[U-Boot] [PATCH 4/9] UBIFS: Implement read-only UBIFS support in U-Boot (Part 3)
This patchset adds UBIFS read-only support to U-Boot. The following commands are implemented:
- ubifsmount Mount an UBIFS volume
- ubifsls List a directory of the mounted UBIFS volume
- ubifsload Load a file from the mounted UBIFS volume to memory
The U-Boot UBIFS implementation is largely a direct copy from the current Linux version (2.6.29-rc6). As already done in the UBI version we have an "abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock() ...). This makes it possible to use the original Linux code with very little changes. And by this we can better update to later Linux versions.
I removed some of the Linux features that are not used in the U-Boot version (e.g. garbage-collection, write support).
Signed-off-by: Stefan Roese sr@denx.de CC: Artem Bityutskiy dedekind@infradead.org CC: Adrian Hunter ext-Adrian.Hunter@nokia.com --- fs/ubifs/master.c | 341 ++++++++++++++ fs/ubifs/misc.h | 310 +++++++++++++ fs/ubifs/orphan.c | 316 +++++++++++++ fs/ubifs/recovery.c | 1249 +++++++++++++++++++++++++++++++++++++++++++++++++++ fs/ubifs/replay.c | 1070 +++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 3286 insertions(+), 0 deletions(-) create mode 100644 fs/ubifs/master.c create mode 100644 fs/ubifs/misc.h create mode 100644 fs/ubifs/orphan.c create mode 100644 fs/ubifs/recovery.c create mode 100644 fs/ubifs/replay.c
diff --git a/fs/ubifs/master.c b/fs/ubifs/master.c new file mode 100644 index 0000000..3f2926e --- /dev/null +++ b/fs/ubifs/master.c @@ -0,0 +1,341 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Artem Bityutskiy (Битюцкий Артём) + * Adrian Hunter + */ + +/* This file implements reading and writing the master node */ + +#include "ubifs.h" + +/** + * scan_for_master - search the valid master node. + * @c: UBIFS file-system description object + * + * This function scans the master node LEBs and search for the latest master + * node. Returns zero in case of success and a negative error code in case of + * failure. + */ +static int scan_for_master(struct ubifs_info *c) +{ + struct ubifs_scan_leb *sleb; + struct ubifs_scan_node *snod; + int lnum, offs = 0, nodes_cnt; + + lnum = UBIFS_MST_LNUM; + + sleb = ubifs_scan(c, lnum, 0, c->sbuf); + if (IS_ERR(sleb)) + return PTR_ERR(sleb); + nodes_cnt = sleb->nodes_cnt; + if (nodes_cnt > 0) { + snod = list_entry(sleb->nodes.prev, struct ubifs_scan_node, + list); + if (snod->type != UBIFS_MST_NODE) + goto out; + memcpy(c->mst_node, snod->node, snod->len); + offs = snod->offs; + } + ubifs_scan_destroy(sleb); + + lnum += 1; + + sleb = ubifs_scan(c, lnum, 0, c->sbuf); + if (IS_ERR(sleb)) + return PTR_ERR(sleb); + if (sleb->nodes_cnt != nodes_cnt) + goto out; + if (!sleb->nodes_cnt) + goto out; + snod = list_entry(sleb->nodes.prev, struct ubifs_scan_node, list); + if (snod->type != UBIFS_MST_NODE) + goto out; + if (snod->offs != offs) + goto out; + if (memcmp((void *)c->mst_node + UBIFS_CH_SZ, + (void *)snod->node + UBIFS_CH_SZ, + UBIFS_MST_NODE_SZ - UBIFS_CH_SZ)) + goto out; + c->mst_offs = offs; + ubifs_scan_destroy(sleb); + return 0; + +out: + ubifs_scan_destroy(sleb); + return -EINVAL; +} + +/** + * validate_master - validate master node. + * @c: UBIFS file-system description object + * + * This function validates data which was read from master node. Returns zero + * if the data is all right and %-EINVAL if not. + */ +static int validate_master(const struct ubifs_info *c) +{ + long long main_sz; + int err; + + if (c->max_sqnum >= SQNUM_WATERMARK) { + err = 1; + goto out; + } + + if (c->cmt_no >= c->max_sqnum) { + err = 2; + goto out; + } + + if (c->highest_inum >= INUM_WATERMARK) { + err = 3; + goto out; + } + + if (c->lhead_lnum < UBIFS_LOG_LNUM || + c->lhead_lnum >= UBIFS_LOG_LNUM + c->log_lebs || + c->lhead_offs < 0 || c->lhead_offs >= c->leb_size || + c->lhead_offs & (c->min_io_size - 1)) { + err = 4; + goto out; + } + + if (c->zroot.lnum >= c->leb_cnt || c->zroot.lnum < c->main_first || + c->zroot.offs >= c->leb_size || c->zroot.offs & 7) { + err = 5; + goto out; + } + + if (c->zroot.len < c->ranges[UBIFS_IDX_NODE].min_len || + c->zroot.len > c->ranges[UBIFS_IDX_NODE].max_len) { + err = 6; + goto out; + } + + if (c->gc_lnum >= c->leb_cnt || c->gc_lnum < c->main_first) { + err = 7; + goto out; + } + + if (c->ihead_lnum >= c->leb_cnt || c->ihead_lnum < c->main_first || + c->ihead_offs % c->min_io_size || c->ihead_offs < 0 || + c->ihead_offs > c->leb_size || c->ihead_offs & 7) { + err = 8; + goto out; + } + + main_sz = (long long)c->main_lebs * c->leb_size; + if (c->old_idx_sz & 7 || c->old_idx_sz >= main_sz) { + err = 9; + goto out; + } + + if (c->lpt_lnum < c->lpt_first || c->lpt_lnum > c->lpt_last || + c->lpt_offs < 0 || c->lpt_offs + c->nnode_sz > c->leb_size) { + err = 10; + goto out; + } + + if (c->nhead_lnum < c->lpt_first || c->nhead_lnum > c->lpt_last || + c->nhead_offs < 0 || c->nhead_offs % c->min_io_size || + c->nhead_offs > c->leb_size) { + err = 11; + goto out; + } + + if (c->ltab_lnum < c->lpt_first || c->ltab_lnum > c->lpt_last || + c->ltab_offs < 0 || + c->ltab_offs + c->ltab_sz > c->leb_size) { + err = 12; + goto out; + } + + if (c->big_lpt && (c->lsave_lnum < c->lpt_first || + c->lsave_lnum > c->lpt_last || c->lsave_offs < 0 || + c->lsave_offs + c->lsave_sz > c->leb_size)) { + err = 13; + goto out; + } + + if (c->lscan_lnum < c->main_first || c->lscan_lnum >= c->leb_cnt) { + err = 14; + goto out; + } + + if (c->lst.empty_lebs < 0 || c->lst.empty_lebs > c->main_lebs - 2) { + err = 15; + goto out; + } + + if (c->lst.idx_lebs < 0 || c->lst.idx_lebs > c->main_lebs - 1) { + err = 16; + goto out; + } + + if (c->lst.total_free < 0 || c->lst.total_free > main_sz || + c->lst.total_free & 7) { + err = 17; + goto out; + } + + if (c->lst.total_dirty < 0 || (c->lst.total_dirty & 7)) { + err = 18; + goto out; + } + + if (c->lst.total_used < 0 || (c->lst.total_used & 7)) { + err = 19; + goto out; + } + + if (c->lst.total_free + c->lst.total_dirty + + c->lst.total_used > main_sz) { + err = 20; + goto out; + } + + if (c->lst.total_dead + c->lst.total_dark + + c->lst.total_used + c->old_idx_sz > main_sz) { + err = 21; + goto out; + } + + if (c->lst.total_dead < 0 || + c->lst.total_dead > c->lst.total_free + c->lst.total_dirty || + c->lst.total_dead & 7) { + err = 22; + goto out; + } + + if (c->lst.total_dark < 0 || + c->lst.total_dark > c->lst.total_free + c->lst.total_dirty || + c->lst.total_dark & 7) { + err = 23; + goto out; + } + + return 0; + +out: + ubifs_err("bad master node at offset %d error %d", c->mst_offs, err); + dbg_dump_node(c, c->mst_node); + return -EINVAL; +} + +/** + * ubifs_read_master - read master node. + * @c: UBIFS file-system description object + * + * This function finds and reads the master node during file-system mount. If + * the flash is empty, it creates default master node as well. Returns zero in + * case of success and a negative error code in case of failure. + */ +int ubifs_read_master(struct ubifs_info *c) +{ + int err, old_leb_cnt; + + c->mst_node = kzalloc(c->mst_node_alsz, GFP_KERNEL); + if (!c->mst_node) + return -ENOMEM; + + err = scan_for_master(c); + if (err) { + err = ubifs_recover_master_node(c); + if (err) + /* + * Note, we do not free 'c->mst_node' here because the + * unmount routine will take care of this. + */ + return err; + } + + /* Make sure that the recovery flag is clear */ + c->mst_node->flags &= cpu_to_le32(~UBIFS_MST_RCVRY); + + c->max_sqnum = le64_to_cpu(c->mst_node->ch.sqnum); + c->highest_inum = le64_to_cpu(c->mst_node->highest_inum); + c->cmt_no = le64_to_cpu(c->mst_node->cmt_no); + c->zroot.lnum = le32_to_cpu(c->mst_node->root_lnum); + c->zroot.offs = le32_to_cpu(c->mst_node->root_offs); + c->zroot.len = le32_to_cpu(c->mst_node->root_len); + c->lhead_lnum = le32_to_cpu(c->mst_node->log_lnum); + c->gc_lnum = le32_to_cpu(c->mst_node->gc_lnum); + c->ihead_lnum = le32_to_cpu(c->mst_node->ihead_lnum); + c->ihead_offs = le32_to_cpu(c->mst_node->ihead_offs); + c->old_idx_sz = le64_to_cpu(c->mst_node->index_size); + c->lpt_lnum = le32_to_cpu(c->mst_node->lpt_lnum); + c->lpt_offs = le32_to_cpu(c->mst_node->lpt_offs); + c->nhead_lnum = le32_to_cpu(c->mst_node->nhead_lnum); + c->nhead_offs = le32_to_cpu(c->mst_node->nhead_offs); + c->ltab_lnum = le32_to_cpu(c->mst_node->ltab_lnum); + c->ltab_offs = le32_to_cpu(c->mst_node->ltab_offs); + c->lsave_lnum = le32_to_cpu(c->mst_node->lsave_lnum); + c->lsave_offs = le32_to_cpu(c->mst_node->lsave_offs); + c->lscan_lnum = le32_to_cpu(c->mst_node->lscan_lnum); + c->lst.empty_lebs = le32_to_cpu(c->mst_node->empty_lebs); + c->lst.idx_lebs = le32_to_cpu(c->mst_node->idx_lebs); + old_leb_cnt = le32_to_cpu(c->mst_node->leb_cnt); + c->lst.total_free = le64_to_cpu(c->mst_node->total_free); + c->lst.total_dirty = le64_to_cpu(c->mst_node->total_dirty); + c->lst.total_used = le64_to_cpu(c->mst_node->total_used); + c->lst.total_dead = le64_to_cpu(c->mst_node->total_dead); + c->lst.total_dark = le64_to_cpu(c->mst_node->total_dark); + + c->calc_idx_sz = c->old_idx_sz; + + if (c->mst_node->flags & cpu_to_le32(UBIFS_MST_NO_ORPHS)) + c->no_orphs = 1; + + if (old_leb_cnt != c->leb_cnt) { + /* The file system has been resized */ + int growth = c->leb_cnt - old_leb_cnt; + + if (c->leb_cnt < old_leb_cnt || + c->leb_cnt < UBIFS_MIN_LEB_CNT) { + ubifs_err("bad leb_cnt on master node"); + dbg_dump_node(c, c->mst_node); + return -EINVAL; + } + + dbg_mnt("Auto resizing (master) from %d LEBs to %d LEBs", + old_leb_cnt, c->leb_cnt); + c->lst.empty_lebs += growth; + c->lst.total_free += growth * (long long)c->leb_size; + c->lst.total_dark += growth * (long long)c->dark_wm; + + /* + * Reflect changes back onto the master node. N.B. the master + * node gets written immediately whenever mounting (or + * remounting) in read-write mode, so we do not need to write it + * here. + */ + c->mst_node->leb_cnt = cpu_to_le32(c->leb_cnt); + c->mst_node->empty_lebs = cpu_to_le32(c->lst.empty_lebs); + c->mst_node->total_free = cpu_to_le64(c->lst.total_free); + c->mst_node->total_dark = cpu_to_le64(c->lst.total_dark); + } + + err = validate_master(c); + if (err) + return err; + + err = dbg_old_index_check_init(c, &c->zroot); + + return err; +} diff --git a/fs/ubifs/misc.h b/fs/ubifs/misc.h new file mode 100644 index 0000000..b745d86 --- /dev/null +++ b/fs/ubifs/misc.h @@ -0,0 +1,310 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Artem Bityutskiy (Битюцкий Артём) + * Adrian Hunter + */ + +/* + * This file contains miscellaneous helper functions. + */ + +#ifndef __UBIFS_MISC_H__ +#define __UBIFS_MISC_H__ + +/** + * ubifs_zn_dirty - check if znode is dirty. + * @znode: znode to check + * + * This helper function returns %1 if @znode is dirty and %0 otherwise. + */ +static inline int ubifs_zn_dirty(const struct ubifs_znode *znode) +{ + return !!test_bit(DIRTY_ZNODE, &znode->flags); +} + +/** + * ubifs_wake_up_bgt - wake up background thread. + * @c: UBIFS file-system description object + */ +static inline void ubifs_wake_up_bgt(struct ubifs_info *c) +{ + if (c->bgt && !c->need_bgt) { + c->need_bgt = 1; + wake_up_process(c->bgt); + } +} + +/** + * ubifs_tnc_find_child - find next child in znode. + * @znode: znode to search at + * @start: the zbranch index to start at + * + * This helper function looks for znode child starting at index @start. Returns + * the child or %NULL if no children were found. + */ +static inline struct ubifs_znode * +ubifs_tnc_find_child(struct ubifs_znode *znode, int start) +{ + while (start < znode->child_cnt) { + if (znode->zbranch[start].znode) + return znode->zbranch[start].znode; + start += 1; + } + + return NULL; +} + +/** + * ubifs_inode - get UBIFS inode information by VFS 'struct inode' object. + * @inode: the VFS 'struct inode' pointer + */ +static inline struct ubifs_inode *ubifs_inode(const struct inode *inode) +{ + return container_of(inode, struct ubifs_inode, vfs_inode); +} + +/** + * ubifs_compr_present - check if compressor was compiled in. + * @compr_type: compressor type to check + * + * This function returns %1 of compressor of type @compr_type is present, and + * %0 if not. + */ +static inline int ubifs_compr_present(int compr_type) +{ + ubifs_assert(compr_type >= 0 && compr_type < UBIFS_COMPR_TYPES_CNT); + return !!ubifs_compressors[compr_type]->capi_name; +} + +/** + * ubifs_compr_name - get compressor name string by its type. + * @compr_type: compressor type + * + * This function returns compressor type string. + */ +static inline const char *ubifs_compr_name(int compr_type) +{ + ubifs_assert(compr_type >= 0 && compr_type < UBIFS_COMPR_TYPES_CNT); + return ubifs_compressors[compr_type]->name; +} + +/** + * ubifs_wbuf_sync - synchronize write-buffer. + * @wbuf: write-buffer to synchronize + * + * This is the same as as 'ubifs_wbuf_sync_nolock()' but it does not assume + * that the write-buffer is already locked. + */ +static inline int ubifs_wbuf_sync(struct ubifs_wbuf *wbuf) +{ + int err; + + mutex_lock_nested(&wbuf->io_mutex, wbuf->jhead); + err = ubifs_wbuf_sync_nolock(wbuf); + mutex_unlock(&wbuf->io_mutex); + return err; +} + +/** + * ubifs_leb_unmap - unmap an LEB. + * @c: UBIFS file-system description object + * @lnum: LEB number to unmap + * + * This function returns %0 on success and a negative error code on failure. + */ +static inline int ubifs_leb_unmap(const struct ubifs_info *c, int lnum) +{ + int err; + + if (c->ro_media) + return -EROFS; + err = ubi_leb_unmap(c->ubi, lnum); + if (err) { + ubifs_err("unmap LEB %d failed, error %d", lnum, err); + return err; + } + + return 0; +} + +/** + * ubifs_leb_write - write to a LEB. + * @c: UBIFS file-system description object + * @lnum: LEB number to write + * @buf: buffer to write from + * @offs: offset within LEB to write to + * @len: length to write + * @dtype: data type + * + * This function returns %0 on success and a negative error code on failure. + */ +static inline int ubifs_leb_write(const struct ubifs_info *c, int lnum, + const void *buf, int offs, int len, int dtype) +{ + int err; + + if (c->ro_media) + return -EROFS; + err = ubi_leb_write(c->ubi, lnum, buf, offs, len, dtype); + if (err) { + ubifs_err("writing %d bytes at %d:%d, error %d", + len, lnum, offs, err); + return err; + } + + return 0; +} + +/** + * ubifs_leb_change - atomic LEB change. + * @c: UBIFS file-system description object + * @lnum: LEB number to write + * @buf: buffer to write from + * @len: length to write + * @dtype: data type + * + * This function returns %0 on success and a negative error code on failure. + */ +static inline int ubifs_leb_change(const struct ubifs_info *c, int lnum, + const void *buf, int len, int dtype) +{ + int err; + + if (c->ro_media) + return -EROFS; + err = ubi_leb_change(c->ubi, lnum, buf, len, dtype); + if (err) { + ubifs_err("changing %d bytes in LEB %d, error %d", + len, lnum, err); + return err; + } + + return 0; +} + +/** + * ubifs_add_dirt - add dirty space to LEB properties. + * @c: the UBIFS file-system description object + * @lnum: LEB to add dirty space for + * @dirty: dirty space to add + * + * This is a helper function which increased amount of dirty LEB space. Returns + * zero in case of success and a negative error code in case of failure. + */ +static inline int ubifs_add_dirt(struct ubifs_info *c, int lnum, int dirty) +{ + return ubifs_update_one_lp(c, lnum, LPROPS_NC, dirty, 0, 0); +} + +/** + * ubifs_return_leb - return LEB to lprops. + * @c: the UBIFS file-system description object + * @lnum: LEB to return + * + * This helper function cleans the "taken" flag of a logical eraseblock in the + * lprops. Returns zero in case of success and a negative error code in case of + * failure. + */ +static inline int ubifs_return_leb(struct ubifs_info *c, int lnum) +{ + return ubifs_change_one_lp(c, lnum, LPROPS_NC, LPROPS_NC, 0, + LPROPS_TAKEN, 0); +} + +/** + * ubifs_idx_node_sz - return index node size. + * @c: the UBIFS file-system description object + * @child_cnt: number of children of this index node + */ +static inline int ubifs_idx_node_sz(const struct ubifs_info *c, int child_cnt) +{ + return UBIFS_IDX_NODE_SZ + (UBIFS_BRANCH_SZ + c->key_len) * child_cnt; +} + +/** + * ubifs_idx_branch - return pointer to an index branch. + * @c: the UBIFS file-system description object + * @idx: index node + * @bnum: branch number + */ +static inline +struct ubifs_branch *ubifs_idx_branch(const struct ubifs_info *c, + const struct ubifs_idx_node *idx, + int bnum) +{ + return (struct ubifs_branch *)((void *)idx->branches + + (UBIFS_BRANCH_SZ + c->key_len) * bnum); +} + +/** + * ubifs_idx_key - return pointer to an index key. + * @c: the UBIFS file-system description object + * @idx: index node + */ +static inline void *ubifs_idx_key(const struct ubifs_info *c, + const struct ubifs_idx_node *idx) +{ + return (void *)((struct ubifs_branch *)idx->branches)->key; +} + +/** + * ubifs_tnc_lookup - look up a file-system node. + * @c: UBIFS file-system description object + * @key: node key to lookup + * @node: the node is returned here + * + * This function look up and reads node with key @key. The caller has to make + * sure the @node buffer is large enough to fit the node. Returns zero in case + * of success, %-ENOENT if the node was not found, and a negative error code in + * case of failure. + */ +static inline int ubifs_tnc_lookup(struct ubifs_info *c, + const union ubifs_key *key, void *node) +{ + return ubifs_tnc_locate(c, key, node, NULL, NULL); +} + +/** + * ubifs_get_lprops - get reference to LEB properties. + * @c: the UBIFS file-system description object + * + * This function locks lprops. Lprops have to be unlocked by + * 'ubifs_release_lprops()'. + */ +static inline void ubifs_get_lprops(struct ubifs_info *c) +{ + mutex_lock(&c->lp_mutex); +} + +/** + * ubifs_release_lprops - release lprops lock. + * @c: the UBIFS file-system description object + * + * This function has to be called after each 'ubifs_get_lprops()' call to + * unlock lprops. + */ +static inline void ubifs_release_lprops(struct ubifs_info *c) +{ + ubifs_assert(mutex_is_locked(&c->lp_mutex)); + ubifs_assert(c->lst.empty_lebs >= 0 && + c->lst.empty_lebs <= c->main_lebs); + mutex_unlock(&c->lp_mutex); +} + +#endif /* __UBIFS_MISC_H__ */ diff --git a/fs/ubifs/orphan.c b/fs/ubifs/orphan.c new file mode 100644 index 0000000..d091031 --- /dev/null +++ b/fs/ubifs/orphan.c @@ -0,0 +1,316 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Author: Adrian Hunter + */ + +#include "ubifs.h" + +/* + * An orphan is an inode number whose inode node has been committed to the index + * with a link count of zero. That happens when an open file is deleted + * (unlinked) and then a commit is run. In the normal course of events the inode + * would be deleted when the file is closed. However in the case of an unclean + * unmount, orphans need to be accounted for. After an unclean unmount, the + * orphans' inodes must be deleted which means either scanning the entire index + * looking for them, or keeping a list on flash somewhere. This unit implements + * the latter approach. + * + * The orphan area is a fixed number of LEBs situated between the LPT area and + * the main area. The number of orphan area LEBs is specified when the file + * system is created. The minimum number is 1. The size of the orphan area + * should be so that it can hold the maximum number of orphans that are expected + * to ever exist at one time. + * + * The number of orphans that can fit in a LEB is: + * + * (c->leb_size - UBIFS_ORPH_NODE_SZ) / sizeof(__le64) + * + * For example: a 15872 byte LEB can fit 1980 orphans so 1 LEB may be enough. + * + * Orphans are accumulated in a rb-tree. When an inode's link count drops to + * zero, the inode number is added to the rb-tree. It is removed from the tree + * when the inode is deleted. Any new orphans that are in the orphan tree when + * the commit is run, are written to the orphan area in 1 or more orphan nodes. + * If the orphan area is full, it is consolidated to make space. There is + * always enough space because validation prevents the user from creating more + * than the maximum number of orphans allowed. + */ + +/** + * tot_avail_orphs - calculate total space. + * @c: UBIFS file-system description object + * + * This function returns the number of orphans that can be written in half + * the total space. That leaves half the space for adding new orphans. + */ +static int tot_avail_orphs(struct ubifs_info *c) +{ + int avail_lebs, avail; + + avail_lebs = c->orph_lebs; + avail = avail_lebs * + ((c->leb_size - UBIFS_ORPH_NODE_SZ) / sizeof(__le64)); + return avail / 2; +} + +/** + * ubifs_clear_orphans - erase all LEBs used for orphans. + * @c: UBIFS file-system description object + * + * If recovery is not required, then the orphans from the previous session + * are not needed. This function locates the LEBs used to record + * orphans, and un-maps them. + */ +int ubifs_clear_orphans(struct ubifs_info *c) +{ + int lnum, err; + + for (lnum = c->orph_first; lnum <= c->orph_last; lnum++) { + err = ubifs_leb_unmap(c, lnum); + if (err) + return err; + } + c->ohead_lnum = c->orph_first; + c->ohead_offs = 0; + return 0; +} + +/** + * insert_dead_orphan - insert an orphan. + * @c: UBIFS file-system description object + * @inum: orphan inode number + * + * This function is a helper to the 'do_kill_orphans()' function. The orphan + * must be kept until the next commit, so it is added to the rb-tree and the + * deletion list. + */ +static int insert_dead_orphan(struct ubifs_info *c, ino_t inum) +{ + struct ubifs_orphan *orphan, *o; + struct rb_node **p, *parent = NULL; + + orphan = kzalloc(sizeof(struct ubifs_orphan), GFP_KERNEL); + if (!orphan) + return -ENOMEM; + orphan->inum = inum; + + p = &c->orph_tree.rb_node; + while (*p) { + parent = *p; + o = rb_entry(parent, struct ubifs_orphan, rb); + if (inum < o->inum) + p = &(*p)->rb_left; + else if (inum > o->inum) + p = &(*p)->rb_right; + else { + /* Already added - no problem */ + kfree(orphan); + return 0; + } + } + c->tot_orphans += 1; + rb_link_node(&orphan->rb, parent, p); + rb_insert_color(&orphan->rb, &c->orph_tree); + list_add_tail(&orphan->list, &c->orph_list); + orphan->dnext = c->orph_dnext; + c->orph_dnext = orphan; + dbg_mnt("ino %lu, new %d, tot %d", (unsigned long)inum, + c->new_orphans, c->tot_orphans); + return 0; +} + +/** + * do_kill_orphans - remove orphan inodes from the index. + * @c: UBIFS file-system description object + * @sleb: scanned LEB + * @last_cmt_no: cmt_no of last orphan node read is passed and returned here + * @outofdate: whether the LEB is out of date is returned here + * @last_flagged: whether the end orphan node is encountered + * + * This function is a helper to the 'kill_orphans()' function. It goes through + * every orphan node in a LEB and for every inode number recorded, removes + * all keys for that inode from the TNC. + */ +static int do_kill_orphans(struct ubifs_info *c, struct ubifs_scan_leb *sleb, + unsigned long long *last_cmt_no, int *outofdate, + int *last_flagged) +{ + struct ubifs_scan_node *snod; + struct ubifs_orph_node *orph; + unsigned long long cmt_no; + ino_t inum; + int i, n, err, first = 1; + + list_for_each_entry(snod, &sleb->nodes, list) { + if (snod->type != UBIFS_ORPH_NODE) { + ubifs_err("invalid node type %d in orphan area at " + "%d:%d", snod->type, sleb->lnum, snod->offs); + dbg_dump_node(c, snod->node); + return -EINVAL; + } + + orph = snod->node; + + /* Check commit number */ + cmt_no = le64_to_cpu(orph->cmt_no) & LLONG_MAX; + /* + * The commit number on the master node may be less, because + * of a failed commit. If there are several failed commits in a + * row, the commit number written on orphan nodes will continue + * to increase (because the commit number is adjusted here) even + * though the commit number on the master node stays the same + * because the master node has not been re-written. + */ + if (cmt_no > c->cmt_no) + c->cmt_no = cmt_no; + if (cmt_no < *last_cmt_no && *last_flagged) { + /* + * The last orphan node had a higher commit number and + * was flagged as the last written for that commit + * number. That makes this orphan node, out of date. + */ + if (!first) { + ubifs_err("out of order commit number %llu in " + "orphan node at %d:%d", + cmt_no, sleb->lnum, snod->offs); + dbg_dump_node(c, snod->node); + return -EINVAL; + } + dbg_rcvry("out of date LEB %d", sleb->lnum); + *outofdate = 1; + return 0; + } + + if (first) + first = 0; + + n = (le32_to_cpu(orph->ch.len) - UBIFS_ORPH_NODE_SZ) >> 3; + for (i = 0; i < n; i++) { + inum = le64_to_cpu(orph->inos[i]); + dbg_rcvry("deleting orphaned inode %lu", + (unsigned long)inum); + err = ubifs_tnc_remove_ino(c, inum); + if (err) + return err; + err = insert_dead_orphan(c, inum); + if (err) + return err; + } + + *last_cmt_no = cmt_no; + if (le64_to_cpu(orph->cmt_no) & (1ULL << 63)) { + dbg_rcvry("last orph node for commit %llu at %d:%d", + cmt_no, sleb->lnum, snod->offs); + *last_flagged = 1; + } else + *last_flagged = 0; + } + + return 0; +} + +/** + * kill_orphans - remove all orphan inodes from the index. + * @c: UBIFS file-system description object + * + * If recovery is required, then orphan inodes recorded during the previous + * session (which ended with an unclean unmount) must be deleted from the index. + * This is done by updating the TNC, but since the index is not updated until + * the next commit, the LEBs where the orphan information is recorded are not + * erased until the next commit. + */ +static int kill_orphans(struct ubifs_info *c) +{ + unsigned long long last_cmt_no = 0; + int lnum, err = 0, outofdate = 0, last_flagged = 0; + + c->ohead_lnum = c->orph_first; + c->ohead_offs = 0; + /* Check no-orphans flag and skip this if no orphans */ + if (c->no_orphs) { + dbg_rcvry("no orphans"); + return 0; + } + /* + * Orph nodes always start at c->orph_first and are written to each + * successive LEB in turn. Generally unused LEBs will have been unmapped + * but may contain out of date orphan nodes if the unmap didn't go + * through. In addition, the last orphan node written for each commit is + * marked (top bit of orph->cmt_no is set to 1). It is possible that + * there are orphan nodes from the next commit (i.e. the commit did not + * complete successfully). In that case, no orphans will have been lost + * due to the way that orphans are written, and any orphans added will + * be valid orphans anyway and so can be deleted. + */ + for (lnum = c->orph_first; lnum <= c->orph_last; lnum++) { + struct ubifs_scan_leb *sleb; + + dbg_rcvry("LEB %d", lnum); + sleb = ubifs_scan(c, lnum, 0, c->sbuf); + if (IS_ERR(sleb)) { + sleb = ubifs_recover_leb(c, lnum, 0, c->sbuf, 0); + if (IS_ERR(sleb)) { + err = PTR_ERR(sleb); + break; + } + } + err = do_kill_orphans(c, sleb, &last_cmt_no, &outofdate, + &last_flagged); + if (err || outofdate) { + ubifs_scan_destroy(sleb); + break; + } + if (sleb->endpt) { + c->ohead_lnum = lnum; + c->ohead_offs = sleb->endpt; + } + ubifs_scan_destroy(sleb); + } + return err; +} + +/** + * ubifs_mount_orphans - delete orphan inodes and erase LEBs that recorded them. + * @c: UBIFS file-system description object + * @unclean: indicates recovery from unclean unmount + * @read_only: indicates read only mount + * + * This function is called when mounting to erase orphans from the previous + * session. If UBIFS was not unmounted cleanly, then the inodes recorded as + * orphans are deleted. + */ +int ubifs_mount_orphans(struct ubifs_info *c, int unclean, int read_only) +{ + int err = 0; + + c->max_orphans = tot_avail_orphs(c); + + if (!read_only) { + c->orph_buf = vmalloc(c->leb_size); + if (!c->orph_buf) + return -ENOMEM; + } + + if (unclean) + err = kill_orphans(c); + else if (!read_only) + err = ubifs_clear_orphans(c); + + return err; +} diff --git a/fs/ubifs/recovery.c b/fs/ubifs/recovery.c new file mode 100644 index 0000000..fe3b364 --- /dev/null +++ b/fs/ubifs/recovery.c @@ -0,0 +1,1249 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Adrian Hunter + * Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * This file implements functions needed to recover from unclean un-mounts. + * When UBIFS is mounted, it checks a flag on the master node to determine if + * an un-mount was completed sucessfully. If not, the process of mounting + * incorparates additional checking and fixing of on-flash data structures. + * UBIFS always cleans away all remnants of an unclean un-mount, so that + * errors do not accumulate. However UBIFS defers recovery if it is mounted + * read-only, and the flash is not modified in that case. + */ + +#include "ubifs.h" + +/** + * is_empty - determine whether a buffer is empty (contains all 0xff). + * @buf: buffer to clean + * @len: length of buffer + * + * This function returns %1 if the buffer is empty (contains all 0xff) otherwise + * %0 is returned. + */ +static int is_empty(void *buf, int len) +{ + uint8_t *p = buf; + int i; + + for (i = 0; i < len; i++) + if (*p++ != 0xff) + return 0; + return 1; +} + +/** + * get_master_node - get the last valid master node allowing for corruption. + * @c: UBIFS file-system description object + * @lnum: LEB number + * @pbuf: buffer containing the LEB read, is returned here + * @mst: master node, if found, is returned here + * @cor: corruption, if found, is returned here + * + * This function allocates a buffer, reads the LEB into it, and finds and + * returns the last valid master node allowing for one area of corruption. + * The corrupt area, if there is one, must be consistent with the assumption + * that it is the result of an unclean unmount while the master node was being + * written. Under those circumstances, it is valid to use the previously written + * master node. + * + * This function returns %0 on success and a negative error code on failure. + */ +static int get_master_node(const struct ubifs_info *c, int lnum, void **pbuf, + struct ubifs_mst_node **mst, void **cor) +{ + const int sz = c->mst_node_alsz; + int err, offs, len; + void *sbuf, *buf; + + sbuf = vmalloc(c->leb_size); + if (!sbuf) + return -ENOMEM; + + err = ubi_read(c->ubi, lnum, sbuf, 0, c->leb_size); + if (err && err != -EBADMSG) + goto out_free; + + /* Find the first position that is definitely not a node */ + offs = 0; + buf = sbuf; + len = c->leb_size; + while (offs + UBIFS_MST_NODE_SZ <= c->leb_size) { + struct ubifs_ch *ch = buf; + + if (le32_to_cpu(ch->magic) != UBIFS_NODE_MAGIC) + break; + offs += sz; + buf += sz; + len -= sz; + } + /* See if there was a valid master node before that */ + if (offs) { + int ret; + + offs -= sz; + buf -= sz; + len += sz; + ret = ubifs_scan_a_node(c, buf, len, lnum, offs, 1); + if (ret != SCANNED_A_NODE && offs) { + /* Could have been corruption so check one place back */ + offs -= sz; + buf -= sz; + len += sz; + ret = ubifs_scan_a_node(c, buf, len, lnum, offs, 1); + if (ret != SCANNED_A_NODE) + /* + * We accept only one area of corruption because + * we are assuming that it was caused while + * trying to write a master node. + */ + goto out_err; + } + if (ret == SCANNED_A_NODE) { + struct ubifs_ch *ch = buf; + + if (ch->node_type != UBIFS_MST_NODE) + goto out_err; + dbg_rcvry("found a master node at %d:%d", lnum, offs); + *mst = buf; + offs += sz; + buf += sz; + len -= sz; + } + } + /* Check for corruption */ + if (offs < c->leb_size) { + if (!is_empty(buf, min_t(int, len, sz))) { + *cor = buf; + dbg_rcvry("found corruption at %d:%d", lnum, offs); + } + offs += sz; + buf += sz; + len -= sz; + } + /* Check remaining empty space */ + if (offs < c->leb_size) + if (!is_empty(buf, len)) + goto out_err; + *pbuf = sbuf; + return 0; + +out_err: + err = -EINVAL; +out_free: + vfree(sbuf); + *mst = NULL; + *cor = NULL; + return err; +} + +/** + * write_rcvrd_mst_node - write recovered master node. + * @c: UBIFS file-system description object + * @mst: master node + * + * This function returns %0 on success and a negative error code on failure. + */ +static int write_rcvrd_mst_node(struct ubifs_info *c, + struct ubifs_mst_node *mst) +{ + int err = 0, lnum = UBIFS_MST_LNUM, sz = c->mst_node_alsz; + __le32 save_flags; + + dbg_rcvry("recovery"); + + save_flags = mst->flags; + mst->flags |= cpu_to_le32(UBIFS_MST_RCVRY); + + ubifs_prepare_node(c, mst, UBIFS_MST_NODE_SZ, 1); + err = ubi_leb_change(c->ubi, lnum, mst, sz, UBI_SHORTTERM); + if (err) + goto out; + err = ubi_leb_change(c->ubi, lnum + 1, mst, sz, UBI_SHORTTERM); + if (err) + goto out; +out: + mst->flags = save_flags; + return err; +} + +/** + * ubifs_recover_master_node - recover the master node. + * @c: UBIFS file-system