[U-Boot] [PATCH v3 0/3] efi_loader: fix simple network protocol
We should not call eth_rx() before the network interface is initialized. The services of the simple network protocol should check the state of the network adapter.
Provide a correctly aligned transmit buffer not depending on CONFIG_EFI_LOADER_BOUNCE_BUFFER.
Correct the unit test.
Add and correct comments.
Without this patch i.mx6 system Wandboard Quad rev B1 fails to execute bootefi selftest.
--- v3: split the patch into a series v2: match EFI_ENTRY() and EFI_EXIT() in efi_network_timer_notify() update comments ---
Heinrich Schuchardt (3): efi_selftest: fix simple network protocol test efi_loader: correctly aligned transmit buffer efi_loader: fix simple network protocol
lib/efi_loader/efi_net.c | 415 +++++++++++++++++++++++----- lib/efi_selftest/efi_selftest_snp.c | 16 +- 2 files changed, 357 insertions(+), 74 deletions(-)
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3: split the patch into a series --- lib/efi_loader/efi_net.c | 32 +++++++++++++++++++++----------- 1 file changed, 21 insertions(+), 11 deletions(-)
diff --git a/lib/efi_loader/efi_net.c b/lib/efi_loader/efi_net.c index a64c603ed3..9987aba1b9 100644 --- a/lib/efi_loader/efi_net.c +++ b/lib/efi_loader/efi_net.c @@ -14,6 +14,8 @@ static const efi_guid_t efi_pxe_guid = EFI_PXE_GUID; static struct efi_pxe_packet *dhcp_ack; static bool new_rx_packet; static void *new_tx_packet; +static void *transmit_buffer; + /* * The notification function of this event is called in every timer cycle * to check if a new network packet has been received. @@ -198,13 +200,11 @@ static efi_status_t EFIAPI efi_net_transmit(struct efi_simple_network *this, return EFI_EXIT(EFI_INVALID_PARAMETER); }
-#ifdef CONFIG_EFI_LOADER_BOUNCE_BUFFER - /* Ethernet packets always fit, just bounce */ - memcpy(efi_bounce_buffer, buffer, buffer_size); - net_send_packet(efi_bounce_buffer, buffer_size); -#else - net_send_packet(buffer, buffer_size); -#endif + /* Ensure that the packet fits into the buffer */ + if (buffer_size > PKTSIZE_ALIGN) + return EFI_EXIT(EFI_INVALID_PARAMETER); + memcpy(transmit_buffer, buffer, buffer_size); + net_send_packet(transmit_buffer, buffer_size);
new_tx_packet = buffer;
@@ -325,10 +325,15 @@ efi_status_t efi_net_register(void)
/* We only expose the "active" network device, so one is enough */ netobj = calloc(1, sizeof(*netobj)); - if (!netobj) { - printf("ERROR: Out of memory\n"); - return EFI_OUT_OF_RESOURCES; - } + if (!netobj) + goto out_of_resources; + + /* Allocate an aligned transmit buffer */ + transmit_buffer = calloc(1, PKTSIZE_ALIGN + ARCH_DMA_MINALIGN); + if (!transmit_buffer) + goto out_of_resources; + transmit_buffer = (void *)ALIGN((uintptr_t)transmit_buffer, + ARCH_DMA_MINALIGN);
/* Hook net up to the device list */ efi_add_handle(&netobj->header); @@ -408,4 +413,9 @@ efi_status_t efi_net_register(void) failure_to_add_protocol: printf("ERROR: Failure to add protocol\n"); return r; +out_of_resources: + free(netobj); + /* free(transmit_buffer) not needed yet */ + printf("ERROR: Out of memory\n"); + return EFI_OUT_OF_RESOURCES; }
What problem does this patch fix? Please describe so in the patch header.
