[PATCH] arm: dts: ls1088a-rdb: replace 'xgmii' with '10gbase-r'
When the first device tree description was added for the ethernet nodes, the 2 10G ports on the LS1088ARDB were wrongly described as 'xgmii'.
Fix this by replacing the two last occurrences of 'xgmii' in the device trees of the Layerscape DPAA2 devices.
Fixes: 68c7c008e84a ("arm: dts: ls1088ardb: add DPMAC and PHY nodes") Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com --- arch/arm/dts/fsl-ls1088a-rdb.dts | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/fsl-ls1088a-rdb.dts b/arch/arm/dts/fsl-ls1088a-rdb.dts index ad059437b534..01f8fcb61aef 100644 --- a/arch/arm/dts/fsl-ls1088a-rdb.dts +++ b/arch/arm/dts/fsl-ls1088a-rdb.dts @@ -19,13 +19,13 @@
&dpmac1 { status = "okay"; - phy-connection-type = "xgmii"; + phy-connection-type = "10gbase-r"; };
&dpmac2 { status = "okay"; phy-handle = <&mdio2_phy1>; - phy-connection-type = "xgmii"; + phy-connection-type = "10gbase-r"; };
&dpmac3 {
Reviewed-by: Peng Fan peng.fan@nxp.com
&dpmac3 {
Ioana Ciornei
Peng Fan