description object + * + * This function recovers the master node from corruption that may occur due to + * an unclean unmount. + * + * This function returns %0 on success and a negative error code on failure. + */ +int ubifs_recover_master_node(struct ubifs_info *c) +{ + void *buf1 = NULL, *buf2 = NULL, *cor1 = NULL, *cor2 = NULL; + struct ubifs_mst_node *mst1 = NULL, *mst2 = NULL, *mst; + const int sz = c->mst_node_alsz; + int err, offs1, offs2; + + dbg_rcvry("recovery"); + + err = get_master_node(c, UBIFS_MST_LNUM, &buf1, &mst1, &cor1); + if (err) + goto out_free; + + err = get_master_node(c, UBIFS_MST_LNUM + 1, &buf2, &mst2, &cor2); + if (err) + goto out_free; + + if (mst1) { + offs1 = (void *)mst1 - buf1; + if ((le32_to_cpu(mst1->flags) & UBIFS_MST_RCVRY) && + (offs1 == 0 && !cor1)) { + /* + * mst1 was written by recovery at offset 0 with no + * corruption. + */ + dbg_rcvry("recovery recovery"); + mst = mst1; + } else if (mst2) { + offs2 = (void *)mst2 - buf2; + if (offs1 == offs2) { + /* Same offset, so must be the same */ + if (memcmp((void *)mst1 + UBIFS_CH_SZ, + (void *)mst2 + UBIFS_CH_SZ, + UBIFS_MST_NODE_SZ - UBIFS_CH_SZ)) + goto out_err; + mst = mst1; + } else if (offs2 + sz == offs1) { + /* 1st LEB was written, 2nd was not */ + if (cor1) + goto out_err; + mst = mst1; + } else if (offs1 == 0 && offs2 + sz >= c->leb_size) { + /* 1st LEB was unmapped and written, 2nd not */ + if (cor1) + goto out_err; + mst = mst1; + } else + goto out_err; + } else { + /* + * 2nd LEB was unmapped and about to be written, so + * there must be only one master node in the first LEB + * and no corruption. + */ + if (offs1 != 0 || cor1) + goto out_err; + mst = mst1; + } + } else { + if (!mst2) + goto out_err; + /* + * 1st LEB was unmapped and about to be written, so there must + * be no room left in 2nd LEB. + */ + offs2 = (void *)mst2 - buf2; + if (offs2 + sz + sz <= c->leb_size) + goto out_err; + mst = mst2; + } + + dbg_rcvry("recovered master node from LEB %d", + (mst == mst1 ? UBIFS_MST_LNUM : UBIFS_MST_LNUM + 1)); + + memcpy(c->mst_node, mst, UBIFS_MST_NODE_SZ); + + if ((c->vfs_sb->s_flags & MS_RDONLY)) { + /* Read-only mode. Keep a copy for switching to rw mode */ + c->rcvrd_mst_node = kmalloc(sz, GFP_KERNEL); + if (!c->rcvrd_mst_node) { + err = -ENOMEM; + goto out_free; + } + memcpy(c->rcvrd_mst_node, c->mst_node, UBIFS_MST_NODE_SZ); + } + + vfree(buf2); + vfree(buf1); + + return 0; + +out_err: + err = -EINVAL; +out_free: + ubifs_err("failed to recover master node"); + if (mst1) { + dbg_err("dumping first master node"); + dbg_dump_node(c, mst1); + } + if (mst2) { + dbg_err("dumping second master node"); + dbg_dump_node(c, mst2); + } + vfree(buf2); + vfree(buf1); + return err; +} + +/** + * ubifs_write_rcvrd_mst_node - write the recovered master node. + * @c: UBIFS file-system description object + * + * This function writes the master node that was recovered during mounting in + * read-only mode and must now be written because we are remounting rw. + * + * This function returns %0 on success and a negative error code on failure. + */ +int ubifs_write_rcvrd_mst_node(struct ubifs_info *c) +{ + int err; + + if (!c->rcvrd_mst_node) + return 0; + c->rcvrd_mst_node->flags |= cpu_to_le32(UBIFS_MST_DIRTY); + c->mst_node->flags |= cpu_to_le32(UBIFS_MST_DIRTY); + err = write_rcvrd_mst_node(c, c->rcvrd_mst_node); + if (err) + return err; + kfree(c->rcvrd_mst_node); + c->rcvrd_mst_node = NULL; + return 0; +} + +/** + * is_last_write - determine if an offset was in the last write to a LEB. + * @c: UBIFS file-system description object + * @buf: buffer to check + * @offs: offset to check + * + * This function returns %1 if @offs was in the last write to the LEB whose data + * is in @buf, otherwise %0 is returned. The determination is made by checking + * for subsequent empty space starting from the next min_io_size boundary (or a + * bit less than the common header size if min_io_size is one). + */ +static int is_last_write(const struct ubifs_info *c, void *buf, int offs) +{ + int empty_offs; + int check_len; + uint8_t *p; + + if (c->min_io_size == 1) { + check_len = c->leb_size - offs; + p = buf + check_len; + for (; check_len > 0; check_len--) + if (*--p != 0xff) + break; + /* + * 'check_len' is the size of the corruption which cannot be + * more than the size of 1 node if it was caused by an unclean + * unmount. + */ + if (check_len > UBIFS_MAX_NODE_SZ) + return 0; + return 1; + } + + /* + * Round up to the next c->min_io_size boundary i.e. 'offs' is in the + * last wbuf written. After that should be empty space. + */ + empty_offs = ALIGN(offs + 1, c->min_io_size); + check_len = c->leb_size - empty_offs; + p = buf + empty_offs - offs; + + for (; check_len > 0; check_len--) + if (*p++ != 0xff) + return 0; + return 1; +} + +/** + * clean_buf - clean the data from an LEB sitting in a buffer. + * @c: UBIFS file-system description object + * @buf: buffer to clean + * @lnum: LEB number to clean + * @offs: offset from which to clean + * @len: length of buffer + * + * This function pads up to the next min_io_size boundary (if there is one) and + * sets empty space to all 0xff. @buf, @offs and @len are updated to the next + * min_io_size boundary (if there is one). + */ +static void clean_buf(const struct ubifs_info *c, void **buf, int lnum, + int *offs, int *len) +{ + int empty_offs, pad_len; + + lnum = lnum; + dbg_rcvry("cleaning corruption at %d:%d", lnum, *offs); + + if (c->min_io_size == 1) { + memset(*buf, 0xff, c->leb_size - *offs); + return; + } + + ubifs_assert(!(*offs & 7)); + empty_offs = ALIGN(*offs, c->min_io_size); + pad_len = empty_offs - *offs; + ubifs_pad(c, *buf, pad_len); + *offs += pad_len; + *buf += pad_len; + *len -= pad_len; + memset(*buf, 0xff, c->leb_size - empty_offs); +} + +/** + * no_more_nodes - determine if there are no more nodes in a buffer. + * @c: UBIFS file-system description object + * @buf: buffer to check + * @len: length of buffer + * @lnum: LEB number of the LEB from which @buf was read + * @offs: offset from which @buf was read + * + * This function scans @buf for more nodes and returns %0 is a node is found and + * %1 if no more nodes are found. + */ +static int no_more_nodes(const struct ubifs_info *c, void *buf, int len, + int lnum, int offs) +{ + int skip, next_offs = 0; + + if (len > UBIFS_DATA_NODE_SZ) { + struct ubifs_ch *ch = buf; + int dlen = le32_to_cpu(ch->len); + + if (ch->node_type == UBIFS_DATA_NODE && dlen >= UBIFS_CH_SZ && + dlen <= UBIFS_MAX_DATA_NODE_SZ) + /* The corrupt node looks like a data node */ + next_offs = ALIGN(offs + dlen, 8); + } + + if (c->min_io_size == 1) + skip = 8; + else + skip = ALIGN(offs + 1, c->min_io_size) - offs; + + offs += skip; + buf += skip; + len -= skip; + while (len > 8) { + struct ubifs_ch *ch = buf; + uint32_t magic = le32_to_cpu(ch->magic); + int ret; + + if (magic == UBIFS_NODE_MAGIC) { + ret = ubifs_scan_a_node(c, buf, len, lnum, offs, 1); + if (ret == SCANNED_A_NODE || ret > 0) { + /* + * There is a small chance this is just data in + * a data node, so check that possibility. e.g. + * this is part of a file that itself contains + * a UBIFS image. + */ + if (next_offs && offs + le32_to_cpu(ch->len) <= + next_offs) + continue; + dbg_rcvry("unexpected node at %d:%d", lnum, + offs); + return 0; + } + } + offs += 8; + buf += 8; + len -= 8; + } + return 1; +} + +/** + * fix_unclean_leb - fix an unclean LEB. + * @c: UBIFS file-system description object + * @sleb: scanned LEB information + * @start: offset where scan started + */ +static int fix_unclean_leb(struct ubifs_info *c, struct ubifs_scan_leb *sleb, + int start) +{ + int lnum = sleb->lnum, endpt = start; + + /* Get the end offset of the last node we are keeping */ + if (!list_empty(&sleb->nodes)) { + struct ubifs_scan_node *snod; + + snod = list_entry(sleb->nodes.prev, + struct ubifs_scan_node, list); + endpt = snod->offs + snod->len; + } + + if ((c->vfs_sb->s_flags & MS_RDONLY) && !c->remounting_rw) { + /* Add to recovery list */ + struct ubifs_unclean_leb *ucleb; + + dbg_rcvry("need to fix LEB %d start %d endpt %d", + lnum, start, sleb->endpt); + ucleb = kzalloc(sizeof(struct ubifs_unclean_leb), GFP_NOFS); + if (!ucleb) + return -ENOMEM; + ucleb->lnum = lnum; + ucleb->endpt = endpt; + list_add_tail(&ucleb->list, &c->unclean_leb_list); + } + return 0; +} + +/** + * drop_incomplete_group - drop nodes from an incomplete group. + * @sleb: scanned LEB information + * @offs: offset of dropped nodes is returned here + * + * This function returns %1 if nodes are dropped and %0 otherwise. + */ +static int drop_incomplete_group(struct ubifs_scan_leb *sleb, int *offs) +{ + int dropped = 0; + + while (!list_empty(&sleb->nodes)) { + struct ubifs_scan_node *snod; + struct ubifs_ch *ch; + + snod = list_entry(sleb->nodes.prev, struct ubifs_scan_node, + list); + ch = snod->node; + if (ch->group_type != UBIFS_IN_NODE_GROUP) + return dropped; + dbg_rcvry("dropping node at %d:%d", sleb->lnum, snod->offs); + *offs = snod->offs; + list_del(&snod->list); + kfree(snod); + sleb->nodes_cnt -= 1; + dropped = 1; + } + return dropped; +} + +/** + * ubifs_recover_leb - scan and recover a LEB. + * @c: UBIFS file-system description object + * @lnum: LEB number + * @offs: offset + * @sbuf: LEB-sized buffer to use + * @grouped: nodes may be grouped for recovery + * + * This function does a scan of a LEB, but caters for errors that might have + * been caused by the unclean unmount from which we are attempting to recover. + * + * This function returns %0 on success and a negative error code on failure. + */ +struct ubifs_scan_leb *ubifs_recover_leb(struct ubifs_info *c, int lnum, + int offs, void *sbuf, int grouped) +{ + int err, len = c->leb_size - offs, need_clean = 0, quiet = 1; + int empty_chkd = 0, start = offs; + struct ubifs_scan_leb *sleb; + void *buf = sbuf + offs; + + dbg_rcvry("%d:%d", lnum, offs); + + sleb = ubifs_start_scan(c, lnum, offs, sbuf); + if (IS_ERR(sleb)) + return sleb; + + if (sleb->ecc) + need_clean = 1; + + while (len >= 8) { + int ret; + + dbg_scan("look at LEB %d:%d (%d bytes left)", + lnum, offs, len); + + cond_resched(); + + /* + * Scan quietly until there is an error from which we cannot + * recover + */ + ret = ubifs_scan_a_node(c, buf, len, lnum, offs, quiet); + + if (ret == SCANNED_A_NODE) { + /* A valid node, and not a padding node */ + struct ubifs_ch *ch = buf; + int node_len; + + err = ubifs_add_snod(c, sleb, buf, offs); + if (err) + goto error; + node_len = ALIGN(le32_to_cpu(ch->len), 8); + offs += node_len; + buf += node_len; + len -= node_len; + continue; + } + + if (ret > 0) { + /* Padding bytes or a valid padding node */ + offs += ret; + buf += ret; + len -= ret; + continue; + } + + if (ret == SCANNED_EMPTY_SPACE) { + if (!is_empty(buf, len)) { + if (!is_last_write(c, buf, offs)) + break; + clean_buf(c, &buf, lnum, &offs, &len); + need_clean = 