[PATCH v2 0/3] support separate asm-offsets.h for SPL and TPL
Bin Meng asked me how to generate correct asm-offsets headers for SPL/TPL.
1/3: fix a bug that I just happened to find when touching this line 2/3: cherry-pick some Kbuild changes. This is a good resync regardless of 3/3 3/3: change as Bin Meng requested. This complicates the build process a bit more, but if we want this, just go ahead.
Changes in v2: - Check-pick two more while I am here - Rebase on the mainline
Masahiro Yamada (3): kbuild: add FORCE to dependency of $(obj)/dts/dt-platdata.o kbuild: cherry-pick kbuild changes from Linux kbuild: SPL/TPL: generate separate asm-offsets.h for SPL and TPL
Kbuild | 49 +++++------------------------------------- Makefile | 3 +-- scripts/Kbuild.include | 15 +++++++------ scripts/Makefile.build | 18 +++++----------- scripts/Makefile.host | 12 ----------- scripts/Makefile.lib | 42 ++++++++++++++++++++++++++++-------- scripts/Makefile.spl | 13 ++++++++--- 7 files changed, 62 insertions(+), 90 deletions(-)
if_changed must have FORCE as a prerequisite.
Add $(obj)/dts/dt-platdata.o to 'targets' so that the corresponding .cmd file is included.
Signed-off-by: Masahiro Yamada masahiroy@kernel.org ---
Changes in v2: None
scripts/Makefile.spl | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 5384f21278..4c2c0567c5 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -307,10 +307,11 @@ quiet_cmd_dtoch = DTOC H $@ cmd_dtoch = $(pythonpath) $(srctree)/tools/dtoc/dtoc -d $(obj)/$(SPL_BIN).dtb -o $@ struct
quiet_cmd_plat = PLAT $@ -cmd_plat = $(CC) $(c_flags) -c $< -o $@ +cmd_plat = $(CC) $(c_flags) -c $< -o $(filter-out $(PHONY),$@)
+targets += $(obj)/dts/dt-platdata.o $(obj)/dts/dt-platdata.o: $(obj)/dts/dt-platdata.c \ - include/generated/dt-structs-gen.h + include/generated/dt-structs-gen.h FORCE $(call if_changed,plat)
PHONY += dts_dir
b42841b7bb62 kbuild: Get rid of KBUILD_STR 2aedcd098a94 kbuild: suppress annoying "... is up to date." message 9c8fa9bc08f6 kbuild: fix if_change and friends to consider argument order ebf003f0cfb3 kbuild: Consolidate header generation from ASM offset information 2982c953570b kbuild: remove redundant $(wildcard ...) for cmd_files calculation 8a78756eb545 kbuild: create object directories simpler and faster 4d4b5c2e3b6e treewide: remove explicit rules for *offsets.s 01d509a48b46 kbuild: remove unimportant comments from ./Kbuild
Kbuild | 45 +++--------------------------------------- Makefile | 3 +-- scripts/Kbuild.include | 15 +++++++------- scripts/Makefile.build | 18 +++++------------ scripts/Makefile.host | 12 ----------- scripts/Makefile.lib | 42 ++++++++++++++++++++++++++++++--------- 6 files changed, 50 insertions(+), 85 deletions(-)
