[PATCH RFC 0/2] Unify K3 initial memory map
Hello all,
This is just an RFC as it probably breaks remoteproc loading. I wanted to post anyway as the complexity of having a dedicated memory map for each SoC came up in a different series.
Or maybe we can take this now and that will expose the issue in remoteproc loading better and force someone to go fix it. :)
This series depends on this[0].
Thanks, Andrew
[0] https://patchwork.ozlabs.org/project/uboot/patch/20231106165205.22066-1-afd@...
Andrew Davis (2): arm: mach-k3: Remove non-cached memory map areas arm: mach-k3: Merge initial memory maps
arch/arm/mach-k3/arm64-mmu.c | 253 +---------------------------------- 1 file changed, 2 insertions(+), 251 deletions(-)
All normal memory areas should be mapped as such.
We added these un-cached holes in our memory map to hack around the remoteproc driver missing the proper cache maintenance operations.
The problem is having these non-cached memory map areas causes stability issues later in system operation due to the nature of the K3 coherency architecture. Plus these are board specific carveouts and instead should have been added at the board level, not here in the SoC common code area.
Remove these non-cached memory map areas.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/mach-k3/arm64-mmu.c | 48 +++--------------------------------- 1 file changed, 3 insertions(+), 45 deletions(-)
diff --git a/arch/arm/mach-k3/arm64-mmu.c b/arch/arm/mach-k3/arm64-mmu.c index 471295fa7eb..a5afdf9f4a7 100644 --- a/arch/arm/mach-k3/arm64-mmu.c +++ b/arch/arm/mach-k3/arm64-mmu.c @@ -25,19 +25,7 @@ struct mm_region am654_mem_map[] = { }, { .virt = 0x80000000UL, .phys = 0x80000000UL, - .size = 0x20000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0xa0000000UL, - .phys = 0xa0000000UL, - .size = 0x02100000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL_NC) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0xa2100000UL, - .phys = 0xa2100000UL, - .size = 0x5df00000UL, + .size = 0x80000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_INNER_SHARE }, { @@ -76,19 +64,7 @@ struct mm_region j721e_mem_map[] = { }, { .virt = 0x80000000UL, .phys = 0x80000000UL, - .size = 0x20000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0xa0000000UL, - .phys = 0xa0000000UL, - .size = 0x1bc00000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL_NC) | - PTE_BLOCK_NON_SHARE - }, { - .virt = 0xbbc00000UL, - .phys = 0xbbc00000UL, - .size = 0x44400000UL, + .size = 0x80000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_INNER_SHARE }, { @@ -104,12 +80,6 @@ struct mm_region j721e_mem_map[] = { .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0x4d80000000UL, - .phys = 0x4d80000000UL, - .size = 0x0002000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL_NC) | - PTE_BLOCK_INNER_SHARE }, { /* List terminator */ 0, @@ -131,19 +101,7 @@ struct mm_region j7200_mem_map[] = { }, { .virt = 0x80000000UL, .phys = 0x80000000UL, - .size = 0x20000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0xa0000000UL, - .phys = 0xa0000000UL, - .size = 0x04800000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL_NC) | - PTE_BLOCK_NON_SHARE - }, { - .virt = 0xa4800000UL, - .phys = 0xa4800000UL, - .size = 0x5b800000UL, + .size = 0x80000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_INNER_SHARE }, {
The Device vs Normal memory map is the same for all K3 SoCs. Merge the SoC specific maps into one.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/mach-k3/arm64-mmu.c | 211 +---------------------------------- 1 file changed, 2 insertions(+), 209 deletions(-)
diff --git a/arch/arm/mach-k3/arm64-mmu.c b/arch/arm/mach-k3/arm64-mmu.c index a5afdf9f4a7..cfd3b40d54c 100644 --- a/arch/arm/mach-k3/arm64-mmu.c +++ b/arch/arm/mach-k3/arm64-mmu.c @@ -13,8 +13,7 @@ #include <asm/system.h> #include <asm/armv8/mmu.h>
