[U-Boot] [PATCH 1/8] ARM: rmobile: Enable MTD partitioning on Gen2 with SF
Enable MTD partitioning support on Gen2 boards with SPI NORs.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- include/configs/rcar-gen2-common.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index eadf5594c8..231c4ecea4 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -51,4 +51,12 @@ #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN)
+/* SF MTD */ +#if defined(CONFIG_SPI_FLASH_MTD) && !defined(CONFIG_SPL_BUILD) +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#else +#undef CONFIG_SPI_FLASH_MTD +#endif + #endif /* __RCAR_GEN2_COMMON_H */
Add mtdparts description for the board.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/alt_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/alt_defconfig b/configs/alt_defconfig index b0b864c1a1..49f344babd 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -46,6 +46,9 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -58,9 +61,11 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_SH_MMCIF=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/gose_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 8479887604..4b8c5a4aea 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -46,6 +46,9 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -57,9 +60,11 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/koelsch_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index faca596115..39d5805f94 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -46,6 +46,9 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -57,9 +60,11 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/lager_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/lager_defconfig b/configs/lager_defconfig index 70083bcbfe..0eaf33d7f8 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -46,6 +46,9 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -59,9 +62,11 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_SH_MMCIF=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/porter_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/porter_defconfig b/configs/porter_defconfig index b04627efa3..0588387cbd 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -46,6 +46,9 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -57,9 +60,11 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/silk_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/silk_defconfig b/configs/silk_defconfig index a1c4e5cde3..9a9301e7e0 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -46,6 +46,9 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -59,9 +62,11 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_SH_MMCIF=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/stout_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/stout_defconfig b/configs/stout_defconfig index d940932baf..1a9e6ce366 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -46,6 +46,9 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -57,9 +60,11 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y
