[U-Boot] [PATCH RESEND 1/2] rockchip: make_fit_atf: use elf entry point
make_fit_atf.py uses physical address of first segment as the entry point to bl31. It is incorrect and causes following abort when bl31_entry() is called:
U-Boot SPL board initTrying to boot from MMC1 "Synchronous Abort" handler, esr 0x02000000 elr: 0000000000000000 lr : 00000000ff8c7e8c x 0: 00000000ff8e0000 x 1: 0000000000000000 x 2: 0000000000000000 x 3: 00000000ff8e0180 x 4: 0000000000000000 x 5: 0000000000000000 x 6: 0000000000000030 x 7: 00000000ff8e0188 x 8: 00000000000001e0 x 9: 0000000000000000 x10: 000000000007fcdc x11: 00000000002881b8 x12: 00000000000001a2 x13: 0000000000000198 x14: 000000000007fdcc x15: 00000000002881b8 x16: 00000000003c0724 x17: 00000000003c0718 x18: 000000000007fe80 x19: 00000000ff8e0000 x20: 0000000000200000 x21: 00000000ff8e0000 x22: 0000000000000000 x23: 000000000007fe30 x24: 00000000ff8d1c3c x25: 00000000ff8d5000 x26: 00000000deadbeef x27: 00000000000004a0 x28: 000000000000009c x29: 000000000007fd90
Fix it by using the entry point from the elf header.
Signed-off-by: Mian Yousaf Kaukab yousaf.kaukab@suse.com --- arch/arm/mach-rockchip/make_fit_atf.py | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-rockchip/make_fit_atf.py b/arch/arm/mach-rockchip/make_fit_atf.py index 6b3d9201c9..b88a5e1f16 100755 --- a/arch/arm/mach-rockchip/make_fit_atf.py +++ b/arch/arm/mach-rockchip/make_fit_atf.py @@ -53,7 +53,7 @@ DT_END=""" }; """
-def append_atf_node(file, atf_index, phy_addr): +def append_atf_node(file, atf_index, phy_addr, elf_entry): """ Append ATF DT node to input FIT dts file. """ @@ -67,7 +67,7 @@ def append_atf_node(file, atf_index, phy_addr): print >> file, '\t\t\tcompression = "none";' print >> file, '\t\t\tload = <0x%08x>;' % phy_addr if atf_index == 1: - print >> file, '\t\t\tentry = <0x%08x>;' % phy_addr + print >> file, '\t\t\tentry = <0x%08x>;' % elf_entry print >> file, '\t\t};' print >> file, ''
@@ -141,12 +141,13 @@ def generate_atf_fit_dts(fit_file_name, bl31_file_name, uboot_file_name, dtbs_fi
with open(bl31_file_name) as bl31_file: bl31 = ELFFile(bl31_file) + elf_entry = bl31.header['e_entry'] for i in range(bl31.num_segments()): seg = bl31.get_segment(i) if ('PT_LOAD' == seg.__getitem__(ELF_SEG_P_TYPE)): paddr = seg.__getitem__(ELF_SEG_P_PADDR) p= seg.__getitem__(ELF_SEG_P_PADDR) - append_atf_node(fit_file, i+1, paddr) + append_atf_node(fit_file, i+1, paddr, elf_entry) atf_cnt = i+1 append_fdt_node(fit_file, dtbs_file_name) print >> fit_file, '%s' % DT_IMAGES_NODE_END
Make script python3 compatible. No functional changes intended.
