[U-Boot] [U-boot] [Patch 0/6] keystone2: add k2l SoC and k2l_evm board support
This patch series adds Keystone II Lamar (K2L) SoC and k2l_evm board support.
Based on "[U-boot] [Patch] mtd: nand: davinci_nand: correct keystone RBL layout definition" https://www.mail-archive.com/u-boot@lists.denx.de/msg146305.html
Hao Zhang (6): ARM: keystone2: add K2L device hardware definitions keystone2: clock: add K2L clock definitions and commands keystone2: msmc: add MSMC cache coherency support for K2L SOC ARM: keystone2: spl: add K2L SoC support keystone2: enable OSR clock domain for K2L SoC keystone2: k2l-evm: add board support
arch/arm/Kconfig | 3 + arch/arm/cpu/armv7/keystone/Makefile | 1 + arch/arm/cpu/armv7/keystone/clock-k2l.c | 139 +++++++++++++++++++++ arch/arm/cpu/armv7/keystone/cmd_clock.c | 10 ++ arch/arm/cpu/armv7/keystone/init.c | 52 ++++++++ arch/arm/cpu/armv7/keystone/spl.c | 7 ++ arch/arm/include/asm/arch-keystone/clock-k2l.h | 94 ++++++++++++++ arch/arm/include/asm/arch-keystone/clock.h | 4 + arch/arm/include/asm/arch-keystone/hardware-k2hk.h | 2 - arch/arm/include/asm/arch-keystone/hardware-k2l.h | 99 +++++++++++++++ arch/arm/include/asm/arch-keystone/hardware.h | 14 +++ board/ti/ks2_evm/Kconfig | 24 ++++ board/ti/ks2_evm/Makefile | 2 + board/ti/ks2_evm/board_k2l.c | 60 +++++++++ board/ti/ks2_evm/ddr3_cfg.c | 36 ++++++ board/ti/ks2_evm/ddr3_cfg.h | 3 + board/ti/ks2_evm/ddr3_k2l.c | 43 +++++++ configs/k2l_evm_defconfig | 2 + include/configs/k2l_evm.h | 37 ++++++ 19 files changed, 630 insertions(+), 2 deletions(-) create mode 100644 arch/arm/cpu/armv7/keystone/clock-k2l.c create mode 100644 arch/arm/include/asm/arch-keystone/clock-k2l.h create mode 100644 arch/arm/include/asm/arch-keystone/hardware-k2l.h create mode 100644 board/ti/ks2_evm/board_k2l.c create mode 100644 board/ti/ks2_evm/ddr3_k2l.c create mode 100644 configs/k2l_evm_defconfig create mode 100644 include/configs/k2l_evm.h
This patch adds hardware definitions specific to Keystone II Lamar (K2L) SoC.
Acked-by: Vitaly Andrianov vitalya@ti.com Signed-off-by: Hao Zhang hzhang@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/include/asm/arch-keystone/hardware-k2hk.h | 2 - arch/arm/include/asm/arch-keystone/hardware-k2l.h | 74 ++++++++++++++++++++++ arch/arm/include/asm/arch-keystone/hardware.h | 13 ++++ 3 files changed, 87 insertions(+), 2 deletions(-) create mode 100644 arch/arm/include/asm/arch-keystone/hardware-k2l.h
diff --git a/arch/arm/include/asm/arch-keystone/hardware-k2hk.h b/arch/arm/include/asm/arch-keystone/hardware-k2hk.h index 43c2c42..2db806c 100644 --- a/arch/arm/include/asm/arch-keystone/hardware-k2hk.h +++ b/arch/arm/include/asm/arch-keystone/hardware-k2hk.h @@ -10,8 +10,6 @@ #ifndef __ASM_ARCH_HARDWARE_K2HK_H #define __ASM_ARCH_HARDWARE_K2HK_H
-#define KS2_MISC_CTRL (KS2_DEVICE_STATE_CTRL_BASE + 0xc7c) - #define KS2_ARM_PLL_EN BIT(13)