Alex
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3: split the patch into a series v2: match EFI_ENTRY() and EFI_EXIT() in efi_network_timer_notify() update comments --- lib/efi_loader/efi_net.c | 391 +++++++++++++++++++++++++++++++++------ 1 file changed, 332 insertions(+), 59 deletions(-)
diff --git a/lib/efi_loader/efi_net.c b/lib/efi_loader/efi_net.c index 9987aba1b9..c4b1e6e1d9 100644 --- a/lib/efi_loader/efi_net.c +++ b/lib/efi_loader/efi_net.c @@ -43,22 +43,68 @@ struct efi_net_obj { struct efi_pxe_mode pxe_mode; };
+/* + * efi_net_start() - start the network interface + * + * This function implements the Start service of the + * EFI_SIMPLE_NETWORK_PROTOCOL. See the Unified Extensible Firmware Interface + * (UEFI) specification for details. + * + * @this: pointer to the protocol instance + * Return: status code + */ static efi_status_t EFIAPI efi_net_start(struct efi_simple_network *this) { + efi_status_t ret = EFI_SUCCESS; + EFI_ENTRY("%p", this);
- return EFI_EXIT(EFI_SUCCESS); + /* Check parameters */ + if (!this) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + if (this->mode->state != EFI_NETWORK_STOPPED) + ret = EFI_ALREADY_STARTED; + else + this->mode->state = EFI_NETWORK_STARTED; +out: + return EFI_EXIT(ret); }
+/* + * efi_net_stop() - stop the network interface + * + * This function implements the Stop service of the + * EFI_SIMPLE_NETWORK_PROTOCOL. See the Unified Extensible Firmware Interface + * (UEFI) specification for details. + * + * @this: pointer to the protocol instance + * Return: status code + */ static efi_status_t EFIAPI efi_net_stop(struct efi_simple_network *this) { + efi_status_t ret = EFI_SUCCESS; + EFI_ENTRY("%p", this);
- return EFI_EXIT(EFI_SUCCESS); + /* Check parameters */ + if (!this) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + if (this->mode->state == EFI_NETWORK_STOPPED) + ret = EFI_NOT_STARTED; + else + this->mode->state = EFI_NETWORK_STOPPED; +out: + return EFI_EXIT(ret); }
/* - * Initialize network adapter and allocate transmit and receive buffers. + * efi_net_initialize() - initialize the network interface * * This function implements the Initialize service of the * EFI_SIMPLE_NETWORK_PROTOCOL. See the Unified Extensible Firmware Interface @@ -67,7 +113,7 @@ static efi_status_t EFIAPI efi_net_stop(struct efi_simple_network *this) * @this: pointer to the protocol instance * @extra_rx: extra receive buffer to be allocated * @extra_tx: extra transmit buffer to be allocated - * @return: status code + * Return: status code */ static efi_status_t EFIAPI efi_net_initialize(struct efi_simple_network *this, ulong extra_rx, ulong extra_tx) @@ -77,9 +123,10 @@ static efi_status_t EFIAPI efi_net_initialize(struct efi_simple_network *this,
EFI_ENTRY("%p, %lx, %lx", this, extra_rx, extra_tx);
+ /* Check parameters */ if (!this) { r = EFI_INVALID_PARAMETER; - goto error; + goto out; }
/* Setup packet buffers */ @@ -92,32 +139,83 @@ static efi_status_t EFIAPI efi_net_initialize(struct efi_simple_network *this, ret = eth_init(); if (ret < 0) { eth_halt(); + this->mode->state = EFI_NETWORK_STOPPED; r = EFI_DEVICE_ERROR; + goto out; + } else { + this->mode->state = EFI_NETWORK_INITIALIZED; } - -error: +out: return EFI_EXIT(r); }
+/* + * efi_net_reset() - reinitialize the network interface + * + * This function implements the Reset service of the + * EFI_SIMPLE_NETWORK_PROTOCOL. See the Unified Extensible Firmware Interface + * (UEFI) specification for details. + * + * @this: pointer to the protocol instance + * @extended_verification: execute exhaustive verification + * Return: status code + */ static efi_status_t EFIAPI efi_net_reset(struct efi_simple_network *this, int extended_verification) { EFI_ENTRY("%p, %x", this, extended_verification);