diff --git a/Kbuild b/Kbuild index e2e3b2995f..6014f7c34a 100644 --- a/Kbuild +++ b/Kbuild @@ -1,54 +1,20 @@ +# SPDX-License-Identifier: GPL-2.0 # # Kbuild for top-level directory of U-Boot -# This file takes care of the following: -# 1) Generate generic-asm-offsets.h -# 2) Generate asm-offsets.h - -# Default sed regexp - multiline due to syntax constraints -define sed-y - "s:[[:space:]]*.ascii[[:space:]]*"(.*)":\1:; \ - /^->/{s:->#(.*):/* \1 */:; \ - s:^->([^ ]*) [$$#]*([-0-9]*) (.*):#define \1 \2 /* \3 */:; \ - s:^->([^ ]*) [$$#]*([^ ]*) (.*):#define \1 \2 /* \3 */:; \ - s:->::; p;}" -endef - -# Use filechk to avoid rebuilds when a header changes, but the resulting file -# does not -define filechk_offsets - (set -e; \ - echo "#ifndef $2"; \ - echo "#define $2"; \ - echo "/*"; \ - echo " * DO NOT MODIFY."; \ - echo " *"; \ - echo " * This file was generated by Kbuild"; \ - echo " */"; \ - echo ""; \ - sed -ne $(sed-y); \ - echo ""; \ - echo "#endif" ) -endef
##### -# 1) Generate generic-asm-offsets.h +# Generate generic-asm-offsets.h
generic-offsets-file := include/generated/generic-asm-offsets.h
always := $(generic-offsets-file) targets := lib/asm-offsets.s
-# We use internal kbuild rules to avoid the "is up to date" message from make -lib/asm-offsets.s: lib/asm-offsets.c FORCE - $(Q)mkdir -p $(dir $@) - $(call if_changed_dep,cc_s_c) - $(obj)/$(generic-offsets-file): lib/asm-offsets.s FORCE $(call filechk,offsets,__GENERIC_ASM_OFFSETS_H__)
##### -# 2) Generate asm-offsets.h -# +# Generate asm-offsets.h
ifneq ($(wildcard $(srctree)/arch/$(ARCH)/lib/asm-offsets.c),) offsets-file := include/generated/asm-offsets.h @@ -59,10 +25,5 @@ targets += arch/$(ARCH)/lib/asm-offsets.s
CFLAGS_asm-offsets.o := -DDO_DEPS_ONLY
-# We use internal kbuild rules to avoid the "is up to date" message from make -arch/$(ARCH)/lib/asm-offsets.s: arch/$(ARCH)/lib/asm-offsets.c FORCE - $(Q)mkdir -p $(dir $@) - $(call if_changed_dep,cc_s_c) - $(obj)/$(offsets-file): arch/$(ARCH)/lib/asm-offsets.s FORCE $(call filechk,offsets,__ASM_OFFSETS_H__) diff --git a/Makefile b/Makefile index 26307fd4a6..7e0ca8ccba 100644 --- a/Makefile +++ b/Makefile @@ -2239,8 +2239,7 @@ quiet_cmd_rmfiles = $(if $(wildcard $(rm-files)),CLEAN $(wildcard $(rm-files))
# read all saved command lines
-targets := $(wildcard $(sort $(targets))) -cmd_files := $(wildcard .*.cmd $(foreach f,$(targets),$(dir $(f)).$(notdir $(f)).cmd)) +cmd_files := $(wildcard .*.cmd $(foreach f,$(sort $(targets)),$(dir $(f)).$(notdir $(f)).cmd))
ifneq ($(cmd_files),) $(cmd_files): ; # Do not try to update included dependency files diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index cad3b6e76c..dfb67226b0 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -7,6 +7,7 @@ quote := " squote := ' empty := space := $(empty) $(empty) +space_escape := _-_SPACE_-_ pound := #