/* PA SS Registers */ diff --git a/arch/arm/include/asm/arch-keystone/hardware-k2l.h b/arch/arm/include/asm/arch-keystone/hardware-k2l.h new file mode 100644 index 0000000..3402d0c --- /dev/null +++ b/arch/arm/include/asm/arch-keystone/hardware-k2l.h @@ -0,0 +1,74 @@ +/* + * K2L: SoC definitions + * + * (C) Copyright 2012-2014 + * Texas Instruments Incorporated, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARCH_HARDWARE_K2L_H +#define __ASM_ARCH_HARDWARE_K2L_H + +#define KS2_ARM_PLL_EN BIT(13) + +/* PA SS Registers */ +#define KS2_PASS_BASE 0x26000000 + +/* Power and Sleep Controller (PSC) Domains */ +#define KS2_LPSC_MOD 0 +#define KS2_LPSC_DFE_IQN_SYS 1 +#define KS2_LPSC_USB 2 +#define KS2_LPSC_EMIF25_SPI 3 +#define KS2_LPSC_TSIP 4 +#define KS2_LPSC_DEBUGSS_TRC 5 +#define KS2_LPSC_TETB_TRC 6 +#define KS2_LPSC_PKTPROC 7 +#define KS2_LPSC_PA KS2_LPSC_PKTPROC +#define KS2_LPSC_SGMII 8 +#define KS2_LPSC_CPGMAC KS2_LPSC_SGMII +#define KS2_LPSC_CRYPTO 9 +#define KS2_LPSC_PCIE0 10 +#define KS2_LPSC_PCIE1 11 +#define KS2_LPSC_JESD_MISC 12 +#define KS2_LPSC_CHIP_SRSS 13 +#define KS2_LPSC_MSMC 14 +#define KS2_LPSC_GEM_1 16 +#define KS2_LPSC_GEM_2 17 +#define KS2_LPSC_GEM_3 18 +#define KS2_LPSC_EMIF4F_DDR3 23 +#define KS2_LPSC_TAC 25 +#define KS2_LPSC_RAC 26 +#define KS2_LPSC_DDUC4X_CFR2X_BB 27 +#define KS2_LPSC_FFTC_A 28 +#define KS2_LPSC_OSR 34 +#define KS2_LPSC_TCP3D_0 35 +#define KS2_LPSC_TCP3D_1 37 +#define KS2_LPSC_VCP2X4_A 39 +#define KS2_LPSC_VCP2X4_B 40 +#define KS2_LPSC_VCP2X4_C 41 +#define KS2_LPSC_VCP2X4_D 42 +#define KS2_LPSC_BCP 47 +#define KS2_LPSC_DPD4X 48 +#define KS2_LPSC_FFTC_B 49 +#define KS2_LPSC_IQN_AIL 50 + +/* Chip Interrupt Controller */ +#define KS2_CIC2_DDR3_ECC_IRQ_NUM 0x0D3 +#define KS2_CIC2_DDR3_ECC_CHAN_NUM 0x01D + +/* Number of DSP cores */ +#define KS2_NUM_DSPS 4 + +/* NETCP pktdma */ +#define KS2_NETCP_PDMA_CTRL_BASE 0x26186000 +#define KS2_NETCP_PDMA_TX_BASE 0x26187000 +#define KS2_NETCP_PDMA_TX_CH_NUM 21 +#define KS2_NETCP_PDMA_RX_BASE 0x26188000 +#define KS2_NETCP_PDMA_RX_CH_NUM 91 +#define KS2_NETCP_PDMA_SCHED_BASE 0x26186100 +#define KS2_NETCP_PDMA_RX_FLOW_BASE 0x26189000 +#define KS2_NETCP_PDMA_RX_FLOW_NUM 96 +#define KS2_NETCP_PDMA_TX_SND_QUEUE 896 + +#endif /* __ASM_ARCH_HARDWARE_K2L_H */ diff --git a/arch/arm/include/asm/arch-keystone/hardware.h b/arch/arm/include/asm/arch-keystone/hardware.h index fdffb87..89dce96 100644 --- a/arch/arm/include/asm/arch-keystone/hardware.h +++ b/arch/arm/include/asm/arch-keystone/hardware.h @@ -141,6 +141,7 @@ typedef volatile unsigned int *dv_reg_p; /* Device speed */ #define KS2_REV1_DEVSPEED (KS2_DEVICE_STATE_CTRL_BASE + 0xc98) #define KS2_EFUSE_BOOTROM (KS2_DEVICE_STATE_CTRL_BASE + 0xc90) +#define KS2_MISC_CTRL (KS2_DEVICE_STATE_CTRL_BASE + 0xc7c)
/* Queue manager */ #define KS2_QM_BASE_ADDRESS 0x23a80000 @@ -175,6 +176,10 @@ typedef volatile unsigned int *dv_reg_p; #include <asm/arch/hardware-k2e.h> #endif
+#ifdef CONFIG_SOC_K2L +#include <asm/arch/hardware-k2l.h> +#endif + #ifndef __ASSEMBLY__ static inline int cpu_is_k2hk(void) { @@ -192,6 +197,14 @@ static inline int cpu_is_k2e(void) return (part_no == 0xb9a6) ? 1 : 0; }
+static inline int cpu_is_k2l(void) +{ + unsigned int jtag_id = __raw_readl(KS2_JTAG_ID_REG); + unsigned int part_no = (jtag_id >> 12) & 0xffff; + + return (part_no == 0xb9a7) ? 1 : 0; +} + static inline int cpu_revision(void) { unsigned int jtag_id = __raw_readl(KS2_JTAG_ID_REG);
This patch adds clock definitions and commands to support Keystone II K2L SOC.
