[PATCH v3 0/3] Add SPL build support for RK3568
This series adds support for the rk3568 SOC, SPL load next-stage image from eMMC will be supported after this series of patches.
Changes in v3: Replace configuration parameters of SGRF_SOC_CON4 with macro definitions.
Changes in v2: We use the rk_clrreg function instead of the writel to set eMMC sdmmc0 to secure. Modify comments to make them more explicit.
Nico Cheng (3): rockchip: Kconfig: Enable SPL support for rk3568 arm: dts: rockchip: rk3568: Enable sdhci and sdmmc0 node rockchip: rk3568: add arch_cpu_init()
arch/arm/dts/rk3568-u-boot.dtsi | 17 ++++++++++++++++ arch/arm/mach-rockchip/Kconfig | 2 ++ arch/arm/mach-rockchip/rk3568/rk3568.c | 27 +++++++++++++++++++++++--- configs/evb-rk3568_defconfig | 25 +++++++++++++++++++++++- include/configs/rk3568_common.h | 4 ++++ 5 files changed, 71 insertions(+), 4 deletions(-)
Enable SPL support in Kconfig and add some related option in rk3568_common.h
Signed-off-by: Nico Cheng nico.cheng@rock-chips.com Signed-off-by: Jason Zhu jason.zhu@rock-chips.com ---
(no changes since v1)
arch/arm/mach-rockchip/Kconfig | 2 ++ configs/evb-rk3568_defconfig | 25 ++++++++++++++++++++++++- include/configs/rk3568_common.h | 4 ++++ 3 files changed, 30 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index b164afb529..21b9c381cf 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -260,6 +260,8 @@ config ROCKCHIP_RK3399 config ROCKCHIP_RK3568 bool "Support Rockchip RK3568" select ARM64 + select SUPPORT_SPL + select SPL select CLK select PINCTRL select RAM diff --git a/configs/evb-rk3568_defconfig b/configs/evb-rk3568_defconfig index a102a5a999..a145b71ac2 100644 --- a/configs/evb-rk3568_defconfig +++ b/configs/evb-rk3568_defconfig @@ -1,20 +1,42 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_DEFAULT_DEVICE_TREE="rk3568-evb" CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_TARGET_EVB_RK3568=y CONFIG_DEBUG_UART_BASE=0xFE660000 CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEFAULT_DEVICE_TREE="rk3568-evb" CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_ATF=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y @@ -28,6 +50,7 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_REGULATOR_PWM=y CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/include/configs/rk3568_common.h b/include/configs/rk3568_common.h index b6568917ea..47fc91779e 100644 --- a/include/configs/rk3568_common.h +++ b/include/configs/rk3568_common.h @@ -18,6 +18,10 @@
#define CONFIG_SYS_INIT_SP_ADDR 0x00c00000 #define CONFIG_SYS_LOAD_ADDR 0x00c00800 +#define CONFIG_SPL_STACK 0x00400000 +#define CONFIG_SPL_MAX_SIZE 0x20000 +#define CONFIG_SPL_BSS_START_ADDR 0x4000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x4000 #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
#define CONFIG_SYS_SDRAM_BASE 0
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- select SUPPORT_SPL
- select SPL select CLK select PINCTRL select RAM
Reviewed-by: Jagan Teki jagan@amarulasolutions.com
Enable sdhci and sdmmc0 node in rk3568-u-boot.dtsi
Signed-off-by: Nico Cheng nico.cheng@rock-chips.com ---
arch/arm/dts/rk3568-u-boot.dtsi | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/arm/dts/rk3568-u-boot.dtsi b/arch/arm/dts/rk3568-u-boot.dtsi index 1570f13fc7..5a80dda275 100644 --- a/arch/arm/dts/rk3568-u-boot.dtsi +++ b/arch/arm/dts/rk3568-u-boot.dtsi @@ -9,6 +9,10 @@ mmc1 = &sdmmc0; };
+ chosen { + u-boot,spl-boot-order = &sdhci, &sdmmc0; + }; + dmc: dmc { compatible = "rockchip,rk3568-dmc"; u-boot,dm-pre-reloc; @@ -35,3 +39,16 @@ u-boot,dm-pre-reloc; status = "okay"; }; + +&sdmmc0 { + u-boot,dm-spl; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + u-boot,dm-spl; + mmc-hs200-1_8v; + status = "okay"; +}; +
Thanks, - Kever
- chosen {
- dmc: dmc { compatible = "rockchip,rk3568-dmc"; u-boot,dm-pre-reloc;
+&sdmmc0 {
- u-boot,dm-spl;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- u-boot,dm-spl;
- mmc-hs200-1_8v;
- status = "okay";
We configured the drive strength and security of EMMC in arch_cpu_init().