- return EFI_EXIT(EFI_SUCCESS); + return EFI_EXIT(EFI_CALL(efi_net_initialize(this, 0, 0))); }
+/* + * efi_net_shutdown() - shut down the network interface + * + * This function implements the Shutdown service of the + * EFI_SIMPLE_NETWORK_PROTOCOL. See the Unified Extensible Firmware Interface + * (UEFI) specification for details. + * + * @this: pointer to the protocol instance + * Return: status code + */ static efi_status_t EFIAPI efi_net_shutdown(struct efi_simple_network *this) { + efi_status_t ret = EFI_SUCCESS; + EFI_ENTRY("%p", this);
- return EFI_EXIT(EFI_SUCCESS); + /* Check parameters */ + if (!this) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + eth_halt(); + this->mode->state = EFI_NETWORK_STOPPED; + +out: + return EFI_EXIT(ret); }
-static efi_status_t EFIAPI efi_net_receive_filters( - struct efi_simple_network *this, u32 enable, u32 disable, - int reset_mcast_filter, ulong mcast_filter_count, - struct efi_mac_address *mcast_filter) +/* + * efi_net_receive_filters() - mange multicast receive filters + * + * This function implements the ReceiveFilters service of the + * EFI_SIMPLE_NETWORK_PROTOCOL. See the Unified Extensible Firmware Interface + * (UEFI) specification for details. + * + * @this: pointer to the protocol instance + * @enable: bit mask of receive filters to enable + * @disable: bit mask of receive filters to disable + * @reset_mcast_filter: true resets contents of the filters + * @mcast_filter_count: number of hardware MAC addresses in the new filters list + * @mcast_filter: list of new filters + * Return: status code + */ +static efi_status_t EFIAPI efi_net_receive_filters + (struct efi_simple_network *this, u32 enable, u32 disable, + int reset_mcast_filter, ulong mcast_filter_count, + struct efi_mac_address *mcast_filter) { EFI_ENTRY("%p, %x, %x, %x, %lx, %p", this, enable, disable, reset_mcast_filter, mcast_filter_count, mcast_filter); @@ -125,15 +223,40 @@ static efi_status_t EFIAPI efi_net_receive_filters( return EFI_EXIT(EFI_UNSUPPORTED); }
-static efi_status_t EFIAPI efi_net_station_address( - struct efi_simple_network *this, int reset, - struct efi_mac_address *new_mac) +/* + * efi_net_station_address() - set the hardware MAC address + * + * This function implements the StationAddress service of the + * EFI_SIMPLE_NETWORK_PROTOCOL. See the Unified Extensible Firmware Interface + * (UEFI) specification for details. + * + * @this: pointer to the protocol instance + * @reset: if true reset the address to default + * @new_mac: new MAC address + * Return: status code + */ +static efi_status_t EFIAPI efi_net_station_address + (struct efi_simple_network *this, int reset, + struct efi_mac_address *new_mac) { EFI_ENTRY("%p, %x, %p", this, reset, new_mac);
+/* + * efi_net_statistics() - reset or collect statistics of the network interface + * + * This function implements the Statistics service of the + * EFI_SIMPLE_NETWORK_PROTOCOL. See the Unified Extensible Firmware Interface + * (UEFI) specification for details. + * + * @this: pointer to the protocol instance + * @reset: if true, the statistics are reset + * @stat_size: size of the statistics table + * @stat_table: table to receive the statistics + * Return: status code + */ static efi_status_t EFIAPI efi_net_statistics(struct efi_simple_network *this, int reset, ulong *stat_size, void *stat_table) @@ -143,6 +266,19 @@ static efi_status_t EFIAPI efi_net_statistics(struct efi_simple_network *this, return EFI_EXIT(EFI_UNSUPPORTED); }