Acked-by: Vitaly Andrianov vitalya@ti.com Signed-off-by: Hao Zhang hzhang@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/cpu/armv7/keystone/Makefile | 1 + arch/arm/cpu/armv7/keystone/clock-k2l.c | 139 +++++++++++++++++++++++++ arch/arm/cpu/armv7/keystone/cmd_clock.c | 10 ++ arch/arm/include/asm/arch-keystone/clock-k2l.h | 88 ++++++++++++++++ arch/arm/include/asm/arch-keystone/clock.h | 4 + 5 files changed, 242 insertions(+) create mode 100644 arch/arm/cpu/armv7/keystone/clock-k2l.c create mode 100644 arch/arm/include/asm/arch-keystone/clock-k2l.h
diff --git a/arch/arm/cpu/armv7/keystone/Makefile b/arch/arm/cpu/armv7/keystone/Makefile index 3d8fb70..4750371 100644 --- a/arch/arm/cpu/armv7/keystone/Makefile +++ b/arch/arm/cpu/armv7/keystone/Makefile @@ -10,6 +10,7 @@ obj-y += psc.o obj-y += clock.o obj-$(CONFIG_SOC_K2HK) += clock-k2hk.o obj-$(CONFIG_SOC_K2E) += clock-k2e.o +obj-$(CONFIG_SOC_K2L) += clock-k2l.o obj-y += cmd_clock.o obj-y += cmd_mon.o obj-y += msmc.o diff --git a/arch/arm/cpu/armv7/keystone/clock-k2l.c b/arch/arm/cpu/armv7/keystone/clock-k2l.c new file mode 100644 index 0000000..783355a --- /dev/null +++ b/arch/arm/cpu/armv7/keystone/clock-k2l.c @@ -0,0 +1,139 @@ +/* + * Keystone2: get clk rate for K2L + * + * (C) Copyright 2012-2014 + * Texas Instruments Incorporated, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/clock.h> +#include <asm/arch/clock_defs.h> + +const struct keystone_pll_regs keystone_pll_regs[] = { + [CORE_PLL] = {KS2_MAINPLLCTL0, KS2_MAINPLLCTL1}, + [PASS_PLL] = {KS2_PASSPLLCTL0, KS2_PASSPLLCTL1}, + [TETRIS_PLL] = {KS2_ARMPLLCTL0, KS2_ARMPLLCTL1}, + [DDR3_PLL] = {KS2_DDR3APLLCTL0, KS2_DDR3APLLCTL1}, +}; + +int dev_speeds[] = { + SPD800, + SPD1000, + SPD1200, + SPD800, + SPD800, + SPD800, + SPD800, + SPD800, + SPD1200, + SPD1000, + SPD800, + SPD800, + SPD800, +}; + +int arm_speeds[] = { + SPD800, + SPD1000, + SPD1200, + SPD1350, + SPD1400, + SPD800, + SPD1400, + SPD1350, + SPD1200, + SPD1000, + SPD800, + SPD800, + SPD800, +}; + +/** + * pll_freq_get - get pll frequency + * Fout = Fref * NF(mult) / NR(prediv) / OD + * @pll: pll identifier + */ +static unsigned long pll_freq_get(int pll) +{ + unsigned long mult = 1, prediv = 1, output_div = 2; + unsigned long ret; + u32 tmp, reg; + + if (pll == CORE_PLL) { + ret = external_clk[sys_clk]; + if (pllctl_reg_read(pll, ctl) & PLLCTL_PLLEN) { + /* PLL mode */ + tmp = __raw_readl(KS2_MAINPLLCTL0); + prediv = (tmp & PLL_DIV_MASK) + 1; + mult = (((tmp & PLLM_MULT_HI_SMASK) >> 6) | + (pllctl_reg_read(pll, mult) & + PLLM_MULT_LO_MASK)) + 1; + output_div = ((pllctl_reg_read(pll, secctl) >> + PLL_CLKOD_SHIFT) & PLL_CLKOD_MASK) + 1; + + ret = ret / prediv / output_div * mult; + } + } else { + switch (pll) { + case PASS_PLL: + ret = external_clk[pa_clk]; + reg = KS2_PASSPLLCTL0; + break; + case TETRIS_PLL: + ret = external_clk[tetris_clk]; + reg = KS2_ARMPLLCTL0; + break; + case DDR3_PLL: + ret = external_clk[ddr3_clk]; + reg = KS2_DDR3APLLCTL0; + break; + default: + return 0; + } + + tmp = __raw_readl(reg); + + if (!(tmp & PLLCTL_BYPASS)) { + /* Bypass disabled */ + prediv = (tmp & PLL_DIV_MASK) + 1; + mult = ((tmp >> PLL_MULT_SHIFT) & PLL_MULT_MASK) + 1; + output_div = ((tmp >> PLL_CLKOD_SHIFT) & + PLL_CLKOD_MASK) + 1; + ret = ((ret / prediv) * mult) / output_div; + } + } + + return ret; +} + +unsigned long clk_get_rate(unsigned int clk) +{ + switch (clk) { + case core_pll_clk: return pll_freq_get(CORE_PLL); + case pass_pll_clk: return pll_freq_get(PASS_PLL); + case tetris_pll_clk: return pll_freq_get(TETRIS_PLL); + case ddr3_pll_clk: return pll_freq_get(DDR3_PLL); + case sys_clk0_1_clk: + case sys_clk0_clk: return pll_freq_get(CORE_PLL) / pll0div_read(1); + case sys_clk1_clk: return pll_freq_get(CORE_PLL) / pll0div_read(2); + case sys_clk2_clk: return pll_freq_get(CORE_PLL) / pll0div_read(3); + case sys_clk3_clk: return pll_freq_get(CORE_PLL) / pll0div_read(4); + case sys_clk0_2_clk: return clk_get_rate(sys_clk0_clk) / 2; + case