### @@ -234,10 +235,10 @@ objectify = $(foreach o,$(1),$(if $(filter /%,$(o)),$(o),$(obj)/$(o))) # See Documentation/kbuild/makefiles.txt for more info
ifneq ($(KBUILD_NOCMDDEP),1) -# Check if both arguments has same arguments. Result is empty string if equal. -# User may override this check using make KBUILD_NOCMDDEP=1 -arg-check = $(strip $(filter-out $(cmd_$(1)), $(cmd_$@)) \ - $(filter-out $(cmd_$@), $(cmd_$(1))) ) +# Check if both arguments are the same including their order. Result is empty +# string if equal. User may override this check using make KBUILD_NOCMDDEP=1 +arg-check = $(filter-out $(subst $(space),$(space_escape),$(strip $(cmd_$@))), \ + $(subst $(space),$(space_escape),$(strip $(cmd_$1)))) else arg-check = $(if $(strip $(cmd_$@)),,1) endif @@ -259,7 +260,7 @@ any-prereq = $(filter-out $(PHONY),$?) $(filter-out $(PHONY) $(wildcard $^),$^) if_changed = $(if $(strip $(any-prereq) $(arg-check)), \ @set -e; \ $(echo-cmd) $(cmd_$(1)); \ - printf '%s\n' 'cmd_$@ := $(make-cmd)' > $(dot-target).cmd) + printf '%s\n' 'cmd_$@ := $(make-cmd)' > $(dot-target).cmd, @:)
# Execute the command and also postprocess generated .d dependencies file. if_changed_dep = $(if $(strip $(any-prereq) $(arg-check) ), \ @@ -267,14 +268,14 @@ if_changed_dep = $(if $(strip $(any-prereq) $(arg-check) ), \ $(echo-cmd) $(cmd_$(1)); \ scripts/basic/fixdep $(depfile) $@ '$(make-cmd)' > $(dot-target).tmp;\ rm -f $(depfile); \ - mv -f $(dot-target).tmp $(dot-target).cmd) + mv -f $(dot-target).tmp $(dot-target).cmd, @:)
# Usage: $(call if_changed_rule,foo) # Will check if $(cmd_foo) or any of the prerequisites changed, # and if so will execute $(rule_foo). if_changed_rule = $(if $(strip $(any-prereq) $(arg-check) ), \ @set -e; \ - $(rule_$(1))) + $(rule_$(1)), @:)
### # why - tell why a a target got build diff --git a/scripts/Makefile.build b/scripts/Makefile.build index 5e5f1682c9..705a886cb9 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -75,17 +75,6 @@ ifneq ($(hostprogs-y)$(hostprogs-m)$(hostlibs-y)$(hostlibs-m)$(hostcxxlibs-y)$(h include scripts/Makefile.host endif
-# Uncommented for U-Boot -# We need to create output dicrectory for SPL and TPL even for in-tree build -#ifneq ($(KBUILD_SRC),) -# Create output directory if not already present -_dummy := $(shell [ -d $(obj) ] || mkdir -p $(obj)) - -# Create directories for object files if directory does not exist -# Needed when obj-y := dir/file.o syntax is used -_dummy := $(foreach d,$(obj-dirs), $(shell [ -d $(d) ] || mkdir -p $(d))) -#endif - ifndef obj $(warning kbuild: Makefile.build is included improperly) endif @@ -441,11 +430,14 @@ FORCE: # optimization, we don't need to read them if the target does not # exist, we will rebuild anyway in that case.
-targets := $(wildcard $(sort $(targets))) -cmd_files := $(wildcard $(foreach f,$(targets),$(dir $(f)).$(notdir $(f)).cmd)) +cmd_files := $(wildcard $(foreach f,$(sort $(targets)),$(dir $(f)).$(notdir $(f)).cmd))
ifneq ($(cmd_files),) include $(cmd_files) endif
