[U-Boot] [PATCH 2/7] powerpc/85xx: do not reloc l2srbar if CONFIG_FLASH_BASE is not defined
This fixes the compiling error for the board which doesn't have NOR flash (so CONFIG_FLASH_BASE is not defined)
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 2c3be6d..1fbc0cc 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -327,7 +327,7 @@ int cpu_init_r(void) if (l2cache->l2ctl & MPC85xx_L2CTL_L2E) { puts("already enabled"); l2srbar = l2cache->l2srbar0; -#ifdef CONFIG_SYS_INIT_L2_ADDR +#if defined(CONFIG_SYS_INIT_L2_ADDR) && defined(CONFIG_SYS_FLASH_BASE) if (l2cache->l2ctl & MPC85xx_L2CTL_L2SRAM_ENTIRE && l2srbar >= CONFIG_SYS_FLASH_BASE) { l2srbar = CONFIG_SYS_INIT_L2_ADDR;
Dear Haiying Wang,
Does this commit not break systems which have CONFIG_SYS_FLASH_BASE defined, but with l2srbar < CONFIG_SYS_FLASH_BASE ?
I did not see it breaks the system in that case. It only affects the system without CONFIG_SYS_FLASH_BASE defined. :)
Haiying
Dear Haiying Wang,
Yes, of course you are right. Sorry for the stupid question.
Haiying Wang