sys_clk0_3_clk: return clk_get_rate(sys_clk0_clk) / 3; + case sys_clk0_4_clk: return clk_get_rate(sys_clk0_clk) / 4; + case sys_clk0_6_clk: return clk_get_rate(sys_clk0_clk) / 6; + case sys_clk0_8_clk: return clk_get_rate(sys_clk0_clk) / 8; + case sys_clk0_12_clk: return clk_get_rate(sys_clk0_clk) / 12; + case sys_clk0_24_clk: return clk_get_rate(sys_clk0_clk) / 24; + case sys_clk1_3_clk: return clk_get_rate(sys_clk1_clk) / 3; + case sys_clk1_4_clk: return clk_get_rate(sys_clk1_clk) / 4; + case sys_clk1_6_clk: return clk_get_rate(sys_clk1_clk) / 6; + case sys_clk1_12_clk: return clk_get_rate(sys_clk1_clk) / 12; + default: + break; + } + + return 0; +} diff --git a/arch/arm/cpu/armv7/keystone/cmd_clock.c b/arch/arm/cpu/armv7/keystone/cmd_clock.c index d97c95b..9204887 100644 --- a/arch/arm/cpu/armv7/keystone/cmd_clock.c +++ b/arch/arm/cpu/armv7/keystone/cmd_clock.c @@ -72,6 +72,13 @@ U_BOOT_CMD( "<pa|ddr3> <mult> <div> <OD>\n" ); #endif +#ifdef CONFIG_SOC_K2L +U_BOOT_CMD( + pllset, 5, 0, do_pll_cmd, + "set pll multiplier and pre divider", + "<pa|arm|ddr3> <mult> <div> <OD>\n" +); +#endif
int do_getclk_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -101,6 +108,9 @@ U_BOOT_CMD( #ifdef CONFIG_SOC_K2E "See the 'enum clk_e' in the clock-k2e.h for clk indexes\n" #endif +#ifdef CONFIG_SOC_K2L + "See the 'enum clk_e' in the clock-k2l.h for clk indexes\n" +#endif );
int do_psc_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) diff --git a/arch/arm/include/asm/arch-keystone/clock-k2l.h b/arch/arm/include/asm/arch-keystone/clock-k2l.h new file mode 100644 index 0000000..8cacee0 --- /dev/null +++ b/arch/arm/include/asm/arch-keystone/clock-k2l.h @@ -0,0 +1,88 @@ +/* + * K2L: Clock management APIs + * + * (C) Copyright 2012-2014 + * Texas Instruments Incorporated, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARCH_CLOCK_K2L_H +#define __ASM_ARCH_CLOCK_K2L_H + +enum ext_clk_e { + sys_clk, + alt_core_clk, + pa_clk, + tetris_clk, + ddr3_clk, + pcie_clk, + sgmii_clk, + usb_clk, + rp1_clk, + ext_clk_count /* number of external clocks */ +}; + +extern unsigned int external_clk[ext_clk_count]; + +enum clk_e { + core_pll_clk, + pass_pll_clk, + tetris_pll_clk, + ddr3_pll_clk, + sys_clk0_clk, + sys_clk0_1_clk, + sys_clk0_2_clk, + sys_clk0_3_clk, + sys_clk0_4_clk, + sys_clk0_6_clk, + sys_clk0_8_clk, + sys_clk0_12_clk, + sys_clk0_24_clk, + sys_clk1_clk, + sys_clk1_3_clk, + sys_clk1_4_clk, + sys_clk1_6_clk, + sys_clk1_12_clk, + sys_clk2_clk, + sys_clk3_clk +}; + +#define KS2_CLK1_6 sys_clk0_6_clk + +/* PLL identifiers */ +enum pll_type_e { + CORE_PLL, + PASS_PLL, + TETRIS_PLL, + DDR3_PLL, +}; + +enum { + SPD800, + SPD1000, + SPD1200, + SPD1350, + SPD1400, + SPD_RSV +}; + +#define CORE_PLL_799 {CORE_PLL, 13, 1, 2} +#define CORE_PLL_983 {CORE_PLL, 16, 1, 2} +#define CORE_PLL_1167 {CORE_PLL, 19, 1, 2} +#define CORE_PLL_1228 {CORE_PLL, 20, 1, 2} +#define PASS_PLL_1228 {PASS_PLL, 20, 1, 2} +#define PASS_PLL_983 {PASS_PLL, 16, 1, 2} +#define PASS_PLL_1050 {PASS_PLL, 205, 12, 2} +#define TETRIS_PLL_491 {TETRIS_PLL, 8, 1, 2} +#define TETRIS_PLL_737 {TETRIS_PLL, 12, 1, 2} +#define TETRIS_PLL_799 {TETRIS_PLL, 13, 1, 2} +#define TETRIS_PLL_983 {TETRIS_PLL, 16, 1, 2} +#define TETRIS_PLL_1167 {TETRIS_PLL, 19, 1, 2} +#define TETRIS_PLL_1228 {TETRIS_PLL, 20, 1, 2} +#define DDR3_PLL_200 {DDR3_PLL, 4, 1, 2} +#define DDR3_PLL_400 {DDR3_PLL, 16, 1, 4} +#define DDR3_PLL_800 {DDR3_PLL, 16, 1, 2} +#define DDR3_PLL_333 {DDR3_PLL, 20, 1, 6} + +#endif diff --git a/arch/arm/include/asm/arch-keystone/clock.h b/arch/arm/include/asm/arch-keystone/clock.h index dae000e..bc31267 100644 --- a/arch/arm/include/asm/arch-keystone/clock.h +++ b/arch/arm/include/asm/arch-keystone/clock.h @@ -20,6 +20,10 @@ #include <asm/arch/clock-k2e.h> #endif
+#ifdef CONFIG_SOC_K2L +#include <asm/arch/clock-k2l.h> +#endif + #define MAIN_PLL CORE_PLL
#include <asm/types.h>
This patch adds Keystone II Lamar (K2L) SoC specific definitions to support MSMC cache coherency.