1; + } + empty_chkd = 1; + break; + } + + if (ret == SCANNED_GARBAGE || ret == SCANNED_A_BAD_PAD_NODE) + if (is_last_write(c, buf, offs)) { + clean_buf(c, &buf, lnum, &offs, &len); + need_clean = 1; + empty_chkd = 1; + break; + } + + if (ret == SCANNED_A_CORRUPT_NODE) + if (no_more_nodes(c, buf, len, lnum, offs)) { + clean_buf(c, &buf, lnum, &offs, &len); + need_clean = 1; + empty_chkd = 1; + break; + } + + if (quiet) { + /* Redo the last scan but noisily */ + quiet = 0; + continue; + } + + switch (ret) { + case SCANNED_GARBAGE: + dbg_err("garbage"); + goto corrupted; + case SCANNED_A_CORRUPT_NODE: + case SCANNED_A_BAD_PAD_NODE: + dbg_err("bad node"); + goto corrupted; + default: + dbg_err("unknown"); + goto corrupted; + } + } + + if (!empty_chkd && !is_empty(buf, len)) { + if (is_last_write(c, buf, offs)) { + clean_buf(c, &buf, lnum, &offs, &len); + need_clean = 1; + } else { + ubifs_err("corrupt empty space at LEB %d:%d", + lnum, offs); + goto corrupted; + } + } + + /* Drop nodes from incomplete group */ + if (grouped && drop_incomplete_group(sleb, &offs)) { + buf = sbuf + offs; + len = c->leb_size - offs; + clean_buf(c, &buf, lnum, &offs, &len); + need_clean = 1; + } + + if (offs % c->min_io_size) { + clean_buf(c, &buf, lnum, &offs, &len); + need_clean = 1; + } + + ubifs_end_scan(c, sleb, lnum, offs); + + if (need_clean) { + err = fix_unclean_leb(c, sleb, start); + if (err) + goto error; + } + + return sleb; + +corrupted: + ubifs_scanned_corruption(c, lnum, offs, buf); + err = -EUCLEAN; +error: + ubifs_err("LEB %d scanning failed", lnum); + ubifs_scan_destroy(sleb); + return ERR_PTR(err); +} + +/** + * get_cs_sqnum - get commit start sequence number. + * @c: UBIFS file-system description object + * @lnum: LEB number of commit start node + * @offs: offset of commit start node + * @cs_sqnum: commit start sequence number is returned here + * + * This function returns %0 on success and a negative error code on failure. + */ +static int get_cs_sqnum(struct ubifs_info *c, int lnum, int offs, + unsigned long long *cs_sqnum) +{ + struct ubifs_cs_node *cs_node = NULL; + int err, ret; + + dbg_rcvry("at %d:%d", lnum, offs); + cs_node = kmalloc(UBIFS_CS_NODE_SZ, GFP_KERNEL); + if (!cs_node) + return -ENOMEM; + if (c->leb_size - offs < UBIFS_CS_NODE_SZ) + goto out_err; + err = ubi_read(c->ubi, lnum, (void *)cs_node, offs, UBIFS_CS_NODE_SZ); + if (err && err != -EBADMSG) + goto out_free; + ret = ubifs_scan_a_node(c, cs_node, UBIFS_CS_NODE_SZ, lnum, offs, 0); + if (ret != SCANNED_A_NODE) { + dbg_err("Not a valid node"); + goto out_err; + } + if (cs_node->ch.node_type != UBIFS_CS_NODE) { + dbg_err("Node a CS node, type is %d", cs_node->ch.node_type); + goto out_err; + } + if (le64_to_cpu(cs_node->cmt_no) != c->cmt_no) { + dbg_err("CS node cmt_no %llu != current cmt_no %llu", + (unsigned long long)le64_to_cpu(cs_node->cmt_no), + c->cmt_no); + goto out_err; + } + *cs_sqnum = le64_to_cpu(cs_node->ch.sqnum); + dbg_rcvry("commit start sqnum %llu", *cs_sqnum); + kfree(cs_node); + return 0; + +out_err: + err = -EINVAL; +out_free: + ubifs_err("failed to get CS sqnum"); + kfree(cs_node); + return err; +} + +/** + * ubifs_recover_log_leb - scan and recover a log LEB. + * @c: UBIFS file-system description object + * @lnum: LEB number + * @offs: offset + * @sbuf: LEB-sized buffer to use + * + * This function does a scan of a LEB, but caters for errors that might have + * been caused by the unclean unmount from which we are attempting to recover. + * + * This function returns %0 on success and a negative error code on failure. + */ +struct ubifs_scan_leb *ubifs_recover_log_leb(struct ubifs_info *c, int lnum, + int offs, void *sbuf) +{ + struct ubifs_scan_leb *sleb; + int next_lnum; + + dbg_rcvry("LEB %d", lnum); + next_lnum = lnum + 1; + if (next_lnum >= UBIFS_LOG_LNUM + c->log_lebs) + next_lnum = UBIFS_LOG_LNUM; + if (next_lnum != c->ltail_lnum) { + /* + * We can only recover at the end of the log, so check that the + * next log LEB is empty or out of date. + */ + sleb = ubifs_scan(c, next_lnum, 0, sbuf); + if (IS_ERR(sleb)) + return sleb; + if (sleb->nodes_cnt) { + struct ubifs_scan_node *snod; + unsigned long long cs_sqnum = c->cs_sqnum; + + snod = list_entry(sleb->nodes.next, + struct ubifs_scan_node, list); + if (cs_sqnum == 0) { + int err; + + err = get_cs_sqnum(c, lnum, offs, &cs_sqnum); + if (err) { + ubifs_scan_destroy(sleb); + return ERR_PTR(err); + } + } + if (snod->sqnum > cs_sqnum) { + ubifs_err("unrecoverable log corruption " + "in LEB %d", lnum); + ubifs_scan_destroy(sleb); + return ERR_PTR(-EUCLEAN); + } + } + ubifs_scan_destroy(sleb); + } + return ubifs_recover_leb(c, lnum, offs, sbuf, 0); +} + +/** + * recover_head - recover a head. + * @c: UBIFS file-system description object + * @lnum: LEB number of head to recover + * @offs: offset of head to recover + * @sbuf: LEB-sized buffer to use + * + * This function ensures that there is no data on the flash at a head location. + * + * This function returns %0 on success and a negative error code on failure. + */ +static int recover_head(const struct ubifs_info *c, int lnum, int offs, + void *sbuf) +{ + int len, err, need_clean = 0; + + if (c->min_io_size > 1) + len = c->min_io_size; + else + len = 512; + if (offs + len > c->leb_size) + len = c->leb_size - offs; + + if (!len) + return 0; + + /* Read at the head location and check it is empty flash */ + err = ubi_read(c->ubi, lnum, sbuf, offs, len); + if (err) + need_clean = 1; + else { + uint8_t *p = sbuf; + + while (len--) + if (*p++ != 0xff) { + need_clean = 1; + break; + } + } + + if (need_clean) { + dbg_rcvry("cleaning head at %d:%d", lnum, offs); + if (offs == 0) + return ubifs_leb_unmap(c, lnum); + err = ubi_read(c->ubi, lnum, sbuf, 0, offs); + if (err) + return err; + return ubi_leb_change(c->ubi, lnum, sbuf, offs, UBI_UNKNOWN); + } + + return 0; +} + +/** + * ubifs_recover_inl_heads - recover index and LPT heads. + * @c: UBIFS file-system description object + * @sbuf: LEB-sized buffer to use + * + * This function ensures that there is no data on the flash at the index and + * LPT head locations. + * + * This deals with the recovery of a half-completed journal commit. UBIFS is + * careful never to overwrite the last version of the index or the LPT. Because + * the index and LPT are wandering trees, data from a half-completed commit will + * not be referenced anywhere in UBIFS. The data will be either in LEBs that are + * assumed to be empty and will be unmapped anyway before use, or in the index + * and LPT heads. + * + * This function returns %0 on success and a negative error code on failure. + */ +int ubifs_recover_inl_heads(const struct ubifs_info *c, void *sbuf) +{ + int err; + + ubifs_assert(!(c->vfs_sb->s_flags & MS_RDONLY) || c->remounting_rw); + + dbg_rcvry("checking index head at %d:%d", c->ihead_lnum, c->ihead_offs); + err = recover_head(c, c->ihead_lnum, c->ihead_offs, sbuf); + if (err) + return err; + + dbg_rcvry("checking LPT head at %d:%d", c->nhead_lnum, c->nhead_offs); + err = recover_head(c, c->nhead_lnum, c->nhead_offs, sbuf); + if (err) + return err; + + return 0; +} + +/** + * clean_an_unclean_leb - read and write a LEB to remove corruption. + * @c: UBIFS file-system description object + * @ucleb: unclean LEB information + * @sbuf: LEB-sized buffer to use + * + * This function reads a LEB up to a point pre-determined by the mount recovery, + * checks the nodes, and writes the result back to the flash, thereby cleaning + * off any following corruption, or non-fatal ECC errors. + * + * This function returns %0 on success and a negative error code on failure. + */ +static int clean_an_unclean_leb(const struct ubifs_info *c, + struct ubifs_unclean_leb *ucleb, void *sbuf) +{ + int err, lnum = ucleb->lnum, offs = 0, len = ucleb->endpt, quiet = 1; + void *buf = sbuf; + + dbg_rcvry("LEB %d len %d", lnum, len); + + if (len == 0) { + /* Nothing to read, just unmap it */ + err = ubifs_leb_unmap(c, lnum); + if (err) + return err; + return 0; + } + + err = ubi_read(c->ubi, lnum, buf, offs, len); + if (err && err != -EBADMSG) + return err; + + while (len >= 8) { + int ret; + + cond_resched(); + + /* Scan quietly until there is an error */ + ret = ubifs_scan_a_node(c, buf, len, lnum, offs, quiet); + + if (ret == SCANNED_A_NODE) { + /* A valid node, and not a padding node */ + struct ubifs_ch *ch = buf; + int node_len; + + node_len = ALIGN(le32_to_cpu(ch->len), 8); + offs += node_len; + buf += node_len; + len -= node_len; + continue; + } + + if (ret > 0) { + /* Padding bytes or a valid padding node */ + offs += ret; + buf += ret; + len -= ret; + continue; + } + + if (ret == SCANNED_EMPTY_SPACE) { + ubifs_err("unexpected empty space at %d:%d", + lnum, offs); + return -EUCLEAN; + } + + if (quiet) { + /* Redo the last scan but noisily */ + quiet = 0; + continue; + } + + ubifs_scanned_corruption(c, lnum, offs, buf); + return -EUCLEAN; + } + + /* Pad to min_io_size */ + len = ALIGN(ucleb->endpt, c->min_io_size); + if (len > ucleb->endpt) { + int pad_len = len - ALIGN(ucleb->endpt, 8); + + if (pad_len > 0) { + buf = c->sbuf + len - pad_len; + ubifs_pad(c, buf, pad_len); + } + } + + /* Write back the LEB atomically */ + err = ubi_leb_change(c->ubi, lnum, sbuf, len, UBI_UNKNOWN); + if (err) + return err; + + dbg_rcvry("cleaned LEB %d", lnum); + + return 0; +} + +/** + * ubifs_clean_lebs - clean LEBs recovered during read-only mount. + * @c: UBIFS file-system description object + * @sbuf: LEB-sized buffer to use + * + * This function cleans a LEB identified during recovery that needs to be + * written but was not because UBIFS was mounted read-only. This happens when + * remounting to read-write mode. + * + * This function returns %0 on success and a negative error code on failure. + */ +int ubifs_clean_lebs(const struct ubifs_info *c, void *sbuf) +{ + dbg_rcvry("recovery"); + while (!list_empty(&c->unclean_leb_list)) { + struct ubifs_unclean_leb *ucleb; + int err; + + ucleb = list_entry(c->unclean_leb_list.next, + struct ubifs_unclean_leb, list); + err = clean_an_unclean_leb(c, ucleb, sbuf); + if (err) + return err; + list_del(&ucleb->list); + kfree(ucleb); + } + return 0; +} + +/** + * struct size_entry - inode size information for recovery. + * @rb: link in the RB-tree of sizes + * @inum: inode number + * @i_size: size on inode + * @d_size: maximum size based on data nodes + * @exists: indicates whether the inode exists + * @inode: inode if pinned in memory awaiting rw mode to fix it + */ +struct size_entry { + struct rb_node rb; + ino_t inum; + loff_t i_size; + loff_t d_size; + int exists; + struct inode *inode; +}; + +/** + * add_ino - add an entry to the size tree. + * @c: UBIFS file-system description object + * @inum: inode number + * @i_size: size on inode + * @d_size: maximum size based on data nodes + * @exists: indicates whether the inode exists + */ +static int add_ino(struct