[PATCH] board: gateworks: venice: add eraseenv command
Add eraseenv command and remove the unnecessary env command.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/venice/venice.env | 1 - configs/imx8mm_venice_defconfig | 1 + configs/imx8mn_venice_defconfig | 1 + configs/imx8mp_venice_defconfig | 1 + 4 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/board/gateworks/venice/venice.env b/board/gateworks/venice/venice.env index f81804ca12c1..2054c029a3e9 100644 --- a/board/gateworks/venice/venice.env +++ b/board/gateworks/venice/venice.env @@ -31,4 +31,3 @@ update_rootfs=tftpboot $loadaddr $image && gzwrite mmc $dev $loadaddr $filesize 100000 1000000 update_all=tftpboot $loadaddr $image && gzwrite mmc $dev $loadaddr $filesize -erase_env=mmc dev $dev; mmc erase 0x7f08 0x40 diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index a55e0cd76b54..ad5b7616f30a 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -50,6 +50,7 @@ CONFIG_SYS_PBSIZE=2074 CONFIG_SYS_BOOTM_LEN=0x10000000 # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_ERASEENV=y CONFIG_CRC32_VERIFY=y CONFIG_CMD_MD5SUM=y CONFIG_MD5SUM_VERIFY=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index 4709ecace65c..0742fa759b08 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_PBSIZE=2074 CONFIG_SYS_BOOTM_LEN=0x10000000 # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_ERASEENV=y CONFIG_CRC32_VERIFY=y CONFIG_CMD_MD5SUM=y CONFIG_MD5SUM_VERIFY=y diff --git a/configs/imx8mp_venice_defconfig b/configs/imx8mp_venice_defconfig index 6b6a15588cd4..ae0c0120d107 100644 --- a/configs/imx8mp_venice_defconfig +++ b/configs/imx8mp_venice_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_PBSIZE=2074 CONFIG_SYS_BOOTM_LEN=0x10000000 # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_ERASEENV=y CONFIG_CRC32_VERIFY=y CONFIG_CMD_MD5SUM=y CONFIG_MD5SUM_VERIFY=y
Reviewed-by: Fabio Estevam festevam@denx.de
Add eraseenv command and remove the unnecessary env command. Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Fabio Estevam festevam@denx.de
Best regards, Stefano Babic
Fabio Estevam
sbabic@denx.de
Tim Harvey
