[U-Boot-Users] u-boot-1.1.3 build error
Hi all:
I am trying to build u-boot-1.1.3 for TI OMAP 5912 OSK. My system is Debian amd64 Sarge 3.1. First I encounter errors with option `short-load-bytes'and 'apcs-32'. When I delete this option in cpu/arm926ejs/config.mk, I encountered the second error: undefined CFG_GBL_DATA_SIZE. I found it is not defined in include/configs/omap5912osk.h and other related .h files. I tried to append a line in omap5912osk.h then a new error appeared.
net.c: In function 'NetStartAgain': net.c:579: warning: pointer targets in passing argument 1 of 'getenv' differ in signedness net.c: In function 'NetCksum': net.c:1580: error: invalid lvalue in increment net.c: In function 'getenv_IPaddr': net.c:1742: warning: pointer targets in passing argument 1 of 'getenv' differ in signedness net.c: In function 'getenv_VLAN': net.c:1747: warning: pointer targets in passing argument 1 of 'getenv' differ in signedness make[1]: *** [net.o] Error 1 make: *** [net/libnet.a] Error 2
What should I do now? There is also a strange thing that if I built u-boot-1.1.3 with another PC ( Redhat FC3 ), the building process seems successful without any changes. Something wrong with configuration or else?
Thank you for your advice and I am eager to receive your kind reply.
Best regards!
Li Weichen 2005-10-26
Li Weichen