arch/arm/mach-rockchip/rk3568/rk3568.c | 27 +++++++++++++++++++++++--- 1 file changed, 24 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3568/rk3568.c b/arch/arm/mach-rockchip/rk3568/rk3568.c index 973b4f9dcb..22eeb77d41 100644 --- a/arch/arm/mach-rockchip/rk3568/rk3568.c +++ b/arch/arm/mach-rockchip/rk3568/rk3568.c @@ -11,9 +11,18 @@ #include <asm/arch-rockchip/hardware.h> #include <dt-bindings/clock/rk3568-cru.h>
-#define PMUGRF_BASE 0xfdc20000 -#define GRF_BASE 0xfdc60000 - +#define PMUGRF_BASE 0xfdc20000 +#define GRF_BASE 0xfdc60000 +#define GRF_GPIO1B_DS_2 0x218 +#define GRF_GPIO1B_DS_3 0x21c +#define GRF_GPIO1C_DS_0 0x220 +#define GRF_GPIO1C_DS_1 0x224 +#define GRF_GPIO1C_DS_2 0x228 +#define GRF_GPIO1C_DS_3 0x22c +#define SGRF_BASE 0xFDD18000 +#define SGRF_SOC_CON4 0x10 +#define EMMC_HPROT_SECURE_CTRL 0x03 +#define SDMMC0_HPROT_SECURE_CTRL 0x01 /* PMU_GRF_GPIO0D_IOMUX_L */ enum { GPIO0D1_SHIFT = 4, @@ -81,5 +90,17 @@ void board_debug_uart_init(void)
int arch_cpu_init(void) { +#ifdef CONFIG_SPL_BUILD + /* Set the emmc sdmmc0 to secure */ + rk_clrreg(SGRF_BASE + SGRF_SOC_CON4, (EMMC_HPROT_SECURE_CTRL << 11 + | SDMMC0_HPROT_SECURE_CTRL << 4)); + /* set the emmc driver strength to level 2 */ + writel(0x3f3f0707, GRF_BASE + GRF_GPIO1B_DS_2); + writel(0x3f3f0707, GRF_BASE + GRF_GPIO1B_DS_3); + writel(0x3f3f0707, GRF_BASE + GRF_GPIO1C_DS_0); + writel(0x3f3f0707, GRF_BASE + GRF_GPIO1C_DS_1); + writel(0x3f3f0707, GRF_BASE + GRF_GPIO1C_DS_2); + writel(0x3f3f0707, GRF_BASE + GRF_GPIO1C_DS_3); +#endif return 0; }
Thanks, - Kever
- /* Set the emmc sdmmc0 to secure */
- rk_clrreg(SGRF_BASE + SGRF_SOC_CON4, (EMMC_HPROT_SECURE_CTRL << 11
- /* set the emmc driver strength to level 2 */
- writel(0x3f3f0707, GRF_BASE + GRF_GPIO1B_DS_2);
- writel(0x3f3f0707, GRF_BASE + GRF_GPIO1B_DS_3);
- writel(0x3f3f0707, GRF_BASE + GRF_GPIO1C_DS_0);
- writel(0x3f3f0707, GRF_BASE + GRF_GPIO1C_DS_1);
- writel(0x3f3f0707, GRF_BASE + GRF_GPIO1C_DS_2);
- writel(0x3f3f0707, GRF_BASE + GRF_GPIO1C_DS_3);
+#endif return 0; }
Hi Nico,
Is this expected to work with Arm Trusted Firmware or some other TF?
Could we have some docs/details for how to test this?
Peter
-- 2.17.1
Hi Peter,
The scripts that package the ATF and other components are subject to further updates to the patch, which is not currently available in the submitted patch.
Nico
Hi Nico,
Peter
Changes in v3:
definitions.
Changes in v2:
secure.
Nico Cheng (3):
2.17.1
Hi Peter,
This add SPL support for RK3568, and the ATF support is a function support int the ATF in rockchip platform, so if this chip works, them it will of course support ATF like other rockchip SoCs.
Thanks,
- Kever
On 2021/10/26 下午4:09, Peter Robinson wrote:
Hi Nico,
Peter
-- 2.17.1
participants (5)
Jagan Teki
Kever Yang
Nico Cheng
Peter Robinson
