[PATCH v2] rpi_4_defconfig: add missing CONFIG_ARCH_FIXUP_FDT_MEMORY
As discussed at https://lore.kernel.org/linux-arm-kernel/b726290c-1038-3771-5187-6ac370bc92c... the defconfig for rpi4 miss CONFIG_ARCH_FIXUP_FDT_MEMORY. Without it, booting with an initrd fail.
Signed-off-by: Corentin Labbe clabbe@baylibre.com --- Changes since v1: - added fix for rpi_4_32b_defconfig
configs/rpi_4_32b_defconfig | 2 +- configs/rpi_4_defconfig | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index 8d262d89b4..f2a975891c 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -7,7 +7,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_ARCH_FIXUP_FDT_MEMORY=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index 2a0cea4222..f1c8f5ef7d 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -7,7 +7,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_ARCH_FIXUP_FDT_MEMORY=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set
Changes since v1:
Any reason why you don't added rpi_arm64_defconfig?
Regards, Matthias
Changes since v1:
I didnt see rpi4 in its name so out of context of my changes. I believe it is a common defconfig for all rpis, in that case touching it need more testing. So I propose to apply the change for rpi4 which are tested now. And later I could try to test rpi_arm64_defconfig on rpi4 AND other rpis..
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Changes since v1:
Corentin Labbe
Jaehoon Chung
LABBE Corentin
Matthias Brugger