Signed-off-by: Mian Yousaf Kaukab yousaf.kaukab@suse.com --- arch/arm/mach-rockchip/make_fit_atf.py | 89 +++++++++++++++++----------------- 1 file changed, 45 insertions(+), 44 deletions(-)
diff --git a/arch/arm/mach-rockchip/make_fit_atf.py b/arch/arm/mach-rockchip/make_fit_atf.py index b88a5e1f16..d72a364ff1 100755 --- a/arch/arm/mach-rockchip/make_fit_atf.py +++ b/arch/arm/mach-rockchip/make_fit_atf.py @@ -1,4 +1,4 @@ -#!/usr/bin/env python2 +#!/usr/bin/env python """ A script to generate FIT image source for rockchip boards with ARM Trusted Firmware @@ -43,6 +43,7 @@ DT_HEADER="""// SPDX-License-Identifier: GPL-2.0+ OR X11 compression = "none"; load = <0x%08x>; }; + """
DT_IMAGES_NODE_END=""" @@ -58,18 +59,18 @@ def append_atf_node(file, atf_index, phy_addr, elf_entry): Append ATF DT node to input FIT dts file. """ data = 'bl31_0x%08x.bin' % phy_addr - print >> file, '\t\tatf@%d {' % atf_index - print >> file, '\t\t\tdescription = "ARM Trusted Firmware";' - print >> file, '\t\t\tdata = /incbin/("%s");' % data - print >> file, '\t\t\ttype = "firmware";' - print >> file, '\t\t\tarch = "arm64";' - print >> file, '\t\t\tos = "arm-trusted-firmware";' - print >> file, '\t\t\tcompression = "none";' - print >> file, '\t\t\tload = <0x%08x>;' % phy_addr + file.write('\t\tatf@%d {\n' % atf_index) + file.write('\t\t\tdescription = "ARM Trusted Firmware";\n') + file.write('\t\t\tdata = /incbin/("%s");\n' % data) + file.write('\t\t\ttype = "firmware";\n') + file.write('\t\t\tarch = "arm64";\n') + file.write('\t\t\tos = "arm-trusted-firmware";\n') + file.write('\t\t\tcompression = "none";\n') + file.write('\t\t\tload = <0x%08x>;\n' % phy_addr) if atf_index == 1: - print >> file, '\t\t\tentry = <0x%08x>;' % elf_entry - print >> file, '\t\t};' - print >> file, '' + file.write('\t\t\tentry = <0x%08x>;\n' % elf_entry) + file.write('\t\t};\n') + file.write('\n')
def append_fdt_node(file, dtbs): """ @@ -78,43 +79,43 @@ def append_fdt_node(file, dtbs): cnt = 1 for dtb in dtbs: dtname = os.path.basename(dtb) - print >> file, '\t\tfdt@%d {' % cnt - print >> file, '\t\t\tdescription = "%s";' % dtname - print >> file, '\t\t\tdata = /incbin/("%s");' % dtb - print >> file, '\t\t\ttype = "flat_dt";' - print >> file, '\t\t\tcompression = "none";' - print >> file, '\t\t};' - print >> file, '' + file.write('\t\tfdt@%d {\n' % cnt) + file.write('\t\t\tdescription = "%s";\n' % dtname) + file.write('\t\t\tdata = /incbin/("%s");\n' % dtb) + file.write('\t\t\ttype = "flat_dt";\n') + file.write('\t\t\tcompression = "none";\n') + file.write('\t\t};\n') + file.write('\n') cnt = cnt + 1
def append_conf_section(file, cnt, dtname, atf_cnt): - print >> file, '\t\tconfig@%d {' % cnt - print >> file, '\t\t\tdescription = "%s";' % dtname - print >> file, '\t\t\tfirmware = "atf@1";' - print >> file, '\t\t\tloadables = "uboot@1",', + file.write('\t\tconfig@%d {\n' % cnt) + file.write('\t\t\tdescription = "%s";\n' % dtname) + file.write('\t\t\tfirmware = "atf@1";\n') + file.write('\t\t\tloadables = "uboot@1",') for i in range(1, atf_cnt): - print >> file, '"atf@%d"' % (i+1), + file.write('"atf@%d"' % (i+1)) if i != (atf_cnt - 1): - print >> file, ',', + file.write(',') else: - print >> file, ';' - print >> file, '\t\t\tfdt = "fdt@1";' - print >> file, '\t\t};' - print >> file, '' + file.write(';\n') + file.write('\t\t\tfdt = "fdt@1";\n') + file.write('\t\t};\n') + file.write('\n')
def append_conf_node(file, dtbs, atf_cnt): """ Append configeration nodes. """ cnt = 1 - print >> file, '\tconfigurations {' - print >> file, '\t\tdefault = "config@1";' + file.write('\tconfigurations {\n') + file.write('\t\tdefault = "config@1";\n') for dtb in dtbs: dtname = os.path.basename(dtb) append_conf_section(file, cnt, dtname, atf_cnt) cnt = cnt + 1 - print >> file, '\t};' - print >> file, '' + file.write('\t};\n') + file.write('\n')
def generate_atf_fit_dts(fit_file_name, bl31_file_name, uboot_file_name, dtbs_file_name): """ @@ -127,7 +128,7 @@ def generate_atf_fit_dts(fit_file_name, bl31_file_name, uboot_file_name, dtbs_fi