+/* + * efi_net_mcastiptomac() - translate multicast IP address to MAC address + * + * This function implements the Statistics service of the + * EFI_SIMPLE_NETWORK_PROTOCOL. See the Unified Extensible Firmware Interface + * (UEFI) specification for details. + * + * @this: pointer to the protocol instance + * @ipv6: true if the IP address is an IPv6 address + * @ip: IP address + * @mac: MAC address + * Return: status code + */ static efi_status_t EFIAPI efi_net_mcastiptomac(struct efi_simple_network *this, int ipv6, struct efi_ip_address *ip, @@ -153,6 +289,19 @@ static efi_status_t EFIAPI efi_net_mcastiptomac(struct efi_simple_network *this, return EFI_EXIT(EFI_INVALID_PARAMETER); }
+/** + * efi_net_nvdata() - read or write NVRAM + * + * This function implements the GetStatus service of the Simple Network + * Protocol. See the UEFI spec for details. + * + * @this: the instance of the Simple Network Protocol + * @readwrite: true for read, false for write + * @offset: offset in NVRAM + * @buffer_size: size of buffer + * @buffer: buffer + * Return: status code + */ static efi_status_t EFIAPI efi_net_nvdata(struct efi_simple_network *this, int read_write, ulong offset, ulong buffer_size, char *buffer) @@ -163,13 +312,42 @@ static efi_status_t EFIAPI efi_net_nvdata(struct efi_simple_network *this, return EFI_EXIT(EFI_UNSUPPORTED); }
+/** + * efi_net_get_status() - get interrupt status + * + * This function implements the GetStatus service of the Simple Network + * Protocol. See the UEFI spec for details. + * + * @this: the instance of the Simple Network Protocol + * @int_status: interface status + * @txbuf: transmission buffer + */ static efi_status_t EFIAPI efi_net_get_status(struct efi_simple_network *this, u32 *int_status, void **txbuf) { + efi_status_t ret = EFI_SUCCESS; + EFI_ENTRY("%p, %p, %p", this, int_status, txbuf);
efi_timer_check();
+ /* Check parameters */ + if (!this) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + switch (this->mode->state) { + case EFI_NETWORK_STOPPED: + ret = EFI_NOT_STARTED; + goto out; + case EFI_NETWORK_STARTED: + ret = EFI_DEVICE_ERROR; + goto out; + default: + break; + } + if (int_status) { /* We send packets synchronously, so nothing is outstanding */ *int_status = EFI_SIMPLE_NETWORK_TRANSMIT_INTERRUPT; @@ -180,63 +358,103 @@ static efi_status_t EFIAPI efi_net_get_status(struct efi_simple_network *this, *txbuf = new_tx_packet;
new_tx_packet = NULL; - - return EFI_EXIT(EFI_SUCCESS); +out: + return EFI_EXIT(ret); }
-static efi_status_t EFIAPI efi_net_transmit(struct efi_simple_network *this, - size_t header_size, size_t buffer_size, void *buffer, - struct efi_mac_address *src_addr, - struct efi_mac_address *dest_addr, u16 *protocol) +/** + * efi_net_transmit() - transmit a packet + * + * This function implements the Transmit service of the Simple Network Protocol. + * See the UEFI spec for details. + * + * @this: the instance of the Simple Network Protocol + * @header_size: size of the media header + * @buffer_size: size of the buffer to receive the packet + * @buffer: buffer to receive the packet + * @src_addr: source hardware MAC address + * @dest_addr: destination hardware MAC address + * @protocol: type of header to build + * Return: status code + */ +static efi_status_t EFIAPI efi_net_transmit + (struct efi_simple_network *this, size_t header_size, + size_t buffer_size, void *buffer, + struct efi_mac_address *src_addr, + struct efi_mac_address *dest_addr, u16 *protocol) { + efi_status_t ret = EFI_SUCCESS; + EFI_ENTRY("%p, %lu, %lu, %p, %p, %p, %p", this, (unsigned long)header_size, (unsigned long)buffer_size, buffer, src_addr, dest_addr, protocol);
efi_timer_check();
