[U-Boot] Make "usb start" only start / scan usb once ?
Currently we've this magic in include/config_distro_bootcmd.h to avoid scanning the usb bus multiple times.
And it does not work when also using an usb keyboard because then the preboot command has already scanned the bus, so we're still scanning it twice.
While discussing my latest attempt at fixing this:
http://patchwork.ozlabs.org/patch/413394/ http://patchwork.ozlabs.org/patch/413395/
With Ian, Ian said why not simply make "usb start" keep track of if it already has started things, and then we can remove all the magic for it from include/config_distro_bootcmd.h and just call it unconditionally.
This would also cause "usb start" and "usb reset" to actually do something different, where as currently they are 100% the same.
I must say I like this idea, the only downside is, that it could be seen as a break of the u-boot cmdline API, one could easily argue it is not, because usb will be started by "usb start" if necessary, and people can still force a rescan with "usb reset".
So any input on this, specifically would a patch-set to make "usb start" start usb only once (per boot) be acceptable ?
Regards,
Hans
On Wednesday, November 26, 2014 at 01:44:23 PM, Hans de Goede wrote:
Hello Hans,
It just makes a lot of sense, so yes. You're right it'd break the command like API and it might be a surprise to some, but you're also right that the current "way of things" is confusing and possibly even wrong.
Apologies I got back to you so late.
Best regards, Marek Vasut
Hans de Goede