+# Create directories for object files if they do not exist +obj-dirs := $(sort $(obj) $(patsubst %/,%, $(dir $(targets)))) +$(shell mkdir -p $(obj-dirs)) + .PHONY: $(PHONY) diff --git a/scripts/Makefile.host b/scripts/Makefile.host index da2f4d5bfd..69983a19a4 100644 --- a/scripts/Makefile.host +++ b/scripts/Makefile.host @@ -53,15 +53,6 @@ host-cxxobjs := $(sort $(foreach m,$(host-cxxmulti),$($(m)-cxxobjs))) host-cshobjs := $(sort $(foreach m,$(host-cshlib),$($(m:.so=-objs)))) host-cxxshobjs := $(sort $(foreach m,$(host-cxxshlib),$($(m:.so=-objs))))
-# output directory for programs/.o files -# hostprogs-y := tools/build may have been specified. -# Retrieve also directory of .o files from prog-objs or prog-cxxobjs notation -host-objdirs := $(dir $(__hostprogs) $(host-cobjs) $(host-cxxobjs)) - -host-objdirs := $(strip $(sort $(filter-out ./,$(host-objdirs)))) - - -__hostprogs := $(addprefix $(obj)/,$(__hostprogs)) host-csingle := $(addprefix $(obj)/,$(host-csingle)) host-cmulti := $(addprefix $(obj)/,$(host-cmulti)) host-cobjs := $(addprefix $(obj)/,$(host-cobjs)) @@ -72,9 +63,6 @@ host-cxxshlib := $(addprefix $(obj)/,$(host-cxxshlib)) host-cshobjs := $(addprefix $(obj)/,$(host-cshobjs)) host-cxxshobjs := $(addprefix $(obj)/,$(host-cxxshobjs)) host-shared := $(addprefix $(obj)/,$(host-shared)) -host-objdirs := $(addprefix $(obj)/,$(host-objdirs)) - -obj-dirs += $(host-objdirs)
##### # Handle options to gcc. Support building with separate output directory diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 1c8cb7488f..63fbadd757 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -57,15 +57,11 @@ single-used-m := $(sort $(filter-out $(multi-used-m),$(obj-m))) # objects depend on those (obviously) multi-objs-y := $(foreach m, $(multi-used-y), $($(m:.o=-objs)) $($(m:.o=-y))) multi-objs-m := $(foreach m, $(multi-used-m), $($(m:.o=-objs)) $($(m:.o=-y))) -multi-objs := $(multi-objs-y) $(multi-objs-m)
# $(subdir-obj-y) is the list of objects in $(obj-y) which uses dir/ to # tell kbuild to descend subdir-obj-y := $(filter %/built-in.o, $(obj-y))
-# $(obj-dirs) is a list of directories that contain object files -obj-dirs := $(dir $(multi-objs) $(obj-y)) - # Replace multi-part objects by their individual parts, look at local dir only real-objs-y := $(foreach m, $(filter-out $(subdir-obj-y), $(obj-y)), $(if $(strip $($(m:.o=-objs)) $($(m:.o=-y))),$($(m:.o=-objs)) $($(m:.o=-y)),$(m))) $(extra-y) real-objs-m := $(foreach m, $(obj-m), $(if $(strip $($(m:.o=-objs)) $($(m:.o=-y))),$($(m:.o=-objs)) $($(m:.o=-y)),$(m))) @@ -88,7 +84,6 @@ multi-used-m := $(addprefix $(obj)/,$(multi-used-m)) multi-objs-y := $(addprefix $(obj)/,$(multi-objs-y)) multi-objs-m := $(addprefix $(obj)/,$(multi-objs-m)) subdir-ym := $(addprefix $(obj)/,$(subdir-ym)) -obj-dirs := $(addprefix $(obj)/,$(obj-dirs))
