[U-Boot] [PATCH v1 0/5] SHEEVAPLUG : REFRESH 201412
This serie of patch prepare SHEEVAPLUG for latest kernels
Gérald Kerma (5): SHEEVAPLUG : FIX typo SHEEVAPLUG : FIX multiple defines SHEEVAPLUG : ADD generic board define SHEEVAPLUG : ADD CONFIG_CMD_FAT SHEEVAPLUG : ADD FDT support
include/configs/sheevaplug.h | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
Signed-off-by: Gérald Kerma drEagle@doukki.net --- include/configs/sheevaplug.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 71be823..829c57a 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -49,6 +49,7 @@ #define CONFIG_CMD_NAND #define CONFIG_CMD_PING #define CONFIG_CMD_USB + /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros
Signed-off-by: Gérald Kerma drEagle@doukki.net --- include/configs/sheevaplug.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 829c57a..393fdd4 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -140,6 +140,5 @@ #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_MTD_PARTITIONS #define CONFIG_CMD_MTDPARTS -#define CONFIG_LZO
#endif /* _CONFIG_SHEEVAPLUG_H */
Signed-off-by: Gérald Kerma drEagle@doukki.net --- include/configs/sheevaplug.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 393fdd4..589655a 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -10,6 +10,8 @@ #ifndef _CONFIG_SHEEVAPLUG_H #define _CONFIG_SHEEVAPLUG_H
+#define CONFIG_SYS_GENERIC_BOARD + /* * Version number information */
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 589655a..77e8d17 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -51,6 +51,7 @@ #define CONFIG_CMD_NAND #define CONFIG_CMD_PING #define CONFIG_CMD_USB +#define CONFIG_CMD_FAT
LIBFDT feature is required to support new kernel
Signed-off-by: Gérald Kerma drEagle@doukki.net --- include/configs/sheevaplug.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 77e8d17..0f523c5 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -33,6 +33,11 @@ #define CONFIG_LZO
/* + * Enable device tree support + */ +#define CONFIG_OF_LIBFDT + +/* * Miscellaneous configurable options */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */
Prepare ENV settings for sheevaplugs to be OpenWRT ready.
+----------+ | UBOOT | >> 896 Kb (7x128) = uboot +----------+ | ENV | >> 128 Kb = uboot_env +----------+ | IMAGES | >> 23 Mb @ 1 Mb = image -> UIMAGE+UINITRD+FDT +----------+ | ROOT(FS) | >> 488 Mb @ 24 Mb = root -> rootfs (ubifs) +----------+
With (CC) TRUNK OpenWRT build (QUICK HOWTO) :
<INTERRUPT> ### INITIALIZE Marvell>> nand erase.part root ### PREPARE Marvell>> ubi part root Marvell>> ubi remove rootfs Marvell>> ubi create rootfs ### UPGRADE Marvell>> usb reset Marvell>> fatload usb 0:1 0x800000 sheevaplug/openwrt/openwrt-kirkwood-sheevaplug-rootfs.ubifs Marvell>> ubi write 0x800000 rootfs ${filesize} Marvell>> reset
Changes in v2: - merge patch
Changes in v1: - review typo - define MTDPARTS for UBIFS
Gérald Kerma (6): SHEEVAPLUG : FIX typo SHEEVAPLUG : FIX multiple defines SHEEVAPLUG : ADD generic board define SHEEVAPLUG : ADD CONFIG_CMD_FAT SHEEVAPLUG : ADD FDT support SHEEVAPLUG : REDEFINE MTDPARTS
include/configs/sheevaplug.h | 50 +++++++++++++++++++++++++++++--------------- 1 file changed, 33 insertions(+), 17 deletions(-)
<INTERRUPT> Marvell>> nand erase.part root Marvell>> ubi part root Marvell>> ubi remove rootfs Marvell>> ubi create rootfs Marvell>> usb reset Marvell>> fatload usb 0:1 0x800000 sheevaplug/openwrt/openwrt-kirkwood-sheevaplug-rootfs.ubifs Marvell>> ubi write 0x800000 rootfs ${filesize} Marvell>> reset
Signed-off-by: Gérald Kerma drEagle@doukki.net --- include/configs/sheevaplug.h | 40 ++++++++++++++++++++++++---------------- 1 file changed, 24 insertions(+), 16 deletions(-)
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 0f523c5..dc51a4a 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -78,26 +78,34 @@ * it has to be rounded to sector size */ #define CONFIG_ENV_SIZE 0x20000 /* 128k */ -#define CONFIG_ENV_ADDR 0x80000 -#define CONFIG_ENV_OFFSET 0x80000 /* env starts here */ +#define CONFIG_ENV_OFFSET 0xE0000 /* env starts here */
