[PATCH v4 1/2] ARM: dts: rk3588-rock-5b-u-boot: add bootph-all to pinctrl for sdmmc
To be able to initialize the pinctrl correctly at SPL level and read u-boot proper from SD-Card, the pinctrl must be initialized.
Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- Changes in v4: - rebased on latest master: This is also on top of the USB 2.0 series ! Changes in v3: - change to bootph-all props.
Changes in v2: - add u-boot,dm-spl to pull up nodes, to also setup the pull control correctly. Also, in the loop that initializes multiple pins, only the first will be muxed as the loop will break when the pull up node is not found.
arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 26 +++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index 53d029c60e8f..e9fcb7b92eb3 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -31,6 +31,8 @@ };
&pinctrl { + bootph-all; + usb { vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; @@ -38,11 +40,35 @@ }; };
+&pcfg_pull_up_drv_level_2 { + bootph-all; +}; + +&pcfg_pull_up { + bootph-all; +}; + &sdmmc { bus-width = <4>; status = "okay"; };
+&sdmmc_bus4 { + bootph-all; +}; + +&sdmmc_clk { + bootph-all; +}; + +&sdmmc_cmd { + bootph-all; +}; + +&sdmmc_det { + bootph-all; +}; + &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v;
Add pinctrl driver in SPL. Do not remove pinctrl properties for SPL dtb.
Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- Changes in v4: - rebased on master: Warning ! This is rebased on top of the USB 2.0 series ! Changes in v2,v3: - no change
configs/rock5b-rk3588_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index 8a3d356f729e..95271c312c51 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -47,7 +47,7 @@ CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y @@ -65,6 +65,7 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_SPL_PINCTRL=y CONFIG_REGULATOR_PWM=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_ROCKCHIP=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes in v4:
Changes in v2,v3:
no change
Thanks, - Kever
Changes in v4:
Changes in v3:
Changes in v2:
&pinctrl {
- bootph-all;
- usb { vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
- bootph-all;
+&pcfg_pull_up {
- bootph-all;
- &sdmmc { bus-width = <4>; status = "okay"; };
+&sdmmc_bus4 {
- bootph-all;
+&sdmmc_clk {
- bootph-all;
+&sdmmc_cmd {
- bootph-all;
+&sdmmc_det {
- bootph-all;
- &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v;
Eugen Hristev
Kever Yang
