[U-Boot] [PATCH] usb: ehci-mx6: allow board_ehci_hcd_init to fail
There could be runtime determined board specific reason why a EHCI initialization fails (e.g. ENODEV if a Port is not available). In this case, properly return the error code. While at it, that function (board_ehci_hcd_init) has actually two documentation blocks... Use the correct function name for the documentation block of board_usb_phy_mode.
Signed-off-by: Stefan Agner stefan@agner.ch --- drivers/usb/host/ehci-mx6.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index a981b50..bb48d0d 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -254,7 +254,7 @@ static void usb_oc_config(int index) }
/** - * board_ehci_hcd_init - override usb phy mode + * board_usb_phy_mode - override usb phy mode * @port: usb host/otg port * * Target board specific, override usb_phy_mode. @@ -310,6 +310,7 @@ int ehci_hcd_init(int index, enum usb_init_type init, #endif struct usb_ehci *ehci = (struct usb_ehci *)(USB_BASE_ADDR + (controller_spacing * index)); + int ret;
if (index > 3) return -EINVAL; @@ -317,7 +318,9 @@ int ehci_hcd_init(int index, enum usb_init_type init, mdelay(1);
/* Do board specific initialization */ - board_ehci_hcd_init(index); + ret = board_ehci_hcd_init(index); + if (ret) + return ret;
usb_power_config(index); usb_oc_config(index);
- board_ehci_hcd_init - override usb phy mode
- board_usb_phy_mode - override usb phy mode
- @port: usb host/otg port
- Target board specific, override usb_phy_mode.
int ret;
- ret = board_ehci_hcd_init(index);
- if (ret)
return ret;
Shouldn't this disable the OH3 clock , which were enabled a few lines above?
Otherwise this is nice, thanks.
int ret;
- if (ret)
return ret;
Hm, not sure, the clock does not take a controller index... I guess if the second instance is returning an error, that would disable the clock also for the first controller...
-- Stefan
int ret;
- if (ret)
return ret;
Siiiiiiigh! All right, that sucks and we absolutely have no time for reworking the whole clock framework on imx for this release. You want this stuff in for this release, right ?
Best regards, Marek Vasut
int ret;
- if (ret)
return ret;
Wasn't that urgent as the board which will use this is not upstream yet anyway... But still, nice to have it in.
Btw, I really like the new 2 month release cycle.
-- Stefan
int ret;
- if (ret)
return ret;
Heh, tell that to Tom :)
-- Stefan
Applied, thanks.
Stefan Agner
