[U-Boot] [PULL] u-boot-usb/master
PR with USB fixes follows, please apply for current u-boot/master .
The following changes since commit 38dac81b3d0e777f301ca98100bfbcab01d616c2:
Merge branch 'master' of git://git.denx.de/u-boot-mmc (2015-02-23 16:18:06 -0500)
git://git.denx.de/u-boot-usb.git HEAD
for you to fetch changes up to c01c418717d718603e746fbc7885f76a5f8f73a5:
MAINTAINERS: Add F: drivers/usb/gadget to DFU custodian responsibility (2015-03-02 11:02:59 +0100)
---------------------------------------------------------------- Dileep Katta (4): usb: gadget: fastboot: Add fastboot erase fastboot: OUT transaction length must be aligned to wMaxPacketSize fastboot: Correct fastboot_fail and fastboot_okay strings usb: gadget: fastboot: Set the Serial Number for Fastboot Gadget
Inha Song (1): odroid: adjust get_dfu_alt_*() functions to new declarations
Joonyoung Shim (1): exynos: usb: make dwc3_set_mode to static
Michael Scott (1): fastboot: add "fastboot oem" command support
Paul Kocialkowski (1): usb: musb-new: omap2430: Reset the MUSB controller early
Przemyslaw Marczak (1): dfu: samsung: move call to set_dfu_alt_info() to dfu common code
Rob Herring (2): fastboot: add support for "oem format" command fastboot: Add USB cable detect check
Łukasz Majewski (1): MAINTAINERS: Add F: drivers/usb/gadget to DFU custodian responsibility
MAINTAINERS | 1 + board/samsung/common/board.c | 3 --- board/samsung/common/misc.c | 6 +++--- board/samsung/odroid/odroid.c | 31 +++++++++++++++++-------------- common/cmd_fastboot.c | 6 ++++++ common/fb_mmc.c | 60 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-- doc/README.android-fastboot | 5 ++--- drivers/dfu/dfu.c | 3 +++ drivers/usb/gadget/f_fastboot.c | 83 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++----- drivers/usb/host/xhci-exynos5.c | 2 +- drivers/usb/musb-new/omap2430.c | 16 ++++++++++++++++ include/dfu.h | 3 +++ include/fb_mmc.h | 1 + include/samsung/misc.h | 5 ++--- 14 files changed, 191 insertions(+), 34 deletions(-)