-#ifdef CONFIG_SOC_K3_AM654 -struct mm_region am654_mem_map[] = { +struct mm_region k3_mem_map[] = { { .virt = 0x0UL, .phys = 0x0UL, @@ -47,210 +46,4 @@ struct mm_region am654_mem_map[] = { } };
-struct mm_region *mem_map = am654_mem_map; -#endif /* CONFIG_SOC_K3_AM654 */ - -#ifdef CONFIG_SOC_K3_J721E - -#ifdef CONFIG_TARGET_J721E_A72_EVM -struct mm_region j721e_mem_map[] = { - { - .virt = 0x0UL, - .phys = 0x0UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0x80000000UL, - .phys = 0x80000000UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x880000000UL, - .phys = 0x880000000UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x500000000UL, - .phys = 0x500000000UL, - .size = 0x400000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, - } -}; - -struct mm_region *mem_map = j721e_mem_map; -#endif /* CONFIG_TARGET_J721E_A72_EVM */ - -#ifdef CONFIG_TARGET_J7200_A72_EVM -struct mm_region j7200_mem_map[] = { - { - .virt = 0x0UL, - .phys = 0x0UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0x80000000UL, - .phys = 0x80000000UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x880000000UL, - .phys = 0x880000000UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x500000000UL, - .phys = 0x500000000UL, - .size = 0x400000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, - } -}; - -struct mm_region *mem_map = j7200_mem_map; -#endif /* CONFIG_TARGET_J7200_A72_EVM */ - -#endif /* CONFIG_SOC_K3_J721E */ - -#ifdef CONFIG_SOC_K3_J721S2 -struct mm_region j721s2_mem_map[] = { - { - .virt = 0x0UL, - .phys = 0x0UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0x80000000UL, - .phys = 0x80000000UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x880000000UL, - .phys = 0x880000000UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x500000000UL, - .phys = 0x500000000UL, - .size = 0x400000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, - } -}; - -struct mm_region *mem_map = j721s2_mem_map; - -#endif /* CONFIG_SOC_K3_J721S2 */ - -#if defined(CONFIG_SOC_K3_AM625) || defined(CONFIG_SOC_K3_AM62A7) - -struct mm_region am62_mem_map[] = { - { - .virt = 0x0UL, - .phys = 0x0UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0x80000000UL, - .phys = 0x80000000UL, - .size = 0x1E780000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0xA0000000UL, - .phys = 0xA0000000UL, - .size = 0x60000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - - }, { - .virt = 0x880000000UL, - .phys = 0x880000000UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x500000000UL, - .phys = 0x500000000UL, - .size = 0x400000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, - } -}; - -struct mm_region *mem_map = am62_mem_map; -#endif /* CONFIG_SOC_K3_AM625 || CONFIG_SOC_K3_AM62A7 */ - -#ifdef CONFIG_SOC_K3_AM642 - -struct mm_region am64_mem_map[] = { - { - .virt = 0x0UL, - .phys = 0x0UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0x80000000UL, - .phys = 0x80000000UL, - .size = 0x1E800000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0xA0000000UL, - .phys = 0xA0000000UL, - .size = 0x60000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x880000000UL, - .phys = 0x880000000UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x500000000UL, - .phys = 0x500000000UL, - .size = 0x400000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, - } -}; - -struct mm_region *mem_map = am64_mem_map; -#endif /* CONFIG_SOC_K3_AM642 */ +struct mm_region *mem_map = k3_mem_map;
On 09:14-20231122, Andrew Davis wrote:
Hello all,
Thanks, Andrew
-- 2.39.2
Could you rebase and submit as non-RFC? Please free to add:
Reviewed-by: Nishanth Menon nm@ti.com Tested-by: Nishanth Menon nm@ti.com
tested along with the v2 of dependency patch https://lore.kernel.org/all/20231122211218.607757-1-afd@ti.com/ on top of: next 054222eb68f6 Merge branch '2023-11-22-TI-K3-cleanups' into next
platforms tested: beagleplay-gp-uart j721s2-evm am68_sk-fs j721e-sk j721e-idk-gw j7200-hsevm j7200-evm am64xx-hsevm am64xx_sk-fs am62xx_sk-fs am62xx-sk am62axx_sk-fs
Andrew Davis
Nishanth Menon