# These flags are needed for modversions and compiling, so we define them here # already @@ -97,10 +92,10 @@ obj-dirs := $(addprefix $(obj)/,$(obj-dirs)) # Note: Files that end up in two or more modules are compiled without the # KBUILD_MODNAME definition. The reason is that any made-up name would # differ in different configs. -name-fix = $(subst $(comma),_,$(subst -,_,$1)) -basename_flags = -D"KBUILD_BASENAME=KBUILD_STR($(call name-fix,$(basetarget)))" +name-fix = $(squote)$(quote)$(subst $(comma),_,$(subst -,_,$1))$(quote)$(squote) +basename_flags = -DKBUILD_BASENAME=$(call name-fix,$(basetarget)) modname_flags = $(if $(filter 1,$(words $(modname))),\ - -D"KBUILD_MODNAME=KBUILD_STR($(call name-fix,$(modname)))") + -DKBUILD_MODNAME=$(call name-fix,$(modname)))
orig_c_flags = $(KBUILD_CPPFLAGS) $(KBUILD_CFLAGS) $(KBUILD_SUBDIR_CCFLAGS) \ $(ccflags-y) $(CFLAGS_$(basetarget).o) @@ -153,7 +148,7 @@ endif # Modified for U-Boot: LINUXINCLUDE -> UBOOTINCLUDE c_flags = -Wp,-MD,$(depfile) $(NOSTDINC_FLAGS) $(UBOOTINCLUDE) \ $(__c_flags) $(modkern_cflags) \ - -D"KBUILD_STR(s)=#s" $(basename_flags) $(modname_flags) + $(basename_flags) $(modname_flags)
a_flags = -Wp,-MD,$(depfile) $(NOSTDINC_FLAGS) $(UBOOTINCLUDE) \ $(__a_flags) $(modkern_aflags) @@ -576,3 +571,32 @@ quiet_cmd_fdtgrep = FDTGREP $@ quiet_cmd_fdt_rm_props = FDTGREP $@ cmd_fdt_rm_props = cat $< | $(objtree)/tools/fdtgrep -r -O dtb - -o $@ \ $(addprefix -P ,$(subst $",,$(CONFIG_OF_REMOVE_PROPS))) + +# ASM offsets +# --------------------------------------------------------------------------- + +# Default sed regexp - multiline due to syntax constraints +define sed-offsets + "s:[[:space:]]*.ascii[[:space:]]*"(.*)":\1:; \ + /^->/{s:->#(.*):/* \1 */:; \ + s:^->([^ ]*) [$$#]*([-0-9]*) (.*):#define \1 \2 /* \3 */:; \ + s:^->([^ ]*) [$$#]*([^ ]*) (.*):#define \1 \2 /* \3 */:; \ + s:->::; p;}" +endef + +# Use filechk to avoid rebuilds when a header changes, but the resulting file +# does not +define filechk_offsets + (set -e; \ + echo "#ifndef $2"; \ + echo "#define $2"; \ + echo "/*"; \ + echo " * DO NOT MODIFY."; \ + echo " *"; \ + echo " * This file was generated by Kbuild"; \ + echo " */"; \ + echo ""; \ + sed -ne $(sed-offsets); \ + echo ""; \ + echo "#endif" ) +endef
Currently generic-asm-offsets.h and asm-offsets.h are generated based on U-Boot proper config options. The same asm-offsets headers are used for building U-Boot SPL/TPL, which causes potential offset mismatch if U-Boot proper has different config options from U-Boot SPL/TPL.
This commit adds: spl/include/generated/(generic-)asm-offsets.h tpl/include/generated/(generic-)asm-offsets.h
spl/include/generated/(generic-)asm-offsets.h is generated if CONFIG_SPL=y, and included when building SPL.
tpl/include/generated/(generic-)asm-offsets.h is generated if CONFIG_TPL=y, and included when building TPL.
They are created before Kbuild descends into SPL/TPL object directories and builds $(obj)/dts/dt-platdata.o because $(obj)/dts/dt-platdata.c includes a bunch of headers.
Prepend -I$(obj)/include to $(UBOOTINCLUDE) so (generic-)asm-offsets.h is searched in {spl,tpl}/include/generated/.