num_load_seg = 0 p_paddr = 0xFFFFFFFF - with open(uboot_file_name) as uboot_file: + with open(uboot_file_name, 'rb') as uboot_file: uboot = ELFFile(uboot_file) for i in range(uboot.num_segments()): seg = uboot.get_segment(i) @@ -137,9 +138,9 @@ def generate_atf_fit_dts(fit_file_name, bl31_file_name, uboot_file_name, dtbs_fi
assert (p_paddr != 0xFFFFFFFF and num_load_seg == 1)
- print >> fit_file, DT_HEADER % p_paddr + fit_file.write(DT_HEADER % p_paddr)
- with open(bl31_file_name) as bl31_file: + with open(bl31_file_name, 'rb') as bl31_file: bl31 = ELFFile(bl31_file) elf_entry = bl31.header['e_entry'] for i in range(bl31.num_segments()): @@ -150,15 +151,15 @@ def generate_atf_fit_dts(fit_file_name, bl31_file_name, uboot_file_name, dtbs_fi append_atf_node(fit_file, i+1, paddr, elf_entry) atf_cnt = i+1 append_fdt_node(fit_file, dtbs_file_name) - print >> fit_file, '%s' % DT_IMAGES_NODE_END + fit_file.write('%s\n' % DT_IMAGES_NODE_END) append_conf_node(fit_file, dtbs_file_name, atf_cnt) - print >> fit_file, '%s' % DT_END + fit_file.write('%s\n' % DT_END)
if fit_file_name != sys.stdout: fit_file.close()
def generate_atf_binary(bl31_file_name): - with open(bl31_file_name) as bl31_file: + with open(bl31_file_name, 'rb') as bl31_file: bl31 = ELFFile(bl31_file)
num = bl31.num_segments() @@ -179,17 +180,17 @@ def get_bl31_segments_info(bl31_file_name): bl31 = ELFFile(bl31_file)
num = bl31.num_segments() - print 'Number of Segments : %d' % bl31.num_segments() + print('Number of Segments : %d' % bl31.num_segments()) for i in range(num): - print 'Segment %d' % i + print('Segment %d' % i) seg = bl31.get_segment(i) ptype = seg[ELF_SEG_P_TYPE] poffset = seg[ELF_SEG_P_OFFSET] pmemsz = seg[ELF_SEG_P_MEMSZ] pfilesz = seg[ELF_SEG_P_FILESZ] - print 'type: %s\nfilesz: %08x\nmemsz: %08x\noffset: %08x' % (ptype, pfilesz, pmemsz, poffset) + print('type: %s\nfilesz: %08x\nmemsz: %08x\noffset: %08x' % (ptype, pfilesz, pmemsz, poffset)) paddr = seg[ELF_SEG_P_PADDR] - print 'paddr: %08x' % paddr + print('paddr: %08x' % paddr)
def main(): uboot_elf="./u-boot" @@ -205,7 +206,7 @@ def main(): elif opt == "-b": bl31_elf=val elif opt == "-h": - print __doc__ + print(__doc__) sys.exit(2)
dtbs = args
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Mian Yousaf Kaukab yousaf.kaukab@suse.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
Mian,
Did you change anything or is this just a resend with the same content? I didn’t have a chance to review this yet, so wanted to make sure I work off the latest version...
Thanks, Philipp.
print >> file, '\t\t};' print >> file, ''print >> file, '\t\t\tentry = <0x%08x>;' % elf_entry
atf_cnt = i+1 append_fdt_node(fit_file, dtbs_file_name) print >> fit_file, '%s' % DT_IMAGES_NODE_ENDappend_atf_node(fit_file, i+1, paddr, elf_entry)
-- 2.11.0
On 06/08/2018 08:09 PM, Dr. Philipp Tomsich wrote:
Mian,
Its a resend with the same content. Just sending both patches together.
Thanks, Philipp.
Thanks, Yousaf
Hi Yousaf,
Could you have a look at this patch:
https://patchwork.ozlabs.org/patch/924244/
Hi Yousaf,
You patch looks good, but I don't know why the script always work for me,
and I don't met the abort, where do you get the BL31?
On Wed, Jun 13, 2018 at 4:45 AM, Kever Yang kever.yang@rock-chips.com wrote:
Hi Yousaf,
for me,
It looks similar to what I was seeing previously and haven't had a chance to get to the bottom of.
Peter
Thanks,
- Kever
On 06/13/2018 08:45 AM, Kever Yang wrote:
Hi Yousaf,
I am building it with the following command line: make -j4 CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 DEBUG=1 all Abort is 100% reproducible with ATF v1.4 and v1.5.
Thanks,
- Kever
BR, Yousaf
Philipp,
Can we get get a decision on this one, it fixes issues for me on Rockchips devices. While I'm sure a rewrite in C to reduce dependenciees is an option, this fix doesn't add any extra dependencies and I think is still a candidate for 2018.11
Peter On Fri, Jun 8, 2018 at 11:34 AM Mian Yousaf Kaukab yousaf.kaukab@suse.com wrote:
-- 2.11.0
participants (5)
Dr. Philipp Tomsich
Kever Yang
Mian Yousaf Kaukab
Peter Robinson
Philipp Tomsich