/* * Default environment variables */ -#define CONFIG_BOOTCOMMAND "${x_bootcmd_kernel}; " \ - "setenv bootargs ${x_bootargs} ${x_bootargs_root}; " \ - "${x_bootcmd_usb}; bootm 0x6400000;" - -#define CONFIG_MTDPARTS \ - "mtdparts=orion_nand:512K(uboot)," \ - "512K(env),1M(script),6M(kernel)," \ - "12M(ramdisk),4M(spare),-(rootfs)" - -#define CONFIG_EXTRA_ENV_SETTINGS "x_bootargs=console" \ - "=ttyS0,115200 mtdparts="CONFIG_MTDPARTS \ - "x_bootcmd_kernel=nand read 0x6400000 0x100000 0x300000\0" \ - "x_bootcmd_usb=usb start\0" \ - "x_bootargs_root=root=/dev/mtdblock3 rw rootfstype=jffs2\0" +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs ${console} ${mtdparts} ${bootargs_root}; " \ + "ubi part root; " \ + "ubifsmount ubi:rootfs; " \ + "ubifsload 0x800000 ${kernel}; " \ + "ubifsload 0x700000 ${fdt}; " \ + "ubifsumount; " \ + "fdt addr 0x700000; fdt resize; fdt chosen; " \ + "bootz 0x800000 - 0x700000" + +#define CONFIG_MTDPARTS \ + "mtdparts=orion_nand:" \ + "896K(uboot),128K(uboot_env)," \ + "23M@1M(image)," \ + "-@24M(root)\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=console=ttyS0,115200\0" \ + "mtdids=nand0=orion_nand\0" \ + "mtdparts="CONFIG_MTDPARTS \ + "kernel=/boot/zImage\0" \ + "fdt=/boot/sheevaplug.dtb\0" \ + "bootargs_root=ubi.mtd=3 root=ubi0:rootfs rootfstype=ubifs rw\0"
#define MTDIDS_DEFAULT "nand0=orion_nand"
+----------+ | UBOOT | >> 896 Kb (7x128) = uboot +----------+ | ENV | >> 128 Kb = uboot_env +----------+ | ROOT(FS) | >> 511 Mb @ 1 Mb = root -> rootfs (ubifs) +----------+
include/configs/sheevaplug.h | 49 +++++++++++++++++++++++++++++--------------- 1 file changed, 32 insertions(+), 17 deletions(-)
Changes in v3 - Supress image partition (unused)
Change in v2 - Define new NAND partition mapping
Signed-off-by: Gérald Kerma drEagle@doukki.net --- include/configs/sheevaplug.h | 39 +++++++++++++++++++++++---------------- 1 file changed, 23 insertions(+), 16 deletions(-)
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 0f523c5..a1ce821 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -78,26 +78,33 @@ * it has to be rounded to sector size */ #define CONFIG_ENV_SIZE 0x20000 /* 128k */ -#define CONFIG_ENV_ADDR 0x80000 -#define CONFIG_ENV_OFFSET 0x80000 /* env starts here */ +#define CONFIG_ENV_OFFSET 0xE0000 /* env starts here */
/* * Default environment variables */ -#define CONFIG_BOOTCOMMAND "${x_bootcmd_kernel}; " \ - "setenv bootargs ${x_bootargs} ${x_bootargs_root}; " \ - "${x_bootcmd_usb}; bootm 0x6400000;" - -#define CONFIG_MTDPARTS \ - "mtdparts=orion_nand:512K(uboot)," \ - "512K(env),1M(script),6M(kernel)," \ - "12M(ramdisk),4M(spare),-(rootfs)" - -#define CONFIG_EXTRA_ENV_SETTINGS "x_bootargs=console" \ - "=ttyS0,115200 mtdparts="CONFIG_MTDPARTS \ - "x_bootcmd_kernel=nand read 0x6400000 0x100000 0x300000\0" \ - "x_bootcmd_usb=usb start\0" \ - "x_bootargs_root=root=/dev/mtdblock3 rw rootfstype=jffs2\0" +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs ${console} ${mtdparts} ${bootargs_root}; " \ + "ubi part root; " \ + "ubifsmount ubi:rootfs; " \ + "ubifsload 0x800000 ${kernel}; " \ + "ubifsload 0x700000 ${fdt}; " \ + "ubifsumount; " \ + "fdt addr 0x700000; fdt resize; fdt chosen; " \ + "bootz 0x800000 - 0x700000" + +#define CONFIG_MTDPARTS \ + "mtdparts=orion_nand:" \ + "896K(uboot),128K(uboot_env)," \ + "-@1M(root)\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=console=ttyS0,115200\0" \ + "mtdids=nand0=orion_nand\0" \ + "mtdparts="CONFIG_MTDPARTS \ + "kernel=/boot/zImage\0" \ + "fdt=/boot/sheevaplug.dtb\0" \ + "bootargs_root=ubi.mtd=2 root=ubi0:rootfs rootfstype=ubifs rw\0"
-----Original Message----- From: Gérald Kerma [mailto:drEagle@doukki.net] Sent: 17 December 2014 19:33 To: u-boot@lists.denx.de; Prafulla Wadaskar Cc: albert.u.boot@aribaud.net; luka@openwrt.org; Gérald Kerma Subject: [PATCH v3 0/6] SHEEVAPLUG : REFRESH 201412
<INTERRUPT> Marvell>> nand erase.part root Marvell>> ubi part root Marvell>> ubi remove rootfs Marvell>> ubi create rootfs Marvell>> usb reset Marvell>> fatload usb 0:1 0x800000 sheevaplug/openwrt/openwrt-kirkwood-sheevaplug- rootfs.ubifs Marvell>> ubi write 0x800000 rootfs ${filesize} Marvell>> reset
Is this final one to be pulled, or you are planning more changes? :-)
Regards... Prafulla . . .
Hi Prafulla, I think this one is good.
Regards, Gérald
Hi Prafulla,
Have you review these patchs ? Have you any comments or suggestions ?
Regards Gérald
-----Original Message----- From: drEagle [mailto:dreagle@doukki.net] Sent: 23 December 2014 17:14 To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; luka@openwrt.org Subject: Re: [U-Boot] [PATCH v3 0/6] SHEEVAPLUG : REFRESH 201412
Hi Prafulla,
Nope... ready to get pulled.
Gérald
more changes? :-)
Regards Gérald
Hi Prafulla,
Hi Prafulla,
Any news of this patch ?
Regards, Gérald
Gérald
more changes? :-)
Regards Gérald
drEagle
Gérald Kerma
Prafulla Wadaskar