+ /* Check parameters */ + if (!this) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + /* We do not support jumbo packets */ + if (buffer_size > PKTSIZE_ALIGN) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + if (header_size) { - /* We would need to create the header if header_size != 0 */ - return EFI_EXIT(EFI_INVALID_PARAMETER); + /* + * TODO: We would need to create the header + * if header_size != 0 + */ + ret = EFI_INVALID_PARAMETER; + goto out; + } + + switch (this->mode->state) { + case EFI_NETWORK_STOPPED: + ret = EFI_NOT_STARTED; + goto out; + case EFI_NETWORK_STARTED: + ret = EFI_DEVICE_ERROR; + goto out; + default: + break; }
- /* Ensure that the packet fits into the buffer */ - if (buffer_size > PKTSIZE_ALIGN) - return EFI_EXIT(EFI_INVALID_PARAMETER); + /* Ethernet packets always fit, just bounce */ memcpy(transmit_buffer, buffer, buffer_size); net_send_packet(transmit_buffer, buffer_size);
- return EFI_EXIT(EFI_SUCCESS); -} - -static void efi_net_push(void *pkt, int len) -{ - new_rx_packet = true; - wait_for_packet->is_signaled = true; +out: + return EFI_EXIT(ret); }
-/* - * Receive a packet from a network interface. +/** + * efi_net_receive() - receive a packet from a network interface * * This function implements the Receive service of the Simple Network Protocol. * See the UEFI spec for details. * - * @this the instance of the Simple Network Protocol - * @header_size size of the media header - * @buffer_size size of the buffer to receive the packet - * @buffer buffer to receive the packet - * @src_addr source MAC address - * @dest_addr destination MAC address - * @protocol protocol - * @return status code + * @this: the instance of the Simple Network Protocol + * @header_size: size of the media header + * @buffer_size: size of the buffer to receive the packet + * @buffer: buffer to receive the packet + * @src_addr: source MAC address + * @dest_addr: destination MAC address + * @protocol: protocol + * Return: status code */ -static efi_status_t EFIAPI efi_net_receive(struct efi_simple_network *this, - size_t *header_size, size_t *buffer_size, void *buffer, - struct efi_mac_address *src_addr, - struct efi_mac_address *dest_addr, u16 *protocol) +static efi_status_t EFIAPI efi_net_receive + (struct efi_simple_network *this, size_t *header_size, + size_t *buffer_size, void *buffer, + struct efi_mac_address *src_addr, + struct efi_mac_address *dest_addr, u16 *protocol) { + efi_status_t ret = EFI_SUCCESS; struct ethernet_hdr *eth_hdr; size_t hdr_size = sizeof(struct ethernet_hdr); u16 protlen; @@ -244,14 +462,35 @@ static efi_status_t EFIAPI efi_net_receive(struct efi_simple_network *this, EFI_ENTRY("%p, %p, %p, %p, %p, %p, %p", this, header_size, buffer_size, buffer, src_addr, dest_addr, protocol);
+ /* Execute events */ efi_timer_check();
- if (!new_rx_packet) - return EFI_EXIT(EFI_NOT_READY); + /* Check parameters */ + if (!this) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + switch (this->mode->state) { + case EFI_NETWORK_STOPPED: + ret = EFI_NOT_STARTED; + goto out; + case EFI_NETWORK_STARTED: + ret = EFI_DEVICE_ERROR; + goto out; + default: + break; + } + + if (!new_rx_packet) { + ret = EFI_NOT_READY; + goto out; + } /* Check that we at least received an Ethernet header */ if (net_rx_packet_len < sizeof(struct ethernet_hdr)) { new_rx_packet = false; - return EFI_EXIT(EFI_NOT_READY); + ret = EFI_NOT_READY; + goto out; } /* Fill export parameters */ eth_hdr = (struct ethernet_hdr *)net_rx_packet; @@ -271,16 +510,22 @@ static efi_status_t EFIAPI efi_net_receive(struct efi_simple_network *this, if (*buffer_size < net_rx_packet_len) { /* Packet doesn't fit, try again with bigger buffer */ *buffer_size = net_rx_packet_len; - return EFI_EXIT(EFI_BUFFER_TOO_SMALL); + ret = EFI_BUFFER_TOO_SMALL; + goto out; } /* Copy packet */ memcpy(buffer, net_rx_packet, net_rx_packet_len); *buffer_size = net_rx_packet_len; new_rx_packet = false; - - return EFI_EXIT(EFI_SUCCESS); +out: + return EFI_EXIT(ret); }