Acked-by: Vitaly Andrianov vitalya@ti.com Signed-off-by: Hao Zhang hzhang@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/cpu/armv7/keystone/init.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/cpu/armv7/keystone/init.c b/arch/arm/cpu/armv7/keystone/init.c index a8f8aee..a0ecfa2 100644 --- a/arch/arm/cpu/armv7/keystone/init.c +++ b/arch/arm/cpu/armv7/keystone/init.c @@ -32,6 +32,9 @@ int arch_cpu_init(void) #ifdef CONFIG_SOC_K2E msmc_share_all_segments(13); /* PCIE 1 */ #endif +#ifdef CONFIG_SOC_K2L + msmc_share_all_segments(14); /* PCIE 1 */ +#endif
/* * just initialise the COM2 port so that TI specific
Add Keystone II Lamar (K2L) SoC support.
Acked-by: Vitaly Andrianov vitalya@ti.com Signed-off-by: Hao Zhang hzhang@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/cpu/armv7/keystone/spl.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/cpu/armv7/keystone/spl.c b/arch/arm/cpu/armv7/keystone/spl.c index d4b0e9b..6a3adf4 100644 --- a/arch/arm/cpu/armv7/keystone/spl.c +++ b/arch/arm/cpu/armv7/keystone/spl.c @@ -31,6 +31,13 @@ static struct pll_init_data spl_pll_config[] = { }; #endif
+#ifdef CONFIG_K2L_EVM +static struct pll_init_data spl_pll_config[] = { + CORE_PLL_799, + TETRIS_PLL_491, +}; +#endif + void spl_init_keystone_plls(void) { init_plls(ARRAY_SIZE(spl_pll_config), spl_pll_config);
This patches enables the On-chip Shared Ram clock domain for K2L SoC.
Signed-off-by: Hao Zhang hzhang@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/cpu/armv7/keystone/init.c | 49 +++++++++++++++++++++++ arch/arm/include/asm/arch-keystone/hardware-k2l.h | 25 ++++++++++++ arch/arm/include/asm/arch-keystone/hardware.h | 1 + 3 files changed, 75 insertions(+)
diff --git a/arch/arm/cpu/armv7/keystone/init.c b/arch/arm/cpu/armv7/keystone/init.c index a0ecfa2..2228132 100644 --- a/arch/arm/cpu/armv7/keystone/init.c +++ b/arch/arm/cpu/armv7/keystone/init.c @@ -13,6 +13,7 @@ #include <asm/arch/msmc.h> #include <asm/arch/clock.h> #include <asm/arch/hardware.h> +#include <asm/arch/psc_defs.h>
void chip_configuration_unlock(void) { @@ -20,6 +21,53 @@ void chip_configuration_unlock(void) __raw_writel(KS2_KICK1_MAGIC, KS2_KICK1); }
+#ifdef CONFIG_SOC_K2L +void osr_init(void) +{ + u32 i; + u32 j; + u32 val; + u32 base = KS2_OSR_CFG_BASE; + u32 ecc_ctrl[KS2_OSR_NUM_RAM_BANKS]; + + /* Enable the OSR clock domain */ + psc_enable_module(KS2_LPSC_OSR); + + /* Disable OSR ECC check for all the ram banks */ + for (i = 0; i < KS2_OSR_NUM_RAM_BANKS; i++) { + val = i | KS2_OSR_ECC_VEC_TRIG_RD | + (KS2_OSR_ECC_CTRL << KS2_OSR_ECC_VEC_RD_ADDR_SH); + + writel(val , base + KS2_OSR_ECC_VEC); + + /** + * wait till read is done. + * Print should be added after earlyprintk support is added. + */ + for (j = 0; j < 10000; j++) { + val = readl(base + KS2_OSR_ECC_VEC); + if (val & KS2_OSR_ECC_VEC_RD_DONE) + break; + } + + ecc_ctrl[i] = readl(base + KS2_OSR_ECC_CTRL) ^ + KS2_OSR_ECC_CTRL_CHK; + + writel(ecc_ctrl[i], KS2_MSMC_DATA_BASE + i * 4); + writel(ecc_ctrl[i], base + KS2_OSR_ECC_CTRL); + } + + /* Reset OSR memory to all zeros */ + for (i = 0; i < KS2_OSR_SIZE; i += 4) + writel(0, KS2_OSR_DATA_BASE + i); + + /* Enable OSR ECC check for all the ram banks */ + for (i = 0; i < KS2_OSR_NUM_RAM_BANKS; i++) + writel(ecc_ctrl[i] | + KS2_OSR_ECC_CTRL_CHK, base + KS2_OSR_ECC_CTRL); +} +#endif + int arch_cpu_init(void) { chip_configuration_unlock(); @@ -34,6 +82,7 @@ int arch_cpu_init(void) #endif #ifdef CONFIG_SOC_K2L msmc_share_all_segments(14); /* PCIE 1 */ + osr_init(); #endif