Requested-by: Bin Meng bmeng.cn@gmail.com Signed-off-by: Masahiro Yamada masahiroy@kernel.org ---
Changes in v2: None
Kbuild | 4 ++-- scripts/Makefile.spl | 10 ++++++++-- 2 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/Kbuild b/Kbuild index 6014f7c34a..1eac091594 100644 --- a/Kbuild +++ b/Kbuild @@ -10,7 +10,7 @@ generic-offsets-file := include/generated/generic-asm-offsets.h always := $(generic-offsets-file) targets := lib/asm-offsets.s
-$(obj)/$(generic-offsets-file): lib/asm-offsets.s FORCE +$(obj)/$(generic-offsets-file): $(obj)/lib/asm-offsets.s FORCE $(call filechk,offsets,__GENERIC_ASM_OFFSETS_H__)
##### @@ -25,5 +25,5 @@ targets += arch/$(ARCH)/lib/asm-offsets.s
-$(obj)/$(offsets-file): arch/$(ARCH)/lib/asm-offsets.s FORCE +$(obj)/$(offsets-file): $(obj)/arch/$(ARCH)/lib/asm-offsets.s FORCE $(call filechk,offsets,__ASM_OFFSETS_H__) diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 4c2c0567c5..6741ef911e 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -22,6 +22,8 @@ include $(srctree)/scripts/Kbuild.include -include include/config/auto.conf -include $(obj)/include/autoconf.mk
+UBOOTINCLUDE := -I$(obj)/include $(UBOOTINCLUDE) + KBUILD_CPPFLAGS += -DCONFIG_SPL_BUILD ifeq ($(CONFIG_TPL_BUILD),y) KBUILD_CPPFLAGS += -DCONFIG_TPL_BUILD @@ -311,7 +313,7 @@ cmd_plat = $(CC) $(c_flags) -c $< -o $(filter-out $(PHONY),$@)
targets += $(obj)/dts/dt-platdata.o $(obj)/dts/dt-platdata.o: $(obj)/dts/dt-platdata.c \ - include/generated/dt-structs-gen.h FORCE + include/generated/dt-structs-gen.h prepare FORCE $(call if_changed,plat)
PHONY += dts_dir @@ -422,9 +424,13 @@ $(obj)/$(SPL_BIN): $(u-boot-spl-platdata) $(u-boot-spl-init) \ $(sort $(u-boot-spl-init) $(u-boot-spl-main)): $(u-boot-spl-dirs) ;
PHONY += $(u-boot-spl-dirs) -$(u-boot-spl-dirs): $(u-boot-spl-platdata) +$(u-boot-spl-dirs): $(u-boot-spl-platdata) prepare $(Q)$(MAKE) $(build)=$@
+PHONY += prepare +prepare: + $(Q)$(MAKE) $(build)=$(obj)/. + quiet_cmd_cpp_lds = LDS $@ cmd_cpp_lds = $(CPP) -Wp,-MD,$(depfile) $(cpp_flags) $(LDPPFLAGS) -ansi \ -D__ASSEMBLY__ -x assembler-with-cpp -std=c99 -P -o $@ $<
Changes in v2: None
It works like a charm. Thanks!
Tested-by: Bin Meng bmeng.cn@gmail.com
Hi Tom,
Changes in v2: None
It looks only patch 1 and 2 in this series were applied. This patch was missed.
Regards, Bin
On Mon, Apr 27, 2020 at 09:37:28AM +0800, Bin Meng wrote:
Hi Tom,
Changes in v2: None
So, I was going to ask and forgot, sorry. Why do we need to have these differ between TPL/SPL/U-Boot itself, and then why is that good? I thought this was something we wanted to ensure was consistent from stage to stage to facilitate sharing of information. But I also am happy to assume I just missed an explanation along the way. Thanks!
Hi Tom,
Hi Tom,
Changes in v2: None
Because currently the offsets {spl,tpl}/include/generated/(generic-)asm-offsets.h are generated per the U-Boot config options. But SPL and TPL are not guaranteed to have the same config options.
For example it's possible to have SPL/TPL turned on {SPL,TPL}_CONFIG_XXX but U-Boot to turn off CONFIG_XXX, or vice verse.
To me this is more like a bug fix other than a feature.
Regards, Bin
On Mon, Apr 27, 2020 at 10:50:48PM +0800, Bin Meng wrote:
Hi Tom,
Hi Tom,
Changes in v2: None
Ah, OK. But shouldn't we make sure that asm-offsets are consistent between SPL/TPL/U-Boot? Or is there a use-case where it makes sense for them to differ intentionally?
Hi Tom,
Hi Tom,
Hi Tom,
Changes in v2: None
I don't know other boards, but for now RISC-V does turn on SPL_SMP in SPL, but does not turn on SMP in U-Boot S-mode. U-Boot M-mode can still turn on SMP.