+/** + * efi_net_set_dhcp_ack() - take note of a selected DHCP IP address + * + * This function is called by dhcp_handler(). + */ void efi_net_set_dhcp_ack(void *pkt, int len) { int maxsize = sizeof(*dhcp_ack); @@ -291,8 +536,22 @@ void efi_net_set_dhcp_ack(void *pkt, int len) memcpy(dhcp_ack, pkt, min(len, maxsize)); }
-/* - * Check if a new network packet has been received. +/** + * efi_net_push() - callback for received network packet + * + * This function is called when a network packet is received by eth_rx(). + * + * @pkt: network packet + * @len: length + */ +static void efi_net_push(void *pkt, int len) +{ + new_rx_packet = true; + wait_for_packet->is_signaled = true; +} + +/** + * efi_network_timer_notify() - check if a new network packet has been received * * This notification function is called in every timer cycle. * @@ -302,20 +561,34 @@ void efi_net_set_dhcp_ack(void *pkt, int len) static void EFIAPI efi_network_timer_notify(struct efi_event *event, void *context) { + struct efi_simple_network *this = (struct efi_simple_network *)context; + EFI_ENTRY("%p, %p", event, context);
+ /* + * Some network drivers do not support calling eth_rx() before + * initialization. + */ + if (!this || this->mode->state != EFI_NETWORK_INITIALIZED) + goto out; + if (!new_rx_packet) { push_packet = efi_net_push; eth_rx(); push_packet = NULL; } +out: EFI_EXIT(EFI_SUCCESS); }
-/* This gets called from do_bootefi_exec(). */ +/** + * efi_net_register() - register the simple network protocol + * + * This gets called from do_bootefi_exec(). + */ efi_status_t efi_net_register(void) { - struct efi_net_obj *netobj; + struct efi_net_obj *netobj = NULL; efi_status_t r;
if (!eth_get_dev()) { @@ -396,7 +669,7 @@ efi_status_t efi_net_register(void) * iPXE is running at TPL_CALLBACK most of the time. Use a higher TPL. */ r = efi_create_event(EVT_TIMER | EVT_NOTIFY_SIGNAL, TPL_NOTIFY, - efi_network_timer_notify, NULL, NULL, + efi_network_timer_notify, &netobj->net, NULL, &network_timer_event); if (r != EFI_SUCCESS) { printf("ERROR: Failed to register network event\n");
Looks reasonable to me
Reviewed-by: Alexander Graf agraf@suse.de
Alex
To use the simple network protocol we have to call the start service first and the initialize service second.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3: split the patch into a series --- lib/efi_selftest/efi_selftest_snp.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/lib/efi_selftest/efi_selftest_snp.c b/lib/efi_selftest/efi_selftest_snp.c index 09bd53da82..e10a34ba64 100644 --- a/lib/efi_selftest/efi_selftest_snp.c +++ b/lib/efi_selftest/efi_selftest_snp.c @@ -103,7 +103,7 @@ static efi_status_t send_dhcp_discover(void) struct dhcp p = {};
/* - * Fill ethernet header + * Fill Ethernet header */ boottime->copy_mem(p.eth_hdr.et_dest, (void *)BROADCAST_MAC, ARP_HLEN); boottime->copy_mem(p.eth_hdr.et_src, &net->mode->current_address, @@ -229,19 +229,19 @@ static int setup(const efi_handle_t handle, return EFI_ST_FAILURE; } /* - * Initialize network adapter. + * Start network adapter. */ - ret = net->initialize(net, 0, 0); - if (ret != EFI_SUCCESS) { - efi_st_error("Failed to initialize network adapter\n"); + ret = net->start(net); + if (ret != EFI_SUCCESS && ret != EFI_ALREADY_STARTED) { + efi_st_error("Failed to start network adapter\n"); return EFI_ST_FAILURE; } /* - * Start network adapter. + * Initialize network adapter. */ - ret = net->start(net); + ret = net->initialize(net, 0, 0); if (ret != EFI_SUCCESS) { - efi_st_error("Failed to start network adapter\n"); + efi_st_error("Failed to initialize network adapter\n"); return EFI_ST_FAILURE; } return EFI_ST_SUCCESS;
Alexander Graf
