[U-Boot] mtd partition &kernel
does the kernel know about different mtd partition from the boot loader?
How do I go about creating a new mtd partition say /var/logs.
I'm using a mini2440 board which has 4 mtd partition uboot uboot-env kernel rootfs
I want to add another one, how do I go about doing that?
TIA
Yes. But only If the kernel is compiled with support for parsing the 'mtdpart' boot argument [1] and the mtdparts argument is passed to the linux kernel from u-boot by adding $mtdparts to the bootargs u-boot environment variable. See for example, include/configs/imx31_phycore.h.
Once your system meets the requirements listed above, you can add another partition by adding its definition to the end of the mtdparts u-boot environment variable. The format of this variable is well documented [2].
Best Regards, Ben Gardiner
[1] http://www.mjmwired.net/kernel/Documentation/kernel-parameters.txt#1500 [2] http://www.denx.de/wiki/view/DULG/UBootCmdGroupFlash#Section_5.9.3.5.
--- Nanometrics Inc. http://www.nanometrics.ca
Ben Gardiner
Fundu