/* diff --git a/arch/arm/include/asm/arch-keystone/hardware-k2l.h b/arch/arm/include/asm/arch-keystone/hardware-k2l.h index 3402d0c..dfde040 100644 --- a/arch/arm/include/asm/arch-keystone/hardware-k2l.h +++ b/arch/arm/include/asm/arch-keystone/hardware-k2l.h @@ -57,6 +57,31 @@ #define KS2_CIC2_DDR3_ECC_IRQ_NUM 0x0D3 #define KS2_CIC2_DDR3_ECC_CHAN_NUM 0x01D
+/* OSR */ +#define KS2_OSR_DATA_BASE 0x70000000 /* OSR data base */ +#define KS2_OSR_CFG_BASE 0x02348c00 /* OSR config base */ +#define KS2_OSR_ECC_VEC 0x08 /* ECC Vector reg */ +#define KS2_OSR_ECC_CTRL 0x14 /* ECC control reg */ + +/* OSR ECC Vector register */ +#define KS2_OSR_ECC_VEC_TRIG_RD BIT(15) /* trigger a read op */ +#define KS2_OSR_ECC_VEC_RD_DONE BIT(24) /* read complete */ + +#define KS2_OSR_ECC_VEC_RAM_ID_SH 0 /* RAM ID shift */ +#define KS2_OSR_ECC_VEC_RD_ADDR_SH 16 /* read address shift */ + +/* OSR ECC control register */ +#define KS2_OSR_ECC_CTRL_EN BIT(0) /* ECC enable bit */ +#define KS2_OSR_ECC_CTRL_CHK BIT(1) /* ECC check bit */ +#define KS2_OSR_ECC_CTRL_RMW BIT(2) /* ECC check bit */ + +/* Number of OSR RAM banks */ +#define KS2_OSR_NUM_RAM_BANKS 4 + +/* OSR memory size */ +#define KS2_OSR_SIZE 0x100000 + + /* Number of DSP cores */ #define KS2_NUM_DSPS 4
diff --git a/arch/arm/include/asm/arch-keystone/hardware.h b/arch/arm/include/asm/arch-keystone/hardware.h index 89dce96..2eec4e7 100644 --- a/arch/arm/include/asm/arch-keystone/hardware.h +++ b/arch/arm/include/asm/arch-keystone/hardware.h @@ -161,6 +161,7 @@ typedef volatile unsigned int *dv_reg_p;
/* MSMC control */ #define KS2_MSMC_CTRL_BASE 0x0bc00000 +#define KS2_MSMC_DATA_BASE 0x0c000000
/* USB */ #define KS2_USB_SS_BASE 0x02680000
This patch adds Keystone II Lammar (K2L) EVM board support.
Acked-by: Vitaly Andrianov vitalya@ti.com Signed-off-by: Hao Zhang hzhang@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/Kconfig | 3 ++ arch/arm/include/asm/arch-keystone/clock-k2l.h | 6 +++ board/ti/ks2_evm/Kconfig | 24 +++++++++++ board/ti/ks2_evm/Makefile | 2 + board/ti/ks2_evm/board_k2l.c | 60 ++++++++++++++++++++++++++ board/ti/ks2_evm/ddr3_cfg.c | 36 ++++++++++++++++ board/ti/ks2_evm/ddr3_cfg.h | 3 ++ board/ti/ks2_evm/ddr3_k2l.c | 43 ++++++++++++++++++ configs/k2l_evm_defconfig | 2 + include/configs/k2l_evm.h | 37 ++++++++++++++++ 10 files changed, 216 insertions(+) create mode 100644 board/ti/ks2_evm/board_k2l.c create mode 100644 board/ti/ks2_evm/ddr3_k2l.c create mode 100644 configs/k2l_evm_defconfig create mode 100644 include/configs/k2l_evm.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index e385eda..29c4b00 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -467,6 +467,9 @@ config TARGET_K2E_EVM config TARGET_K2HK_EVM bool "Support k2hk_evm"
+config TARGET_K2L_EVM + bool "Support k2l_evm" + config TARGET_M53EVK bool "Support m53evk"
diff --git a/arch/arm/include/asm/arch-keystone/clock-k2l.h b/arch/arm/include/asm/arch-keystone/clock-k2l.h index 8cacee0..b3f4e71 100644 --- a/arch/arm/include/asm/arch-keystone/clock-k2l.h +++ b/arch/arm/include/asm/arch-keystone/clock-k2l.h @@ -69,7 +69,9 @@ enum {