ubifs_info *c, ino_t inum, loff_t i_size, + loff_t d_size, int exists) +{ + struct rb_node **p = &c->size_tree.rb_node, *parent = NULL; + struct size_entry *e; + + while (*p) { + parent = *p; + e = rb_entry(parent, struct size_entry, rb); + if (inum < e->inum) + p = &(*p)->rb_left; + else + p = &(*p)->rb_right; + } + + e = kzalloc(sizeof(struct size_entry), GFP_KERNEL); + if (!e) + return -ENOMEM; + + e->inum = inum; + e->i_size = i_size; + e->d_size = d_size; + e->exists = exists; + + rb_link_node(&e->rb, parent, p); + rb_insert_color(&e->rb, &c->size_tree); + + return 0; +} + +/** + * find_ino - find an entry on the size tree. + * @c: UBIFS file-system description object + * @inum: inode number + */ +static struct size_entry *find_ino(struct ubifs_info *c, ino_t inum) +{ + struct rb_node *p = c->size_tree.rb_node; + struct size_entry *e; + + while (p) { + e = rb_entry(p, struct size_entry, rb); + if (inum < e->inum) + p = p->rb_left; + else if (inum > e->inum) + p = p->rb_right; + else + return e; + } + return NULL; +} + +/** + * remove_ino - remove an entry from the size tree. + * @c: UBIFS file-system description object + * @inum: inode number + */ +static void remove_ino(struct ubifs_info *c, ino_t inum) +{ + struct size_entry *e = find_ino(c, inum); + + if (!e) + return; + rb_erase(&e->rb, &c->size_tree); + kfree(e); +} + +/** + * ubifs_recover_size_accum - accumulate inode sizes for recovery. + * @c: UBIFS file-system description object + * @key: node key + * @deletion: node is for a deletion + * @new_size: inode size + * + * This function has two purposes: + * 1) to ensure there are no data nodes that fall outside the inode size + * 2) to ensure there are no data nodes for inodes that do not exist + * To accomplish those purposes, a rb-tree is constructed containing an entry + * for each inode number in the journal that has not been deleted, and recording + * the size from the inode node, the maximum size of any data node (also altered + * by truncations) and a flag indicating a inode number for which no inode node + * was present in the journal. + * + * Note that there is still the possibility that there are data nodes that have + * been committed that are beyond the inode size, however the only way to find + * them would be to scan the entire index. Alternatively, some provision could + * be made to record the size of inodes at the start of commit, which would seem + * very cumbersome for a scenario that is quite unlikely and the only negative + * consequence of which is wasted space. + * + * This functions returns %0 on success and a negative error code on failure. + */ +int ubifs_recover_size_accum(struct ubifs_info *c, union ubifs_key *key, + int deletion, loff_t new_size) +{ + ino_t inum = key_inum(c, key); + struct size_entry *e; + int err; + + switch (key_type(c, key)) { + case UBIFS_INO_KEY: + if (deletion) + remove_ino(c, inum); + else { + e = find_ino(c, inum); + if (e) { + e->i_size = new_size; + e->exists = 1; + } else { + err = add_ino(c, inum, new_size, 0, 1); + if (err) + return err; + } + } + break; + case UBIFS_DATA_KEY: + e = find_ino(c, inum); + if (e) { + if (new_size > e->d_size) + e->d_size = new_size; + } else { + err = add_ino(c, inum, 0, new_size, 0); + if (err) + return err; + } + break; + case UBIFS_TRUN_KEY: + e = find_ino(c, inum); + if (e) + e->d_size = new_size; + break; + } + return 0; +} + +/** + * ubifs_recover_size - recover inode size. + * @c: UBIFS file-system description object + * + * This function attempts to fix inode size discrepancies identified by the + * 'ubifs_recover_size_accum()' function. + * + * This functions returns %0 on success and a negative error code on failure. + */ +int ubifs_recover_size(struct ubifs_info *c) +{ + struct rb_node *this = rb_first(&c->size_tree); + + while (this) { + struct size_entry *e; + int err; + + e = rb_entry(this, struct size_entry, rb); + if (!e->exists) { + union ubifs_key key; + + ino_key_init(c, &key, e->inum); + err = ubifs_tnc_lookup(c, &key, c->sbuf); + if (err && err != -ENOENT) + return err; + if (err == -ENOENT) { + /* Remove data nodes that have no inode */ + dbg_rcvry("removing ino %lu", + (unsigned long)e->inum); + err = ubifs_tnc_remove_ino(c, e->inum); + if (err) + return err; + } else { + struct ubifs_ino_node *ino = c->sbuf; + + e->exists = 1; + e->i_size = le64_to_cpu(ino->size); + } + } + if (e->exists && e->i_size < e->d_size) { + if (!e->inode && (c->vfs_sb->s_flags & MS_RDONLY)) { + /* Fix the inode size and pin it in memory */ + struct inode *inode; + + inode = ubifs_iget(c->vfs_sb, e->inum); + if (IS_ERR(inode)) + return PTR_ERR(inode); + if (inode->i_size < e->d_size) { + dbg_rcvry("ino %lu size %lld -> %lld", + (unsigned long)e->inum, + e->d_size, inode->i_size); + inode->i_size = e->d_size; + ubifs_inode(inode)->ui_size = e->d_size; + e->inode = inode; + this = rb_next(this); + continue; + } + iput(inode); + } + } + this = rb_next(this); + rb_erase(&e->rb, &c->size_tree); + kfree(e); + } + return 0; +} diff --git a/fs/ubifs/replay.c b/fs/ubifs/replay.c new file mode 100644 index 0000000..da33a14 --- /dev/null +++ b/fs/ubifs/replay.c @@ -0,0 +1,1070 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Adrian Hunter + * Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * This file contains journal replay code. It runs when the file-system is being + * mounted and requires no locking. + * + * The larger is the journal, the longer it takes to scan it, so the longer it + * takes to mount UBIFS. This is why the journal has limited size which may be + * changed depending on the system requirements. But a larger journal gives + * faster I/O speed because it writes the index less frequently. So this is a + * trade-off. Also, the journal is indexed by the in-memory index (TNC), so the + * larger is the journal, the more memory its index may consume. + */ + +#include "ubifs.h" + +/* + * Replay flags. + * + * REPLAY_DELETION: node was deleted + * REPLAY_REF: node is a reference node + */ +enum { + REPLAY_DELETION = 1, + REPLAY_REF = 2, +}; + +/** + * struct replay_entry - replay tree entry. + * @lnum: logical eraseblock number of the node + * @offs: node offset + * @len: node length + * @sqnum: node sequence number + * @flags: replay flags + * @rb: links the replay tree + * @key: node key + * @nm: directory entry name + * @old_size: truncation old size + * @new_size: truncation new size + * @free: amount of free space in a bud + * @dirty: amount of dirty space in a bud from padding and deletion nodes + * + * UBIFS journal replay must compare node sequence numbers, which means it must + * build a tree of node information to insert into the TNC. + */ +struct replay_entry { + int lnum; + int offs; + int len; + unsigned long long sqnum; + int flags; + struct rb_node rb; + union ubifs_key key; + union { + struct qstr nm; + struct { + loff_t old_size; + loff_t new_size; + }; + struct { + int free; + int dirty; + }; + }; +}; + +/** + * struct bud_entry - entry in the list of buds to replay. + * @list: next bud in the list + * @bud: bud description object + * @free: free bytes in the bud + * @sqnum: reference node sequence number + */ +struct bud_entry { + struct list_head list; + struct ubifs_bud *bud; + int free; + unsigned long long sqnum; +}; + +/** + * set_bud_lprops - set free and dirty space used by a bud. + * @c: UBIFS file-system description object + * @r: replay entry of bud + */ +static int set_bud_lprops(struct ubifs_info *c, struct replay_entry *r) +{ + const struct ubifs_lprops *lp; + int err = 0, dirty; + + ubifs_get_lprops(c); + + lp = ubifs_lpt_lookup_dirty(c, r->lnum); + if (IS_ERR(lp)) { + err = PTR_ERR(lp); + goto out; + } + + dirty = lp->dirty; + if (r->offs == 0 && (lp->free != c->leb_size || lp->dirty != 0)) { + /* + * The LEB was added to the journal with a starting offset of + * zero which means the LEB must have been empty. The LEB + * property values should be lp->free == c->leb_size and + * lp->dirty == 0, but that is not the case. The reason is that + * the LEB was garbage collected. The garbage collector resets + * the free and dirty space without recording it anywhere except + * lprops, so if there is not a commit then lprops does not have + * that information next time the file system is mounted. + * + * We do not need to adjust free space because the scan has told + * us the exact value which is recorded in the replay entry as + * r->free. + * + * However we do need to subtract from the dirty space the + * amount of space that the garbage collector reclaimed, which + * is the whole LEB minus the amount of space that was free. + */ + dbg_mnt("bud LEB %d was GC'd (%d free, %d dirty)", r->lnum, + lp->free, lp->dirty); + dbg_gc("bud LEB %d was GC'd (%d free, %d dirty)", r->lnum, + lp->free, lp->dirty); + dirty -= c->leb_size - lp->free; + /* + * If the replay order was perfect the dirty space would now be + * zero. The order is not perfect because the the journal heads + * race with each other. This is not a problem but is does mean + * that the dirty space may temporarily exceed c->leb_size + * during the replay. + */ + if (dirty != 0) + dbg_msg("LEB %d lp: %d free %d dirty " + "replay: %d free %d dirty", r->lnum, lp->free, + lp->dirty, r->free, r->dirty); + } + lp = ubifs_change_lp(c, lp, r->free, dirty + r->dirty, + lp->flags | LPROPS_TAKEN, 0); + if (IS_ERR(lp)) { + err = PTR_ERR(lp); + goto out; + } +out: + ubifs_release_lprops(c); + return err; +} + +/** + * trun_remove_range - apply a replay entry for a truncation to the TNC. + * @c: UBIFS file-system description object + * @r: replay entry of truncation + */ +static int trun_remove_range(struct ubifs_info *c, struct replay_entry *r) +{ + unsigned min_blk, max_blk; + union ubifs_key min_key, max_key; + ino_t ino; + + min_blk = r->new_size / UBIFS_BLOCK_SIZE; + if (r->new_size & (UBIFS_BLOCK_SIZE - 1)) + min_blk += 1; + + max_blk = r->old_size / UBIFS_BLOCK_SIZE; + if ((r->old_size & (UBIFS_BLOCK_SIZE - 1)) == 0) + max_blk -= 1; + + ino = key_inum(c, &r->key); + + data_key_init(c, &min_key, ino, min_blk); + data_key_init(c, &max_key, ino, max_blk); + + return ubifs_tnc_remove_range(c, &min_key, &max_key); +} + +/** + * apply_replay_entry - apply a replay entry to the TNC. + * @c: UBIFS file-system description object + * @r: replay entry to apply + * + * Apply a replay entry to the TNC. + */ +static int apply_replay_entry(struct ubifs_info *c, struct replay_entry *r) +{ + int err, deletion = ((r->flags & REPLAY_DELETION) != 0); + + dbg_mnt("LEB %d:%d len %d flgs %d sqnum %llu %s", r->lnum, + r->offs, r->len, r->flags, r->sqnum, DBGKEY(&r->key)); + + /* Set c->replay_sqnum to help deal with dangling branches. */ + c->replay_sqnum = r->sqnum; + + if (r->flags & REPLAY_REF) + err = set_bud_lprops(c, r); + else if (is_hash_key(c, &r->key)) { + if (deletion) + err = ubifs_tnc_remove_nm(c, &r->key, &r->nm); + else + err = ubifs_tnc_add_nm(c, &r->key, r->lnum, r->offs, + r->len, &r->nm); + } else { + if (deletion) + switch (key_type(c, &r->key)) { + case UBIFS_INO_KEY: + { + ino_t inum = key_inum(c, &r->key); + + err = ubifs_tnc_remove_ino(c, inum); + break; + } + case UBIFS_TRUN_KEY: + err = trun_remove_range(c, r); + break; + default: + err = ubifs_tnc_remove(c, &r->key); + break; + } + else + err = ubifs_tnc_add(c, &r->key, r->lnum, r->offs, + r->len); + if (err) + return err; + + if (c->need_recovery) + err = ubifs_recover_size_accum(c, &r->key, deletion, + r->new_size); + } + + return err; +} + +/** + * destroy_replay_tree - destroy the replay. + * @c: UBIFS file-system description object + * + * Destroy the replay tree. + */ +static void destroy_replay_tree(struct ubifs_info *c) +{ + struct rb_node *this = c->replay_tree.rb_node; + struct replay_entry *r; + + while (this) { + if (this->rb_left) { + this = this->rb_left; + continue; + } else if (this->rb_right) { + this = this->rb_right; + continue; + } + r = rb_entry(this, struct replay_entry, rb); + this = rb_parent(this); + if (this) { + if (this->rb_left == &r->rb) + this->rb_left = NULL; + else + this->rb_right = NULL; + } + if (is_hash_key(c, &r->key)) + kfree((void *)r->nm.name); + kfree(r); + } + c->replay_tree = RB_ROOT; +} + +/** + * apply_replay_tree - apply the replay tree to the TNC. + * @c: UBIFS file-system description object + * + * Apply the replay tree. + * Returns zero in case of success and a negative error code in case of + * failure. + */ +static int apply_replay_tree(struct ubifs_info *c) +{ + struct rb_node *this = rb_first(&c->replay_tree); + + while (this) { + struct replay_entry *r; + int err; + + cond_resched(); + + r = rb_entry(this, struct replay_entry, rb); + err = apply_replay_entry(c, r); + if (err) + return err; + this = rb_next(this); + } + return 0; +} + +/** + * insert_node - insert a node to the replay tree. + * @c: UBIFS file-system description object + * @lnum: node logical eraseblock number + * @offs: node offset + * @len: node length + * @key: node key + * @sqnum: sequence number + * @deletion: non-zero if this is a deletion + * @used: number of bytes in use in a LEB + * @old_size: truncation old size + * @new_size: truncation new size + * + * This function inserts a scanned non-direntry node to the replay tree. The + * replay tree is an RB-tree containing @struct replay_entry elements which are + * indexed by the sequence number. The replay tree is applied at the very end + * of the replay process. Since the tree is sorted in sequence number order, + * the older modifications are applied first. This function returns zero in + * case of success and a negative error code in case of failure. + */ +static int insert_node(struct ubifs_info *c, int lnum, int offs, int len, + union ubifs_key *key, unsigned long long sqnum, + int deletion, int *used, loff_t old_size, + loff_t new_size) +{ + struct rb_node **p = &c->replay_tree.rb_node, *parent = NULL; + struct replay_entry *r; + + if (key_inum(c, key) >= c->highest_inum) + c->highest_inum = key_inum(c, key); + + dbg_mnt("add LEB %d:%d, key %s", lnum, offs, DBGKEY(key)); + while (*p) { + parent = *p; + r = rb_entry(parent, struct replay_entry, rb); + if (sqnum < r->sqnum) { + p = &(*p)->rb_left; + continue; + } else if (sqnum > r->sqnum) { + p = &(*p)->rb_right; + continue; + } + ubifs_err("duplicate sqnum in replay"); + return -EINVAL; + } + + r = kzalloc(sizeof(struct replay_entry), GFP_KERNEL); + if (!r) + return -ENOMEM; + + if (!deletion) + *used += ALIGN(len, 8); + r->lnum = lnum; + r->offs = offs; + r->len = len; + r->sqnum = sqnum; + r->flags = (deletion ? REPLAY_DELETION : 0); + r->old_size = old_size; + r->new_size = new_size; + key_copy(c, key, &r->key); + + rb_link_node(&r->rb, parent, p); + rb_insert_color(&r->rb, &c->replay_tree); + return 0; +} + +/** + * insert_dent - insert a directory entry node into the replay tree. + * @c: UBIFS file-system description object + * @lnum: node logical eraseblock number + * @offs: node offset + * @len: node length + * @key: node key + * @name: directory entry name + * @nlen: directory entry name length + * @sqnum: sequence number + * @deletion: non-zero if this is a deletion + * @used: number of bytes in use in a LEB + * + * This function inserts a scanned directory entry node to the replay tree. + * Returns zero in case of success and a negative error code in case of + * failure. + * + * This function is also used for extended attribute entries because they are + * implemented as directory entry nodes. + */ +static int insert_dent(struct ubifs_info *c, int lnum, int offs, int len, + union ubifs_key *key, const char *name, int nlen, + unsigned long long sqnum, int deletion, int *used) +{ + struct rb_node **p = &c->replay_tree.rb_node, *parent = NULL; + struct replay_entry *r; + char *nbuf; + + if (key_inum(c, key) >= c->highest_inum) + c->highest_inum = key_inum(c, key); + + dbg_mnt("add LEB %d:%d, key %s", lnum, offs, DBGKEY(key)); + while (*p) { + parent = *p; + r = rb_entry(parent, struct replay_entry, rb); + if (sqnum < r->sqnum) { + p = &(*p)->rb_left; + continue; + } + if (sqnum > r->sqnum) { + p = &(*p)->rb_right; + continue; + } + ubifs_err("duplicate sqnum in replay"); + return -EINVAL; + } + + r = kzalloc(sizeof(struct replay_entry), GFP_KERNEL); + if (!r) + return -ENOMEM; + nbuf = kmalloc(nlen + 1, GFP_KERNEL); + if (!nbuf) { + kfree(r); + return -ENOMEM; + } + + if (!deletion) + *used += ALIGN(len, 8); + r->lnum = lnum; + r->offs = offs; + r->len = len; + r->sqnum = sqnum; + r->nm.len = nlen; + memcpy(nbuf, name, nlen); + nbuf[nlen] = '\0'; + r->nm.name = nbuf; + r->flags = (deletion ? REPLAY_DELETION : 0); + key_copy(c, key, &r->key); + + ubifs_assert(!*p); + rb_link_node(&r->rb, parent, p); + rb_insert_color(&r->rb, &c->replay_tree); + return 0; +} + +/** + * ubifs_validate_entry - validate directory or extended attribute entry node. + * @c: UBIFS file-system description object + * @dent: the node to validate + * + * This function validates directory or extended attribute entry node @dent. + * Returns zero if the node is all right and a %-EINVAL if not. + */ +int ubifs_validate_entry(struct ubifs_info *c, + const struct ubifs_dent_node *dent) +{ + int key_type = key_type_flash(c, dent->key); + int nlen = le16_to_cpu(dent->nlen); + + if (le32_to_cpu(dent->ch.len) != nlen + UBIFS_DENT_NODE_SZ + 1 || + dent->type >= UBIFS_ITYPES_CNT || + nlen > UBIFS_MAX_NLEN || dent->name[nlen] != 0 || + strnlen((char *)dent->name, nlen) != nlen || + le64_to_cpu(dent->inum) > MAX_INUM) { + ubifs_err("bad %s node", key_type == UBIFS_DENT_KEY ? + "directory entry" : "extended attribute entry"); + return -EINVAL; + } + + if (key_type != UBIFS_DENT_KEY && key_type != UBIFS_XENT_KEY) { + ubifs_err("bad key type %d", key_type); + return -EINVAL; + } + + return 0; +} + +/** + * replay_bud - replay a bud logical eraseblock. + * @c: UBIFS file-system description object + * @lnum: bud logical eraseblock number to replay + * @offs: bud start offset + * @jhead: journal head to which this bud belongs + * @free: amount of free space in the bud is returned here + * @dirty: amount of dirty space from padding and deletion nodes is returned + * here + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +static int replay_bud(struct ubifs_info *c, int lnum, int offs, int jhead, + int *free, int *dirty) +{ + int err = 0, used = 0; + struct ubifs_scan_leb *sleb; + struct ubifs_scan_node *snod; + struct ubifs_bud *bud; + + dbg_mnt("replay bud LEB %d, head %d", lnum, jhead); + if (c->need_recovery) + sleb = ubifs_recover_leb(c, lnum, offs, c->sbuf, jhead != GCHD); + else + sleb = ubifs_scan(c, lnum, offs, c->sbuf); + if (IS_ERR(sleb)) + return PTR_ERR(sleb); + + /* + * The bud does not have to start from offset zero - the beginning of + * the 'lnum' LEB may contain previously committed data. One of the + * things we have to do in replay is to correctly update lprops with + * newer information about this LEB. + * + * At this point lprops thinks that this LEB has 'c->leb_size - offs' + * bytes of free space because it only contain information about + * committed data. + * + * But we know that real amount of free space is 'c->leb_size - + * sleb->endpt', and the space in the 'lnum' LEB between 'offs' and + * 'sleb->endpt' is used by bud data. We have to correctly calculate + * how much of these data are dirty and update lprops with this + * information. + * + * The dirt in that LEB region is comprised of padding nodes, deletion + * nodes, truncation nodes and nodes which are obsoleted by subsequent + * nodes in this LEB. So instead of calculating clean space, we + * calculate used space ('used' variable). + */ + + list_for_each_entry(snod, &sleb->nodes, list) { + int deletion = 0; + + cond_resched(); + + if (snod->sqnum >= SQNUM_WATERMARK) { + ubifs_err("file system's life ended"); + goto out_dump; + } + + if (snod->sqnum > c->max_sqnum) + c->max_sqnum = snod->sqnum; + + switch (snod->type) { + case UBIFS_INO_NODE: + { + struct ubifs_ino_node *ino = snod->node; + loff_t new_size = le64_to_cpu(ino->size); + + if (le32_to_cpu(ino->nlink) == 0) + deletion = 1; + err = insert_node(c, lnum, snod->offs, snod->len, + &snod->key, snod->sqnum, deletion, + &used, 0, new_size); + break; + } + case UBIFS_DATA_NODE: + { + struct ubifs_data_node *dn = snod->node; + loff_t new_size = le32_to_cpu(dn->size) + + key_block(c, &snod->key) * + UBIFS_BLOCK_SIZE; + + err = insert_node(c, lnum, snod->offs, snod->len, + &snod->key, snod->sqnum, deletion, + &used, 0, new_size); + break; + } + case UBIFS_DENT_NODE: + case UBIFS_XENT_NODE: + { + struct ubifs_dent_node *dent = snod->node; + + err = ubifs_validate_entry(c, dent); + if (err) + goto out_dump; + + err = insert_dent(c, lnum, snod->offs, snod->len, + &snod->key, (char *)dent->name, + le16_to_cpu(dent->nlen), snod->sqnum, + !le64_to_cpu(dent->inum), &used); + break; + } + case UBIFS_TRUN_NODE: + { + struct ubifs_trun_node *trun = snod->node; + loff_t old_size = le64_to_cpu(trun->old_size); + loff_t new_size = le64_to_cpu(trun->new_size); + union ubifs_key key; + + /* Validate truncation node */ + if (old_size < 0 || old_size > c->max_inode_sz || + new_size < 0 || new_size > c->max_inode_sz || + old_size <= new_size) { + ubifs_err("bad truncation node"); + goto out_dump; + } + + /* + * Create a fake truncation key just to use the same + * functions which expect nodes to have keys. + */ + trun_key_init(c, &key, le32_to_cpu(trun->inum)); + err = insert_node(c, lnum, snod->offs, snod->len, + &key, snod->sqnum, 1, &used, + old_size, new_size); + break; + } + default: + ubifs_err("unexpected node type %d in bud LEB %d:%d", + snod->type, lnum, snod->offs); + err = -EINVAL; + goto out_dump; + } + if (err) + goto out; + } + + bud = ubifs_search_bud(c, lnum); + if (!bud) + BUG(); + + ubifs_assert(sleb->endpt - offs >= used); + ubifs_assert(sleb->endpt % c->min_io_size == 0); + + *dirty = sleb->endpt - offs - used; + *free = c->leb_size - sleb->endpt; + +out: + ubifs_scan_destroy(sleb); + return err; + +out_dump: + ubifs_err("bad node is at LEB %d:%d", lnum, snod->offs); + dbg_dump_node(c, snod->node); + ubifs_scan_destroy(sleb); + return -EINVAL; +} + +/** + * insert_ref_node - insert a reference node to the replay tree. + * @c: UBIFS file-system description object + * @lnum: node logical eraseblock number + * @offs: node offset + * @sqnum: sequence number + * @free: amount of free space in bud + * @dirty: amount of dirty space from padding and deletion nodes + * + * This function inserts a reference node to the replay tree and returns zero + * in case of success or a negative error code in case of failure. + */ +static int insert_ref_node(struct ubifs_info *c, int lnum, int offs, + unsigned long long sqnum, int free, int dirty) +{ + struct rb_node **p = &c->replay_tree.rb_node, *parent = NULL; + struct replay_entry *r; + + dbg_mnt("add ref LEB %d:%d", lnum, offs); + while (*p) { + parent = *p; + r = rb_entry(parent, struct replay_entry, rb); + if (sqnum < r->sqnum) { + p = &(*p)->rb_left; + continue; + } else if (sqnum > r->sqnum) { + p = &(*p)->rb_right; + continue; + } + ubifs_err("duplicate sqnum in replay tree"); + return -EINVAL; + } + + r = kzalloc(sizeof(struct replay_entry), GFP_KERNEL); + if (!r) + return -ENOMEM; + + r->lnum = lnum; + r->offs = offs; + r->sqnum = sqnum; + r->flags = REPLAY_REF; + r->free = free; + r->dirty = dirty; + + rb_link_node(&r->rb, parent, p); + rb_insert_color(&r->rb, &c->replay_tree); + return 0; +} + +/** + * replay_buds - replay all buds. + * @c: UBIFS file-system description object + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +static int replay_buds(struct ubifs_info *c) +{ + struct bud_entry *b; + int err, uninitialized_var(free), uninitialized_var(dirty); + + list_for_each_entry(b, &c->replay_buds, list) { + err = replay_bud(c, b->bud->lnum, b->bud->start, b->bud->jhead, + &free, &dirty); + if (err) + return err; + err = insert_ref_node(c, b->bud->lnum, b->bud->start, b->sqnum, + free, dirty); + if (err) + return err; + } + + return 0; +} + +/** + * destroy_bud_list - destroy the list of buds to replay. + * @c: UBIFS file-system description object + */ +static void destroy_bud_list(struct ubifs_info *c) +{ + struct bud_entry *b; + + while (!list_empty(&c->replay_buds)) { + b = list_entry(c->replay_buds.next, struct bud_entry, list); + list_del(&b->list); + kfree(b); + } +} + +/** + * add_replay_bud - add a bud to the list of buds to replay. + * @c: UBIFS file-system description object + * @lnum: bud logical eraseblock number to replay + * @offs: bud start offset + * @jhead: journal head to which this bud belongs + * @sqnum: reference node sequence number + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +static int add_replay_bud(struct ubifs_info *c, int lnum, int offs, int jhead, + unsigned long long sqnum) +{ + struct ubifs_bud *bud; + struct bud_entry *b; + + dbg_mnt("add replay bud LEB %d:%d, head %d", lnum, offs, jhead); + + bud = kmalloc(sizeof(struct ubifs_bud), GFP_KERNEL); + if (!bud) + return -ENOMEM; + + b = kmalloc(sizeof(struct bud_entry), GFP_KERNEL); + if (!b) { + kfree(bud); + return -ENOMEM; + } + + bud->lnum = lnum; + bud->start = offs; + bud->jhead = jhead; + ubifs_add_bud(c, bud); + + b->bud = bud; + b->sqnum = sqnum; + list_add_tail(&b->list, &c->replay_buds); + + return 0; +} + +/** + * validate_ref - validate a reference node. + * @c: UBIFS file-system description object + * @ref: the reference node to validate + * @ref_lnum: LEB number of the reference node + * @ref_offs: reference node offset + * + * This function returns %1 if a bud reference already exists for the LEB. %0 is + * returned if the reference node is new, otherwise %-EINVAL is returned if + * validation failed. + */ +static int validate_ref(struct ubifs_info *c, const struct ubifs_ref_node *ref) +{ + struct ubifs_bud *bud; + int lnum = le32_to_cpu(ref->lnum); + unsigned int offs = le32_to_cpu(ref->offs); + unsigned int jhead = le32_to_cpu(ref->jhead); + + /* + * ref->offs may point to the end of LEB when the journal head points + * to the end of LEB and we write reference node for it during commit. + * So this is why we require 'offs > c->leb_size'. + */ + if (jhead >= c->jhead_cnt || lnum >= c->leb_cnt || + lnum < c->main_first || offs > c->leb_size || + offs & (c->min_io_size - 1)) + return -EINVAL; + + /* Make sure we have not already looked at this bud */ + bud = ubifs_search_bud(c, lnum); + if (bud) { + if (bud->jhead == jhead && bud->start <= offs) + return 1; + ubifs_err("bud at LEB %d:%d was already referred", lnum, offs); + return -EINVAL; + } + + return 0; +} + +/** + * replay_log_leb - replay a log logical eraseblock. + * @c: UBIFS file-system description object + * @lnum: log logical eraseblock to replay + * @offs: offset to start replaying from + * @sbuf: scan buffer + * + * This function replays a log LEB and returns zero in case of success, %1 if + * this is the last LEB in the log, and a negative error code in case of + * failure. + */ +static int replay_log_leb(struct ubifs_info *c, int lnum, int offs, void *sbuf) +{ + int err; + struct ubifs_scan_leb *sleb; + struct ubifs_scan_node *snod; + const struct ubifs_cs_node *node; + + dbg_mnt("replay log LEB %d:%d", lnum, offs); + sleb = ubifs_scan(c, lnum, offs, sbuf); + if (IS_ERR(sleb)) { + if (c->need_recovery) + sleb = ubifs_recover_log_leb(c, lnum, offs, sbuf); + if (IS_ERR(sleb)) + return PTR_ERR(sleb); + } + + if (sleb->nodes_cnt == 0) { + err = 1; + goto out; + } + + node = sleb->buf; + + snod = list_entry(sleb->nodes.next, struct ubifs_scan_node, list); + if (c->cs_sqnum == 0) { + /* + * This is the first log LEB we are looking at, make sure that + * the first node is a commit start node. Also record its + * sequence number so that UBIFS can determine where the log + * ends, because all nodes which were have higher sequence + * numbers. + */ + if (snod->type != UBIFS_CS_NODE) { + dbg_err("first log node at LEB %d:%d is not CS node", + lnum, offs); + goto out_dump; + } + if (le64_to_cpu(node->cmt_no) != c->cmt_no) { + dbg_err("first CS node at LEB %d:%d has wrong " + "commit number %llu expected %llu", + lnum, offs, + (unsigned long long)le64_to_cpu(node->cmt_no), + c->cmt_no); + goto out_dump; + } + + c->cs_sqnum = le64_to_cpu(node->ch.sqnum); + dbg_mnt("commit start sqnum %llu", c->cs_sqnum); + } + + if (snod->sqnum < c->cs_sqnum) { + /* + * This means that we reached end of log and now + * look to the older log data, which was already + * committed but the eraseblock was not erased (UBIFS + * only un-maps it). So this basically means we have to + * exit with "end of log" code. + */ + err = 1; + goto out; + } + + /* Make sure the first node sits at offset zero of the LEB */ + if (snod->offs != 0) { + dbg_err("first node is not at zero offset"); + goto out_dump; + } + + list_for_each_entry(snod, &sleb->nodes, list) { + + cond_resched(); + + if (snod->sqnum >= SQNUM_WATERMARK) { + ubifs_err("file system's life ended"); + goto out_dump; + } + + if (snod->sqnum < c->cs_sqnum) { + dbg_err("bad sqnum %llu, commit sqnum %llu", + snod->sqnum, c->cs_sqnum); + goto out_dump; + } + + if (snod->sqnum > c->max_sqnum) + c->max_sqnum = snod->sqnum; + + switch (snod->type) { + case UBIFS_REF_NODE: { + const struct ubifs_ref_node *ref = snod->node; + + err = validate_ref(c, ref); + if (err == 1) + break; /* Already have this bud */ + if (err) + goto out_dump; + + err = add_replay_bud(c, le32_to_cpu(ref->lnum), + le32_to_cpu(ref->offs), + le32_to_cpu(ref->jhead), + snod->sqnum); + if (err) + goto out; + + break; + } + case UBIFS_CS_NODE: + /* Make sure it sits at the beginning of LEB */ + if (snod->offs != 0) { + ubifs_err("unexpected node in log"); + goto out_dump; + } + break; + default: + ubifs_err("unexpected node in log"); + goto out_dump; + } + } + + if (sleb->endpt || c->lhead_offs >= c->leb_size) { + c->lhead_lnum = lnum; + c->lhead_offs = sleb->endpt; + } + + err = !sleb->endpt; +out: + ubifs_scan_destroy(sleb); + return err; + +out_dump: + ubifs_err("log error detected while replying the log at LEB %d:%d", + lnum, offs + snod->offs); + dbg_dump_node(c, snod->node); + ubifs_scan_destroy(sleb); + return -EINVAL; +} + +/** + * take_ihead - update the status of the index head in lprops to 'taken'. + * @c: UBIFS file-system description object + * + * This function returns the amount of free space in the index head LEB or a + * negative error code. + */ +static int take_ihead(struct ubifs_info *c) +{ + const struct ubifs_lprops *lp; + int err, free; + + ubifs_get_lprops(c); + + lp = ubifs_lpt_lookup_dirty(c, c->ihead_lnum); + if (IS_ERR(lp)) { + err = PTR_ERR(lp); + goto out; + } + + free = lp->free; + + lp = ubifs_change_lp(c, lp, LPROPS_NC, LPROPS_NC, + lp->flags | LPROPS_TAKEN, 0); + if (IS_ERR(lp)) { + err = PTR_ERR(lp); + goto out; + } + + err = free; +out: + ubifs_release_lprops(c); + return err; +} + +/** + * ubifs_replay_journal - replay journal. + * @c: UBIFS file-system description object + * + * This function scans the journal, replays and cleans it up. It makes sure all + * memory data structures related to uncommitted journal are built (dirty TNC + * tree, tree of buds, modified lprops, etc). + */ +int ubifs_replay_journal(struct ubifs_info *c) +{ + int err, i, lnum, offs, _free; + void *sbuf = NULL; + + BUILD_BUG_ON(UBIFS_TRUN_KEY > 5); + + /* Update the status of the index head in lprops to 'taken' */ + _free = take_ihead(c); + if (_free < 0) + return _free; /* Error code */ + + if (c->ihead_offs != c->leb_size - _free) { + ubifs_err("bad index head LEB %d:%d", c->ihead_lnum, + c->ihead_offs); + return -EINVAL; + } + + sbuf = vmalloc(c->leb_size); + if (!sbuf) + return -ENOMEM; + + dbg_mnt("start replaying the journal"); + + c->replaying = 1; + + lnum = c->ltail_lnum = c->lhead_lnum; + offs = c->lhead_offs; + + for (i = 0; i < c->log_lebs; i++, lnum++) { + if (lnum >= UBIFS_LOG_LNUM + c->log_lebs) { + /* + * The log is logically circular, we reached the last + * LEB, switch to the first one. + */ + lnum = UBIFS_LOG_LNUM; + offs = 0; + } + err = replay_log_leb(c, lnum, offs, sbuf); + if (err == 1) + /* We hit the end of the log */ + break; + if (err) + goto out; + offs = 0; + } + + err = replay_buds(c); + if (err) + goto out; + + err = apply_replay_tree(c); + if (err) + goto out; + + ubifs_assert(c->bud_bytes <= c->max_bud_bytes || c->need_recovery); + dbg_mnt("finished, log head LEB %d:%d, max_sqnum %llu, " + "highest_inum %lu", c->lhead_lnum, c->lhead_offs, c->max_sqnum, + (unsigned long)c->highest_inum); +out: + destroy_replay_tree(c); + destroy_bud_list(c); + vfree(sbuf); + c->replaying = 0; + return err; +}
Stefan Roese
