. + */ +#define CONFIG_SYS_IPBCLK_EQUALS_XLBCLK /* define for 133MHz speed */ + +/* + * I2C configuration + */ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ +#define CONFIG_SYS_I2C_MODULE 2 /* Select I2C module #1 or #2 */ + +#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ +#define CONFIG_SYS_I2C_SLAVE 0x7F + +/* + * EEPROM configuration + */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 + +/* + * RTC configuration + */ +#define CONFIG_RTC_PCF8563 +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 + +/* I2C SYSMON (LM75) */ +#define CONFIG_DTT_LM81 1 /* ON Semi's LM75 */ +#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ +#define CONFIG_SYS_DTT_MAX_TEMP 70 +#define CONFIG_SYS_DTT_LOW_TEMP -30 +#define CONFIG_SYS_DTT_HYSTERESIS 3 + +/* + * Flash configuration + */ +#define CONFIG_SYS_FLASH_BASE 0xFF800000 + +#define CONFIG_SYS_FLASH_SIZE 0x00800000 /* 8 MByte */ + +#define CONFIG_ENV_ADDR (TEXT_BASE+0x40000) /* second sector */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks + (= chip selects) */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout [ms]*/ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout [ms]*/ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_CFI_AMD_RESET + +/* + * Environment settings + */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) + +/* + * Memory map + */ +#define CONFIG_SYS_MBAR 0xF0000000 +#define CONFIG_SYS_DEFAULT_MBAR 0x80000000 + +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END -\ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SRAM_BASE 0x80100000 /* CS 1 */ +#define CONFIG_SYS_DISPLAY_BASE 0x80600000 /* CS 3 */ + +/* Settings for XLB = 132 MHz */ +#define SDRAM_DDR 1 +#define SDRAM_MODE 0x018D0000 +#define SDRAM_EMODE 0x40090000 +#define SDRAM_CONTROL 0x714f0f00 +#define SDRAM_CONFIG1 0x73722930 +#define SDRAM_CONFIG2 0x47770000 +#define SDRAM_TAPDELAY 0x10000000 + +/* Use ON-Chip SRAM until RAM will be available */ +#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM +#ifdef CONFIG_POST +/* preserve space for the post_word at end of on-chip SRAM */ +#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#else +#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#endif + +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) +# define CONFIG_SYS_RAMBOOT 1 +#endif + +#define CONFIG_SYS_MONITOR_LEN (192 << 10) +#define CONFIG_SYS_MALLOC_LEN (512 << 10) +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) + +/* + * Ethernet configuration + */ +#define CONFIG_MPC5xxx_FEC 1 +#define CONFIG_MPC5xxx_FEC_MII100 +#define CONFIG_PHY_ADDR 0x00 +#define CONFIG_MII 1 + +/*use Hardware WDT */ +#define CONFIG_HW_WATCHDOG + +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value*/ +#endif + +/* + * Various low-level settings + */ +#if defined(CONFIG_MPC5200) +#define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI +#define CONFIG_SYS_HID0_FINAL HID0_ICE +#else +#define CONFIG_SYS_HID0_INIT 0 +#define CONFIG_SYS_HID0_FINAL 0 +#endif + +#define CONFIG_SYS_BOOTCS_START CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_BOOTCS_SIZE CONFIG_SYS_FLASH_SIZE +#define CONFIG_SYS_CS0_START CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_CS0_SIZE CONFIG_SYS_FLASH_SIZE + +/* 8Mbit SRAM @0x80100000 */ +#define CONFIG_SYS_CS1_START CONFIG_SYS_SRAM_BASE + +#define CONFIG_SYS_CS_BURST 0x00000000 +#define CONFIG_SYS_CS_DEADCYCLE 0x33333333 + +/*----------------------------------------------------------------------- + * IDE/ATA stuff Supports IDE harddisk + *----------------------------------------------------------------------- + */ + +#undef CONFIG_IDE_8xx_PCCARD /* Use IDE with PC Card Adapter */ + +#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ +#undef CONFIG_IDE_LED /* LED for ide not supported */ + +#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ + +#define CONFIG_IDE_PREINIT 1 + +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 + +#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA + +/* Offset for data I/O */ +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) + +/* Offset for normal register accesses */ +#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) + +/* Offset for alternate registers */ +#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) + +/* Interval between registers */ +#define CONFIG_SYS_ATA_STRIDE 4 + +#define CONFIG_ATAPI 1 + +#define OF_CPU "PowerPC,5200@0" +#define OF_SOC "soc5200@f0000000" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc5200@f0000000/serial@2000" +#define CONFIG_OF_IDE_FIXUP + +#endif /* __MANROLAND_MPC52XX__COMMON_H */ diff --git a/include/configs/mucmc52.h b/include/configs/mucmc52.h index ae60cd2..367b8f6 100644 --- a/include/configs/mucmc52.h +++ b/include/configs/mucmc52.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2008 + * (C) Copyright 2008-2009 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * * (C) Copyright 2003-2005 @@ -32,260 +32,51 @@ * (easy to change) */