#define CORE_PLL_799 {CORE_PLL, 13, 1, 2} #define CORE_PLL_983 {CORE_PLL, 16, 1, 2} +#define CORE_PLL_1000 {CORE_PLL, 114, 7, 2} #define CORE_PLL_1167 {CORE_PLL, 19, 1, 2} +#define CORE_PLL_1198 {CORE_PLL, 39, 2, 2} #define CORE_PLL_1228 {CORE_PLL, 20, 1, 2} #define PASS_PLL_1228 {PASS_PLL, 20, 1, 2} #define PASS_PLL_983 {PASS_PLL, 16, 1, 2} @@ -78,8 +80,12 @@ enum { #define TETRIS_PLL_737 {TETRIS_PLL, 12, 1, 2} #define TETRIS_PLL_799 {TETRIS_PLL, 13, 1, 2} #define TETRIS_PLL_983 {TETRIS_PLL, 16, 1, 2} +#define TETRIS_PLL_1000 {TETRIS_PLL, 114, 7, 2} #define TETRIS_PLL_1167 {TETRIS_PLL, 19, 1, 2} +#define TETRIS_PLL_1198 {TETRIS_PLL, 39, 2, 2} #define TETRIS_PLL_1228 {TETRIS_PLL, 20, 1, 2} +#define TETRIS_PLL_1352 {TETRIS_PLL, 22, 1, 2} +#define TETRIS_PLL_1401 {TETRIS_PLL, 114, 5, 2} #define DDR3_PLL_200 {DDR3_PLL, 4, 1, 2} #define DDR3_PLL_400 {DDR3_PLL, 16, 1, 4} #define DDR3_PLL_800 {DDR3_PLL, 16, 1, 2} diff --git a/board/ti/ks2_evm/Kconfig b/board/ti/ks2_evm/Kconfig index 7890b30..81cf07a 100644 --- a/board/ti/ks2_evm/Kconfig +++ b/board/ti/ks2_evm/Kconfig @@ -45,3 +45,27 @@ config SYS_CONFIG_NAME default "k2hk_evm"
endif + +if TARGET_K2L_EVM + +config SYS_CPU + string + default "armv7" + +config SYS_BOARD + string + default "ks2_evm" + +config SYS_VENDOR + string + default "ti" + +config SYS_SOC + string + default "keystone" + +config SYS_CONFIG_NAME + string + default "k2l_evm" + +endif diff --git a/board/ti/ks2_evm/Makefile b/board/ti/ks2_evm/Makefile index 00f1164..071dbee 100644 --- a/board/ti/ks2_evm/Makefile +++ b/board/ti/ks2_evm/Makefile @@ -11,3 +11,5 @@ obj-$(CONFIG_K2HK_EVM) += board_k2hk.o obj-$(CONFIG_K2HK_EVM) += ddr3_k2hk.o obj-$(CONFIG_K2E_EVM) += board_k2e.o obj-$(CONFIG_K2E_EVM) += ddr3_k2e.o +obj-$(CONFIG_K2L_EVM) += board_k2l.o +obj-$(CONFIG_K2L_EVM) += ddr3_k2l.o diff --git a/board/ti/ks2_evm/board_k2l.c b/board/ti/ks2_evm/board_k2l.c new file mode 100644 index 0000000..b8faff6 --- /dev/null +++ b/board/ti/ks2_evm/board_k2l.c @@ -0,0 +1,60 @@ +/* + * K2L EVM : Board initialization + * + * (C) Copyright 2014 + * Texas Instruments Incorporated, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/ddr3.h> +#include <asm/arch/hardware.h> +#include <asm/ti-common/ti-aemif.h> + +DECLARE_GLOBAL_DATA_PTR; + +unsigned int external_clk[ext_clk_count] = { + [sys_clk] = 122880000, + [alt_core_clk] = 100000000, + [pa_clk] = 122880000, + [tetris_clk] = 122880000, + [ddr3_clk] = 100000000, + [pcie_clk] = 100000000, + [sgmii_clk] = 156250000, + [usb_clk] = 100000000, +}; + +static struct pll_init_data core_pll_config[] = { + CORE_PLL_799, + CORE_PLL_1000, + CORE_PLL_1198, +}; + +static struct pll_init_data tetris_pll_config[] = { + TETRIS_PLL_799, + TETRIS_PLL_1000, + TETRIS_PLL_1198, + TETRIS_PLL_1352, + TETRIS_PLL_1401, +}; + +static struct pll_init_data pa_pll_config = + PASS_PLL_983; + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ + int speed; + + speed = get_max_dev_speed(); + init_pll(&core_pll_config[speed]); + + init_pll(&pa_pll_config); + + speed = get_max_arm_speed(); + init_pll(&tetris_pll_config[speed]); + + return 0; +} +#endif diff --git a/board/ti/ks2_evm/ddr3_cfg.c b/board/ti/ks2_evm/ddr3_cfg.c index f7da9f2..ab44676 100644 --- a/board/ti/ks2_evm/ddr3_cfg.c +++ b/board/ti/ks2_evm/ddr3_cfg.c @@ -133,6 +133,42 @@ struct ddr3_emif_config ddr3_1600_4g = { }; #endif