Regards, Bin
On Tue, Apr 28, 2020 at 11:01:12PM +0800, Bin Meng wrote:
Hi Tom,
Hi Tom,
Hi Tom,
On Fri, Apr 17, 2020 at 3:22 PM Masahiro Yamada masahiroy@kernel.org wrote: > > Currently generic-asm-offsets.h and asm-offsets.h are generated based > on U-Boot proper config options. The same asm-offsets headers are used > for building U-Boot SPL/TPL, which causes potential offset mismatch if > U-Boot proper has different config options from U-Boot SPL/TPL. > > This commit adds: > spl/include/generated/(generic-)asm-offsets.h > tpl/include/generated/(generic-)asm-offsets.h > > spl/include/generated/(generic-)asm-offsets.h is generated if > CONFIG_SPL=y, and included when building SPL. > > tpl/include/generated/(generic-)asm-offsets.h is generated if > CONFIG_TPL=y, and included when building TPL. > > They are created before Kbuild descends into SPL/TPL object directories > and builds $(obj)/dts/dt-platdata.o because $(obj)/dts/dt-platdata.c > includes a bunch of headers. > > Prepend -I$(obj)/include to $(UBOOTINCLUDE) so (generic-)asm-offsets.h > is searched in {spl,tpl}/include/generated/. > > Requested-by: Bin Meng bmeng.cn@gmail.com > Signed-off-by: Masahiro Yamada masahiroy@kernel.org > --- > > Changes in v2: None > > Kbuild | 4 ++-- > scripts/Makefile.spl | 10 ++++++++-- > 2 files changed, 10 insertions(+), 4 deletions(-) >
OK. I'd really like to have it confirmed that it's a good idea to have that value differ between the modes and it's not a bug that should be fixed. Thanks!
On Wed, Apr 29, 2020 at 12:01 AM Bin Meng bmeng.cn@gmail.com wrote:
Hi Tom,
Hi Tom,
Hi Tom,
Maybe, save memory for SPL/TPL ? We can say "do not do that", but it is fragile.
People are adding #ifdef around to all sort of structs, and it is difficult to guess which ones are used to construct asm-offsets.
Hi Tom,
Hi Tom,
Hi Tom,
On Sat, Apr 18, 2020 at 8:37 PM Bin Meng bmeng.cn@gmail.com wrote: > > On Fri, Apr 17, 2020 at 3:22 PM Masahiro Yamada masahiroy@kernel.org wrote: > > > > Currently generic-asm-offsets.h and asm-offsets.h are generated based > > on U-Boot proper config options. The same asm-offsets headers are used > > for building U-Boot SPL/TPL, which causes potential offset mismatch if > > U-Boot proper has different config options from U-Boot SPL/TPL. > > > > This commit adds: > > spl/include/generated/(generic-)asm-offsets.h > > tpl/include/generated/(generic-)asm-offsets.h > > > > spl/include/generated/(generic-)asm-offsets.h is generated if > > CONFIG_SPL=y, and included when building SPL. > > > > tpl/include/generated/(generic-)asm-offsets.h is generated if > > CONFIG_TPL=y, and included when building TPL. > > > > They are created before Kbuild descends into SPL/TPL object directories > > and builds $(obj)/dts/dt-platdata.o because $(obj)/dts/dt-platdata.c > > includes a bunch of headers. > > > > Prepend -I$(obj)/include to $(UBOOTINCLUDE) so (generic-)asm-offsets.h > > is searched in {spl,tpl}/include/generated/. > > > > Requested-by: Bin Meng bmeng.cn@gmail.com > > Signed-off-by: Masahiro Yamada masahiroy@kernel.org > > --- > > > > Changes in v2: None > > > > Kbuild | 4 ++-- > > scripts/Makefile.spl | 10 ++++++++-- > > 2 files changed, 10 insertions(+), 4 deletions(-) > > > > It works like a charm. Thanks! > > Tested-by: Bin Meng bmeng.cn@gmail.com
So, you're right. I'm doing a build now to check the differences, but fairly often SPL and TPL disagree here, related to malloc and similar it looks like. So this is a bug-fix and I'll apply it shortly. Thanks!
Requested-by: Bin Meng bmeng.cn@gmail.com Signed-off-by: Masahiro Yamada masahiroy@kernel.org Tested-by: Bin Meng bmeng.cn@gmail.com
Bin Meng
Masahiro Yamada
