[U-Boot] [PATCH] nand_spl: fix u-boot.lst breakage
Commit 97b24d3d51a92cb8c0c1e1a74abf22fe1a1807a3 "common: Add symbol handling for generic lists into Makefile" introduced build errors in many nand_spl targets, complaining of a missing u-boot.lst. When not doing an out-of-tree build, $(obj) expands to nothing, so GCC ended up being given -I with no argument (or rather, -ansi was the argument). The failure didn't show up during a -j1 build because it was picking up the non-SPL version of u-boot.lst.
Signed-off-by: Scott Wood scottwood@freescale.com --- I didn't fix p1_p2_rdb_pc because that will just conflict with the patchset that migrates that target away from nand_spl.
nand_spl/board/freescale/mpc8536ds/Makefile | 3 ++- nand_spl/board/freescale/mpc8569mds/Makefile | 3 ++- nand_spl/board/freescale/mpc8572ds/Makefile | 3 ++- nand_spl/board/freescale/mx31pdk/Makefile | 3 ++- nand_spl/board/freescale/p1010rdb/Makefile | 3 ++- nand_spl/board/freescale/p1023rds/Makefile | 3 ++- nand_spl/board/freescale/p1_p2_rdb/Makefile | 3 ++- nand_spl/board/karo/tx25/Makefile | 3 ++- 8 files changed, 16 insertions(+), 8 deletions(-)
diff --git a/nand_spl/board/freescale/mpc8536ds/Makefile b/nand_spl/board/freescale/mpc8536ds/Makefile index c923557..9c77826 100644 --- a/nand_spl/board/freescale/mpc8536ds/Makefile +++ b/nand_spl/board/freescale/mpc8536ds/Makefile @@ -67,7 +67,8 @@ $(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot-nand_spl.lds # $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. $(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) $(nandobj)u-boot-nand_spl.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj) -ansi -D__ASSEMBLY__ -P - <$< >$@ + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ + -ansi -D__ASSEMBLY__ -P - <$< >$@
# create symbolic links for common files
diff --git a/nand_spl/board/freescale/mpc8569mds/Makefile b/nand_spl/board/freescale/mpc8569mds/Makefile index c923557..9c77826 100644 --- a/nand_spl/board/freescale/mpc8569mds/Makefile +++ b/nand_spl/board/freescale/mpc8569mds/Makefile @@ -67,7 +67,8 @@ $(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot-nand_spl.lds # $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. $(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) $(nandobj)u-boot-nand_spl.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj) -ansi -D__ASSEMBLY__ -P - <$< >$@ + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ + -ansi -D__ASSEMBLY__ -P - <$< >$@
diff --git a/nand_spl/board/freescale/mpc8572ds/Makefile b/nand_spl/board/freescale/mpc8572ds/Makefile index c923557..9c77826 100644 --- a/nand_spl/board/freescale/mpc8572ds/Makefile +++ b/nand_spl/board/freescale/mpc8572ds/Makefile @@ -67,7 +67,8 @@ $(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot-nand_spl.lds # $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. $(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) $(nandobj)u-boot-nand_spl.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj) -ansi -D__ASSEMBLY__ -P - <$< >$@ + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ + -ansi -D__ASSEMBLY__ -P - <$< >$@
diff --git a/nand_spl/board/freescale/mx31pdk/Makefile b/nand_spl/board/freescale/mx31pdk/Makefile index 43e72c4..f67ed09 100644 --- a/nand_spl/board/freescale/mx31pdk/Makefile +++ b/nand_spl/board/freescale/mx31pdk/Makefile @@ -42,7 +42,8 @@ $(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot.lds # $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. $(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) $(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj) -ansi -D__ASSEMBLY__ -P - <$< >$@ + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ + -ansi -D__ASSEMBLY__ -P - <$< >$@
diff --git a/nand_spl/board/freescale/p1010rdb/Makefile b/nand_spl/board/freescale/p1010rdb/Makefile index ccff1c7..c3495ec 100644 --- a/nand_spl/board/freescale/p1010rdb/Makefile +++ b/nand_spl/board/freescale/p1010rdb/Makefile @@ -67,7 +67,8 @@ $(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot-nand_spl.lds # $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. $(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) $(nandobj)u-boot-nand_spl.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj) -ansi -D__ASSEMBLY__ -P - <$< >$@ + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)board/$(BOARDDIR) \ + -ansi -D__ASSEMBLY__ -P - <$< >$@
diff --git a/nand_spl/board/freescale/p1023rds/Makefile b/nand_spl/board/freescale/p1023rds/Makefile index ffe29c8..9b2c0d7 100644 --- a/nand_spl/board/freescale/p1023rds/Makefile +++ b/nand_spl/board/freescale/p1023rds/Makefile @@ -62,7 +62,8 @@ $(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot-nand_spl.lds # $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. $(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) $(nandobj)u-boot-nand_spl.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj) -ansi -D__ASSEMBLY__ -P - <$< >$@ + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ + -ansi -D__ASSEMBLY__ -P - <$< >$@
diff --git a/nand_spl/board/freescale/p1_p2_rdb/Makefile b/nand_spl/board/freescale/p1_p2_rdb/Makefile index c923557..9c77826 100644 --- a/nand_spl/board/freescale/p1_p2_rdb/Makefile +++ b/nand_spl/board/freescale/p1_p2_rdb/Makefile @@ -67,7 +67,8 @@ $(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot-nand_spl.lds # $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. $(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) $(nandobj)u-boot-nand_spl.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj) -ansi -D__ASSEMBLY__ -P - <$< >$@ + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ + -ansi -D__ASSEMBLY__ -P - <$< >$@
diff --git a/nand_spl/board/karo/tx25/Makefile b/nand_spl/board/karo/tx25/Makefile index becf7fa..b27189d 100644 --- a/nand_spl/board/karo/tx25/Makefile +++ b/nand_spl/board/karo/tx25/Makefile @@ -63,7 +63,8 @@ $(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot.lds # $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. $(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) $(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj) -ansi -D__ASSEMBLY__ -P - <$< >$@ + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ + -ansi -D__ASSEMBLY__ -P - <$< >$@
Dear Scott Wood,
Here comes Wolfgangs' "in-tree builds have no benefit" ;)
ICK ... thanks for fixing it.
It seems my warm stop under the rock won't get cold any soon due to my recent changes to uboot source ... crawl crawl crawl ...
Dear Marek Vasut,
Please do not misquote me. I never said anything like that.
Appied to staging/agust@denx.de, thanks!
Anatolij
Anatolij Gustschin
Scott Wood