+struct ddr3_phy_config ddr3phy_1600_2g = { + .pllcr = 0x0001C000ul, + .pgcr1_mask = (IODDRM_MASK | ZCKSEL_MASK), + .pgcr1_val = ((1 << 2) | (1 << 7) | (1 << 23)), + .ptr0 = 0x42C21590ul, + .ptr1 = 0xD05612C0ul, + .ptr2 = 0, /* not set in gel */ + .ptr3 = 0x0D861A80ul, + .ptr4 = 0x0C827100ul, + .dcr_mask = (PDQ_MASK | MPRDQ_MASK | BYTEMASK_MASK), + .dcr_val = ((1 << 10)), + .dtpr0 = 0x9D5CBB66ul, + .dtpr1 = 0x12868300ul, + .dtpr2 = 0x5002D200ul, + .mr0 = 0x00001C70ul, + .mr1 = 0x00000006ul, + .mr2 = 0x00000018ul, + .dtcr = 0x710035C7ul, + .pgcr2 = 0x00F07A12ul, + .zq0cr1 = 0x0001005Dul, + .zq1cr1 = 0x0001005Bul, + .zq2cr1 = 0x0001005Bul, + .pir_v1 = 0x00000033ul, + .pir_v2 = 0x0000FF81ul, +}; + +struct ddr3_emif_config ddr3_1600_2g = { + .sdcfg = 0x6200CE62ul, + .sdtim1 = 0x166C9855ul, + .sdtim2 = 0x00001D4Aul, + .sdtim3 = 0x435DFF53ul, + .sdtim4 = 0x543F0CFFul, + .zqcfg = 0x70073200ul, + .sdrfc = 0x00001869ul, +}; + int ddr3_get_dimm_params(char *dimm_name) { int ret; diff --git a/board/ti/ks2_evm/ddr3_cfg.h b/board/ti/ks2_evm/ddr3_cfg.h index 15fcf52..5bd786c 100644 --- a/board/ti/ks2_evm/ddr3_cfg.h +++ b/board/ti/ks2_evm/ddr3_cfg.h @@ -19,6 +19,9 @@ extern struct ddr3_emif_config ddr3_1333_2g; extern struct ddr3_phy_config ddr3phy_1600_4g; extern struct ddr3_emif_config ddr3_1600_4g;
+extern struct ddr3_phy_config ddr3phy_1600_2g; +extern struct ddr3_emif_config ddr3_1600_2g; + int ddr3_get_dimm_params(char *dimm_name);
#endif /* __DDR3_CFG_H */ diff --git a/board/ti/ks2_evm/ddr3_k2l.c b/board/ti/ks2_evm/ddr3_k2l.c new file mode 100644 index 0000000..98da162 --- /dev/null +++ b/board/ti/ks2_evm/ddr3_k2l.c @@ -0,0 +1,43 @@ +/* + * Keystone2: DDR3 initialization + * + * (C) Copyright 2014 + * Texas Instruments Incorporated, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include "ddr3_cfg.h" +#include <asm/arch/ddr3.h> + +static int ddr3_size; +static struct pll_init_data ddr3_400 = DDR3_PLL_400; + +void ddr3_init(void) +{ + char dimm_name[32]; + + ddr3_get_dimm_params(dimm_name); + printf("Detected SO-DIMM [%s]\n", dimm_name); + + init_pll(&ddr3_400); + + /* No SO-DIMM, 2GB discreet DDR */ + printf("DRAM: 2 GiB\n"); + ddr3_size = 2; + + /* Reset DDR3 PHY after PLL enabled */ + ddr3_reset_ddrphy(); + + ddr3_init_ddrphy(KS2_DDR3A_DDRPHYC, &ddr3phy_1600_2g); + ddr3_init_ddremif(KS2_DDR3A_EMIF_CTRL_BASE, &ddr3_1600_2g); +} + +/** + * ddr3_get_size - return ddr3 size in GiB + */ +int ddr3_get_size(void) +{ + return ddr3_size; +} diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig new file mode 100644 index 0000000..ba22181 --- /dev/null +++ b/configs/k2l_evm_defconfig @@ -0,0 +1,2 @@ +CONFIG_ARM=y +CONFIG_TARGET_K2L_EVM=y diff --git a/include/configs/k2l_evm.h b/include/configs/k2l_evm.h new file mode 100644 index 0000000..0e1f725 --- /dev/null +++ b/include/configs/k2l_evm.h @@ -0,0 +1,37 @@ +/* + * Configuration header file for TI's k2l-evm + * + * (C) Copyright 2012-2014 + * Texas Instruments Incorporated, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_K2L_EVM_H +#define __CONFIG_K2L_EVM_H + +/* Platform type */ +#define CONFIG_SOC_K2L +#define CONFIG_K2L_EVM + +/* U-Boot general configuration */ +#define CONFIG_SYS_PROMPT "K2L EVM # " + +#define KS2_ARGS_UBI "args_ubi=setenv bootargs ${bootargs} rootfstype=ubifs "\ + "root=ubi0:rootfs rootflags=sync rw ubi.mtd=2,4096\0" + +#define KS2_FDT_NAME "name_fdt=k2l-evm.dtb\0" +#define KS2_ADDR_MON "addr_mon=0x0c140000\0" +#define KS2_NAME_MON "name_mon=skern-k2l-evm.bin\0" +#define NAME_UBOOT "name_uboot=u-boot-spi-k2l-evm.gph\0" +#define NAME_UBI "name_ubi=k2l-evm-ubifs.ubi\0" + +#include <configs/ks2_evm.h> + +/* SPL SPI Loader Configuration */ +#define CONFIG_SPL_TEXT_BASE 0x0c100000 + +/* NAND Configuration */ +#define CONFIG_SYS_NAND_PAGE_4K + +#endif /* __CONFIG_K2L_EVM_H */
Ivan Khoronzhuk
