[U-Boot] [PATCH v4] ppc4xx: Rename compactcenter to intip
Signed-off-by: Dirk Eibach eibach@gdsys.de --- Changes since v1: - also changed config name
Changes since v2: - also changed file- and directory-names
Changes since v3: - used format-patch -M -C to detect renames properly
MAINTAINERS | 2 +- MAKEALL | 2 +- Makefile | 16 ++++++++-------- board/gdsys/{compactcenter => intip}/Makefile | 0 board/gdsys/{compactcenter => intip}/chip_config.c | 0 board/gdsys/{compactcenter => intip}/config.mk | 0 board/gdsys/{compactcenter => intip}/init.S | 0 .../compactcenter.c => intip/intip.c} | 2 +- board/gdsys/{compactcenter => intip}/u-boot.lds | 2 +- include/configs/{compactcenter.h => intip.h} | 8 ++++---- 10 files changed, 16 insertions(+), 16 deletions(-) rename board/gdsys/{compactcenter => intip}/Makefile (100%) rename board/gdsys/{compactcenter => intip}/chip_config.c (100%) rename board/gdsys/{compactcenter => intip}/config.mk (100%) rename board/gdsys/{compactcenter => intip}/init.S (100%) rename board/gdsys/{compactcenter/compactcenter.c => intip/intip.c} (99%) rename board/gdsys/{compactcenter => intip}/u-boot.lds (98%) rename include/configs/{compactcenter.h => intip.h} (98%)
diff --git a/MAINTAINERS b/MAINTAINERS index e9db278..e0d4786 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -141,10 +141,10 @@ Jon Diekema jon.diekema@smiths-aerospace.com
- compactcenter PPC460EX devconcenter PPC460EX dlvision PPC405EP gdppc440etx PPC440EP/GR + intip PPC460EX neo PPC405EP
Dave Ellis DGE@sixnetio.com diff --git a/MAKEALL b/MAKEALL index f0ed8ea..b3d35ac 100755 --- a/MAKEALL +++ b/MAKEALL @@ -185,7 +185,6 @@ LIST_4xx=" \ canyonlands \ canyonlands_nand \ CMS700 \ - compactcenter \ CPCI2DP \ CPCI405 \ CPCI4052 \ @@ -214,6 +213,7 @@ LIST_4xx=" \ hcu5 \ HH405 \ HUB405 \ + intip \ JSE \ KAREF \ katmai \ diff --git a/Makefile b/Makefile index 0449a5b..bb06d86 100644 --- a/Makefile +++ b/Makefile @@ -1304,14 +1304,6 @@ CATcenter_33_config: unconfig CMS700_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx cms700 esd
-# Compact-Center & DevCon-Center use different U-Boot images -compactcenter_config \ -devconcenter_config: unconfig - @mkdir -p $(obj)include - @echo "#define CONFIG_$$(echo $(subst ,,$(@:_config=)) | \ - tr '[:lower:]' '[:upper:]')" >$(obj)include/config.h - @$(MKCONFIG) -n $@ -a compactcenter ppc ppc4xx compactcenter gdsys - CPCI2DP_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx cpci2dp esd
@@ -1396,6 +1388,14 @@ HH405_config: unconfig HUB405_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx hub405 esd
+# Compact-Center(codename intip) & DevCon-Center use different U-Boot images +intip_config \ +devconcenter_config: unconfig + @mkdir -p $(obj)include + @echo "#define CONFIG_$$(echo $(subst ,,$(@:_config=)) | \ + tr '[:lower:]' '[:upper:]')" >$(obj)include/config.h + @$(MKCONFIG) -n $@ -a intip ppc ppc4xx intip gdsys + JSE_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx jse
diff --git a/board/gdsys/compactcenter/Makefile b/board/gdsys/intip/Makefile similarity index 100% rename from board/gdsys/compactcenter/Makefile rename to board/gdsys/intip/Makefile diff --git a/board/gdsys/compactcenter/chip_config.c b/board/gdsys/intip/chip_config.c similarity index 100% rename from board/gdsys/compactcenter/chip_config.c rename to board/gdsys/intip/chip_config.c diff --git a/board/gdsys/compactcenter/config.mk b/board/gdsys/intip/config.mk similarity index 100% rename from board/gdsys/compactcenter/config.mk rename to board/gdsys/intip/config.mk diff --git a/board/gdsys/compactcenter/init.S b/board/gdsys/intip/init.S similarity index 100% rename from board/gdsys/compactcenter/init.S rename to board/gdsys/intip/init.S diff --git a/board/gdsys/compactcenter/compactcenter.c b/board/gdsys/intip/intip.c similarity index 99% rename from board/gdsys/compactcenter/compactcenter.c rename to board/gdsys/intip/intip.c index f448ef9..e929c8b 100644 --- a/board/gdsys/compactcenter/compactcenter.c +++ b/board/gdsys/intip/intip.c @@ -129,7 +129,7 @@ int checkboard(void) #ifdef CONFIG_DEVCONCENTER printf("Board: DevCon-Center"); #else - printf("Board: CompactCenter"); + printf("Board: Intip"); #endif
if (s != NULL) { diff --git a/board/gdsys/compactcenter/u-boot.lds b/board/gdsys/intip/u-boot.lds similarity index 98% rename from board/gdsys/compactcenter/u-boot.lds rename to board/gdsys/intip/u-boot.lds index 0c95d5c..c1cbd1c 100644 --- a/board/gdsys/compactcenter/u-boot.lds +++ b/board/gdsys/intip/u-boot.lds @@ -66,7 +66,7 @@ SECTIONS /* the sector layout of our flash chips! XXX FIXME XXX */
cpu/ppc4xx/start.o (.text) - board/gdsys/compactcenter/init.o (.text) + board/gdsys/intip/init.o (.text)
*(.text) *(.fixup) diff --git a/include/configs/compactcenter.h b/include/configs/intip.h similarity index 98% rename from include/configs/compactcenter.h rename to include/configs/intip.h index f8a1bbb..4f7bc7e 100644 --- a/include/configs/compactcenter.h +++ b/include/configs/intip.h @@ -23,7 +23,7 @@ */
/* - * compactcenter.h - configuration for CompactCenter (460EX) + * intip.h - configuration for CompactCenter aka intip (460EX) and DevCon-Center */ #ifndef __CONFIG_H #define __CONFIG_H @@ -32,15 +32,15 @@ * High Level Configuration Options */ /* - * This config file is used for CompactCenter and DevCon-Center + * This config file is used for CompactCenter(codename intip) and DevCon-Center */ #define CONFIG_460EX 1 /* Specific PPC460EX */ #ifdef CONFIG_DEVCONCENTER #define CONFIG_HOSTNAME devconcenter #define CONFIG_IDENT_STRING " devconcenter 0.02" #else -#define CONFIG_HOSTNAME compactcenter -#define CONFIG_IDENT_STRING " compactcenter 0.02" +#define CONFIG_HOSTNAME intip +#define CONFIG_IDENT_STRING " intip 0.02" #endif #define CONFIG_440 1 #define CONFIG_4xx 1 /* ... PPC4xx family */
Applied to u-boot-ppc4xx. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Dirk Eibach
Stefan Roese