-#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ - -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ - -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CONFIG_SYS_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -#define CONFIG_BOARD_EARLY_INIT_R +#include "manroland-common.h" +#include "manroland-mpc52xx-common.h"
@@ -309,42 +100,12 @@ #define CONFIG_SYS_CS7_SIZE 0x00008000 #define CONFIG_SYS_CS7_CFG 0xFF00F930
-#define CONFIG_IDE_PREINIT 1 - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) - -/* Interval between registers */ -#define CONFIG_SYS_ATA_STRIDE 4 - -#define CONFIG_ATAPI 1 - /* * PCI Mapping: * 0x40000000 - 0x4fffffff - PCI Memory diff --git a/include/configs/uc101.h b/include/configs/uc101.h index 87cb4e5..5fbcb0c 100644 --- a/include/configs/uc101.h +++ b/include/configs/uc101.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2003-2006 + * (C) Copyright 2003-2009 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * * See file CREDITS for list of people who contributed to this @@ -29,29 +29,16 @@ * (easy to change) */
-#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ - -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ - -#define CONFIG_BOARD_EARLY_INIT_R - -#define CONFIG_HIGH_BATS 1 /* High BATs supported */ +#include "manroland-common.h" +#include "manroland-mpc52xx-common.h"
/* * BOOTP options @@ -61,243 +48,40 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
@@ -316,41 +100,12 @@ #define CONFIG_SYS_CS7_SIZE 0x00010000 #define CONFIG_SYS_CS7_CFG 0x00081800
Hello Heiko,
- add OF support
Argh, sorry for interrupting again, but I think I suggested something problematic on second thought:
So all boards using manroland-mpc52xx-common.h are in fact 5200s. In this case, I should have suggested the filename "manroland-mpc5200-common.h" as the "xx" part surely cannot be anything else then "00".
Sorry for this wrong lead.
Cheers Detlev
Hello Detlev,
- add OF support
Argh.. and I didn;t detected it too ;-)
No problem, I send a patch soon, if the rest of this patch is ok.
bye Heiko
- as this boards are similiar, collect common config option in manroland/common.h and manroland/mpc52xx-common.h for mpc5200 specific common options for this manufacturer. - add OF support - update default environment
- changes since v2: as discussed with Wolfgang and Detlev, moved the manroland common headers in include/configs/manroland
board/mucmc52/mucmc52.c | 7 + board/uc101/uc101.c | 7 + include/configs/manroland/common.h | 139 +++++++++++++++ include/configs/manroland/mpc5200-common.h | 229 ++++++++++++++++++++++++ include/configs/mucmc52.h | 257 +-------------------------- include/configs/uc101.h | 267 ++-------------------------- 6 files changed, 402 insertions(+), 504 deletions(-) create mode 100644 include/configs/manroland/common.h create mode 100644 include/configs/manroland/mpc5200-common.h
diff --git a/board/mucmc52/mucmc52.c b/board/mucmc52/mucmc52.c index 7181bd8..bac49be 100644 --- a/board/mucmc52/mucmc52.c +++ b/board/mucmc52/mucmc52.c @@ -398,3 +398,10 @@ void pci_init_board (void) pci_mpc5xxx_init (&hose); } #endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/board/uc101/uc101.c b/board/uc101/uc101.c index 7df349f..4030b9d 100644 --- a/board/uc101/uc101.c +++ b/board/uc101/uc101.c @@ -371,3 +371,10 @@ void hw_watchdog_reset(void) *(vu_long *)MPC5XXX_GPT0_ENABLE = GPT_OUT_0; } #endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/include/configs/manroland/common.h b/include/configs/manroland/common.h new file mode 100644 index 0000000..ffc94e1 --- /dev/null +++ b/include/configs/manroland/common.h @@ -0,0 +1,139 @@ +/* + * (C) Copyright 2009 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MANROLAND_COMMON_H +#define __MANROLAND_COMMON_H + +/* + * High Level Configuration Options + * (easy to change) + */ + +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#define CONFIG_BOARD_EARLY_INIT_R + +/* Partitions */ +#define CONFIG_DOS_PARTITION + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DISPLAY +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_DTT +#define CONFIG_CMD_IDE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_NFS +#define CONFIG_CMD_MII +#define CONFIG_CMD_SNTP + +#define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */ + +/* + * Autobooting + */ +#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ + +#define CONFIG_PREBOOT "echo;" \ + "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ + "echo" + +#undef CONFIG_BOOTARGS + +#define xstr(s) str(s) +#define str(s) #s + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addwdt=setenv bootargs ${bootargs} wdt=off\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "kernel_addr=ff810000\0" \ + "fdt_addr="xstr(CONFIG_SYS_FLASH_BASE)"\0" \ + "flash_nfs=run nfsargs addip addcon addwdt;" \ + "bootm ${kernel_addr} - ${fdt_addr}\0" \ + "rootpath=/opt/eldk/ppc_82xx\0" \ + "kernel_addr_r=300000\0" \ + "fdt_addr_r=200000\0" \ + "fdt_file=" xstr(CONFIG_HOSTNAME) "/" \ + xstr(CONFIG_HOSTNAME) ".dtb\0" \ + "kernel_file=" xstr(CONFIG_HOSTNAME) "/uImage \0" \ + "load_fdt=tftp ${fdt_addr_r} ${fdt_file};\0" \ + "load_kernel=tftp ${kernel_addr_r} ${kernel_file};\0" \ + "addcon=setenv bootargs ${bootargs} console=ttyPSC0,${baudrate}\0"\ + "net_nfs=run load_fdt load_kernel; " \ + "run nfsargs addip addcon addwdt;" \ + "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.bin \0" \ + "u-boot_addr_r=200000\0" \ + "load=tftp ${u-boot_addr_r} ${u-boot}\0" \ + "update=protect off " xstr(TEXT_BASE) " +${filesize};" \ + "erase " xstr(TEXT_BASE) " +${filesize};" \ + "cp.b ${u-boot_addr_r} " xstr(TEXT_BASE) \ + " ${filesize};" \ + "protect on " xstr(TEXT_BASE) " +${filesize}\0" \ + "" + +#define CONFIG_BOOTCOMMAND "run net_nfs" + +#define CONFIG_MISC_INIT_R 1 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args*/ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* Enable an alternate, more extensive memory test */ +#define CONFIG_SYS_ALT_MEMTEST + +/* + * Enable loopw command. + */ +#define CONFIG_LOOPW + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +#endif /* __MANROLAND_COMMON_H */ diff --git a/include/configs/manroland/mpc5200-common.h b/include/configs/manroland/mpc5200-common.h new file mode 100644 index 0000000..2f092b1 --- /dev/null +++ b/include/configs/manroland/mpc5200-common.h @@ -0,0 +1,229 @@ +/* + * (C) Copyright 2009 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MANROLAND_MPC52XX__COMMON_H +#define __MANROLAND_MPC52XX__COMMON_H + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_MPC5xxx 1 /* This is an MPC5xxx CPU */ +#define CONFIG_MPC5200 1 /* (more precisely an MPC5200 CPU) */ + +#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ + +#define CONFIG_HIGH_BATS 1 /* High BATs supported */ + +/* + * Serial console configuration + */ +#define CONFIG_PSC_CONSOLE 1 /* console is on PSC1 */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200,\ + 230400 } + +#if (TEXT_BASE == 0xFFF00000) /* Boot low */ +# define CONFIG_SYS_LOWBOOT 1 +#endif + +/* + * IPB Bus clocking configuration. + */ +#define CONFIG_SYS_IPBCLK_EQUALS_XLBCLK /* define for 133MHz speed */ + +/* + * I2C configuration + */ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ +#define CONFIG_SYS_I2C_MODULE 2 /* Select I2C module #1 or #2 */ + +#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ +#define CONFIG_SYS_I2C_SLAVE 0x7F + +/* + * EEPROM configuration + */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 + +/* + * RTC configuration + */ +#define CONFIG_RTC_PCF8563 +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 + +/* I2C SYSMON (LM75) */ +#define CONFIG_DTT_LM81 1 /* ON Semi's LM75 */ +#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ +#define CONFIG_SYS_DTT_MAX_TEMP 70 +#define CONFIG_SYS_DTT_LOW_TEMP -30 +#define CONFIG_SYS_DTT_HYSTERESIS 3 + +/* + * Flash configuration + */ +#define CONFIG_SYS_FLASH_BASE 0xFF800000 + +#define CONFIG_SYS_FLASH_SIZE 0x00800000 /* 8 MByte */ + +#define CONFIG_ENV_ADDR (TEXT_BASE+0x40000) /* second sector */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks + (= chip selects) */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout [ms]*/ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout [ms]*/ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_CFI_AMD_RESET + +/* + * Environment settings + */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) + +/* + * Memory map + */ +#define CONFIG_SYS_MBAR 0xF0000000 +#define CONFIG_SYS_DEFAULT_MBAR 0x80000000 + +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END -\ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SRAM_BASE 0x80100000 /* CS 1 */ +#define CONFIG_SYS_DISPLAY_BASE 0x80600000 /* CS 3 */ + +/* Settings for XLB = 132 MHz */ +#define SDRAM_DDR 1 +#define SDRAM_MODE 0x018D0000 +#define SDRAM_EMODE 0x40090000 +#define SDRAM_CONTROL 0x714f0f00 +#define SDRAM_CONFIG1 0x73722930 +#define SDRAM_CONFIG2 0x47770000 +#define SDRAM_TAPDELAY 0x10000000 + +/* Use ON-Chip SRAM until RAM will be available */ +#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM +#ifdef CONFIG_POST +/* preserve space for the post_word at end of on-chip SRAM */ +#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#else +#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#endif + +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) +# define CONFIG_SYS_RAMBOOT 1 +#endif + +#define CONFIG_SYS_MONITOR_LEN (192 << 10) +#define CONFIG_SYS_MALLOC_LEN (512 << 10) +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) + +/* + * Ethernet configuration + */ +#define CONFIG_MPC5xxx_FEC 1 +#define CONFIG_MPC5xxx_FEC_MII100 +#define CONFIG_PHY_ADDR 0x00 +#define CONFIG_MII 1 + +/*use Hardware WDT */ +#define CONFIG_HW_WATCHDOG + +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value*/ +#endif + +/* + * Various low-level settings + */ +#if defined(CONFIG_MPC5200) +#define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI +#define CONFIG_SYS_HID0_FINAL HID0_ICE +#else +#define CONFIG_SYS_HID0_INIT 0 +#define CONFIG_SYS_HID0_FINAL 0 +#endif + +#define CONFIG_SYS_BOOTCS_START CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_BOOTCS_SIZE CONFIG_SYS_FLASH_SIZE +#define CONFIG_SYS_CS0_START CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_CS0_SIZE CONFIG_SYS_FLASH_SIZE + +/* 8Mbit SRAM @0x80100000 */ +#define CONFIG_SYS_CS1_START CONFIG_SYS_SRAM_BASE + +#define CONFIG_SYS_CS_BURST 0x00000000 +#define CONFIG_SYS_CS_DEADCYCLE 0x33333333 + +/*----------------------------------------------------------------------- + * IDE/ATA stuff Supports IDE harddisk + *----------------------------------------------------------------------- + */ + +#undef CONFIG_IDE_8xx_PCCARD /* Use IDE with PC Card Adapter */ + +#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ +#undef CONFIG_IDE_LED /* LED for ide not supported */ + +#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ + +#define CONFIG_IDE_PREINIT 1 + +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 + +#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA + +/* Offset for data I/O */ +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) + +/* Offset for normal register accesses */ +#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) + +/* Offset for alternate registers */ +#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) + +/* Interval between registers */ +#define CONFIG_SYS_ATA_STRIDE 4 + +#define CONFIG_ATAPI 1 + +#define OF_CPU "PowerPC,5200@0" +#define OF_SOC "soc5200@f0000000" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc5200@f0000000/serial@2000" + +#endif /* __MANROLAND_MPC52XX__COMMON_H */ diff --git a/include/configs/mucmc52.h b/include/configs/mucmc52.h index ae60cd2..07ed046 100644 --- a/include/configs/mucmc52.h +++ b/include/configs/mucmc52.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2008 + * (C) Copyright 2008-2009 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * * (C) Copyright 2003-2005 @@ -32,260 +32,51 @@ * (easy to change) */
-#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ - -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ - -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CONFIG_SYS_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -#define CONFIG_BOARD_EARLY_INIT_R +#include "manroland/common.h" +#include "manroland/mpc5200-common.h"
-#define CONFIG_IDE_PREINIT 1 - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) - -/* Interval between registers */ -#define CONFIG_SYS_ATA_STRIDE 4 - -#define CONFIG_ATAPI 1 - /* * PCI Mapping: * 0x40000000 - 0x4fffffff - PCI Memory diff --git a/include/configs/uc101.h b/include/configs/uc101.h index 87cb4e5..fc0b103 100644 --- a/include/configs/uc101.h +++ b/include/configs/uc101.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2003-2006 + * (C) Copyright 2003-2009 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * * See file CREDITS for list of people who contributed to this @@ -29,29 +29,16 @@ * (easy to change) */
-#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ - -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ - -#define CONFIG_BOARD_EARLY_INIT_R - -#define CONFIG_HIGH_BATS 1 /* High BATs supported */ +#include "manroland/common.h" +#include "manroland/mpc5200-common.h"
Hi Heiko,
- add OF support
Signed-off-by: Heiko Schocher hs@denx.de
Acked-by: Detlev Zundel dzu@denx.de
Thanks Detlev
U-Boot can detect, if a ide device is present or not. If not and this new config option is activated, u-boot removes the ata node from the DTS before booting Linux, so the Linux IDE driver didn;t crashs, when probing the device. This is needed for buggy hardware (uc101) where no pull down resistor is connected to the signal IDE5V_DD7.
Signed-off-by: Heiko Schocher hs@denx.de ---
changes since v1: - added comment from Wolfgang Denk, to move this to a more common place, so others can also use it, and made it therefore per CONFIG_OF_IDE_FIXUP selectable.
changes since v2: - add CONFIG_OF_IDE_FIXUP to mpc5200-common.h
README | 9 +++++++++ cpu/mpc5xxx/cpu.c | 18 ++++++++++++++++++ include/configs/manroland/mpc5200-common.h | 1 + 3 files changed, 28 insertions(+), 0 deletions(-)
diff --git a/README b/README index ff4ed8b..b9364bf 100644 --- a/README +++ b/README @@ -386,6 +386,15 @@ The following options need to be configured: This define fills in the correct boot CPU in the boot param header, the default value is zero if undefined.
+ CONFIG_OF_IDE_FIXUP + + U-Boot can detect, if a ide device is present or not. + If not and this config option is activated, u-boot + removes the ata node from the DTS before booting Linux, + so the Linux IDE driver didn;t crashs, when probing the + device. This is needed for buggy hardware (uc101) where + no pull down resistor is connected to the signal IDE5V_DD7. + - vxWorks boot parameters:
bootvx constructs a valid bootline using the following diff --git a/cpu/mpc5xxx/cpu.c b/cpu/mpc5xxx/cpu.c index f6258c7..a2fc323 100644 --- a/cpu/mpc5xxx/cpu.c +++ b/cpu/mpc5xxx/cpu.c @@ -125,6 +125,9 @@ void ft_cpu_setup(void *blob, bd_t *bd) uchar enetaddr[6]; char * eth_path = "/" OF_SOC "/ethernet@3000"; #endif +#if defined(CONFIG_OF_IDE_FIXUP) + extern block_dev_desc_t ide_dev_desc[CONFIG_SYS_IDE_MAXDEVICE]; +#endif
do_fixup_by_path_u32(blob, cpu_path, "timebase-frequency", OF_TBCLK, 1); do_fixup_by_path_u32(blob, cpu_path, "bus-frequency", bd->bi_busfreq, 1); @@ -137,6 +140,21 @@ void ft_cpu_setup(void *blob, bd_t *bd) do_fixup_by_path(blob, eth_path, "mac-address", enetaddr, 6, 0); do_fixup_by_path(blob, eth_path, "local-mac-address", enetaddr, 6, 0); #endif +#if defined(CONFIG_OF_IDE_FIXUP) + if (ide_dev_desc[0].type == DEV_TYPE_UNKNOWN) { + /* NO CF card detected -> delete ata node in DTS */ + int nodeoffset = 0; + char nodename[] = "/soc5200@f0000000/ata@3a00"; + + nodeoffset = fdt_path_offset (blob, nodename); + if (nodeoffset >= 0) { + fdt_del_node(blob, nodeoffset); + } else + printf("%s: cannot find %s node err:%s\n", + __func__, nodename, fdt_strerror(nodeoffset)); + } + +#endif } #endif
diff --git a/include/configs/manroland/mpc5200-common.h b/include/configs/manroland/mpc5200-common.h index 2f092b1..b29ef9b 100644 --- a/include/configs/manroland/mpc5200-common.h +++ b/include/configs/manroland/mpc5200-common.h @@ -225,5 +225,6 @@ #define OF_SOC "soc5200@f0000000" #define OF_TBCLK (bd->bi_busfreq / 4) #define OF_STDOUT_PATH "/soc5200@f0000000/serial@2000" +#define CONFIG_OF_IDE_FIXUP
Detlev Zundel
Heiko Schocher
Heiko Schocher
